Monitoring Support
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Enabled – Always-on
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
Added show commands for the RPC feature in App-Infra SMF.
2020.03.0
First introduced.
Pre-2020.02.0
Monitor Subscriber and Monitor Protocol
Feature Description
The SMF supports the Monitor Subscriber and Monitor Protocol on the Kubernetes environment. This feature allows to capture messages of subscribers and protocols.
Converged Core Refactoring Changes
This section describes the changes related to converged core refactoring in this chapter.
The monitor subscriber supi CLI command is enhanced to add the namespace option to display the output pertaining to the respective namespace.
Configuring the Monitor Subscriber and Monitor Protocol Feature
Monitoring the Subscriber
Use the following sample configuration to monitor the subscriber in the SMF.
monitor subscriber [ capture-duration duration_sec  | imsi imsi_value | internal-messages [ yes ] | namespace [ sgw | smf ] | supi supi_id | transaction-logs [ yes ] ]
NOTES:
  • capture-duration duration_sec : Specify the duration in seconds during which monitor subscriber is enabled. The default value is 300 seconds (5 minutes). This is an optional parameter.
  • imsi imsi_value : Specify the subscriber IMSI. For example: 123456789, *
  • internal-messages [ yes ] : Enable internal messages when set to yes. By default, it is disabled. This is an optional parameter.
  • namespace [ sgw | smf ] : Enable the specified namespace. By default, namespace is set to none. This is an optional parameter.
    Important
    This keyword is deprecated in release 2021.02.0 and replaced with nf-service keyword.
  • supi supi_id : Specify the subscriber identifier. For example: imsi-123456789, imsi-123*
  • transaction-logs [ yes ] : Enable transaction logs when set to yes. By default, it is disabled. This is an optional parameter.
The monitor subscriber CLI command can be run simultaneously on multiple terminals. For example, run the CLI simultaneously in two SMF Ops Center terminals for two subscribers (for example, imsi-123456789012345 and imsi-456780123456789) to implement the following:
  • Monitor the duration when the monitor subscriber is enabled.
  • View internal messages for the specified subscriber.
  • View transaction logs for the specified subscriber
Terminal 1: The following command monitors and displays subscriber messages for the specified subscriber.
monitor subscriber supi imsi-123456789012345 capture-duration 1000 internal-messages yes
Terminal 2: The following command monitors and displays transaction logs for the specified subscriber.
monitor subscriber supi imsi-456780123456789 capture-duration 500 internal-messages yes transaction-logs yes
After the capture-duration is over or to stop the CLI, use the Ctrl+C keys. The captured messages are reordered and stored in a file. To retrieve the list of stored files, use the monitor subscriber list CLI command.
For example:
RELEASE_NAMESPACE: 'smf'
'monsublogs/subscriberID_imsi-*_AT_2019-10-22T09:19:05.586237087.txt.sorted'
monsublogs/subscriberID_imsi-123456789012345_AT_2019-10-22T09:20:11.122225534.txt.sorted
Enabling or Disabling the Transaction Messages
Use the following CLI command to enable or disable the presence of request response messages in the transaction logs.
config
  logging transaction message [ enable | disable ]
  commit
end
NOTES:
  • logging transaction message : Specifies the transaction messages in the transaction logs.
  • enable : Enables the presence of transaction messages in the transaction logs.
  • disable : Disables the presence of transaction messages in the transaction logs.
Viewing the Sorted File on SMF Ops Center
Use the following CLI command to view the sorted file on the SMF Ops Center screen.
monitor subscriber dump filename filename
For example:
monitor subscriber dump filename monsublogs/subscriberID_imsi-123456789012345_AT_2019-10-22T09:20:11.122225534.txt.sorted
Monitoring the Interface Protocol
Use the following sample configuration to monitor the interface protocol on the SMF.
monitor protocol interface endpoint_name [ capture-duration duration_sec  | gr-instance gr_instance_id  ]
NOTES:
  • interface endpoint_name : Specify the endpoint name on which PCAP is captured. This CLI allows the configuration of multiple endpoint names in a single CLI command.
  • capture-duration duration_sec : Specify the duration in seconds during which the monitor subscriber is enabled. The default is 300 seconds (5 minutes).
  • The configured endpoint names can be retrieved using the show endpoint CLI command.
The monitor protocol CLI can be run simultaneously on multiple terminals. Also, the interface endpoint_name CLI allows the configuration of multiple endpoint names in a single CLI command. For example:
monitor protocol interface sbi,N4:10.86.73.161:8805,gtpc capture-duration 1000
Viewing Transaction History Logs
Use the following CLI command to view the transaction history on an OAM pod shell. On another terminal, use the kubectl command to tail the logs of the OAM pod and then run the following CLI from the Ops Center.
dump transactionhistory
Note
In this release, the most recent transaction logs are stored in a circular queue of size 1024 transaction logs.
Sample Transaction Log
The following is an example of transaction log collected in Monitor Subscriber during SMF PDU session establishment.
Transaction Log received from Instance: smf.smf-rest-ep.unknown.smf.0
************* TRANSACTION: 00010 *************
TRANSACTION SUCCESS:
    Txn Type             : N10RegistrationRequest(33)
    Priority             : 1
    Session State        : No_Session
LOG MESSAGES:
    2020/03/03 05:31:39.345 [DEBUG] [infra.transaction.core] Processing transaction Id: 10 Type: 33 SubscriberID: imsi-123456789012345 Keys: []
    2020/03/03 05:31:39.345 [DEBUG] [infra.transaction.core] Trace is disabled
    2020/03/03 05:31:39.346 [TRACE] [infra.message_log.core] >>>>>>>
IPC message
MessageType: N10RegistrationRequest
Key:
--body--
{"regInfo":{"ueId":"imsi-123456789012345","pduSessionId":5},"regReq":{"dnn":"intershat",
  "pduSessionId":5,"pgwFqdn":"cisco.com.apn.epc.mnc456.mcc123","plmnId":{"mcc":"123","mnc":"456"},
  "smfInstanceId":"c388eec5-e2ff-4bda-8154-b5dd9f10ad97","supportedFeatures":"0","singleNssai":{"sd":"Abf123","sst":2}},
  "msgReq":{"Type":2,"ServiceName":4,"Versions":["v1"],"ProfileName":"UP1","FailureProfile":"FH1","SvcMsgType":3,"Filter":{"Bitmapfeilds":2,"Dnn":"intershat"}}}
    2020/03/03 05:31:39.346 [DEBUG] [nrfClient.Discovery.nrf] Message send Metadata [Type:UDM ServiceName:nudm-uecm
      Method:"Register" Payload:"\022\030\n\024imsi-123456789012345\020\005\032o\n\tintershat\030\005\"\037cisco.com.apn.epc.mnc456.
      mcc123*\n\n\003123\022\0034562$c388eec5-e2ff-4bda-8154-b5dd9f10ad97:\0010B\n\n\006Abf123\020\002\"%\010\002\030\004J\002v1b\
      003UP1j\r\010\002\022\tintershat\272\001\003FH1\300\001\003" Versions:"v1" MsgType:33 ProfileName:"UP1" FailureProfile:"FH1"
      SvcMsgType:UdmUecmRegisterSMF Filter:<Bitmapfeilds:2 Dnn:"intershat" > ] client locality [] Preferred locality [], Geo Locality []
    2020/03/03 05:31:39.347 [DEBUG] [nrfClient.generic.Int] GetAvailableSLAInMS returned timeoutInMS [0]
    2020/03/03 05:31:39.347 [DEBUG] [infra.transaction.core] Requested host Setname:  Name: http://10.86.73.209:9020/nudm-uecm/v1 Version:  ApiRoot:
    2020/03/03 05:31:39.347 [DEBUG] [infra.transaction.core] Exact match found. Selected remote host is Id 2
      Name: http://10.86.73.209:9020/nudm-uecm/v1 Setname:  Host:  Port: 0 Url: http://10.86.73.209:9020/nudm-uecm/v1
    2020/03/03 05:31:39.347 [INFO] [infra.transaction.core] Calling RPC UDM on host http://10.86.73.209:9020/nudm-uecm/v1 proc-name UDM proc-method: Register
    2020/03/03 05:31:39.348 [DEBUG] [rest_ep.app.n10] Sending registration request to udm: /imsi-123456789012345/registrations/
      smf-registrations/5 with payload {"dnn":"intershat","pduSessionId":5,"pgwFqdn":"cisco.com.apn.epc.mnc456.mcc123",
      "plmnId":{"mcc":"123","mnc":"456"},"singleNssai":{"sd":"Abf123","sst":2},"smfInstanceId":"c388eec5-e2ff-4bda-8154-b5dd9f10ad97","supportedFeatures":"0"}
    2020/03/03 05:31:39.348 [DEBUG] [infra.rest_client.core] Sending rest mesasge to http://10.86.73.209:9020/nudm-uecm/v1/imsi-123456789012345/registrations/smf-registrations/5
    2020/03/03 05:31:39.348 [TRACE] [infra.message_log.core] <<<<<<<<
Request
Host: http://10.86.73.209:9020/nudm-uecm/v1/imsi-123456789012345/registrations/smf-registrations/5
Method: PUT
RequestURI:
--- Headers ---
Content-Type: application/json
Body:{"dnn":"intershat","pduSessionId":5,"pgwFqdn":"cisco.com.apn.epc.mnc456.mcc123","plmnId":{"mcc":"123","mnc":"456"},"singleNssai":{"sd":"Abf123","sst":2},"smfInstanceId":"c388eec5-e2ff-4bda-8154-b5dd9f10ad97","supportedFeatures":"0"}
    2020/03/03 05:31:39.376 [TRACE] [infra.message_log.core] >>>>>>>
Response
Name:
Response Status 201
--- Headers ---
Location: http://10.86.73.209:9020/nudm-uecm/v1/imsi-123456789012345/registrations/smf-registrations/5
Content-Length: 225
Body:{"pgwFqdn": "cisco.com.apn.epc.mnc456.mcc123", "plmnId": {"mcc": "123", "mnc": "456"}, "dnn": "intershat",
  "smfInstanceId": "524f5f8a-b584-47b8-86f5-a5292eabcdef", "pduSessionId": 5, "singleNssai": {"sd": "Abf123", "sst": 2}}
    2020/03/03 05:31:39.377 [INFO] [rest_ep.app.n10] Received registration success response with status = 201 and body =
    2020/03/03 05:31:39.377 [DEBUG] [infra.transaction.core] Last stage ( init_done ) -> Next stage ( finished )
    2020/03/03 05:31:39.378 [TRACE] [infra.message_log.core] <<<<<<<<
IPC message
MessageType: N10RegistrationSuccess
Key:
--body--
{"regRes":{"dnn":"intershat","pduSessionId":5,"pgwFqdn":"cisco.com.apn.epc.mnc456.mcc123","plmnId":{"mcc":"123","mnc":"456"},
  "msgRsp":{"Type":2,"Http2_Status":201,"MsgType":34,"ServiceName":4,"SelectedVersion":"v1","SelectedEndPoint":
  {"ipv4Address":"10.86.73.209","port":9020,"transport":1},"SelectedProfileName":"UP1","SelectedEndPointName":"EP1",
  "SelectedEndPointProfile":"EP1","SelectedLocality":"LOC1","FailureProfile":"FH1","GroupID":"UDM-dnn=intershat;"}}
    2020/03/03 05:31:39.378 [DEBUG] [infra.transaction.core] no response message sent for 10
************* TRANSACTION: 00011 *************
    Txn Type             : N10SubscriptionFetchReq(36)
    Priority             : 1
LOG MESSAGES:
    2020/03/03 05:31:39.384 [DEBUG] [infra.transaction.core] Processing transaction Id: 11 Type: 36 SubscriberID: imsi-123456789012345 Keys: []
    2020/03/03 05:31:39.384 [DEBUG] [infra.transaction.core] Trace is disabled
    2020/03/03 05:31:39.384 [TRACE] [infra.message_log.core] >>>>>>>
IPC message
MessageType: N10SubscriptionFetchReq
Key:
--body--
{"subInfo":{"ueId":"imsi-123456789012345"},"uriParams":{"supportedFeatures":"0","singleNssai":{"sd":"Abf123","sst":2},
  "dnn":"intershat","plmnId":{"mcc":"123","mnc":"456"}},"msgReq":{"Type":2,"ServiceName":3,"Versions":["v1"],"ProfileName":
  "UP1","FailureProfile":"FH1","SvcMsgType":1,"Filter":{"Bitmapfeilds":2,"Dnn":"intershat"}}}
    2020/03/03 05:31:39.384 [DEBUG] [nrfClient.Discovery.nrf] Message send Metadata [Type:UDM ServiceName:nudm-sdm Method:"Subscription"
      Payload:"\022\026\n\024imsi-123456789012345\032&\n\0010\022\n\n\006Abf123\020\002\032\tintershat\"\n\n\003123\022\003456
      \"%\010\002\030\003J\002v1b\003UP1j\r\010\002\022\tintershat\272\001\003FH1\300\001\001" Versions:"v1" MsgType:36
      ProfileName:"UP1" FailureProfile:"FH1" SvcMsgType:UdmSdmGetUESMSubscriptionData Filter:<Bitmapfeilds:2 Dnn:"intershat" > ]
    2020/03/03 05:31:39.385 [DEBUG] [nrfClient.generic.Int] GetAvailableSLAInMS returned timeoutInMS [0]
    2020/03/03 05:31:39.385 [DEBUG] [infra.transaction.core] Requested host Setname:  Name: http://10.86.73.209:9020/nudm-sdm/v1 Version:  ApiRoot:
    2020/03/03 05:31:39.385 [DEBUG] [infra.transaction.core] Exact match found. Selected remote host is Id 1 Name: http://10.86.73.209:9020/
      nudm-sdm/v1 Setname:  Host:  Port: 0 Url: http://10.86.73.209:9020/nudm-sdm/v1
    2020/03/03 05:31:39.385 [INFO] [infra.transaction.core] Calling RPC UDM on host http://10.86.73.209:9020/nudm-sdm/v1 proc-name
      UDM proc-method: Subscription
    2020/03/03 05:31:39.385 [DEBUG] [rest_ep.app.n10] Sending sm subscription request to udm: /imsi-123456789012345/sm-data?
      dnn=intershat&plmn-id=%7B%22mcc%22%3A%22123%22%2C%22mnc%22%3A%22456%22%7D&single-nssai=%7B%22sd%22%3A%22Abf123%22%2C%22sst%22%3A2%
      7D&supported-features=0
    2020/03/03 05:31:39.385 [DEBUG] [infra.rest_client.core] Sending rest mesasge to http://10.86.73.209:9020/nudm-sdm/v1/
      imsi-123456789012345/sm-data?dnn=intershat&plmn-id=%7B%22mcc%22%3A%22123%22%2C%22mnc%22%3A%22456%22%7D&single-nssai=%7B%22sd%22
      %3A%22Abf123%22%2C%22sst%22%3A2%7D&supported-features=0
    2020/03/03 05:31:39.385 [TRACE] [infra.message_log.core] <<<<<<<<
Request
Host: http://10.86.73.209:9020/nudm-sdm/v1/imsi-123456789012345/sm-data?dnn=intershat&plmn-id=%7B%22mcc%22%3A%22123%22%2C%22mnc%22%3A%2
    2456%22%7D&single-nssai=%7B%22sd%22%3A%22Abf123%22%2C%22sst%22%3A2%7D&supported-features=0
Method: GET
RequestURI:
--- Headers ---
    2020/03/03 05:31:39.400 [TRACE] [infra.message_log.core] >>>>>>>
Response
Name:
Response Status 200
--- Headers ---
Content-Length: 812
Body:[{"sharedDnnConfigurationsIds": "012345", "internalGroupIds": ["1aAbB00866564", "dhsjdha67673AA"], "singleNssai": {"sd": "Abf123",
  "sst": 2}, "dnnConfigurations": {"intershat": {"3gppChargingCharacteristics": "1", "5gQosProfile": {"5qi": 5, "arp": {"preemptVuln":
  "NOT_PREEMPTABLE", "preemptCap": "NOT_PREEMPT", "priorityLevel": 15}, "priorityLevel": 1}, "sscModes": {"allowedSscModes": ["SSC_MODE_1",
  "SSC_MODE_2"], "defaultSscMode": "SSC_MODE_1"}, "ladnIndicator": true, "pduSessionTypes": {"defaultSessionType": "IPV4",
  "allowedSessionTypes": ["IPV6", "IPV4V6", "UNSTRUCTURED", "ETHERNET"]}, "staticIpAddress": [{"ipv4Addr": "1.1.1.1"}, {"ipv6Addr": "::1"}],
  "upSecurity": {"upIntegr": "REQUIRED", "upConfid": "PREFERRED"}, "sessionAmbr": {"downlink": "125 Mbps", "uplink": "100 Mbps"},
  "iwkEpsInd": false}}}]
    2020/03/03 05:31:39.400 [INFO] [rest_ep.app.n10] Received sm subscription success response with status = 200 and body =
      "Abf123", "sst": 2}, "dnnConfigurations": {"intershat": {"3gppChargingCharacteristics": "1", "5gQosProfile": {"5qi": 5, "arp":
      {"preemptVuln": "NOT_PREEMPTABLE", "preemptCap": "NOT_PREEMPT", "priorityLevel": 15}, "priorityLevel": 1}, "sscModes":
      {"allowedSscModes": ["SSC_MODE_1", "SSC_MODE_2"], "defaultSscMode": "SSC_MODE_1"}, "ladnIndicator": true, "pduSessionTypes":
      {"defaultSessionType": "IPV4", "allowedSessionTypes": ["IPV6", "IPV4V6", "UNSTRUCTURED", "ETHERNET"]}, "staticIpAddress":
      [{"ipv4Addr": "1.1.1.1"}, {"ipv6Addr": "::1"}], "upSecurity": {"upIntegr": "REQUIRED", "upConfid": "PREFERRED"}, "sessionAmbr":
      {"downlink": "125 Mbps", "uplink": "100 Mbps"}, "iwkEpsInd": false}}}]
    2020/03/03 05:31:39.401 [INFO] [rest_ep.app.n10] Unmarshalled smData: smData:<dnnConfiguration:<key:"intershat" value:
      <_3gppChargingCharacteristics:"1" ladnIndicator:true pduSessionTypes:<allowedSessionTypes:IPV6 allowedSessionTypes:IPV4V6
      allowedSessionTypes:UNSTRUCTURED allowedSessionTypes:ETHERNET defaultSessionType:IPV4 > sessionAmbr:<downlink:"125 Mbps"
      uplink:"100 Mbps" > sscModes:<allowedSscModes:SSC_MODE_1 allowedSscModes:SSC_MODE_2 defaultSscMode:SSC_MODE_1 >
      upSecurity:<upConfid:PREFERRED > subsQosProfile:<_5qi:5 arp:<preemptCap:NOT_PREEMPT preemptVuln:NOT_PREEMPTABLE priorityLevel:15 >
      priorityLevel:1 > staticIpAddress:<ipv4Addr:"1.1.1.1" > staticIpAddress:<ipv6Addr:"::1" > > > singleNssai:<sd:"Abf123" sst:2 >
      internalGroupIds:"1aAbB00866564" internalGroupIds:"dhsjdha67673AA" sharedDnnConfigurationsIds:"012345" >
    2020/03/03 05:31:39.402 [DEBUG] [infra.transaction.core] Last stage ( init_done ) -> Next stage ( finished )
    2020/03/03 05:31:39.403 [TRACE] [infra.message_log.core] <<<<<<<<
IPC message
MessageType: N10SubscriptionFetchSuccess
Key:
--body--
{"subInfo":{"ueId":"imsi-123456789012345"},"uriParams":{"supportedFeatures":"0","singleNssai":{"sd":"Abf123","sst":2},"dnn":"intershat",
  "plmnId":{"mcc":"123","mnc":"456"}},"smData":[{"dnnConfiguration":{"intershat":{"_3gppChargingCharacteristics":"1","ladnIndicator":true,
  "pduSessionTypes":{"allowedSessionTypes":[2,3,4,5],"defaultSessionType":1},"sessionAmbr":{"downlink":"125 Mbps","uplink":"100 Mbps"},
  "sscModes":{"allowedSscModes":[1,2],"defaultSscMode":1},"upSecurity":{"upConfid":2},"subsQosProfile":{"_5qi":5,"arp":{"preemptCap":1,
  "preemptVuln":1,"priorityLevel":15},"priorityLevel":1},"staticIpAddress":[{"ipv4Addr":"1.1.1.1"},{"ipv6Addr":"::1"}]}},"singleNssai":
  {"sd":"Abf123","sst":2},"internalGroupIds":["1aAbB00866564","dhsjdha67673AA"],"sharedDnnConfigurationsIds":"012345"}],"msgRsp":
  {"Type":2,"Http2_Status":200,"MsgType":37,"ServiceName":3,"SelectedVersion":"v1","SelectedEndPoint":{"ipv4Address":"10.86.73.209",
  "port":9020,"transport":1},"SelectedProfileName":"UP1","SelectedEndPointName":"EP1","SelectedEndPointProfile":"EP1","SelectedLocality":
    2020/03/03 05:31:39.403 [DEBUG] [infra.transaction.core] no response message sent for 11
RPC Remote Host Management
Feature Description
RPC Remote Host Management OAM Support
This section provides information regarding show commands available to monitor and troubleshoot the SMF RPC Remote Host Management.
show-rpc
This command lists all the RPCs from all the pods with RPC and remote host information.
POD
  • POD INSTANCE - Displays the Instance info of the POD
  • NAME - Displays the Name of the RPC registered in POD
  • REMOTE ADDRESS - Displays IP address and Port of remote endpoint
  • REMOTE HOST - Displays name of the RPC host
  • TYPE - Displays the type of connection like Rest, Grpc, GrpcStream etc
  • SET NAME- Displays the RPC set name for group of RPC hosts
  • STATUS - Displays the current state of the RPC host, possible status values are Started, Starting and Stopped
  • CONNECTED TIME - Displays the time when the RPC host was connected
  • DISCONNECTED TIME - Displays the time when the RPC host was disconnected
  • MONITOR RPC HOST - Indicates whether the RPC host is being monitored for connection status
  • PROCESSING INSTANCE INFO - Indicates the if the processing instance name if available
  • VERSION - Displays the version of the RPC host API if available
