cdl logging default-log-level
debug_level
debug_level —Specifies the default log level.
NA
NA
cluster-id
cluster-id
cluster-id
cluster-id —Specifies the Kubernetes cluster identity.
NA |
1 |
endpoint replica
num_replica
endpoint replica
num_replica —Specifies the number of replicas to be created. The value must be an integer.
num_replica —The value must be an integer in the range of 1 to 16.
num_replica —The default value is 1.
slot { replica
num_replica | map
num_map/shards| write-factor
write_factor
replica
map
num_map/shards —Specifies the number of partitions in a slot.
write-factor
write_factor —Specifies the number of copies to be written before a successful response.
Note
Make sure that the value is lower than or equal to the number of replicas.
num_map/shards —The value must be an integer in the range of 1 to 1024.
write_factor —The value must be an integer in the range of 0 to 16.
num_map/shards —The default value is 1.
write_factor —The default value is 1.
slot notification { host
host | port
port | limit
tps}
notification host
host —Specifies the notification server hostname or IP address.
slot notification port
port —Specifies the notification server port number.
slot notification limit
tps —Specifies the notification limit per second.
NA
host —The default value is datastore-notification-ep
port —The default value is 8890.
tps —The default value is 2000
index { replica
num_replica | map
num_map/shards | write-factor
write_factor
replica num_replica —Specifies the number of replicas to be created.
map
num_map/shards —Specifies the number of partitions in a slot. Avoid modifying this value after deploying the CDL.
write-factor
map
write-factor
write_factor
num_replica —The default value is 2.
write_factor
slice-names
cdl_slice_name |
slice-names
cdl_slice_name —Specify the CDL slice names. The value must be an alphanumeric string.
cdl_slice_name —The value must be an integer in the range of 0 to 16.
NA |
