SMF Serviceability
Peer Monitoring
View Peer Status Through Grafana
Table 1. Feature History
Feature Name
Release Information
Description
SMF Metrics – View Peer Status Through Grafana
2025.01.0
With this release, SMF provides the ability to view the connection status of Diameter (Gx and Gy), RADIUS, CGF, and N4 peers using Grafana queries on Grafana cloud.
In a single pane view, you can see the peer status across various deployments, aiding in faster identification and resolution of connectivity issues.
The Grafana query shows the current status of the peers and also shows the peer status if it is connected or not connected.
For more information about SMF metrics, see SMF Metrics.
SMF uses the following metrics to view the peer status in Grafana:
Table 2. Metrics Used for Grafana Queries
Peer
Metric
Configuration Required
rpc_host_status
infra metrics verbose protocol
metrics rpc_host_status
 level debug
exit
OR
 level debug
exit
Note
After adding this configuration, you must restart the diameter-ep pods.
RADIUS
Radius_Server_Status
No configuration required
CGF (GTPP/Gz)
nodemgr_gtpp_stats
Note that this metric is new in this release (2025.01.0).
infra metrics verbose application
metrics nodemgr_gtpp_stats
 level debug
exit
OR
 level debug
exit
N4
nodemgr_upf_link_status
metrics nodemgr_upf_link_status
 level debug
exit
OR
 level debug
exit
Log Monitoring
Summary Data
Table 3. Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Enabled – Always-on
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 4. Revision History
Revision Details Release
First introduced.
2023.01.0
Feature Description
The SMF logs and serviceability feature perform in the following modes:
  • It helps and captures capabilities to enable limited debug logs in the production with a chain of troubleshooting tools.
  • These further help in improving the time taken in finding a root cause of any issue found during the production.
This feature allows the operator to enable specific LogTag to debug call failures and procedure failures, to facilitate a better RCA in the production. It has the following characteristics:
  • The SMF must provide a tool or utility to generate core dumps that help in downloading and investigating the problem further.
  • The SMF must print the SUPI of the failed subscriber along with the error details in the logs.
  • The required subscriber information MonSub helps in debugging a particular subscriber.
How it Works
This section describes how this feature works.
Log Instances
The log instance generates messages, used for identifying issues, deployment status, and performance tuning. The application infrastructure provides a common way to enable log messages across applications. Each log instance has the following:
  • Timestamp
  • Log message
  • Log level
  • LogTag
LogTag
The LogTag is used as a filter to enable or disable the specific type of log messages. Before or during the logging session, they are precreated, evaluated, and exempted. It consists of the following:
  • Module name
  • Component name
  • Interface name
Creating a LogTag
The following is a sample example of creating a LogTag:
common.LogTagN7RestEp = appCtx.RegisterLogTag("rest_ep", "app", "n7")
Logging a Message
The following is a sample example of a LogTag message logging:
appCtx.Info(common.LogTagN7RestEp, "Starting rest-ep app")
Log Levels
The application infrastructure provides upto six variants of log levels, which can be used as filter along with LogTag to enable or disable specific logs. Each level represents the level of importance of a log message, which can be used while troubleshooting. The following table lists log levels and their usage:
Table 5. Log Levels
Log Levels
Usage
Error
Used when there’s incorrectness leading to serious issues.
Warning
Used to notify and warn, when there’s an occurrence of any of the following scenarios:
  • Something serious is about to happen.
  • If there’s an activity which is erroneously running
  • Continuously giving error notes
  • Not attended scenarios
Info
Used for normal expected behavior such as starting an application or stopping the same, and so on.
Debug
Used to provide more information required to debug problems.
Trace
Used to provide extensive information. Also, used in monitoring routines, where the same debug log keeps coming periodically.
Off
Used when there isn't any meaning in the logging information. Configured in the CLI to turn off or turn on the logging activity.
Log Level Order
Every time, the application infrastructure logs any log message, it matches the log level, and the LogTag with the configured log setting, before logging.
Table 6. Log Levels
Log Levels (Order)
Usage
Error (0)
Matches error logs.
Warn (1)
Matches warn and error logs.
Info (2)
Matches info, warn, and error logs.
Debug (3)
Matches debug, info, warn, and error logs.
Trace (4)
Matches trace, debug, info, warn, and error logs.
Off (5)
Matches no log to disable errors.
SMF Logs
The SMF supports operators to enable specific LogTag. The following is a list of modules which support the implementation of this feature.
  1. Call Failure LogTag:
    • Enabled in the CLI mode
    • The SMF must enable the following logs based on the disconnect reason:
      • Error
      • Warning
      • Debug
    • It prints the following log parameters:
      • Transaction ID
      • Disconnect reason
      • Event Trace
      • Session Keys
      • Error Category (For major disconnect reason)
  2. Procedure Failure LogTag:
      • Warning
      • Transaction ID
      • Procedure Name
      • Event Trace
      • Detailed Error: It includes the following:
        • Failure reason or cause
        • Disconnect reason (if applicable)
        • Failure metrics
  3. Additional Call Flow Failure LogTag:
    • Enabled for specific reasons or conditions
      • Transaction ID
      • Event Trace
      • Call flow-specific error messages
    • The supported log levels:
      • Error
      • Warning
      • Info
      • Debug
  4. Additional Generic Procedure Failure LogTag:
    • The SMF must not enable the Event Trace based on the disconnect reason.
    • If the operator needs failure logs for all procedures, then the operator can enable this LogTag.
      Note
      The operator needs to activate this LogTag carefully, as it prints logs of all failed procedures. This action can cause an overflow of service logs.
      • Transaction ID
      • Procedure Name
        • Failure metrics
  5. Call Flow Statistics LogTag:
    • This process gets tabulated at the end of all procedures.
  6. Core Dump LogTag:
    • This process initiates the debugging activities for a core dump utility.
  7. Subscriber Monitoring LogTag:
    • This process initiates the debugging activities for any kind of failures. It also processes the subscriber monitoring based on the subscriber SUPI.
Timesaver
For more information, see Troubleshooting Information > Logs.
Call Failure Logs
The following are the synopsis of the Call Failure logs to trigger session management policies towards the SMF:
  • For call failures and call releases, the disconnect-reason-based statistics are defined and attached.
  • Disconnect Reasons—They are classified into three categories as the following:
    • Major
    • Minor
    • Normal
  • On call failure or call release scenarios, messages are logged as the following:
    • Major (Catastrophic) Category Disconnect Reasons—The transaction log at Error level is to display the Error category, Disconnect reason, along with Event Trace, and Session keys.
    • Minor (Critical) Category Disconnect Reasons—The transaction log at Warning level to dump the Disconnect reason, along with Event Trace, and Session keys.
    • Normal Category Disconnect Reasons—The transaction log at Debug level to dump the Disconnect reason along with the Event Trace and Session keys.
    • Graceful Core Dump—This transaction log also gets performed with the same LogTag and levels.
  • A new LogTag to log the Call Failures also gets defined.
  • The Transaction ID gets printed in a Call Failure logs to align with the logs and call flow.
  • Based on the disconnect reason statistics, the callfailure tag with the corresponding log level can be enabled to collect further information of the session. The following is a list of examples:
    • Event Trace
    • Session keys
    • Core Dump
Sample Dump for Call Failure Logs
The following is a sample dump for Call Failure logs:
Example: For a procedure lapsed time of over two seconds, a Warning message gets logged with the event trace.
2022/08/23 11:10:31.222 [WARN] [smf-service.smf-app.callfailure-debug] 2sec Time Elapsed: EVENT TRACE SessionKeys[[imsi-123456789012345:5 (pk)]]
CurIndex:[2], CurProcInst:[0], CreateTimeStamp:[2022-08-23 11:10:31.204 +0530 IST], BaseTimeStamp:[2022-08-23 11:10:31.204 +0530 IST]
|INDEX|EVENT NAME                         |EVENT TYPE           |PROC NAME                                           |PROC INST |TXN ID    |TIMESTAMP                          |
|1    |N11SmContextCreateReq              |INCOMING_EVENT       |PDU Session Establishment                           |1         |1         |2022-08-23 11:10:31.215 +0530 IST  |
|2    |N11SmContextCreateReq              |ENDPROC_EVENT        |PDU Session Establishment                           |1         |1         |2022-08-23 11:10:31.221 +0530 IST  |
Configuring the Call Failure Logs
To configure this feature, use the following configuration:
logging name smf-service.smf-app.callfailure-debug level application/transaction <debug level>
NOTES:
  • Warning —The logging level supported for call failure LogTags.
  • For more information, see Troubleshooting Information > Logs.
Configuration Example
The following is an example configuration.
config
   logging name smf-service.smf-app.callfailure-debug level transaction warn
   logging name smf-service.smf-app.callfailure-debug level application error
exit
Configuration Verification
To verify the configuration:
[smf] smf# show running-config logging name smf-service.smf-app.callfailure-debug
Procedure Failure Logs
The following are the synopsis of the Procedure Failure logs to trigger session management policies towards the SMF:
  • During the termination scenario, each Procedure Failure log turns on the EndProcedure.
  • During the failure scenario, the Error Code returns to the SMF Infra indicating whether the procedure was a success or a failure.
  • On failure, a Transaction log (common to all procedures) with level warning is used to dump the session details as the following:
    • Event Trace
    • Procedure Name
    • Error Details—It contains failure reason or cause, disconnect reason (if applicable) and failure metrics.
  • The Procedure Failure LogTag is common to all procedures.
  • Procedure-specific LogTags will be configured for each procedure and used to enable logging for specific procedure failures.
  • The Transaction ID gets printed in a procedure failure logs to align with the logs and call flow.
  • The detailed errors note gets printed in the procedure failure logs. It helps in understanding the problem, the actual error cause, disconnect reason (if applicable), and failure metrics.
Logging a Message for Procedure Failure Logs
The following is a sample example of a LogTag for Procedure Failure logs:
2023/01/15 11:34:30.002 [WARN] [smf-service.smf-app.pdnsetup-procfailure]
[Txn :7]Procedure=[PDN Connect [LTE]], PduState=[IDLE], Rat-Type=[rat_type_unknown],
FailureReason=[udm_subscribe_notify_failure], DisconnectReason=[disc_pdnsetup_udm_sub_notify_resp_failed]
2023/01/15 11:34:30.002 [WARN] [smf-service.smf-app.pdnsetup-procfailure] [Txn :7]EVENT TRACE
CurIndex:[8], CurProcInst:[0], CreateTimeStamp:[2022-09-13 11:34:27.942 +0000 UTC],
BaseTimeStamp:[2022-09-13 11:34:27.942 +0000 UTC]
|1 |S5S8CreateSessReq |INCOMING_EVENT |PDN Connect [LTE] |1 |7 |2022-09-13 11:34:27.942 +0000 UTC |
|2 |N10RegistrationSuccess |INCOMING_EVENT |PDN Connect [LTE] |1 |7 |2022-09-13 11:34:27.943 +0000 UTC |
Configuring the Procedure Failure Logs
logging 	name 	smf-service.smf-app.pdusetup-procfailure  	       level 	transaction <debug level>
logging 	name 	smf-service.smf-app.pdnsetup-procfailure 		level 	transaction <debug level>
logging 	name 	smf-service.smf-app.pdurelease-procfailure             level 	transaction <debug level>
logging 	name 	smf-service.smf-app.pdndisconnect-procfailure       level 	transaction <debug level>
logging 	name 	smf-service.smf-app.5gim-procfailure                      level 	        transaction <debug level>
logging 	name 	smf-service.smf-app.xnho-procfailure                      level         transaction <debug level>
logging 	name 	smf-service.smf-app.n2ho-procfailure                     level  	transaction <debug level>
logging 	name 	smf-service.smf-app.nrtowifiho-procfailure             level  	transaction <debug level>
logging 	name 	smf-service.smf-app.enbtowifiho-procfailure             level 	transaction <debug level>
logging 	name 	smf-service.smf-app.wifitonrho-procfailure               level 	transaction <debug level>
logging 	name 	smf-service.smf-app.wifitoenbho-procfailure             level 	transaction <debug level>
logging 	name 	smf-service.smf-app.4gdedbrr-procfailure                 level 	transaction <debug level>
logging 	name 	smf-service.smf-app.pdnmodmbr-procfailure            level 	transaction <debug level>
logging 	name 	smf-service.smf-app.5gmodify-procfailure                level 	transaction <debug level>
logging 	name 	smf-service.smf-app.5g4gho-procfailure                   level 	transaction <debug level>
logging 	name 	smf-service.smf-app.n26ho-procfailure                     level 	       transaction <debug level>
NOTES:
  • Warning —The logging level supported for procedure failure LogTags.
config
  logging name smf-service.smf-app.4gdedbrr-procfailure level transaction warn
  logging name smf-service.smf-app.5g4gho-procfailure level transaction warn
  logging name smf-service.smf-app.5gim-procfailure level transaction warn
  logging name smf-service.smf-app.5gmodify-procfailure level transaction warn
  logging name smf-service.smf-app.enbtowifiho-procfailure level transaction warn
  logging name smf-service.smf-app.n26ho-procfailure level transaction warn
  logging name smf-service.smf-app.n2ho-procfailure level transaction warn
  logging name smf-service.smf-app.nrtowifiho-procfailure level transaction warn
  logging name smf-service.smf-app.pdndisconnect-procfailure level transaction warn
  logging name smf-service.smf-app.pdnmodmbr-procfailure level transaction warn
  logging name smf-service.smf-app.pdnsetup-procfailure level transaction warn
  logging name smf-service.smf-app.pdurelease-procfailure level transaction warn
  logging name smf-service.smf-app.pdusetup-procfailure level transaction warn
  logging name smf-service.smf-app.wifitoenbho-procfailure level transaction warn
  logging name smf-service.smf-app.wifitonrho-procfailure level transaction warn
  logging name smf-service.smf-app.xnho-procfailure level transaction warn
exit
Generic Procedure Failure Logs
The following are the synopsis of the Generic Procedure Failure logs to trigger session management policies towards the SMF:
  • On failure, a Generic Transaction log (common to all procedures) with level warning is used to dump the session details as the following:
    • Transaction ID
    • Procedure Name
    • Detailed Error—It contains failure reason or cause, disconnect reason (if applicable) and failure metrics.
  • The Generic Procedure Failure LogTag is common to all procedures.
  • When a specific procedure failure LogTag is disabled and a Generic Procedure Failure LogTag is enabled, then the SMF doesn't print the Event Trace.
  • The Event Trace is printed, only when a specific procedure failure LogTag gets enabled.
  • The Detailed errors note gets printed in the generic procedure failure logs. It helps in understanding the problem, the actual error cause, disconnect reason (if applicable), and failure metrics.
Logging a Message for Generic Procedure Failure Logs
The following is a sample example of a LogTag for Generic Procedure Failure logs:
2023/01/15 10:58:01.171 [WARN] [smf-service.smf-app.procfailure] [Txn :1]Procedure=[PDN Connect [LTE]],
PduState=[IDLE], Rat-Type=[rat_type_unknown], FailureReason=[udm_subscribe_notify_failure],
Configuring the Generic Procedure Failure Logs
logging name smf-service.smf-app.procfailure level transaction <debug level>
NOTES:
  • Warning —The logging level supported for generic procedure failure LogTags.
config
 logging name smf-service.smf-app.procfailure level transaction warn
exit
[smf] smf# show running-config logging name smf-service.smf-app.procfailure
Additional Call Flow Failure Logs
The following are the synopsis of the Additional Call Flow Failure logs to trigger session management policies towards the SMF:
  • Extra LogTags are added for specific procedures.
  • These LogTags can be enabled for specific conditions between the procedure flow.
  • The Additional Call Flow Failure logs help in identifying a procedure lapsed event and reciprocate with a logged warning message in the event trace.
Sample Dump for Additional Call Flow Failure Logs
The following is a sample dump for Additional Call Flow Failure logs:
Example: For a procedure lapsed time of over two seconds, a warning message gets logged with the event trace.
2022/08/23 11:10:31.222 [WARN] [smf-service.smf-app.5gmodify-failure] 2sec Time Elapsed: EVENT TRACE SessionKeys[[imsi-123456789012345:5 (pk)]]
Logging a Message for Additional Call Flow Failure Logs
The following is a sample example of a LogTag for Additional Call Flow Failure logs:
Configuring the Additional Call Flow Failure Logs
Logging	name	smf-service.smf-app.4gdedbrr-failure	level	transaction	<debug level>
logging	     name     smf-service.smf-app.pdnmodmbr-failure     level     transaction     <debug level>
logging	     name     smf-service.smf-app.5gmodify-failure        	 level     transaction     <debug level>
logging	     name     smf-service.smf-app.5g4gho-failure            level     transaction     <debug level>
logging	     name     smf-service.smf-app.n26ho-failure              level     transaction     <debug level>
logging	     name     smf-service.smf-app.wifi-nr-ho                   level     transaction     <debug level>
logging	     name     smf-service.smf-app.datacheck     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.N16     			    	level     transaction     <debug level>
logging	     name     smf-service.smf-app.erir     			    	level     transaction     <debug level>
logging	     name     smf-service.smf-app.flagdb     		    	level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr     				level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-ue     			level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-dup     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-mme     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-pcf     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-ubr     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-absent     	level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-amf     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-chf    		level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-gnb     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-smf     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-udm     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.dcr-brr-ue     		level     transaction     <debug level>
logging	     name     smf-service.smf-app.epsfb     			level     transaction     <debug level>
NOTES:
  • Warning —The logging level supported for additional call flow failure LogTags.
config
  logging name smf-service.smf-app.4gdedbrr-failure level transaction warn
  logging name smf-service.smf-app.5g4gho-failure level transaction warn
  logging name smf-service.smf-app.5gmodify-failure level transaction warn
  logging name smf-service.smf-app.N16 level transaction warn
  logging name smf-service.smf-app.datacheck level transaction warn
  logging name smf-service.smf-app.dcr level transaction warn
  logging name smf-service.smf-app.dcr-brr-absent level transaction warn
  logging name smf-service.smf-app.dcr-brr-amf level transaction warn
  logging name smf-service.smf-app.dcr-brr-chf level transaction warn
  logging name smf-service.smf-app.dcr-brr-dup level transaction warn
  logging name smf-service.smf-app.dcr-brr-gnb level transaction warn
  logging name smf-service.smf-app.dcr-brr-mme level transaction warn
  logging name smf-service.smf-app.dcr-brr-pcf level transaction warn
  logging name smf-service.smf-app.dcr-brr-smf level transaction warn
  logging name smf-service.smf-app.dcr-brr-ubr level transaction warn
  logging name smf-service.smf-app.dcr-brr-udm level transaction warn
  logging name smf-service.smf-app.dcr-brr-ue level transaction warn
  logging name smf-service.smf-app.dcr-ue level transaction warn
  logging name smf-service.smf-app.epsfb level transaction warn
  logging name smf-service.smf-app.erir level transaction warn
  logging name smf-service.smf-app.flagdb level transaction warn
  logging name smf-service.smf-app.n26ho-failure level transaction warn
  logging name smf-service.smf-app.pdnmodmbr-failure level transaction warn
  logging name smf-service.smf-app.wifi-nr-ho level transaction warn
end
Event Trace Logs
The following are the synopsis of the Event Trace logs to trigger session management policies towards the SMF:
  • Event Trace logs provide an execution sequence for a session. It represents the following:
    • Message Type
    • Event Type—Incoming or Outgoing or Internal submitted event type.
    • Procedure Type and Procedure Instance—Where the message is associated with.
    • Txn ID—Where the message is associated with.
    • Timestamp—For the same message associated with
  • Event Trace logs also describe other events as the following:
    • Local2DB—When the session details are derived into a primitive structure.
    • DB2Local—When the session details aren’t derived from DB to Session DS.
    • Procedure Events—When it conveys the END or SUSPEND or ABORT or CLEANUP events also.
Sample Dump for Event Trace Logs
The following is a sample dump for Event Trace logs:
2020/09/10 13:16:16.177 smf-service [DEBUG] [Genericutil.go:5739] [smf-service0.smf-app.event-trace] EVENT TRACE SessionKeys[[imsi-123456789012345:5 (pk)]]
CurIndex:[31], CurProcInst:[1], CreateTimeStamp:[2020-09-10 13:16:15.503 +0000 UTC], BaseTimeStamp:[2020-09-10 13:16:15.503 +0000 UTC]
|1    |N11SmContextCreateReq              |INCOMING_EVENT       |PDU Session Establishment                           |1         |1776      |2020-09-10 13:16:15.503 +0000 UTC  |
|2    |N10RegistrationRequest             |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1776      |2020-09-10 13:16:15.525 +0000 UTC  |
|3    |N10RegistrationSuccess             |INCOMING_EVENT       |PDU Session Establishment                           |1         |1776      |2020-09-10 13:16:15.605 +0000 UTC  |
|4    |N10SubscriptionFetchReq            |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1776      |2020-09-10 13:16:15.606 +0000 UTC  |
|5    |N10SubscriptionFetchSuccess        |INCOMING_EVENT       |PDU Session Establishment                           |1         |1776      |2020-09-10 13:16:15.644 +0000 UTC  |
|6    |N10SubscribeForNotificationReq     |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1776      |2020-09-10 13:16:15.65 +0000 UTC   |
|7    |N10SubscribeForNotificationSuccess |INCOMING_EVENT       |PDU Session Establishment                           |1         |1776      |2020-09-10 13:16:15.67 +0000 UTC   |
|8    |NIntSelfTxnPduSetup                |INTERNAL_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.67 +0000 UTC   |
|9    |Message Type None                  |LOCAL_2_DB           |Unknown                                             |0         |0         |2020-09-10 13:16:15.671 +0000 UTC  |
|10   |N11SmContextCreateSuccess          |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1776      |2020-09-10 13:16:15.711 +0000 UTC  |
|11   |NIntSelfTxnPduSetup                |INCOMING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.712 +0000 UTC  |
|12   |N7SmPolicyCreateReq                |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.712 +0000 UTC  |
|13   |N7SmPolicyCreateSuccess            |INCOMING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.797 +0000 UTC  |
|14   |NmgrRersourceMgmtRequest           |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.805 +0000 UTC  |
|15   |NmgrRersourceMgmtResponse          |INCOMING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.814 +0000 UTC  |
|16   |N7SmPolicyUpdateReq                |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.823 +0000 UTC  |
|17   |N7SmPolicyUpdateSuccess            |INCOMING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.853 +0000 UTC  |
|18   |N40ChargingDataReq                 |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.854 +0000 UTC  |
|19   |N40ChargingDataSuccess             |INCOMING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.912 +0000 UTC  |
|20   |N4SessionEstablishmentReq          |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.921 +0000 UTC  |
|21   |N4SessionEstablishmentSuccess      |INCOMING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.986 +0000 UTC  |
|22   |N11EbiAssignmentReq                |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:15.99 +0000 UTC   |
|23   |N11EbiAssignmentRsp                |INCOMING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:16.017 +0000 UTC  |
|24   |N11N1N2MessageTransferReq          |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:16.021 +0000 UTC  |
|25   |N11N1N2MessageTransferSuccess      |INCOMING_EVENT       |PDU Session Establishment                           |1         |1777      |2020-09-10 13:16:16.096 +0000 UTC  |
|26   |Message Type None                  |LOCAL_2_DB           |Unknown                                             |0         |0         |2020-09-10 13:16:16.096 +0000 UTC  |
|27   |N11SmContextUpdateReq              |INCOMING_EVENT       |PDU Session Establishment                           |1         |1778      |2020-09-10 13:16:16.111 +0000 UTC  |
|28   |N4SessionModificationReq           |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1778      |2020-09-10 13:16:16.114 +0000 UTC  |
|29   |N4SessionModificationSuccess       |INCOMING_EVENT       |PDU Session Establishment                           |1         |1778      |2020-09-10 13:16:16.155 +0000 UTC  |
|30   |N4GtpuRouterAdvertisementReq       |OUTGOING_EVENT       |PDU Session Establishment                           |1         |1778      |2020-09-10 13:16:16.156 +0000 UTC  |
|31   |N4SessionModificationSuccess       |ENDPROC_EVENT        |PDU Session Establishment                           |1         |1778      |2020-09-10 13:16:16.175 +0000 UTC  |
Logging a Message for Event Trace Logs
The following is a sample example of a LogTag for Event Trace logs:
Configuring the Event Trace Logs
logging name smf-service.smf-app.event-trace level transaction debug-level
NOTES:
  • Warning | Error —The logging level supported for Event Trace LogTags.
  • Session Keys | Procedure Name | Event Trace —The logging level parameters supported for Event Trace LogTags.
logging name smf-service.smf-app.event-trace level transaction warn
[smf] smf# show running-config logging name smf-service.smf-app.event-trace
Call Flow Statistics Logs
The following are the synopsis of the Call Flow Statistics Logs to trigger session management policies towards the SMF:
  • Currently, each call flow has the following general labels and other specific labels:
    • Attempted
    • Success
    • Failure + Reason
  • All the call flow statistics gets integrated with EndProcedure.
  • Each DispositionEnd used to end the call flow in the procedure, concludes either as a success or a failure scenario. Each failure scenario has a reason for integration as well.
  • Failure causes can be classified into different levels. They are further mapped and classified as the following:
    • Major or Error
      • Internal Error—All internal errors due to which the call flow is failing, are categorized as error.
      • Transaction Timeout Error—On interfaces, outbound response timeouts (transaction timeouts) are categorized as errors.
    • Minor or Warning
      • Server Error—On interfaces, outbound responses with the http status code 5xx (server errors) are categorized as a warning.
      • Client Error—On interfaces, inbound responses with the http status code 4xx (client errors) or timeouts are categorized as a warning.
    • Normal
      • Server Error—On interfaces, inbound responses with the http status code 5xx (server errors) are categorized as normal.
      • Client Error—On interfaces, outbound responses with http status code 4xx (client errors) are categorized as normal.
  • Unknown—Those scenarios, where the call flow gets failed, but the reason doesn't get populated, fall under the unknown cause.
  • Further, these scenarios can be enhanced to cases, other statistics labels of statistics, which get integrated to empty statuses.
    Example: RAT type integrated as empty, DNN type not integrated, and so on.
Configuring the Call Flow Statistics Logs
logging name smf-service.smf-app.stats-debug level transaction debug-level
NOTES:
  • Warning | Error —The logging level supported for call flow statistics LogTags.
logging name smf-service.smf-app.stats-debug level transaction warn
[smf] smf# show running-config logging name smf-service.smf-app.stats-debug
Core Dump Utility Logs
The following are the synopsis of the Core Dump Utility Logs to trigger session management policies towards the SMF:
  • The Core Dump Utility logs provide functionality to conditionally generate a core dump for debugging purposes.
  • The core file generation doesn’t kill the process and it continues to execute as usual.
  • The core dump functionality is disabled by default and it needs to be enabled by specifying the appropriate configurable parameters.
Important
The core dump generation is a performance impacting activity. Hence, it’s recommended to restrict the core dump to a minimum number, such as one or two core dumps for every 15 minutes. As a result, you need to fine-tune the core dump, if you see any performance impact.
Logging a Message for Core Dump Utility Logs
The following is a sample example of a LogTag for Core Dump Utility Logs:
2022/10/14 09:14:38.809 [WARN] [smf-service.smf-app.pdusetup-procfailure] [Txn Id: 3] {PDU Session Establishment} -> COREDUMP ->
Generating Core: current core count 1, File:/opt/workspace/smf-service/src/smf-service/procedures/pdusetup/procedure.go:612
2022/10/14 09:15:38.817 [WARN] [smf-service.smf-app.pdusetup-procfailure] {PDU Session Establishment} -> COREDUMP ->
Generating Core: current core count 2, File:/opt/workspace/smf-service/src/smf-service/procedures/generic/CallFailureDebug.go:70
Configuring the Core Dump Utility Logs
config
    dump core [ count count_number | interval interval_details | expires expires_details | pod-name pod_name | file-detail file_detail ]
    end
NOTES:
  • count count_number —Specify the maximum number of times the core dump can be taken. Example: Two core dumps can be taken in a span of 15 minutes, where two is the count. Range: 0-50
  • interval interval_details —Specify the total duration of the interval (in minutes) to take the core dumps. Example: Two cores can be taken in a span of 15 minutes, where 15 minutes is the total interval time to take two core dumps. Range: 1-3600
  • expires expires_details —Specify the time after which a core agent stops generating a core dump. Format: CCYY-MM-DDTHH:MM:SS, with an example: 2020-03-24T23:15:00+05:30 or 2022-10-17T19:00:00+00:00
  • pod-name pod_name —List the name of the pod to enable core dump activities.
  • file-detail file_detail —List the file name, line number to a specific core dump. Example: Procedures or PDUIM or procedure.go:1902, the maximum size is 10.
dump core count 2 interval 15 expires pod-name [ smf-service-n0-0 smf-service-n0-1 ]
file-detail [ procedures/generic/CallFailureDebug.go:70 procedures/pdusetup/procedure.go:612 ]
[smf] smf# show running-config dump core
dump core
count 2 interval 15 expires 2023-01-18T18:00:00-00:00 pod-name [ smf-service-n0-0 smf-service-n0-1 ] file-detail [ procedures/generic/CallFailureDebug.go:70 procedures/pdusetup/procedure.go:612 ]
exit
Monitor Subscriber (MonSub) Logs
The following are the synopsis of the Monitor Subscriber (MonSub) Logs to trigger session management policies towards the SMF:
  • The logs help to control the logging level of transaction logs, when the monitor subscriber CLI gets enabled.
  • The Monitor Subscriber CLI captures the transaction logs for a given SUPI or IMSI.
  • The Monitor Subscriber Logger uses a specific logging level, used for the subscriber, for which the monitor subscriber CLI gets triggered.
  • The SMF must support per-subscriber monitoring activities. If required, it must be used to monitor a particular subscriber based on the appropriate configurable parameters, such as SUPI or IMSI.
  • As a default value, the monitor subscriber functionality is disabled. It gets enabled manually by specifying the appropriate configurable parameters.
Logging a Message for MonSub Logs
The following is a sample example of a LogTag for MonSub Logs:
smf# monitor subscriber imsi 123456789012345 capture-duration 3600 transaction-logs yes
internal-messages yes
Fri Oct 14 09:05:53.902 UTC+00:00
supi: imsi-123456789012345
captureDuration: 3600
enableInternalMsg: true
enableTxnLog: true
namespace(deprecated. Use nf-service instead.): none
nf-service: none
gr-instance: 0
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 318 100 116 100 202 12888 22444 --:--:-- --:--:-- --:--:-- 35333
Command: --header Content-type:application/json --request POST --data
{"commandname":"mon_sub",
"parameters":{"supi":"imsi-123456789012345",
"duration":3600,"enableTxnLog":true,"enableInternalMsg":true,
"action":"start","namespace":"none","nf-service":"none",
"grInstance":0}} http://oam-pod:8879/commands
Result start mon_sub,
fileName ->logs/monsublogs/none.imsi-123456789012345_WithTxnLogs_TS_2022-10-14T09:05:53.926268924.txt
Starting to tail the monsub messages from
file: logs/monsublogs/none.imsi-123456789012345_WithTxnLogs_TS_2022-10-14T09:05:53.926268924.txt
Defaulted container "oam-pod" out of: oam-pod, apache
Transaction Log received from Instance: SMF.nodemgr.DC.SMF.1
************* TRANSACTION: 00166 *************
TRANSACTION SUCCESS:
Start Time : 2022/10/14 09:07:24.449
GR Instance ID : 1
Txn Type : GtpcAssocEstReq(2114)
Priority : 1
Session Namespace : none(0)
CDL Slice Name : 1
LOG MESSAGES:
2022/10/14 09:07:24.449 [TRACE] [infra.message_log.core] >>>>>>>>
IPC message
MessageType: GtpcAssocEstReq
Key:
--body--
{"IPv4address":167844075,"restart_counter":65535,
"nodemgr_instance_id":1,"timestamp":1665738444,
"gtpcPathStatus":2,"gtpcInterfaceType":4,"ddnInfo":{},
"gr_instance_id":1,"isNodeStarted":true}
2022/10/14 09:07:24.449 [DEBUG] [nodemgr1.app.Int] GetSessionNamespace for txn id: 166, Type: 2114
2022/10/14 09:07:24.449 [DEBUG] [nodemgr.gtpmgr.gtp] Received New GTP Peer info
[&GtpcAssocEstReq{IPv4Address:167844075,IPv6Address:[],SupportedFeatures:0,RestartCounter:65535,
NodemgrInstanceId:1,Timestamp:1665738444,OverloadControl:nil,GtpcPathStatus:GTPC_PATH_UP,
GtpcInterfaceType:4,DdnInfo:&DdnInfo{DelayValid:false,ThrottleValRcvd:false,ThrottleActive:false,
DelayValue:0,ThrottleDelayValue:0,ThrottleDelayUnit:0,ThrottleFactor:0,},GrInstanceId:1,
IsNodeStarted:true,SelfRCVal:0,PeerType:0,DeletedAt:0,}]
2022/10/14 09:07:24.449 [INFO] [nodemgr.gtpmgr.gtp] GTPC Path Mgmt Disabled for interface [4]
2022/10/14 09:07:24.449 [INFO] [nodemgr.gtpmgr.gtp] Rcvd timestamp 1665738444, stored timestamp 1665738177
peer 10.1.24.235
2022/10/14 09:07:24.449 [DEBUG] [nodemgr.gtpmgr.gtp] Assoc req for already present peer [10.1.24.235]
2022/10/14 09:07:24.449 [DEBUG] [nodemgr.gtpmgr.gtp] stop timer for existing gtp-peer [10.1.24.235]
2022/10/14 09:07:24.451 [TRACE] [infra.message_log.core] <<<<<<<<
************* TRANSACTION: 00167 *************
Start Time : 2022/10/14 09:07:34.061
GR Instance ID : 1
Priority : 1
CDL Slice Name : 1
LOG MESSAGES:
2022/10/14 09:07:34.062 [TRACE] [infra.message_log.core] >>>>>>>>
IPC message
Key:
--body--
{"IPv4address":167844075,"restart_counter":100,"timestamp":1665738454,"gtpcInterfaceType":4,
"ddnInfo":{},"isNodeStarted":true}
2022/10/14 09:07:34.062 [DEBUG] [nodemgr1.app.Int] GetSessionNamespace for txn id: 167, Type: 2114
2022/10/14 09:07:34.062 [DEBUG] [nodemgr.gtpmgr.gtp] Received New GTP Peer info
[&GtpcAssocEstReq{IPv4Address:167844075,IPv6Address:[],SupportedFeatures:0,RestartCounter:100,
NodemgrInstanceId:0,Timestamp:1665738454,OverloadControl:nil,GtpcPathStatus:GTP_PATH_INVALID,
DelayValue:0,ThrottleDelayValue:0,ThrottleDelayUnit:0,ThrottleFactor:0,},GrInstanceId:0,
2022/10/14 09:07:34.062 [INFO] [nodemgr.gtpmgr.gtp] GTPC Path Mgmt Disabled for interface [4]
2022/10/14 09:07:34.062 [INFO] [nodemgr.gtpmgr.gtp] Rcvd timestamp 1665738454,
stored timestamp 1665738444 peer 10.1.24.235
2022/10/14 09:07:34.062 [DEBUG] [nodemgr.gtpmgr.gtp] Assoc req for already present peer [10.1.24.235]
2022/10/14 09:07:34.062 [DEBUG] [nodemgr.gtpmgr.gtp] stop timer for existing gtp-peer [10.1.24.235]
2022/10/14 09:07:34.065 [TRACE] [infra.message_log.core] <<<<<<<<
Configuring the Monitor Subscriber Logs
config
    monitor subscriber [ supi supi_id | imsi imsi_value | imei imei_id | capture-duration capture_duration | dump dump_name | gr-instance gr_instance_id | internal-messages internal_messages | list list_details | namespace namespace_details | nf-service nf_service_details | transaction-logs transaction_logs ]
    end
NOTES:
  • supi supi_id —Specify the subscriber identifier. For example, imsi-123456789, imsi-123*
  • imsi imsi_value —Specify the subscriber IMSI. For example: 123456789, *
  • imei imei_id —Specify the subscriber IMEI. For example: 123456789012345, *
  • capture-duration capture_duration —Specify the duration in seconds during which the monitor subscriber activity gets captured. The default is 300 seconds (five minutes). It's an optional parameter.
  • dump dump_filename —Specify the name of the dump filename. Example: monitor subscriber-dump [filename]
  • gr-instance gr_instance_id —Specify the GR instance ID. It's an optional parameter. It's a monitor subscriber for the given gr-instance only. The instance ID 1 denotes the local instance ID.
  • internal-messages internal_messages —When set to yes, it enables internal messaging. By default, a disabled value It's an optional parameter.
  • list list_details —Specify the details of the list. It includes the monitor subscriber list files.
  • namespace namespace_details —Enable the specified namespace. By default, the namespace is set to none. It's an optional parameter.
    Note
    A deprecated keyword in the release 2021.02.0 and replaced with nf-service as the keyword
  • nf-service nf_service_details —Enable the specified NF service. By default, nf-service is set to none. It's a mandatory parameter. The possible values: sgw, smf, pgw
    Note
    The nf-service keyword replaces the namespace keyword in the release 2021.02 and onwards.
  • transaction-logs transaction_logs —Enable transaction logs when set to yes. By default, a disabled value. It's an optional parameter.
    Note
    To view the transaction history logs, use the dump transaction history command. The latest transaction logs get stored in a circular queue of size 1024 transaction logs.
Important
The MonSub needs subscriber SUPI or IMSI in monitor subscriber command. The following are important actions:
  • As a prerequisite, the SMF must print the subscriber SUPI or IMSI in the logs.
  • Currently, SMF transaction logs are printing subscriber session keys which include subscriber SUPI or IMSI in the transcation logs.
  • The operator can pick the subscriber SUPI or IMSI from these logs.
logging level monitor-subscriber info
logging name infra.message_log.core level monitor-subscriber debug
N40 Additional Logs and Statistics
The following are the synopsis of the additional logs and statistics for N40 to trigger session management policies towards the SMF:
  • Enhances the current message-level statistics for rest-ep consisting of extra LogTag or labels, as the following:
    • DNN type
    • RAT type
    • PDN type
    • Procedure type
    • Types of error cause, when there are errors.
    • Interface failure
  • When the current message-level statistics get enhanced, the redundant statistics from the SMF-Service such as Message-level statistics can be removed, as the rest-ep already consists of the same message.
  • The problems and their details can be updated for all the CHF-initiated messages as the following:
    • Notify
    • For Abort
    • Re-Auth
  • The transaction logging levels and the LogTag for the additional logs and statistics for N40 must be in sync. In the event of a failure scenario, the applicable LogTag for N40 must be added. They are as the following:
    • Major (Error)
    • Minor (Warning)
    • Normal (Info)
  • When the logging level gets enabled with the corresponding category, the following options are available:
    • Event Trace
    • Core Dump
Configuring the N40 Additional Logs and Statistics
To configure this feature use the following configuration:
logging name smf-service.smf-app.chf level transaction debug-level
NOTES:
  • Warning | Error —The logging level supported for the N40 additional logs and statistics LogTags.
logging name smf-service.smf-app.chf level transaction warn
[smf] smf# show running-config logging name smf-service.smf-app.chf
N7 Additional Logs and Statistics
The following are the synopsis of the additional logs and statistics for N7 to trigger session management policies towards the SMF:
  • It detects HTTP error codes for the PCF initiated update notification and terminate messages containing problem details.
    • DNN type
    • RAT type
    • PDN type
    • Procedure type
    • Interface failure
  • The transaction logging levels and LogTag for the additional logs and statistics for N7 must be in sync. They are as the following:
    • Error
    • Warning
    • Info
    • Event Trace
    • Core Dump
Configuring the N7 Additional Logs and Statistics
logging name smf-service.smf-app.pcf level transaction debug-level
NOTES:
  • Warning | Error —The logging level supported for N7 additional logs and statistics LogTags.
logging name smf-service.smf-app.pcf level transaction warn
[smf] smf# show running-config logging name smf-service.smf-app.pcf
