Application-based Alerts
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Disabled - Configuration Required
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
First introduced.
Pre-2020.02.0
Feature Description
When the system detects an anomaly, it generates an alert notification. The system statistics are the cause for these alert notifications. You can set an expression to trigger an alert when the expression becomes true.
Converged Core Refactoring Changes
This section describes the changes related to converged core refactoring in this chapter.
For the following interface-specific alerts, the n4 and smf prefixes in the procedure type names and statistic names respectively are removed.
  • N4 Message Success
  • N4 UPF Association Down
  • N4 UPF Association Up
How it Works
The Common Execution Environment (CEE) uses the Prometheus Alert Manager for alerting operations. The CEE YANG model - either through CLI or API - allows users to view the active alerts, silenced alerts, and alert history. Also, the applications can call the alert API directly to add or clear alerts. The Prometheus Alert Manager API (v2) is the standard API used.
The Prometheus Alerts Manager includes the following options:
  • Defining Alert Rules: This option defines the types of alerts that the Alert Manager should trigger. Use the Prometheus Query Language (PromQL) to define the alerts.
  • Defining Alert Routing: This option defines the action the Alert Manager should take after receiving the alerts. At present, the SNMP Trapper is supported as the outbound alerting. Also, the CEE provides an Alert Logger for storing the generated alerts.
Configuring Alert Rules
To configure the alert rules, use the following configuration:
configure
   alerts rules group alert_group_name
   interval-seconds seconds
   rule rule_name
      expression promql_expression
      duration duration
      severity severity_level
      type alert-type
      annotation annotation_name
      value annotation_value
      exit
   exit
NOTES:
  • alerts rules : Specifies the Prometheus alerting rules.
  • group alert_group_name : Specifies the Prometheus alerting rule group. One alert group can have multiple lists of rules. alert-group-name is the name of the alert group. The alert-group-name must be a string in the range of 0–64 characters.
  • interval-seconds seconds : Specifies the evaluation interval of the rule group in seconds.
  • rule rule_name : Specifies the alerting rule definition. rule_name is the name of the rule.
  • expression promql_expression : Specifies the PromQL alerting rule expression. promql_expression is the alert rule query expressed in PromQL syntax.
  • duration duration : Specifies the duration of a true condition before it is considered true. duration is the time interval before the alert is triggered.
  • severity severity_level : Specifies the severity of the alert. severity-level is the severity level of the alert. The severity levels are critical, major, minor, and warning.
  • type alert_type : Specifies the type of the alert. alert_type is the user-defined alert type. For example, Communications Alarm, Environmental Alarm, Equipment Alarm, Indeterminate Integrity Violation Alarm, Operational Violation Alarm, Physical Violation Alarm, Processing Error Alarm, Quality of Service Alarm, Security Service Alarm, Mechanism Violation Alarm, or Time Domain Violation Alarm.
  • annotation annotation_name : Specifies the annotation to attach to the alerts. annotation_name is the name of the annotation.
  • value annotation_value : Specifies the annotation value. annotation_value is the value of the annotation.
The following example configures an alert, which is triggered when the percentage of Unified Data Management (UDM) responses is less than the specified threshold limit.
Example:
	configure terminal
		alerts rules group SMFUDMchk_incr
		interval-seconds 300
		rule SMFUDMchk_incr
		expression "sum(increase(smf_restep_http_msg_total{nf_type=\"udm\", message_direction=\"outbound\", response_status=~\"2..\"}[3m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"udm\", message_direction=\"outbound\"}[3m])) < 0.95"
		severity major
		type "Communications Alarm"
		annotation summary
		value "This alert is fired when the percentage of UDM responses is less than threshold“
		exit
	exit
exit
You can view the configured alert using the show running-config alerts command.
Example:
The following example displays the alerts configured in the running configuration:
		rule SMFUDMchk_incr
		severity major
		annotation summary
		exit
	exit
exit
Viewing Alert Logger
The Alert Logger stores all the generated alerts by default. You can view the stored alerts using the following show command.
show alert history [ filtering ]
You can narrow down the result using the following filtering options:
  • annotations: Specifies the annotations of the alert.
  • endsAt: Specifies the end time of the alert.
  • labels: Specifies the additional labels of the alert.
  • severity: Specifies the severity of the alert.
  • source: Specifies the source of the alert.
  • startsAt: Specifies the start time of the alert.
  • type: Specifies the type of the alert.
The following example displays the history of the alerts configured in the system:
Example:
show alerts history
alerts active SMFUDMchk_incr ac2a970ab621
state active
severity major
startsAt 2019-11-15T08:26:48.283Z
source System
annotations [ "summary:This alert is fired when the percentage of UDM responses is less than threshold.” ]
You can view the active and silenced alerts with the show alerts active and show alerts active commands.
The following example displays the active alerts. The alerts remain active as long as the evaluated expression is true.
Example:
show alerts active
state active
severity major
source System
Call Flow Procedure Alerts
This section provides detail of commands that are required to configure alerts related to various call flow procedures.
4G PDN Modify
Use the following commands to configure alerts related to the 4G PDN Modify procedure.
alerts rules group SMFPDN
   rule SMFPDNModify
   expression “sum(smf_service_stats{procedure_type=~\”pdn_ho_location_changed| pdn_ho_rat_type_changed|pdn_inter_sgw_handover|pdn_mbr\” , status=\“success\”})/sum(smf_service_stats{procedure_type=~ \”pdn_ho_location_changed|pdn_ho_rat_type_changed |pdn_inter_sgw_handover|pdn_mbr\” , status=\“attempted\”}) < 0.95”
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 4G PDN Modify is below threshold”
   exit
exit
4G PDN Release Success
Use the following commands to configure alerts related to the 4G PDN Release Success procedure.
   rule SMFPDNRelease
   expression “sum(smf_service_stats{procedure_type=~\“.*pdn_sess_rel\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“.*pdn_sess_rel\” , status=\“attempted\”} < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 4G PDN Release is below threshold.”
   exit
exit
4G PDN Setup Success
Use the following commands to configure alerts related to the 4G PDN Setup Success procedure.
   rule SMFPDNSetup
   expression “sum(smf_service_stats{procedure_type=\”pdn_sess_create\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\”pdn_sess_create\” , status=\“attempted\”} < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 4G PDN Setup is below threshold.”
   exit
exit
4G to 5G HO Success
Use the following commands to configure alerts related to the 4G to 5G HO Success procedure.
alerts rules group Handover
   rule 4gTo5gHOSuccess
   expression “sum(smf_service_stats{procedure_type=~\“n26_4g_to_5g_handover|n26_4g_to_5g_im_mobility\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“n26_4g_to_5g_handover|n26_4g_to_5g_im_mobility\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 4G to 5G HO is below threshold.”
   exit
exit
4G To WiFi HO Success
Use the following commands to configure alerts related to the 4G to WiFi HO Success procedure.
   rule 4GtoWifiHOSuccess
   expression “sum(smf_service_stats{procedure_type=\”enb_to_untrusted_wifi_handover\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\“enb_to_untrusted_wifi_handover\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage of N4 responses sent is lesser than 95 %."
   exit
exit
5G N2 HO Success
Use the following commands to configure alerts related to the 5G N2 HO Success procedure.
   rule N2HOSuccess
   expression “sum(smf_service_stats{procedure_type=\“n2_handover\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\“n2_handover\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G N2 HO is below threshold.”
   exit
exit
5G PDU Idle Success
Use the following commands to configure alerts related to the 5G PDU Idle Success procedure.
alerts rules group SMFPDU
   rule SMFPDUIdleSuccess
   expression “sum(smf_service_stats{procedure_type=~\“.*idle\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“.*idle\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G PDU Idle is below threshold”
   exit
exit
5G PDU Modify Success
Use the following commands to configure alerts related to the 5G PDU Modify Success procedure.
   rule SMFSessionModifySuccess
   expression “sum(smf_service_stats{procedure_type=~\“.*pdu_sess_mod\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“.*pdu_sess_mod\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G PDU Modify is below threshold”
   exit
exit
5G PDU Release Success
Use the following commands to configure alerts related to the 5G PDU Release Success procedure.
   rule SMFSessionReleaseFailure
   expression “sum(smf_service_stats{procedure_type=~\“.*pdu_sess_rel\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“.*pdu_sess_rel\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G PDU Setup is below threshold”
   exit
exit
5G PDU Setup Success
Use the following commands to configure alerts related to the 5G PDU Setup Success procedure.
   rule SMFSessionSetupFailure
   expression “sum(smf_service_stats{procedure_type=\”pdu_sess_create\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\”pdu_sess_create\” , status=\“attempted\”} < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when failed to setup sessions is more than 5%”
   exit
exit
5G to 4G HO Success
Use the following commands to configure alerts related to the 5G to 4G HO Success procedure.
   rule 5gTo4gHOSuccess
   expression “sum(smf_service_stats{procedure_type=~\“pdn_5g_4g_handover |pdn_5g_4g_handover_dft|eps_fb_5g_4g_handover_dft|eps_fb_5g_4g_handover_idft |pdn_5g_4g_handover_idft\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“pdn_5g_4g_handover  |pdn_5g_4g_handover_dft|eps_fb_5g_4g_handover_dft| eps_fb_5g_4g_handover_idft|pdn_5g_4g_handover_idft\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G to 4G HO is below threshold.”
   exit
exit
5G To WiFi HO Success
Use the following commands to configure alerts related to the 5G to WiFi HO Success procedure.
   rule 5GtoWifiHOSuccess
   expression “sum(smf_service_stats{procedure_type=\”nr_to_untrusted_wifi_handover\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\“nr_to_untrusted_wifi_handover\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   exit
exit
5G Xn HO Success
Use the following commands to configure alerts related to the 5G Xn HO Success procedure.
   rule XnHOSuccess
   expression “sum(smf_service_stats{procedure_type=\“xn_handover\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\“xn_handover\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G Xn HO is below threshold.”
   exit
exit
PDN Session Create
Use the following commands to configure alerts related to the PDN Session Create procedure.
alerts rules group SMFProcStatus
   rule PDNSessCreate
   expression "sum(increase(smf_service_stats{app_name=\"SMF\",procedure_type=  /\"pdn_sess_create\",status=\"success\”}[5m])) / sum(increase(smf_service_stats{app_name=\"SMF\  /",procedure_type=\"pdn_sess_create\",status=\"  /attempted\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the success percentage of pdn_sess_create procedure is lesser threshold.”
   exit
exit
PDU Session Create
Use the following commands to configure alerts related to the PDU Session Create procedure.
   rule PDUSessCreate
   expression "sum(increase(smf_service_stats{app_name=\"SMF\",procedure_type=  /\"pdu_sess_create\",status=\"success\”}[5m]))sum  /(increase(smf_service_stats{app_name=\"SMF\",  /procedure_type=\"pdu_sess_create\",status=\  /"attempted\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the success percentage of pdu_sess_create procedure is lesser threshold.”
   exit
exit
PDU Session Modify
Use the following commands to configure alerts related to the PDU Session Modify procedure.
   rule PDUSessModify
   expression "sum(increase(smf_service_stats{app_name=\"SMF\",procedure_type=~\".  /*req_pdu_sess_mod\",status=\"success\”}[5m]))sum(increase  /(smf_service_stats{app_name=\"SMF\",procedure_type=~  /\”.*req_pdu_sess_mod\",status=\"attempted\”}[5m]))  / < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the success percentage of req_pdu_sess_mod procedure is lesser threshold.”
   exit
exit
PDU Session Release
Use the following commands to configure alerts related to the PDU Session Release procedure.
   rule PDUSessRelease
   expression "sum(increase(smf_service_stats{app_name=\"SMF\",procedure_type=~\".*req_pdu_sess_rel\",status=\  /"success\”}[5m]))sum(increase(smf_service_stats{app_name=\"SMF  /\",procedure_type=~\”.*req_pdu_sess_rel\",status=\  /"attempted\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the success percentage of req_pdu_sess_rel procedure is lesser threshold.”
   exit
exit
Interface Specific Alerts
This section provides detail of commands that are required to configure alerts related to various interfaces.
GTPC Peer Down
Use the following commands to configure alerts related to the GTPC Peer Down procedure.
alerts rules group GTPCPeerDown
   rule GTPCPeerDown
   expression nodemgr_gtpc_peer_status{gtpc_peer_status=\“gtpc_peer_path_down\”})
   severity major
   annotation summary
   value “This alert is fired when the GTPC Path failure detected for peer crosses threshold”
   exit
exit
N4 Message Success
Use the following commands to configure alerts related to the N4 Message Success procedure.
alerts rules group SMFSvcStatus
   rule SMFN4MessageSuccess
   expression "sum(protocol_udp_res_msg_total{message_direction=\"inbound\", status=\”accepted\”}) / sum(protocol_udp_res_msg_total{message_direction=\"inbound\”, status=~\”accepted|denied\”}) < 0.95"
   severity major
   annotation summary
   exit
exit
Use the following commands to configure alerts related to the N4 UPF Association Down query by N4 address.
alerts rules group N4Association
   rule SMFAssociationRelease
   expression ”proto_udp_res_msg_total{procedure_type=\“n4_association_release_res\”, message_direction= \“inbound\”, status=\“accepted\”}) ”
   severity major
   annotation summary
   value “This alert is fired when the N4 Association with UPF is released”
   exit
exit
Use the following commands to configure alerts related to the N4 UPF Association Up query by N4 address.
   rule N4AssociationUP
   expression ”proto_udp_res_msg_total{procedure_type=\“n4_association_setup_res\”, message_direction= \“inbound\”, status=\“accepted\”}”
   severity major
   annotation summary
   value “This alert is fired when the N4 Association with UPF is established”
   exit
exit
N7 Interface Outbound
Use the following commands to configure alerts related to an outbound N7 interface.
   rule SMFN7Outbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"pcf\", message_direction=\"outbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"pcf\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N7 responses received is lesser threshold.”
   exit
exit
N7 Interface Inbound
Use the following commands to configure alerts related to an inbound N7 interface.
   rule SMFN7Inbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"pcf\", message_direction=\"inbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"pcf\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N7 responses sent is lesser threshold.”
   exit
exit
N7 Message Timed Out
Use the following commands to configure alerts related to the N7 Message Timed Out procedure.
alerts rules group MessageTimeout
   rule SMFN7Timeout
   expression ”sum(irate(smf_restep_http_msg_total{nf_type=\“pcf\”, message_direction=\”inbound\”, response_status=\”504\”}[5m])) > 5”
   severity major
   annotation summary
   value “This alert is fired when the increase in timeout for N7 messages toward PCF crosses threshold”
   exit
exit
N10 Interface
Use the following commands to configure alerts related to the N10 interface.
   rule SMFN10
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"udm\", message_direction=\"outbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"udm\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N10 responses received is lesser threshold.”
   exit
exit
N11 Interface Inbound
Use the following commands to configure alerts related to an inbound N11 interface.
   rule SMFN11Inbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"amf\", message_direction=\"inbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"amf\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N11 responses sent is lesser threshold.”
   exit
exit
N11 Interface Outbound
Use the following commands to configure alerts related to an outbound N11 interface.
   interval-seconds 60
   rule SMFN11Outbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"amf\", message_direction=\"outbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"amf\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N11 responses received is lesser threshold.”
   exit
exit
N11 Message Timed Out
Use the following commands to configure alerts related to the N11 Message Timed Out procedure.
   rule SMFN40Timeout
   expression ”sum(irate(smf_restep_http_msg_total{nf_type=\“chf\”, message_direction=\”inbound\”, response_status=\”504\”}[5m])) > 5”
   severity major
   annotation summary
   value “This alert is fired when the increase in timeout for N11 messages toward AMF crosses threshold”
   exit
exit
N40 Interface Inbound
Use the following commands to configure alerts related to an inbound N40 interface.
   rule SMFN40Inbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"chf\", message_direction=\"inbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"chf\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N40 responses sent is lesser threshold.”
   exit
exit
N40 Interface Outbound
Use the following commands to configure alerts related to an outbound N40 interface.
   rule SMFN40Outbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"chf\", message_direction=\"outbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"chf\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N40 responses received is lesser threshold.”
   exit
exit
N40 Message Timed Out
Use the following commands to configure alerts related to the N40 Message Timed Out procedure.
   rule SMFN11Timeout
   severity major
   annotation summary
   value “This alert is fired the increase in timeout for N40 messages toward CHF crosses threshold”
   exit
exit
NRF Discovery
Use the following commands to configure alerts related to the NRF Discovery procedure.
alerts rules group NRF
   rule NRFDiscovery
   expression “sum(nf_discover_messages_total{result=~\”success|failure\”,svc_name=\”nnrf-disc\”, service_name=\”smf-rest-ep\”}) < 0.95”
   severity major
   annotation summary
   exit
exit
SMF Service Start
Use the following commands to configure alerts related to the SMF Service Start procedure.
alerts rules group SMFService
   rule SMFServiceStart
   expression “irate(outgoing_response_msg_total{msg_type=\”NrfNfmRegistration\”}[5m])”
   severity major
   annotation summary
   value "This alert is fired when SMF-Service starts upon registration with NRF”
   exit
exit
IP Pool
This section provides detail of commands that are required to configure alerts related to IP Pool.
IP Pool Used
Use the following commands to configure alerts related to the IP Pool used procedure.
alerts rules group IPPool
   rule IPPool
   expression “sum(IPAM_address_allocations_current) > THRESHOLD”
   severity major
   annotation summary
   value “This alert is fired when the percentage IP pool addresses used is above the threshold”
   exit
exit
Message Level Alerts
This section provides detail of commands that are required to configure alerts related to various messages.
N11 SM Create
Use the following commands to configure alerts related to N11 SM Create.
   rule SMFN11Success
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_create_sm_context\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_create_sm_context\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_create_sm_context responses sent is lesser threshold.”
   exit
exit
N11 SM Update
Use the following commands to configure alerts related to N11 SM Update.
   rule SMFN11Update
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_update_sm_context\", message_direction=\"inbound\", response_status=\"200\"}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_update_sm_context\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_update_sm_context responses sent is lesser threshold.”
   exit
exit
N11 SM Release
Use the following commands to configure alerts related to N11 SM Release.
   rule SMFN11Release
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_release_sm_context\", message_direction=\"inbound\", response_status=\"204\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_release_sm_context\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_release_sm_context responses sent is lesser threshold.”
   exit
exit
N1 N2 Message Transfer
Use the following commands to configure alerts related to N1 N2 Message Transfer.
   rule SMFN1N2Transfer
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_n1_n2_transfer\", message_direction=\"outbound\", response_status=\"200\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_n1_n2_transfer\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_n1_n2_transfer responses received is lesser threshold.”
   exit
exit
N11 EBI Assignment
Use the following commands to configure alerts related to N11 EBI Assignment.
   rule SMFN11EBI
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_assign_ebi\", message_direction=\"outbound\", response_status=\"200\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_assign_ebi\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_assign_ebi responses received is lesser threshold.”
   exit
exit
N11 SM Status Notify
Use the following commands to configure alerts related to N11 SM Status Notify.
   rule SMFN11StatusNotify
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_status_notify\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_status_notify\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_status_notify responses received is lesser threshold.”
   exit
exit
N11 SM Context Retrieve
Use the following commands to configure alerts related to N11 SM Context Retrieve.
   rule SMFN11ContextRetrieve
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_retrieve_sm_context\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_retrieve_sm_context\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_retrieve_sm_context responses sent is lesser threshold.”
   exit
exit
N7 SM Policy Create
Use the following commands to configure alerts related to N7 SM Policy Create.
   rule SMFN7PolicyCreate
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_create\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_create\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_create responses received is lesser threshold.”
   exit
exit
N7 SM Policy Update
Use the following commands to configure alerts related to N7 SM Policy Update.
   rule SMFN7PolicyUpdate
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_update\", message_direction=\"outbound\", response_status=\"200\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_update\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_update responses received is lesser threshold.”
   exit
exit
N7 SM Policy Delete
Use the following commands to configure alerts related to N7 SM Policy Delete.
   rule SMFN7PolicyDelete
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_delete\", message_direction=\"outbound\", response_status=\"204\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_delete\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_delete responses received is lesser threshold.”
   exit
exit
N7 SM Policy Notify Update
Use the following commands to configure alerts related to N7 SM Policy Notify Update.
   rule SMFN7PolicyUpdateNotify
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_update_notify\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_update_notify\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_update_notify responses sent is lesser threshold.”
   exit
exit
N7 SM Policy Notify Terminate
Use the following commands to configure alerts related to N7 SM Policy Terminate.
   rule SMFN7PolicyTerminateNotify
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_terminate_notify\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_terminate_notify\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_terminate_notify responses sent is lesser threshold.”
   exit
exit
N10 UE Register
Use the following commands to configure alerts related to N10 UE Register.
   rule SMFN10UERegister
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"register_ue\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"register_ue\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of register_ue responses received is lesser threshold.”
   exit
exit
N10 UE DeRegister
Use the following commands to configure alerts related to N10 UE DeRegister.
   rule SMFN10UEDeRegister
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"deregister_ue\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"deregister_ue\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of deregister_ue responses received is lesser threshold.”
   exit
exit
N10 SM Subscription Fetch
Use the following commands to configure alerts related to N10 Subscription Fetch.
   rule SMFN10SubscriptionFetch
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"subscription_req\", message_direction=\"outbound\", response_status=\"200\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"subscription_req\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of subscription_req responses received is lesser threshold.”
   exit
exit
N10 SM Subscribe for Notification
Use the following commands to configure alerts related to N10 Subscribe for Notification.
   rule SMFN10SubscriptionNotification
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"sdm_subscription_req\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"sdm_subscription_req\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of sdm_subscription_req responses received is lesser threshold.”
   exit
exit
N10 Charging Data Request
Use the following commands to configure alerts related to N10 Charging Data Request.
   rule SMFN10ChargingRequest
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"chf_charging_data_request\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"chf_charging_data_request\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of chf_charging_data_request responses received is lesser threshold.”
   exit
exit
N10 Charging Data Notify
Use the following commands to configure alerts related to N10 Charging Data Notify.
   rule SMFN10ChargingDataNotify
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"chf_abort_notify\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"chf_abort_notify\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of chf_abort_notify responses sent is lesser threshold.”
   exit
exit
Policy Rule Alerts
This section provides detail of commands that are required to configure alerts related to various policy rules.
Addition of Dynamic PCC Rules
Use the following commands to configure alerts related to addition of dynamic PCC rules.
alerts rules group SMFPolicyStatus
   rule AddPCCRule
   expression "sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"success\",operation=\"install\”}[5m]))  / sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"attempted\",operation=\"install\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of successful addition of dynamic pcc rules is lesser threshold.”
   exit
exit
Modification of Dynamic PCC Rules
Use the following commands to configure alerts related to modification of dynamic PCC rules.
   rule ModifyPCCRule
   expression "sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"success\",operation=\"modify\”}[5m]))  / sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"attempted\",operation=\"modify\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of successful modification of dynamic pcc rules is lesser threshold.”
   exit
exit
Removal of Dynamic PCC Rules
Use the following commands to configure alerts related to removal of dynamic PCC rules.
   rule RemovePCCRule
   expression "sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"success\",operation=\"remove\”}[5m]))  / sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"attempted\",operation=\"remove\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of successful removal of dynamic pcc rules is lesser threshold.”
   exit
exit
SMF Overload/Congestion
This section provides detail of commands that are required to configure alerts related to various SMF Overload/Congestion.
SMF Overload
Use the following commands to configure alerts related to the SMF Overload procedure.
   rule SMFOverload
   expression “sum by (component) (system_overload_status) == true”
   severity major
   annotation summary
   value "This alert is fired when increase in events not processed due to system overload”
   exit
exit
SMF Sessions
This section provides detail of commands that are required to configure alerts related to various SMF sessions.
Session Release Rate
Use the following commands to configure alerts related to the Session Release Rate procedure.
alerts rules group SMFSession
   rule SMFSessionReleaseRate
   expression “sum(rate(smf_service_stats{procedure_type=~\“.*pdu_sess_rel|.*pdn_sess_rel\” , status=\“attempted\”}[5m])) >  THRESHOLD ”
   severity major
   annotation summary
   value “This alert is fired when the session release rate exceeds the threshold”
   exit
exit
Session Setup Failure
Use the following commands to configure alerts related to the Session Setup Failure procedure.
   expression “sum(smf_service_stats{procedure_type=~\”pdu_sess_create|pdn_sess_create\” , status=\“failures\”}) / sum(smf_service_stats{procedure_type=\”pdu_sess_create|pdn_sess_create\” , status=\“attempted\”}) >  0.05 “
   severity major
   annotation summary
   exit
exit
Session Setup Rate
Use the following commands to configure alerts related to the Session Setup Rate procedure.
   rule SMFSessionSetupRate
   expression “sum(rate(smf_service_stats{procedure_type=~\”pdu_sess_create|pdn_sess_create\” , status=\“attempted\”}[5m]))>  THRESHOLD ”
   severity major
   annotation summary
   value “This alert is fired when the session setup rate exceeds the threshold”
   exit
exit
Subscriber Limit
Use the following commands to configure alerts related to the Subscriber Limit procedure.
   rule SMFSubscriberLimit
   expression “sum(smf_session_counters{pdu_type=~\”ipv4v6|ipv4|ipv6\”}) > THRESHOLD”
   severity major
   annotation summary
   value "This alert is fired when the max number of subscribers is more
   than the threshold”
   exit
exit
