Release Notes for UCC SMF, Release 2026.01.3
Available Languages
Download Options
  • PDF
    (379.7 KB)
    View with Adobe Reader on a variety of devices
Updated:April 28, 2026
Bias-Free Language
The documentation set for this product strives to use bias-free language. For the purposes of this documentation set, bias-free is defined as language that does not imply discrimination based on age, disability, gender, racial identity, ethnic identity, sexual orientation, socioeconomic status, and intersectionality. Exceptions may be present in the documentation due to language that is hardcoded in the user interfaces of the product software, language used based on RFP documentation, or language that is used by a referenced third-party product. Learn more about how Cisco is using Inclusive Language.
Available Languages
Download Options
  • PDF
    (379.7 KB)
Ultra Cloud Core - Session Management Function, Release 2026.01.3. 3
New software features. 3
Changes in behavior 3
Resolved issues. 5
Open issues. 5
Compatibility. 5
Supported software packages. 6
Related resources. 8
Legal information. 8
This Release Notes identifies changes and issues related to the software release of 5G Converged Core Session Management Function (SMF).
Release lifecycle milestones
The following table provides EoL milestones for Cisco UCC SMF software:
Table 1.             EoL milestone information for UCC SMF, Release 2026.01.3
Milestone
Date
First Customer Ship (FCS)
30-Jan-2026
End of Life (EoL)
30-Jan-2026
End of Software Maintenance (EoSM)
31-July-2027
End of Vulnerability and Security Support (EoVSS)
31-July-2027
Last Date of Support (LDoS)
31-July-2028
These milestones and the intervals between them are defined in the Cisco Ultra Cloud Core (UCC) Software Release Lifecycle Product Bulletin available on cisco.com.
There are no new software features introduced in this release.
Changes in behavior
Table 2.             Behavior changes for UCC SMF, Release 2026.01.3
Description
Behavior changes
Optimized DNS cache retrieval and synchronization
[CSCwu05697]
Previous Behavior: When executing the show dns-cache command, the system retrieved information from all dns-proxy instances because the cache entries were not synchronized across the various instances.
New Behavior: All dns-proxy instances are now synchronized. Consequently, the show dns-cache command only needs to retrieve information from a single instance to provide a complete view of the cache.
Customer Impact: This change improves the performance and response time of the show dns-cache command, particularly in high-scale environments, by reducing the internal overhead required to aggregate data from multiple instances.
Updated N4 FAR handling for unreachable UEs
[CSCwu08006]
Previous Behavior: When AMF responded to an N11N1N2MessageTransfer message with a 504 error and the cause "UE_NOT_REACHABLE", the SMF updated the Forwarding Action Rule (FAR) to the UPF with the flags BUFF=1, NOCP=1, and DROPBU=1.
New Behavior: When AMF responds with a 504 error ("UE_NOT_REACHABLE"), SMF now updates the FAR to UPF with the flags DROP=1 and DROPBU=1.
Customer Impact: This change modifies how UPF handles traffic when a UE is in idle mode and unreachable. Instead of attempting to buffer packets, the system will now drop them, preventing unnecessary resource consumption or the delivery of stale data.
Resolved issues
This table lists the resolved issues in this specific software release.
Note: This software release may contain bug fixes first introduced in other releases. To see additional information, click the bug ID to access the Cisco Bug Search Tool. To search for a documented Cisco product issue, type in the browser: <bug_number> site:cisco.com.
Table 3.        Resolved issues for UCC SMF, Release 2026.01.3
Bug ID
Description
CSCwt81979
SMF not updating RAT-TYPE when changed in between HO.
CSCwt85627
Unnecessary EBI Assignment during VoNR Flow multiparty calls.
CSCwu00785
Error logs for specific etcd keys "C.GR.1.etcd.checkpoint" and "C.GR.2.etcd.checkpoint" randomly observed in service pod log.
CSCwu05697
FQDN Resolution issue when dns-proxy Pod Failover to Secondary Node.
CSCwu08006
504 "GATEWAY TIMEOUT" with Cause=UE_NOT_REACHABLE.
Open issues
There are no open bugs in this specific software release.
Compatibility
This section lists compatibility information of the Cisco UCC software products that are verified to work with this version of the UCC SMF software.
Table 4.             Compatibility information for UCC SMF, Release 2026.01.3
Product
Supported Release
Ultra Cloud Core SMI
2026.01.1.08
Ultra Cloud CDL
2.1
Ultra Cloud Core UPF
2026.01.0
Ultra Cloud cnSGWc
2026.01.3
This section provides information about the release packages associated with UCC SMF software.
Table 5.             Software packages for UCC SMF, Release 2026.01.3
Software Package
Description
Release
ccg-2026.01.3.SPA.tgz
The SMF offline release signature package. This package contains the SMF deployment software, NED package, as well as the release signature, certificate, and verification information.
2026.01.3
ncs-6.4.8.2-ccg-nc-1.1. 2026.01.3.tar.SPA.tgz
The NETCONF NED package. This package includes all the yang files that are used for NF configuration.
Note that NSO is used for the NED file creation.
6.4.8.2
ncs-6.1.14-ccg-nc-1.1. 2026.01.3.tar.SPA.tgz
6.1.14
Cloud native product version numbering system
The show helm list command displays detailed information about the version of the cloud native product currently deployed.
Figure 1.           Cloud native product versioning format and description
P530#yIS1
The appropriate version number field increments after a version has been released. The new version numbering format is a contiguous sequential number that represents incremental changes between releases. This format facilitates identifying the changes between releases when using Bug Search Tool to research software releases.
Software integrity version
To verify the integrity of the software image you have from Cisco, you can validate the SHA512 checksum information against the checksum identified by Cisco for the software.
Image checksum information is available through Cisco.com Software Download Details. To find the checksum, hover the mouse pointer over the software image you have downloaded.
Figure 2.           Sample of converged core gateway software image
P536#yIS1
At the bottom you find the SHA512 checksum, if you do not see the whole checksum you can expand it by pressing the "..." at the end.
To validate the information, calculate a SHA512 checksum using the information in the following table and verify that it matches the one provided on the software download page.
To calculate a SHA512 checksum on your local desktop, see this table.
Table 6.             Checksum calculations per operating system
Operating System
SHA512 checksum calculation command examples
Microsoft Windows
Open a command line window and type the following command:
> certutil.exe -hashfile <filename.extension> SHA512
Apple MAC
Open a terminal window and type the following command:
$ shasum -a 512 <filename.extension>
Linux
$ sha512sum <filename.extension>
OR
Note:      <filename> is the name of the file. <extension> is the file type extension (for example, .zip or .tgz).
If the SHA512 checksum matches, you can be sure that no one has tampered with the software image or the image has not been corrupted during download.
If the SHA512 checksum does not match, we advise you not to attempt upgrading any systems with the corrupted software image. Download the software again and verify the SHA512 checksum again. If there is a constant mismatch, please open a case with the Cisco Technical Assistance Center.
Certificate validation
SMF software images are signed via x509 certificates. Please view the.README file packaged with the software for information and instructions on how to validate the certificates.
Related resources
This table provides key resources and links to the support information and essential documentation for SMF and other Ultra Cloud Core (UCC) products.
Table 7.             Related resources and additional information
Resource
Link
SMF documentation
cnSGWc documentation
Serving Gateway Function
SMI documentation
Subscriber Microservices Infrastructure
UPF documentation
User Plane Function
Service request and additional information
Cisco Support
Legal information
Cisco and the Cisco logo are trademarks or registered trademarks of Cisco and/or its affiliates in the U.S. and other countries. To view a list of Cisco trademarks, go to this URL: www.cisco.com/go/trademarks. Third-party trademarks mentioned are the property of their respective owners. The use of the word partner does not imply a partnership relationship between Cisco and any other company. (1110R)
Any Internet Protocol (IP) addresses and phone numbers used in this document are not intended to be actual addresses and phone numbers. Any examples, command display output, network topology diagrams, and other figures included in the document are shown for illustrative purposes only. Any use of actual IP addresses or phone numbers in illustrative content is unintentional and coincidental.
© 2026 Cisco Systems, Inc. All rights reserved.
Learn more
