Router Solicit and Router Advertisement
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area SMF
Applicable Platform(s) SMI
Feature Default Setting Enabled – Always-on
Related Changes in this Release Not Applicable
Related Documentation Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
First introduced. Pre-2020.02.0
Feature Description
To comply to IPv6 Stateless Auto-configuration, SMF supports ICMPv6 Router Solicit and Advertisement.
The following ICMPv6 options are supported in Router Advertisement:
  • Prefix Information: Allocated UE IPv6 Prefix is sent.
  • MTU: Value is taken from configuration. Default is 1500.
  • Source Link Layer Address: Value is taken from configuration local virtual mac.
In releases prior to 2020.02, the SMF queued the Router Advertisement (RA) and Router Solicitation (RS) messages when the PCF-initiated PDU Modification Request is triggered immediately after the Session Create Request.
In this release, the SMF sends the RA message and also responds to the RS message when the PCF-initiated PDU Modification Request is triggered immediately after the Session Create Request. That is, the SMF prioritizes the processing of RA and RS messages over the PCF-initiated PDU Modification Request.
Unsolicited Router Advertisement
SMF sends unsolicited router advertisement on successful PDU session establishment to share the allocated IPv6 prefix to UE. RA message is sent over the GTPU tunnel, which is created between the SMF and UPF during the Session Establishment procedure. SMF also installs PDRs and FARs on the UPF to enable routing for RS/RA messages.
Solicited Router Advertisement
To get the allocated IPv6 prefix, UE can send a router solicit message. On receiving router solicit message, SMF sends router advertisement message towards UE containing the allocated UE IPv6 prefix.
ICMPv6 Profile Configuration
The following configuration is used to configure Router Advertisement parameters:
scheduler(config-icmpv6-profile-icmp1# show full
icmpv6-profile icmp1
local-virtual-mac ac:de:48:00:11:22
hop-limit          64     default 255
router-lifetime    100 (seconds) default 65535
reachable-time     30 (milliseconds) default 0
retrans-timer      1 (milliseconds) default 0
mtu                1500 default 1500
dnn-profile dnn1
remote-virtual-mac fa:00:4c:a8:22:05 default(00:14:22:01:23:45)
ipv6-pool name pool1
      prefix          2001:300:4001::/48
      prefix-lifetime 3456 (seconds) default 4294967295
smf-profile prof
service name srv1
  associate-icmpv6-profile icmp1
NOTES:
  • /48 is the only prefix supported in this release.
