Managing Multi-Generation Device Support with Unified SMF
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Enabled – Configuration Required
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
Added SGSN PDN modification and handovers support which includes intra-SGSN, inter-SGSN, and SGSN-to-S4-SGSN/MME handovers for complex back-to-back scenarios.
2026.01.0
Periodic Secondary RAT Usage Data Report is supported from MME over S5/S8 interface in the Modify-Bearer-Request, Delete-Session-Request, Delete-Bearer-Response, and Change-Notification-Request.
2023.04.0
Added the extended QoS support for SMF with the legacy interfaces.
2023.02.0
The Phase-2 support for 4G-UE and Option-3x feature includes:
  • DCNR based UPF selection
  • Handling Secondary RAT Data Usage Report from S-GW/MME and relaying it to CHF
  • UE Presence Reporting
  • Handling GTPV1 messages for 4G to 3G handover
  • SUPI+IP session and affinity key for 4G and WiFi handover
  • Avoiding sending of 5G QoS for 4G-only UE
  • Handling 5GCNRS and 5GCNRI indication flags from S-GW/MME
2021.01.0
First introduced.
2020.03.0
Feature Description
Important
The PGW-C term used in this chapter denotes the EPS interworking functionality supported by SMF and must not be assumed as a standalone P-GW that is used in the LTE network.
The dual connectivity enabled UEs support 4G LTE and 5G NR. Such UEs send a signal to the 4G Core Network, indicating that it’s a dual connectivity-enabled device.
When the Dual Connectivity New Radio (DCNR)-capable UE attempts to register in an MME, the MME sets the "UP Function Selection Indication Flags" IE with the DCNR flag set to 1 in the Create Session Request message. After the S-GW receives this IE over S11, it sends the IE over S5 to PGW-C. This IE transmission helps the SGW-C and PGW-C to select SGW-U and UPF, which supports dual connectivity with NR.
The SMF and PGW-C support Packet Data Unit (PDU) sessions from both the 4G-only capable device and the Option 3x capable device (NR and LTE radio connected to the EPC).
The SMF supports the following features and functionality:
DCNR-based UPF Selection
The SMF selects DCNR supported UPF for DCNR enabled session if DCNR is configured under query parameters. DCNR isn’t a mandatory query parameter for UPF selection. You can configure DCNR under the UPF Group profile.
For more information, refer to the UPF Node Selection section in the Policy and User Plane Management feature chapter.
The SMF and UPF track the usage on eNB to differentiate the NR or LTE usage for NSA devices. SMF receives usage data ports on the S5 interface in various messages and reports the usage towards CHF.
The SMF handles the periodic Secondary RAT Usage Data Report from MME over the S5 or S8 interface in the Modify Bearer Request, Delete Session Request, Delete Bearer Response, and Delete Bearer Command based on the Intended Receiver PGW-C (IRPGW) flag. SMF retains the Usage-Report if IRPGW = 1.
The SMF supports multiple instances of Secondary RAT Usage Data Report IEs. It stores reports until they are sent out to CHF based on the triggers. SMF sends out the stored secondary RAT usage data report through gtpp-ep endpoint when any of the charging triggers are met. You can configure the maximum number of stored secondary RAT usage reports under Charging Profile. SMF sends the stored secondary RAT usage data report along with offline usage report when CDR is closed due to offline usage report.
Presence Reporting Area
Presence Reporting Area (PRA) is an area defined within the 3GPP packet domain for reporting UE presence within that area due to policy control and/or charging reasons. For E-UTRAN, a PRA consists of a set of neighbor or non-neighbors tracking areas, eNBs and/or cells. You can enable the PRA functionality under the DNN profile.
The two types of Presence Reporting Areas that apply to an MME pool are UE-dedicated Presence Reporting Areas and Core Network preconfigured Presence Reporting Areas. SMF supports Core Network preconfigured PRAs.
4G to 2G or 3G Handover
During 4G to 2G or 3G handover, the SMF rejects the GTPv1 message request and reattaches with 2G or 3G for nondisrupted service continuity. If SMF drops the request, it delays the handover failure and subsequent attach to 2G or 3G.
Extended QoS Support with Legacy Interfaces
When the DCNR-enabled 4G devices connect to the SMF with the legacy interfaces and the Extended-BW-NR feature is negotiated with PCRF, the SMF sends the APN-AMBR values that are greater than 4.2 Gbps towards PCRF in the extended Bit-rates AVP.
If the SMF receives APN-AMBR values greater than 4.2 Gbps in the GTP-v2 messages from S-GW and the DCNR feature isn’t enabled, then the SMF limits the APN-AMBR value to 4.2 Gbps.
If the SMF receives extended QoS values from PCRF and the session isn’t DCNR-enabled, then the SMF limits the APN-AMBR value to 4.2 Gbps.
How it Works
The SMF generates a PDU session ID (pdu-session-id) upon receiving a Create Session Request from the 4G-only UE. The SMF validates if the request has the EPS interworking indication without the PDU session ID in the Protocol Configuration Option. The UDM provides the interworking indication to the SMF per DNN. The SMF does not use this indication for deciding whether the UE is 5G capable.
The SMF generates a pdu-session-id based on Linked EPS Bearer Identity (LBI). For the 4G sessions, the pdu-sesion-id is LBI+64 and for the Wi-Fi sessions, the pdu-session-id is LBI+80.
The SMF allows you to configure the default NSSAI under the profile DNN. The NSSAI is part of sliceInfo IE sent in the Policy Create Request to the PCF during session creation from 4G-only UEs. If the default slice is not configured, then SMF selects one of the configured slices.
When the UE is DCNR capable, and the DCNR is enabled for the session, the SMF considers that the UE is capable of supporting dual connectivity. You can configure DCNR per DNN and other NFs, such as UPF. The S-GW notifies the DCNR support to PGW-C through the UPF Selection Indication Flags IE.
Standards Compliance
The Option 3x and 4G-Only Device feature complies with the following standards:
  • 3GPP TS 23.003 [2]
  • 3GPP TS 24.301 [23]
  • 3GPP TS 29.272 [70]
  • 3GPP TS 29.274
  • 3GPP TS 29.212
Limitations
This feature has the following limitations:
  • Ultra low latency QCIs are not supported.
  • PRA:
    • PRA is supported only towards PCF and not CHF.
    • PRA is applied only based on RAT type of the connecting device and not based on the device type. It is applied to both 4G and 5G devices when connected from LTE.
    • A maximum of four PRA-IDs are processed in a single PCF update message. If a PCF update has more than four PRA-IDs, then the other PRA-IDs are ignored.
    • Only the PRA-ID will be sent in the "Presence Reporting Area Action" IE on S5 interface. User location information will not be sent.
    • Only the PRA-ID will be sent in the "repPraInfos" IE on N7 interface. User location information will not be sent.
    • PRA Set is not supported due to which "Additional PRA Information" is not supported on S5 and N7 interfaces.
  • Secondary RAT Data Usage Report:
    • Supports only Option 3 and Option 3x (NR Secondary RAT) UEs on S5 interface.
    • Does not support E-UTRAN Secondary RAT on N2 interface.
Configuring Parameters to Support 4G and 5G Devices
This section describes how to configure the SMF with the capabilities to support 4G and 5G devices.
Configuring this feature involves the following steps:
Configuring the NSSAI
This section describes how to configure the default NSSAI in SMF, which it includes in sliceInfo IE in the Policy Create Request message. The SMF sends this message towards the PCF during the session creation from 4G-only UEs.
Use the following sample configuration to configure the default NSSAI in the SMF:
config
   profile dnn profile_name
      nssai { sd sd_value | sst sst_value }
      exit
NOTES:
  • profile dnn profile_name : Specify the DNN profile name. profile_name must be an alphanumeric string.
  • nssai { sd sd_value | sst sst_value } : Configure the default NSSAI.
    • sd sd_value : Specify the slice descriptor (sd). sd_value must be a 6-digit hex string ([0-9a-fA-F]{6} - 000000 – ffffff). For example, 1A2B3c.
    • sst sst_value : Specify the slice type (sst) value. sd_value must be an integer in the range of 0–255.
Enabling DCNR in DNN Profile
To enable SMF to support the DCNR capability for the sessions handled using the DNN profile, use the following sample configuration:
config
      dcnr { false | true }
      exit
NOTES:
  • dcnr { false | true } :
    • false : Configure the DNN profile to have DCNR flag set to false. The DCNR configuration is disabled by default.
    • true : Configure the DNN profile to have DCNR flag set to true.
      This configuration enables the SMF to support DCNR capability. When the DCNR capability is enabled, the UE sends the DCNR flag to indicate that it supports dual connectivity.
Configuring UPF Selection
This section describes how to enable the DCNR flag and configure the appropriate precedence for DCNR.
Defining the UPF Group
Use the following sample configuration to configure the UPF group and define DCNR in the UPF Group profile.
config
   profile upf-group profile_name
      exit
NOTES:
  • profile upf-group profile_name : Specify the UPF group name that must be associated to the specified UPF network configuration. profile_name must be an alphanumeric string.
  • dcnr { false | true } : Configure the DCNR capability.
    • false : Disable support for DCNR. This is the default setting.
    • true : Enable support for DCNR.
Associating UPF Selection Query Parameters
Use the following sample configuration to associate the defined UPF group with the UPF network element in the DNN profile.
config
      upf-selection-policy  upfpolicy_name
      exit
NOTES:
  • policy dnn profile_name : Enter the DNN Profile configuration mode. profile_name must be an alphanumeric string.
  • upf-selection-policy upfpolicy_name : Specify the name of the UPF selection policy that must be associated to the DNN profile. upfpolicy_name must be an alphanumeric string.
Configuring Precedence for DCNR
Use the following sample configuration to configure the appropriate precedence for DCNR in the UPF Selection Policy profile.
config
   policy upf-selection upf_name
      precedence precedence_num
         dcnr
         exit
      exit
NOTES:
  • policy upf-selection upf_name : Specify the UPF policy name that must be associated with the DNN profile. profile_name must be an alphanumeric string.
  • precedence precedence_num : Assign the precedence value to the UPF policy. precedence_num must be an integer in the range of 1–4.
  • dcnr : Configure the DCNR capability.
Configuring Secondary RAT Usage Report
Use the following sample configuration to configure secondary RAT usage reports before being sent to CHF.
config
   profile charging profile_name
      max-secondary-rat-reports report_range
      exit
NOTES:
  • profile charging profile_name : Enter the Charging Profile configuration mode.
  • max-secondary-rat-reports report_range : Configure the maximum number of secondary RAT usage reports to trigger GTPP (Gz) or CHF update. report_range must be an integer in the range of 0–50. Default value: 0.
Configuring Presence Reporting
Use the following sample configuration to configure presence reporting.
config
   profile dnn dnnprofile_name
      presence-reporting { false | true }
      exit
NOTES:
  • profile dnn dnnprofile_name : Enter the DNN Profile Configuration mode.
  • presence-reporting { false | true } : Configure presence reporting for the DNN.
    • false : Disable presence reporting. This is the default setting.
    • true : Enable presence reporting.
Configuration Verification
To verify the configuration, use the following command:
show subscriber supi supi_id nf-service smf
In the output of the preceding show command, check the value associated with the field "dncr". This field displays one of the following values:
  • Enabled
  • None
  • UE Requested and Enabled
If the feature is configured, then the "dcnr" field displays "Enabled".
The following configuration is an example output of the show subscriber supi nf-service smf command:
unknown] smf# show subscriber supi imsi-123456789012345 nf-service smf
subscriber-details
"subResponses": [
"status": true,
"genericInfo": {
"sScMode": 1,
"chargEnabled": true,
"uetimeZone": "+00:15+1",
"allocatedIp": "209.165.201.12",
"eUtranLocation": {
"ecgi": {
"mcc": "123",
"mnc": "456",
"eutraCellId": "1234567"
"tai": {
"mcc": "123",
"mnc": "456",
"tac": "1820"
"alwaysOn": "None",
"dcnr": "Enabled",
"policySubData": {
 "TotalDynamicRules": 3,
Presence Information: "Enabled",
 "praIdList": [  -> list of all enabled PRA IDs
          "8388608",  Status = IN
          "8388618" Status = OUT
OAM Support
This section describes operations, administration, and maintenance information for this feature.
Statistics Support
The SMF uses the "dcnr" label in the session gauge "smf_session_counter" and "smf_service_stats" for collecting the DCNR session count. When the SMF session is DCNR supported, the "dcnr" label value is enabled. The label does not support non-DCNR sessions.
The following is a sample query to count the active DCNR SMF sessions:
nts{action_type="rejected",app_name="smf",cluster="smf",data_center="unknown",
failure_type="hdr_decode_failure",hdr_decode_fail_reason="",instance_id="0",interface_type="
",message_type="",reject_cause="",service_name="gtpc-ep"} 2
smf_session_counter: sum (smf_session_counters{dcnr_on="enable"}) by (dcnr)
smf_service_stats: sum (smf_session_stats{dcnr_on="enable"}) by (dcnr, status, reason)
smf_session_counters{ presence-reporting ="enable"}) by (presence-reporting)
DCNR Session Count
For DCNR, Session Count supports the "dcnr" label in the existing session gauge "smf_session_counter". If the SMF session is a DCNR session, then the "dcnr" label value is "enable", otherwise it is "disable" for DCNR session.
The following is a sample query to count the DCNR active SMF sessions:
For DCNR statistics, the existing "smf_service_stats" counter supports the "dcnr" label. For DCNR sessions, this counter pegs the following labels and values:
  • Attempt Statistics – dcnr= "enable" and status= "attempted"
  • Success Statistics – dcnr= "enable" and status= "success"
  • Failure Statistics – dcnr= "enable" and status= "failures"
The following is a sample query for DCNR statistics:
Secondary RAT Data Usage Reports
The Secondary-Rat-Data-Usage-Reports support the "smf_secondary_rat_usage_report_stats" counter. Labels for these statistics include ebi, qfi, rat_type, reason, service_name, and status. This counter pegs with the following labels and values:
  • ebi=ebi-val
  • qfi=qfi-val
  • rat_type=NR
  • reason=success/failure
  • service_name=smf-service
  • status=ReceivedFromSgw/SentToChf
sum (smf_secondary_rat_usage_report_stats”) by (qfi, status, reason)
Presence Reporting
For Presence Reporting, Session Count supports the "pra" label in the existing session gauge "smf_session_counter". If the SMF session has presence reporting enabled, then the "presence-reporting" label value is "enable" else it is "none" if presence reporting is not enabled.
sum (smf_session_counters{ pra ="enable"}) by (pra)
For Presence Reporting, statistics support the "presence-reporting" label in the existing counter "smf_service_stats". For presence-reporting session, this counter pegs the following labels and values:
  • Attempt Statistics – pra = "enable" and status= "attempted"
  • Success Statistics – pra = "enable" and status= "success"
  • Failure Statistics – pra = "enable" and status= "failures"
sum (smf_session_stats{ pra ="enable"}) by (pra, status, reason)
Bulk Statistics
The Option 3x and 4G-Only Device feature supports the following bulk statistics in SMF schema:
Bulk Statistics Name
Statistics Type
Trigger
Description
Gauge
Increments or decrements for session attach or detach.
Indicates the total number of currently active SMF sessions. You can filter the active session using labels, such as "dcnr=enable" for the DCNR session count.
smf_session_stats
Counter
Increments for success or failures of the call flow.
Indicates the statistics for call flow states such as attempted, success, and failures. You can filter the statistics using labels, such as “dcnr=enable” for only DCNR statistics.
The Secondary RAT Data Usage Report functionality supports the following bulk statistics:
smf_secondary_rat_usage_ report_stats
Counter
Increments for the status of the secondaryRatDataUsage Report processing.
Displays the statistics for secondaryRatUsageReports processing for call flow status such as "ReceivedFromSgw" and "SentToCHF". You can filter the statistics using labels, such as reason and QFI.
OFCS_CDR_MESSAGE_STATS
Counter
A new label "Trigger Type" captures the event when a configured Secondary RAT usage limit is reached. The trigger type label contains "GZ_SECONDARY_RAT_USAGE_LIMIT_REACHED" value.
The PRA functionality supports the following bulk statistics:
Gauge
Indicates the total number of current active SMF sessions. You can filter the session using labels, such as "pra=enable" for the presence reporting enabled session count.
smf_session_stats
Counter
Indicates the statistics for call flow states such as attempted, success, and failures. You can filter the statistics using labels, such as “pra=enable” for only presence-reporting statistics.
Troubleshooting Information
This section provides information on using the command line interface (CLI) commands, alerts, logs, and metrics for troubleshooting issues that may arise during system operation.
Subscriber Details with DCNR and Presence Reporting Enabled
The show subscriber nf-service smf supi supi_id full CLI command displays the DCNR active session with presence reporting enabled for the Option-3x feature.
Note
In 2021.02 and later releases, the namespace keyword is deprecated and replaced with the nf-service keyword.
[unknown] smf# show subscriber nf-service smf supi imsi-310260789012345 full
subscriber-details
  “subResponses”: [
      “status”: true,
      “genericInfo”: {
        “supi”: “imsi-310260789012345”,
        “pei”: “imei-123456786666660”,
        “pduSessionId”: 5,
        “pduSesstype”: “Ipv4PduSession”,
        “accessType”: “3GPP_ACCESS”,
        “dnn”: “fast.t-mobile.com”,
        “plmnId”: {
          “mcc”: “123”,
          “mnc”: “456”
        “alwaysOn”: “None”,
        “dcnr”: “Enabled”,
        “wps”: “Non-Wps Session”,
        “ratType”: “EUTRA”,
        “ueType”: “NR Capable UE”,
        “iwkEpsInd”: true,
        “sessTimeStamp”: “2021-01-12 12:40:39.931012285 +0000 UTC”,
        “callDuration”: “4m25.36784895s”,
        “ipPool”: “poolv4”,
        “commonId”: 16777223,
        “linkedEbi”: 5,
        “smfIwkEpsInd”: true,
        “snssai”: {
          “sd”: “Abf123”,
          “sst”: 1
        “authStatus”: “Unauthenticated”,
        “roamingStatus”: “Roamer”,
        “uePlmnId”: {
          “mcc”: “310”,
          “mnc”: “260”
      “policySubData”: {
        “TotalDynamicRules”: 2,
        “TotalFlowCount”: 2,
        “TotalNonGBRFlows”: 1,
        “TotalGBRFlows”: 1,
        “presenceReporting”: “Enabled”,
        “praList”: [
            “praId”: “0x80000b”,
            “presenceState”: “Inactive”
            “praId”: “0x800000”,
            “presenceState”: “InArea”
            “praId”: “0x80000a”,
            “presenceState”: “OutOfArea”
Option-3x: DCNR Enabled UE Alerts
This section describes the alerts supported for DCNR enabled UEs with presence-reporting enabled. You can enhance these alerts as per 4G procedure or as per the intent of the end user.
Examples of DCNR statistics or gauges are pdn_sess_create, pdn_inter_sgw_handover, pdn_mbr, pcf_req_ded_brr_mod, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, delete_session_request, smf_initiated_pdn_detach, ue_req_pdn_sess_rel, and so on.
DCNR UE Attach Failure Threshold Alert
Use the following example to configure alerts related to DCNR UE Attach Failure Threshold.
alerts rules group DCNRUEs
 rule DCNR_UE_SR
  expression "sum by (namespace) (increase(smf_service_stats{app_name=\"smf\", dcnr=\"enable\", rat_type!=\"EUTRA\", status=\"success\", procedure_type=\"pdn_sess_create\"}[5m])) / sum by (namespace) (increase(smf_service_stats{app_name=\"smf\", dcnr =\"enable\", rat_type!=\"EUTRA\", status=\"attempted\", procedure_type=\"pdn_sess_create\"}[5m])) < 0.10"
  severity   major
  type       "Communications Alarm"
  annotation summary
   value "This alert is fired when attach success rate of DCNR enabled UE lesser than threshold"
  exit
 exit
DCNR UE Attach Failure Threshold Alert with Presence Reporting
Use the following example to configure alerts related to DCNR UE Attach Failure Threshold with presence reporting enabled.
rule DCNR_UE_PRA_ENABLE_SR
  expression "sum by (namespace) (increase(smf_service_stats{app_name=\"smf\", dcnr=\"enable\", rat_type!=\"EUTRA\", status=\"success\", procedure_type=\"pdn_sess_create\", pra=\"enable\"}[5m])) / sum by (namespace) (increase(smf_service_stats{app_name=\"smf\", dcnr =\"enable\", rat_type!=\"EUTRA\", status=\"attempted\", procedure_type=\"pdn_sess_create\", pra=\"enable\"}[5m])) < 0.10"
  severity   major
  annotation summary
   value "This alert is fired when attach success rate of DCNR enabled UE and presence reporting enabled lesser than threshold "
  exit
 exit
DCNR UE Bulk Statistics
Use the following SMF service bulk statistics to monitor the failures or issues associated with DCNR UEs.
Table 3. DCNR UE
Query
Description
4G_DCNRUE_Attempted
bulk-stats query 4G_DCNRUE_Attempted expression "sum(smf_service_stats {dcnr='enable',status='attempted', rat_type='EUTRA'}) by (namespace)" exit
4G_DCNRUE_Success
bulk-stats query 4G_DCNRUE_Success expression "sum(smf_service_stats {dcnr='enable',status='success', rat_type='EUTRA'}) by (namespace)" exit
4G_PRA_ENABLE_Attempted
bulk-stats query 4G_PRA_ENABLE_Attempted expression "sum(smf_service_stats {pra='enable',status='attempted', rat_type='EUTRA', procedure_type!='create_session_request'}) by (namespace)" exit
4G_PRA_ENABLE_Success
bulk-stats query 4G_PRA_ENABLE_Success expression "sum(smf_service_stats {pra='enable',status='success', rat_type='EUTRA', procedure_type!='create_session_request'}) by (namespace)" exit
Option-3x Device Specific Error Logs
This section provides the basic error conditions and logs that are captured to debug the failures for the Option-3x feature.
DCNR Disabled UE or 4G capable UE only
The following example displays the error log for DCNR disabled UE or 4G capable UE only.
2021/01/24 10:11:22.648 smf-service [ERROR] [GenericGtpMsg.go:1811] [smf-service.smf-app.sgw] secRatUsageRpt recvd wrongly for DNCR disbled UE, ignoring report
2020/12/19 13:17:17.834 smf-service [ERROR] [GenericGtpMsg.go:1834] [smf-service.smf-app.sgw] secRatUsageRpt recvd wrongly for 4gOnly UE, ignoring report
Secondary RAT Usage with invalid EBI
The following example displays the error log for secondary RAT usage with invalid EBI.
2021/01/24 11:38:18.917 smf-service [DEBUG] [GenericGtpMsg.go:1824] [smf-service.smf-app.sgw] Secondary Rat Data Usage Report Recvd
2021/01/24 11:38:18.917 smf-service [WARN] [IntMethods.go:137] [smf-service.Policy.gen] Qos Flow not found with EBI [8]
2021/01/24 11:38:18.917 smf-service [ERROR] [GenericGtpMsg.go:1853] [smf-service.smf-app.sgw]  Qfi invalid in secRatUsageRpt
Secondary RAT Usage invalid RAT Type
The following example displays the error log for secondary RAT usage with invalid RAT type.
2021/01/24 11:42:21.474 smf-service [DEBUG] [GenericGtpMsg.go:1824] [smf-service.smf-app.sgw] Secondary Rat Data Usage Report Recvd
2021/01/24 11:42:21.474 smf-service [ERROR] [GenericGtpMsg.go:1861] [smf-service.smf-app.sgw]  Rat type invalid in secRatUsageRpt
Secondary RAT Usage with intended PGW set to zero
The following example displays the error log for secondary RAT usage with intended P-GW set to zero (IRPGW:0).
2021/01/24 11:33:10.390 smf-service [DEBUG] [GenericGtpMsg.go:1824] [smf-service.smf-app.sgw] Secondary Rat Data Usage Report Recvd
2021/01/24 11:33:10.390 smf-service [ERROR] [GenericGtpMsg.go:1865] [smf-service.smf-app.sgw]  secRatUsageRpt.IRPGW is false
PRA ID received greater than four
The following example displays the error log when PRA ID received is greater than four.
2021/01/24 14:48:26.085 smf-service [DEBUG] [policy_types.go:659] [smf-service.Policy.gen] praConfig:true for dnn:fast.t-mobile.com
2021/01/24 14:48:26.085 smf-service [DEBUG] [policy_pcf.go:1939] [smf-service.Policy.gen] Added PRA ID: 9388618
2021/01/24 14:48:26.085 smf-service [DEBUG] [policy_pcf.go:1939] [smf-service.Policy.gen] Added PRA ID: 9388608
2021/01/24 14:48:26.085 smf-service [DEBUG] [policy_pcf.go:1939] [smf-service.Policy.gen] Added PRA ID: 8388618
2021/01/24 14:48:26.085 smf-service [DEBUG] [policy_pcf.go:1939] [smf-service.Policy.gen] Added PRA ID: 9388619
2021/01/24 14:48:26.085 smf-service [WARN] [policy_pcf.go:1934] [smf-service.Policy.gen] Max 4 PRAs allowed, ignoring the PRA-ID (8388608) from PCF
2021/01/24 14:48:26.085 smf-service [WARN] [policy_pcf.go:1934] [smf-service.Policy.gen] Max 4 PRAs allowed, ignoring the PRA-ID (8388619) from PCF
2G and 3G network integration in SMF
2G and 3G network integration overview
Table 4. Feature History Table
Feature
Release
Description
SMF-initiated Update PDP Context Request suppression
2026.01.0
This feature supports supress network initiated UPC request for 2G 3G calls..
Command introduced:
[ no ] deactivate-features 2g-3g-nrupc - This command is configured under the DNN profile.
Default Settings: Disabled—Configuration required to Enable
GTPv1 QoS negotiation
2026.01.0
This feature supports QoS negotiation to manage and enforce QoS for 2G and 3G calls within the Converged Core architecture.
SGSN PDN modification and handover support
2026.01.0
This enhancement provides comprehensive SGSN PDN modification and handover support, including intra-SGSN and inter-SGSN, SGSN-to-S4-SGSN and MME handovers for complex back-to-back scenarios.
2G and 3G session attach and detach procedures over GTPv1
2025.03.0
This features includes details on 2G and 3G session attach and detach support on SMF for v1SGSN. It captures the GTPv1 messages/procedure and information elements that are translated to GTPv2 equivalents.
QoS negotiation for 2G and 3G sessions
2025.03.0
This feature introduces Quality of Service (QoS) negotiation capabilities for 2G and 3G subscribers utilizing the S4-SGSN in SMF. It enables dynamic and automated adjustments to the QoS parameters of the default bearer based on triggers originating from the Home Location Register (HLR) or PCF.
This allows the network to adapt to changing conditions and subscriber needs, optimizing resource utilization and enhancing the user experience.
S4-SGSN session handover and mobility management for 2G and 3G networks
2025.03.0
This feature details the handling of Modify Bearer Requests (MBR) and handover scenarios within the context of 2G and 3G support for S4SGSN in SMF. It outlines the procedures for user location changes, inter-RAT handovers (4G to 3G/2G and 3G/2G to 4G ), intra-RAT handovers (3G SGW handover), and handovers involving dedicated bearers.
This ensure that the sessions are maintained during handovers, minimizing disruption to user applications.
2G and 3G session attach and detach procedures for S4-SGSN
2025.02.0
This feature adds support to the SMF for managing attach and detach functions originating from S4-SGSN (Serving GPRS Support Node). This allows the consolidation of 2G/3G and 4G/5G network control within a single converged core. By integrating the networks, you can simplify the network management and reduce the operational costs.
Commands Introducted:
profile converged-core activated-features 2g3g —This CLI command enables S4-SGSN support for 2G and 3G RAT type in SMF.
Default Settings:Disabled - Configuration Required to Enable
The inclusion of 2G and 3G network intergartion in Converged Core (CC) is to support the full spectrum of radio access technologies such as 2G, 3G, 4G,Wi-Fi and 5G networks on a single environment. This eliminates the need to maintain separate networks for different radio access types.
The 2G and 3G session attach and detach procedures for S4-SGSN feature includes 2G and 3G RAT types in the existing SMF set by leveraging the support of SMF for SBI interfaces. The features and functionalities supported at the SMF for 4G are extented to 2G and 3G networks.
The key capablities of this feature are listed here:
  • GTPv2 protocol support: Implements the necessary GTPv2 protocol handling within the SMF to process attach and detach signaling messages originating from S4-SGSN nodes.
  • Converged core integration: Allows for the management of 2G/3G subscribers within the same SMF instance as 4G/5G subscribers, streamlining network management and reducing the need for separate control plane entities.
  • Inter-RAT mobility: Supports mobility scenarios between 2G/3G and 4G/5G networks, enabling a consistent user experience across different radio access technologies (RATs).
Standard compliance for 2G and 3G network integration with converged core
The 2G and 3G network integration feature complies with the following 3GPP standards for configuring N7 and N40 interfaces and common data types in SMF:
  • 3GPP TS 29.512, Version 17.3.0—For N7 interface
  • 3GPP TS 32.291, Version 17.0.0—For N40 interface
  • 3GPP TS 29.571, Version 17.3.0—For common data types
When interacting with Release 15 or Release 16 PCF or CHF, SMF appplies the following constraints:
  • Excludes unsupported attribute values from N7 and N40 messages sent to PCF and CHF, including RATType and User Location Information (ULI).
  • Does not include the associated UserLocationInfoTime information element when ULI is not sent.
Prequisites for 2G and 3G network integration with converged core
The prerequistes for 2G and 3G network integration feature in SMF are listed here:
  • SMF supports interoperability with PCF and CHF on 3GPP Release 15 and Release 16 with limited attribute handling. Ensure that PCF and CHF use 3GPP Release 17 or later to enable full support of all attributes and information elements.
  • You should migrate to N7 or N40 interface from Gx,Gy, and Gz interface for 2G and 3G calls and interaction.
  • Secondary PDR will not be created during 2G and 3G attach, as the handover to 5G network will not be allowed if the UE is attached to 2G or 3G network.
Limitations of 2G and 3G network integration with converged core
Here are the limitations of 2G and 3G network integration feature in SMF:
  • Secondary PDP context (Network or UE) is not supported in this feature.
  • The 2G and 3G networks do not support DHCP/OC/VoGX functionalities that are not supported in SMF for 4G network.
  • The Dual-Connectivity with New Radio (DCNR) is not received in the CSR request from S4-SGSN nodes. Hence, DCNR support is not required in SMF.
  • N10 subscription fetch, subscription to notifications, and registration functionalities are skipped for UTRAN/GERAN attach, as the S4-SGSN/SGSN retrieves the subscription data from HSS/HLR.
Attach and detach procedure call flows for S4-SGSN
The attach and detach procedures are explained through PDN connect call flow and PDN disconnect call flow over S4-SGSN network.
PDN connect over S4-SGSN
This section describes the call flow and stages in PDN connect over S4-SGSN.
Figure 1. PDN connect over S4-SGSN
The given stages describe the interactions between SMF and other NFs for initial attach on GERAN and UTRAN through SMF:
  1. SMF receives CreateSessionRequest notification from SGW. The RAT type in CreateSessionRequest is GERAN for 2G attach and UTRAN for 3G attach.
    The User Location Information (ULI) contains any one of the given values:
    • Routing Area Identification (Rai)
    • Serving Area Identifier (Sai)
    • Cell Global Identification (Cgi)
    • Serving Area Identifier + Routing Area Identification
    • Cell Global Identification + Routing Area Identification
    Note
    UDM interaction is enabled for 2G and 3G RAT types.
    Refer the Interface level IE information to support S4-SGSN for more information on IE and RAT type values for different notifications.
  2. SMF sends PolicyCreateRequest message to PCF to establish the policy association.
  3. SMF receives PolicyCreateSuccess message from PCF with policy charging and control information.
  4. UE IP address is allocated and SMF sends PolicyUpdateRequest message to PCF with trigger UE_IP_CH.
  5. SMF receives PolicyUpdateSuccess message from PCF.
  6. Based on the charging policies received from PCF, the SMF initiates ChargingDataRequest message towards CHF.
  7. SMF receives ChargingDataSuccess message from CHF and receive these notifications:
    • CC triggers at Session/RG Level
    • Session level Time/Volume Limits
    • Time/Volume Limits at RG level
    • Quota at RG Level
  8. SMF sends N4SessionEstablishmentRequest message towards UPF to relay information related to PDRs, QERs, FARs and URRs.
  9. SMF receives N4SessionEstablishmentSuccess message from UPF.
  10. The SMF sends CreateSessionResponse message to S-GW and includes the bearer information and Tunnel Endpoint Identifier (TEID) for the default bearer.
PDN disconnect over S4-SGSN
This section describes the PDN disconnect over S4-SGSN call flows.
UE-initiated release
The call flow illustrates the UE-initiated release for PDN disconnect over S4-SGSN.
Figure 2. UE-initiated PDN disconnect
The following procedure explains the UE-initiated release for PDN disconnect over S4-SGSN:
  1. SMF receives DeleteSessionRequest message from SGW.
    Note
  2. SMF sends N4SessionReleaseRequest message to remove the user plane resources UPF.
  3. SMF receives N4SessionReleaseSuccess message with final usage from UPF.
  4. SMF sends DeleteSessionResponse message to SGW.
  5. SMF sends ChargingReleaseRequest message with final usage to CHF.
  6. SMF receives ChargingReleaseSuccess message from CHF.
  7. SMF sends PolicyDeleteRequest message to PCF to delete the policy association to PCF.
  8. SMF receives PolicyDeleteSuccess message from PCF.
SMF-initiated release
The call flow illustrates the SMF-initiated release for PDN disconnect over S4-SGSN.
Figure 3. SMF-initiated PDN disconnect
The given procedure explains the SMF-initiated release for PDN disconnect:
  1. The SMF-initiated release is triggered using the clear subscriber command.
    Note
  2. SMF sends N4SessionModificationRequest message with drop action set in update FAR to UPF.
  3. SMF receives N4SessionModificationSuccess message from UPF.
  4. SMF sends DeleteBearerRequest message to SGW to delete the bearer context.
  5. SMF receives DeleteBearerSuccess message from SGW.
  6. SMF sends N4SessionReleaseRequest message to UPF to remove the user plane resources.
  7. SMF receives N4SessionReleaseSuccess message with final usage from UPF.
  8. SMF sends ChargingReleaseRequest message to CHF with final usage.
  9. SMF receives ChargingReleaseSuccess message from CHF.
  10. SMF sends PolicyDeleteRequest message to PCF to delete the policy association.
  11. SMF receives PolicyDeleteSuccess message from PCF.
This section provides information about the IE and RAT type values for notifications from S5/S8, N7, N40, and N4 interfaces.
S5/S8 interface
Here is the set of new enums and corresponding values that are supported on the S5/S8 interface when the control signaling originates from S4-SGSN node in the operator network.
Table 5. S5/S8 interface
Interface S5/S8 messages
IE
Details
Message Create/Modify Session Request
GTPV2_IE_RAT_TYPE
GERAN/UTRAN
Create/Modify/ Delete Session Request
GTPV2_IE_ULI
The User Location Information (ULI) contains any one of the these listed values:
  • Rai
  • Sai
  • Cgi
  • Cgi + Rai
  • Sai + Rai
N7 interface
Refer the following IE information for N7 interface messages:
Table 6. N7 interface
Interface N7 messages
IE
Details
Message :: N7 Create Request
SmPolicyContextData- >ServNfId
AnGwAddr for GTPv2 2G/3G and SgsnAddr for GTPv1 2G/3G call
SmPolicyContextData->RatType
GERA/UTRA
SmPolicyContextData->AccessType
3GPP_ACCESS
SmPolicyContextData-> PolicyCtrlReqTriggers
'SCELL_CH', 'SAREA_CH', 'SCNN_CH'
SmPolicyContextData-> UserLocationInfo-> GeraLocation/UtraLocation
The GeraLocation or UtraLocation may contain any one of the these values:
  • Rai
  • Sai
  • Cgi
  • Cgi + Rai
  • Sai + Rai
SmPolicyContextData->Suppfeat
The 2G3GIWK flag bit is set to 1, if the PCF release version is greater than and equal to 17.3.0 and the 2g3g CLI is configured.
Message :: N7 Update Request
SmPolicyUpdateContextData ->ServNfId
SmPolicyUpdateContextData ->RatType
GERA/UTRA
SmPolicyUpdateData->ServNfId
SmPolicyUpdateData-> UserLocationInfo-> GeraLocation/UtraLocation
The GeraLocation or UtraLocation contains any one of the these values:
  • Rai
  • Sai
  • Cgi
  • Cgi + Rai
  • Sai + Rai
Message :: N7 Delete Request
SmPolicyDeleteData-> UserLocationInfo-> GeraLocation/UtraLocation
  • Rai
  • Sai
  • Cgi
  • Cgi + Rai
  • Sai + Rai
N40 interface
Refer the following IE information for N40 interface messages:
Table 7. N40 interface
Interface N40 messages
IE
Details
Message :: ChargingDataRequest
PDUSessionInformation-> RatType
GERA/UTRA
nfConsumerIdentification-> nodeFunctionality
SMF
PDUSessionInformation ->servingNetworkFunctionID -> nodeFunctionality
SGW for GTPv2 2G/3G and SGSN for GTPv1 2G/3G call
  • Rai
  • Sai
  • Cgi
  • Cgi + Rai
  • Sai + Rai
Message :: ChargingDataResponse
[]triggers
Trigger Type CGI_SAI_CHANGE RAI_CHANGE
MultiUnitInformation-> []triggers
Message :: ChargingReleaseRequest
PDUContainerInformation-> RatType
GERA/UTRA
PDUContainerInformation-> ServingNodeID-> nodeFunctionality
GERA/UTRA
SMF
  • Rai
  • Sai
  • Cgi
  • Cgi + Rai
  • Sai + Rai
N4 interface
Refer the following IE information for N4 interface messages:
Table 8. N4 interface
Interface N4
IE
Details
PFCP Establishment Request
PFCP Modification Request
Subscriber Params->Rat Type
The RAT Type value can be either 1 or 2.
1 - UTRAN
2 - GERAN
Subscriber Params->Uli
  • Rai
  • Sai
  • Cgi
  • Cgi + Rai
  • Sai + Rai
Subscriber Params->Sgsn address
The SGSN address can be either IPv4/IPv6.
Subscriber Params->Ggsn address
The GGSN address can be either IPv4/IPv6.
Create_FAR ->Outer Header Creation ->Teid
The TEID value contains the SGW GTP-U TEID.
Note
The User Location Information - Location Area Identifier (Lai) is not supported in S5/S8, N7, N40, and N4 interfaces.
Enable S4-SGSN for 2G and 3G RAT type
This configuration allows to enable the S4-SGSN support for 2G and 3G RAT type in SMF.
Procedure
Step 1
Enter the converged core profile name converged-core <name> in congifuration mode.
config
profile converged-core <name>
Step 2
Enter the 2g3g flag to enable S4-SGSN in SMF and end the command.
config
end
Here is the sample configuration:
[smf] smf(config)# profile converged-core cc activated-features ?
Possible completions:
  2g3g               This flag enables the support for 2G 3G RAT on SMF
  upf-blocklisting   This flag enables upf blocklist feature
[smf] smf(config)# profile converged-core cc activated-features 2g3g
Tue Mar  4  13:28:27.850 UTC+00:00
[smf] smf(config-converged-core-cc)#
Note
To disable the configuration, use the given syntax:
config
   [no] activated-features 2g3g
end
If the configuration is disabled, the S4-SGSN (v2) messages are rejected with appropriate System Failure error code and gtpc_app_total_unexpected_gtpc_msg_events metric is incremented.
Step 3
Optional: Run the show running-config profile converged-core cc CLI command to verify if the 2g3g flag is enabled.
[smf] smf# show running-config profile converged-core cc
Tue Mar  4  13:30:51.799 UTC+00:00
 supported-features [ rolling-upgrade-all ]
exit
Configure N40 charging compliance version
This procedure allows to configure the 3GPP Specification TS 32.291 of Version 17.0.0 in N40 charging for 2G and 3G sessions in SMF.
Procedure
Step 1
Enter the compliance profile name in configuration mode.
config
profile compliance < compliance profile name>
Step 2
Enter the nchf-convergedcharging version as 17.0.0 and end the command.
config
service nchf-convergedcharging version spec 17.0.0
end
[smf] smf(config-compliance-comp1)# service nchf-convergedcharging version spec ?
Description: 3gpp nchf-convergedcharging Spec version number - 15.0.0 [default]
  [17.0.0] 15.0.0  15.1.0  15.2.1  15.3.0  15.3.0.custom  15.3.0.std  15.4.0  16.8.1  17.0.0
[smf] smf(config-compliance-comp1)# service nchf-convergedcharging version spec 17.0.0
Mon Oct  21 12:19:46.838 UTC+00:00
[smf] smf(config-service-nchf-convergedcharging)#
Step 3
Optional: Run the show running-config profile compliance comp1 service nchf-convergedcharging CLI command to verify the charging compliance version for N40 interface.
[smf] smf# show running-config profile compliance comp1 service nchf-convergedcharging
Wed Oct  23 11:49:52.490 UTC+00:00
  version uri v1
  version full 1.0.0
  version spec 17.0.0
 exit
exit
[smf] smf#
Configure N7 policy compliance version
This procedure allows to configure the 3GPP Specification TS 29.512 of Version 17.3.0 in N7 Policy for 2G and 3G Sessions in SMF.
Procedure
Step 1
config
Step 2
Enter the nchf- smpolicycontrol version as 17.3.0 and end the command.
config
service nchf- smpolicycontrol version spec 17.3.0
end
[smf] smf(config-compliance-comp1)# service npcf-smpolicycontrol version spec ?
Description: 3gpp npcf-smpolicycontrol Spec version number - 15.2.0 [default]
  [17.3.0]  15.0.0  15.2.0  15.4.0  16.10.0  17.3.0
[smf] smf(config-compliance-comp1)# service npcf-smpolicycontrol version spec 17.3.0
Mon Oct  21 12:21:22.960 UTC+00:00
[smf] smf(config-service-npcf-smpolicycontrol)
Step 3
Optional: Run the show running-config profile compliance comp1 service npcf-smpolicycontrol CLI command to verify the policy compliance version for N7 interface.
[smf] smf# show running-config profile compliance comp1 service npcf-smpolicycontrol
Wed Oct  23 11:49:01.841 UTC+00:00
  version uri v1
  version full 1.0.0
  version spec 17.3.0
 exit
exit
Show commands and clear session commands for 2G and 3G sessions
This section provides information on the show commands and clear session commands associated with 2G and 3G network intergation feature in SMF.
Display subscriber information for 3G session with UTRAN RAT type
Here is the sample output for show subscriber CLI command for 3G session with UTRAN RAT type:
show subscriber nf-service smf supi imsi-123456789012345 full
  "subResponses": [
      "status": true,
      "genericInfo": {
        "pduState": "pduState_None",
        "supi": "imsi-123456789012345",
        "pei": "imei-123456786666660",
        "allocatedIp": "12.0.0.1",
        "alwaysOn": "None",
        "dcnr": "None",
        "wps": "Non-Wps Session",
        "ratType": "UTRA",
        "ueType": "NR Capable UE",
        "sessTimeStamp": "2025-03-03 12:34:35.409932765 +0000 UTC",
     "ipAllocationBy": "Dynamic",
        "anType": "3GPP_ACCESS",
        "utranLocation": {
          "cgi": {
            "mcc": "123",
            "mnc": "456",
            "lac": "04d2",
            "cellId": "0004"
          "ueLocationTimestamp": "2025-03-03T12:34:35Z"
        "initialRatType": "UTRA"
      "policySubData": {
        "TotalDynamicRules": 1,
        "TotalFlowCount": 1,
        "TotalNonGBRFlows": 1,
     "access3GSubData": {
        "localTeid": 2097154,
        "lbi": 5,
        "bearerContexts": [
            "ebi": 5,
            "defBrr": true,
            "dlFteid": {
              "teid": 1647,
              "ipaddr": "10.1.34.62"
   "AnGwAddr": {  For GTPv2 3G call
    "anGwIpv4Addr": "10.1.0.227"
   "sgsnAddr": {  For GTPv1 3G call
   "sgsnIpv4Addr": "10.1.0.227"
        "gtpVersion": "GtpV2"
The output for 2G session is similar with GERAN as RAT type.
Display session count information
Use the show subscriber count CLI command to display the number of active sessions for a specific RAT type. Here is an example:
show subscriber count nf-service smf rat utran
subscriber-details
  "sessionCount": 1
Note
The RAT type based show and clear session options are enhanced for 2G and 3G sessions as given here:
  • show subscriber nf-service smf rat geran/utran​
  • clear subscriber nf-service smf rat utran/geran
For clear session, the options applicable for 4G sessions such as IMSI, MSID, RuleBase and so on are applicable for 2G and 3G sessions as well.
S4-SGSN MBR and handover procedures for 2G and 3G support
This feature enhances the converged core to provide mobility and session continuity for UE operating in 2G (GERAN) and 3G (UTRAN) networks. It focuses on the handling of Modify Bearer Requests (MBRs) to manage user location updates and supports various handover scenarios to ensure uninterrupted service as users move between different RATs.
Following is the list of MBR and handover procedures for S4-SGSN in SMF:
  • User location update handling (MBR)
  • Inter-RAT handover support (4G/LTE <=> 2G/3G)
  • Dedicated bearer handling
  • Intra-RAT handover support (2G/3G)
Restricted S4-SGSN handover
Here is the list of restricted S4-SGSN handover support in SMF:
  • If the UE attach is in 2G/3G access type, the direct and indirect handover to 5G and vice versa are rejected with a service not supported reason. The given handovers are not supported:
    • 2G/3G -> 5G
    • 5G->2G/3G
    • 5G->4G->2G/3G
    • 2G/3G->4G->5G
  • Direct handover from 2G/3G to Wi-Fi and vice versa are not supported.Indirect handover such as, 2G/3G->4G->Wi-Fi and vice versa are supported.
  • The SMF will disregard the handover indication flag in the ModifyBearerRequest when processing 2G/3G handovers.
  • Handover to 2G/3G is rejected, if the 2G/3G CLI is not enabled during attach procedure.
  • Handover to 2G/3G is rejected, if the 4G session is established in previous release 2025.2.0 version.
MBR procedure for user location change
This call flow illustrates the MBR procedure for user location change in S4-SGSN.
Workflow
Figure 4. MBR for ULI change
The following procedure explains the step by step process of MBR in SMF:
  1. After successful attach of 2G/3G in SMF, the SMF receives ModifyBearerRequest message with modified cgi/rai/sai values.
  2. SMF sends ModifyBearerResponse message to SGW.
  3. SMF sends N4ModificationRequest message with the following values:
    • PFCP_IE_SUB_PARAMS having updated cgi/rai/sai.
    • PFCP_IE_QUERY_URR sent for URRs with trigger configured.
  4. SMF receives N4ModificationResponse message with usage report.
  5. SMF sends ChargingDataUpdateRequest message to CHF with the following values:
    • TriggerType as USER_LOCATION_CHANGE.
    • MultipleUnitUsage with GERA/UTRA type.
    • PDUSessionChargingInformation with GERA/UTRA RAT type.
  6. SMF receives ChargingDataUpdateResponse message from CHF.
  7. SMF sends PolicyUpdateRequest message with SAREA_CH.
  8. SMF receives PolicyUpdateResponse message from PCF.
Note
The call flow is similar for 2G RAT type.
S4-SGSN inter-RAT handover procedures
This section describes handovers between 4G and 2G/3G, with home and roaming scenarios.
The following procedures are covered as a part of inter-RAT handover in S4-SGSN:
  • 4G homer to 3G roamer handover
  • 3G homer to 4G roamer handover
  • 4G roamer to 3G homer handover
  • 3G roamer to 4G homer handover
This call flow illustrates the inter-Rat handover for 4G homer to 3G roamer scenario in S4-SGSN.
Workflow
Figure 5. 4G homer to 3G roamer
The following procedure explains the step by step process of inter-RAT handover for 4G homer to 3G roamer in SMF:
  1. After successful attach of 4G in SMF, the SMF receives ModifyBearerRequest message with the following values:
    • Visitor PLMN in Serving NW
    • RAT Type UTRA
    • Modified target GTP-U TeID
  2. SMF sends N4ModificationRequest message with the following values:
    • PFCP_IE_SUB_PARAMS with ratType = 1(UTRAN) and roaming_status = 4(ROMER).
    • Create N9 and S5 PDRs.
    • Delete N3 and S5 PDRs.
    • Update DL S5 FAR with forw action set and target TeID in outer_header_creation.
    • Query_interface for online and offline URRs.
  3. SMF receives N4ModificationResponse message with usage report.
  4. SMF sends ChargingDataUpdateRequest message to CHF with the following values:
    • TriggerType as RAT_CHANGE.
    • MultipleUnitUsage with EUTRA RAT type.
    • PDUSessionChargingInformation with UTRA RAT type.
  5. SMF receives ChargingDataUpdateResponse message from CHF.
  6. SMF sends PolicyUpdateRequest message with repPolicyCtrlReqTriggers as RAT_TY_CH and RAT type UTRA.
  7. SMF receives PolicyUpdateResponse message from PCF.
Note
The call flow is similar for 4G homer to 2G roamer scenario where RAT type will be as GERA for 2G network.
This call flow illustrates the inter-Rat handover for 3G homer to 4G roamer scenario in S4-SGSN.
Workflow
Figure 6. 3G homer to 4G roamer
The following procedure explains the step by step process of inter-RAT handover for 3G homer to 4G romer in SMF:
    • RAT Type EUTRA
    • Delete S5 UL PDRs
    • Re-create S5 UL PDRs
    The secondary PDR is not created during 3G attach.
    • MultipleUnitUsage with UTRA RAT type.
    • PDUSessionChargingInformation with EUTRA RAT type.
  6. SMF sends PolicyUpdateRequest with repPolicyCtrlReqTriggers as RAT_TY_CH and RAT type UTRA.
Note
The call flow is similar for following cases with corresponding RAT type and target roaming status.
  • 2G homer to 4G roamer
  • 2G homer to 3G roamer
  • 3G homer to 2G roamer
This call flow illustrates the inter-Rat handover for 4G roamer to 3G homer scenario in S4-SGSN.
Workflow
Figure 7. 4G roamer to 3G homer
The following procedure explains the step by step process of inter-RAT handover for 4G roamer to 3G homer in SMF:
    • Homer PLMN in Serving NW
    • RAT Type UTRA
    • PFCP_IE_SUB_PARAMS with ratType = 1(UTRAN) and roaming_status = 1(HOMER).
    • Create N3 and S5 PDRs.
    • Delete N9 and S5 PDRs.
Note
The call flow is similar for 4G roamer to 2G homer scenario where RAT type will be as GERA for 2G network.
This call flow illustrates the inter-Rat handover for 3G roamer to 4G homer scenario in S4-SGSN.
Figure 8. 3G roamer to 4H homer
The following procedure explains the step by step process of inter-RAT handover for 3G roamer to 4G homer in SMF:
  1. After successful attach of 3G in SMF, the SMF receives ModifyBearerRequest message with the following values:
    • RAT Type EUTRA
    • PFCP_IE_SUB_PARAMS with ratType = 6(UTRAN) and roaming_status = 1(HOMER).
    • Delete S5 UL PDRs.
  6. SMF sends PolicyUpdateRequest with repPolicyCtrlReqTriggers as RAT_TY_CH and RAT type EUTRA.
Note
The call flow is similar for 2G roamer to 4G homer scenario where RAT type will be as GERA for 2G network.
Handover procedure with dedicated bearer in S4-SGSN
This call flow illustrates the handover procedure with dedicated bearer for 4G homer to 3G roamer scenario in S4-SGSN.
Workflow
Figure 9. Dedicated bearer handover for 4G homer to 3G roamer
The following procedure explains the step by step process of handover procedure with dedicated bearer for 4G homer to 3G roamer scenario in SMF:
  1. After successful attach with dedicated bearer of 4G in SMF, the SMF receives ModifyBearerRequest message with the following values:
    • RAT Type UTRA
    • Bearer list with default and dedicated bearer
    • Create N9 and S5 PDRs for default bearer.
    • Delete N3 and S5 PDRs for default bearer.
    • Update DL S5 FAR for default bearer with forw action set and target TeID in outer_header_creation.
Note
In this call flow,
  • If the ModifyBearerRequest message is received with only default bearer in bearer list, the default bearer is processed and dedicated bearer is removed by sending delete PDR,QER,FAR,URR in N4ModificationRequest message.
  • If only dedicated bearer is received, the MBR is rejected.
The call flow is similar for 4G homer with dedicated bearer to 2G roamer scenario where RAT type will be as GERA for 2G network.
Handling bearer context list in MBR for 4G to 3G handover
During 4G to 2G or 3G handovers, when a Modify Bearer Request is received, the following occurs:
  • If both default and dedicated bearers are present, the default bearer is accepted, and dedicated bearers are removed due to lack of 2G or 3G support.
  • If only dedicated bearers are present, the request is rejected with a Context Not Found cause.
  • If no bearer context list is provided, the default bearer is accepted, and a ClearSubscriberRequest is triggered to remove any dedicated bearers.
This call flow illustrates the handling of MBR with bearer context list not present for a 4g to 2G or 3G scenario.
Note
Note that 4G to 2G handovers will follow a similar procedure, with the ratType specifically being GERAN.
Figure 10. Handling bearer context list in MBR in 4G to 3G handover
  1. After successful attach with UE in 4G with dedicated bearer, the SMF receives ModifyBearerRequest message without the GTPV2_IE_BEARER list.
      PFCP_IE_QUERY_INTERFACE due to RAT type change trigger.
    • SMF receives N4ModificationResponse message with usage report.
    • CharingUpdateReq/Res sent for reporting usage.
    • PolicyUpdateReq/Res sent for RAT type change trigger.
    • Internal transaction submitted per bearer to clear subscribers.
  3. ClearSubscriberReq is received invoking PDN Session Modify - Bearer Delete - Admin initiated procedure.
  4. SMF sends N4ModificationRequest message with the following values:
    • PFCP_IE_UPDATE_FAR sent with drop action set for dedicated bearers.
    • PFCP_IE_SUB_PARAMS with newType, ULI, roaming status.
    • PFCP_IE_PFCPSMREQFLAGS with drobu set.
  5. SMF sends N4ModificationResponse message with the following values:
    • PFCP_IE_REMOVE_PDR, PFCP_IE_REMOVE_FAR, PFCP_IE_REMOVE_URR and PFCP_IE_REMOVE_QER for dedicated bearer
  6. SMF receives N4ModRsp with final usage report.
  7. ChargingDataUpdateResponse message is sent for final usage.
  8. SMF sends PolicyUpdateRequest message with ruleReport as RES_ALLO_FAIL.
  9. SMF receives PolicyUpdateResponse message.
Intra-RAT handover for S4-SGSN
The call flow illustrates the SGW handover in 3G network.
Workflow
Figure 11. SGW handover in 3G
The following procedure explains the step by step process of SGW handover for 3G network in SMF:
  1. After successful attach of 3G in SMF, the SMF receives Modify Bearer Request message with Target SGW GTP-U teid and IP address values.
    • Update DL S5 FAR with forw action set and target SGW teid and IP address in outer_header_creation.
    • TriggerType as SERVING_NODE_CHANGE.
Dynamic QoS Modification for S4-SGSN on Converged Core
This feature introduces QoS negotiation capabilities for 2G and 3G subscribers using the S4-SGSN within converged core. It enables dynamic and automated adjustments to the QoS parameters of the default bearer based on triggers originating from HLR or PCF.
The key functionalites of QoS modification feature includes:
  • HLR-initiated QoS modification
  • PCF-inititated QoS modification
Limitations of QoS negotiation
Here are the limitations of QoS negotiation for default bearer:
  • HLR or PCF initiated QoS modification for default bearer is allowed only for QCI/ARP change or Sess-AMBR change. Other parameters cannot be modified.
  • Dedicated bearer is not supported for 2G/3G sessions and hence, QoS negotiation for dedicated bearer is not applicable.
  • The non-standard QCI is supported for PCF-initiated modification. It is not for supported for HLR-initiated modification.
HLR-inititated QoS modification
Summary
This call flow illustrates the HLR-inititated QoS modification process in SMF.
Figure 12. HLR-inititated QoS modification
Workflow
The following procedure consists of step by step process for HLR-inititated QoS modification in SMF:
  1. The S4-SGSN sends a Modify Bearer Command to the SGW in response to HLR-initiated QoS parameter updates, with support restricted to default bearer QoS changes. This process supports only default bearer QoS changes.
  2. SMF sends Npcf_SMPolicyControl_Update message to PCF with SESS_AMBR or QOS_CH values.
    • For QoS change, SMF includes the DEF_QOS_CH value within the repPolicyCtrlReqTriggers attribute and the new subscribed default QoS within the subsDefQos attribute.
    • For Sess-AMBR change, SMF includes the SE_AMBR_CH within the repPolicyCtrlReqTriggers attribute and the new Session-AMBR within the subsSessAmbr attribute.
  3. PCF provisions the new authorized session AMBR and authorized default QoS to the SMF in the response.
  4. SMF sends Update Bearer Request message to SGW with modified APN-AMBR, and/or EPS Bearer QoS if the QCI/ARP value is changed.
  5. After receiving a successful Update Bearer Response message from S-GW, SMF triggers the N4 Modification with Update-PDR and/or Update-QER values.
  6. If the bearer modification fails, the SMF takes action based on the Failure Handling Type (FHT).
  7. The existing smf_service_stats metrics with procedure_type mme_req_ded_brr_mod and appropriate rat_type are pegged for this scenario, similar to the 4G session.
Note
The DEF_QOS_CH and SE_AMBR_CH PCF triggers are sent during HLR-initiated QoS modification as indicated. However, they are not supported in any other scenarios.
This call flow illustrates the PCF-inititated QoS modification process in SMF.
Workflow
Figure 13. PCF-inititated QoS modification
The following procedure consists of step by step process for PCF-inititated QoS modification in SMF:
  1. The PCF-initiated notification update for QoS parameters are supported for default bearer.
    When the SMF receives notification update from PCF, SMF sends Update Bearer Request message to SGW with modified APN-AMBR value, and/or EPS Bearer QoS valuse if the QCI/ARP is changed.
  2. After receiving a successful Update Bearer Response message from S-GW, SMF triggers N4 Modification with Update-PDR and/or Update-QER values.
  3. If a bearer modification fails, the SMF takes action based on the Failure Handling Type (FHT).
Note
For 4G Sessions, SMF doesn’t send any notification to PCF upon UBR or N4 failure. Same behaviour is applied in 2G/3G sessions for both PCF-initiated and HLR-initiated QoS modification.
S4-SGSN PCF-inititated modification
Workflow
In S4-SGSN PCF-inititated modification, the PCF-initiated notification update is supported for default bearer along with the existing 4G implementation. New ProcedureTypes are added for 2g/3g procedures in EventTrace. dedicated bearer operations are not supported for 2g/3g
The following Procedure Failure LogTags are added:
  • 3gbrrmod-procfailure
  • 2gbrrmod-procfailure
The Dedicated bearer creation/modification/deletion is not supported for 2G/3G sessions. SMF rejects any addition of PCC rule that requires creation of dedicated bearer as given in the following illustration.
Dedicated bearer rejection handling
This call flow illustrates the dedicated bearer rejection handling in SMF.
Figure 14. S4-SGSN PCF-inititated modification
When the dedicated bearer creation is rejected, HTTP status code 400 is sent with RuleReport containing failure code as MAX_NR_QoS_Flow.
Note
  1. The given call flow for dedicated bearer rejection handling illustrates a scenario with SmPolicyUpdateNotification message from PCF. Similar rejection handling is done if the PCF sends PccRules value for a new QoS flow such as a new dedicated bearer in SmPolicyCreateResponse or SmPolicyUpdateResponse message. In this case, the SmPolicyUpdateReq message with RuleReports value is triggered.
    • When the new PccRules are received in SmPolicyCreateRsp/ SmPolicyUpdateResponse message during PDN Setup (Piggy-back Dedicated Bearer scenario), rule reports are triggered after PDN setup is complete.
  2. During SmPolicyUpdateNotification, if the expedite CLI is enabled for PCF response, then these RuleReports are sent in SmPolicyUpdateReq message instead of SmPolicyUpdateNotificationResp message.
The existing smf_service_stats with procedure type pcf_req_ded_brr_create is pegged with failures status and reason as oper_not_supported_in_rat. Label qos_5qi containing QCI values is not populated in such reject scenarios.
Attach and detach procedures for GTPv1 SGSN
The feature describes the support for attach and detach procedures for GTPv1 SGSN. The GTPv1 messages and information elements are translated to their GTPv2 equivalents for processing by the SMF.
As part of the 2G and 3G support, SMF needs the capability to support Gn interface. SMF receives GTPv1 messages on the same interface (service IP) exposed as S5.
In this feature, the following GTPv1 messages are supported:
  • Create PDP Context Request
  • Create PDP Context Response
  • Delete PDP Context Request
  • Delete PDP Context Response
The attach and detach procedures are explained through PDN connect call flow and PDN disconnect call flow over SGSN.
  • PDN connect over SGSN
  • PDN disconnect over SGSN
This section describes the call flow and stages in PDN connect over SGSN.
Workflow
Figure 15. PDN connect over SGSN
  1. SMF receives Create PDP Context Request message from SGSN with the following values:
    • RAT types are GERAN for 2G attach and UTRAN for 3G attach
    • SGSN Control
    • Data TEID
    The ULI contains any one of the following values:
    Note
  2. SMF sends PolicyCreateRequest message to PCF to establish policy association.
  4. UE IP address is allocated and SMF sends PolicyUpdateRequest to PCF with UE_IP_CH trigger.
  7. SMF receives ChargingDataSuccess message from CHF and get the following values:
    • Quota at RG Level
  10. SGSN receives Create PDP Context Response (Bearer Control Mode value as 1) from SMF.
UE-initiated release for SGSN
The call flow illustrates the UE-initiated release for PDN disconnect over SGSN.
Workflow
Figure 16. UE initiated PDN disconnect
Summary
The following procedure explains the UE-initiated release for PDN disconnect over SGSN:
  1. SMF receives Delete PDP Context Request message from SGSN.
    Note
  2. SMF sends N4SessionReleaseRequest message to UPF to remove the user plane resources.
  4. SGSN receives Delete PDP Context Response message from SMF.
  5. SMF sends ChargingReleaseRequest message to CHF with final usage.
  7. SMF sends PolicyDeleteRequest message to PCF to delete the policy association.
SMF-initiated release for SGSN
The call flow illustrates the SMF-initiated release for PDN disconnect over SGSN.
Workflow
Figure 17. SMF-initiated PDN disconnect
The following procedure explains the SMF-initiated release for PDN disconnect:
  1. The SMF-initiated release is triggered using the clear subscriber command. SMF sends N4SessionModificationRequest message with drop action set in update FAR.
    Note
  2. SMF receives N4SessionModificationSuccess message.
  3. SMF sends the Delete PDP Context Request message to SGSN.
  4. SMF receives the Delete PDP Context Response message from SGSN.
  5. SMF sends N4SessionReleaseRequest message to UPF to remove the user plane resources.
  6. SMF receives N4SessionReleaseSuccess message with final usage from UPF.
  7. SMF sends ChargingReleaseRequest message to CHF with final usage.
  8. SMF receives ChargingReleaseSuccess message from CHF.
  9. SMF sends PolicyDeleteRequest message to PCF to delete the policy association.
  10. SMF receives PolicyDeleteSuccess message from PCF.
Show command output for GTPv1 2G and 3G sessions
Sample output for show command
Here is the sample output for show subscriber CLI command with GTPv1 message information:
show subscriber supi imsi-123456789012345 nf-service smf full | exclude subscriber-details
  "subResponses": [
      "status": true,
      "genericInfo": {
        "pduSessionId": 69,
        "pduSesstype": "Ipv4PduSession",
        "accessType": "3GPP_ACCESS",
        "dnn": "intershat",
        "plmnId": {
          "mcc": "123",
          "mnc": "456"
        "sScMode": 1,
        "uetimeZone": "+00:15",
        "allocatedIp": "12.0.4.0",
        "alwaysOn": "None",
        "dcnr": "Enabled",
        "ratType": "UTRA",
        "ueType": "4G Capable And NR Unknown UE",
        "sessTimeStamp": "2025-07-14 06:40:23.582495295 +0000 UTC",
        "callDuration": "5.743140999s",
        "ipPool": "poolv4",
        "commonId": 66,
        "linkedEbi": 5,
        "snssai": {
          "sd": "Abf123",
          "sst": 2
        "utranLocation": {
          "cgi": {
            "mcc": "123",
            "mnc": "456",
            "lac": "04d2",
            "cellId": "0004"
          "rai": {
            "mcc": "123",
            "mnc": "456",
            "lac": "04d2",
            "rac": "22"
          "ueLocationTimestamp": "2025-07-14T06:40:23Z"
        "qosFlow": [
            "qfi": 1,
            "GBRFlow": "False",
            "bindingParameters": {
              "x5Qi": 9,
              "arp": {
                "preemptCap": "NOT_PREEMPT",
                "preemptVuln": "PREEMPTABLE",
                "priorityLevel": 1
            "startTime": "2025-07-14T06:40:23Z",
            "rulebase": "rba_charging_staticonly_offline",
            "chargingDisabled": "false",
            "dropTraffic": "false",
            "gtppGrp": "group1",
            "profileName": "chgprf1",
            "accountingEnabled": "false",
            "n40ChargingEnabled": "true",
            "qbcChargingEnabled": "false",
            "offlineConverted": "false",
            "chfGroupId": "CHF-dnn=intershat;",
            "chfChargDataRef": "1111",
            "bearerInctCharg": "false",
            "gyChargingEnabled": "false",
            "gzChargingEnabled": "false"
  "upfSeid": "17293822569102704642",
        "TotalNumberOfPdrs": "2 (Ul:1 Dl:1)",
        "TotalNumberOfFars": 2,
        "TotalNumberOfQers": 2
        "localTeid": 66,
        "lbi": 5,
        "bearerContexts": [
            "ebi": 5,
            "defBrr": true,
            "dlFteid": {
              "teid": 1655,
              "ipaddr": "192.168.7.61"
        "sgsnAddr": {
          "sgsnIpv4Addr": "172.10.1.26"
        "gtpVersion": "GtpV1"
Sample output for monitor subscriber CLI command
This section provides information on the sample output for monitor subscriber CLI command associated with the GTPv1 messages in SMF.
Create PDP Context Request message output
Here is the sample output that dispalys Create PDP Context Request message information in monitor subscriber CLI command:
Subscriber Id: imsi-123456789012345
      Timestamp: 2025/02/27 11:37:03.690314
    Message: S5 S8 Create PDP Context Request
    Description: Create PDP Context Request Message displayed after decoding into Create Session Request Message Proto
      Source: 172.00.0.00
      Destination: 10.1.00.000
      PAYLOAD:
        S5 S8 Create PDP Context Request:
                Version: 1
                MsgType:
                   Create_Session_Request:
                       IMSI: 123456789012345
Create PDP Context Response message output
Here is the sample output that dispalys Create PDP Context Response message information in monitor subscriber CLI command:
         Timestamp: 2025/02/27 11:37:03.939684
      Message: S5 S8 Create PDP Context Response
      Description: Create PDP Context Response Message displayed after decoding into Create Session Response Message Proto
      Source: 10.0.00.000
      Destination: 172.00.0.00
PAYLOAD:
       S5 S8 Create PDP Context Response:
                Version: 1
             MsgType:
                    Create_Session_Response:
                     Cause:
                         Cause_Value: 16
Delete PDP Context Request message output
Here is the sample output that dispalys Delete PDP Context Request message information in monitor subscriber CLI command:
      Timestamp: 2025/02/27 11:37:14.149143
    Message: S5 S8 Delete PDP Context Request
    Description: SGSN Initiated Delete PDP Context Request Message
displayed after decoding into Delete Session Request Message Proto
      Source: 172.00.0.00
      PAYLOAD:
        S5 S8 Delete PDP Context Request:
                Version: 1
                MsgType:
                   Delete_Session_Request:
                       Linked_EBI:
                            Value: 6
Delete PDP Context Response message output
Here is the sample output that dispalys Delete PDP Context Response message information in monitor subscriber CLI command:
      Timestamp: 2025/02/27 11:37:14.187506
    Message: S5 S8 Delete PDP Context Response
    Description: SGSN Initiated Delete PDP Context Response Message
displayed after decoding into Delete Session Response Message Proto
      Source: 172.00.0.00
      PAYLOAD:
        S5 S8 Delete PDP Context Response:
                Version: 1
                MsgType:
                   Delete_Session_Response:
                       Cause:
                           Cause_Value: 16
The enhancement introduces comprehensive SGSN PDN modification and handover support, including intra-SGSN changes for User Location Information (ULI), RAT, and TEID, as well as inter-SGSN and SGSN-to-S4-SGSN handovers. It also adds support for GTPv1 message metrics, secondary PDR validation for GTPv1 and GTPv2, handling of UPC messages with default bearers, CLI-based rejection of unsupported 4G to 2G/3G handovers, collision handling for Modify Bearer Requests, and support for complex back-to-back handover scenarios with home and roaming combinations, enhancing mobility management and session continuity across multi-generation networks.
Intra SGSN user location change
This call flow illustrates the Update PDP Context (UPC) procedure for user location change in Intra SGSN.
Figure 18. Intra SGSN user location change
The following procedure explains the step by step process of UPC procedure for user location change in Intra SGSN.
  1. SMF receives an Update PDP Context Request(default bearer) with a ULI change, but without RAT, RAI, and GTP-C TEID IEs. The GTP-U TEID is received without any change in cgi/rai/sai values.
  2. SMF sends Update PDP Context Response.
    • No change to N3/N9 PDR if secondary PDR present.
    • No change to UL and DL S5 PDR.
  8. SMF receives PolicyUpdateResponse message.
Intra SGSN RAT change
This call flow illustrates the UPC procedure for intra SGSN RAT change.
Figure 19. Intra SGSN RAT change
The following procedure explains the step by step process of intra SGSN RAT change in SMF:
  1. After successful attach of 3G in SMF, the SMF receives an Update PDP Context Request(default bearer) message with a RAT change, but without ULI, RAI, and GTP-C teid IEs. The GTP-U teid is received without any change with rat value.
    • PFCP_IE_SUB_PARAMS having updated RAT.
  4. SMF sends Update PDP Context Response.
    • MultipleUnitUsage with GERAN/UTRAN RAT type.
    • PDUSessionChargingInformation with with GERAN/UTRAN RAT type.
  6. SMF receives ChargingDataUpdateResponse message.
  7. SMF sends PolicyUpdateRequest with repPolicyCtrlReqTriggers as RAT_TY_CH and RatType GERAN/UTRAN.
  8. SMF receives PolicyUpdateResponse.
Intra SGSN GTP-U TEID change
This call flow illustrates the UPC procedure for user location change in SGSN GTP-U TEID change.
Figure 20. Intra SGSN GTP-U TEID change
The following procedure explains the step by step process of intra SGSN GTP-U TEID change in SMF:
  1. SMF receives an Update PDP Context Request(default bearer) with GTP-U TEID change, but without RAT, ULI, RAI, and GTP-C TEID IEs. targeting GTP-U(RNC/SGSN) TEID and IP address values.
    • No change to UL S5 PDR
    • Update DL S5 FAR with forw action set and target RNC/SGSN GTP-U teid and IP address in outer_header_creation.
Inter SGSN handover
The following procedures are covered as a part of inter-RAT handover:
  • 3G-GTPv1 homer to 2G-GTPv1 homer handover
  • 3G-GTPv1 homer to 2G-GTPv2 homer handover
  • 4G homer to 3G-GTPv1 homer handover
  • 4G homer to 3G-GTPv1 roamer handover
This call flow illustrates the inter-RAT handover for 3G-GTPv1 homer to 2G-GTPv1 homer scenario.
Figure 21. Inter/Intra RAT 3G-GTPv1 homer to 2G-GTPv1 homer
The following procedure explains the step by step process of inter-RAT handover for 3G-GTPv1 homer to 2G-GTPv1 homer in SMF:
  1. After successful attach of 3G-GTPv1 in SMF, the SMF receives Update PDP Context Request message with the default bearer values:
    • RatType 2G-GTPv1
    • Modified target SGSN GTP-C and RNC/SGSN GTP-U TEID
    • May receive ULI and RAI change
    • No change to UL S5 PDR.
    • Update DL S5 FAR with forw action set and target RNC/SGSN GTP-U TEID in outer_header_creation.
    • PFCP_IE_SUB_PARAMS with Targe RAT Type(GERAN) and .
  5. SMF sends ChargingDataUpdateRequest message to CHF if trigger armed.
  6. SMF receives ChargingDataUpdateResponse message from PCF if trigger armed.
This call flow illustrates the inter-RAT handover for 3G -GTPv1 homer to 2G-GTPv2 homer scenario.
Figure 22. Inter/Intra RAT 3G-GTPv1 homer to 2G-GTPv2 homer
The following procedure explains the step by step process of SGW handover for 3G-GTPv1 home to 2G-GTPv2 home network in SMF:
  1. After successful attach of 3G in SMF, SMF receives Modify Bearer Request message with the following values:
    • RatType 2G-GTPv2
    • Modified target SGW GTP-C and GTP-U TEID
    • May receive ULI and Serving-NW change
    • a. No change to N3/N9 PDR if secondary PDR present.
    • PFCP_IE_SUB_PARAMS with Target RAT type (GERAN)
  4. SMF sends Modify Bearer Response.
  5. SMF sends ChargingDataUpdateRequest and Response message to CHF if trigger armed.
  6. SMF receives ChargingDataUpdateResquest and Reponse message from PCF if trigger armed.
This call flow illustrates the inter-RAT handover for 4G homer to 3G-GTPv1 homer scenario.
Figure 23. Inter RAT 4G homer to 3G-GTPv1 homer
The following procedure explains the step by step process of inter-RAT handover for 4G homer to 3G-GTPv1 homer in SMF:
  1. After successful attach of 4G in SMF, the SMF receives Update PDP Context Request message with default bearer with the following values:
    • RatType 3G-GTPv1
    • Might receive ULI and RAI change
    • Update DL S5 FAR with forw action set and target RNC/SGSN GTP-U TeID in outer_header_creation.
    • Delete PDR, FAR, QER, and URRs for dedicated bearer is dedicated bearer is present.
    • PFCP_IE_SUB_PARAMS with Target RAT Type(UTRAN) and .
  6. SMF sends ChargingDataUpdateRequest and Response message to PCF if trigger armed.
  7. SMF receives Update PDP Context Request with default bearer.
  8. SMF sends Update PDP Context Response with Reject cause and context not found.
This call flow illustrates the inter-RAT handover for 4G homer to 3G-GTPv1 roamer scenario.
Figure 24. Inter RAT 4G homer to 3G-GTPv1 roamer
The following procedure explains the step by step process of inter-RAT handover for 4G homer to 3G-GTPv1 roamer in SMF:
  1. After successful attach of 4G in SMF, the SMF receives Update PDP Context Request with default bearer message with the following values:
    • RatType 3G-GTPv1
    • Receive RAI change
    • May receive ULI change
    • [Create N9 and Delete N3(Homer->Roamer)]/[Create N3 and Delete N9 (Roamer->Homer)] if secondary PDR present.
    • Re-create UL S5 PDR.
    • Delete PDR, FAR, QER, and URRs for dedicated bearer of dedicated bearer is present.
      with
      • Target RAT type (UTRAN)
      • target roaming_status
  6. SMF receives ChargingDataUpdateRequest and Response message from PCF if trigger armed.
Dynamic QoS negotiation for GTPv1 SGSN
The objective of GTPv1 QoS negotiation is to manage and enforce Quality of Service for 2G and 3G calls within the Converged Core (CC) architecture.
In 2G and 3G networks, the Serving GPRS Support Node (SGSN) is the primary entity responsible for controlling and enforcing the QoS for a given call. In any reply from the PCF, if PCF upgrades the QoS parameters, then the SMF cannot directly send these upgraded values in the reply messages towards the access side. Therefore, the SMF initiates a new Update PDP Context (UPC) procedure to apply the new Upgraded QoS parameters.
For 2G and 3G calls, each PDP Context has MBR (max-bit-rate uplink and downlink) as a part of QoS profile and APN-AMBR(uplink and downlink) values. When the SMF receives an APN-AMBR from either the SGSN or PCF, the QoS Profile MBRs of the default bearer is also set to PCF-authorized APN-AMBR values.
The SMF includes the APN-AMBR values in messages sent to the SGSN, only if the APN-AMBR is received from the SGSN previously.
The GTPv1 QoS negotiation happens in these two scenarios:
  • QoS negotiation during Create PDP Context
  • QoS negotiation during Update PDP Context
QoS negotiation during CPC
QoS negotiation during the CPC highlights how SMF processes the changes in various QoS values in CPC process.
SMF supports these changes in the QoS negotiation during the Create PDP Context (CPC):
  • APN-AMBR change from PCF: The CPC response message carries the new APN-AMBR. If there is a need to upgrade the MBR, SMF initiates a UPC process.
  • QCI or ARP change from PCF: If the default bearer requires a QCI upgrade, SMF initiates a UPC process.
QoS negotiation during UPC
QoS negotiation during UPC describes how SMF handles the changes in the QoS values during the UPC process.
During an Update PDP Context procedure, SMF supports these changes for QoS negotiation:
  • QoS profile change: Similar to the Modify Bearer Command (MBC) handling in 4G calls, SMF applies the downgraded QoS values directly in the response messages. However, in case of the QoS upgrades, SMF initiates a separate Update PDP Context.
  • APN-AMBR change: The SMF applies the downgrades in the APN-AMBR in the response messages. However, the upgrades in the APN-AMBR necessitate a separate SMF-initiated UPC.
  • ULI (User Location Information) change: SMF processes the ULI change as a regular MBR and handles the same way as in 4G.
  • RAI (Routing Area Identity) change: SMF processes the RAI change as a regular MBR and handles the same way as in 4G.
  • Combination cases: During the scenarios of multiple changes in values, SMF handles the processing the same downgrades are applied in response messages, and upgrades require a separate SMF-initiated UPC.
Limitations of GTPv1 QoS negotiation
The GBR QCI for default bearer are not supported for 2G 3G calls.
This feature allows the network operator to suppress the SMF-initiated Update PDP Context Request for 2G and 3G sessions towards SGSN.
Suppress SMF-initiated Update PDP Context Request toward SGSN
This configuration allows you to suppress SMF-initiated Update PDP Context.
Procedure
Step 1
Use the CLI profile dnn dnn_profile_name to get into the DNN profile.
Example:
[smf] smf# config
[smf] smf(config)# profile dnn intershat
[smf] smf(config-dnn-intershat)#
Step 2
Use the CLI [ no ] deactivate-features 2g-3g-nrupc to suppress or enable SMF-initiated Update PDP Context.
Example:
[smf] smf(config-dnn-intershat)# [ no ] deactivate-features 2g-3g-nrupc
  • The CLI [ no ] disables the suppressing of SMF-initiated Update PDP Context.
  • By default, the CLI 2g-3g-nrupc is disabled.
Step 3
Use the CLI show running-config profile dnn dnn_profile_name to verify the configuration.
Example:
[smf] smf# show running-config profile dnn intershat
  supported-features [ inter-plmn-ho n3-interface-separation ]
  upip data-rate dl max-ue-rate ul max-ue-rate restrict-action terminate
exit
Statistics for 2G and 3G sessions
Use these bulk statistics for monitoring, analyzing, and troubleshooting 2G and 3G sessions.
Table 9. Metrics for 2G and 3G sessions
Metrics
Label Information
smf_gtpc_msg_stats
This counter is incremented for every access request message received from SGW.
  • app_name < app_name>
  • cluster <cluster>
  • data_center <data_center>
  • dnn <dnn>
  • gr_instance_id < gr_instance_id>
  • instance_id <instance_id>
  • message_type <message_name>
  • qos_5qi <qci>
  • rat_type <rat_type>
    The rat_type value shall be either GERA or UTRA for 2G/3G.
  • smf_service_stats
  • smf_session_stats
  • chf_message_stats
  • chf_session_stats
  • policy_msg_processing_status
  • policy_pdu_flows_total
  • smf_datacheck_stats
  • smf_disconnect_stats
  • smf_service_counters
  • smf_service_resource_mgmt_stats
  • smf_restep_http_msg_total
rat_type <rat_type>
The rat_type value is either GERA or UTRA for 2G and 3G calls.
smf_session_counters
The fourg_only_ue label is marked as fourg_only_ue:unknown when the SessionID is greater than or equal to 64 for 2G and 3G sessions.
cdl show sessions summary
smf_service_stats
  • procedure_type : The specific type of 2G/3G Hanover procedure being tracked. Example values include "pdn_ho_3gv2_3gv1
  • status : The outcome of the procedure
  • reason : Provides more specific details if the procedure failed
  • rat_type : Radio Access Technology type: UTRA (3G), GERA (2G), or EUTRA (4G).
  • dnn : Data Network Name used for the session
  • roaming_status : Indicates whether the user is roaming or not
  • direct_tunnel : A Boolean value (true or false) indicating if a direct tunnel flag present in MBR Request or not
  • serv_node_change : A Boolean value (true or false) indicating that the serving node has changed or not
  • location_change : A Boolean value (true or false) indicating if the user's location changed during the procedure or not
The GTPC metrics for 2G and 3G sessions are listed here:
Table 10. GTPC metrics
Metrics
Label Information
gtpc_app_events
Added version (v1 / v2) in the metrics.
The event_type is updated to reflect v1 messages.
gtpc_app_events_seconds
gtpc_app_priority_events
Added failed Message type and version.
gtpc_msg_total
Captures the v1 message names.
gtpc_app_validation_events
Captures the v1 specific message names, failure type, fail reason and rejection cause.
gtpc_msg_seconds
gtpc_golang_enc_dec_stats
  • gtpc_msg_type is updated to reflect v1 messages.
  • gtpc_msg_status_cause is updated to display the v1 specific error.
gtpc_echo_msg_stats
The GTPC metrics for node managers are listed here:
Table 11. GTPC metrics
Metrics
Description
nodemgr_gtpc_msg_stats
nodemgr_gtpc_peer_status
For more information on the metrics, refer UCC 5G SMF Metrics Reference 2025.02.0 Guide or above versions.
