3gpp-Sbi-Target-apiRoot Headers
A 3gpp-Sbi-Target-apiRoot header is a configuration parameter that
  • enables the operator to specify a target API root URI,
  • is included in messages exchanged with the Network Repository Function (NRF), and
  • allows operators to control network function registration and discovery behavior according to deployment needs.
Feature History
Product Impact
Feature
Description
Software Reliability
sbi-target-apiroot URI update for NRF
The 3gpp-Sbi-Target-apiRoot header lets operators set a target API root URI for registration, deregistration, subscribe, unsubscribe, update, and discovery messages. SMF includes this header in each HTTP request to NRF, ensuring requests reach the desired destination based on deployment needs.
Command introduced:
  • profile message-handling nf-type nf_type { mh-profile mh_profile_name { service name type service_name_type { message type [ nf-register { header 3gpp-sbi target-apiroot api_root_uri } | nf-deregister { header 3gpp-sbi-target-apiroot api_root_uri } | nf-update { header 3gpp-sbi-target-apiroot api_root_uri } | nf-status-subscribe { header 3gpp-sbi-target-apirootapi_root_uri } | nf-status-unsubscribe { header 3gpp-sbi-target-apirootapi_root_uri} ] } } }
    Used to configure the target API root URI for NF management messages.
  • profile message-handling nf-type nf_type { mh-profile mh_profile_name { service name type service_name_type { message type nf-discover { header 3gpp-sbi target-apiroot api_root_uri } } } }
    Used to configure the target API root URI for NF discovery.
Default Setting: Disabled – Configuration Required
Configure the 3gpp-Sbi-Target-apiRoot header for NF management interactions
Enables SMF to send a custom API root header to the NRF for network function management operations. Operators use this task when their 5G deployment requires explicit control over which API root the SMF communicates with for NRF services.
Before you begin
  • Obtain the correct API root URI required by your deployment.
  • Ensure access to the SMF configuration interface (CLI or configuration file).
Procedure
Step 1
Enter the NRF message-handling profile configuration mode.
profile message-handling nf-type nf_type { mh-profile mh_profile_name { service name type service_name_type } }
Example:
profile message-handling nf-type nrf
 mh-profile MHNRF
  service name type nnrf-nfm
Step 2
Specify the 3gpp-Sbi-Target-apiRoot header for each message type.
  • For registration:
    message type nf-register { header 3gpp-sbi-target-apiroot api_root_uri }
  • For deregistration:
    message type nf-deregister { header 3gpp-sbi-target-apiroot api_root_uri }
  • For update:
    message type nf-update { header 3gpp-sbi-target-apiroot api_root_uri }
  • To subscribe:
    message type nf-status-subscribe { header 3gpp-sbi-target-apiroot api_root_uri }
  • To unsubscribe:
    message type nf-status-unsubscribe { header 3gpp-sbi-target-apiroot api_root_uri }
Example:
(config-nnrf-nfm)# message type nf-register
(config-nf-register)# header 3gpp-sbi-target-apiroot https://nrf.example.com/api
(config-nf-register)# exit
(config-nnrf-nfm)# message type nf-deregister
(config-nf-deregister)# header 3gpp-sbi-target-apiroot https://nrf.example.com/api
(config-nf-deregister)# exit
(config-nnrf-nfm)# message type nf-update
(config-nf-update)# header 3gpp-sbi-target-apiroot https://nrf.example.com/api
(config-nf-update)# exit
(config-nnrf-nfm)# message type nf-status-subscribe
(config-nf-status-subscribe)# header 3gpp-sbi-target-apiroot https://nrf.example.com/api
(config-nf-status-subscribe)# exit
(config-nnrf-nfm)# message type nf-status-unsubscribe
(config-nf-status-unsubscribe)# header 3gpp-sbi-target-apiroot https://nrf.example.com/api
(config-nf-status-unsubscribe)# exit
Step 3
Enter the NF management group configuration to associate message-handling profile with group nf-mgmt.
group nf-mgmt group_nf_mgmt_name { nrf-mgmt-group nrf_nfmgmt_grp | locality locality_name | heartbeat interval heartbeat_interval message-handling-profile message-handling-profile_name | failure-handling-profile failure_handling_profile_name
Example:
group nf-mgmt NFMGMT1
 nrf-mgmt-group           nrf-nfmgmt-grp
 locality                 LOC1
 heartbeat interval 50
 message-handling-profile MHNRF
 failure-handling-profile FHNRF
exit
Step 4
Save and commit the configuration.
Configure the 3gpp-Sbi-Target-apiRoot header for NF discovery interactions
This configuration enables SMF to send a custom API root header to the NRF for network function discovery operation. Operators use this task when their 5G deployment requires explicit control over which API root the SMF communicates with for NRF services.
Procedure
Step 1
profile message-handling nf-type nf_type { mh-profile mh_profile { service name type service name type } }
Example:
config
(config)# profile message-handling nf-type nrf
(config-msg-handling-nrf)# mh-profile MHNRFDISC
(config-msg-handling-MHNRFDISC)# service name type nnrf-nfd
Step 2
Specify the 3gpp-Sbi-Target-apiRoot header for the discovery message type.
message type message_type { header 3gpp-sbi-target-apiroot api-root-uri }
Example:
(config-nnrf-disc)# message type nf-discover
(config-DiscoverNF)# header 3gpp-sbi-target-apiroot https://nrf.example.com/api
(config-DiscoverNF)# exit
Step 3
Enter the NRF discovery group configuration mode to associate message-handling profile with group nrf discovery.
group nrf discovery nrf_discovery_group { service type nrf service_type { failure-handling-profile failure_handling_profile | message-handling-profile message_handling_profile} }
Example:
config
(config)# group nrf discovery nfdiscovery
(config-nrf-discovery-nfdiscovery)# service type nrf nnrf-disc
(config-nrf-discovery-nfdiscovery)# failure-handling-profile FHDISC
(config-nrf-discovery-nfdiscovery)# message-handling-profile MHNRFDISC
(config-nrf-discovery-nfdiscovery)# exit
Step 4
