Peer Monitoring
View Peer Status Through Grafana
Feature Name |
Release Information |
Description |
SMF Metrics – View Peer Status Through Grafana |
2025.01.0 |
With this release, SMF provides the ability to view the connection status of Diameter (Gx and Gy), RADIUS, CGF, and N4 peers using Grafana queries on Grafana cloud. In a single pane view, you can see the peer status across various deployments, aiding in faster identification and resolution of connectivity issues. The Grafana query shows the current status of the peers and also shows the peer status if it is connected or not connected. For more information about SMF metrics, see SMF Metrics. |
SMF uses the following metrics to view the peer status in Grafana:
Peer |
Metric |
Configuration Required |
Diameter (Gx and Gy) |
rpc_host_status |
OR
RADIUS |
Radius_Server_Status |
No configuration required |
CGF (GTPP/Gz) |
nodemgr_gtpp_stats Note that this metric is new in this release (2025.01.0). |
OR
N4 |
nodemgr_upf_link_status Note that this metric is new in this release (2025.01.0). |
OR
Feedback
