nfInstanceId
NfInstanceId
M
Unique identity of the NF Instance.
nfType
NFType
M
Type of Network Function
nfStatus
NFStatus
M
Status of the NF Instance.
nfInstanceName
String
O
0.1
Human readable name of the NF Instance
heartBeatTimer
Integer
C
0.1
Time in seconds expected between 2 consecutive heart-beat messages from an NF Instance to the NRF. It may be included in the
registration request. When present in the request it shall contain the heartbeat time proposed by the NF service consumer.
It shall be included in responses from NRF to registration requests (PUT) or in NF profile updates (PUT or PATCH). If the
proposed heartbeat time is acceptable by the NRF based on the local configuration, it shall use the same value as in the registration
request; otherwise the NRF shall override the value using a preconfigured value.
plmnList
array(PlmnId)
C
1..N
PLMN(s) of the Network Function (NOTE 7). This IE shall be present if this information is available for the NF. If not provided,
PLMN ID(s) of the PLMN of the NRF are assumed for the NF.
snpnList
array(PlmnIdNid)
C
1..N
SNPN(s) of the Network Function. This IE shall be present if the NF pertains to one or more SNPNs.
sNssais
array(Snssai)
O
1..N
S-NSSAIs of the Network Function. If not provided, the NF can serve any S-NSSAI. When present this IE represents the list
of S-NSSAIs supported in all the PLMNs listed in the plmnList IE. If the sNSSAIs attribute is provided in at least one NF
Service, the S-NSSAIs supported by the NF Profile shall be the set or a superset of the S-NSSAIs of the NFService(s).
perPlmnSnssaiList
array(PlmnSnssai)
O
1..N
This IE may be included when the list of S-NSSAIs supported by the NF for each PLMN it’s supporting is different. When present,
this IE shall include the S-NSSAIs supported by the Network Function for each PLMN supported by the Network Function. When
present, this IE shall override sNssais IE. (NOTE 9) If the perPlmnSnssaiList attribute is provided in at least one NF Service,
the S-NSSAIs supported per PLMN in the NF Profile shall be the set or a superset of the perPlmnSnssaiList of the NFService(s).
nsiList
array(string)
O
1..N
NSI identities of the Network Function. If not provided, the NF can serve any NSI.
fqdn
Fqdn
C
0..1
FQDN of the Network Function (NOTE 1) (NOTE 2). For AMF, the FQDN registered with the NRF shall be that of the AMF Name (see
3GPP 23.003 [12] clause 28.3.2.5).
interPlmnFqdn
Fqdn
C
0..1
If the NF needs to be discoverable by other NFs in a different PLMN, then an FQDN that is used for inter-PLMN routing as specified
in 3GPP 23.003 [12] shall be registered with the NRF (NOTE 8).
A change of this attribute shall result in triggering a "NF_PROFILE_CHANGED" notification from NRF towards subscribing NFs
located in a different PLMN, but the new value shall be notified as a change of the "fqdn" attribute.
ipv4Addresses
array(Ipv4Addr)
C
1..N
IPv4 address(es) of the Network Function (NOTE 1) (NOTE 2)
ipv6Addresses
array(Ipv6Addr)
C
1..N
IPv6 address(es) of the Network Function.
allowedPlmns
array(PlmnId)
O
1..N
PLMNs allowed to access the NF instance. If not provided, any PLMN is allowed to access the NF.
A change of this attribute shall not trigger a "NF_PROFILE_CHANGED" notification from NRF, and this attribute shall not be
included in profile change notifications to subscribed NFs.
allowedSnpns
array(PlmnIdNid)
O
1..N
SNPNs allowed to access the NF instance.
If this attribute is present in the NFService and in the NF profile, the attribute from the NFService shall prevail.
The absence of this attribute in both the NFService and in the NF profile indicates that no SNPN, other than the SNPN(s) registered
in the snpnList attribute of the NF Profile, is allowed to access the service instance.
A change of this attribute won’t trigger a "NF_PROFILE_CHANGED" notification from NRF, and this attribute won’t be included
allowedNfTypes
array(NFType)
O
1..N
Type of the NFs allowed to access the NF instance.
If not provided, any NF type is allowed to access the NF.
allowedNfDomains
array(string)
O
1..N
Pattern (regular expression according to the ECMA-262 dialect [8]) representing the NF domain names allowed to access the
NF instance.
If not provided, any NF domain is allowed to access the NF.
allowedNssais
array(Snssai)
O
1..N
S-NSSAI of the allowed slices to access the NF instance.
If not provided, any slice is allowed to access the NF.
priority
Integer
O
0..1
Priority (relative to other NFs of the same type) within the range 0 to 65535, to be used for NF selection; lower values indicate
a higher priority. Priority may or may not be present in the nfServiceList parameters, xxxInfo parameters and in this attribute.
Priority in the nfServiceList has precedence over the priority in this attribute, which has precedence over the priority in
xxxInfo parameter. (NOTE 4).
The NRF may overwrite the received priority value when exposing an NFProfile with the Nnrf_NFDiscovery service.
capacity
Integer
O
0..1
Static capacity information within the range 0 to 65535, expressed as a weight relative to other NF instances of the same
type; if capacity is also present in the nfServiceList parameters, those will have precedence over this value. (NOTE 4).
load
Integer
O
0..1
Dynamic load information, within the range 0 to 100, indicates the current load percentage of the NF.
oadTimeStamp
DateTime
O
0..1
It indicates the point in time in which the latest load information (sent by the NF in the "load" attribute of the NF Profile)
was generated at the NF Instance.
If the NF did not provide a timestamp, the NRF should set it to the instant when the NRF received the message where the NF
provided the latest load information.
locality
string
O
0..1
Operator defined information about the location of the NF instance (e.g. geographic location, data center) (NOTE 3)
udrInfo
UdrInfo
O
0..1
Specific data for the UDR (ranges of SUPI, group ID …)
udrInfo
map(UdrInfo)
O
1..N
Multiple entries of UdrInfo. This attribute provides additional information to the udrInfo. udrInfoList may be present even
if the udrInfo is absent.
The key of the map will be a (unique) valid JSON string per clause 7 of IETF RFC 8259 [22], with a maximum of 32 characters.
udmInfo
UdmInfo
O
0..1
Specific data for the UDM (ranges of SUPI, group ID…)
udmInfoList
map(UdmInfo)
O
1..N
Multiple entries of UdmInfo. This attribute provides additional information to the udmInfo. udmInfoList may be present even
if the udmInfo is absent.
ausfInfo
AusfInfo
O
0..1
Specific data for the AUSF (ranges of SUPI, group ID…)
ausfInfoList
map(AusfInfo)
O
1..N
Multiple entries of AusfInfo. This attribute provides additional information to the ausfInfo. ausfInfoList may be present
even if the ausfInfo is absent.
amfInfo
AmfInfo
O
0..1
Specific data for the AMF (AMF Set ID, …)
amfInfoList
map(AmfInfo)
O
1..N
Multiple entries of AmfInfo. This attribute provides additional information to the amfInfo. amfInfoList may be present even
if the amfInfo is absent.
smfInfo
SmfInfo
O
0..1
Specific data for the SMF (DNN's, …).
smfInfoList
map(SmfInfo)
O
1..N
Multiple entries of SmfInfo. This attribute provides additional information to the smfInfo. smfInfoList may be present even
if the smfInfo is absent.
upfInfo
UpfInfo
O
0..1
Specific data for the UPF (S-NSSAI, DNN, SMF serving area, interface…)
upfInfoList
map(UpfInfo)
O
1..N
Multiple entries of UpfInfo. This attribute provides additional information to the upfInfo. upfInfoList may be present even
if the upfInfo is absent.
pcfInfo
PcfInfo
O
0..1
Specific data for the PCF
pcfInfoList
map(PcfInfo)
O
1..N
Multiple entries of PcfInfo. This attribute provides additional information to the pcfInfo. pcfInfoList may be present even
if the pcfInfo is absent.
bsfInfo
BsfInfo
O
0..1
Specific data for the BSF.
bsfInfoList
map(BsfInfo)
O
1..N
Multiple entries of BsfInfo. This attribute provides additional information to the bsfInfo. bsfInfoList may be present even
if the bsfInfo is absent.
chfInfo
ChfInfo
O
0..1
Specific data for the CHF.
chfInfoList
map(ChfInfo)
O
1..N
Multiple entries of ChfInfo. This attribute provides additional information to the chfInfo. chfInfoList may be present even
if the chfInfo is absent.
nefInfo
NefInfo
O
0..1
Specific data for the NEF.
nrfInfo
NrfInfo
O
0..1
Specific data for the NRF.
udsfInfo
UdsfInfo
O
0..1
Specific data for the UDSF.
udsfInfoList
map(UdsfInfo)
O
1..N
Multiple entries of udsfInfo. This attribute provides additional information to the udsfInfo. udsfInfoList may be present
even if the udsfInfo is absent.
nwdafInfo
NwdafInfo
O
0..1
Specific data for the NWDAF.
pcscfInfoList
map(PcscfInfo)
O
1..N
Specific data for the P-CSCF.
(NOTE 11)
hssInfoList
map(HssInfo)
O
1..N
Specific data for the HSS.
customInfo
object
O
0..1
Specific data for custom Network Functions.
recoveryTime
DateTime
0..1
Timestamp when the NF was (re)started.
nfServicePersistence
boolean
O
0..1
True: If present, and set to true, it indicates that the different service instances of a same NF Service in this NF instance,
supporting a same API version, are capable to persist their resource state in shared storage and therefore these resources
are available after a new NF service instance supporting the same API version is selected by a NF Service Consumer (see 3GPP
23.527 [27]).
False (default): Otherwise, it indicates that the NF Service Instances of a same NF Service are not capable to share resource
state inside the NF Instance.
nfServices
array(NFService)
O
1..N
List of NF Service Instances. It will include the services produced by the NF that can be discovered by other NFs, if any.
nfProfileChangesSupportInd
boolean
O
0..1
NF Profile Changes Support Indicator.
See Annex B.
This IE may be present in the NFRegister or NFUpdate (NF Profile Complete Replacement) request and must be absent in the response.
True: the NF Service Consumer supports receiving NF Profile Changes in the response.
False (default): the NF Service Consumer does not support receiving NF Profile Changes in the response.
Write-Only: true
nfProfileChangesInd
boolean
O
0..1
NF Profile Changes Indicator.
See Annex B.
This IE must be absent in the request to the NRF and may be included by the NRF in NFRegister or NFUpdate (NF Profile Complete
Replacement) response.
True: the NF Profile contains NF Profile changes.
False (default): complete NF Profile.
Read-Only: true
defaultNotification
Subscriptions
array(DefaultNotificatio
nSubscription)
O
1..N
Notification endpoints for different notification types.
(NOTE 10)
gmlcInfo
GmlcInfo
O
0..1
Specific data for the GMLC
nfSetIdList
array(NfSetId)
O
1..N
NF Set ID defined in clause 28.12 of 3GPP TS 23.003 [12].
At most one NF Set ID must be indicated per PLMN of the NF.
servingScope
array(string)
O
1..N
The served area(s) of the NF instance.
The absence of this attribute does not imply that the NF instance can serve every area in the PLMN.
lcHSupportInd
boolean
O
0..1
This IE indicates whether the NF supports Load Control based on LCI Header (see clause 6.3 of 3GPP TS 29.500 [4]).
True: the NF supports the feature.
False (default): the NF does not support thefeature.
olcHSupportInd
boolean
O
0..1
This IE indicates whether the NF supports Overload Control based on OCI Header (see clause 6.4 of 3GPP TS 29.500 [4]).
| Note
At least one of the addressing parameters (FQDN, IPv4address or IPv6adress) is included in the NF Profile. If the NF supports
the NF services with "https" URI scheme (i.e use of TLS is mandatory), then the FQDN provided in the NF Profile or the NF
Service profile (see clause 6.1.6.2.3). See NOTE 1 of Table 6.1.6.2.3-1 for the use of these parameters. If multiple ipv4
addresses and/or ipv6 addresses are included in the NF Profile, the NF Service Consumer of the discovery service must select
one of these addresses randomly, unless operator defined local policy of IP address selection, in order to avoid overload
for a specific ipv4 address and/or ipv6 address.
| Note
If the type of Network Function is UPF, the addressing information is for the UPF N4 interface.
| Note
A requester NF may use this information to select a NF instance (e.g. a NF instance preferably located in the same data center).
| Note
The capacity and priority parameters, if present, are used for NF selection and load balancing. The priority and capacity
attributes must be used for NF selection in the same way that priority and weight are used for server selection as defined
in IETF RFC 2782 [23].
| Note
The NRF must notify NFs subscribed to receiving notifications of changes of the NF profile, if the NF recoveryTime or the
nfStatus is changed. See clause 6.2 of 3GPP 23.527 [27].
| Note
A requester NF may consider that all the resources created in the NF before the NF recovery time have been lost. This may
be used to detect a restart of a NF and to trigger appropriate actions, e.g. release local resources. See clause 6.2 of 3GPP 23.527 [27].
| Note
A NF may register multiple PLMN IDs in its profile within a PLMN comprising multiple PLMN IDs. If so, all the attributes of
the NF Profile must apply to each PLMN ID registered in the plmnList. As an exception, attributes including a PLMN ID, e.g.
IMSI-based SUPI ranges, TAIs and GUAMIs, are specific to one PLMN ID and the NF may register in its profile multiple occurrences
of such attributes for different PLMN IDs (e.g. the UDM may register in its profile SUPI ranges for different PLMN IDs).
| Note
Other NFs are in a different PLMN if they belong to none of the PLMN ID(s) configured for the PLMN of the NRF.
| Note
This is for the use case where an NF (e.g. AMF) supports multiple PLMNs and the slices supported in each PLMN are different.
See clause 9.2.6.2 of 3GPP TS 38.413 [29].
| Note
If notification endpoints are present both in the profile of the NF instance (NFProfile) and in some of its NF Services (NFService)
for a same notification type, the notification endpoint(s) of the NF Services must be used for this notification type.
| Note
The absence of the pcscfInfoList attribute in a P-CSCF profile indicates that the P-CSCF can be selected for any DNN and Access
Type.
| Note
The absence of both the smfInfo and smfInfoList attributes in an SMF profile indicates that the SMF can be selected for any
S-NSSAI, DNN, TAI and access type.
| Note
The servingScope attribute may indicate geographical areas, It may be used e.g. to discover and select NFs in centralized
Data Centers that are expected to serve users located in specific region(s) or province(s). It may also be used to reduce
the large configuration of TAIs in the NF instances.
