Release Notes for UCC SMF, Release 2026.01.1
Available Languages
Download Options
  • PDF
    (410.3 KB)
    View with Adobe Reader on a variety of devices
Updated:March 9, 2026
Bias-Free Language
The documentation set for this product strives to use bias-free language. For the purposes of this documentation set, bias-free is defined as language that does not imply discrimination based on age, disability, gender, racial identity, ethnic identity, sexual orientation, socioeconomic status, and intersectionality. Exceptions may be present in the documentation due to language that is hardcoded in the user interfaces of the product software, language used based on RFP documentation, or language that is used by a referenced third-party product. Learn more about how Cisco is using Inclusive Language.
Available Languages
Download Options
  • PDF
    (410.3 KB)
Ultra Cloud Core - Session Management Function, Release 2026.01.1. 3
New software features. 3
Changes in behavior 3
Resolved issues. 5
Open issues. 5
Compatibility. 5
Supported software packages. 6
Related resources. 8
Legal information. 8
This Release Notes identifies changes and issues related to the software release of 5G Converged Core Session Management Function (SMF).
Release lifecycle milestones
The following table provides EoL milestones for Cisco UCC SMF software:
Table 1.             EoL milestone information for UCC SMF, Release 2026.01.1
Milestone
Date
First Customer Ship (FCS)
30-Jan-2026
End of Life (EoL)
30-Jan-2026
End of Software Maintenance (EoSM)
31-July-2027
End of Vulnerability and Security Support (EoVSS)
31-July-2027
Last Date of Support (LDoS)
31-July-2028
These milestones and the intervals between them are defined in the Cisco Ultra Cloud Core (UCC) Software Release Lifecycle Product Bulletin available on cisco.com.
There are no new software features introduced in this release.
Changes in behavior
This section provides a brief description of the behavior changes introduced in this release.
Table 2.             Behavior changes for UCC SMF, Release 2026.01.1
Description
Behavior changes
Handling of conditional or optional IEs and Supportedfeatures in N11/N16 messages
CSCwt28379]
Previous Behavior: Conditional or optional IEs were sent with null/empty values in compliance with specification for nsmf-pdusession v.16. Supportedfeatures with 0 value were sent in nsmf-pdusession specification v.15, and mandatory feature flags HOFAIL, ES3XX, and AASN were included in Supportedfeatures in nsmf-pdusession specification v.16.
New Behavior: To optimize N11 and N16 messaging, the SMF now omits null or empty conditional and optional IEs.
·       nsmf-pdusession specification v.15: SupportedFeatures are omitted if the value is empty.
·       Following the nsmf-pdusession v16 specification, the HOFAIL, ES3XX, and AASN flags are now excluded by default. A new CLI parameter has been added to the SMF profile to enable these flags if required: profile smf > instances > supported-features [hofail es3xx aasn]
·       By default, only the VQOS bit is included; DTSSA and ACSCR bits are sent only when explicitly enabled.
Customer Impact: Null or empty conditional/optional IEs and supportedfeatures with empty values are skipped on N11/N16 messages, and mandatory feature flags are excluded unless explicitly enabled using a new CLI parameter.
SNSSAI encoding in N1 accept message during roaming
[CSCwt33699]
Previous Behavior: SNSSAI was not encoded properly in N1 accept when both visitor SNSSAI (SST only) and mapped SNSSAI (SST and SD) were sent during roaming scenarios.
New Behavior: SNSSAI is now encoded correctly in N1 accept with both visitor SNSSAI (SST with or without SD) and mapped SNSSAI (SST with or without SD) during roaming scenarios.
qosFlowDescription IE handling in EPCO/PCO within bearer context of CBR message
[CSCwt09790]
Previous Behavior: qosFlowDescription IE in EPCO/PCO within Bearer-Context of a CBR message included EPS Bearer Identity (EBI) IE containing the previous call's dedicated bearer EBI.
New Behavior: qosFlowDescription IE in EPCO/PCO within Bearer-Context of a CBR message no longer includes EBI IE.
Customer Impact: Prevents semantic errors on the UE caused by EBI IE.
Sequence number handling for MBC-triggered UBR
[CSCwt13922]
Previous Behavior: When SMF received an MBC without AMBR or Default QoS changes, the resulting UBR was sent directly to sgw-service and did not reuse the MBC's sequence number.
New Behavior: The MBC-triggered UBR now always uses the same sequence number as the original MBC, regardless of AMBR or Default QoS changes.
Customer Impact: Ensures consistent sequence number handling, resolving issues where UBR did not reuse the MBC sequence number in certain scenarios.
NRF subscription request – subscriptionId field handling
[CSCwt26067]
Previous Behavior: SMF included the subscriptionId field with an empty value ("subscriptionId": "") in the NRF subscription creation request (POST /nnrf-nfm/v1/subscriptions). As per 3GPP specification v.29.510, subscriptionId is a read-only attribute generated by NRF in the response and must not be present in the request.
New Behavior: SMF omits the subscriptionId field from the NRF subscription creation request when it is not set. NRF generates and returns the subscriptionId only in the response, in accordance with 3GPP specification v.29.510.
Customer Impact: This change aligns the implementation with 3GPP specification 29.510 and ensures standards compliance.
Resolved issues
This table lists the resolved issues in this specific software release.
Note: This software release may contain bug fixes first introduced in other releases. To see additional information, click the bug ID to access the Cisco Bug Search Tool. To search for a documented Cisco product issue, type in the browser: <bug_number> site:cisco.com.
Table 3.        Resolved issues for UCC SMF, Release 2026.01.1
Bug ID
Description
CSCwt28379
Suppressing IE with null values on N16.
CSCwt16290
Static IP allocation fails after GR switchover when new static IP pools and dnn added multiple times.
CSCwt31579
PAPN SMF is not allocating IPAM from dynamic pool and unable to recover the same as well.
CSCwt33699
vSMF does not send correct value of Mapped Slice SST and SD in PDU Session establishment accept.
CSCwt33061
Roaming-flow - AMF-N11 released EBI error log.
CSCwt09790
SMF - EBI in PCO CBR sent wrongly post EPSFB.
CSCwt13922
CC Enable-bypass UBR sent with wrong sequence number
CSCwt26067
SubscriptionId is empty in request to NRF.
Open issues
There are no open bugs in this specific software release.
Compatibility
This section lists compatibility information of the Cisco UCC software products that are verified to work with this version of the UCC SMF software.
Table 4.             Compatibility information for UCC SMF, Release 2026.01.1
Product
Supported Release
Ultra Cloud Core SMI
2026.01.1.08
Ultra Cloud CDL
2.1
Ultra Cloud Core UPF
2026.01.0
Ultra Cloud cnSGWc
2026.01.1
This section provides information about the release packages associated with UCC SMF software.
Table 5.             Software packages for UCC SMF, Release 2026.01.1
Software Package
Description
Release
ccg-2026.01.1.SPA.tgz
The SMF offline release signature package. This package contains the SMF deployment software, NED package, as well as the release signature, certificate, and verification information.
2026.01.1
ncs-6.4.8.2-ccg-nc-1.1. 2026.01.1.tar.SPA.tgz
The NETCONF NED package. This package includes all the yang files that are used for NF configuration.
Note that NSO is used for the NED file creation.
6.4.8.2
ncs-6.1.14-ccg-nc-1.1. 2026.01.1.tar.SPA.tgz
6.1.14
Cloud native product version numbering system
The show helm list command displays detailed information about the version of the cloud native product currently deployed.
Figure 1.           Cloud native product versioning format and description
P530#yIS1
The appropriate version number field increments after a version has been released. The new version numbering format is a contiguous sequential number that represents incremental changes between releases. This format facilitates identifying the changes between releases when using Bug Search Tool to research software releases.
Software integrity version
To verify the integrity of the software image you have from Cisco, you can validate the SHA512 checksum information against the checksum identified by Cisco for the software.
Image checksum information is available through Cisco.com Software Download Details. To find the checksum, hover the mouse pointer over the software image you have downloaded.
Figure 2.           Sample of converged core gateway software image
P536#yIS1
At the bottom you find the SHA512 checksum, if you do not see the whole checksum you can expand it by pressing the "..." at the end.
To validate the information, calculate a SHA512 checksum using the information in the following table and verify that it matches the one provided on the software download page.
To calculate a SHA512 checksum on your local desktop, see this table.
Table 6.             Checksum calculations per operating system
Operating System
SHA512 checksum calculation command examples
Microsoft Windows
Open a command line window and type the following command:
> certutil.exe -hashfile <filename.extension> SHA512
Apple MAC
Open a terminal window and type the following command:
$ shasum -a 512 <filename.extension>
Linux
$ sha512sum <filename.extension>
OR
Note:      <filename> is the name of the file. <extension> is the file type extension (for example, .zip or .tgz).
If the SHA512 checksum matches, you can be sure that no one has tampered with the software image or the image has not been corrupted during download.
If the SHA512 checksum does not match, we advise you not to attempt upgrading any systems with the corrupted software image. Download the software again and verify the SHA512 checksum again. If there is a constant mismatch, please open a case with the Cisco Technical Assistance Center.
Certificate validation
SMF software images are signed via x509 certificates. Please view the.README file packaged with the software for information and instructions on how to validate the certificates.
Related resources
This table provides key resources and links to the support information and essential documentation for cnSGWc and other Ultra Cloud Core (UCC) products.
Table 7.             Related resources and additional information
Resource
Link
SMF documentation
cnSGWc documentation
Serving Gateway Function
SMI documentation
Subscriber Microservices Infrastructure
UPF documentation
User Plane Function
Service request and additional information
Cisco Support
Legal information
Cisco and the Cisco logo are trademarks or registered trademarks of Cisco and/or its affiliates in the U.S. and other countries. To view a list of Cisco trademarks, go to this URL: www.cisco.com/go/trademarks. Third-party trademarks mentioned are the property of their respective owners. The use of the word partner does not imply a partnership relationship between Cisco and any other company. (1110R)
Any Internet Protocol (IP) addresses and phone numbers used in this document are not intended to be actual addresses and phone numbers. Any examples, command display output, network topology diagrams, and other figures included in the document are shown for illustrative purposes only. Any use of actual IP addresses or phone numbers in illustrative content is unintentional and coincidental.
© 2026 Cisco Systems, Inc. All rights reserved.
Learn more
