Failure Handling Support
Summary Data
Table 1. Summary Data
Applicable Products or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Disabled - Configuration Required
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
Enhanced the existing failure handling configuration of N4SessionModificationReq message to support cause codes 0-255.
2021.02.3
Enhanced the existing failure handling configuration of N4SessionModificationReq message to include conditions to control the session termination based on predefined procedures.
2021.02.3
Added retransmission support for the following request messages:
  • Namf_Communication EBI Assignment Request
  • Namf_Communication N1 N2 Message Transfer Request
2021.02.2
Added permissible range values for response-timeout command in the PCF and UDM configuration
2021.02.0
RAT type FHT support and graceful timeout handling and its related statistics introduced.
2021.01.0
First introduced.
Pre-2020.02.0
Feature Description
The system performs error handling by segregating error codes into recoverable and non-recoverable error codes. It attempts to recover the endpoints with continuous retries when SMF receives recoverable errors from the NRF server for messages, such as NF Registration, NF Update, NF Heart Beat, and so on. This feature provides a flexible way for handling errors during the NRF interactions with SMF and other network functions, such as Charging Function (CHF), Network Repository Function (NRF), Policy Control Function (PCF), Unified Data Management (UDM), and User Plane Function (UPF).
This feature supports the following functionality:
  • Configurable retry actions for specific error codes, which occur during the NRF interactions with other NFs.
  • Flexibility to decide on a retry action for an error code after retrying all the endpoints in an NRF.
  • CLI configuration under the profile nf-client-failure template to configure the error codes and the corresponding retry actions for NRF messages. You can also configure a failover option for an error code after retrying all the endpoints in an NRF.
  • Provides HTTPv2 status code range support in the failure handling templates of other NFs.
Access and Mobility Management Function Failure Handling
Feature Description
The SMF supports failure handling of the Access and Mobility Management Function (AMF). Based on the request messages, SMF supports retransmission to the same endpoint.
How it Works
SMF provides retransmission support for the following request messages:
When SMF doesn't receive a response for the preceding messages, SMF retransmits the message to the same endpoint. SMF starts the internally configured timer after sending these messages to the AMF. The timer stops after SMF receives a response from the AMF. In case the timer expires while waiting for a response, SMF uses the retry mechanism for which you have configured the number of retry attempts.
Configuring Retransmission for Request Messages
To configure retransmission for the Namf_Communication EBI Assignment and Namf_Communication EBI Assignment messages, use the following sample configuration:
config
   profile nf-client-failure nf-type amf
      profile failure-handling failure_handling_name
      service name type namf-comm
         message type { AmfCommEBIAssignment | AmfCommN1N2MessageTransfer | AmfCommSMStatusChangeNotify }
         status-code httpv2 status_code
         retransmit retransmit_value
         retransmit interval retransmit_interval_value
         retry retry_value
         action retry-and-continue
      exit
   exit
NOTES:
  • service name type namf-comm : Specify the AMF service name type as namf-comm.
  • message type { AmfCommEBIAssignment | AmfCommN1N2MessageTransfer | AmfCommSMStatusChangeNotify } : Specify the message type of the namf-comm AMF service name type as AmfCommEBIAssignment , AmfCommN1N2MessageTransfer , or AmfCommSMStatusChangeNotify .
  • status-code httpv2 status_code : Specify the status code of the service. The status_code must be an integer in the range of 0–599.
  • retransmit retransmit_value : Specify the maximum retransmission value for the same endpoint. The retransmit_value must be an integer in the range of 1–10.
    If SMF sends message and receive an error in the HTTP status code and if you have configured a valid retransmit count, then that number of retransmission attempts are made to the same endpoint. The maximum retransmit count is used from the first-time configuration of the HTTP status code.
    If SMF receives failure error HTTP code even after retransmission, then SMF retransmits to the same endpoint in the following conditions:
    • If valid retransmit counts are configured for the first HTTP status code that SMF received.
    • If a valid retransmit count, which must not be zero, exists for the received HTTP error code.
  • retransmit interval retransmit_interval_value : Specify the retransmission interval value in milliseconds. The default value is 1000.
    If you have configured the retransmit interval, then SMF waits for the timeout between retransmissions.
  • retry retry_value : Specify the number of retry attempts to the different available endpoints. The retry_value must be an integer in the range of 1–10.
  • action retry-and-continue : Specify the retry as per the configured retry count and continue the session.
Configuration Example
The following is an example configuration of the retransmission for the Namf_Communication EBI Assignment message:
config
      profile failure-handling FHAMF
         message type AmfCommEBIAssignment
         status-code httpv2 504
         retransmit 1
         retransmit interval 1000
         retry 1
      exit
   exit
Charging Function Failure Handling
Feature Description
The SMF supports failure handling of the Charging Function (CHF) server. In the event of the failure of an online CHF server, the SMF relays the charging information to the offline CHF server.
For a seamless transfer of charging information, the SMF invokes the configurations associated with the CHF failure handling profile. If you have configured failure handling, the SMF continues the session with the selected CHF configured in another profile.
SMF supports failure handling of the Charging Function (CHF) server at the following levels.
  • HTTP-level status code
For information on how to select the charging server, see the CHF Selection section in the Subscriber Charging chapter of this guide.
How it Works
This section describes how the offline failover support for charging feature works.
Handling a CHF Server Failure
The CHF server failure occurs when the selected CHF sends failure response or sends no response. For a CHF server failure, the NF library sends status code that is based on the failure template. This template is associated with the CHF network profile. The smf-service sends the profile information to smf-rest-ep while sending the IPC message.
The failure template is configured with the list of HTTP error codes and the associated failure actions and retry count, as required. This feature supports the failure actions:
  • Retry and Continue—For this failure action, NF library attempts until the configured number of times before fallback. After the configured number of times complete, the NF library falls back to the lower priority CHF server IP address. If a failure or no response is received from the CHF server, the "continue" action is returned to the smf-service.
  • Terminate—For this failure action, NF library does not attempt to send a message to other CHF servers. The library sends a reply to smf-service with the action as "terminate". For the "terminate" failure action, the smf-service deletes the session.
  • Continue—For this failure action, the smf-service continues the session and sends the charging message to the offline CHF server. This server is configured as part of the local static CHF profile that is meant for offline purposes. In addition, the failure handling profile for offline CHF is configured.
Note
For the "continue" failure action, you can configure the offline CHF server at SMF in a separate profile. SMF will use this profile after the CHF server failure. If the offline CHF server is not confgured, the session is continued without imposing any charging.
Relaying to an Offline CHF Server
After CHF server failure, when the SMF continues, it converts the ongoing charging services as follows:
  • Converts the services with both online and offline charging method to the offline charging method.
  • Converts the services with online charging method to the offline charging method.
  • No change for the services with the offline charging method.
HTTP Cause Code Mapping with Failure Actions
The following table lists the mapping of failure actions with the associated HTTP cause code. Based on the network requirements, you can change the mapping.
Table 3. HTTP Cause Code Mapping with Failure Actions
Http-2 Cause Codes and Description Converged CHF Failure Action Offline CHF Failure Actions
Code Description CDR-I CDR-U CDR-T CDR-I CDR-U CDR-T
400 Bad Request Terminate No config No config Terminate No config No config
403 Forbidden Terminate No config No config Terminate No config No config
404 Not found Terminate No config No config Terminate No config No config
405 Method Not allowed Retry and Continue Retry and Continue Retry and Continue Terminate No config No config
408 Request Timeout Retry and Continue Retry and Continue Retry and Continue Terminate Retry and Continue Retry and Continue
500 Internal Server Error Retry and Continue Retry and Continue Retry and Continue Terminate Retry and Continue Retry and Continue
503 Service Unavailable Retry and Continue Retry and Continue Retry and Continue Terminate Retry and Continue Retry and Continue
508 Gateway Timeout Retry and Continue Retry and Continue Retry and Continue Terminate Retry and Continue Retry and Continue
0 No reply from server Retry and Continue Retry and Continue Retry and Continue Terminate Retry and Continue Retry and Continue
SMF Behaviour for Failure Actions
The following table describes the SMF behaviour on receiving different failures (Continue, Ignore, and Terminate) in CDR-(I/U/T).
CHF Failure Actions
Converged CHF
Offline CHF
CDR-I
CDR-U
CDR-T
CDR-I
CDR-U
CDR-T
Continue
Send CDR to offline CHF. If offline CHF is not configured, continue the session without charging.
Send CDR to offline CHF if offline CHF is configured
Continue the session without charging
Continue the session deletion
Terminate
Delete the session
Delete the session
Delete the session
Delete the session
Ignore
Delete the session
No action taken. Record(s) will be reattempted in the next CDR request.
Delete the session
Standards Compliance
The offline failover support for charging feature complies with the following standards:
  • 3GPP TS 32.255, version 15.3.0
  • 3GPP TS 32.290, version 15.4.0
  • 3GPP TS 32.291, version 15.3.0
Limitations
The offline failover support for charging feature has the following limitation:
  • Session Level limits are mandatory from CHF or you must configure them locally. As per the 3GPP specification, the last linked URR can’t be removed when the online URR needs to be delinked from the offline URR.
Configuring CHF Failure Handling
This section describes how to configure the CHF failure handling.
This feature involves the following steps:
  1. Configuring Failure Handling Profile
  2. Configuring Offline Server Client and Offline Failure Handling Profile
You can configure the HTTP status code with the corresponding action for the CHF Create, Update, or Release messages. Based on the configuration of the Failure Handling profile, the SMF takes an action when the CHF server failure occurs.
To configure the failure handling profile, use the following sample configuration:
config
   profile nf-client-failure nf-type chf
      profile failure-handling fh_profile_name
         service name type servicename_type
            message type messagetype_value
               status-code httpv2 statuscode_value
                  action { continue | retry-and-continue | retry-and-ignore | retry-and-terminate } retry retry_value
                  exit
NOTES:
  • profile nf-client-failure nf-type chf : Specify the name of the network function that is required after the NF client failure.
  • profile failure-handling fh_profile_name : Specify the name of the profile for failure handling.
  • service name type servicename_type : Specify the name of the service type. servicename_type can be one of the following values for CHF:
    • nchf-convergedcharging
    • nchf-spendinglimitcontrol
  • message type messagetype_value : Specify the value for the type of message. messagetype_value can be one of the following values for CHF:
    • ChfConvergedchargingCreate
    • ChfConvergedchargingUpdate
    • ChfConvergedchargingDelete
  • status-code httpv2 statuscode_value : Specify the status code as per the configured failure template. statuscode_value must be an integer in the range of 0–599. Use either '-' or ' as separator for the range of status codes.
  • action { continue | retry-and-continue | retry-and-ignore | retry-and-terminate } retry retry_value : Specify the failure action and the number of retry attempts. retry_value must be an integer in the range of 1–10.
To configure the offline client profile and offline failure handling profile for the selected CHF server, use the following sample configuration:
config
   profile network-element chf chf_name
      nf-client-profile nf_client_profile_name
      failure-handling-profile fh_profile_name
      nf-client-profile-offline offline_server_profile_name
      failure-handling-profile-offline fh_profile_offline_name
      exit
NOTES:
  • profile network-element chf chf_name : Specify the name of the CHF server.
  • nf-client-profile nf_client_profile_name : Specify the name of the NF client profile.
  • failure-handling-profile fh_profile_name : Specify the name of the failure handling profile.
  • nf-client-profile-offline offline_server_profile_name : Specify the NF client profile name for the offline server.
  • failure-handling-profile-offline fh_profile_offline_name : Specify the failure handling profile name for the offline server.
Network Repository Function Failure Handling
Feature Description
The Network Repository Function (NRF) communication failure handling logic is implemented within the SMF. The SMF uses the NF registration messages for tracking the management NRF group operational status.
How it Works
The following figure shows how the SMF handles NRF failures.
In the preceding diagram, NRF 1 is Primary and NRF 2 is secondary for SMF. On bringing up, the SMF registers (NF registration) with NRF 1 and starts NF heartbeat with NRF 1. The SMF uses the heartbeat response to track the operational status.
In case the SMF detects NRF 1 failure by missing NF heartbeat response, the SMF registers to NRF 2 (secondary NRF) and starts sending NF heartbeat. The SMF continues to send NF Register message to NRF 1 to keep track of its status.
If the SMF receives register response from NRF 1, it detects that the NRF 1 is up again. The SMF marks NRF 1 as active once it recovers and stops sending NF heartbeats to NRF 2.
Note
NF Reregistration (default behavior) on failover and fallback is configuration driven. When NRF 2 detects that the SMF has stopped sending heartbeats, it checks from NRF 1 if it has received SMF registration by using discovery with SMF instance ID.
As the management and discovery endpoint groups are separate, the Registration based operation status check is not used for NRF failure handling during NF discovery. During NF discovery, the configured NRF endpoints within the group are attempted in the priority order. If the first choice NRF endpoint is not responding, the next best NRF endpoint is chosen.
Call Flow
The following diagram shows the basic NF management call flow covering the NF registration, NF management and the NRF failure handling.
Figure 1. NF Management Call Flow
Configuring NRF Failure Handling
This section provides the NRF configurations that are required for the failure handling of other NFs.
Configuring the Failure Handling Template
To configure the failure handling template, use the following sample configuration:
config
   profile nf-client-failure { nf-type { amf | chf | nrf | pcf | udm }
      end
NOTES:
  • profile nf-client-failure { nf-type { amf | chf | nrf | pcf | udm } : Specify the required NF client failure profile and provide the local configuration support for the following configured NFs:
    • amf : Enable the AMF local configuration
    • chf : Enable the CHF local configuration
    • nrf : Enable the NRF local configuration
    • pcf : Enable the PCF local configuration
    • udm : Enable the UDM local configuration
      For example, if the NF type selected is udm , then this command enables the UDM local configuration. The same approach applies for the other configured NFs.
  • profile failure-handling failure_handling_name : Specify the failure handling profile name. For example, "udmFail".
The following is an example configuration of NRF failure handling.
group nf-mgmt NFMGMT1
   nrf-mgmt-group nrf-nfmgmt-grp
      failure-handling-profile FHNRF
         locality       LOC1
            heartbeat interval 50
         exit
profile nf-client-failure nf-type nrf
   profile failure-handling FHNRF
      service name type nrf-nfm
         responsetimeout 2300
            message type NRFRegistration
               failover-enabled true
               status-code httpv2 400,500
            action retry
         exit
         status-code httpv2 401,504
         action retry-next
      exit
   exit
message type NFUpdate
      status-code httpv2 400,503
   action retry
exit
status-code httpv2 411,500
   action retry-next
   exit
exit
message type Heartbeat
      re-registration-enabled true
      status-code httpv2 400,429
   action retry
exit
            action retry-next
          exit
        exit
     exit
  exit
exit
When an AMF failure occurs, use the following example configuration for the range of error codes with the same retry-action and retry-count in the failure handling template.
Note
You can use similar configuration during the failure of other NFs.
 profile failure-handling FH1
    status-code httpv2 100,200,300,400-410
     retry  4
     action continue
    exit
   exit
  exit
 exit
 profile failure-handling FH2
     retry  4
     action continue
    exit
   exit
  exit
 exit
profile failure-handling FH3
    status-code httpv2 250-260
     retry  4
     action continue
    exit
   exit
  exit
 exit
 profile failure-handling FH4
     action continue
    exit
   exit
  exit
 exit
 profile failure-handling FH5
  service name type namf-loc
    status-code httpv2 150,160,170-175
     action continue
    exit
   exit
  exit
 exit
exit
The following configuration is an example of the failure template mapping to DNN.
profile dnn intershat
 network-element-profiles chf chf1
 network-element-profiles amf amf1
 network-element-profiles pcf pcf1
 network-element-profiles udm udm1
 ssc-mode 2 allowed [ 3 ]
 session type IPV4 allowed [ IPV4V6 ]
 upf apn intershat
exit
The following configuration is an example of the failure template mapping to SMF.
profile smf smf1
 node-id          12b888e1-8e7d-49fd-9eb5-e2622a57722
 locality         LOC1
 bind-address ipv4 209.165.202.129
 bind-port        8008
 fqdn             example.com.apn.epc.mnc456.mcc123
 plmn-id mcc 123
 plmn-id mnc 456
exit
profile network-element amf amf1
 nf-client-profile        AMF-L1
 failure-handling-profile FH1
 query-params [ target-nf-instance-id ]
exit
profile network-element pcf pcf1
 nf-client-profile        PCF-L1
exit
profile network-element udm udm1
 nf-client-profile        UDM-L1
exit
profile network-element chf chf1
 nf-client-profile        CHF-L1
 failure-handling-profile FH2
exit
end
Configuring Failure Handling Actions
To configure the failure retry and action for each NF service and the different message types, use the following sample configuration:
config
   profile nf-client-failure { nf-type { amf | chf | pcf | udm }
      service name type service_type
         message type message_type
            retry retry_count
            action { continue | retry-and-continue | retry-and-terminate | terminate }
            end
NOTES:
  • service name type service_type : Specify the configured NF service types and provide the local configuration support for the following configured NFs. The service types vary depending on the configured service.
    The AMF service supports the following service types:
    • namf-comm
    • namf-evts
    • namf-loc
    • namf-mt
    The CHF service supports the following service types:
    The NRF service supports the following service type:
    • nrf-nfm
    The PCF service supports the following service types:
    • npcf-am-policy-control
    • npcf-bdtpolicycontrol
    • npcf-eventexposure
    • npcf-policyauthorization
    • npcf-smpolicycontrol
    • npcf-ue-policy-control
    The UDM service supports the following service types:
    • nudm-ee
    • nudm-pp
    • nudm-sdm
    • nudm-ueau
    • nudm-uecm
    For example, if the service_type that is selected is nudm-sdm , then this command enables the UDM local configuration. The same approach applies for the other configured NFs.
  • message type message_type : Specify the configured NF message type and provide the local configuration support for the configured NF.
    The message types vary depending on the configured profile and service type.
  • status code httpv2 status_code : Specify the status code for the retry and action for the NF service. Currently only "http" status code is provided. status_code must be an integer in the range of 0–599.
  • retry retry_count : Specify the number of times the NF service must retry before proceeding with the action. retry_count must be an integer in the range of 1–10.
  • action : Specify the action. The supported actions are:
    • continue : Specify to continue the session without any retry. The retry count configuration is invalid with this action.
    • retry-and-continue : Specify to retry as per the configured retry count and continue the session.
    • retry-and-terminate : Specify to retry as per the configured retry count and terminate the session in case all retry fails.
    • terminate : Specify to terminate the session without any retry. The retry count configuration is invalid with this action.
      The retry and action for a message send is picked based on the first sent status code failure. A different status code in the retry does not lead to picking a new retry count and action.
The following table provides a sample of the configured profile, service, and message type options.
Profile
Service Type
Message Type Options
amf
namf-comm
  • AmfCommEBIAssignment
  • AmfCommN1N2MessageTransfer
  • AmfCommSMStatusChangeNotify
  • range
chf
  • range
nrf
nrf-nfm
  • Heartbeat
  • NFUpdate
  • NRFRegistration
pcf
  • PcfSmpolicycontrolCreate
  • PcfSmpolicycontrolDelete
  • PcfSmpolicycontrolUpdate
  • range
udm
nudm-sdm
  • UdmRegistrationReq
  • UdmSdmGetUESMSubscriptionData
  • UdmSdmSubscribeToNotification
  • UdmSubscriptionReq
  • UdmUecmRegisterSMF
  • UdmUecmUnregisterSMF
  • UdmSdmUnsubscribeToNotification
  • range
Note
The example does not cover all the message options that are provided for each profile and service type.
Configuring NRF Failover Option
The NRF Failover feature enables the user to configure the retry actions for every error code, which occurs during the NRF interactions with SMF and other NFs.
After trying all the hosts or endpoints, the next action is decided based on the failover options, which are configured for the error codes.
To configure the NRF failover functionality, use the following sample configuration:
config
   profile nf-client-failure nrf
            message type { Heartbeat [ re-registration-enabled { false | true } ] | NFUpdate [ failover-enabled { false | true } ] | NRFRegistration [ failover-enabled { false | true } ] }
               status-code httpv2 status_code  action { retry | retry-next }
               end
NOTES:
  • message type { Heartbeat [ re-registration-enabled { false | true } ] | NFUpdate [ failover-enabled { false | true } ] | NRFRegistration [ failover-enabled { false | true } ] } : Specify the NRF message type and enable failover functionality.
    The failover options for the NRF messages are as follows:
    • NRFRegistration or NFUpdate
      • true—After trying all the hosts or endpoints in an NRF, the system selects the next available NRF.
      • false—After trying all the hosts or endpoints in an NRF, the system does not select the next available NRF.
      Spawning of backup routine is only available for those NRFs in which the endpoints have been tried.
    • Heartbeat
      • true—After trying all the hosts or endpoints in an NRF, if the start reregistration option is enabled, then the system starts the reregistration process for the NF clients.
      • false—After trying all the hosts or endpoints in an NRF, the system continues the heart beat routine with the same registered NRF.
  • status-code httpv2 status_code action { retry | retry-next } : Specify the status code and retry action for the NRF service. Currently only "http" status code is provided. status_code must be an integer in the range of 0–599.
    • retry—The system attempts one more retry to the same endpoint or host.
    • retry-next—The system does not retry the same endpoint or host, but it attempts the retry action to the next available endpoint or host.
  • The error handling for NF Registration, NF Heartbeat, and NF Update is based on status codes. This functionality is not available for subscription and NF Deregister messages. The user can configure the max retry-count for the subscription and NF Deregister messages by using the endpoint configuration available in the group nrf management CLI. The system attempts the retry action based on that configuration.
  • The failover-enabled option is applicable for the NF Registration and NF Update messages.
  • The reregistration-enabled option is applicable for the NF Heartbeat message.
  • The failover-enabled or reregistration-enabled options are not applicable for the NF Deregister message.
  • The failover and reregistration options are enabled by default.
Configuring Failure Handling in Network Element Profile
To configure the failure handling in the network element profile, use the following sample configuration:
config
   profile network-element { { amf | chf | pcf | udm } nf_profile_name }
      failure-handling-profile profile_name
      end
NOTES:
  • failure-handling-profile profile_name : Specify the NRF failure handling network profile for the configured NF type. profile_name must be an alphanumeric string representing the corresponding NRF failure handling network profile name.
The following is an example configuration.
         locality       LOC1
         exit
            action retry
         exit
         action retry-next
      exit
   exit
   action retry
exit
   action retry-next
   exit
exit
   action retry
exit
            action retry-next
          exit
        exit
     exit
  exit
exit
When an AMF failure occurs, use the following example configuration for the range of error codes with the same retry-action and retry-count in the failure-handling template.
     retry  4
     action continue
    exit
   exit
  exit
 exit
     retry  4
     action continue
    exit
   exit
  exit
 exit
     retry  4
     action continue
    exit
   exit
  exit
 exit
     action continue
    exit
   exit
  exit
 exit
     action continue
    exit
   exit
  exit
 exit
exit
Verifying the NRF Failure Handling
NF Management Failure Handling
The following is an example of management NRF endpoint configuration.
product smf# show running-config group nf-mgmt
group nf-mgmt MGM
 nrf-mgmt-group mgmt_group
 locality       LOC1
exit
product smf# show running-config group nrf mgmt
group nrf mgmt mgmt_group
 service type nrf nnrf-nfm
  endpoint-profile epprof
   uri-scheme http
   endpoint-name EP1
    priority 2
    primary ip-address ipv4 209.165.200.237
    primary ip-address port 8082
    secondary ip-address ipv4 209.165.200.238
    secondary ip-address port 8082
   exit
   endpoint-name EP2
    priority 10
   exit
  exit
 exit
exit
product smf#
In the sample configuration, EP1 is the higher priority endpoint name as its priority is lesser than EP2 (2 against 10). On bringing up, SMF sends NF registration to primary ip:port of EP1 [209.165.200.235:8082]. SMF uses secondary ip:port of EP1 if the primary is down. SMF performs a failover of endpoint to EP2 only if all ip:port of EP1 is down.
On successful registration with EP1 primary, SMF starts heartbeat with EP1 primary. If EP1 primary goes down, SMF detects the same by missing heartbeat response. On detecting that the EP1 primary is down, SMF sends heartbeat to EP1 secondary without reregistration. Also, it periodically sends NF heartbeat to EP1 primary to detect if it has recovered.
If SMF detects that EP1 primary and secondary is down, SMF performs a failover of endpoint to EP2. After the successful failover to EP2 primary, it sends reregistration (default behavior). It is assumed that all the endpoints with an endpoint name shares the same database and so reregistration is only supported when the failover is across endpoint names. In this case, EP1 primary and secondary share the same database. Similarly, EP2 primary and secondary share another database. On failover to EP2 primary, periodic NF registration is sent to primary of the EP1 only (to detect recovery).
Whenever a higher priority endpoint name is detected to be recovered, SMF falls back to the recovered IP:Port. For example, the current active NRF endpoint is EP2 primary and SMF detects that EP1 primary has recovered, then SMF performs reregistration with EP1 primary (default behavior) and stops heartbeat on EP2 primary.
Within endpoint NF heartbeat is used to track operational status. Across endpoints, registration is used to track the operational status. Request message timeout, RPC error, and HTTP response codes 408, 429, 500, 501, 502, 503 are considered as failure to move to the next NRF.
NF Discovery Failure Handling
The following is an example of discovery NRF endpoint configuration.
product smf# show running-config profile nf-pair nf-type UDM
 nrf-discovery-group others_group
 locality client LOC1
exit
product smf# show running-config group nrf discovery others_group
 service type nrf nnrf-disc
  endpoint-profile ep1
   capacity 30
   priority 50
   uri-scheme http
   endpoint-name ED1
    priority 56
    primary ip-address ipv4 209.165.201.19
    secondary ip-address ipv4 209.165.201.20
    exit
   endpoint-name ED2
    priority 10
    primary ip-address ipv4 209.165.201.21
    secondary ip-address ipv4 209.165.201.22
   exit
  exit
 exit
exit
product smf#
In the sample configuration, ED1 is the higher priority endpoint name as its priority is lesser than ED2 (2 against 10). Whenever a NRF discovery is required, primary ip:port of ED1 [209.165.201.19:8082] is attempted. SMF uses secondary ip:port of ED1 if the primary is down. SMF performs a failover of endpoint to ED2 only if all ip:port of ED1 is down. There is no state maintained regarding NRF discovery failure with any NRF endpoint. The SMF always starts with ED1 primary and falls back to ED1 secondary in case of failure, followed by ED2 primary, and so on.
Policy Control Function Failure Handling
Feature Description
The SMF utilizes the NF Failover support to achieve the PCF failover functionality.
The NF Failover feature supports the following functionality:
  • Multiple endpoints for a service as primary and secondary endpoints. The endpoints can be configured using the NRF Client Profile configuration and the NRF Failure Profile configuration.
  • Failure behavior based on:
    • Message Type
    • HTTP Status Codes in the response messages
Once the PCSCF profile is configured, the SMF assumes that the PDU activation is for the IMS and IMS requires PCF, then SMF rejects the PDU regardless of the failure handling configuration.
  • The SMF ignores the failure handling configuration and rejects the PDU creation if there is “pcscf-profile” under profile dnn.
  • Operator can’t configure the following parameters under the same “profile dnn”:
    • pcf-interaction false
    • pcscf-profile
How it Works
This section describes how the SMF handles message-level failures and the corresponding HTTP status code-based failures.
The SMF initiates the following messages:
During the PDU session lifecycle, the SMF exchanges the messages at various stages with the PCF. Depending on the HTTP status code configured in the NRF failure profile, the SMF takes one of the following actions:
  • Ignore
  • Continue
  • Terminate
Table 4. Relationship between PCF Failover Messages and Actions
PcfSmpolicy controlCreate
PcfSmpolicy controlUpdate
PcfSmpolicy controlDelete
Ignore
Continue with locally configured/UDM-provided policy parameters.
Note
Do not contact PCF for subsequent messages.
PCF-Interaction Status: OFF
Continue with currently available snapshot of policy parameters.
Contact PCF for subsequent messages.
PCF-Interaction Status: ON
Ignore the current failure and delete the session.
PCF-Interaction Status: Session deleted
Continue
Note
Note
Terminate
Terminate the session.
PCF Interaction Status
This feature supports the following status messages for SMF-initiated and PCF-initiated messages:
  • PCF-Interaction Status: ON
    SMF-initiated messages—The SMF continues to initiate the messages towards the PCF whenever the criteria is met.
    PCF-initiated messages—The SMF continues to accept all the messages initiated from the PCF towards the SMF.
  • PCF-Interaction Status: OFF
    SMF-initiated messages—The SMF does not initiate or send the messages towards the PCF whenever the criteria is met. The SMF treats the PCF as if it is not available and continues further actions.
    PCF-initiated messages—There are two messages initiated by the PCF.
    • SmPolicyUpdateNotifyReq: On receiving this message, the SMF sends a 404 error code in response and cleans up the session and does not send the Delete Request to the PCF.
      Note
      The SMF also sends FIVEGSM_CAUSE value as REACTIVATION REQUESTED in the FIVEG_PDU_SESSION_RELEASE_COMMAND to UE for 5G. In case of 4G, the SMF sends cause REACTIVATION REQUESTED in DELETE BEARER REQUEST message to the S-GW.
    • SmPolicyAssociationTerminationReq—On receiving this message, the SMF sends a success response and cleans up the session. As part of this interaction, the SMF sends a Delete Request to the PCF.
      Note
      This is an exception when the PCF-Interaction Status is set to OFF.
Configuring the PCF Failure Handling Feature
This section desribes how to configure the PCF Failure Handling feature.
Configuring the PCF Failure Handling feature involves the following steps:
Configuring the PCF Failure Handling Profile
To configure the PCF failure handling profile with action, use the following sample configuration:
config
   profile nf-client-failure nf-type pcf
      profile failure-handling fhprofile_name
               exit
NOTES:
  • profile failure-handling fhprofile_name : Specify the failure handling profile name.
  • service name type servicename_type : Specify the PCF service name type. servicename_type can be one of the following values:
  • message type messagetype_value : Specify the message type. messagetype_value can be one of the following values:
    • PcfAmfPolicyControlCreate
  • status-code httpv2 status_code : Specify the HTTPv2 status code. status_code must be an integer in the range of 0–599, separated by either '-' or ','.
  • action { continue | retry-and-continue | retry-and-ignore | retry-and-terminate } retry retry_value : Specify the action and the number of retry attempts. retry_value must be an integer in the range of 1–10.
Configuring the Association of Failure Handling Profile
To configure the association of FH profile in PCF, use the following sample configuration:
config
   profile network-element pcf pcf_profile_name
      nf-client-profile nf_profile_name
      exit
NOTES:
  • nf-client-profile nf_profile_name : Specify the NF client profile name.
  • failure-handling-profile fh_profile_name : Specify the failure handling profile name.
Configuring Secondary and Tertiary IP Addresses
To configure the secondary and tertiary IP addresses, use the following sample configuration:
config
   profile nf-client nf-type pcf
      pcf-profile pcfprofile_name
         locality locality_name
            service name type npcf-smpolicycontrol
               endpoint-profile endpointprofile_name
                  endpoint-name endpoint_name
                     primary ip-address { ipv4 primary_ipv4_address | ipv6 primary_ipv6_address | port primary_port_number }
                     secondary ip-address { ipv4 secondary_ipv4_address | ipv6 secondary_ipv6_address | port secondary_port_number }
                     tertiary ip-address { ipv4 tertiary_ipv4_address | ipv6 tertiary_ipv6_address | port tertiary_port_number }
                     end
NOTES:
  • primary ip-address ipv4 primary_ipv4_address : Specify the IPv4 address of primary endpoint.
  • primary ip-address ipv6 primary_ipv6_address : Specify the IPv6 address of primary endpoint.
  • primary ip-address port primary_port_number : Specify the port number of primary endpoint.
  • secondary ip-address ipv4 secondary_ipv4_address: Specify the IPv4 address of secondary endpoint.
  • secondary ip-address ipv6 secondary_ipv6_address : Specify the IPv6 address of secondary endpoint.
  • secondary ip-address port secondary_port : Specify the port number of secondary endpoint.
  • tertiary ip-address ipv4 tertiary_ipv4_address : Specify the IPv4 address of tertiary endpoint.
  • tertiary ip-address ipv6 tertiary_ipv6_address : Specify the IPv6 address of tertiary endpoint.
  • tertiary ip-address port tertiary_port_number : Specify the port number of tertiary endpoint.
OAM Support for PCF Failure Handling
This section describes operations, administration, and maintenance information for this feature.
Bulk Statistics Support
This feature supports the following statistics:
  • PcfSmpolicyControlCreate
    • Number of ignore responses
    • Number of continue responses
    • Number of terminate responses
  • PcfSmPolicyControlUpdate
  • PcfSmpolicyControlDelete
  • PolicyUpdateNotifyReq
    • Number of accepted requests
    • Number of rejected requests
    • Number of skipped requests
  • PolicyDeleteReq
  • PolicyUpdateRequest
  • Gauge counter for number of subscribers with policy type local/pcf.
Unified Data Management Failure Handling
Feature Description
The Unified Data Management (UDM) is responsible for primarily storing the subscriber data, which SMF accesses for managing the user sessions on the network.
The UDM failure handling support on SMF introduces a new failure handling template (FHT) profile. This profile is associated with the UDM profile in SMF.
The FHT template provides flexibility for SMF to fine tune its interactions with UDM over N10 for the sessions. It supports the SMF to handle the HTTP status codes in response from UDM for both new and existing sessions.
The NF failover support is available in the SMF using the NF Client profile configuration and the NF failure profile configuration. This feature supports the following functionality:
  • Configure multiple endpoints for a service as primary and secondary endpoints.
  • Specify the failure handling behavior based on:
    • Message Type
How it Works
The SMF utilizes the NF Failover to achieve the UDM failover support functionality. This section provides information on how the SMF handles message-level failures and the corresponding HTTP status code-based failures.
  • UE-Connection-Management (UE-CM)
    • Nudm_UECM_Registration
    • Nudm_UECM_DeRegistration
  • UE-Subscription-Management (UE-SDM)
    • Nudm_SDM_Get
    • Nudm_SDM_Subscribe
    • Nudm_SDM_Unsubscribe
During the PDU session lifecycle, the SMF exchanges the preceding messages at various stages with the UDM. Depending on the HTTP status code configured in the NF failure profile, the SMF takes one of the following actions:
  • Ignore
  • Continue
  • Terminate
The SMF provides the following actions to attempt the same request to other available UDM servers.
  • retry-and-ignore
When all the retry attempts fail, the SMF takes the appropriate failure handling action. For example, if the FH action is retry-and-terminate, the SMF terminates the call after all the attempts fail.
Note
The SMF allows dynamic changes to the failure handling template configuration. Any changes to the configuration apply only to the new calls.
Table 5. Relationship between N10 Messages and Failover Actions
Scenario
Service
Message
Condition
Action
Success Response
Handling of Failure Response
Terminate
Continue
Ignore
PDU Session Creation procedures in 5G, 4G, and Wi-Fi
Inter-RAT Handover procedures
UECM
Nudm_
UECM
_Registration
If the Nudm UECM Registration is not done and the access type is not 4G
Send the message
Mark the Registration is successful
Terminate call
Continue call
Continue call
Nudm _UECM_
DeRegistration
If the Nudm UECM Registration is done
Send the message
No action
Terminate call
Terminate call
Terminate call
SDM
Nudm_SDM _Get
If skipping the subscription fetch config is not enabled
Send the message
Mark the subscription fetch is successful
Terminate call
Continue call
Continue call
Nudm_
SDM
_Subscribe
If the subscription fetch is successful
Send the message
No action
Terminate call
Continue call if the subscription is not done
PDU Session Release procedures in 5G, 4G, and Wi-Fi
SDM
Nudm_SDM
_Unsubscribe
If the subscription fetch is successful and the registration is not done
Send the message
No action
Terminate call
Continue call
Continue call
  • Terminate: The SMF terminates the call in any message type.
  • Continue: The SMF ignores the current failure and skips the subsequent interaction for the other messages in the same service group.
  • Ignore: The SMF ignores failure only for the current interaction and proceeds with the call. The SMF processes the subsequent message interaction.
  • Perform UDM subscription fetch only during the session establishment in EPS and NR network.
    If the UDM subscription fetch fails and the FH action is ‘Ignore’ or the configuration to skip subscribe-to-notification is enabled, then the SMF skips the subscribe-to-notification interaction.
  • When the UDM failure handling template is not configured, the default failure handling action is 'Terminate'.
Configuring UDM Failure Handling Feature
This section describes how to configure the UDM Failure Handling feature.
Configuring the UDM Failure Handling feature involves the following steps:
Configuring UDM Failure Handling Profile
Use the following sample configuration to configure the UDM failure handling profile with action.
config
   profile nf-client-failure nf-type udm
         service name type { nudm-ee | nudm-pp | nudm-sdm | nudm-ueau
         | nudm-uecm }
         message type { UdmRegistrationReq | UdmSdmGetUESMSubscriptionData
         | UdmSdmSubscribeToNotification | UdmSubscriptionReq
         | UdmUecmRegisterSMF | UdmUecmUnregisterSMF |
         UdmSdmUnsubscribeToNotification }
            status-code httpv2 0
              end
Configuring Association of FH profile
To configure the association of FH profile in the UDM, use the following sample configuration:
config
   profile network-element udm udm_profile_name
      failure-handling-profile-rat nr
         exit
NOTES:
  • failure-handling-profile-rat nr : Specify the failure handling profile specific to RAT type.
  • failure-handling-profile fh_profile_name : Specify the failure handling network profile name. fh_profile_name must be a string.
Verifying the RAT-based FH Profile
This section describes how to verify RAT-based FH profile in the UDM.
Use the show running-config profile network-element udm udm_profile_name command to verify the feature configuration details.
The following is an example output.
nf-client-profile UP1
      failure-handling-profile FH4
      exit
exit
In this example, FH1 is the default failure handling profile. However, if the RAT type is configured as nr , then the failure handling profile FH4 is used.
To configure secondary and tertiary IP addresses, use the following sample configuration:
config
   profile nf-client nf-type udm
      udm-profile udmprofile_name
         locality LOC
            service name type { nudm-ee | nudm-pp | nudm-sdm | nudm-ueau | nudm-uecm }
               endpoint-profile epprofile_name
                     end
NOTES:
Configuring Response Timeout Parameter
To configure response timeout for fail-open support over the UDM interface (N10), use the following sample configuration:
config
      response-timeout timeout_value
      exit
NOTES:
  • response-timeout timeout_value : Specify the response timeout in milliseconds. timeout_value must be an integer in the range of 1000-30000.
    Default: 4000
Verifying the Response Timeout Configuration
[unknown] smf# show running-config profile network-element udm
query-params [ dnn ]
response-timeout 2000
exit
[unknown] smf#
Statistics
The following statistics are supported for all the UDM message status with status as Attempted/Success/Skipped/Failed for all UDM services and message combination.
udm_msg_processing_status{app_name="SMF",cluster="Local",data_center="DC"
,instance_id="1",msg_status="attempted",rat_type="nr",service_name="smfservice",
udm_end_point="",udm_msg="UdmSmSubscription”} 1
udm_msg_processing_status{app_name="SMF",cluster="Local",data_center="DC",
instance_id="1",msg_status="skipped",rat_type="nr",service_name="smfservice",udm_end_point="",
udm_msg="UdSmSubscription"} 1
OAM Support for UDM Failure Handling Feature
This section describes the operations, administration, and maintenance information for this feature.
The SMF maintains the following statistics in support of the UDM Failure Handling feature.
  • Nudm_SDM_Get
The "udm_msg_processing_status" statistic in smf-service tracks the number of UDM messages with status as—Attempted, Success, Skipped, and Failed.
For example:
{app_name="SMF",cluster="Local",data_center="DC",instance_id="1",msg_status="attempted",
rat_type="nr",
service_name="smf-service",udm_end_point="",udm_msg="UdmSmSubscription"} 1
{app_name="SMF",cluster="Local",data_center="DC",instance_id="1",msg_status="skipped",
rat_type="nr",
service_name="smf-service",udm_end_point="",udm_msg="UdSmSubscription"} 1
User Plane Function Failure Handling
Feature Description
During a session, if the User Plane function (UPF) is in congested state, it rejects the Packet Forwarding Control Protocol (PFCP) establishment messages from SMF with a cause code in the response message. To reduce call loss, the SMF retries to send PFCP establishment messages to a different UPF. Then, SMF selects a UPF based on configured priority value and capacity (that is, load information from UPF).
The SMF provides a failure handling template (FHT) profile for PFCP. This profile is associated with the UPF profile in SMF.
The FHT template provides flexibility for SMF to fine tune its interactions with UPFs for sessions. It enables SMF to handle the error cause codes in response from UPF for both new and existing sessions. Based on the error cause codes in response from UPF, this feature provides the following configurable actions:
  • ignore
  • terminate
  • retry-terminate
This following table describes the configuration options available for N4 Session Establishment Request, N4 Session Modification Request, and N4 Session Report Request messages.
Table 6. Configuration Matrix
Message type Applicable action Applicable cause code Default behaviour
N4Session EstablishmentReq retry-terminate
  • pfcp-entity-in -congestion
  • system-failure
  • service-not -supported
  • no-resource -available
  • no-response -received
  • reject
terminate
N4Session ModificationReq
terminate
  • mandatory-ie -incorrect
  • session-ctx-not -found
  • reject
continue
N4SessionReportReq
ignore
terminate
2-255
terminate
Configuring the UPF Failure Handling Feature
This section describes how to configure the UPF Failure Handling feature.
Configuring the UPF Failure Handling feature involves the following steps:
  1. Configuring UPF Failure Handling Profile
  2. Configuring the Failure Profile Association
To configure the UPF failure handling profile, use the following sample configuration:
config
      interface pfcp message { N4SessionEstablishmentReq | N4SessionModificationReq | N4SessionReportReq }
         cause-code cause_ID
         action { ignore | retry-terminate { max-retry retry_value } | terminate } [ condition { handover-execution | handover-preparation | modify | idft | handover-cancel } ]
         end
NOTES:
  • profile failure-handling fh_profile_name : Specify the UPF failure handling profile name.
  • interface pfcp message { N4SessionEstablishmentReq | N4SessionModificationReq | N4SessionReportReq } : Specify the failure handling for N4SessionEstablishmentReq (for new sessions), N4SessionModificationReq messages (for existing sessions), and N4 Session Report Request.
    Note
    UPF reselection is not applicable for message type N4SessionModificationReq because the session is already active on a UPF.
  • cause-code cause_ID : Specify the error codes that the SMF receives in the failure response message from the UPF.
    For the N4SessionEstablishmentReq and N4SessionModificationReq message types, the cause_ID must be one of the following values:
    • pfcp-entity-in-congestion : Specify this cause code when the UPF is congested.
    • reject : Specify this option to handle the cause codes in the failure response message from UPF. The cause codes are not configured by using the CLI commands available for this feature.
    • no-response-received : Specify this option to determine the scenarios where SMF does not receive any response from UPF.
    • FHT does not support the following cause codes, which are configured with their default behaviour:
      • request-reject-unspecified
      • cond-ie-missing
      • invalid-length
      • invalid-fw-policy
      • invalid-fteid-alloc-opt
      • no-established-pfcp-assoc
      • rule-creation-mod-failure .
    For the N4SessionReportReq message type, the cause_ID must be an integer in the range of 2– 255. Separate the cause code value using either '-' or ',' or both. For example, cause-code 72-74,76,78-100
    When the N4SessionReportReq keyword is configured, the SMF triggers the Session Deletion Request followed by the rejection of Session Report. The UPF responds to the delete request and clears the session gracefully.
  • action { ignore | retry-terminate { max-retry retry_value } | terminate } : Specify the action to perform based on the error cause code received in the failure response message from the UPF.
    • ignore —Specify to ignore the session. This FH action is applicable for N4SessionReportReq message type.
    • retry-terminate max-retry retry_value —Specify number of retry attempts to an alternate UPF. If the retry attempt fails, the session is terminated. This FH action is applicable for N4SessionEstablishmentReq message type.
      Default value: 2
      Maximum value: 5
      Note
      If all the UPFs are in congested state, the call fails even if the action is set to continue .
    • terminate —Specify to terminate the session. This FH action is applicable for N4SessionEstablishmentReq, N4SessionModificationReq, and N4SessionReportReq message types.
      You can configure different failure handling conditions based on the procedures applicable only for the N4SessionModificationReq message type. To configure the conditions, use the following command:
      action terminate condition { handover-execution | handover-preparation | modify | idft | handover-cancel }
      Configuring the condition command is optional.
      Note
      The SMF allows configuration of one or more conditions for failure handling of N4 session modifications.
      The SMF either terminates or allows the existing session to continue according to the configured conditions. For example, if any of the handover execution procedures fail during N4 modification, the SMF terminates the session.
      The cause codes 0-255 are supported. Precedence of the cause codes are in the following order:
      1. Predefined string
      2. Number
      3. Range
      4. Reject
      Reject is the default cause code.
      The following table describes the configuration for cause codes:
      Table 7. Configuration for Cause Codes
      Cause code Configuration
      0-63
      Corresponding template configuration
      64-255
      reject
Verifying the UPF Failure Handling Configuration
Use the show running-config command to view the configuration.
The following is an example output of the command.
show running-config profile failure-handling interface pfcp
 interface pfcp message N4SessionEstablishmentReq
  cause-code pfcp-entity-in-congestion action retry-terminate max-retry 2
  cause-code system-failure action terminate
  cause-code service-not-supported action terminate
  cause-code no-resource-available action retry-terminate max-retry 3
  cause-code no-response-received action retry-terminate max-retry 1
  cause-code reject action terminate
 exit
 interface pfcp message N4SessionModificationReq
  cause-code mandatory-ie-incorrect action terminate
  cause-code session-ctx-not-found action terminate
 exit
 interface pfcp message N4SessionReportReq
  cause-code 69 action terminate
  cause-code 72-74,76,78-100 action terminate
 exit
exit
To configure the failure profile association, use the following sample configuration.
config
   profile upf-group  upf_group_name
      failure-profile failure_profile_name
      end
NOTES:
  • profile upf-group upf_group_name : Specify the UPF group name.
  • failure-profile failure_profile_name : Specify the UPF failure profile name.
OAM Support
Statistics Support
The SMF supports the following disconnect reasons as part of “smf_disconnect_stats”:
  • smf_sess_pdn_rel_peer_request_reject — This disconnect reason is applicable for 4G and WiFi calls.
  • smf_sess_pdu_rel_peer_request_reject — This disconnect reason is applicable for 5G calls.
