IPv6 PDU Sessions
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area SMF
Applicable Platform(s) SMI
Feature Default Setting Enabled – Always-on
Related Changes in this Release Not Applicable
Related Documentation Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
Added permissible range values for the following commands in ICMPv6 Profile configuration options.
  • mtu
  • reachable-time
  • retrans-timer
2021.02.1
First introduced.
Pre-2020.02.0
Feature Description
SMF supports ICMPv6 Router Solicit and Advertisement to comply to IPv6 Stateless Auto-configuration.
Router Advertisement supports the following ICMPv6 options:
  • Prefix Information—Sends the allocated UE IPv6 prefix.
  • MTU—Takes the MTU size from the configuration. Default is 1500.
  • Source Link Layer Address—Takes the value from the configured local virtual MAC.
Unsolicited Router Advertisement
The SMF sends unsolicited router advertisement on successful PDU Session Establishment to share the allocated IPv6 prefix to UE. RA message is sent over the GTPU tunnel, which is created between SMF and UPF during the session establishment procedure. SMF also installs PDRs and FARs on the UPF to enable routing for RS and RA messages.
Figure 1. Router Advertisement Message Processing Call Flow
Note
The UPF cannot generate or send the unsolicited router advertisement to the UE as the IPv6 prefix allocation is performed by SMF.
Solicited Router Advertisement
To get the allocated IPv6 prefix, UE sends a router solicit message. Upon receiving the router solicit message, SMF sends the router advertisement message containing the allocated UE IPv6 prefix towards UE.
Figure 2. Router Solicitation and Advertisement Message Processing Call Flow
Configuring Router Solicit and Router Advertisement
This section describes how to configure the Router Solicit and Router Advertisement feature.
Configuring the Router Solicit and Router Advertisement feature involves the following:
Configuring Router Advertisement Parameters
To configure the Router Advertisement parameters, use the following sample configuration:
config
   profile icmpv6 icmpv6profile_name
      options { hop-limit hop_limit | mtu mtu_size | reachable-time reachable_time | retrans-timer retrans_timer | router-lifetime router_lifetime | virtual-mac virtual_mac }
      ra trigger handover { false | true }
      end
NOTES:
  • profile icmpv6 icmpv6profile_name : Specify the ICMPv6 profile name. icmpv6profile_name must be an alphanumeric string.
  • options { hop-limit hop_limit | mtu mtu_size | reachable-time reachable_time | retrans-timer retrans_timer | router-lifetime router_lifetime | virtual-mac virtual_mac } : Configure the ICMPv6 options.
    • hop-limit hop_limit : Configure the hop limit. hop_limit must be an integer in the range of 0–255. Default: 255.
    • mtu mtu_size : Configure the MTU size. Default: 1500.
      mtu_size must be an integer in the range of 1280-1500.
    • reachable-time reachable_time : Configure the reachable time in milliseconds. Default: 0.
      reachable_time must be an integer in the range of 0-3600.
    • retrans-timer retrans_timer : Configure the retransmission timer in milliseconds. Default: 0.
      retrans_timer must be an integer in the range of 0-4294968.
    • router-lifetime router_lifetime : Configure the router lifetime in seconds. router_lifetime must be an integer in the range of 0–65535. Default: 65535.
    • virtual-mac virtual_mac : Configure the local virtual MAC address.
  • ra trigger handover { false | true } : Configure the trigger to send router advertisements for Wi-Fi handovers.
Verifying the Configuration
Use the show running-config profile icmpv6 command to verify the Router Advertisement configuration.
The following configuration is an example output of the command:
[unknown] smf(config)# show running-config profile icmpv6
profile icmpv6 icmpprf1
 options hop-limit 255
 options mtu   1500
 options reachable-time 0
 options retrans-timer 0
 options router-lifetime 65535
 options virtual-mac b6:6d:57:45:45:45
 ra trigger handover true
exit
Configuring Virtual MAC Address
To configure the remote virtual MAC address in the DNN profile, use the following sample configuration:
config
   profile dnn dnnprofile_name
      virtual-mac mac_address
      exit
NOTES:
  • profile dnn dnnprofile_name : Specify the DNN profile name. dnnprofile_name must be an alphanumeric string.
  • virtual-mac mac_address : Specify the remote virtual MAC address used to generate interface ID for UE. mac_address must be a string in the MAC address pattern.
In release 2021.01 and later, the SMF generates unique 64-bit interface ID which is non-EUI-64 format by using SBI VIP address and CommonId of the subscriber.
That is, IPv6 interface ID = VIP-IP (4 bytes) + CommonId (4 bytes)
By default, virtual-mac CLI command is now disabled under DNN configuration.
Table 3. Interface ID for Different Messages
Call Model
PDU Session Establishment Accept
Create Session Response
5G
N11-SBI-VIP+CommonID
4G
GTP-VIP+CommonID
WiFi
GTP-VIP+CommonID
5G->4G
—(N26 HO - there are NAS contents during handover)
4G->5G
— (N26 HO - there are NAS contents during handover)
4G->WiFi
GTP-VIP+CommonID (Same as 4G)
WiFi->4G
5G->WiFi
N11-SBI-VIP+CommonID (Same as 5G)
WiFi->5G
GTP-VIP+CommonID (Same as WiFi)
Associating the ICMPv6 Profile with SMF Service Profile
To associate the ICMPv6 profile with the SMF service profile, use the following sample configuration:
config
   profile smf smfprofile_name
      service name svc_name
         icmpv6-profile icmpv6profile_name
         exit
NOTES:
  • profile smf smfprofile_name : Specify the SMF service profile name. smfprofile_name must be an alphanumeric string.
  • service name svc_name : Specify the name of the SMF network function service. svc_name must be an alphanumeric string.
  • icmpv6-profile icmpv6profile_name : Specify the load profile name to associate with the SMF service profile. icmpv6profile_name must be an alphanumeric string.
