DSCP Marking
Revision history
Table 1. Revision history
Revision Details
Introductory Release
Provided support for DSCP marking of control plane signaling messages.
2021.01.0
First introduced.
Pre-2020.02.0
DSCP markings for QoS in SMF
The Differentiated Services Code Point (DSCP) marking feature is a mechanism that enables the SMF to
  • mark packets with a specific value,
  • perform traffic classification, and
  • provide the appropriate quality of service (QoS) treatment in SMF.
The DSCP is a 6-bit field in the Differentiated Services (DiffServ) field of an IPv4 and IPv6 packet header.
Functionality of DSCP marking
SMF supports the DSCP marking feature for
  • data packets and
  • control plane signaling.
For more information, refer to the How the DSCP marking works for data packets and How the DSCP marking works for control plane signaling sections.
This feature uses CLI commands to configure DSCP parameters for both signaling messages and data packets.
Note
This feature is also applicable on 4G calls with legacy interfaces.
How DSCP marking works for data packets
Summary
DSCP marking is a CLI-controlled feature that enables the creation and mapping of 5G QoS Identifier (5QI) and Allocation and Retention Priority (ARP) values to enforceable QoS parameters.
DSCP marking offers detailed configuration options for users. For Interactive Traffic Class (ITC), the SMF allows DSCP marking for Uplink and Downlink directions based on 5QI and ARP priority levels for each APN.
This feature allows the users to assign different DSCP values to flows with the same 5QI but different ARP priority values. For example, the ability to assign DSCP values that are based on 5QI+ARP can be used to meet compliance on priority and emergency calling via VoLTE.
Workflow
The method for allocating DSCP values to flows with the same 5QI but different ARP values is described here:
  1. New 5QI and ARP configurations override any pre-existing DSCP marking of packets using a 5QI and ARP combination.
  2. 5QI-only DSCP entry overrides all the existing 5QI and ARP configuration.
  3. SMF sends the configured DSCP value to the UPF.
  4. UPF applies the associated DSCP marking for 5QI and ARP for uplink and downlink traffic.
How DSCP marking works for control signaling
Workflow
The DSCP marking process for control signaling involves categorizing and marking network packets to ensure Quality of Service (QoS) in data transmission.
The key components involved in the DSCP marking process are:
  • SMF
  • Protocol endpoints
  • Control packets
The DSCP marking for control signaling works with these characteristics:
  1. SMF marks the incoming and outgoing packets after the QoS classification. The protocol endpoints provide the DSCP values when registering the endpoint and interface.
  2. SMF marks the DSCP values on control packets as per the interface configuration.
  3. DSCP marking feature supports dynamic configuration changes.
  4. DSCP marking configuration is applicable to all the interfaces defined within the configured endpoints.
  5. DSCP marking is supported only on a per-interface and per-protocol basis, not on a per-peer or per-session basis.
  6. SMF uses the DSCP command in the endpoint and interface configurations to define the DSCP values.
    Understanding the DSCP code value range and its denoted priority is essential for DHCP marking.
    This table lists the commonly used DSCP values as described in RFC 2475.
    Table 2. Commonly Used DSCP values
    DSCP Value
    Decimal Value
    Meaning
    Drop Probability
    Equivalent IP Precedence Value
    101 110
    46
    High Priority Expedited Forwarding (EF)
    101 - Critical
    000 000
    Best Effort
    000 - Routine
    001 010
    AF11
    Low
    001 - Priority
    001 100
    12
    AF12
    Medium
    001 - Priority
    001 110
    14
    AF13
    High
    001 - Priority
    010 010
    18
    AF21
    Low
    010 - Immediate
    010 100
    20
    AF22
    Medium
    010 - Immediate
    010 110
    22
    AF23
    High
    010 - Immediate
    011 010
    26
    AF31
    Low
    011 - Flash
    011 100
    28
    AF32
    Medium
    011 - Flash
    011 110
    30
    AF33
    High
    011 - Flash
    100 010
    34
    AF41
    Low
    100 - Flash Override
    100 100
    36
    AF42
    Medium
    100 110
    38
    AF43
    High
    001 000
    8
    CS1
    16
    CS2
    24
    CS3
    32
    CS4
    40
    CS5
    48
    CS6
    6
    111 000
    56
    CS7
    7
    000 000
    Default
    101 110
    46
    EF
Configure DSCP marking
To configure the DSCP Marking feature, perform these steps.
Procedure
Step 1
Configure DSCP marking for data packets
Step 2
Configure DSCP marking for control signaling
Use this procedure to create and map 5QI values to QoS parameters.
Procedure
Step 1
Specify the name of the QoS profile in the global configuration mode to configure the QoS profile.
profile qos <qos_profile_name>
Example:
[smf] smf(config)# profile qos test
Step 2
Specify the ID for the authorized QoS parameters.
dscp-map qi5 <qos_id>
Example:
[smf] smf(config-qos-profile_name)# dscp-map qi5 1
The qos_id value must be an integer in the range of 1 to 255.
Note
Use the DSCP configuration from the QoS profile level if it is unavailable at the QoS flow level.
Step 3
Set the ARP priority level and DSCP value in the inner IP header in the Uplink direction to apply the value to the packet.
arp-priority-level <arp_value> uplink user-datagram dscp-marking <dscp_marking_value>
Example:
[smf] smf(config-qos-profile_name)# dscp-map qi5 1arp-priority-level  2 uplink user-datagram dscp-marking 0X00
The arp_value must be an integer in the range of 1 to 255.
The dscp_marking_value must be a hexadecimal number from 0x00 through 0x3F.
Step 4
Set the ARP priority level and DSCP value either in the encapsulation header or user datagram in Downlink direction.
arp-priority-level arp_value downlink { encsp-header { copy-inner | dscp-marking dscp_marking_value } | user-datagram dscp-marking dscp_marking_value }
Example:
[smf] smf(config-qos-profile_name)# dscp-map qi5 1arp-priority-level 1  downlink encsp-header copy-inner
[smf] smf(config-qos-profile_name)# dscp-map qi5 1arp-priority-level 1  downlink encsp-header dscp-marking 0x3b
  • If encsp-header is configured, set the DSCP in the outer IP header in the Downlink direction or copy the DSCP value from the inner IP header to the outer IP header.
  • If the user-datagram is configured, set the DSCP in the inner IP header in the Downlink direction.
  • The arp_value must be an integer in the range of 1 to 255.
  • The dscp_marking_value must be a hexadecimal number from 0x00 through 0x3F.
Step 5
[Optional] Use the show running-config profile qos command to verify the DSCP configuration for UP packets.
Example:
[smf] smf# show running-config profile qos
profile qos abc
 ambr ul "250 Kbps"
 ambr dl "500 Kbps"
 qi5      7
 arp priority-level 14
 arp preempt-cap NOT_PREEMPT
 arp preempt-vuln PREEMPTABLE
 priority 120
 max data-burst 2000
exit
profile qos qos_1
 dscp-map qi5 1 arp-priority-level 5 uplink user-datagram dscp-marking 0x1e
 dscp-map qi5 1 arp-priority-level 5 downlink user-datagram dscp-marking 0x22 encsp-header copy-inner
 dscp-map qi5 2 arp-priority-level 6 uplink user-datagram dscp-marking 0x3e
 dscp-map qi5 2 arp-priority-level 6 downlink user-datagram dscp-marking 0x23 encsp-header copy-inner
 dscp-map qi5 3 arp-priority-level 12 uplink user-datagram dscp-marking 0x2f
 dscp-map qi5 3 arp-priority-level 12 downlink user-datagram dscp-marking 0x14 encsp-header copy-inner
 dscp-map qi5 6 downlink encsp-header copy-inner
 dscp-map qi5 7 downlink encsp-header dscp-marking 0x01
exit
Sample configuration of DSCP marking for data packets
This sample configuration defines the QoS with specific DSCP mapping rules for both uplink and downlink traffic, including ARP packets.
profile qos test
 dscp-map qi5 1 downlink encaps-header copy-inner
 dscp-map qi5 1 downlink encaps-header dscp-marking 0x3b
 dscp-map qi5 2 downlink user-datagram dscp-marking 0x3b
 dscp-map qi5 3 downlink user-datagram dscp-marking 0x3b encaps-header copy-inner
 dscp-map qi5 4 downlink user-datagram dscp-marking 0x3b encaps-header dscp-marking 0x3f
 dscp-map qi5 2 uplink user-datagram dscp-marking 0x3b
 dscp-map qi5 1 arp-priority-level 1 downlink encaps-header copy-inner
 dscp-map qi5 2 arp-priority-level 2 downlink encaps-header dscp-marking 0x3b
 dscp-map qi5 4 arp-priority-level 3 downlink user-datagram dscp-marking 0x3b
 dscp-map qi5 2 arp-priority-level 4 downlink user-datagram dscp-marking 0x3b encaps-header copy-inner
 dscp-map qi5 4 arp-priority-level 5 downlink user-datagram dscp-marking 0x3b encaps-header dscp-marking 0x3f
 dscp-map qi5 4 arp-priority-level 5 uplink user-datagram dscp-marking 0x3b
Use this procedure to configure the DSCP marking for control signaling at the endpoint and interface:
Procedure
Step 1
Specify the instance and group instance ID in the global configuration mode.
instance instance-id <gr_instance_id>
Example:
[smf] smf(config)# instance instance-id 1
Step 2
Specify the endpoint for DSCP marking.
endpoint { gtp | li | protocol | radius | sbi }
Example:
[smf] smf(config-instance-instance-id-1)# endpoint gtp
The DSCP marking configuration is applicable only to these endpoints:
  • protocol
  • sbi
  • gtp
  • radius
  • li
Step 3
Specify the DSCP value for the control plane signaling messages.
dscp <dscp_value >
Example:
[smf] smf(config-endpoint-gtp)# dscp  24
The dscp_value must be a hexadecimal number from 0x00 to 0x3F or a decimal value from 0 to 63.
Step 4
Specify the interface within the selected endpoint for DSCP marking.
interface { coa-nas | gtpu | n4 | n7 | n10 | n11 | n16 | n40 |nrf | radius-client | s2b | s5 | s8 | upf-rcm-connupf-rcm-reg }
Example:
[smf] smf(config-endpoint-gtp)# interface  nrf
The Service-based Interface (SBI) configuration applies to all the interfaces. If a specific interface configuration is present, it overrides the DSCP values.
Note
Configure vip-ip, vip-port, and loopbackPort at each interface level for the proper functionality of the interfaces.
Step 5
Specify the DSCP value for the control plane signaling messages and save the configuration.
dscp <dscp_value >
Example:
[smf] smf(config-interface-nrf)# dscp  24
Step 6
[Optional] Use the show running-config instance instance-id gr_instance_id endpoint command to verify the DSCP configuration for control packets.
Example:
smf# show running-config instance instance-id 1 endpoint
 endpoint sbi
  replicas 2
  nodes 1
  dscp 24
  vip-ip 209.165.200.230
  interface nrf
   loopbackPort 9050
   vip-ip 209.165.200.236 vip-port 8090
   dscp 24
  exit
 exit
exit
Monitor the DSCP marking value
Use these commands to view the configured DSCP value:
  • monitor protocol
  • monitor subscriber
