Content Filtering and X-Header Enrichment
Revision History
Table 1. Revision History
Revision Details
Introductory Release
First introduced.
Pre-2020.02.0
Functions of content filtering
The Content Filtering (CF) service prevents subscribers from accidentally accessing unacceptable content, or inappropriate content based on subscriber preferences.
The CF service filters HTTP and WAP requests from mobile subscribers based on the URLs in the subscriber requests.
Operators can control and filter the content accessible to an individual subscriber.
Configure content filtering
This section describes how to configure content filtering.
Important
Apart from these configurations, all other configurations are used only in the UPF, and SMF sends it to the UPF. The SMF doesn't use these configurations. For more information on how to enable the feature on UPF, see the UCC 5G UPF Configuration and Administration Guide.
Procedure
SUMMARY STEPS
  1. Define the active-charging service name in global configuration mode to configure content filtering under the active charging service.
  2. Define rulebase name to configure content filtering under rulebase.
  3. Specify the CF policy number.
  4. Define apn name and CF policy number to configure content filtering under apn. Save the configuration and commit the changes.
DETAILED STEPS
Step 1
active-charging service service_name
Example:
[smf] smf(config)# active-charging service acs
Step 2
rulebase rulebase_name
Example:
[smf] smf(config-service-acs)# rulebase rule1
Step 3
content-filtering category policy-id cf_policy_id
Example:
[smf] smf(config-rulebase-rule1)# content-filtering category policy-id 32
The value of cf_policy_id must be an integer in the range of 1 to 4294967295.
Step 4
apn apn_name
Example:
[smf] smf(config)# apn isp1
[smf] smf(config-apn-isp1)# content-filtering category policy-id 101
Content filtering policy ID on N7 interface
The CF categories are configured under the active charging service with specific policy IDs. The rulebase and APN also have an associated policy ID. Only one policy ID can be associated with a session at any time. The categories configured under that CF policy ID are applicable for the session on the UPF.
The PCF can override the CF policy ID by sending this value on the N7 interface. A proprietary IE available in the YAML definition for the N7 interface facilitates this process.
The hierarchy for the CF policy ID is structured as:
smPolicyDecision
   ciscoAvpSet:
      cfPolicyId: uint32 value
When the PCF does not send a CF policy ID, the existing CF policy ID in the rulebase configuration or the policy ID configured in the APN configuration is selected, in the order of precedence. This CF policy ID value is sent to the UPF in the PFCP Session Establishment Request message in the "Subscriber Parameters" attribute. During PDU Session Modification, if the PCF changes the CF policy ID, the ID is sent to the UPF in the PFCP Session Modification Request message.
X-Header enrichment
X-Header insertion and X-Header encryption features are collectively known as X-Header enrichment.
X-Header enrichment is a feature that:
  • allows appending headers to HTTP or WSP GET and POST request packets
  • adds headers to HTTP response packets for use by end applications,
  • such as mobile advertisement insertion (for example, MSISDN, IMSI, IP address).
X-Header information
Certain X-header configurations need the SMF to send relevant values to the UPF.
The table describes information sent from SMF to UPF for X-header insertion.
Table 2. X-header information description
Xheader Field Description Present in Session Establishment Modified in Session Modification
String Constant Inserts the configured string in X-header
Charging ID Per Flow or Bearer Charging Id Yes
IMEI IMEI for the call Yes
IMSI IMSI for the call Yes
Rat-Type RAT type for the UE session Yes Yes
s-mcc-mnc MCC or MNC of the SGW or AMF Yes
Sgsn-address AMF or SGW address Yes Yes
ULI User Location Info Yes Yes
GGSN-Address N4 or or S5 endpoint of SMF Yes Yes
Radius-station-ID MSISDN of the UE
Sn-rulebase Rulebase for a call Yes Yes
Subscriber-ip-address IP address allocated to UE
Msisdn-no-cc Obtained from MSISDN Yes No
The subscriber-specific fields—IMSI, MSIDN, and IMEI—are encoded in the "User ID" standard IE. For more information, refer to 3GPP 29.244, Section 8.2.101.
Rest of the fields are sent in the "Subscriber Parameters" proprietary AVP. Some fields, such as the "Rulebase" and "UE IP address", are sent as a part of the created PDRs.
Important
  • All parameters are consistently sent from the SMF to the UPF, regardless of the availability of X-header configurations. These parameters ensure that any change in configuration after session creation is immediately applied on the UPF.
  • The SMF supports X-header insertion-related configurations. The SMF does not require these configurations for its functionality. These configurations are sent to the UPF.
