Redundancy Support
Summary Data
Table 1. Summary Data
Applicable Product or Functional Area
SMF
Applicable Platform
SMI
Feature Default Setting
  • Redundancy Support: Enabled - Configuration required to disable.
  • Traffic Monitoring on L2 VIP for Active Instance: Disabled - Configuration required to enable.
  • Geo Strengthening: Enabled - Configuration required to disable.
  • Minimize Session Loss During Application VIP switchover: Not Applicable.
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
Enhanced the High Availability Redundancy support to minimize the session loss during application VIP switchover between master nodes.
2023.04.0
Support added for the following sub-features:
  • Traffic Monitoring on L2 VIP for Active Instance.
  • Inter-site Redundancy.
  • GR Strengthening.
2023.03.0
Support added for Maintenance Mode.
2021.04.0
Geographic Redundancy (GR) support introduced.
2021.02.0
First introduced.
Pre-2020.02.0
Feature Description
This chapter provides an overview of the redundancy features, the architecture, and the configurations required to achieve the functionality in the failover scenario.
Types of Redundancies Supported
SMF supports following types of redundancies:
Redundancy Type
Description
Server
The solution is designed to sustain server failures and distribute the workload to another server in the cluster.
In this scenario, most of the essential and service critical pods are running in Active and Standby modes, and they reside on a different server to cause minimum impact in the event of a hardware failure.
Rack
In this scenario, the Kubernetes cluster is mirrored in the same Data Center, but on different racks.
In case of multiple server failures, software failures, or an adjacent routing layer issue, the sessions are switched to other racks. This way, it is assured to achieve the same level of service from the new rack.
Site
In this scenario, the Kubernetes cluster is mirrored in different geographical data centers.
In case of a whole data center is downtime, the sessions are switched to the other rack in a different data center. Through this, it is assured to achieve the same level of service from the new rack.
High Availability Support
Table 3. Feature History
Feature Name
Release Information
Description
Minimizing Session Loss During Application VIP switchover
2023.04
The High Availability redundancy support is enhanced in SMF in a way that when the gRPC IPC stream breaks, the App-Infra library re-tries immediately and the IPC connection is re-established between gRPC endpoints within milliseconds.
Feature Description
The SMF is built on the Kubernetes cluster strategy so that it inherits the high availability aspects of K8 cluster deployments. The SMF uses the construct that includes the components such as pods and services.
Each pod has at least 2 instances to ensure high availability against
  • Pod instance restart or failure
  • Pod lost due to node restart or failure
For details on the pods and services, see the Pods and Services Reference chapter in this guide.
High Availability of Node Manager
The SMF supports IPAM redundancy and load balancing for each UPF. The IPAM running in the Node Manager microservice has two IPAM instances that are associated to each UPF. When one IPAM instance is inactive, the other IPAM instance manages the address allocation requests for the UPF.
For more information on node manager redundancy, see the IPAM Redundancy Support Per UPF section in the IP Address Management chapter.
High Availability Inside Rack
High availability inside rack is an arrangement that handles server level redundancies. In this solution, in case of a single server failure, a few pods according to the design might get distributed in another available server. Meanwhile, other pods remain in pending state until the server comes back.
In this scenario, the critical pods that handle the external traffic run on Active-Stand-by pair on a different server. The redundancy support in the routing layer is provided by leaf and spine layers.
Figure 1. High Availability Layout
Architecture
This section describes the recommended layout of SMF pods and VMs.
SMF Pod and VM Deployment Layout
This section describes the deployment of SMF pods and its microservices.
The following figure shows the deployment model of six VMs in SMF.
Figure 2. VM Deployment Model
In this model, the pods are deployed on VM pairs. Two replicas are available for each protocol pod (for example, rest-ep, protocol-ep, and gtp-ep). One instance is deployed on each protocol VM.
Similarly, service pods and session pods are distributed on both the service and session VMs equally. Such a distribution is controlled by labelling the VMs as well as implementing the K8 affinity and anti-affinity rules during pod scheduling.
This model ensures that, during VM reboot scenarios, at least 50% of the replicas of each pod type are available to handle user signaling.
Graceful pod restart allows pod to complete ongoing processing within 30 seconds. Abrupt pod restart will affect ongoing transactions without impact to PDU sessions.
How It Works
This section provides information on how the resiliency and HA can be achieved.
The SMF enables inter-pod communication during the pod failure or restart.
During a graceful pod restart:
  • Ongoing processing is not impacted.
  • New messages are not sent to this pod through the Kubernetes service.
  • Messages with session affinity continue to be received by this pod.
  • Existing call flow expected to complete within 30 seconds.
After the pod restarts:
  • All Prometheus metrics of the pod are reset.
  • Internal pod diagnostics once passed, the pod's status is changed to ready.
  • The pod is ready to process the new messages.
When the SMF VM reboots or the VM is unavailable,
  • All pods on the VM are lost.
  • Pods on other available VM continue processing, thus providing high availability.
  • VIP if present is switched to the other available node.
  • It takes about 5 minutes of node unreachability for Kubernetes to detect the node as down.
  • Pods on the node are thereafter not discoverable through the Kubernetes service.
After the pod restarts, pods on the VM are scheduled one after another. This operation is similar to the pod restart.
During the VIP and VM reboot, virtual IP is associated with a single VM. UDP proxy binds to N4 VIP address for communication with UPF. UDP proxy binds to S5 VIP address for communication with cnSGW.
Reboot of VM with active VIP causes VIP to switch to other protocol VM. The active UDP proxy failure causes VIP to switch to the other protocol VM.
Before the Subscriber Microservices Infrastructure (SMI) handles the VIP monitoring and switchover, make sure that the appropriate VIP configuration is available in the SMI deployer. Also, check if the port is set to 28000 and the host priority is equal.
The BGP-speaker monitors the IP address changes on its node. In case of addition or deletion of service IP addresses, it immediately advertises them with the proper Med value using "IP monitor" support by netlink.
During the VIP switchover, when the gRPC IPC stream breaks, the App-Infra library re-tries immediately and IPC connection is reestablished between gRPC endpoints within milliseconds.
During BGP POD graceful shutdown, all VIPs failover to other master and the traffic should be served by the other node immediately. To take immediate traffic of the peer pod/node, the shutting pod reduces Med preference, i.e., 1217/1218.
BGP speaker needs to move the VIP immediately to other master, when the BFD links are detected as down from both the leafs. This is achieved by restarting the monitoring of Keepalived interfaces from the BGP speaker and identify when the BFD links are down.
Configuring Pod-level Labelling and Replicas
The node label is configured on the SMI cluster deployer. For information on the configuration commandsin the chapter.
Configuration Example
The following is an example of VM labelling and replica configuration.
k8 label protocol-layer key smi.cisco.com/node-type value smf-proto
exit
k8 label service-layer key vm-type value smf-svc
exit
k8 label cdl-layer key smi.cisco.com/node-type value smf-cdl
exit
k8 label oam-layer key smi.cisco.com/node-type value oam
exit
endpoint pfcp
 replicas 1
 nodes    2
exit
endpoint service
 replicas 1
 nodes    2
exit
endpoint protocol
 replicas 1
 nodes    2
 vip-ip 209.165.201.28
exit
endpoint sbi
 replicas 1
 nodes    2
Configuration Verification
To verify the configuration, use the following show command:
show running-config instance instance-id instance_id endpoint
The following is an example output of this show command.
[unknown] smf# show running-config instance instance-id 1 endpoint
 endpoint nodemgr
  replicas 1
  nodes    2
 exit
 endpoint gtp
  replicas 1
  vip-ip 209.165.202.149
 exit
 endpoint pfcp
  replicas                2
  enable-cpu-optimization true
  interface n4
   heartbeat
    interval               0
    retransmission-timeout 3
    max-retransmissions    5
   exit
  exit
 exit
 endpoint service
  replicas 2
 exit
 endpoint protocol
  replicas 1
 exit
exit
This command output displays the configurations related to multiple endpoints, such as endpoint names, pod replicas, nodes, and so on.
Feature Description
SMF identifies active L2 VIPs on the protocol node that do not have any traffic. If case of an active L2 VIPs, there may not be any traffic due to various reasons, including network connectivity issues.
Upon detecting the no traffic scenario on active L2 VIPs, the SMF attempts to restart the pod or triggers the GR based on the CLI configuration action. It facilitates the restoration of traffic resulting in minimal loss of sessions.
This feature can be enabled or disabled using a CLI.
How It Works
  • The traffic monitoring on IPC L2 VIP happens periodically and is matched with configurable no-traffic-duration time.
  • If there is no traffic on the active IPC L2 VIP for the configured time duration, depending on the action configured either the GR trigger happens, so that other rack can handle the traffic, or the pod restarts, so that VIP switches to the other pod restoring traffic.
  • If a pod restart action is configured and even after the VIP switchover if traffic is not restored, the IPC connection monitoring feature will trigger the GR scenario if configured to minimize the impact.
  • Following checks are monitored periodically. If the checks fulfill the condition, the traffic is monitored:
    • CLI config no-traffic-duration should be greater than 10 seconds.
    • CLI config session-threshold should be greater than or equal to 1000. The default value is 1000.
    • Whether any of the GR Instance ID roles is PRIMARY.
    • Whether internal VIP is present on the protocol node.
    • If the session count is greater than or equal to the session threshold configured using the CLI, traffic monitoring is triggered. However, if the session count is less than 1000, traffic monitoring is stopped.
  • Single IPC endpoint handles traffic for both the GR Instance IDs in GR mode. Traffic monitoring on IPC endpoint will not be GR Instance ID specific. However, checks are done for both the GR Instance IDs.
Configuring HA and GR Scenarios
Use the following configuration to trigger HA (pod-restart) scenario or GR (trigger-switch-over) scenario:
config
   monitor
      active-instance-traffic {  no-traffic-duration no_traffic_duration session-threshold session_threshold action { pod-restart | trigger-switch-over  } }
NOTES:
  • active-instance-traffic —Specify this keyword to enable or disable active traffic monitoring.
  • no-traffic-duration no_traffic_duration —Maximum allowed time in seconds of no traffic on active instance. The value range is 10-300. There is no default value set for this CLI. The value of no-traffic-duration should be less than the value of max-conn-downtime if set.
  • session-threshold session_threshold —Minimum session count required to start the active instance traffic monitoring. The value range is 10-10000000. The default value is 1000.
  • action { pod-restart | trigger-switch-over } —Action to take on condition fulfillment. The possible values for this command are pod-restart and trigger-switch-over . The default value is pod-restart .
Following example shows the configuration of this feature:
smf(config)# monitor active-instance-traffic no-traffic-duration 15 session-threshold 1000 action pod-restart
Following show command displays the output for this feature:
smf# show running-config monitor active-instance-traffic
OAM Support
This section defines various statistics supported in this feature.
KPI
Following KPIs are supported as part of this feature:
Active Instance Traffic Monitor Services KPI
KPI Name
Description
Labels
active_instance_traffic_monitor_services
This statistic displays services which have registered for traffic monitoring.
interface_name
internal_vip_ip
Active Instance Traffic Monitor Status KPI
KPI Name
Description
Labels
Possible Values
active_instance_traffic_monitor_status
This statistic displays the status of active instance traffic monitoring.
interface_name
internal_vip_ip
0 – Not Monitoring
1 – Monitoring
Active Instance Traffic Monitor Reason KPI
KPI Name
Description
Labels
Possible Values
active_instance_traffic_monitor_reason
This statistic displays the reason if conditions do not meet for active instance traffic monitoring in the monitoring or not-monitoring state.
interface_name
internal_vip_ip
1 - GR Instance ID is not Primary
2 - Current session count is less than session threshold count
3 - Internal VIP not active
4 - Active Instance Traffic Monitor not configured
Active Instance Traffic Monitor Session Count KPI
KPI Name
Description
Labels
active_instance_traffic_monitor_session_count
This statistic displays the current session count.
interface_name
internal_vip_ip
Note
The count displayed will be from the affinity cache.
Active Instance Traffic Monitor Last Received Traffic KPI
KPI Name
Description
Labels
active_instance_traffic_monitor_last_recv_traffic
This statistic displays the last received traffic time in seconds.
interface_name
internal_vip_ip
Note
This statistic will be calculated only when all the conditions of the active instance traffic monitor are met.
Inter-Rack Redundancy Support
Inter-Rack redundancy support refers to the ability of a system or service to maintain its functionality and availability in the event of a failure or outage in one rack can be mitigated by moving the operations to another rack in the same geo location.
Feature Description
The SMF supports Inter-Rack redundancy in the active-active mode. The Inter-Rack redundancy is achieved through replication of sessions, configuration, and any other data required for seamless failover and failback of services to the remote rack.
How It Works
SMF (CNF) can be deployed in the same data center to provide service for a catastrophic failure localized to a rack hosting an SMF SMF cluster.
Each CNF instance service registers with NRF and S11/S5 for DNS entry for MME/SGW. Local HA redundancy allows instance to achieve rack level redundancy in addition to K8 cluster level failures within same data center or handle locally within same K8 cluster if failed containers are per Type-2 < n.
where, n is a value. For less than 50% of container failures, HA should handle the failures. For more than 50% of container failures, Inter-rack switchover is triggered.
Overview
In active-active mode,
  • The inter-rack deployment is transparent to the adjacent NFs.
  • The inter-rack deployment contains two instances of the CCG function, each instance manifest itself with a set of interface IPs.
  • Each instance support sets of sessions and continue to use the same IP for session consistency.
  • At a specific time period, one CCG instance can be primary only on one rack and standby on the other rack.
  • The set of interface IPs that are associated with the CCG instance, dynamically route to the primary rack of the instance.
SMF supports primary/standby redundancy in which data is replicated from the primary to standby instance. The primary instance provides services in normal operation. If the primary instance fails, the standby instance becomes the primary and takes over the operation. To achieve inter-rack redundancy, two primary/standby pairs can be set up where each rack is actively processing traffic and standby is acting as backup for the remote rack.
In an Active-Active inter-rack redundancy deployment, consider there are two racks: Rack-1 and Rack-2 located in the same data center. All the NFs are trying to reach instance-1 and instance-2.
Figure 3. Active-Active Inter-Rack Redundancy Deployment
For NFs, both the instances are active. But in real, instance-1 and instance-2 are divided across racks.
Rack-1 has instance-1 and instance-2. In a pre-trigger scenario, instance-1 is local and acts as Primary and instance-2 is in Standby mode.
Rack-2 also has instance-1 and instance-2. In a pre-trigger scenario, instance-2 is local and acts as Primary and instance-1 is in Standby mode.
In case, if Rack-1 goes down, the traffic moves to Rack-2. On Rack-2 both the instances, instance-1 and instance-2 acts as Primary.
Inter-Rack Redundancy Triggers
Inter-rack redundancy supports the following triggers:
  • CLI-based Switchover: Manual CLI commands are used to switch the roles and trigger inter-rack redundancy failover.
  • BFD Link Failover Detection: When both the BFD links between the connected rack and the leafs are down, inter-rack redundancy failover is triggered.
  • Local Rack POD Failure Detection: When threshold percentage of POD replica-sets failing is greater than the configured threshold value, the inter-rack redundancy failover is triggered.
  • Remote Rack POD Failure Detection: When the remote POD monitoring detects failure breaching threshold percentage, the POD becomes self-primary for that instance.
  • Remote Rack Role Monitoring: When the remote role monitoring detects that the rack is in Standy_error state, it becomes self-primary.
  • Multi-Compute Failure: When two or more servers are powered down, it triggers inter-rack redundancy failover.
Rack NF Roles
The following is a list of applicable rack NF roles:
Note
  • The Cachepod/ETCD and the CDL Replication happen during all the roles mentioned in the following section.
  • If the inter-rack links are down or under periodic heartbeat fails, then these inter-rack redundancy triggers get suspended.
  • PRIMARY: In this role, the rack is in ready state and actively taking traffic for the given instance.
  • STANDBY: In this role, the rack is in standby mode, ready to take traffic, but not taking traffic for the given instance.
  • STANDBY_ERROR: In this role, the rack is in problem state, not active, and not ready to take traffic for the given instance.
    Note
    When the instance role is in STANDBY_ERROR, data replication gets halted. The command show georeplication-status consistently fails under this condition. However, once the instance role gets transitioned to STANDBY, data replication resumes automatically, and the command displays the result as pass.
  • FAILOVER_INIT: In this role, the rack has started to fail over and not in condition to take traffic. The buffer time is two seconds for the application to complete their activity.
For fresh installation, the rack boots-up with the following roles:
  • PRIMARY: In this role, the rack is in for the local instance (each rack has local instance-id configured to identify the local instance). It is recommended not to configure the pods for monitoring during fresh installation. Once the setup is ready, you can configure the pods for monitoring.
  • STANDBY: In this role, the rack is in for other instances.
For upgrades, the rack boots-up with the following roles:
  • STANDBY_ERROR: In this role, the rack is for all the instances as moving the traffic post upgrade needs manual intervention.
General Guidelines
Before configuring the inter-rack redundancy deployment, here are some general guidelines:
  • Both racks should be on the same software version.
  • Both racks should be configured with same configuration.
  • Loopback port of Instance 1 and Instance 2 should be different. Else, REST-EP POD would not come up due to K8 IP/Port conflict.
  • Respective interface on both the racks should be on the same VLAN. For example, N4 VLAN of Instance1 and Instance2 should be on the same VLAN. Else, there is a route conflict on Kernel while enforcing BGP policies.
  • Consult your Cisco Technical Representative to perform the following procedures to make sure proper roles are assigned.
    For more information, see Software Upgrade on GR Pairs.
  • Post failover, perform the failback manually after ensuring the rack is healthy. Autonomous failback is not supported.
    For more information, see Recovery Procedure.
  • Use non-bonded interface in BGP speaker PODs for BGP peering.
  • BGP peering per Proto node is supported with only two BGP routers/leafs. Considering two Proto nodes, there can be maximum of four BGP neighborships.
  • Use bonded interfaces for Service traffic.
  • Geo pod uses two VIPs:
    • Internal-VIP for Inter-POD communication (within the rack)
    • External-VIP for Inter-rack Geo pod communication. Configure only on Proto Nodes on L2 Subnet. This is used to communicate across the racks. This node has external connectivity to other rack.
  • Geo Internal IP to be reachable to all nodes within the rack.
  • Geo External IP:
  • CDL/Kafka VIPs: Configure on CDL Labeled Nodes on L2 Subnet.
  • Enable LI tapping on both the racks.
  • MDF server should be reachable from both the racks.
Instance Awareness
Instance awareness configuration in SMF helps to distinguish local rack instance and remote rack instance.
Configuring Inter-Rack Redundancy Instance
This configuration is needed to provide a inter-rack redundancy configuration for multiple rack. With instance ID, endpoint configurations should be configured for each rack.
Sample Configuration 1
The following is a sample configuration for endpoint VIP configuration under one instance:
config
  instance instance-id gr_instanceId
    endpoint endpoint_name
        vip-ip vip_ip_address
  exit
exit
Example:
config
 endpoint sbi
  vip-ip 209.165.201.21
 exit
exit
Sample Configuration 2
The following is a sample configuration to provide information on system-id, cluster-id and slice-name under an instance:
config
  instances instance instance_id
   system-id system_id
   cluster-id cluster_id
   slice-name cdl_slice_name
  exit
exit
Example:
config
 instances instance 1
  system-id smf
  cluster-id smf
  slice-name 1
 exit
exit
Note
It is recommended to have the same values for system-id, cluster-id in the instance, and app-name, cluster-name in deployment.
Configuring Endpoint Instance Awareness
Only two instances can be configured on each local and remote rack, and corresponding endpoints can be instantiated.
A local instance-id is the identity of the local rack irrespective of if the rack is redundant or not.
Local Instance ID Configuration
The local instance is configured using the local-instance command.
local-instance instance 1
Endpoint configuration must be under instance specified by each unique instance ID.
Endpoint Configuration Example
Following are a few configuration examples.
Note
In the following example, instance-id "1" is a local instance-id, and endpoints configured under it belong to the local rack.
Optionally, remote rack instance-id "2" can be configured for endpoints belonging to the inter-rack.
 endpoint li
  replicas 1
  nodes    2
  vip-ip 209.165.201.6
  vip-ip 209.165.201.13
 exit
 endpoint gtp
  replicas 1
  nodes    2
  retransmission timeout 5 max-retry 4
  vip-ip 209.165.201.4
  interface s5
   echo interval          60
   echo retransmission-timeout 5
   echo max-retransmissions 4
  exit
  interface s2b
   echo interval 60
  exit
 exit
exit
instance instance-id 2
 endpoint li
  replicas 1
  nodes    2
 exit
exit
endpoint gtp
  replicas 1
  nodes    2
  vip-ip 209.165.201.5
  interface s5
   echo interval 60
  exit
  interface s2b
   echo interval 60
  exit
 exit
exit
Configuring Profile SMF Instance Awareness
Add instance for PGW FQDN corresponding to local and remote instances.
Example
Following is a configuration example.
Note
In the following example, instance-id "1" is a local instance-id, and the SMF profile configured under it belongs to the local rack.
Optionally, remote rack instance-id "2" can be configured for FQDN belonging to the inter-rack.
profile smf smf1
locality LOC1
allowed-nssai [ slice1 ]
instances 1 fqdn cisco.com.apn.epc.mnc456.mcc123
instances 2 fqdn cisco.com.apn.epc.mnc567.mcc123
Dynamic Routing
Border Gateway Protocol (BGP) allows you to create loop-free inter-domain routing between autonomous systems (AS). An AS is a set of routers under a single technical administration. The routers can use an Exterior Gateway Protocol to route packets outside the AS. The Dynamic Routing by Using BGP feature enables you to configure the next-hop attribute of a BGP router with alternate local addresses to service IP addresses with priority and routes. The App-Infra BGP speaker pods enable dynamic routing of traffic by using BGP to advertise pod routes to the service VIP.
This feature supports the following functionality:
  • Dynamic routing by using BGP to advertise service IP addresses for the incoming traffic.
  • Learn route for outgoing traffic.
  • Handling a BGP pod failover.
  • Handling a protocol pod failover.
  • Statistics and KPIs for the BGP speakers.
  • Log messages for debugging the BGP speakers.
  • Enable or disable the BGP speaker pods.
  • New CLI commands to configure BGP.
Incoming Traffic
BGP uses TCP as the transport protocol, on port 179. Two BGP routers form a TCP connection between one another. These routers are peer routers. The peer routers exchange messages to open and confirm the connection parameters.
The BGP speaker publishes routing information of the protocol pod for incoming traffic in the active standby mode. Use the following image as an example to understand the dynamic routing functionality. There are two protocol pods, pod1 and pod2. Pod1 is active and pod2 is in the standby mode. The service IP address, 209.165.200.225 is configured on both the nodes, 209.165.200.226 and 209.165.200.227. pod1 is running on host 209.165.200.226 and pod2 on host 209.165.200.227. The host IP address exposes the pod services. BGP speaker publishes the route 209.165.200.225 through 209.165.200.226 and 209.165.200.227. It also publishes the preference values, 110 and 100 to determine the priority of pods.
Figure 4. Dynamic Routing for Incoming Traffic in the Active-standby Topology
For high availability, each cluster has two BGP speaker pods with Active-standby topology. Kernel route modification is done at host network level where the protocol pod runs.
MED Value
The Local Preference is used only for IGP neighbours, whereas the MED Attribute is used only for EGP neighbours. A lower MED value is the preferred choice for BGP.
Table 4. MED Value
Bonding Interface Active
VIP Present
MED Value
Local Preference
Yes
Yes
1210
2220
Yes
No
1220
2210
No
Yes
1215
2215
No
No
1225
2205
Bootstrap of BGP Speaker Pods
The following sequence of steps set up the BGP speaker pods:
  1. The BGP speaker pods use TCP as the transport protocol, on port 179. These pods use the AS number configured in the Ops Center CLI.
  2. Register the Topology manager.
  3. Select the Leader pod. The Active speaker pod is the default choice.
  4. Establish connection to all the BGP peers provided by the Ops Center CLI.
  5. Publish all existing routes from ETCD.
  6. Configure import policies for routing by using CLI configuration.
  7. Start gRPC stream server on both the speaker pods.
  8. Similar to the cache pod, two BGP speaker pods must run on each Namespace.
External Network Failure
The NF instance start-up causes the BGP Speaker K8s pod to configure the next-hop attribute of the BGP router with alternate local addresses to service IP addresses with priority and routes.
After the Geo HA is triggered, the path selection is based on the destination service IP address, path connectivity and the priority value.
Note
The subscriber sessions are not impacted because of the transparent migration between pods.
Geo Switchover
The SMF achieves geo switchover by transparently migrating service IP address to mated peer K8s cluster, rack collocated, or geo-located. During the NF start-up, all the K8s cluster Namespaces register with the next-hop BGP router to advertise its service IP address and local IP address along with the priority and route modifier values.
Each logical NF exposes separate NF instance toward NRF or DNS, separate configuration, and separate LCM for a Namespace.
Internal Network Failure
If a functioning K8s cluster has an internal network failure due to a disrupted server communication with the master node, BFD failure, or a K8s pod networking issue, Geo HA is triggered due to K8s dependency checks that are based on the K8s liveliness failure.
In the example shown in the following figure, the AMF or MME transparently starts using the alternate rack server. The N11/S11/S5 and N4/Sxa service addresses are migrated to site B rack B. The system continues signalling from rack B for rack A. At rack B, the session continues without any impact to existing subscriber sessions.
Note
Few in-transit calls might fail depending on the state where it is terminated before the UE re-attaches.
Figure 5. Geo HA for Internal Network Failure
Local Switchover
The SMF achieves geo switchover by transparently migrating service IP address to mated peer K8s cluster or rack collocated within the same data center. During the NF start-up, all the K8s cluster Namespaces register with the next-hop BGP router to advertise its service IP address and local IP address along with the priority and route modifier values. Each logical NF exposes separate NF instance toward NRF or DNS, separate configuration, and separate LCM for a Namespace.
Recovery and Failback
For a seamless failover and failback, the UE sessions and the corresponding service IP addresses are grouped together.
The following scenarios describe the seamless failover and failback mechanism for the UE sessions:
  • Normal - The UE sessions set is created, updated, or deleted from first rack and replicated to second rack.
  • Failure - The UE sessions set is created, updated, or deleted from second rack and is not replicated to first rack due to its unavailability.
  • Recovery - The CDL for first rack performs an auto-sync with the CDL for second rack to recover all the UE session data. During the recovery, the second rack continues to handle traffic from the sessions set.
Call Flows
This section describes the key call flows for Dyanmic Routing by Using BGP.
Publish Route for Incoming Traffic in an Active-Standby Mode
The following sections describe the Control Plane and Data Plane call flows in an active/standby mode.
Control Plane Call Flow
This section describes the Control Plane call flow.
Figure 6. Control Plane Call Flow
Table 5. Control Plane Call Flow Description
Step
Description
The BGP speaker pod starts and fetches the service IP address, next-hop IP address (host IP or loopbackEth), and the Instance ID for the BGP speaker pod.
The pod service is exposed through host IP or configured loopbackEth.
The NF Instance ID is used to find the route priority or preference.
The BGP speaker pod advertises routes by fetching vip-ip (service IP addresses) from the Ops Center.
Data Plane Call Flow
This section describes the data plane call flow.
Figure 7. Data Plane Call Flow
Table 6. Data Plane Call Flow Description
Step
Description
AMF requests for service IP address. The request is sent to the nearest connected router through multiple external routers. Then, the router sends the request to the BGP speaker pod with highest priority.
The BGP router sets the data plane flow based on the preference value. In the preceding call flow example, the router routes the service request through the host, 209.165.200.226 to pod 1 due to its higher preference value.
From host 209.165.200.226, traffic is forwarded to the K8 service IP address, 209.165.201.10, which is then sent to either protocol pod 1 (209.165.200.226) or pod 2 (209.165.200.227).
Single Protocol Pod Failure Call Flow
The following section describes the Single Protocol Pod Failure call flow.
Figure 8. Single Protocol Pod Failure Call Flow
Table 7. Single Protocol Pod Failure Call Flow Description
Step
Description
AMF requests for service IP address. The request is sent to the nearest connected BGP router through multiple external routers based on the next highest preference value.
The BGP router sets the data plane flow based on the preference value. If the pod with the highest preference value is not available, then the request is routed to the pod with the next highest preference value through the K8 service pod.
In the example shown in the preceding call flow figure, pod 2 with the IP address, 209.165.200.227 serves the request due to its higher preference value.
Learn Route for Outgoing Traffic Call Flow
This section describes the Learn route for outgoing traffic call flow.
Figure 9. Learn Route for Outgoing Traffic Call Flow
AMF or other systems advertise route to the external BGP route. In turn, the external BGP router advertises routes for its service through BGP.
Table 8. Learn Route for Outgoing Traffic Call Flow Description
Step
Description
The BGP speakers receive the routing information.
Learn the route by using the BGP protocol.
Based on the configure policy, the system either checks the routing information or ignores it.
If the policy is not allowed, then the system logs the messages and updates the statistics.
The protocol pods configures the route in Kernel space on host through the netlink go APIs.
Configuring Dynamic Routing Using BGP
This section describes how to configure the dynamic routing using BGP.
Configuring AS and BGP Router IP Address
To configure the AS and IP address for the BGP router, use the following commands:
config
   router bgp local_as_number
   exit
exit
NOTES:
  • router bgp local_as_number —Specify the identification number for the AS for the BGP router.
    In a inter-rack redundancy deployment, you need to configure two Autonomous Systems (AS).
    • One AS for leaf and spine.
    • Second AS for both racks: Rack-1 and Rack-2.
Configuring BGP Service Listening IP Address
To configure the BGP service listening IP address, use the following commands:
config
      interface interface_name
   exit
exit
NOTES:
  • interface interface_name —Specify the name of the interface.
Configuring BGP Neighbors
To configure the BGP neighbors, use the following commands:
config
      neighbor neighbor_ip_address remote-as as_number
   exit
exit
NOTES:
  • neighbor neighbor_ip_address —Specify the IP address of the neighbor BGP router.
  • remote-as as_number —Specify the identification number for the AS.
Configuring Bonding Interface
To configure the bonding interface related to the interfaces, use the following commands:
config
      bondingInterface interface_name
   exit
exit
NOTES:
  • bondingInterface interface_name —Specify the related bonding interface for an interface. If the bonding interface is active, then the BGP gives a higher preference to the interface-service by providing a lower MED value.
Configuring Learn Default Route
If the user configures specific routes on their system and they need to support all routes, then they must set the learnDefaultRoute as true.
Note
This configuration is optional.
To configure the Learn Default Route, use the following commands:
config
      learnDefaultRoute true/false
   exit
exit
NOTES:
  • learnDefaultRoute true/false —Specify the option to enable or disable the learnDefaultRoute parameter. When set to true, BGP learns default route and adds it in the kernel space. By default, it is false.
Configuring BGP Port
To configure the Port number for a BGP service, use the following commands:
config
      loopbackPort port_number
   exit
exit
NOTES:
  • loopbackPort port_number —Specify the port number for the BGP service. The default value is 179.
Policy Addition
The BGP speaker pods learns many route information from its neighbors. However, only a few of them are used for supporting the outgoing traffic. This is required for egress traffic handling only, when SMF is sending information outside to AMF/PCF. Routes are filtered by configuring import policies on the BGP speakers and is used to send learned routes to the protocol pods.
A sample CLI code for policy addition and the corresponding descriptions for the parameters are shown below.
$bgp policy <policy_Name> ip-prefix 209.165.200.225 subnet 16 masklength-range 21..24 as-path-set “^65100”
Table 9. Import Policies Parameters
Element Description Example Optional
as-path-set AS path value “^65100” Yes
ip-prefix Prefix value “209.165.200.225/16” Yes
masklength-range Range of length “21..24” Yes
interface Interface to set as source IP (default is VM IP) eth0 Yes
gateWay Change gateway of incoming route 209.165.201.30 Yes
modifySourceIp Modify source ip of incoming route
Default value is False.
true Yes
isStaticRoute Flag to add static IP address into kernel route
true Yes
Configuring BGP Speaker
This configuration controls the number of BGP speaker pods in deployment. BGP speaker advertises service IP information for incoming traffic from both the racks.
Note
  • Use non-bonded interface in BGP speaker pods for BGP peering.
instance instance-id  instance_id endpoint bgpspeaker interface { bgp | bfd } internal base-port start base_port_number
config
 endpoint bgpspeaker
   replicas replica_id
   nodes node_id
   interface bgp
   exit
   interface bfd
  exit
exit
NOTES:
  • instance instance-id instance_id —Specify the GR instance ID.
  • base_port_number —Specify the port range only if logical NF is configured. This range depends on your deployment.
Example
The following is a configuration example:
endpoint bgpspeaker
   replicas 1
   nodes    2
   interface bgp
     internal base-port start {24000}
   exit
   interface bfd
     internal base-port start {25000}
 exit
Monitoring and Troubleshooting
This section describes the show commands that are supported by the Dynamic Routing by Using BGP feature.
show bgp-kernel-route
Use the show bgp-kernel-route command to view all the kernel level routes for a BGP router.
The following configuration is a sample output of the show bgp-kernel-route command:
kernel-route
-----bgpspeaker-pod-1 ----
 DestinationIP       SourceIP        Gateway
 209.165.200.235     209.165.200.239   209.165.200.239
-----bgpspeaker-pod-2 ----
 209.165.200.235     209.165.200.229   209.165.200.244
show bgp-global
Use the show bgp-global command to view all BGP global configurations.
The following configuration is a sample output of the show bgp-global command:
global-details
AS:        65000
Router-ID: 209.165.200.239
Listening Port: 179, Addresses: 209.165.200.239
AS:        65000
Router-ID: 209.165.200.232
Listening Port: 179, Addresses: 209.165.200.232
AS:        65000
Router-ID: 209.165.200.235
Listening Port: 179, Addresses: 209.165.200.235
AS:        65000
Router-ID: 209.165.200.246
Listening Port: 179, Addresses: 209.165.200.246
show bgp-neighbors
Use the show bgp-neighbors command to view all BGP neighbors for a BGP router.
The following configuration is a sample output of the show bgp-neighbors command:
neighbor-details
Peer             AS  Up/Down State       |#Received  Accepted
209.165.200.244 60000 00:34:20 Establ      |       10        10
209.165.200.250 60000 00:34:16 Establ      |        3         3
209.165.200.244 60000 00:33:53 Establ      |       10        10
209.165.200.250 60000 00:33:53 Establ      |        3         3
show bgp-neighbors ip
Use the show bgp-neighbors ip command to view details of a neighbor for a BGP router.
The following configuration is a sample output of the show bgp-neighbors ip command:
neighbor-details
BGP neighbor is 209.165.200.244, remote AS 60000
  BGP version 4, remote router ID 209.165.200.244
  BGP state = ESTABLISHED, up for 00:34:50
  BGP OutQ = 0, Flops = 0
  Hold time is 90, keepalive interval is 30 seconds
  Configured hold time is 90, keepalive interval is 30 seconds
  Neighbor capabilities:
    multiprotocol:
        ipv4-unicast:   advertised and received
    route-refresh:      advertised and received
    extended-nexthop:   advertised
        Local:  nlri: ipv4-unicast, nexthop: ipv6
    4-octet-as: advertised and received
  Message statistics:
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:                1          2
    Keepalives:            70         70
    Route Refresh:          0          0
    Discarded:              0          0
    Total:                 72         73
  Route statistics:
    Advertised:             0
    Received:              10
    Accepted:              10
  BGP state = ESTABLISHED, up for 00:35:17
    multiprotocol:
  Message statistics:
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:                1          2
    Keepalives:            71         71
    Route Refresh:          0          0
    Discarded:              0          0
    Total:                 73         74
  Route statistics:
    Advertised:             0
    Received:              10
    Accepted:              10
show bgp-route-summary
Use the show bgp-route-summary command to view all the route details of a BGP router.
The following configuration is a sample output of the show bgp-route-summary command:
route-details
Table afi:AFI_IP safi:SAFI_UNICAST
Destination: 5, Path: 5
show bgp-routes
Use the show bgp-routes command to view all the routes for a BGP router.
The following configuration is a sample output of the show bgp-routes command:
bgp-route
   Network              Next Hop             AS_PATH       Age        Attrs
*> 209.165.200.235/24   209.165.200.250      60000         00:36:39   [{Origin: i} {Med: 0}]
*> 209.165.200.227/32   209.165.200.232                    00:36:44   [{Origin: e} {LocalPref: 220} {Med: 3220}]
*> 209.165.200.247/24   209.165.200.250      60000         00:36:39   [{Origin: i} {Med: 0}]
*> 209.165.200.251/24   209.165.200.250      60000         00:36:39   [{Origin: i} {Med: 0}]
*> 209.165.200.252/32   209.165.200.232                    00:36:44   [{Origin: e} {LocalPref: 220} {Med: 3220}]
*> 209.165.200.235/24   209.165.200.250      60000          00:37:02   [{Origin: i} {Med: 0}]
*> 209.165.200.227/32   209.165.200.246                     00:37:11   [{Origin: e} {LocalPref: 220} {Med: 3220}]
*> 209.165.200.228/24   209.165.200.234      60000          00:37:02   [{Origin: i} {Med: 0}]
*> 209.165.200.229/24   209.165.200.234      60000          00:37:02   [{Origin: i} {Med: 0}]
*> 209.165.200.230/32   209.165.200.246                     00:37:11   [{Origin: e} {LocalPref: 220} {Med: 3220}]
KPIs
The following KPIs are supported for this feature:
Table 10. Statistics for Dynamic Routing by Using BGP
KPI Name
Type
Description/Formula
Label
bgp_outgoing_route
request_total
Counter
Total number of outgoing routes.
local_pref, med, next_hope, service_IP
bgp_outgoing_failedroute
request_total
Counter
Total number of failed outgoing routes.
bgp_incoming_route
request_total
Counter
Total number of incoming routes.
interface, next_hope, service_IP
bgp_incoming_failedroute
request_total
Counter
Total number of failed incoming routes.
bgp_peers_total
Counter
Total number of peers added.
peer_ip, as_path
bgp_failed_peerstotal
Counter
Total number of failed peers.
peer_ip, as_path, error
IPAM
This section describes IP Address Management (IPAM) at the rack level.
Figure 10. IPAM
During UPF registration, active IPAM instance reserves four address-ranges per UPF per DNN.
  • Range-1: Active cluster, nodemgr-1
  • Range-2: Active cluster, nodemgr-2
  • Range-3: Standby cluster, nodemgr-1
  • Range-4: Standby cluster, nodemgr-2
During normal operation, Rack-1 handles UPF-register/release, address-allocate/release for subscribers coming up in GR-instance-1.
If Rack-2 goes down, Rack-1 gets role-change trigger for GR-Instance-2.
  • IPAM in Rack-1, restores the content of GR-Instance-2 from local-cache-pod (which was already synced)
  • IPAM in Rack-1 handles UPF-Register/Release and address-allocate/release for subscribers coming up with GR-Instance-2 using the restored content in addition to handling GR-Instance-1.
Each IPAM pool is associated to a GR-Instance, with the following:
  • Pool name is unique across all the instances.
  • Address-ranges are unique within VRF and across all the instances.
The same pool configuration must be configured in both the active and standby SMF clusters of a particular instance.
During address-allocation, active instance assign free-IP from reserved address-range for the UPF.
Incase new address-ranges is not available, change ownership of standby’s address-range to current active instance and continue assigning address-ranges from it.
Configuring IPAM
The following section provides IPAM configuraton examples.
SMF-1 Example
The following is a configuration example for SMF-1:
ipam
 instance 1
  address-pool pool-1
  vrf-name ISP
   tags
   dnn dnn-1
  exit
  ipv4
    address-range 209.165.201.1 209.165.201.31
 exit
instance 2
 address-pool pool-2
  vrf-name ISP
  tags
   dnn dnn-2
  exit
  ipv4
    address-range 209.165.202.129 209.165.202.159
 exit
exit
SMF-2 Example
The following is a configuration example for SMF-2:
ipam
 instance 1
 address-pool pool-1
  vrf-name ISP
  tags
   dnn dnn-1
  exit
  ipv4
 exit
 instance 2
 address-pool pool-2
  vrf-name ISP
   tags
   dnn dnn-2
  exit
  ipv4
 exit
exit
Geo Replication
The Geo-replication is used in inter-rack communication and for POD or VIP or BFD monitoring within the rack. The Geographic Redundancy comprises with the following:
  • Two instances of Geo pods are running for each rack.
  • Two Geo pods functions in Active-Standby mode.
  • Each Geo pod instance is spawned on a different Proto node or VM.
  • Geo pod running on the Proto node or VM having VIP is Active Geo pod.
  • In the event of Active Geo pod restart, VIPs get switched to other Proto node or VM and Standby Geo pod running on the other Proto node/VM becomes active.
  • Geo pod uses host networking mode (similar to UDP-Proxy).
    • Internal: VIP for Inter-POD communication (within the rack)
    • External: VIP for Inter-rack Geo pod communication
      It configures only on Proto Nodes on the L2 Subnet. It's used to communicate across the racks. This node has external connectivity to other Rack.
  • Logical-NF-InstanceID must be configured same for both SMFs in GR-Pair.
  • For KeepAliveD monitoring:
    • Geo pod uses base port as: 15000+(Logical-NF-InstanceID * 32) + 4
      Geo pod base port must be different than BGP speaker pod port.
      • The default port (without logical SMF) as: 15004
      • For Logical SMF configured with logical-nf-instance-id as 1, and then the port as: 15036
    • UDP-Proxy pod uses base port as: 28000+Logical-NF-InstanceID.
      • The default port (without logical SMF) as: 28000
      • For Logical SMF configured with logical-nf-instance-id as 1, and then the port as: 28001
    • BGPSpeaker-pod uses default base port as: 20000+(Logical-NF-InstanceID * 32)+4.
      • The default port (without logical SMF) as: 20004
      • For logically SMF configured with logical-nf-instance-id as 1, and then the port as: 20036
Note
Only ETCD and cache pod data gets replicated to the standby rack.
Configuring ETCD/Cachepod Replication
Endpoints must be configured under an instance. Two Geo-Redundancy pods are needed on each rack. You should also configure VIP for internal and external Geo interface for ETCD/CachePod replication.
instance instance-id  instance_id endpoint geo interface { geo-internal | geo-external } vip-ip { vip_ip_address } vip-port { vip_port_number }
config
 endpoint geo
  replicas replica_id
  nodes node_id
  interface geo-internal
   vip-ip vip_ip_address vip-port vip_port_number
  exit
  interface geo-external
  exit
exit
exit
NOTES:
  • instance instance-id instance_id —Specify GR instance ID. One instance ID for local rack and other for another rack.
  • vip-ip vip_ip_address —Specify VIP IP address for Internal/External Geo interface.
  • vip-port vip_port_number —Specify VIP port number.
  • internal base-port start base_port_number —Specify port range only if logical NF is configured.
Example
endpoint geo
  replicas 1
  nodes 2
  internal base-port start 25000
   vip-ip 209.165.201.8 vip-port 7001
  exit
   vip-ip 209.165.201.8 vip-port 7002
  exit
exit
Geo Monitoring
This section describes Geo monitoring.
Pod Monitoring
To configure pod monitoring and failover thresholds in the inter-rack setup, use the following sample configuration. The geo pod monitors the configured pod name.
config
 geomonitor
  podmonitor pods pod_name
   retryCount value
   retryInterval interval_value
   retryFailOverInterval failover_interval
   failedReplicaPercent percent_value
  exit
 exit
NOTES:
  • pods pod_name —Specify the name of the pod to be monitored. For example, Cache-pod, rest-ep, and so on.
  • retryCount value —Specify the retry counter value to retry if pod fails to ping after which pod is marked as down. It should be an integer in the range of 1-10.
  • retryInterval interval_value —Specify the retry interval in milliseconds if the pod successfully pings. It should be an integer in the range of 200-10000.
  • retryFailOverInterval failover_interval —Specify the retry interval in milliseconds if the pod fails to ping. It should be an integer in the range of 200-10000.
  • failedReplicaPercent percent_value —Specify the percent value of failed replica after which the inter-rack redundancy failover is triggered. It should be an integer in the range of 10-100.
The following is an example configuration.
geomonitor podmonitor pods cache-pod
 retryCount 3
 retryInterval 5
 retryFailOverInterval 1
 failedReplicaPercent 40
exit
Remote Cluster Monitoring
Remote cluster monitoring auto corrects roles (it becomes self-primary, when the remote rack is in STANDBY_ERROR state) for uninterrupted traffic flow of traffic. However, this auto role correction gets done only for specific roles.
To configure this feature, use the following sample configuration:
config
    geomonitor
        remoteclustermonitor
            retryCount value
            end
NOTES:
  • retryCount value —Specify the retry count before making the current rack PRIMARY. It should be an integer in the range of 1-10. The default value is 3.
  • retryInterval interval_value —Specify the retry interval in the count of milliseconds, after which the remote rack status gets fetched. It should be an integer in the range of 200-50000. The default value is 3000.
geomonitor remoteclustermonitor
retryCount 3
retryInterval 3000
Traffic Monitoring
The following command is used to monitor the traffic.
config
 geomonitor
  trafficMonitor
   thresholdCount value
   thresholdInterval interval_value
  exit
 exit
NOTES:
  • thresholdCount value —It specifies the number of calls received for standby instance. It should be an integer in the range of 0-10000. Default value is 0. Both UDP-proxy and REST-EP must be considered for the counter value.
  • thresholdInterval interval_value —It specifies the maximum duration to hit the threshold count value in ms. It should be an integer in the range of 100-10000. Default value is 3000.
geomonitor trafficmonitor
thresholdCount 3
thresholdInterval 3000
Geo Redundancy Strengthening
The geo redundancy strengthening activity addresses multiple issues stemming from different scenarios such as the following:
  • Hardware failure
  • Network failure
  • Process failure
  • Abnormal conditions
  • Code walkthroughs
These failed scenarios impact the functionality of the geo-replication pod, causing the system malfunction. To address these issues, it is necessary to strengthen various areas of the geo-replication pod.
How It Works
The following areas of the enhanced geo replication pod are part of the geo redundancy strengthening feature:
  • The system makes GRPC replication and admin stream available when it becomes healthy.
  • The system ensures that both instances have the correct role in all scenarios.
  • The system maintains data replication between the geo replication pod of rack-1 and rack-2 in sync.
  • The system verifies that checksum and checkpoint data is always correct on both racks to ensure data integrity.
  • The system provides a mechanism for users to sync replication data, when it becomes out of sync, and requires manual intervention.
    To know more about the command, see the Geo Replication Pull Data section.
  • The system ensures that Geo VIP movement between geo replication pods does not impact functionality.
  • The system takes measures to prevent failures of dependent processes from affecting its functionality for users.
Limitations
Some of the known limitations of this feature are as follows:
  • Replication Data Loss: It can occur when a switchover occurs because both cache pods are down on the partner rack.
OAM Support
This section describes operations, administration, and maintenance support for this feature.
KPI Support
The following set of statistics supports the geo redundancy strengthening and securing feature:
  1. KPI Name: geo_replication_finalpull_total
    The following table lists geo_replication_finalpull_total KPI details.
    Description
    Functionality
    Label Names
    Possible Values
    This KPI displays the total number of geo replications present in the final pull of the feature messages.
    geo_replication_finalpull_total, it is the functionality output.
    MessageType
    It is a request or a response message type.
    TotalTimeTaken
    It is the total time taken to process the request.
    GRInstanceNumber
    It is the GR Instance ID in number from the list of the following:
    • Instance.1
    • Instance.2
BFD Monitoring
Bidirectional Forwarding Detection (BFD) protocol is used for Faster Network Failure Detection along with BGP. Whenever connectivity between BGP peering fails with cluster (NF), failover is triggered to minimize traffic failure impact.
config
  router bgp as
    bfd interval interval min_rx min_rx multiplier multiplier
    loopbackPort loopbackPort loopbackBFDPort loopbackBFDPort
  interface interface_id  (BGP on non-bonded interface <-- loopbackEth)
    bondingInterface bondingInterface  (leaf6-nic)
    neighbor neighbor_ip_address remote-as remote_as fail-over fail_over_type
  exit
    bondingInterface bondingInterface  (leaf7-nic)
    neighbor bondingInterface remote-as remote_as fail-over fail_over_type
  exit
  policy-name policy_name
   as-path-set as_path_set
   gateWay gateWay_address
   interface interface_id_source
   ip-prefix ip_prefix_value
   isStaticRoute false | true
   mask-range mask_range
   modifySourceIp false | true
  exit
exit
NOTES:
  • bgp as —Specify the Autonomous System (AS) path set.
  • bfd —Specify BFD configuration.
    • interval interval —Specify BFD interval in milliseconds.
    • min_rx min_rx —Specify BFD minimum RX in milliseconds.
    • multiplier multiplier —Specify BFD interval multiplier.
  • interface interface_id —Specify BGP local interface.
    • bondingInterface bondingInterface —Specify linked bonding interface.
    • neighbor neighbor_ip_address —Specify IP address of neighbor.
      • fail-over fail_over_type —Specify failover type.
      • remote-as remote_as —Specify Autonomous System (AS) number of BGP neighbor.
  • learnDefaultRoute —Learn default route and add it in kernel space
  • loopbackBFDPort loopbackBFDPort —Specify BFD local port.
  • loopbackPort loopbackPort —Specify BGP local port.
  • policy-name policy_name —Specify policy name.
    • as-path-set as_path_set —Specify Autonomous System (AS) path set.
    • gateWay gateWay_address —Specify gateway address.
    • interface interface_id_source —Specify interface to set as source IP.
    • ip-prefix ip_prefix_value —Specify IP prefix value.
    • isStaticRoute false | true —Specify whether to add static route in kernel space. Default value is false.
    • mask-range mask_range —Specify mask range.
    • modifySourceIp false | true —Modify source IP of the incoming route. Default value is false.
      true: This option is used for non-UDP related VIPs. Source IP of the given interface is used as Source IP while sending out packets from SMF.
      false: This option is used for all UDP related VIPs. VIP is used as Source IP while sending out packets from SMF.
Example
Following are configuration examples:
router bgp 65000
  bfd interval 250000 min_rx 250000 multiplier 3
  loopbackPort 179 loopbackBFDPort 3784
interface ens160 (BGP on non-bonded interface <-- loopbackEth)
  bondingInterface enp216s0f0 (leaf6-nic)
  bondingInterface enp216s0f1 (leaf6-nic)
  neighbor leaf6-ip remote-as 60000 fail-over bfd
exit
interface ens192 (BGP on non-bonded interface <-- loopbackEth)
  bondingInterface enp94s0f1 (leaf7-nic)
  bondingInterface enp94s0f0 (leaf7-nic)
  neighbor leaf7-ip remote-as 60000 fail-over bfd
exit
policy-name allow-all ip-prefix 209.165.201.30/0 mask-range 0...32
exit
BGP router configuration with BFD
show running-config router
router bgp 65142
 learnDefaultRoute false
 interface enp94s0f0.3921
  neighbor 209.165.201.24 remote-as 65141 fail-over bfd
 exit
 interface enp94s0f1.3922
  neighbor 209.165.202.24 remote-as 65141 fail-over bfd
Show BFD status of neighbor
show bfd-neigbor
status-details
----- bgpspeaker-pod-1----
Peer             Status
209.165.202.142  STATE_DOWN
----- bgpspeaker-pod-2----
Peer             Status
209.165.202.142  STATE_UP
policy-name allow-n11 ip-prefix 209.165.200.225/54 mask-range 25..32 interface bd1.n11.2271 modifySourceIp true isStaticRoute true gateWay 209.165.201.14
In the above example, modifySourceIp is set to true.
  • AMF subnet: 209.165.200.225/54
    N11 Svc Bonded Physical Interface: bd1.n11.2271 (IP address - 209.165.201.23)
    N11 Svc Bonded VxLAN Anycast GW: 209.165.201.14
    N11 VIP Address: 209.165.201.7
  • SMF Outbound Packet (will have source IP as 209.165.201.23)
    Inbound Packet to SMF (will have destination IP as 209.165.201.7)
policy-name allow-n4-1 ip-prefix 209.165.201.17/41 mask-range 24..32 interface bd2.n4.2274 gateWay 209.165.201.17
In the above example, modifySourceIp is set to false (default).
  • UPF N4 Interface IP: 209.165.201.17/41
    N4 Svc Bonded Physical Interface: bd2.n4.2274 (IP address - 209.165.201.23)
    N4 Svc Bonded VxLAN Anycast GW: 209.165.201.17
    N4 VIP Address: 209.165.201.14
  • SMF Outbound Packet (will have source IP as 209.165.201.14)
    Inbound Packet to SMF (will have destination IP as 209.165.201.14)
CDL GR Deployment
By default, CDL is deployed with two replicas for db-ep, 1 slot map (2 replicas per map), and 1 index map (2 replicas per map).
Note
It is recommended to configure the CDL container in YANG.
Prerequisites for CDL GR
Before deploying the CDL GR, user must configure the following:
  • CDL Session Database and define the base configuration.
  • Kafka for CDL.
  • Zookeeper for CDL.
CDL Instance Awareness and Replication
In CDL, along with existing GR related parameters, GR instance awareness must be enabled using a feature flag on all the racks. Also, the mapping of system-id to slice names should also be provided for this feature to work on all the racks.
The CDL is also equipped with Geo Replication (GR) failover notifications, which can notify the timer expiry of session data and bulk notifications to the currently active rack. The CDL uses Border Gateway Protocol (BGP) through App-Infra for the GR failover notifications.
The CDL subscribes to the key value on both the GR racks. The App-Infra sends notifications to the CDL when there is any change in these key values. A key value indicates the state of the CDL System ID or the GR instance. The GR instance is mapped to the CDL slices using the CDL system ID or the GR instance ID in the key.
The system ID is mandatory on both the racks. The GR instance ID in the NF configuration must match the CDL system ID.
CDL has instance-specific data slices. It also allows users to configure instance-specific slice information at the time of bringing up.
  • CDL notifies the data on expiry or upon bulk notification request from the active slices.
  • CDL determines the active instance based on the notification from app-infra memory-cache.
  • CDL slice is a partition within a CDL instance to store a different kind of data. In this case, NF stores a different instance of data.
Note
CDL slice name should match with the slice-name configured in GR.
Configuring CDL Instance Awareness
The following command is used to configure CDL instance awareness.
config
cdl
 datastore datastore_session_name
   features
     instance-aware-notification
       enable [ true | false ]
       system-id system_id
        slice-names slice_names
    end
NOTES:
  • datastore datastore_session_name —Specify the datastore name.
  • enable [ true | false ] —Enables the GR instance state check for slices.
  • system-id system_id —Mapping of system ID to slice name.
  • slice-names slice_names —Specify the list of slice names associated with the system ID. CDL slice name should match with the slice-name configured in GR.
Example
cdl datastore session
 features instance-aware-notification enable true
 features instance-aware-notification system-id 1
  slice-names [ sgw1 smf1 ]
 exit
 features instance-aware-notification system-id 2
  slice-names [ sgw2 smf2 ]
 end
Configuring CDL Replication
This section describes CDL replication configuration.
  1. Configure Rack-1 CDL HA system without any Geo-HA-related configuration parameters.
    1. Set the System ID as 1 in the configuration.
    2. Set the slot map/replica and index map/replica and Kafka replica as per requirements.
    The following is a sample configuration:
    cdl system-id 1
    cdl node-type session
    endpoint replica replica_id
      slot map 4
      slot replica 2
      index map 1
      index replica 2
    cdl kafka replica 2
  1. Configure external IPs on Rack-1 for Rack-2 to Rack-1 communication.
    1. Enable geo-replication on Rack-1 and configure the remote Rack as 2 for Rack-1.
      cdl enable-geo-replication true
    2. Configure the external IP for CDL endpoint to be accessed by Rack-2.
      cdl datastore session endpoint external-ip site-1_external_ip
    3. Configure the external IP and port for all Kafka replicas.
      So, if two replicas (default) are configured for Kafka, user need to provide two different <ip>+<port> pairs.
      cdl kafka external-ip site-1_external_ip port1 cdl kafka external-ip site-1_external_ip port2
  2. Add remote rack information on Rack-2.
    • Remote rack cdl-ep configuration on Rack-2:
      cdl remote-site 1 db-endpoint host site-1_cdl_ep_ip
      cdl remote-site 1 db-endpoint port site-1_cdl_ep_port
      (Port Example: 8882)
    • Remote rack Kafka configuration on Rack-2:
      cdl remote-site 1 kafka-server site-1_kafka1_ip site-1_kafka1_port
      cdl remote-site 1 kafka-server site-1_kafka2_ip site-1_kafka2_port
    • Direct the session datastore configuration to remote Rack-2 configuration:
      cdl datastore session geo-remote-site 1
    • (Optional) Configure the SSL certificates to establish a secure connection with remote rack on Rack-1. All the certificates are in multi-line raw text format. If the certificates are not valid, the server continues with non-secure connection.
      cdl ssl-config certs site-2_external_ip ssl-key <ssl_key>
      cdl ssl-config certs site-2_external_ip ssl-crt <ssl_crt>
  3. Commit GR configuration on Rack-2:
    • Commit the configuration and let the pods be deployed on Rack-2.
    • Verify all pods are in running state.
    • Once both the racks are deployed, verify that the mirror maker pods on both racks are running and in ready state.
Examples
HA:
cdl node-type db-ims
 endpoint replica 2
 index map    1
 index write-factor 1
 slot replica 2
 slot map     4
 slot write-factor 1
exit
k8 label cdl-layer key smi.cisco.com/node-type value smf-ims-session
Rack-1:
cdl system-id          1
cdl zookeeper replica 1
cdl remote-site 2
 db-endpoint host 209.165.201.21 >> Rack-2 external CDL IP
 db-endpoint port 8882
 kafka-server 209.165.201.21 10092 >> Rack-2 external CDL IP
 exit
exit
cdl label-config session
 endpoint key smi.cisco.com/node-type1
 endpoint value smf-cdl
 slot map 1
  value smf-cdl
 exit
 index map 1
  value smf-cdl
 exit
exit
cdl logging default-log-level debug
 geo-remote-site [ 2 ]
 slice-names     [ 1 2 ]
 endpoint cpu-request 100
 endpoint replica 2
 endpoint external-ip 209.165.201.25 >> Rack-1 external CDL IP
 endpoint external-port 8882
 index cpu-request 100
 index replica 2
 index map   1
 slot cpu-request 100
 slot replica 2
 slot map    1
exit
cdl kafka replica 1
cdl kafka label-config key smi.cisco.com/node-type1
cdl kafka label-config value smf-cdl
cdl kafka external-ip 209.165.201.25 10092 >> Rack-1 external CDL IP
Rack-2:
cdl system-id          2
cdl remote-site 1
 db-endpoint host 209.165.201.25 >> Rack-1 external CDL IP
 kafka-server 209.165.201.25 10092 >> Rack-1 external CDL IP
 exit
exit
 endpoint key smi.cisco.com/node-type12
 slot map 1
  value smf-cdl
 exit
 index map 1
  value smf-cdl
 exit
exit
 geo-remote-site [ 1 ]
 slice-names     [ 1 2 ]
 endpoint replica 2
 endpoint external-ip 209.165.201.21 >> Rack-2 external CDL IP
 index replica 2
 index map   1
 slot replica 2
 slot map    1
exit
cdl kafka replica 1
cdl kafka label-config key smi.cisco.com/node-type12
cdl kafka external-ip 209.165.201.21 10092 >> Rack-2 external CDL IP
Lawful Intercept
The Lawful Intercept (LI) feature enables law enforcement agencies (LEAs) to intercept subscriber communications. The LI functionality provides the network operator the capability to intercept control and data messages of the targeted mobile users. To invoke this support, the LEA requests the network operator to start the interception of a particular mobile user. Legal approvals support this request.
  1. Lawful Intercept (LI) tap should be configured/enabled on all the racks. If LI configuration fails on one rack, LEA should re-configure it so that for a given subscriber tap is enabled on all the racks.
    Note
    LI tap configuration is not synchronized across racks.
    Hence, LI tap configuration is mandatory on all the racks.
    For more information on LI tap configuration, contact your Cisco Technical Representative.
  2. GR instance awareness is applicable for lawful-intercept src-address only.
    Example:
    lawful-intercept instance 1 src-addr 209.165.200.225
    OR
    lawful-intercept
      instance 1
  3. show commands are not instance-aware. It shows all the taps configured in a given cluster.
    For more information on LI show commands, contact your Cisco Technical Representative.
  4. In case all GR instances are in Standby state in a cluster and active LI tap fails with CLI message Rack is in standby mode, Active Tap is not allowed. Try camp on, configure camp-on tap for the same subscriber.
RADIUS Configuration
NAS-IP and NAS-Identifier is instance-aware. You can configure different NAS-IP and NAS-Identifier per instance-id in profile-radius configuration. Existing non-instance based NAS-IP and NAS-Identifier configuration is used as default nas-ip and default nas-id for local instance of the rack.
Example
profile radius
 attribute
  instance 1
   nas-ip 209.165.200.225  --> Instance-1 specific NAS-IP, used for common AUTH & ACCT
   nas-identifier  smf1    --> Instance-1 specific NAS-Identifier, used for common AUTH & ACCT
  exit
  instance 2
   nas-ip 209.165.200.230  --> Instance-2 specific NAS-IP, used for common AUTH & ACCT
   nas-identifier  smf2    --> Instance-2 specific NAS-Identifier, used for common AUTH & ACCT
  exit
 exit
 accounting
  attribute
   instance 1
    nas-ip 209.165.200.225  --> Instance-1 specific NAS-IP, used for common ACCT
    nas-identifier  smf1    --> Instance-1 specific NAS-Identifier , used for common ACCT
   exit
   instance 2
    nas-ip 209.165.200.230  --> Instance-2 specific NAS-IP, used for common ACCT
    nas-identifier  smf2    --> Instance-2 specific NAS-Identifier , used for common ACCT
   exit
  exit
 exit
 server-group g1
  attribute
   instance 1
    nas-ip 209.165.200.225  --> Instance-1 specific NAS-IP, used for server-group <g1> AUTH & ACCT
    nas-identifier  smf1    --> Instance-1 specific NAS-ID, used for server-group <g1> Auth &Acct
   exit
   instance 2
    nas-ip 209.165.200.230  --> Instance-2 specific NAS-IP, used for server-group <g1> AUTH & ACCT
    nas-identifier  smf2    --> Instance-2 specific NAS-ID,used for server-group <g1>AUTH&ACCT
   exit
  exit
  accounting
   attribute
    instance 1
     nas-ip 209.165.200.225 --> Instance-1 specific NAS-IP, used for server-group <g1> ACCT
     nas-identifier  smf1   --> Instance-1 specific NAS-ID, used for server-group <g1> ACCT
    exit
    instance 2
     nas-ip 209.165.200.230 --> Instance-2 specific NAS-IP, used for server-group <g1> ACCT
     nas-identifier  smf2   --> Instance-2 specific NAS-ID, used for server-group <g1> ACCT
    exit
   exit
  exit
 exit
exit
Since endpoint pod configuration is moved under specific instance, Radius Disconnect-Request VIP is also instance-aware.
 endpoint radius
  replicas 1
  interface coa-nas
   vip-ip 209.165.202.130 vip-port 3799  --> Instance-1 specific Radius-Disconnect-Msg-VIP & PORT
  exit
 exit
exit
 endpoint radius
  replicas 1
  interface coa-nas
   vip-ip 209.165.202.129 vip-port 3799  --> Instance-2 specific Radius-Disconnect-Msg-VIP & PORT
  exit
 exit
exit
Considering config commit as reference. The same checklist is also applicable for other upgrade scenarios.
Checklist
Note
Do not perform cluster sync on both racks (Rack-1 and Rack-2) at the same time. Trigger manual switchover on Rack-1 before proceeding with Rack-1 upgrade.
  • Do not perform config commits on both racks at the same time. Perform config commit on each rack separately.
  • Before to the config commit procedure on Rack-1, initiate the CLI-based switchover on Rack-1 and make sure that Rack-2 is having Primary ownership for both the instances (instance-id 1 and instance-id 2).
  • Perform config commit on Rack-1. Wait for the successful config commit, PODs restart, and are back in running state to fetch the latest helm charts (if applicable).
  • Revert the role of Rack-1 to be Primary (Switch/Reset roles on both racks).
  • Verify that the available roles of Rack-1 (Primary) and Rack-2 (Standby) are on the expected status.
  • Repeat the preceding checklist for Rack-2.
Software Upgrade
Upgrading the Rack-1, when the GR is Enabled:
  1. Verify that the available roles of both instances on Rack-1 are in PRIMARY/STANDBY.
    show role instance-id 1
    result "PRIMARY"
    show role instance-id 2
    result "STANDBY"
  2. Initiate switch role for both instances on Rack-1 to STANDBY with failback-interval of 0 seconds. This step transitions the roles from PRIMARY/STANDBY to STANDBY_ERROR/STANDBY_ERROR.
    geo switch-role instance-id 1 role standby [failback-interval 0]
    geo switch-role instance-id 2 role standby [failback-interval 0]
    Note
    • Heartbeat between both the racks must be successful.
    • The CLI failback-interval is an optional command to provide backward compatibility of upgrades between releases. The value of failback-interval is 0. It is deprecated from current release and will be discontinued from the subsequent releases.
  3. Verify that the available roles of both instances have moved to STANDBY_ERROR on Rack-1.
    result "STANDBY_ERROR"
  4. Verify that the available roles of both instances have moved to PRIMARY on Rack-2.
    result "PRIMARY"
    result "PRIMARY"
  5. Perform rolling upgrade (or) non-graceful upgrade using system mode shutdown/running as per the requirement on Rack-1. To allow replication to finish, give a 5-minute gap between the GR switchover and SMF shutdown.
  6. Perform the following steps post completion of the upgrade procedure. Perform health check on Rack-1 and ensure the PODs have come up and Rack-1 is healthy.
  7. Verify that the available roles of both instances remain in STANDBY_ERROR mode on Rack-1.
  8. Initiate reset role for both instances on Rack-1 to STANDBY. This step transitions the roles from STANDBY_ERROR/STANDBY_ERROR to STANDBY/STANDBY.
    geo reset-role instance-id 1 role standby
    geo reset-role instance-id 2 role standby
  9. Verify that the roles of both instances have moved to STANDBY on Rack-1.
    result "STANDBY"
    result "STANDBY"
  10. Initiate switch role for instance-id 1 on Rack-2 to STANDBY. This step transitions the available roles of Rack-2 from PRIMARY/PRIMARY to STANDBY_ERROR/PRIMARY and Rack-1 from STANDBY/STANDBY to PRIMARY/STANDBY.
  11. Verify that the available roles of the instances on Rack-2 are in STANDBY_ERROR/PRIMARY.
    result "PRIMARY"
  12. Verify that the available roles of both instances on Rack-1 are in PRIMARY/STANDBY.
     result "PRIMARY"
     result "STANDBY"
  13. Initiate reset role for instance-id 1 on Rack-2 to STANDBY. This step transitions the roles of Rack-2 from STANDBY_ERROR/PRIMARY to STANDBY/PRIMARY.
  14. Verify that the available roles of both instances on Rack-2 are in STANDBY/PRIMARY.
    result "STANDBY"
     result "PRIMARY"
Upgrading the Rack-2, when the GR is Enabled:
  1. Verify that the available roles of both instances on Rack-2 are in STANDBY/PRIMARY.
    result "STANDBY"
    result "PRIMARY"
  2. Initiate switch role for both instances on Rack-2 to STANDBY with failback-interval of 0 seconds. This step transitions the roles from STANDBY/PRIMARY to STANDBY_ERROR/STANDBY_ERROR.
  3. Verify that the available roles of both instances move to STANDBY_ERROR on Rack-2.
  4. Verify that the available roles of both instances move to PRIMARY on Rack-1.
     result "PRIMARY"
     result "PRIMARY"
  5. Perform rolling upgrade (or) non-graceful upgrade via system mode shutdown/running as per the requirement on Rack-2.
  6. Perform the subsequent steps post completion of the upgrade procedure. Perform the health check on Rack-2 and ensure the PODs have come up and Rack-2 is healthy.
  7. Verify that the available roles of both the instances remain in STANDBY_ERROR on Rack-2.
  8. Initiate reset role for both instances on Rack-2 to STANDBY. This step transitions the roles from STANDBY_ERROR/STANDBY_ERROR to STANDBY/STANDBY.
  9. Verify that the available roles of both instances move to STANDBY on Rack-2.
    result "STANDBY"
    result "STANDBY"
  10. Initiate switch role for instance-id 2 on Rack-1 to STANDBY. This step transitions the available roles of Rack-1 from PRIMARY/PRIMARY to PRIMARY/STANDBY_ERROR and Rack-2 from STANDBY/STANDBY to STANDBY/PRIMARY.
  11. Verify that the available roles of both instances on Rack-1 are in PRIMARY/STANDBY_ERROR.
    result "PRIMARY"
  12. Verify that the available roles of both instances on Rack-2 are in STANDBY/PRIMARY.
    result "STANDBY"
    result "PRIMARY"
  13. Initiate reset role for instance-id 2 on Rack-1 to STANDBY. This step transitions the roles of Rack-1 from PRIMARY/STANDBY_ERROR to PRIMARY/STANDBY.
  14. Verify that the available roles of both the instances on Rack-1 are in PRIMARY/STANDBY.
    result "PRIMARY"
    result "STANDBY"
GR CLI
The following section provides information on GR CLI based commands.
The following sample setup configures the Geo Replication Pull Data. These commands help and perform the replication data sync activities, during the event of any malfunction scenario. To transition to the GR role and minimize any replication data mismatch on the system, you can initiate the following commands to synchronize the data across all accessible racks:
geo replication-pull instance-id gr_instanceId
NOTES:
  • geo replication-pull —It pulls the replication data from the peer rack and syncs it with the local rack.
  • instance-id gr_instanceId —Specify the GR Instance ID.
Geo Reset Role
To reset the GR instance role (for example, roles from STANDBY_ERROR to STANDBY to PRIMARY), use the following sample commands:
geo reset-role role role instance-id gr_instanceId
NOTES:
  • role role —Specify the new role for the given rack.
    The role can be PRIMARY or STANDBY.
Important
The command geo reset-role triggers change in the role for the given instance on the local rack. The remote rack does not receive any message for the same command. It is only possible to change the role for the given instance ID from STANDBY_ERROR to STANDBY and STANDBY to PRIMARY. Another role change is not possible.
Geo Switch Role
To switch the GR role, initiate the command on the primary rack (for example, role PRIMARY to STANDBY only), and use the following command.
geo switch-role { role primary | standby  instance-id gr_instanceId [ failback-interval  failback_interval ] }
NOTES:
    The roles can be primary or standby . It’s mandatory to trigger manual switchover from primary role for a specific GR instance ID.
  • failback-interval is an optional command to provide backward compatibility of upgrades between releases. The recommended value of failback-interval is 0.
Important
geo switch-role command triggers manual failover from one rack to another rack for specific instance ID. The rack which triggers the failover changes from the PRIMARY role to the STANDBY_ERROR role. In between, the rack which triggers the failover, sends a failover (Trigger GR) message to another rack. The other rack which receives the failover message changes from the STANDBY role to the PRIMARY role.
Note
failback-interval is deprecated from current release and will be discontinued from the subsequent releases.
Troubleshooting
This section describes about various applicable troubleshooting scenarios.
show/clear Commands
This section describes show/clear commands that help in debugging issues.
clear subscriber
To clear gr-instance aware subscriber, use the following command:
clear subscriber all gr-instance gr_instanceId
Note
gr-instance is optional parameter. If gr-instance is not specified, show subscriber all considers the local instance-id of that rack.
Example
The following is a configuration example.
clear subscriber all gr-instance 1
result
ClearSubscriber Request submitted
show BFD Status
To view the BFD status of neighbors, use the following command:
show bfd-neighbor
Example
The following is a list of few configuration examples:
show bfd-neighbor
status-details
-----example-bgp-ep-1 ----
Peer             Status
-----example-bgp-ep-2 ----
Peer             Status
show bfd-neigbor
status-details
Peer             Status
 209.165.202.131
Peer             Status
 209.165.202.131   STATE_UP
show BGP Global
To view BGP global configuration, use the following command:
show bgp-global
Example
show bgp-global
global-details
AS:        65000
Router-ID: 209.165.202.149
Listening Port: 179, Addresses: 209.165.202.149
AS:        65000
Router-ID: 209.165.202.148
Listening Port: 179, Addresses: 209.165.202.148
show bgp-global
global-details
AS:        65061
Router-ID: 209.165.202.132
Listening Port: 179, Addresses: 209.165.202.132
show bgp kernel route
To view BGP kernel configured routes, use the following command:
show bgp-kernel-route kernel-route
Example
kernel-route
 209.165.202.133    209.165.202.148   209.165.202.142
 209.165.202.134    209.165.202.148   209.165.202.142
kernel-route
 209.165.202.135    209.165.202.132    209.165.202.131
show bgp neighbors
To view BGP neighbors status, use the following command
show bgp-neighbors neighbor-details
show bgp-neighbors ip ip_address neighbor-details
Example
209.165.202.142 60000 00:25:06 Establ      |        3         3
209.165.202.142 60000   never Idle        |        0         0
show bgp-neighbors ip 209.165.202.142 neighbor-details
BGP neighbor is 209.165.202.142, remote AS 60000
  BGP version 4, remote router ID unknown
  BGP state = ACTIVE
  Hold time is 0, keepalive interval is 0 seconds
    multiprotocol:
  Message statistics:
                         Sent       Rcvd
    Opens:                130          0
    Notifications:          0          0
    Updates:                0          0
    Keepalives:             0          0
    Route Refresh:          0          0
    Discarded:              0          0
    Total:                130          0
  Route statistics:
    Advertised:             0
    Received:               0
    Accepted:               0
  BGP version 4, remote router ID 209.165.202.136
  BGP state = ESTABLISHED, up for 00:25:20
    multiprotocol:
  Message statistics:
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:                1          1
    Keepalives:            51         51
    Route Refresh:          0          0
    Discarded:              0          0
    Total:                 53         53
  Route statistics:
    Advertised:             0
    Received:               3
    Accepted:               3
show bgp route summary
To view BGP route summary, use the following command:
Example
route-details
Destination: 2, Path: 2
show BGP Routes
To view BGP routes information, use the following command:
show bgp-routes
Example
show bgp-routes
bgp-route
*> 209.165.202.133/24   209.165.202.142        60000      00:25:55   [{Origin: i} {Med: 0}]
*> 209.165.200.225/32   209.165.202.148                   00:26:00   [{Origin: e} {LocalPref: 100} {Med: 600}]
*> 209.165.202.134/24   209.165.202.142        60000      00:25:55   [{Origin: i} {Med: 0}]
*> 209.165.202.140/24   209.165.202.142        60000      00:25:55   [{Origin: i} {Med: 0}]
*> 209.165.202.146/32   209.165.202.148                   00:26:00   [{Origin: e} {LocalPref: 100} {Med: 600}]
*> 209.165.200.225/32   209.165.202.149                   00:26:24   [{Origin: e} {LocalPref: 100} {Med: 600}]
*> 209.165.202.146/32   209.165.202.149                   00:26:24   [{Origin: e} {LocalPref: 100} {Med: 600}]
show endpoint
To view endpoints that are now gr-instance aware, use the following command:
show endpoint all grInstance gr_instanceId
Note
grInstance is optional parameter. If grInstance is not specified, show subscriber all considers the local instance-id of that rack.
Example
show endpoint all grInstance 1
        START     STOPPED  GR
ENDPOINT                          ADDRESS        TYPE  STATUS   INTERFACE  INTERNAL  TIME      TIME     INSTANCE
209.165.202.137:2123       209.165.202.137:2123  Udp   Started             false     10 hours  <none>   1
Gtpu:209.165.202.137:2152  209.165.202.137:2152  Udp   Started  GTPU       false     10 hours  <none>   1
N4:209.165.202.137:8806    209.165.202.137:8806  Udp   Started  N4         false     10 hours  <none>   1
S2B-GTP                    209.165.202.138:2124  Udp   Started  s2b        false     10 hours  <none>   1
S5-GTP                     209.165.202.138:2125  Udp   Started  s5         false     10 hours  <none>   1
S5S8S2B-GTP                209.165.202.138:2123  Udp   Started  s5s8s2b    false     10 hours  <none>   1
Sxa:209.165.202.137:8805   209.165.202.137:8805  Udp   Started  SXA        false     10 hours  <none>   1
n10-1                      209.165.202.139:9010  Rest  Started  N10-1      false     10 hours  <none>   1
n11-1                      209.165.202.139:9011  Rest  Started  N11-1      false     10 hours  <none>   1
n40-1                      209.165.202.139:9040  Rest  Started  N40-1      false     10 hours  <none>   1
n7-1                       209.165.202.139:9007  Rest  Started  N7-1       false     10 hours  <none>   1
sbi-1                      209.165.202.139:8090  Rest  Started  SBI-1      false     10 hours  <none>   1
show ETCD/Cache Pod Replication
To view replication details for etcd and cache-pod data, use the following command:
show georeplication checksum instance-id gr_instanceId
Example
Value for 'instance-id' (<string>): 1
checksum-details
 ID             Type    Checksum
 1              ETCD    1617984439
 IPAM           CACHE   1617984439
 NRFCache       CACHE   1617984439
 NRFSubs        CACHE   1617984439
 IDMGR          CACHE   1617984439
 NRFMgmt        CACHE   1617984439
show role
To view the current role of the GR instance, use the following command:
show role instance-id gr_instanceId
Note
The following is a list of possible values for the role:
  • PRIMARY
  • STANDBY
  • INIT
  • FAILOVER_INIT
  • STANDBY_ERROR
Example
result
"PRIMARY"
result
"STANDBY"
show ipam dp with type and address
To view the instance ID and flag to indicate chunk for remote instance, use the following command:
show ipam dp { dp_type } { addr_type }
NOTES:
  • dp dp_type —Specify DP type.
  • addr_type —Specify IPv4/IPv6 address type.
Example
show ipam dp 209.165.202.145:209.165.202.144  ipv4-addr
Flag Indication: S(Static) O(Offline) R(For Remote Instance)
G:N/P Indication: G(GR InstId) N(Native NM InstId) P(Peer NM InstId)
StartAddress    EndAddress      AllocContext                    Route              G:N/P Utilization Flag
209.165.200.240 209.165.200.243 209.165.202.145:209.165.202.144 209.165.200.240/24 1:0/1 0.00%        R
show ipam dp
To view all the instances this DP has chunks from, use the following command:
show ipam dp dp_name
NOTES:
  • dp dp_name —Specify data plane allocation name.
Example
Ipv4Addr [Total/Used/Utilization] = 257 / 1 / 0.39%
Ipv6Addr [Total/Used/Utilization] = 0 / 0 / 0.00%
Ipv6Prefix [Total/Used/Utilization] = 2048 / 0 / 0.00%
Instance ID = 1
show ipam pool
To view instance ID information under which pool is configured, use the following command:
show ipam pool pool_name
NOTES:
  • pool pool_name —Specify pool name.
Example
The following is a list of few configuration examples.
show ipam pool
PoolName                       Ipv4Utilization  Ipv6AddrUtilization  Ipv6PrefixUtilization
poolv6DNN2                     0.00%            0.00%                0.00%
poolv6                         0.00%            0.00%                0.00%
poolv4vDNN                     0.00%            0.00%                0.00%
poolv4DNN2                     0.00%            0.00%                0.00%
poolv4                         0.00%            0.00%                0.00%
poolv6vDNN                     0.00%            0.00%                0.00%
poolv4DNN3                     -                -                    -
show ipam pool poolv4DNN3
Ipv4Addr [Total/Used/Utilization] = 2814 / 0 / -
Ipv6Addr [Total/Used/Utilization] = 0 / 0 / -
Ipv6Prefix [Total/Used/Utilization] = 65536 / 0 / -
Instance ID = 1
isStatic = true
 Ipv4Addr   [Total/Used/Utilization] = 2814 / 0 / 0.00%
 Ipv6Prefix [Total/Used/Utilization] = 0 / 0 / 0.00%
 Instance ID                         = 1
show nrf discovery-info discovery-filter
To view GR Instance ID information to determine for which GR instance the discovery filter information belongs, use the following command:
show nrf discovery-info nf_type discovery-filter
Example
Discovery Filter: dnn=intershat;
Expiry Time: 1580146356
GR Instance ID: 1
To view GR Instance ID information to determine for which GR instance the discovery information belongs, use the following command:
Example
------Discovered NFs:-------
    NF Type: AMF
    Number of Discovery Filters: 15
    Number of NF Profiles: 15
    GR Instance ID: 1
    NF Type: UDM
    Number of NF Profiles: 3
    GR Instance ID: 2
show nrf registration-info
To view GR Instance ID information to determine which GR instance the registration information belongs to, use the following command:
Example
 NF Status: Not Registered
 Registration Time:
 Active MgmtEP Name:
 Heartbeat Duration: 0
 GR Instance ID: 1
 Gr-instance:
 Registration Time:
 Active MgmtEP Name:
 Uri:
 Host Type:
 Gr-instance:
 Registration Time:
 Active MgmtEP Name:
 Uri:
 Host Type:
show nrf subscription-info
To view GR Instance ID information to determine for which GR instance the subscription information belongs, use the following command:
Example
NF Instance Id: f9882966-a253-32d1-8b82-c785b34a7cc9
SubscriptionID : subs123459
Actual Validity Time : 2020-01-21 12:39:45 +0000 UTC
Requested Validity Time : 2020-01-21 12:39:45 +0000 UTC
GR Instance ID: 1
show peers
To view peers that are now gr-instance aware, use the following command:
show peers all grInstance gr_instanceId
Note
Example
show peers all grInstance 1
                                                       POD              CONNECTED       ADDITIONAL  INTERFACE  GR
ENDPOINT  LOCAL ADDRESS   PEER ADDRESS     DIRECTION  INSTANCE TYPE TIME     RPC DETAILS NAME       INSTANCE
<none>  209.165.202.139 209.165.201.22:8001 Outbound rest-ep-0 Rest 10 hours UDM <none>  n10        1
<none>  209.165.202.139 209.165.201.22:8002 Outbound rest-ep-0 Rest 10 hours AMF <none>  n11        1
<none>  209.165.202.139 209.165.201.22:8003 Outbound rest-ep-0 Rest 10 hours PCF <none>  n7         1
<none>  209.165.202.139 209.165.201.22:8004 Outbound rest-ep-0 Rest 10 hours CHF <none>  n40        1
<none>  209.165.202.139 209.165.201.22:9040 Outbound rest-ep-0 Rest 10 hours CHF <none>  n40
show subscriber
To view subscriber details that are made gr-instance aware, use the following command:
show subscriber { all | gr-instance gr_instanceId }
Note
show subscriber all displays only the local instance subscriber details.
Example
show subscriber gr-instance 1 all
subscriber-details
"subResponses": [
"roaming-status:homer",
"supi:imsi-123456789300001",
"gpsi:msisdn-22331010301010",
"psid:1",
"dnn:intershat",
"emergency:false",
"rat:nr",
"access:3gpp access",
"connectivity:5g",
"udm-uecm:209.165.202.150",
"udm-sdm:209.165.202.150",
"auth-status:unauthenticated",
"pcfGroupId:PCF-*",
"policy:2",
"pcf:209.165.202.152",
"upf:209.165.202.154",
"upfEpKey:209.165.202.154:209.165.202.158",
"ipv4-addr:v4pool1/209.165.200.250",
"ipv4-pool:v4pool1",
"ipv4-range:v4pool1/209.165.200.249",
"ipv4-startrange:v4pool1/209.165.200.250",
"id-index:1:0:0:32768",
"id-value:8",
"chfGroupId:CHF-*",
"chf:209.165.202.151",
"amf:209.165.202.153",
"peerGtpuEpKey:209.165.202.154:209.165.202.155",
"namespace:smf",
"nf-service:smf"
Monitor Subscriber
To capture messages for subscriber (gr-instance aware), use the following command:
monitor subscriber [ capture-duration duration  | gr-instance gr_instance_id  | imei imei_id | imsi imsi_value | internal-messages [ yes ] | namespace [ sgw | smf ] | nf-service [ sgw | smf ] | supi supi_id | transaction-logs [ yes ] ]
Note
In 2021.02 and later releases, the namespace keyword is deprecated and replaced with the nf-service keyword.
NOTES:
  • capture-duration duration : Specify the duration in seconds during which monitor subscriber is enabled. The default value is 300 seconds (5 minutes). This is an optional parameter.
  • gr-instance gr_instance_id : Specify the GR instance ID. The instance ID 1 denotes the local instance ID.
  • imei imei_id : Specify the subscriber IMEI. For example: 123456789012345, *
  • imsi imsi_value : Specify the subscriber IMSI. For example: 123456789, *
  • internal-messages [ yes ] : Enable internal messages when set to yes . By default, it is disabled. This is an optional parameter.
  • namespace [ sgw | smf ] : Enable the specified namespace. By default, namespace is set to none. This is an optional parameter.
    Important
    This keyword is deprecated in release 2021.02.0 and replaced with nf-service keyword.
  • nf-service [ sgw | smf ] : Enable the specified NF service. By default, nf-service is set to none. This is a mandatory parameter.
    Important
    The nf-service keyword replaces the namespace keyword in release 2021.02 and beyond.
  • supi supi_id : Specify the subscriber identifier. For example: imsi-123456789, imsi-123*
  • transaction-logs [ yes ] : Enable transaction logs when set to yes . By default, it is disabled. This is an optional parameter.
    To view the transaction history logs, use the dump transactionhistory command.
    Note
    The most recent transaction logs are stored in a circular queue of size 1024 transaction logs.
Example
monitor subscriber imsi 123456789 gr-instance 1
supi: imsi-123456789
captureDuration: 300
enableInternalMsg: false
enableTxnLog: false
namespace(deprecated. Use nf-service instead.): none
nf-service: none
gr-instance: 1
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   295  100    98  100   197  10888  21888 --:--:-- --:--:-- --:--:-- 29500
Command: --header Content-type:application/json --request POST --data
{"commandname":"mon_sub","parameters":{"supi":"imsi-123456789","duration":300,
"enableTxnLog":false,"enableInternalMsg":false,"action":"start","namespace":"none",
"nf-service":"none","grInstance":1}} http://oam-pod:8879/commands
Result start mon_sub, fileName ->logs/monsublogs/none.imsi-123456789_TS_2021-04-09T09:59:59.964148895.txt
Starting to tail the monsub messages from file: logs/monsublogs/none.imsi-123456789_TS_2021-04-09T09:59:59.964148895.txt
Defaulting container name to oam-pod.
Use 'kubectl describe pod/oam-pod-0 -n smf' to see all the containers in this pod.
Monitor Protocol
To capture packets on different interfaces (gr-instance aware), use the following command:
monitor protocol { interface interface_name [ capture-duration duration  | gr-instancegr_instance | pcacp yes | | ] | list [ | ] }
Warning
Use the monitor protocol interface command cautiously, as it may disrupt user services. When used in a live network, it can cause session delays, call drops, and degrade system performance.
Note
  • interface interface_name —Specify the interface name on which PCAP is captured. This CLI allows the configuration of multiple interface names in a single CLI command.
  • capture-duration duration —Specify the duration in seconds during which pcap is captured. The default is 300 seconds (5 minutes).
  • The configured interface names can be retrieved using the show endpoint CLI command.
  • gr-instance gr_instance_id —Specify the GR instance ID. The instance ID 1 denotes the local instance ID.
  • pcap yes —Configure this option to enable PCAP file generation. By default, this option is disabled.
  • list —Monitor protocol list files.
Example
monitor protocol interface sbi gr-instance 1
100   220  100    95  100   125   8636  11363 --:--:-- --:--:-- --:--:-- 20000
{"commandname":"mon_pro","parameters":{"interface":"sbi","duration":300,"action":
"start","enable_pcap":false,"grInstance":1}} http://oam-pod:8879/commands
Result start mon_pro, fileName ->logs/monprologs/sessintfname_sbi_at_2021-04-30T05:26:22.712229347.txt
Starting to tail the monpro messages from file: logs/monprologs/sessintfname_sbi_at_2021-04-30T05:26:22.712229347.txt
Use 'kubectl describe pod/oam-pod-0 -n cn' to see all of the containers in this pod.
Geographic Redundancy OAM Support
This section describes operations, administration, and maintenance information for this feature.
Health Check
The following section provides information on GR setup health check.
  • All critical pods are in good condition to serve user traffic.
    Use the following command to check whether GR and CDL related pods are in Running state.
    kubectl get pods -n cn-cn1 -o wide | grep georeplication-pod
    kubectl get pods -n cn-cn1 -o wide | grep cdl
    kubectl get pods -n cn-cn1 -o wide | grep mirror-maker
  • Keepalived pods are in healthy state to monitor all VIPs which are configured for check-interface/check-port.
    Use the following command to check whether keepalived pods in “smi-vips” namespace are in “Running” state.
    kubectl get pods -n smi-vips
  • Health-check of pods related to CDL: Check the status of CDL db-endpoint, slot and indexes. All should be in STARTED or ONLINE state for both System IDs 1 and 2.
    cdl show status
    message params: {cmd:status mode:cli dbName:session sessionIn:{mapId:0 limit:500 key: purgeOnEval:0 filters:[] nextEvalTsStart:0 nextEvalTsEnd:0 allReplicas:false maxDataSize:4096} sliceName:}
    db-endpoint {
        endpoint-site {
            system-id 1
            state STARTED
            total-sessions 4
            site-session-count 2
            total-reconciliation 0
            remote-connection-time 66h37m31.36054781s
            remote-connection-last-failure-time 2021-07-13 11:24:10.233825924 +0000 UTC
            slot-geo-replication-delay 2.025396ms
        endpoint-site {
            system-id 2
            state STARTED
            total-sessions 4
            remote-connection-time 66h58m49.83449066s
            remote-connection-last-failure-time 2021-07-13 11:02:51.759971655 +0000 UTC
            slot-geo-replication-delay 1.561816ms
    slot {
        map {
            map-id 1
            instance {
                system-id 1
                instance-id 1
                records 4
                capacity 2500000
                state ONLINE
                avg-record-size-bytes 1
                up-time 89h38m37.335813523s
                sync-duration 9.298061ms
            instance {
                system-id 1
                instance-id 2
                records 4
                capacity 2500000
                state ONLINE
                up-time 89h39m11.1268024s
                sync-duration 8.852556ms
            instance {
                system-id 2
                instance-id 1
                records 4
                capacity 2500000
                state ONLINE
                up-time 89h28m38.274713022s
                sync-duration 8.37766ms
            instance {
                system-id 2
                instance-id 2
                records 4
                capacity 2500000
                state ONLINE
                up-time 89h29m37.934345015s
                sync-duration 8.877442ms
    index {
        map {
            map-id 1
            instance {
                system-id 1
                instance-id 1
                records 4
                capacity 60000000
                state ONLINE
                up-time 89h38m16.119032086s
                sync-duration 2.012281769s
                leader false
                geo-replication-delay 10.529821ms
            instance {
                system-id 1
                instance-id 2
                records 4
                capacity 60000000
                state ONLINE
                up-time 89h39m8.47664588s
                sync-duration 2.011171261s
                leader true
                leader-time 89h38m53.761213379s
                geo-replication-delay 10.252683ms
            instance {
                system-id 2
                instance-id 1
                records 4
                capacity 60000000
                state ONLINE
                up-time 89h28m29.5479133s
                sync-duration 2.012101957s
                leader false
                geo-replication-delay 15.974538ms
            instance {
                system-id 2
                instance-id 2
                records 4
                capacity 60000000
                state ONLINE
                up-time 89h29m11.633496562s
                sync-duration 2.011566639s
                leader true
                leader-time 89h28m51.29928233s
                geo-replication-delay 16.213323ms
  • CDL replication status
    Check whether four gRPC connections are established between the CDL EP session pods (of each namespace) across the racks in GRPC_Connections_to_RemoteSite panel of CDL Replication Stats Grafana dashboard. Check Grafana on both racks.
  • Admin port status between the racks for geo-replication.
    Check heartbeat messages between geo-replication pods across the racks in Periodic_Heartbeat_to_Remote_Site panel of GR Statistics Grafana dashboard.
  • BGP/BFD link status on rack
    Check whether neighborship with BGP peers is established in BGP Peers panel of BGP, BFD Statistics Grafan dashboard.
    Check whether BFD link is in connected state in BFD Link Status panel of BGP, BFD Statistics Grafana dashboard.
  • Roles of each instances are in healthy state
    Check that in each rack the roles are not in STANDBY_ERROR state at any point of time.
    • Active/Standby Model: Roles should be in the following states on each rack
      Rack-1:
      result "PRIMARY"
      result "PRIMARY"
      Rack-2:
      result "STANDBY"
      result "STANDBY"
    • Active/Active Model: Roles should be in the following states on each rack.
      Rack-1:
      result "PRIMARY"
      result "STANDBY"
      Rack-2:
      result "STANDBY"
      result "PRIMARY"
Recovery Procedure
On Rack-1
  1. Verify that roles of both instances on Rack-1 are in STANDBY_ERROR.
  2. Initiate reset role for both instances on Rack-1 to STANDBY. This step transitions the roles from STANDBY_ERROR/STANDBY_ERROR to STANDBY/STANDBY.
  3. Verify that roles of both instances have moved to STANDBY on Rack-1.
    result "STANDBY"
    result "STANDBY"
  4. Initiate switch role for instance-id 1 on Rack-2 to STANDBY with failback-interval of 30 seconds. This step transitions the roles of Rack-2 from PRIMARY/PRIMARY to STANDBY_ERROR/PRIMARY and Rack-1 from STANDBY/STANDBY to PRIMARY/STANDBY.
  5. Verify that roles of both instances on Rack-2 are in STANDBY_ERROR/PRIMARY.
    result "PRIMARY"
  6. Verify that roles of both instances on Rack-1 are in PRIMARY/STANDBY.
    result "PRIMARY"
    result "STANDBY"
  7. Initiate reset role for instance-id 1 on Rack-2 to STANDBY. This step transitions the roles of Rack-2 from STANDBY_ERROR/PRIMARY to STANDBY/PRIMARY.
  8. Verify that the roles of Rack-2 are in STANDBY/PRIMARY.
    result "STANDBY"
    result "PRIMARY"
On Rack-2
  1. Verify that roles of both the instances on Rack-2 are in STANDBY_ERROR.
  2. Initiate reset role for both instances on Rack-2 to STANDBY. This step transitions the roles from STANDBY_ERROR/STANDBY_ERROR to STANDBY/STANDBY.
  3. Verify that the roles of both the instances move to STANDBY on Rack-2.
    result "STANDBY"
    result "STANDBY"
  4. Initiate switch role for instance-id 2 on Rack-1 to STANDBY. This step transitions roles of Rack-1 from PRIMARY/PRIMARY to PRIMARY/STANDBY_ERROR and Rack-2 from STANDBY/STANDBY to STANDBY/PRIMARY.
  5. Verify that roles of instances on Rack-1 are in PRIMARY/STANDBY_ERROR mode.
    result "PRIMARY"
  6. Verify that roles of instances on Rack-2 are in STANDBY/PRIMARY mode.
    result "STANDBY"
    result "PRIMARY"
  7. Initiate reset role for instance-id 2 on Rack-1 to STANDBY. This step transitions the roles of Rack-1 from PRIMARY/STANDBY_ERROR to PRIMARY/STANDBY.
  8. Verify that roles of instances on Rack-1 are in PRIMARY/STANDBY.
    result "PRIMARY"
    result "STANDBY"
Key Performance Indicators (KPIs)
The following section describes KPIs.
ETCD/Cachepod Replication KPIs
The following table lists ETCD/Cachepod Replication KPIs.
Table 11. geo_replication_total KPIs
KPI Name
Description
Labels
Possible Values
geo_replication
_total
This KPI displays total number of replication requests/responses for various Sync types and Replication types.
ReplicationRequest
Type
Request / Response
ReplicationSync
Type
Immediate / Deferred / Pull
ReplicationNode
ETCD / CACHE_POD / PEER
ReplicationReceiver
Local / Remote
status
True / False
status_code
Error code/description
Geo Rejected Role Change KPIs
The following table lists Geo Rejected Role Change KPIs.
Table 12. Geo Rejected Role Change KPIs
KPI Name
Description
Labels
Possible Values
geo_RejectedRole
Changed_total
This KPI displays the total number of rejected requests/calls received for STANDBY instance. After the count, the same instance is moved to PRIMARY.
RejectedCount
Number value indicating rejected calls/requests received for standby instance.
GRInstance
Number
1 / 2
Monitoring KPIs
The following table lists monitoring KPIs.
Table 13. geo_monitoring_total KPIs
KPI Name
Description
Labels
Possible Values
geo_monitoring
_total
This KPI displays the total number of successful / failure messages of different kinds such as, heartbeat / remoteNotify / TriggerGR and so on.
ControlAction
Type
AdminMonitoring
ActionType / AdminRemote
MessageAction
Type / AdminRole
ChangeActionType
ControlAction
NameType
MonitorPod / MonitorBfd /
RemoteMsgHeartbeat /
RemoteMsgNotifyFailover /
RemoteMsgNotify
PrepareFailover /
RemoteMsgGetSiteStatus /
RemoteClusterPodFailure /
RemoteSiteRole
Monitoring /
TriggerGRApi /
ResetRoleApi
Admin Node
Any string value. For example, GR Instance ID or instance key / pod name
Status Code
0 / 1001 / 1002 / 1003 /
1004 / 1005 / 1006 / 1007 /
1008 / received error code (1206, 1219, 2404, …)
Status Message
Success (0) /
STANDBY_ERROR => STANDBY/STANDBY => PRIMARY (0) / Pod Failure (0) /
CLI (0) / BFD Failure (0) /
Decode Failure (1001) /
remote status unavailable (1002) /
target role does not support (1002) /
Pod Failure (1002) /
CLI (1002) / BFD Failure (1002) /
site is down (1003) / Pod Failure (1003) /
CLI (1003) / BFD Failure (1003) /
Traffic Hit (1004) /
Pod Failure (1004) / CLI (1004) /
BFD Failure (1004) / current role is not
STANDBY_ERROR/
STANDBY to reset
role (1005) / resetRole:
Key not found in etcd (1006) /
monitoring threshold per
pod is breached (1007) /
Retry on heartbeat
failure (1008) /
received error message (No remote host available for this request / Selected remote host <remotehostname> has no client connection / Sla is expired for transaction / …)
Table 14. geo_replication_finalpull_total KPIs
KPI Name
Description
Label Names
Possible Values
geo_replication
_finalpull_total
MessageType
It's a request or a response message type.
TotalTimeTaken
It's the total time taken to process the request.
GRInstanceNumber
It's the GR Instance ID in number from the list of the following:
  • Instance.1
  • Instance.2
BFD KPIs
The following table lists BFD KPIs.
Table 15. BFD KPIs - 1
KPI Name
Description
Labels
Possible Values
bgp_speaker
_bfd_status
This KPI displays BFD link status on BGP Speaker.
status
STATE_UP /
STATE_DOWN
geo_bfd_
status
This KPI displays BFD link status on Geo POD.
status
STATE_UP /
STATE_DOWN
Table 16. BFD KPIs - 2
KPI Name
Description
Gauge
bgp_speaker
_bfd_status
1 (UP) or 0 (DOWN)
geo_bfd_
status
1 (UP) or 0 (DOWN)
GR Instance Information
Table 17. GR Instance Information KPI
KPI Name
Description
Labels
Possible Values
gr_instance_
information (Type – Guage)
This KPI displays the current role of the GR instance in the application.
gr_instance_id
Configured GR instances value (numerical value)
Geo Maintenance Mode
Table 18. Geo Maintenance Mode KPI
KPI Name
Description
Labels
Possible Values
geo_MaintenanceMode_
info (Type – Guage)
This KPI displays the current state of maintenance mode for the rack.
MaintenanceMode
0: false
1: true
Bulk Statistics
The following section provides details on GR-specific bulkstats.
bulk-stats query GR-BGP-Incoming-Failed-Routes
 expression "sum(bgp_incoming_failedrouterequest_total) by (namespace, interface, service_IP, next_hop, instance_id)"
 labels     [ instance_id interface next_hop service_IP ]
 alias      gr-bgp-routes-in
exit
bulk-stats query GR-Geo-Monitoring-Failure
 expression "sum(geo_monitoring_total{ControlActionNameType=~'MonitorPod|RemoteMsgHeartbeat|
RemoteMsgGetSiteStatus|RemoteSiteRoleMonitoring|RemoteClusterPodFailure|RemoteMsgNotifyFailover|
RemoteMsgNotifyPrepareFailover|MonitorVip',status!~'success|monitoring.*'}) by (namespace,
AdminNode, ControlActionType, ControlActionNameType,  pod, status, status_code)"
 labels     [ pod AdminNode ControlActionNameType status status_code ]
 alias      gr-geo-monitoring-failure
exit
bulk-stats query GR-Geo-Monitoring-Success
RemoteMsgNotifyPrepareFailover',status=~'success|monitoring.*'}) by (namespace, AdminNode,
ControlActionType, ControlActionNameType,  pod, status)"
 labels     [ pod AdminNode ControlActionNameType status ]
exit
bulk-stats query GR-Geo-Monitoring-Total
|RemoteMsgNotifyPrepareFailover|MonitorVip'})
by (namespace, AdminNode, ControlActionType, ControlActionNameType,  pod, status)"
exit
bulk-stats query GR-Geo-Replication-Failure
 expression "sum(geo_replication_total{ReplicationNode=~'CACHE_POD|ETCD|PEER',status!='success',
ReplicationRequestType='Response'}) by (namespace, ReplicationNode, ReplicationSyncType,
ReplicationReceiver,ReplicationRequestType,status,status_code)"
 labels     [ pod ReplicationNode ReplicationReceiver ReplicationRequestType ReplicationSyncType status status_code ]
 alias      gr-geo-replication-failure
exit
bulk-stats query GR-Geo-Replication-Success
status='success',ReplicationRequestType='Response'}) by (namespace, ReplicationNode,
ReplicationSyncType,ReplicationReceiver,ReplicationRequestType,status)"
 labels     [ pod ReplicationNode ReplicationReceiver ReplicationRequestType ReplicationSyncType status ]
 alias      gr-geo-replication-success
exit
bulk-stats query GR-Geo-Replication-Total
 expression "sum(geo_replication_total{ReplicationNode=~'CACHE_POD|ETCD|PEER'})
by (namespace, ReplicationNode, ReplicationSyncType,ReplicationReceiver,
ReplicationRequestType,pod)"
 labels     [ pod ReplicationNode ReplicationReceiver ReplicationRequestType ReplicationSyncType ]
 alias      gr-geo-replication-total
exit
bulk-stats query GR-Trigger-ResetRole-Api
 expression "sum(geo_monitoring_total{ControlActionNameType=~'TriggerGRApi|ResetRoleApi'})
by (namespace, AdminNode, ControlActionType, ControlActionNameType,  pod, status, status_code)"
 alias      gr-api
exit
bulk-stats query GR-CDL-Index-Replication
 expression "sum(consumer_kafka_records_total) by (pod, origin_instance_id)"
 labels     [ origin_instance_id pod ]
 alias      gr-cdl-index-replication
exit
bulk-stats query GR-CDL-Inter-Rack-Replications-Failures
 expression "sum(datastore_requests_total{local_request='0',errorCode!='0'}) by (operation,sliceName,errorCode)"
 labels     [ sliceName operation errorCode ]
 alias      gr-cdl-inter-rack-replications
exit
bulk-stats query GR-CDL-Inter-Rack-Replications-Success
 expression "sum(datastore_requests_total{local_request='0',errorCode='0'}) by (operation,sliceName,errorCode)"
exit
bulk-stats query GR-CDL-Inter-Rack-Replications-Total
 expression "sum(datastore_requests_total{local_request='0'}) by (operation,sliceName,errorCode)"
exit
bulk-stats query GR-CDL-Intra-Rack-Operations-Failures
 expression "sum(datastore_requests_total{local_request='1',errorCode!='0'}) by (operation,sliceName,errorCode)"
 alias      gr-cdl-intra-rack-operations
exit
bulk-stats query GR-CDL-Intra-Rack-Operations-Success
 expression "sum(datastore_requests_total{local_request='1',errorCode='0'}) by (operation,sliceName,errorCode)"
exit
bulk-stats query GR-CDL-Intra-Rack-Operations-Total
 expression "sum(datastore_requests_total{local_request='1'}) by (operation,sliceName,errorCode)"
 labels     [ errorCode operation sliceName ]
exit
bulk-stats query GR-CDL-Session-Count-Per-Slice
 expression sum(avg(db_records_total{namespace=~'$namespace',session_type='total'})by(systemId,sliceName))by(sliceName)
 labels     [ sliceName ]
 alias      gr-cdl-session-count-per-slice
exit
bulk-stats query GR-CDL-Session-Count-Per-System-ID
by(systemId,sliceName))by(systemId)
 labels     [ systemId ]
 alias      gr-cdl-session-count-per-system-id
exit
bulk-stats query GR-CDL-Slot-Records-Per-Slice
 expression "sum(slot_records_total{pod=~'.*',systemId!=''}) by (pod, sliceName)"
 labels     [ pod sliceName ]
 alias      gr-cdl-slot-records-per-slice
exit
bulk-stats query GR-CDL-Slot-Records-Per-System-ID
 expression "sum(slot_records_total{pod=~'.*',systemId!=''}) by (pod, systemId)"
 labels     [ pod systemId ]
 alias      gr-cdl-slot-records-per-system-id
exit
bulk-stats query GR-CDL-Total-Session-Count
 expression "sum(db_records_total{namespace=~'$namespace',session_type='total'}) by (systemId,sliceName)"
 labels     [ sliceName systemId ]
 alias      gr-cdl-total-session-count
exit
For more information on GR-related statistics, see the following:
  • In RADIUS statistics, you can filter GR-specific statistics using grInstId label.
    For more information, see the UCC 5G Session Management Function - Metrics Reference.
  • In GTP Endpoint statistics, you can filter GR-specific statistics using gr_instance_id label.
  • In SMF statistics, you can filter GR-specific statistics using gr_instance_id label.
  • In REST Endpoint statistics, you can filter GR-specific statistics using gr_instance_id label.
  • In IPAM-related statistics, you can filter GR-specific statistics using grInstId label.
Alerts
The following section provides details on GR alerts.
BFD Alerts
The following table list alerts for rule group BFD with interval-seconds as 60.
Table 19. Alert Rule Group - BFD
Alert Rule
Severity
Duration (in mins)
Type
BFD-Link-Fail
critical
Communication Alarm
Expression: sum by (namespace,pod,status)
(bgp_speaker_bfd_status{status='BFD_STATUS'}) == 0
Description: This alert is generated when BFD link associated with BGP peering is down.
GR Alerts
The following table list alerts for rule group GR with interval-seconds as 60.
Table 20. Alert Rule Group - GR
Alert Rule
Severity
Duration (in mins)
Type
Cache-POD-
Replication-Immediate
-Local
critical
Communication Alarm
Expression: (sum by (namespace)
(increase(geo_replication_total{ReplicationNode='CACHE_POD',
ReplicationSyncType='Immediate',ReplicationReceiver='local',
ReplicationRequestType='Response',status='success'}[1m]))/sum by (namespace)
ReplicationRequestType='Request'}[1m])))*100 < 90
Description: This alert is generated when the success rate of CACHE_POD sync type:Immediate and replication receiver:Local is below threshold value.
Cache-POD-
-Remote
critical
Communication Alarm
ReplicationSyncType='Immediate',ReplicationReceiver='remote',
Description: This alert is generated when the success rate of CACHE_POD sync type:Immediate and replication receiver:Remote is below threshold value.
Cache-POD-
Replication-PULL
-Remote
critical
Communication Alarm
ReplicationSyncType='PULL',ReplicationReceiver='remote',
Description: This alert is generated when the success rate of CACHE_POD sync type:PULL and replication receiver:Remote is below threshold value.
ETCD-
-Local
critical
Communication Alarm
(increase(geo_replication_total{ReplicationNode='ETCD',
Description: This alert is generated when the success rate of ETCD sync type:Immediate and replication receiver:Local is below threshold value.
ETCD-
-Remote
critical
Communication Alarm
Description: This alert is generated when the success rate of ETCD sync type:Immediate and replication receiver:Remote is below threshold value.
ETCD-
Replication-PULL
-Remote
critical
Communication Alarm
Expresion: (sum by (namespace)
sum by (namespace) (increase(geo_replication_total
{ReplicationNode='ETCD',ReplicationSyncType='PULL',
ReplicationReceiver='remote',ReplicationRequestType=
Description: This alert is generated when the success rate of ETCD sync type:PULL and replication receiver:Remote is below threshold value.
Heartbeat-Remote
-Site
critical
Communication Alarm
Expression: sum by (namespace)
(increase(geo_monitoring_total{ControlActionNameType=
'RemoteMsgHeartbeat',status!='success'}[1m])) > 0
Description: This alert is triggerd when periodic Heartbeat to remote site fails.
Local-Site-
POD-Monitoring
critical
Communication Alarm
Expression: sum by (namespace,AdminNode)
='MonitorPod'}[1m])) > 0
Description: This alert is triggerd when local site pod monitoring failures breaches the configured threshold for the pod mentioned in Label:{{$labels.AdminNode}}.
PEER-Replication-
Immediate-
Local
critical
Communication Alarm
(increase(geo_replication_total{ReplicationNode='PEER',
[1m]))/sum by (namespace) (increase(geo_replication_total
{ReplicationNode='PEER',ReplicationSyncType=
Description: This alert is generated when the success rate of PEER sync type:Immediate and replication receiver:Local is below threshold value.
PEER-Replication-
Immediate-
Remote
critical
Communication Alarm
{ReplicationNode='PEER',ReplicationSyncType='Immediate',
Description: This alert is generated when the success rate of PEER sync type:Immediate and replication receiver:Remote is below threshold value.
RemoteCluster-
PODFailure
critical
Communication Alarm
='RemoteClusterPodFailure'}[1m])) > 0
Description: This alert is generated when pod failure is detected on the Remote site for the pod mentioned in Label:{{$labels.AdminNode}}.
RemoteMsg
NotifyFailover
critical
Communication Alarm
Expression: sum by (namespace,status)
='RemoteMsgNotifyFailover',status!='success'}[1m])) > 0
Description: This alert is generated when transient role RemoteMsgNotifyFailover has failed for the reason mentioned in Label:{{$labels.status}}.
RemoteMsg
NotifyPrepare
Failover
critical
Communication Alarm
='RemoteMsgNotifyPrepareFailover',status!='success'}[1m])) > 0
Description: This alert is generated when transient role RemoteMsgNotifyPrepareFailover has failed for the reason mentioned in Label:{{$labels.status}}.
RemoteSite-
RoleMonitoring
critical
Communication Alarm
='RemoteSiteRoleMonitoring'}[1m])) > 0
Description: This alert is generated when RemoteSiteRoleMonitoring detects role inconsistency for an instance on the partner rack and accordingly changes the role of the respective instance on local rack to Primary. The impacted instance is in Label:{{$labels.AdminNode}}.
ResetRoleApi
-Initiated
critical
Communication Alarm
='ResetRoleApi'}[1m])) > 0
Description: This alert is generated when ResetRoleApi is initiated with the state transition of roles mentioned in Label:{{$labels.status}}.
TriggerGRApi
-Initiated
critical
Communication Alarm
='TriggerGRApi'}[1m])) > 0
Description: This alert is generated when TriggerGRApi is initiated for the reason mentioned in Label:{{$labels.status}}.
VIP-Monitoring
-Failures
critical
Communication Alarm
='MonitorVip'}[1m])) > 0
Description: This alert is generated when GR is generated upon detecting VIP monitoring failures for the VIP and Instance mentioned in the Label:{{$labels.AdminNode}}.
CDL Alerts
The following table list alerts for rule group CDL with interval-seconds as 60.
Table 21. Alert Rule Group - CDL
Alert Rule
Severity
Duration (in mins)
Type
GRPC-
Connections-
Remote-Site
critical
Communication Alarm
Expression: sum by (namespace, pod, systemId)
(remote_site_connection_status) !=4
Description: This alert is generated when GRPC connections to remote site are not equal to 4.
Inter-Rack
-CDL-Replication
critical
Communication Alarm
(increase(datastore_requests_total{local_request=\"0\",
errorCode=\"0\"}[1m]))/sum by (namespace)
(increase(datastore_requests_total{local_request=\"0\"}
[1m])))*100 < 90
Description: This alert is generated when the Inter-rack CDL replication success rate is below threshold value.
Intra-Rack
-CDL-Replication
critical
Communication Alarm
(increase(datastore_requests_total{local_request=\"1\",
(increase(datastore_requests_total{local_request=\"1\"}
[1m])))*100 < 90
Description: This alert is generated when the Intra-rack CDL replication success rate is below threshold.
Inter-site Geographic Redundancy
Inter-site geographic redundancy is the practice of implementing redundancy and failover mechanisms across multiple sites or locations. The purpose of inter-site redundancy is to ensure that critical services and applications remain available even in the event of a catastrophic failure at one site.
Feature Description
Mobile operators set up the redundant data centers in different geographical locations, so that if one data center goes down, the other can take over. This feature allows to extend the existing inter-rack solution to the inter-site solution. The current notation of HA inside a rack continues to work in conjunction with inter-site redundancy to provide a more comprehensive high availability solution.
Note
Inter-site and inter-rack solution cannot co-exist together, so customer need to select any one of the solutions.
Architecture
The SMF implements the 1:1 model of inter-site redundancy, also known as active:active model. This model is a type of redundancy configuration in which all sites in a network are actively processing traffic simultaneously, and each site is capable of taking over the full load of the network in case of a failure at another site.
The following topology diagram describes about the inter-site redundancy deployment architecture.
Prerequisites
Following is the list of the minimum site requirements for the 1:1 deployment model for each site:
  • Two leaves
  • Two spines
  • One K8 cluster with logical SMF containing two GR instances
    Note
    Each GR instance is the set of unique EPC, RADIUS, and N11 endpoints with same configuration in both the sites.
  • UPF would be deployed in 1:1 configuration
    Note
    Active and standby UPF instances are associated with GR instances, and UPF carries only N4 address of both the GR instances in control plane profile.
How It Works
Most of the configurations for the inter-rack and inter-site are same, except for the configurations that are required for managing and monitoring redundancy events, and replicating sessions across the sites.
Following are the guidelines to achieve the seamless communication between the sites in the inter-site redundancy implementation:
  • Prepend the autonomous systems (AS) path in the BGP (Border Gateway Protocol) route advertisement configuration. For more information, see Configuration for Inter-site Deployment.
  • L3 routing of the Geo-pod, CDL-ep (s), and CDL-Kafka-servers.
BGP Route Advertisement
In the inter-site redundancy deployment, the Multi-exit Discriminator (MED) attribute, which is a non-transitive BGP attribute, is used to inform the neighboring routers of the best path to reach the active service VIP. However, MED values are not shared beyond neighboring routers to their eBGP peers.
In the inter-rack deployment model, AS-path prepending technique is used in BGP to influence the path selection of routes advertised to other BGP routers. AS-path prepending technique makes a certain route more favorable over another by manipulating the AS-path in the BGP route advertisement. The difference in the number of AS-paths getting prepended by software logic helps to provide guidance to upstream routers to choose the best routable path.
Following table captures the number of AS-path prepend required for various combination of service VIP and interface bonding status.
GR Role Bonding interface active VIP present MED value
Local Preference
AS-Path Prepend (Number of times)
Primary Role (active) Yes Yes 1210 2220 3
Yes No 1220 2210 3
No Yes 1215 2215 3
No No 1225 2205 3
Standby Role Yes Yes 2210 1220 6
Yes No 2220 1210 6
No Yes 2215 1215 6
No No 2225 1205 6
Standby-Error Role NA NA 3220 220 9
KPI
prepend_as_path_count” label is added in the following existing metrics.
  • bgp_outgoing_failedrouterequest_total
  • bgp_outgoing_routerequest_total
The above metrics are populated when routes are advertised.
BGP Outgoing Failed Route Request KPI
KPI Name
Description
Labels
Possible Values
This Key Performance Indicator (KPI) represents the total number of failed outgoing routes.
app_name Application Name
cluster Local
data_center
DC
instance 1
instance_id 1
interface
bd2.nrf.2275
local_pref 320
med
3220
next_hop
50.50.50.50
"9->STANDBY_ERROR"
service_IP
10.10.10.10
service_name
bgpspeaker-pod
vrf
Default
BGP Outgoing Route Request Total KPI
KPI Name
Description
Labels
Possible Values
This Key Performance Indicator (KPI) represents the total number of outgoing routes.
cluster Local
data_center
DC
instance 1
instance_id 1
interface
bd2.nrf.2275
local_pref 320
med
3220
next_hop
50.50.50.50
"9->STANDBY_ERROR"
service_IP
10.10.10.10
service_name
bgpspeaker-pod
vrf
Default
Note
Values for As-Path metrics:
New label "prepend_as_path_count" includes the following values based on RoleInfo:
  • Inter Rack/Prepend CLI disabled:
    • prepend_as_path_count="Not-Applicable"
  • Prepend CLI enabled/Primary, Traffic_Hit reason:
    • prepend_as_path_count="0->PRIMARY,TRAFFIC_HIT"
  • Prepend CLI enabled/Primary, Non Traffic_Hit reason:
    • prepend_as_path_count="3->PRIMARY"
  • Prepend CLI enabled/STANDBY:
    • prepend_as_path_count="6->STANDBY"
  • Prepend CLI enabled/STANDBY_ERROR:
    • prepend_as_path_count="9->STANDBY_ERROR"
To enable the inter-site deployment, you must configure the AS-path prepend flag in the BGP configuration.
Following is the sample configuration:
config
  router local_as_number
    bfd bfd_configuration
    interface bgp_local_interface
    prepend as-path { false | true }
    exit
   exit
NOTES:
  • interface bgp_local_interface : Specify BGP local interface.
  • prepend as-path { false | true } : Select true to enable the Inter-site deployment. By default this option is disabled.
    If this option is set to false , the logical SMF deployment follows the inter-rack model.
Configuration Verification
To verify the configuration, use the following show command:
smf# show running-config router
router bgp 63200
 learnDefaultRoute false
 prepend as-path true  ——————————————————> as-path
 bfd interval 250000 min_rx 250000 multiplier 3
 interface enp216s0f0.2119
  bondingInterface enp216s0f0
  bondingInterface enp94s0f0
  neighbor 101.101.172.254 remote-as 63100 fail-over bfd
 exit
 interface enp216s0f0.2129
  vrf vrf_papn1
  bondingInterface enp94s0f1
  neighbor 101.101.174.254 remote-as 63100 fail-over bfd
 exit
 interface enp216s0f0.2139
  vrf vrf_papn2
  neighbor 101.101.178.254 remote-as 63100 fail-over bfd
 exit
Following is the sample ouput of the bgp-advertised routes corresponding to the GR role.
[smf] smf# show role instance-id 1
result "PRIMARY"
[smf] smf# show bgp-advertised-routes
bgp-route
-----bgpspeaker-pod-0 ----
   Network              Next Hop                 AS_PATH          Age        Interface        Vrf                       Attrs
*> 209.165.200.228    209.165.200.229       63000 63000 63000   00:00:47      ens161         Default      [{Origin: e} {LocalPref: 2205} {Med: 1225}]
L3 Routing of Pods
In the inter-rack solution, leaf and spine servers were incorporated into the same AS-path to enable the utilization of VxLAn techniques. This deployment model allows for the support, monitoring, and exchange of redundancy data and events among various pods, while remaining reachable across racks. Specifically, the external IP address of the Geo-pod on both racks were integrated into a common subnet, enabling data exchange without the need for route discovery as they shared the same VLAN. Additionally, communication between racks remained within the boundaries of the leaf and spine servers, without the need for packets to traverse beyond them.
The following PODs require external connectivity between the sites:
  • Geo-pod
  • CDL-ep (s)
  • CDL-Kafka-server(s)
Unlike service VIPs, these IP addresses do not require floating across sites. A routing decision needs to be made only once during production deployment. Therefore, static routing was used instead of advertising these external IP addresses through BGP.
Static routes are added to the local K8S cluster protocol nodes for reaching remote CDL/Kafka/Geo Networks. The leafs automatically advertise all connected local CDL/Kafka/Geo Networks to the spines. The spines redistribute those routes to the Arg router. The Arg routers know how to reach both Sites' CDL/Kafka/Geo Networks. If a packet is destined for a remote CDL/Kafka/Geo network, the local K8S protocol node has a static route that points to the local leaf. The packet then goes to the spine. The spines have a default route that points to the Arg router. The Arg routers have proper routes to send packets to the remote site.
In addition, the Arg routers are configured with the "default-originate" keyword, which designates the ARG routers as the default gateway for the spines. Consequently, the spines redirect all traffic for which a routing path is not available in the spines to the Arg routers.
Inter-site Redundancy Scenarios
This section describes that how the inter-site redundancy deployment works in the different scenarios:
In a scenario with two sites and both operational, each site have one primary/active GR (Gateway Router) instance. The endpoint configured on each site carries traffic corresponding to its active instance. It is possible that the Aggregation Router (ARG) may not be directly connected to the sites, and there could be multiple autonomous systems between the ARG and sites. The ARG router is responsible for the convergence of the routes from both sites.
Following are the various scenarios for the site redundancy:
  • During sunny weather conditions, Site A advertises the best route for GR1 and a less favorable route for the endpoint associated with GR2.
    On the ARG, following are the routes:
    • Routes from Site A
      • 209.165.200.225 AS-Path 65000 65000 65000 65000
      • 209.165.200.235 AS-Path 65000 65000 65000 65000 65000 65000 65000
    • Routes from Site B
      • 209.165.200.225 AS-Path 64000 64000 64000 64000 64000 64000
      • 209.165.200.235 AS-Path 64000 64000 64000 64000
    • Best Path:
      • Site-A 209.165.200.225 AS-path 65000 65000 65000 65000
      • Site -B 209.165.200.235 AS-path 64000 64000 64000 64000
Now if the Site A goes down:
The BGP session on the ARG routers goes down after the BGP convergence time, resulting in the withdrawal of routes learned from Site A. The current state of routes at ARG is as follows.
  • Routes from Site B:
    • 209.165.200.225 AS-Path 64000 64000 64000 64000 64000 64000 64000
    Now the traffic for both the endpoints 209.165.200.225 and 209.165.200.225 is being sent towards site B.
  • The traffic monitoring feature at site B has identified traffic for the IP address 209.165.200.225. Once the packet threshold for this IP address is exceeded, the GeoReplication pod triggers the transition of the GR-1 instance from standby mode to active mode.
  • After the Geo-pod notifies the BGPSpeaker-pod of the transition of GR1 to the primary instance, the BGPSpeaker-pod readvertises the routes for the GR1 endpoint using the most favorable routing path.
  • Now the routes in the ARG are updated with following information:
    • Routes from site B:
Split Brain
When deploying across multiple sites, the failure domain expands. Failures that occur within the leaf/spine architecture and rack are well-managed, and the state of the GR instances during these failures is well-defined and follows the same mechanism as the Inter-Rack solution. However, if there are failures outside the data center, such as link fluctuations on external routers, there is no mechanism for the rack with an active GR instance in cases where communication with the peer rack is lost.
If the link between the Client Router and Data Center Router goes down, connectivity between the racks is lost. The Client Router then sends incoming data traffic to the next preferred site, which is Site 2 in this case. Site 2 has traffic monitoring enabled, which detects the traffic, and once the incoming traffic threshold is met, the GR instance is transitioned from Standby to Primary. At this point, both Site 1 and Site 2 are active for this GR instance. If the link between ARG-Site1 and the Client Router is restored, a dual-active or split-brain scenario occurs.
This instance leads to the following scenarios:
  1. If the Client Router distributes traffic between ARG-Site1 and ARG-Site2, it results in call loss and disruptions in customer service.
  2. Post external link recovery, which site to consider primary and how to move the other site to standby.
To address the issue of traffic being distributed between the two sites, solution is to not prepend any AS-path when the GR instance transitions from standby to Primary due to traffic monitoring. The new Primary site then performs the BGP readvertising without any explicit local AS path pre-pending, making this site the most preferred even if the peer site comes back online. This approach ensures that traffic is directed to the Primary site until the Secondary site is restored and fully operational.
To address the issue of Site Role transition after external link recovery, solution is to keep a timestamp for every role transition. When the link is restored, communication occurs between the Site-1/Geo-Pod and Site-2/Geo-Pod, during which both the pods exchange the role state and timestamp on which the transition occurred. The site with the older timestamp then transitions from Primary to Standby, ensuring that the most recent Primary site maintains its role after the link is restored.
Note
The timestamp update happens only when there is a change in the role. If there is a change in the reason, the timestamp remains unchanged. When detecting the initial split brain, the preference is given for the Site/Rack combination with the role primary and the reason traffic-hit.
KPI
As part of this feature, the following Key Performance Indicators (KPIs) are associated with split brain support.
Geo Split Brain Detection Total KPI
KPI Name
Description
Labels
Possible Values
geo_split_brain_detection_total
This Key Performance Indicator (KPI) represents the overall count of Split Brain Detection instances.
GRInstanceNumber
It's the GR Instance ID and value can be any one from the following:
  • instance.1
  • instance2.
LocalSiteRole
This is local site’s role as a number. This can be any one of below values:
  • 2 (for Primary role)
  • 3 (for Standby role)
  • 6 (for Standby-error role)
LocalSiteReason
This is local site’s reason’s string value:
  • "CLI"
  • "BFD Failure"
  • "POD Failure"
  • "TRAFFIC Hit"
  • "UPGRADE"
  • "STARTUP"
  • "STUCKED Role"
  • "SITE Notification"
  • "REMOTE Monitoring"
  • "SPLITBRAIN Recover"
  • "DELETE Notification"
  • "HEARTBEAT Recover"
LocalSiteTimeStamp Local site’s timestamp when role was last updated.
RemoteSiteRole This is remote site’s role as a number. This can be any one of below values:
RemoteSiteReason
This is remote site’s reason’s string value:
  • "CLI"
  • "BFD Failure"
  • "POD Failure"
  • "TRAFFIC Hit"
  • "UPGRADE"
  • "STARTUP"
  • "STUCKED Role"
RemoteSiteTimeStamp Remote site’s timestamp when role was last updated.
Geo Split Brain Resolution Total
KPI Name
Description
Labels
Possible Values
geo_split_brain_resolution_total
This Key Performance Indicator (KPI) represents the overall count of split brain resolution instances.
GRInstanceNumber
  • instance.1
  • instance2.
LocalSiteRole
LocalSiteReason
  • "CLI"
  • "BFD Failure"
  • "POD Failure"
  • "TRAFFIC Hit"
  • "UPGRADE"
  • "STARTUP"
  • "STUCKED Role"
RemoteSiteReason
  • "CLI"
  • "BFD Failure"
  • "POD Failure"
  • "TRAFFIC Hit"
  • "UPGRADE"
  • "STARTUP"
  • "STUCKED Role"
OldRole
The role before split-brain resolution. This can be any one of below values:
NewRole
The new role after split-brain resolution. This can be any one of below values:
Geo Role Reason Change Total
KPI Name
Description
Labels
Possible Values
geo_role_reason_change_total
This Key Performance Indicator (KPI) represents the overall count of the total number of times the role reason has been changed to HEARTBEAT Recover.
GRInstanceNumber
  • instance.1
  • instance2.
LocalSiteRole
oldReason
This is local site’s reason’s string value before HEARTBEAT Recover:
NewReason
Note
Currently, this transition occurs exclusively based on Traffic Hit.
