Content Filtering and X-Header Enrichment
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Disabled - Configuration Required
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
First introduced.
Pre-2020.02.0
Feature Description
The SMF supports the following functionality:
  • Content Filtering
  • X-header Enrichment
Content Filtering
Feature Description
The Content Filtering (CF) service prevents subscribers from inadvertently getting exposed to universally unacceptable content, or content that is inappropriate as per subscriber preferences. Based on the URLs in the subscriber requests, the CF service filters HTTP and WAP requests from mobile subscribers. Operators can filter and control the content for an individual subscriber to access.
Configuring Content Filtering
This section describes how to configure CF support.
Note
Apart from the following configurations, all other configurations are used only in the UPF, and SMF sends it to the UPF. The SMF doesn't use these configurations. For more information on how to enable the feature on UPF, see the UCC 5G UPF Configuration and Administration Guide.
Configuring Content Filtering under Active Charging Service
To configure CF under the active charging service, use the following sample configuration:
config
   active-charging service service_name
      content-filtering category policy-id cf_policy_id
      end
NOTES:
  • content-filtering category policy-id cf_policy_id : Specify the CF policy number. cf_policy_id must be an integer in the range of 1-4294967295.
Configuring Content Filtering under Rulebase
To configure CF under the rulebase, use the following sample configuration:
config
      rulebase rulebase_name
         end
NOTES:
Configuring Content Filtering under APN
To configure CF under the APN, use the following sample configuration:
config
   apn apn_name
      end
NOTES:
Content Filtering Policy ID on N7 Interface
The CF categories are configured under the active charging service under specific policy IDs. The rulebase and APN also have an associated policy ID. For any session, one policy ID can be associated with the session at anytime. The categories configured under that CF policy ID are applicable for the session on the UPF.
The PCF can override the CF policy ID by sending this value on the N7 interface. For this purpose, a proprietary IE is available in the YAML definition for the N7 interface. The hierarchy for the CF policy ID is as follows:
smPolicyDecision
   ciscoAvpSet:
      cfPolicyId: uint32 value
When the PCF does not send a CF policy ID, the existing CF policy ID in the rulebase configuration or the policy ID configured in the APN configuration is selected, in the order of precedence. This CF policy ID value is sent to the UPF in PFCP Session Establishment Request message in the "Subscriber Parameters" attribute. During PDU Session Modification, if the PCF changes the CF policy ID, the ID is sent to the UPF in PFCP Session Modification Request message.
X-Header Insertion
With the X-Header Insertion and X-Header Encryption features, collectively known as Header Enrichment, you can append headers to HTTP or WSP GET and POST request packets, and HTTP response packets for use by end applications. For example, mobile advertisement insertion (MSISDN, IMSI, IP address, user-customizable, and so on).
Supported X-Header Information
Out of all the configurable X-header information, some information requires SMF to send the corresponding values to the UPF. The following table lists the information that is sent from the SMF to the UPF for X-header insertion.
Table 3. X-header Information
Xheader Field Description Present in Session Establishment Modified in Session Modification
String Constant Inserts the configured string in xheader
Charging ID Per Flow or Bearer Charging Id Yes
IMEI IMEI for the call Yes
IMSI IMSI for the call Yes
Rat-Type RAT type for the UE session Yes Yes
s-mcc-mnc MCC or MNC of the SGW or AMF Yes
Sgsn-address AMF or SGW address Yes Yes
ULI User Location Info Yes Yes
GGSN-Address N4 or or S5 endpoint of SMF Yes Yes
Radius-station-ID MSISDN of the UE
Sn-rulebase Rulebase for a call Yes Yes
Subscriber-ip-address IP address allocated to UE
Msisdn-no-cc Obtained from MSISDN Yes No
The subscriber-specific fields—IMSI, MSIDN, and IMEI—are encoded in the "User ID" standard IE. For more details, see 3GPP 29.244, Section 8.2.101.
Rest of the fields are sent in the "Subscriber Parameters" proprietary AVP. Some fields, such as the "Rulebase" and "UE IP address", are sent as a part of the created PDRs.
Note
  • All the parameters are always sent from the SMF to the UPF irrespective of whether X-header configuration is available. These parameters ensure that any change in configuration after session creation is immediately applied on the UPF.
  • The SMF supports X-header insertion-related configurations. The SMF does not require these configurations for its functionality. These configurations are sent to the UPF.
