DNN Support
Summary Data
Table 1. Summary Data
Applicable Product(s) or Functional Area
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Disabled – Configuration Required
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
Added dynamic configuration change support for DNN profile.
2023.03.0
Added override keyword in the CLI to support virtual DNN from RADIUS server.
2023.02.0
Added support for IP pool allocation per slice and DNN.
2022.04.0
Added support for:
  • Charging Characteristics lookup parameter in the subscriber policy configuration.
  • Extension in Charging Characteristics ID range values.
2021.02.3.t3
Added support for IPv6 interface ID generation based on SBI VIP address and CommonId of the subscriber.
2021.01.1
SMF supports the maximum limit of 2048 for the following configurations:
  • Precedence
  • Operator policy
  • DNN policy
  • DNN profile
2021.01.0
SMF supports case insensitive DNN configuration.
2020.02.5.t1
First introduced.
Pre-2020.02.0
Feature Description
Important
The PGW-C term used in this chapter denote the EPS interworking functionality supported by SMF and must not be assumed as a standalone P-GW that is used in the LTE network.
The multi-DNN support enables the SMF to have multiple PDN connections for end users to provide different services including Internet and VoNR services.
The SMF fetches the locally configured profile-based Data Network Name (DNN) in PDU Session Establishment Request from the AMF. Then, the SMF maintains the PDN connections based on using SUPI and PDU Session ID. The SMF includes the received DNN in all SBI interfaces to authorize the end user to fetch subscription information, policy, and charging related information. The SMF provisions the forward path information to the UPF. The SMF integrates the multi-DNN support with the IP Address Management (IPAM) module to allocate address to the end user based on received DNN. The SMF maps the DNN profile that is derived from subscriber policies. The SMF also fetches DNN and IPv4 and IPv6 path information based on IPAM pool configuration and updates the UPF as part of node association interactions.
Note
Multiple DNN is supported only for 5GS procedures and is not qualified for EPS Session using SBI interfaces.
The SMF supports virtual DNN (vDNN) mapping based on a subscriber profile. It supports mapping of a UE-requested DNN to a configured DNN and sends the selected DNN profile towards the configured network interfaces.
For 5G subscribers, SMF allows a higher number of vDNNs with slice-based vDNN selection. However, when 5G subscribers connect from 4G access network, the slice information is unavailable until SMF fetches the UE subscription data from UDM. In such scenarios, SMF performs initial vDNN selection based on the CC lookup parameter. After the subscription data is fetched, the SMF reselects the vDNN based on the slice ID information and uses the new vDNN profile. This approach remains the same for the Wi-Fi calls as well.
SMF provides the flexibility of vDNN selection based on using either Charging Characteristics or slice through the CLI configuration. For more information on the configuration part, see the Configuring Subscriber Policy section.
Note
As the DNN profile is under the operator policy, the reselection of the vDNN profile implies the reselection of the operator policy as well. SMF supports the configuration so that the reselection doesn't impact the existing features that are associated to other parameters in the operator policy.
How It Works
The DNN profile lookup is based on subscriber policy or DNN policy. You can associate these policies in the SMF profile configuration. The subscriber policy has a higher precedence over the DNN policy when both the configurations are available.
The subscriber policy consists of a list of precedence values. The selection of precedence is based on various values. For example, the subscriber SUPI, GPSI, Serving PLMN, NSSAI, Charging Characteristics, and IMSI. Each precedence has an associated operator policy and the DNN policy is chosen from the selected operator policy.
The DNN policy can have a DNN profile configuration for each UE-requested DNN. The DNN profile has a Virtual or Mapped DNN with its list of interfaces.
The order of selection for a Virtual DNN is as follows:
  • Based on subscriber policy, the order of selection is as follows: smf-profile > smf-service > subscriber-policy > precedence > operator-policy > dnn-policy > dnn-profile (based on UE-requested DNN) > Virtual DNN mapping.
  • Based on the DNN policy, the order of selection is as follows: smf-profile > dnn-policy > dnn-profile (based on UE-requested DNN) > Virtual DNN mapping.
PCF, CHF, UDM, UPF, and Resource Manager (RMGR) are the supported interfaces for Virtual DNN mapping.
If the Virtual DNN mapping is not configured, the UE-requested DNN is used across all the interfaces.
Limitations
This feature has the following limitation:
  • The SMF includes first-configured DNN profile in "dnnSmfInfoList" of NFProfile during registration with NRF.
Configuring Virtual DNN
This section describes how to configure the Virtual DNN feature.
Configuring the Virtual DNN feature involves the following steps:
  1. Configuring Subscriber Policy
  2. Configuring Operator Policy and Associating a DNN Policy
  3. Configuring a DNN Policy
  4. Configuring a Virtual DNN under a DNN Profile
  5. Associating Subscriber Policy under the SMF Service
To configure the subscriber policy, use the following sample configuration:
config
   policy subscriber subscriber_policy_name
      precedence precedence_value
         cc-start-range cc_start_range_value
         cc-stop-range cc_stop_range_value
         gpsi-start-range gpsi_start_range_value
         gpsi-stop-range gpsi_stop_range_value
         imsi { mcc mcc_value | mnc mnc_value | msin  msin_value }
         imsi-start-range imsi_start_value
         imsi-stop-range imsi_stop_value
         operator-policy operator_policy_name
         pei-start-range pei_start_range_value
         pei-stop-range pei_stop_range_value
         sdt sdt_value
         serving-plmn { mcc mcc_value | mnc mnc_value | mnc-list  mnc_list_value }
         serving-plmn  serving_plmn_value
         sst sst_value
         supi-start-range supi_start_range_value
         supi-stop-range supi_stop_range_value
         instance-start-range start_range_value
         instance-stop-range stop_range_value
         end
NOTES:
  • precedence precedence_value: Specify the precedence value associated with the subscriber policy.
    The maximum limit for precedence is 2048.
  • cc-start-range cc_start_range_value : Specify the charging characteristics start range value associated with the subscriber policy. cc_start_range_value must be a 1 to 4 digit hexadecimal string in the range of 0x1 to 0xffff. For example, 0001.
  • cc-stop-range cc_stop_range_value : Specify the charging characteristics end range value associated with the subscriber policy. cc_stop_range_value must be a 1 to 4 digit hexadecimal string in the range of 0x1 to 0xffff. For example, 12AB.
  • gpsi-start-range gpsi_start_range_value : Specify the GPSI start range value to be associated with the subscriber policy. gpsi_start_range_value must be an integer in the range from 1000000000 through 999999999999999.
  • gpsi-stop-range gpsi_stop_range_value : Specify the GPSI stop range value to be associated with the subscriber policy. gpsi_stop_range_value must be an integer in the range from 1000000000 through 999999999999999.
  • imsi { mcc mcc_value | mnc mnc_value | msin msin_value} : Specify the IMSI value by providing the MCC, MNC, or MSIN value that is to be associated with the subscriber policy.
  • imsi-start-range imsi_start_value : Specify the IMSI start range value. imsi_start_value must be an integer in the range from 1000000000 through 999999999999999.
  • imsi-stop-range imsi_stop_value : Specify the IMSI stop range value. imsi_stop_value must be an integer in the range from 1000000000 through 999999999999999.
  • operator-policy operator_policy_name : Specify the operator policy to be associated with the subscriber policy.
    The maximum limit for operator policy is 2048.
  • pei-start-range pei_start_range_value : Specify the PEI start range value. pei_start_range_value must be an integer in the range from 1000000000 through 999999999999999.
  • pei-stop-range pei_stop_range_value : Specify the PEI stop range value. pei_stop_range_value must be an integer in the range from 1000000000 through 999999999999999.
  • sdt sdt_value : Specify the SDT value be associated with the subscriber policy. sdt_value must be a 6-digit octet string in the [0-9a-fA-F]{6} - 000000 - ffffff format. For example, 1A2B3c.
  • serving-plmn { mcc mcc_value mnc mnc_value mnc-list mnc_list_values} : Specify the 3-digit Mobile Country Code (MCC), 2- or 3-digit Mobile Network Code (MNC), or the list of MNC values of the serving PLMN. mcc_value and mnc_value must be a string. mnc_list_values must be a string, such as [580 660].
  • sst sst_value : Specify the Slice/Service Type (SST) value. sst_value must be a 2-digit octet string in the [0-9a-fA-F]{2} - 00 to FF format. For example, A8.
  • supi-start-range supi_start_range_value : Specify the SUPI start range value. supi_start_range_value must be an integer in the range from 1000000000 through 999999999999999.
  • supi-stop-range supi_stop_range_value : Specify the SUPI stop range value. supi_stop_range_value must be an integer in the range from 1000000000 through 999999999999999.
  • instance-start-range start_range_value : Specify the SMF instance start range value. start_range_value must be an integer in the range from 1 to 8.
  • instance-stop-range stop_range_value : Specify the SMF instance stop range value. stop_range_value must be an integer in the range from 1 to 8.
Configuration Verification
To verify the policy-related configuration details, use one of the following commands:
show subscriber policy policy_name or show full in the policy configuration mode.
The following is an example output of the show command:
If the subscriber policy configuration includes the charging characteristics parameter, then the value appears as part of cc-start-range and cc-stop-range in the following output.
smf(config-subscriber-polSub)# show full
policy smf polSmf
precedence 1
  sst              22
  sdt              232322
  serving-plmn mcc 210
  serving-plmn mnc 90
  supi-start-range 100000000000001
  supi-stop-range  100000000000010
  gpsi-start-range 1000000000
  gpsi-stop-range  9999999999
  cc-start-range 0001
  cc-stop-range 0005
  operator-policy  opPol1
To configure the operator policy, use the following sample configuration:
config
   policy operator operator_policy_name
      policy dnn dnn_policy_name [  [ secondary secondary_dnn_policy_name ] [   network-capability network_capability ]  ]
      end
NOTES:
  • policy dnn dnn_policy_name [ [ secondary secondary_dnn_policy_name ] [ network-capability network_capability] ] : Specify the parameters of primary DNN policy to be associated with the operator policy. dnn_policy_name must be a string.
    • secondary secondary_dnn_policy_name : If the parameters of DNN policy to be associated with the operator policy don't match with the primary policy, specify the secondary DNN policy for fallback. secondary_dnn_policy_name must be a string.
    • network-capability network_capability : Specify the network capability configuration details for the respective operator policy that you have selected. The network_capability value must be a string.
To configure the DNN policy, use the following configuration:
config
      dnn dnn_name profile dnn_profile_name dnn-list dnn_list
   exit
exit
NOTES:
  • policy dnn dnn_policy_name : Specify the DNN policy. dnn_policy_name must be an alphanumeric string.
    The maximum limit for DNN policy is 2048.
  • dnn dnn_name : Specify the virtual DNN profile to map with the specified network DNN profile. dnn_name must be an alphanumeric string.
    The DNN configuration accepts an alphanumeric string from 1 through 62 alphanumeric characters, that is case insensitive. It can also contain dots (.) and/or dashes (-).
  • profile dnn_profile_name : Specify the network DNN profile. dnn_profile_name must be an alphanumeric string.
    The maximum limit for DNN profile is increased from 512 to 2048.
  • dnn-list dnn_list : Specify the list of DNNs supported by the UPF node.
The SMF provides flexibility to send Virtual-DNN value on all northbound interfaces. Virtual DNN to be send on each interface can be configured as follows. The Resource Manager (RMGR) virtual DNN is used to map IP pool to DNN.
To configure a virtual DNN under a DNN profile, use the following sample configuration:
config
   profile dnn profile_name
      dnn dnn_name network-function-list [ chf | ocs | pcf | pcrf | radius | upf | cgf ]
   profile profile_name
   end
NOTES:
  • dnn dnn_name : Specify the DNN name. dnn_name must be an alphanumeric string.
  • network-function-list : Specify the network functions. The DNN profile goes to these network functions. Supported values are CHF, OCS, PCF, PCRF, RADIUS, UPF, and CGF.
Configuring Override Command
In addition to the preceding CLI, SMF has the capability to override the access DNN with the vDNN received from the RADIUS server.
RADIUS-ep is upgraded to decode Starent VSA attribute “SN-Virtual-APN-Name (Type: 94) “ and application is enhanced to support this attribute.
RADIUS Server sends vDNN to SMF in access accept and SMF includes this DNN in N4 messages to UPF. A new configuration is added on the SMF to decide whether to override the DNN sent on specific interfaces with the value received from RADIUS server.
Override keyword is added to support virtual DNN from the Radius Server.
config
      dnn override network-function-list [ chf | ocs | pcf | pcrf | radius | upf | cgf ]
      dnn override rmgr
      end
Details of attribute used for receiving virtual DNN on RADIUS interface is as follows:
  • SN: Virtual-APN-Name
  • Syntax: Opaque Value
  • Length: 1-64
  • Type: 26
  • Vendor ID: 8164
  • VSA Type: 94
  • Override keyword takes priority over the locally configured value.
  • Override keyword is present but RADIUS isn’t providing any vDNN then SMF uses the locally configured value (if present) or gnDNN.
  • If for an interface, there’s no configuration (either override or local-dnn-name), it takes the gnDNN.
    Override vDNN isn’t applicable for UDM network-function.
  • The framed-ip received from the RADIUS server must be a part of the IP pool associated to the vDNN received from the RADIUS server. If there’s mismatch, session creation fails.
  • Different RMGR vDNN can be assigned to the same UE for same DNN for dynamic and static ip allocation case and hence IP can be assigned from dynamic or static pool.
To associate a subscriber policy under SMF service, use the following sample configuration:
config
   profile smf smf_profile_name
      service name service_name
         subscriber-policy subscriber_policy_name
         end
NOTES:
  • subscriber-policy subscriber_policy_name : Specify the subscriber policy name. subscriber_policy_name must be an alphanumeric string.
Network Function Selection based on SMF Instances
Table 3. Feature History
Feature Name
Release Information
Description
UPF Selection based on SMF Instances
2024.01.2
This feature allows you to customize SMF instances in the Subscriber Policy Configuration and to bind SMF instances to the colocated UPFs in the inter-site GR deployment model.
When the user selects operator policies, the SMF instances act as a filter and allow the SMF to select a specific DNN profile. The DNN selection helps in finding the closest and active Network functions (for example, UPFs) and ensures routing the user traffic only to the colocated UPFs. This implementation reduces the latency and improves user experience.
To implement this feature, the following keywords are added under the policy subscriber command:
Default Setting: Disabled – Configuration required to enable
Instance-based Network Function Selection
Feature Description
During the subscriber session creation, SMF selects operator policy based on the SMF instance IDs configured in the Subscriber Policy Configuration mode. For each subscriber, SMF associates the selected operator policies with different DNN profiles, virtual DNNs, IP pools, and UPF profiles.
SMF provides the flexibility to choose appropriate DNN profiles corresponding to the SMF instances.
For example, in an active-standby Geo Redundancy (GR) deployment scenario, assume that there are two racks (Rack 1 and Rack 2) with each rack comprising two regions (Region 1 and Region 2), two active and standby SMF instances (SMF instance 1 and SMF instance 2), IP pools (Pool 1 and Pool 2), virtual DNNs (vdnn 1 and vdnn 2), and two UPF sets (UPF Set 1 (UPF 1 and UPF 3) and UPF Set 2 (UPF 2 and UPF 4)).
SMF is configured in such a way that vdnn 1 is associated to SMF Instance 1, Pool 1, and UPF Set 1, and vdnn 2 is associated to SMF Instance 2, Pool 2, and UPF Set 2. When the subscriber attempts to establish PDU connection, SMF instance is selected based on the Virtual IP (VIP) of the session it lands. If SMF instance 1 in one region is active and selected, SMF chooses vdnn1, Pool 1, and UPF Set 1 even though the SMF instances have the same DNN in both the regions.
SMF subsequently distributes the IP pools from Pool 1 only to the UPFs in UPF Set 1. If the SMF instance IDs are not configured, SMF allocates the available IP addresses to the UPFs associated to both the SMF instances.
Configuring SMF Instances
To configure the SMF instances, use the following sample configuration:
Note
It is recommended to add this configuration at runtime. A new operator policy selection post configuration change uses new configuration.
config
         end
NOTES:
Configuration Example
The following is an example of a configuration show running-config policy subscriber command that describes SMF instances for DNN profile selection.
 [smf] smf# show running-config policy subscriber
Wed Mar  6  05:09:45.143 UTC+00:00
policy subscriber polSub
 precedence 1
  sst                  02
  sdt                  Abf123
  serving-plmn mcc 123
  serving-plmn mnc 456
  supi-stop-range      999999999999999
  gpsi-start-range     100000000000001
  gpsi-stop-range      999999999999999
  instance-start-range 1
  instance-stop-range  1
  operator-policy      opPolHomer
 exit
Switching DNN Profile to Offline Mode During Dynamic Config Update
Feature Description
This feature enables SMF to switch the DNN to offline mode to support dynamic configuration update. SMF allows dynamic configuration update of some DNN profile parameters only when the DNN profile is changed to offline mode.
When the DNN is in offline mode, new sessions or subsequent messages of existing sessions, will use the updated configuration values.
Important
You must clear the subscriber sessions before switching DNN to offline mode while changing the configuration for which dynamic change is not allowed. New session requests are rejected until the DNN is changed back to online mode.
How it Works
This section describes how this feature works for the supported SMF configurations.
DNN Policy
DNN Policy configuration defines the DNN Profile mapping with the DNN. After the DNN to profile mapping is changed, new subscriber for the same DNN uses the updated DNN Profile. So, there is no impact on existing subscribers.
DNN Profile
DNN profile defines various parameters for a particular DNN.
The following table describes if the dynamic configuration change is allowed or if the DNN must be set to an offline mode.
Table 4. DNN Profile Configuration and its Impact During Dynamic Update
Configuration Parameters Dynamic Change Impact on Existing Sessions
DnsServers Allowed No impact
DnnInfo Allowed New values are used after database reload of the session
NetworkElementProfile Not recommended (See NOTES)
Timeout Allowed No impact
ChargingProfile Not recommended (See NOTES)
RemoteVmac Allowed No impact
PcscfProfile Allowed No impact
PpdProfile Allowed Immediate (new values are used)
DefaultSscMode Allowed No impact
DefaultPduSession Allowed No impact
AllowedPduSession Allowed No impact
QosProfile Allowed Immediate (new values are used)
UpfApn Allowed No impact
SecondaryAuthen Allowed No impact
LocalAuthorization Allowed No impact
NetworkCapability
Allowed
No impact
PolicyProfile
Allowed
No impact
NOTES:
  • It’s recommended not to modify or delete the NetworkElementProfile and ChargingProfile configuration parameters. If the parameters are changed, then the behavior for:
    • NetworkElementProfile: Messages for the existing sessions may be sent on new servers.
    • ChargingProfile: There may be some inconsistencies related to Usage Reporting Rules (URRs) between SMF and UPF.
  • For modifying the DNN profile mapping, the DNN profile must be in the offline mode.
  • It’s recommended to review the messages shown in the help string before executing the CLI commands.
  • Switch the DNN profile to an offline mode when configuring the parameters dynamically. This step avoids the network impact, which is caused by the configuration changes.
Subscriber Policy
SMF uses subscriber policy to select the operator policy based on the following options:
  • SUPI range
  • SST (Slice/Service Type)
  • IMSI range
  • GPSI
  • PEI
  • SDT (Slice Differentiator Type)
  • S-NSSAI
  • PLMN ID
  • CC (Charging Characteristics) range
  • SMF instance range
A change in Subscriber Policy configuration can be applied dynamically as it has no impact on the existing sessions. SMF selects the operator policy for the new sessions based on the updated configurations.
Limitations
The following limitations apply when the DNN is in the offline mode:
  • The subsequent 5G calls for the offline DNN are rejected with the HTTP Cause - HTTP_STATUS_CODE_503_SERVICE_UNAVILABLE, and 5GSMCause as “Service option temporarily out of order”.
  • The subsequent 4G calls for the offline DNN are rejected with the GTP cause “No resources available".
Configuring the Offline DNN Profile
This section describes how to enable the offline mode for a DNN profile.
Switching the DNN Profile to Offline Mode
To change the DNN profile to offline mode, use the following sample configuration:
config
  profile dnn dnn_profile_name
    mode dnn_mode
    end
NOTES:
  • profile dnn dnn_profile_name : Specify the DNN profile.
  • mode dnn_mode : Specify the DNN mode of operation. When the DNN mode is set to offline , the new sessions are rejected. The default value is online .
Verifying the DNN Profile Offline Mode Configuration
This section describes how to verify if the DNN profile is set to the offline mode.
The following is an example output of the show running-config profile dnn profile_name command.
show running-config profile dnn intershat
       mode offline
       network-element-profiles chf chf1
       network-element-profiles amf amf1
       network-element-profiles pcf pcf1
       network-element-profiles udm udm1
       charging-profile chgprf1
       virtual-mac b6:6d:47:47:47:47
       ssc-mode 2 allowed [ 3 ]
       session type IPV4 allowed [ IPV6 IPV4V6 ]
       upf apn intershat
       dcnr true
   exit
OAM Support for DNN Profile Offline Mode Setting
This section describes operations, administration, and maintenance information for this feature.
Bulk Statistics Support
The following label is introduced as part of this feature:
  • LABEL_DISC_PDUSETUP_DNN_OFFLINE: This label is defined to indicate that the call is rejected because the DNN is in the offline mode.
DNN Inheritance
Feature Description
Table 5. Feature History
Feature Name
Release Information
Description
DNN Inheritance for 4G Sessions on Legacy Interfaces
2024.02.0
SMF with legacy interfaces support the DNN inheritance feature.
SMF provides a way to configure common attributes in a parent DNN profile template and reuse it in other DNN profiles, for example, child DNN profiles as and when required. This feature optimizes the DNN profile configurations and improves the operational efficiency.
Note
The DNN Inheritance feature is currently qualified only for SMF (including legacy interfaces) and not for cnSGW-C.
How it Works
This section provides details about how the network operators can perform the DNN profile configuration to inherit or reuse a parent DNN profile.
Table 6. Preparation to Configure the Parent DNN Profile
Step Description
Configure parent DNN profile having common attributes.
Inherit the configured parent DNN profile in a child DNN profile.
The following conditions apply:
  • If a child profile is trying to inherit a DNN profile that doesn’t exists, then the SMF CLI displays an error while committing the changes.
  • If the parent DNN profile is deleted but found in a child profile, then SMF CLI displays an error while committing the changes.
    Note
    Delink the parent profile from the child DNN profile to delete the parent DNN profile.
  • If the attributes configured in a child DNN profile do not belong to any parent DNN profile, then the operator can modify those attributes in an individual child DNN profile.
SMF receives request for the child DNN profile. If the child DNN profile has an inherit attribute, then SMF resolves the inherited/parent profile based on the following conditions:
  • If the parent profile is found and the child profile doesn’t override parent attributes, then SMF updates the child profile with inherited attributes.
  • If a parent profile is found and a child profile overrides some or all the parent attributes, then SMF prioritizes overridden attributes over a parent profile and updates the child profile by taking overridden attributes from a child profile and the rest of the attributes from a parent profile.
  • If a parent profile has attributes in the form of arrays or slices, and the child profile also has the same attributes configured, then the resultant DNN profile overrides that attribute completely from the child profile, which means the combined profile contains the value of the child attribute.
    Example for DNN profiles:
    profile dnn intershat_Parent // parent dnn profile
              ims mark qci [ 83 128 ]
              charging-profile chgprfFBC
              override         [ charging-profile charging-characteristics-id ]
              dcnr             true
            exit
     profile dnn intershatRoamer // child dnn profile
        inherit  intershat_Parent
        override [ charging-characteristics-id charging-qbc-profile ]
     exit
    Example for resultant profiles:
     profile dnn intershatRoamer // Resultant dnn profile
               override        [charging-characteristics-id charging-qbc-profile ]
               dcnr             true
             exit
  • If a parent profile has attributes in the form of structures and the child profile also has the same attributes configured, then the resultant DNN profile overrides that attribute completely from child, which means the combined profile contains the value of a child attribute.
            dcnr             true
       exit
    exit
         dcnr             true
     exit
Note
When the SMF receives a request for the child DNN profile and the child DNN profile doesn’t have an inherit attribute, then the SMF returns all attributes from the child DNN profile.
Update the parent and child DNN profile at runtime. After the changes are committed, SMF picks the latest attributes from the child and parent profiles.
Configuring DNN Inheritance
You can define all the common attributes in a separate DNN profile and then use this parent profile in other DNN profiles by using the CLI configuration.
To inherit the parent DNN profile with common attributes, use the following sample configuration:
config
      inherit dnn_template_name
       dnn rmgr  ims_pool_ipv6
      end
NOTES:
  • inherit dnn_template_name : Specify the name of parent DNN profile to inherit to child profile(s).
The following is an example configuration to inherit the attributes from a parent DNN profile and use them in a child profile.
// Parent DNN profile
profile dnn dnnprof-ims.epdg.prod
  dns primary ipv4 10.177.0.34
  dns primary ipv6 fd00:976a::9
  dns secondary ipv4 10.177.0.210
  dns secondary ipv6 fd00:976a::10
  network-element-profiles chf nfprf-chf1
  network-element-profiles amf nfprf-amf1
  network-element-profiles pcf nfprf-pcf1
  network-element-profiles udm nfprf-udm1
  dnn ims.epdg.prod network-function-list [ chf pcf udm upf ]
  timeout up-idle 3600 cp-idle 7320
  charging-profile           chgprof-1
  pcscf-profile              pcscf1
  ppd-profile                ppd-prof1
  ssc-mode 1 allowed [ 2 ]
  session type IPV6
  session skip-ind false
  upf apn ims.epdg.prod
  qos-profile                5qi-to-dscp-mapping-table-IMS
  always-on                  true
  dcnr                       true
  userplane-inactivity-timer 3600
  only-nr-capable-ue         false
exit
// Child DNN profile
profile dnn dnnprof-ims.prod
  inherit dnnprof-ims.epdg.prod
  dnn rmgr ims-pool-ipv6
exit
IP Pool Allocation per DNN
Feature Description
The IP Pool Allocation feature supports mapping of a UE-requested DNN to a configured DNN for IP Pool selection. This feature is supported for the SMF and PGW-C in 5G and 4G.
SMF supports the following functionalities:
  • Supports configuration under the DNN profile to enable mapping of the UE-requested DNN to a DNN that is associated with an IP pool.
  • Sends the mapped DNN over Remote Procedure Call (gRPC) to the Resource Manager functionality under Node Manager service for IP allocation.
  • Supports configuration for IP pool DNN over the virtual DNN with Redundancy Manager, if available.
  • Sends the UE-requested DNN when both the configuration for IP pool and the virtual DNN are unavailable.
How it Works
This section provides a brief of how the IP Pool Allocation feature works.
  • The DNN profile lookup is based on the subscriber policy or DNN policy. The DNN profiles are associated in the SMF profile configuration. The subscriber policy takes precedence over the DNN policy when both the configurations are present.
  • The subscriber policy contains a list of precedence values. The selection of the precedence is based on the SUPI, GPSI, serving PLMN, and NSSAI value of the subscriber.
  • Each precedence has an associated operator policy. The DNN policy is picked from the selected operator policy.
  • The DNN policy can have a DNN profile configuration for each of the UE-requested DNNs.
  • The DNN profile contains the virtual or mapped DNN with its list of interfaces. This is an existing configuration and Redundancy Manager is also in the list of interfaces. For more information, see the Configuring a Virtual DNN under a DNN Profile section.
  • The configuration under the DNN profile contains the mapping of the UE-requested DNN to IP pool DNN.
  • The DNN profile selection occurs in the following order:
    • Based on the DNN policy, the order of selection is as follows: smf-profile > dnn-policy > dnn-profile (based on UE requested Dnn) > Virtual DNN mapping.
Note
  • IP pool DNN mapping takes precedence over the existing virtual DNN configuration if the Redundancy Manager configuration exists.
  • If both the configurations for the Redundancy Manager are not present, the UE-requested DNN is used to select the IP pool.
  • If the mapped DNN does not have the IP pool configured, then IP allocation fails, and the call is deleted.
  • Both the EPS and 5G calls follow the same principles for IP allocation for a DNN.
Configuring IP Pool Allocation
This section describes how to configure the IP Pool Allocation feature.
Configuring the IP Pool Allocation involves either one of the following steps:
  1. Configuring virtual DNN under DNN profile. For more information, see the Configuring a Virtual DNN under a DNN Profile section.
    Note
    This is a generic configuration along with other interfaces as an option.
  2. Allocating the IP pool per DNN
    Note
    This configuration is only for IP allocation.
Allocating the IP Pool per DNN
To allocate the IP pool per DNN, use the following sample configuration:
config
      dnn rmgr rmgr_name
      end
NOTES:
  • profile dnn dnn_profile_name : Map the Virtual DNN profile with the specified network DNN profile. dnn_profile_name must be an alphanumeric string.
  • dnn rmgr rmgr_name : Specifiy the Redundancy Manager to which the DNN profile will be sent. rmgr_name must be an alphanumeric string.
Verifying IP Pool Allocation Configuration
This section describes how to verify the IP pool allocation configuration.
Use the show full CLI command in the DNN Profile Configuration mode to verify the configuration associated with IP pool allocation per DNN.
The following is an example output of this show command.
[unknown] smf(config-dnn-cisco123)# show full
dns primary ipv4 209.165.200.231
dns primary ipv6 2001:DB8:1::1
dns secondary ipv4 209.165.200.232
dns secondary ipv6 2001:DB8:1::2
network-element-profile-list chf [ chgser1 ]
dnn starent.com network-function-list [ upf chf rmgr ]
dnn rmgr cisco.com
virtual-mac      01-00-5E-90-10-00
ppd-profile      ppd1
ssc-mode 1
session type IPV4
IP Pool Allocation per Slice and DNN
Feature Description
SMF supports IP pool allocation per slice with the same DNN. A slice is a logical end-to-end network that is created dynamically. A user equipent (UE) can access multiple slices over one access network, such as over the same radio interface.
SMF performs the following tasks:
  • Register, discover, subscribe, and send traffic to all the external NFs based on the slice ID.
  • Provide slice-based procedure and session statistics.
  • Provide slice information on an EDR.
  • Provide slice information on logs.
  • Limit the maximum number of supported slices on SMF to 512.
How it Works
SMF selects NFs, such as PCF, CHF, UDM, and AMF through the static configuration or NRF-based dynamic selection. In both these options, the messaging includes the slice information that is used in those interfaces.
  • Register slice with NRF.
  • Receive slice information on the N11 and N10 interfaces.
  • Use slice for peer NF discovery and UPF selection.
  • Send slice information on the N7 and N40 interfaces.
Limitations
The IP Pool Allocation per Slice and DNN feature has the following limitations:
  • Only the procedure and session statistics have the slice information. Other statistics are on NF level.
  • Enabling or disabling logging based on slice information is not supported.
Feature Configuration
This section describes how to configure the IP pool allocation per slice and DNN.
Configuring this feature involves the following steps:
  1. Configure tags. For details, see Configuring SMF Tags.
  2. Perform the dynamic node selection with slice using the following tasks:
  3. Configure NSSAI labels of smf_service_stats metrics for slice information on procedure and session statistice. For details, see Configuring Metrics Collection.
Configuring Allowed NSSAI Values
To configure the allowed NSSAI values for slicing, use the following sample configuration:
config
      instances instance_id
         allowed-nssai allowed_nssai_values
         end
NOTES:
  • allowed-nssai allowed_nssai_values : Specify one or multiple values for the allowed NSSAI for slicing.
Configuring Slice-based IP Pool Allocation
To configure the slice-based pool allocation, use the following sample configuration.
config
nssai name nssai_name
    sst sst_value
    sdt sdt_value
    dnn dnn_name_value
    pool-selection pool_selection_value
    end
NOTES:
  • pool-selection pool_selection_value : Configure the IP pool selection methods as DNN or NSSAI. The default pool selection method is DNN. If the pool selection method is slice or slice DNN only, then based on the slice and the DNN, the IP pools are selected.
    Note
    • When you configure the pool selection method as NSSAI for a slice, then in IPAM configuration for all the DNN for that UPF, you must configure "slice1" and "dnn" as values.
    • In IPAM, tag "nssai" is a string and must match with the SMF slice configuration name.
The following is an example configuration of the slice-based pool allocation.
nssai name slice1
 sst 02
 sdt  Abf123
 pool-selection [ dnn nssai ]
exit
