Cisco Common Data Layer
Revision history
Table 1. Revision History
Revision Details
Introductory Release
Added the support for failure handling scenarios.
2023.03.0
Added the procedures for configuration and verification of the event trace data in the Cisco Common Data Layer database record.
2021.02.0
Geo redundancy of Cisco Common Data Layer in SMF
The Cisco Common Data Layer (CDL) is a high-performance, next-generation Key-value (KV) data store layer for the Cloud-Native applications. These applications use the CDL as a state management tool with High Availability (HA) and Geo HA functions.
SMF supports the Geo Redundant (GR) version of the CDL. The CDL endpoint pod is the front end for receiving requests from SMF application to the CDL. When the primary CDL endpoint fails, the SMF sends the database service requests to the next highly rated secondary endpoint. If the next rated endpoint is unavailable, then the SMF reattempts the operation on the subsequent endpoint that has the highest rating and so on.
In case of specific errors or failures from CDL to SMF, the retry mechanism is activated for Create, Find, Update, and Delete requests. The number of retries is based on the SLA.
The successful response to the SMF stops the retry process and sends the response to the application.
With this functionality, SMF provides a non-disrupted N7 or Diameter message handling.
Benefits of using CDL
The benefits of using CDL in SMF include:
  • Data storage: Enables the storage of event trace data in the CDL database record. The event trace data shows the call flow event for the subscribers.
  • Service Continuity: The system's ability to handle retries and redirect requests to available endpoints enables SMF to maintain smooth operations even during failures.
How CDL works in SMF
Key components involved in CDL Datastore Architecture are:
  • SMF REST endpoint
  • SMF service
  • CDL endpoint
  • Indexing or slots
Summary
This figure shows the failover process when the SMF service cannot access the CDL datastore endpoint.
Workflow
Figure 1. CDL Datastore Architecture
These stages describe how CDL operates within SMF, along with the failover and error-handling mechanisms.
  1. Configuring the CDL through the SMF Ops Center enables the SMF to support multiple CDL datastore endpoints.
  2. By default, SMF considers the local endpoint as the primary endpoint, which has the highest rating. SMF performs the CDL API operations on the primary endpoint.
  3. If the primary endpoint is unavailable, SMF routes the operations to the next highest-rated endpoint.
    SMF continues to fail over to the next accessible secondary endpoint until all configured secondary endpoints are exhausted. SMF does not reattempt a query on the next rated endpoint if the endpoint is reachable but responds with an error or timeout.
    The CDL operation fails with a 'Datastore Unavailable' error if SMF cannot access any endpoints within the cluster.
    This table provides the when-then condition scenarios for CDL operations.
    When And... Then the CDL... And CDL...
    all CDL endpoint pods are active and healthy
    triggers the CDL operations
    does not retry the Create, Read, Update, or Delete operations
    do not send any error messages.
    a CDL endpoint pod restarts
    retries the Create, Read, Update, or Delete operations
    sends the error responses with these error codes:
    • ERROR_FROM_INDEXING [501]
    • ERROR_FROM_SLOT [502]
    • DATASTORE_EP_QUEUE_FULL [503]
    • MAX_CAPACITY_REACHED [507]
This section describes the SMF local data store endpoint failure call flow.
Figure 2. CDL endpoint failure call flow
The table details the steps involved in the CDL endpoint failure call flow.
Table 2. CDL endpoint failure call flow description
Step Description
The AMF sends a Create Request to SMF REST endpoint over the N11 interface.
After receiving the request, the SMF REST endpoint forwards the Create Request to the SMF service.
The SMF service attempts to reach the CDL endpoint to send the session creation request. However, the CDL endpoint is unreachable.
The Create Request is evaluated in the stored session. The SMF service then forwards the request to the CDL endpoint.
After the call request is successful, the SMF service sends a Success Message to the SMF REST endpoint.
6
The SMF REST endpoint forwards the Success Message to the AMF.
Configure the CDL through SMF Ops Center
The configuration of the CDL using SMF Ops Center involves these steps:
Procedure
Step 1
Configure the CDL session database and define the base configuration
Step 2
Configure the Zookeeper in CDL
Step 3
Configure event trace data
Procedure
Step 1
Define the system ID, node type, and zookeeper replica server ID in the global configuration mode to set up the CDL session database.
CLI Command Description
Range
Default Value
cdl system-id system_id
Specifies the system or Kubernetes cluster identity.
NA
cdl node-type node_type
Specifies the Kubernetes node label to configure the node affinity. The value must be a string.
0–64
session
cdl zookeeper replica zookeeper_replica_id
Specifies the zookeeper replica server's ID.
NA
NA
Step 2
Set the log level, cluster, replica, slot, index, and slice parameters to define the base configuration for the CDL datastore session and save the configuration.
Range
Default Value
cdl logging default-log-level debug_level
cdl logging default-log-level debug_level —Specifies the default log level.
NA
NA
cluster-id cluster-id
cluster-id cluster-id —Specifies the Kubernetes cluster identity. NA 1
endpoint replica num_replica
endpoint replica num_replica —Specifies the number of replicas to be created. The value must be an integer.
num_replica —The value must be an integer in the range of 1 to 16.
num_replica —The default value is 1.
slot { replica num_replica | map num_map/shards| write-factor write_factor }
  • replica num_replica —Specifies the number of replicas to be created.
  • map num_map/shards —Specifies the number of partitions in a slot.
  • write-factor write_factor —Specifies the number of copies to be written before a successful response.
    Note
    Make sure that the value is lower than or equal to the number of replicas.
  • num_replica —The value must be an integer in the range of 1 to 16.
  • num_map/shards —The value must be an integer in the range of 1 to 1024.
  • write_factor —The value must be an integer in the range of 0 to 16.
  • num_replica —The default value is 1.
  • num_map/shards —The default value is 1.
  • write_factor —The default value is 1.
slot notification { host host | port port | limit tps}
  • notification host host —Specifies the notification server hostname or IP address.
  • slot notification port port —Specifies the notification server port number.
  • slot notification limit tps —Specifies the notification limit per second.
NA
  • host —The default value is datastore-notification-ep
  • port —The default value is 8890.
  • tps —The default value is 2000
index { replica num_replica | map num_map/shards | write-factor write_factor }
  • map num_map/shards —Specifies the number of partitions in a slot. Avoid modifying this value after deploying the CDL.
  • map num_map/shards —The value must be an integer in the range of 1 to 1024.
  • write-factor write_factor —The value must be an integer in the range of 0 to 16.
  • num_replica —The default value is 2.
slice-names cdl_slice_name slice-names cdl_slice_name —Specify the CDL slice names. The value must be an alphanumeric string. cdl_slice_name —The value must be an integer in the range of 0 to 16. NA
What to do next
Support for slice-based CDL session statistics
The SMF Support for Slice Based CDL Session Statistics enables the SMF to support session statistics and management commands based on slice parameters, specifically the Slice/Single Network Slice Selection Assistance Information (Snssai) values such as sst (Slice/Service Type) and sd (Slice Differentiator). Previously, there was no mechanism to determine the number of sessions or perform show and clear operations filtered by these slice parameters.
Sessions are tagged with a CDL non-unique key based on slice values. Key format being, snssai:<sst><sd>.
  • sst: Unsigned integer (0-255), stored as a 3-character string (e.g., 0-9 as "00X", 10-99 as "0XX", 100-255 as "XXX").
  • sd: 3-octet hexadecimal string representing the Slice Differentiator.
Note
cdl show sessions summary slice-name command can be used to verify the snssai key added in db_records_total metrics.
Example query:
avg(db_records_total{ session_type=snssai:010,abf123}) by
(session_type,cdl_slice,systemId)
Benefits of slice-based CDL session statistics
This section lists the positive outcomes that users can experience from using this feature.
  • Slice-specific session visibility: Enables operators to view active session counts and details filtered by slice parameters (sst and sd), improving monitoring granularity
  • Targeted session management: Allows clearing of subscriber sessions based on slice values, facilitating precise session control and troubleshooting.
  • Integration with CDL metrics: Leverages CDL statistics and metrics for real-time session counts and verification.
  • Flexible CLI filtering: Supports exact matches and prefix-based searches (starts-with), accommodating various operational needs.
Procedure
Step 1
Specify the size of Zookeeper data storage in gigabyte in the global configuration mode.
cdl zookeeper data-storage-size data_storage_size_in_gb
Example:
[smf] smf(config)# cdl zookeeper data-storage-size 20 GB
Note
The default value is 20 GB. The value must be an integer in the range of 1 to 64.
Step 2
Specify the size of the Zookeeper data log storage in gigabyte.
log-storage-size log_storage_size_in_gb
Example:
[smf] smf(config-cdl-zookeeper)# log-storage-size 20 GB
Note
Sample configuration of CDL session database
This sample guides you to configure the Common Data Layer (CDL) session database in SMF.
config
cdl zookeeper replica num_zk_replica
cdl datastore session
endpoint replica ep_replica
 index map index_shard_count
 slot replica slot_replica
 slot map slot_shard_count
exit
This section describes how to configure the SMF to store event trace data in CDL database record. You can enable the storage of event trace data in the CDL database record for system diagnostics. The event trace data shows the call flow event for the subscribers.
Follow these steps to enable the storage of event trace data in the CDL database record:
Procedure
Step 1
Define the system-diagnostics event-trace state to enable in the global configuration mode.
system-diagnostics event-trace [ enable | disable ]
Example:
[smf] smf(config)# system-diagnostics event-trace  enable
Note
If you disable the event_trace_state , you save approximately 1 KB of database storage for each SMF database record.
Step 2
[Optional] Use the show running-config system-diagnostics event-trace command to verify whether the event trace is enabled.
Example:
 [smf] smf# show running-config system-diagnostics event-trace
 system-diagnostics event-trace enabled
Limitations of CDL configuration
This section describes the limitations of CDL configuration.
Limitations on retry mechanism
SMF stops retrying the request in these scenarios:
  • By default, the maximum retry limit for a request is three. After reaching this limit, SMF stops retrying the request, and the response is sent to the application
  • The system stops retries upon receiving a successful response during the retry, and sends the response to the application.
Limitations on failure handling
SMF performs the failure handling with these limitations:
  • The SMF service reroutes calls only when it encounters gRPC errors, such as UNAVAILABLE. It does not acknowledge errors returned by the datastore endpoint or actual gRPC timeouts, such as the DEADLINE_EXCEEDED gRPC status code.
  • The SMF service does not resolve failures that occur with the datastore such as indexing and slot failures. The CDL layer must resolve these failures, and send a remote API call if necessary.
