DSCP Marking
Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Disabled – Configuration Required
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Revision Details
Release
Provided support for DSCP marking of control plane signaling messages
2021.01.0
First introduced.
Pre-2020.02.0
Feature Description
The SMF supports a mechanism for differentiated services code point (DSCP) marking of user plane data packets and control plane signaling messages.
The DSCP Marking feature enables the SMF to perform traffic classification and prioritisation to provide the appropriate quality of service (QoS) treatment. DSCP is the six most significant bit of the DiffServ field.
This feature uses CLI commands to configure DSCP parameters for both signaling messages and data packets. For configuration details, see the Configuring 5QI-QoS Mapping and Configuring DSCP Marking for Control Plane Signaling sections in this chapter.
DSCP Marking for Data Packets
Feature Description
DSCP Marking supports granular configuration. For Interactive Traffic Class (ITC), the SMF supports per-APN configurable DSCP marking for Uplink and Downlink direction that is based on 5QI and ARP-Priority level. This support allows the users to assign different DSCP values for flows with the same 5QI but different ARP priority values. For example, the ability to assign DSCP values that are based on 5QI+ARP can be used to meet compliance on priority and emergency calling via VoLTE.
DSCP Marking is a CLI-controlled feature, which enables to create and map 5QI and ARP values to enforceable QoS parameters.
The SMF sends the configured DSCP value to the UPF. Then, the UPF applies the DSCP marking on the uplink and downlink packets based on the 5QI and ARP.
How the DSCP Marking Works for Data Packets
This section describes how the DSCP marking can be performed for the data packets.
Allocation of different DSCP values for flows with the same 5QI, but different ARP values, works as follows:
  • Allows DSCP marking of packets based on 5QI and ARP combination.
  • 5QI and ARP configuration overrides any pre-entry of DSCP marking of packets that was based on 5QI and ARP combination.
  • 5QI-only DSCP entry overrides all the existing 5QI and ARP configuration.
  • Allows implementation of associated DSCP marking for 5QI and ARP for uplink and downlink traffic.
Use the following sample configuration to create and map 5QI values to enforceable QoS parameters.
config
   profile qos qos_profile_name
      dscp-map qi5 qos_id
      arp-priority-level arp_value uplink user-datagram dscp-marking dscp_marking_value
      arp-priority-level arp_value downlink { encsp-header { copy-inner | dscp-marking dscp_marking_value } | user-datagram dscp-marking dscp_marking_value } }
      commit
NOTES:
  • dscp-map qi5 qos_id : Specify the ID for the authorized QoS parameters. qos_id must be an integer in the range of 1-255.
  • arp-priority-level arp_value uplink user-datagram dscp-marking dscp_marking_value : Configure the ARP priority level and then set the DSCP value in the inner IP header in uplink direction. This DSCP value is applied to the packets with the configured 5QI value.
    arp_value must be an integer in the range of 1-255.
    dscp_marking_value must be a hexadecimal number from 0x00 through 0x3F.
  • arp-priority-level arp_value downlink { encsp-header { copy-inner | dscp-marking dscp_marking_value } | user-datagram dscp-marking dscp_marking_value } } : Configure the ARP priority level and then set the DSCP value to be applied to encapsulation header or user datagram.
    If encsp-header is configured, set the DSCP in the outer-ip header in downlink direction or copy the DSCP value from inner IP header to the outer IP header.
    If user-datagram is configured, set the DSCP in the inner IP header in downlink direction.
The following is an example configuration.
profile qos test
 dscp-map qi5 1 downlink encaps-header copy-inner
 dscp-map qi5 1 downlink encaps-header dscp-marking 0x3b
 dscp-map qi5 2 downlink user-datagram dscp-marking 0x3b
 dscp-map qi5 3 downlink user-datagram dscp-marking 0x3b encaps-header copy-inner
 dscp-map qi5 4 downlink user-datagram dscp-marking 0x3b encaps-header dscp-marking 0x3f
 dscp-map qi5 2 uplink user-datagram dscp-marking 0x3b
 dscp-map qi5 1 arp-priority-level 1 downlink encaps-header copy-inner
 dscp-map qi5 2 arp-priority-level 2 downlink encaps-header dscp-marking 0x3b
 dscp-map qi5 4 arp-priority-level 3 downlink user-datagram dscp-marking 0x3b
 dscp-map qi5 2 arp-priority-level 4 downlink user-datagram dscp-marking 0x3b encaps-header copy-inner
 dscp-map qi5 4 arp-priority-level 5 downlink user-datagram dscp-marking 0x3b encaps-header dscp-marking 0x3f
 dscp-map qi5 4 arp-priority-level 5 uplink user-datagram dscp-marking 0x3b
Verifying DSCP Configuration for UP Packets
This section describes how to verify the DSCP Marking feature configuration for the UP packets.
Use the show running-config profile qos command to verify the DSCP configuration for UP packets.
The following is an example output of the show running-config profile qos command.
smf# show running-config profile qos
profile qos abc
 ambr ul "250 Kbps"
 ambr dl "500 Kbps"
 qi5      7
 arp priority-level 14
 arp preempt-cap NOT_PREEMPT
 arp preempt-vuln PREEMPTABLE
 priority 120
 max data-burst 2000
exit
profile qos qos_1
 dscp-map qi5 1 arp-priority-level 5 uplink user-datagram dscp-marking 0x1e
 dscp-map qi5 1 arp-priority-level 5 downlink user-datagram dscp-marking 0x22 encsp-header copy-inner
 dscp-map qi5 2 arp-priority-level 6 uplink user-datagram dscp-marking 0x3e
 dscp-map qi5 2 arp-priority-level 6 downlink user-datagram dscp-marking 0x23 encsp-header copy-inner
 dscp-map qi5 3 arp-priority-level 12 uplink user-datagram dscp-marking 0x2f
 dscp-map qi5 3 arp-priority-level 12 downlink user-datagram dscp-marking 0x14 encsp-header copy-inner
 dscp-map qi5 6 downlink encsp-header copy-inner
 dscp-map qi5 7 downlink encsp-header dscp-marking 0x01
exit
Feature Description
The SMF supports marking of DSCP values to control packets as per the configuration at the interface.
Note
The current implementation of DSCP marking supports only per interface and protocol endpoint. Also, the customers should be aware of the DSCP code value range and its denoted priority.
How the DSCP Marking Works for Control Signaling
The SMF marks the ingress and egress packets after the QoS classification. The protocol endpoints provide the DSCP values at the time of registering the endpoint and interface.
The SMF uses the dscp command in the endpoint and interface configuration to define the DSCP values.
The following table lists the commonly used DSCP values as described in RFC 2475.
Table 1. Commonly Used DSCP Values
DSCP Value
Decimal Value
Meaning
Drop Probability
Equivalent IP Precedence Value
101 110
46
High Priority Expedited Forwarding (EF)
101 - Critical
000 000
Best Effort
000 - Routine
001 010
AF11
Low
001 - Priority
001 100
12
AF12
Medium
001 - Priority
001 110
14
AF13
High
001 - Priority
010 010
18
AF21
Low
010 - Immediate
010 100
20
AF22
Medium
010 - Immediate
010 110
22
AF23
High
010 - Immediate
011 010
26
AF31
Low
011 - Flash
011 100
28
AF32
Medium
011 - Flash
011 110
30
AF33
High
011 - Flash
100 010
34
AF41
Low
100 - Flash Override
100 100
36
AF42
Medium
100 110
38
AF43
High
001 000
8
CS1
16
CS2
24
CS3
32
CS4
40
CS5
48
CS6
6
111 000
56
CS7
7
000 000
Default
101 110
46
EF
Limitations
The DSCP Marking feature has the following limitation:
  • The DSCP Marking is per interface basis and not per peer or session.
This section describes how to configure the DSCP Marking feature for CP signaling messages.
Configuring the DSCP Marking feature involves the following steps:
Configuring DSCP Marking per Endpoint
Use the following sample configuration to configure the DSCP values at the endpoint level.
config
   instance instance-id gr_instance_id
      endpoint { gtp | li | protocol | radius | sbi }
         dscp dscp_value
         commit
NOTES:
  • The DSCP Marking configuration is applicable only to the following endpoints:
    • protocol
    • sbi
    • gtp
    • radius
    • li
  • dscp dscp_value : Specify the DSCP value for the control plane signaling messages. dscp_value must be a hexadecimal number from 0x00 through 0x3F or a decimal value ranging from 0 through 63.
  • The DSCP Marking feature supports dynamic change of the configuration.
Configuring DSCP Marking per Interface
Use the following sample configuration to configure the DSCP values at the interface level.
config
         interface { coa-nas | gtpu | n4 | n7 | n10 | n11 | n16 | n40 | nrf | radius-client | s2b | s5 | s8 | upf-rcm-conn | upf-rcm-reg }
            dscp dscp_value
            commit
NOTES:
  • The DSCP marking configuration is applicable to all the interfaces defined within the configured endpoints.
  • dscp dscp_value : Configures the DSCP value for the control plane signaling messages. dscp_value must be a hexadecimal number from 0x00 through 0x3F or a decimal value ranging from 0 through 63.
  • The Service-based Interface (SBI) configuration applies to all the interfaces. If a specific interface configuration is present, it overrides the DSCP values.
  • For the interfaces to work properly, it is mandatory to configure vip-ip, vip-port, and loopbackPort at each interface level.
Verifying DSCP Configuration for CP Signaling Messages
This section describes how to verify the DSCP Marking feature configuration for the CP signaling messages.
Use the show running-config instance instance-id gr_instance_id endpoint command to verify the DSCP configuration for control packets.
The following is an example output of the show running-config instance instance-id 1 endpoint command.
smf# show running-config instance instance-id 1 endpoint
 endpoint sbi
  replicas 2
  nodes 1
  dscp 24
  vip-ip 209.165.200.230
  interface nrf
   loopbackPort 9050
   vip-ip 209.165.200.236 vip-port 8090
   dscp 24
  exit
 exit
exit
OAM Support for DSCP Marking
Monitoring Support
The SMF uses the monitor protocol and monitor subscriber commands to view the configured DSCP value.
