Common Charging IDs in roaming scenarios
A common Charging ID in roaming scenarios is a unique session-level identifier that
is generated by the SMF for each PDU session,
is used by both the Visited SMF (V-SMF) and Home SMF (H-SMF) during roaming to ensure unified charging data correlation, and
enables the Charging Function (CHF) to accurately aggregate charging events and usage records for the same session, even across different networks.
Feature History
Feature Name |
Release Information |
Description |
Common charging IDs in roaming scenarios |
2026.03.0 |
When a user roams between networks, both the visited and home SMF must use the same Charging ID for the PDU session. This prevents charging data fragmentation, avoids duplicate or mismatched records, and ensures accurate billing and quota management. The Charging ID acts as a session anchor, supporting both online and offline charging in converged deployments. |
Feedback
