Voice call continuity during failed 5G to 4G handover
A voice call continuity feature is a network feature that
detects service requests during 5G-4G handover events
maintains voice call continuity and quick user plane restoration, and
activates automatically
Feature Name |
Release Information |
Feature Description |
Stabilizing voice call continuity during failed 5G to 4G handover |
2026.03.0 |
You maintain voice call continuity and minimize call drops when a 5G to 4G handover fails. Your device can quickly resume 5G voice service with near-instant recovery and improved call stability. |
Feature attributes and applicability for voice call continuity
The following list describes key attributes of this feature:
Detects service requests during handover events
Maintains voice call continuity and quick user plane restoration
Activates automatically
Applies only to UE-initiated (idle mode exit) triggers
The following table compares pre-feature to post-feature behavior:
Attribute |
Pre-feature behavior |
Post-feature behavior |
Service request during handover |
Rejected (HTTP 400), user plane recovery blocked |
Accepted, triggers handover termination and rapid user plane restoration |
Voice call impact |
SIP 481 call drop, RTP loss window up to 10 seconds |
IMS continuity preserved, RTP loss reduced to < 1 second |
Operator action required |
Possible manual intervention |
None; automatic operation |
Compatibility |
Manual configuration required |
Backward compatible, no config changes needed |
Note |
Ensure that the service request trigger is UE-initiated (Idle Mode Exit) for this feature to apply. Other triggers do not activate this enhancement. |
This feature addresses scenarios in which the UE returns to 5G following a failed LTE handover and issues a service request while the access network has not sent a corresponding handover cancel. The SMF enhancement ensures any pending handover is canceled, user plane is re-established quickly, and IMS (IP Multimedia Subsystem) service stability is maintained.
Example of feature usage during failed 5G-to-4G handover
After a failed LTE handover, a UE reselects 5G and sends a service request. The SMF detects that a handover is pending, cancels the incomplete procedure, and resumes user plane services for the call in 5G. The voice call continues without interruption, without a SIP call drop.
Feedback
