Troubleshooting Information
Summary Data
Table 1. Summary Data
Applicable Product(s) or FunctionalArea
SMF
Applicable Platform(s)
SMI
Feature Default Setting
Not Applicable
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details Release
Added the wait time display for ongoing bulk clear subscriber CLI and blocking the consecutive CLI.
2023.04.0
Added the following support:
  • Enabling UPF Monitor Subscriber from SMF.
  • Session Count per slice and NSSAI.
2023.03.0
As part of the IP pool allocation per slice and DNN feature, added example configuration to configure NSSAI labels of smf_service_stats metrics.
2022.04.0
Introduced support for classification and configuration of application metrics
2021.02.3
Added support for the following enhancements:
  • The show subscriber nf-service smf smf_url command to show subscriber details based on the IP address value of the vSMF or hSMF.
  • The clear subscriber nf-service smf smf_url command to clear subscriber details based on the IP address value of the vSMF or hSMF.
  • The show subscriber supi supi_id nf-service smf psid psid_value full command to show detailed subscriber information for roaming-specific use case as hSMF and vSMF.
  • The show subscriber supi supi_id nf-service smf psid psid_value summary command to show detailed information about subscriber sessions for roaming-specific use case as hSMF and vSMF.
2021.02.2
  • The show subscriber supi supi_value nf-service smf psid psid_value summary command to provide detailed information about subscriber sessions.
  • The clear subscriber nf-service smf and show subscriber nf-service smf commands with supported keywords and filters.
  • The clear subscriber and clear subscriber nf-service smf commands to support the reactivation keyword to clear sessions when release cause as reactivation-required is configured. This enhancement also supports disconnect and release reasons.
  • The imei keyword for monitor subscriber, clear subscriber, and show subscriber CLI commands.
2021.02.0
First introduced.
Pre-2020.02.0
Description
This chapter provides information on using the command line interface (CLI) commands, alerts, metrics, monitor tools, and logs for troubleshooting any issues that may arise during system operation.
Using CLI Data
This section describes the show and clear commands and the monitor commands that are used for troubleshooting.
Show and Clear Commands
show Commands
This section lists some of the key show commands that are available for troubleshooting the issues. The output of these show commands provides specific configuration and status information.
show config-error
Use this command to display the configuration error-related information for all pods in the cluster. The following sample output is for the show config-error command:
[smf] smf# show config-error
ERROR
COMPONENT       ERROR DESCRIPTION
RuleBase        Default bandwidth policy does not exist in rulebase <rba1> for charging action <ca1> .Dropping ruleDef <rda1>
RuleBase        Default bandwidth policy does not exist in rulebase <rba6> for charging action <ca1>.Dropping ruleDef <rda60>
RuleBase        Default bandwidth policy does not exist in rulebase <rba6> for charging action <ca1>.Dropping ruleDef <rda61>
ChargingAction  Packet filter <pkt1234> configured for charging action <ca4> associated with rulebase <rb1> does not exist
BandWidthPolicy Uplink peak data rate less than commited data rate in charging action <ca6>Dropping ruleDef <rd6>
Table 3. Output Field Descriptions for the show config-error Command
Field
Description
Error Component
Specifies the error component.
Error Description
Specifies the description of the Error.
show diagnostics
Use this command to display the diagnostics information. The following sample output is for the show diagnostics command:
[smf] smf# show diagnostics
POD INSTANCE       DIAGNOSTIC            COMPONENT  START TIME               STATUS   RETRIES
bgpspeaker-pod-1   Topology              AppInfra   2022/03/08 20:36:24.674  Success  0
bgpspeaker-pod-1   System Topology       AppInfra   2022/03/08 20:36:24.676  Success  0
sgw-service-0      Topology              AppInfra   2022/03/08 20:36:17.152  Success  0
sgw-service-0      System Topology       AppInfra   2022/03/08 20:36:17.154  Success  0
sgw-service-0      Cache Pod             AppInfra   2022/03/08 20:36:27.223  Success  0
sgw-service-0      SESSION_DB Datastore  AppInfra   2022/03/08 20:36:17.155  Success  0
li-ep-0            Topology              AppInfra   2022/03/08 20:36:20.743  Success  0
li-ep-0            System Topology       AppInfra   2022/03/08 20:36:20.741  Success  0
smf-service-1      Topology              AppInfra   2022/03/08 20:36:19.216  Success  0
smf-service-1      System Topology       AppInfra   2022/03/08 20:36:19.218  Success  0
smf-service-1      Cache Pod             AppInfra   2022/03/08 20:36:26.276  Success  0
smf-service-1      SESSION_DB Datastore  AppInfra   2022/03/08 20:36:19.220  Success  0
dns-proxy-0        Topology              AppInfra   2022/03/08 20:36:21.885  Success  0
dns-proxy-0        System Topology       AppInfra   2022/03/08 20:36:21.887  Success  0
protocol2-1        System Topology       AppInfra   2022/03/08 20:36:24.858  Success  0
protocol2-1        Cache Pod             AppInfra   2022/03/08 20:36:25.937  Success  0
protocol2-1        Topology              AppInfra   2022/03/08 20:36:24.856  Success  0
nodemgr-0          System Topology       AppInfra   2022/03/08 20:36:14.831  Success  0
nodemgr-0          Cache Pod             AppInfra   2022/03/08 20:36:26.485  Success  0
nodemgr-0          SESSION_DB Datastore  AppInfra   2022/03/08 20:36:14.833  Success  0
nodemgr-0          Topology              AppInfra   2022/03/08 20:36:14.835  Success  0
nodemgr-1          Topology              AppInfra   2022/03/08 20:36:23.068  Success  0
nodemgr-1          System Topology       AppInfra   2022/03/08 20:36:23.071  Success  0
nodemgr-1          Cache Pod             AppInfra   2022/03/08 20:36:26.690  Success  0
nodemgr-1          SESSION_DB Datastore  AppInfra   2022/03/08 20:36:23.066  Success  0
Table 4. Output Field Descriptions for the show diagnostics Command
Field
Description
Component
Specifies the component name.
Diagnostics
Specifies the diagnostics details.
Pod Instance
Specifies the instance information of the pod.
Retries
Specifies the retry count.
Start Time
Specifies the start time of the application.
Status
Specifies if the diagnostics status is successful or not.
show endpoint all
Use this command to display the list of all internal and external endpoints running on all pods in the cluster. The following sample output is for the show endpoint all command:
[smf] smf# show endpoint all
        START    STOPPED
GR INSTANCE                ENDPOINT             ADDRESS  TYPE     STATUS                     INTERFACE  INTERNAL  TIME     TIME
cache-pod                  xx.xx.xx.xx:0000     Grpc     Started  cache-pod                  true       4 weeks   <none>   0
internal-admin-ep          xx.xx.xx.xx:0000     Rest     Started  internal-admin-ep          true       4 weeks   4 weeks  0
internal-admin-ep          xx.xx.xx.xx:0000     Rest     Started  internal-admin-ep          true       4 weeks   <none>   0
keep-alived-ep             xx.xx.xx.xx:0000     Tcp      Started  keep-alived-ep             true       2 weeks   <none>   0
oam-grpc-ep                xx.xx.xx.xx:0000     Grpc     Started  oam-grpc-ep                true       4 weeks   <none>   0
oam-rest-ep                xx.xx.xx.xx:0000     Rest     Started  oam-rest-ep                true       4 weeks   <none>   0
Table 5. Output Field Descriptions for the show endpoint all Command
Field
Description
Address
Specifies the host and port of the endpoint.
Endpoint
Specifies the name of the endpoint.
GR Instance
Specifies the GR instance.
Interface
Specifies the interface name of the endpoint.
Internal
Specifies the type of the endpoint (Internal or External).
Start Time
Specifies the start time of the endpoint.
Status
Specifies current status of the endpoint.
Stopped Time
Specifies the end time of the endpoint.
Type
Specifies the type of the endpoint.
show endpoint info
Use this command to display the list of endpoints running on all pods in the cluster. The following sample output is for the show endpoint info command:
[smf] smf# show endpoint info
        START    STOPPED  GR
ENDPOINT                 ADDRESS              TYPE  STATUS   INTERFACE  INTERNAL  TIME     TIME     INSTANCE
sbi                     xxx.xxx.xxx.xxx:0000  Rest  Started  rest       false     2 weeks  <none>   0
Table 6. Output Field Descriptions for the show endpoint all Command
Field
Description
Address
Endpoint
GR Instance
Interface
Internal
Start Time
Status
Stopped Time
Type
show geo-maintenance-mode
Use this command to display whether the maintenance mode is enabled or disabled. The following sample output is for the show geo-maintenance-mode command:
[smf] smf# show geo-maintenance-mode
result "geo-maintenance-mode is disabled"
result "geo-maintenance-mode is enabled"
show georeplication checksum instance-id
Use this command to display replication details for etcd and cache-pod data. The following sample output is for the show georeplication checksum instance-id command:
[smf] smf# show georeplication checksum instance-id
Value for 'instance-id' (<string>): 1
checksum-details
ID      Type  Checksum
1       ETCD  1646812528
IPAM    CACHE 1646812528
NRFMgmt CACHE 1646812528
show georeplication-status
Use this command to display the replication status between two racks in a Geo setup.
The following sample output displays, if the connection is successful:
[smf] smf# show georeplication-status
result "pass"
The following sample output displays, if there is an error:
result "fail: [424] checksum missmatch"
show helm
The show helm command displays the version information for the SMF system image.
show ipam pool
Field
Description
PoolName
Name of the Address Pool.
Ipv4Utilization
Utilization percentage for IPv4 address for this pool.
Ipv6AddrUtilization
Utilization percentage for IPv6 address for this pool.
Ipv6PrefixUtilization
Utilization percentage for IPv6 prefix address for this pool.
show ipam pool <pool-name>
Field
Description
Ipv4Addr [Total/Used/Utilization]
Total IPv4 address available(configured for this pool) / Number of used address / Utilization percentage for IPv4 address.
Ipv6Addr [Total/Used/Utilization]
Total IPv6 address available(configured for this pool) / Number of used address / Utilization percentage for IPv6 address.
Ipv6Prefix [Total/Used/Utilization]
Total IPv6 prefix address available(configured for this pool) / Number of used address / Utilization percentage for IPv6 prefix
show ipam pool <pool-name> ipv4-addr
Field
Description
StartAddress
Start address of the range.
EndAddress
End address of the range.
AllocContext
Name of data plane to which this address range is allocated.
Flag
Flag Indicate weather pool is Static or if it is offline.
show ipam pool <pool-name> ipv6-addr
Field
Description
StartAddress
EndAddress
AllocContext
Flag
show ipam pool <pool-name> ipv6-prefix
Field
Description
StartAddress
EndAddress
AllocContext
Name of data plane this address range is allocated.
Flag
Flag Indicates whether pool is Static or if it is offline, S(Static) and O(Offline).
show ipam dp
Field
Description
DpName
Name of the data plane which is registered.
Ipv4Utilization
Utilization percentage for IPv4 by this data plane.
Ipv6AddrUtilization
Utilization percentage for Ipv6 address by this data plane.
Utilization percentage for Ipv6 prefix by this data plane.
show ipam dp <dataplane-name>
Field
Description
Total IPv4 address available(configured for this data plane) / Number of used address / Utilization percentage for IPv4.
Total IPv6 address available(configured for this data plane) / Number of used address / Utilization percentage for IPv6.
Total IPv6 prefix address available(configured for this data plane) / Number of used address / Utilization percentage for IPv6 prefix.
show ipam dp <dataplane-name> ipv4-address
Field
Description
StartAddress
EndAddress
Route
Route allocated for this data plane.
N/P
Display the NodeMgr instance IDs from which it received routes Flag Indication S(Static) and O(Offline).
Field
Description
StartAddress
EndAddress
AllocContext
Flag
show ipam
Field
Description
PoolName
Displays Ipv4Utilization, Ipv6AddrUtilization, and Ipv6PrefixUtilization.
DpName
Displays Ipv4Utilization, Ipv6AddrUtlization, and Ipv6PrefixUtlization.
show nrf registration-info
Table 7. show nrf registration-info Command Output Description
Field
Description
NF Status
Displays the NRF registration information.
Registration Time
Displays the time of registration with NRF.
Active MgmtEP Name
Displays the active NRF management endpoint name.
Heartbeat Duration
Displays the heartbeat duration.
Uri
Displays the Uri information.
Host Type
Displays the NRF host type information.
GR Instance ID
Displays the GR instance ID.
show nrf subscription-info
Table 8. show nrf subscription-info Command Output Description
Field
Description
NF Instance Id
Displays the NF instance identity.
SubscriptionID
Displays the subscription identity information.
Actual Validity Time
Displays the actual validity time received from NRF server.
Requested Validity Time
Displays NF requested validity subscription time.
GR Instance ID
show nrf discovery info
Table 9. show nrf discovery info Command Output Description
Field
Description
NF Type
Displays the NF type information.
Number of Discovery Filters
Displays the number of discovery filters.
Number of NF Profiles
Displays the number of NF profiles.
GR Instance ID
show nrf discovery-info AMF discovery-filter
Table 10. show nrf discovery-info AMF discovery-filter Command Output Description
Step
Description
Discovery Filter
Displays the discovery filter information.
Expiry Time
Displays the expiry time for discovery filter.
GR Instance ID
show nrf discovery-info AMF discovery-filter <discovery_filter>
Table 11. show nrf discovery-info AMF discovery-filter <discovery_filter> Command Description
Field
Description
NF InstanceId
Displays the NF Instance Identity.
NF Type
Displays the NF Type Information.
Discovery Filter
Displays the Discovery Filter Information.
NF Status
Displays the NF Status Information.
Priority
Displays the Priority Information.
Capacity
Displays the NF Profile Capacity Information.
Load
Displays the Load Information.
Locality
Displays the Locality Information.
ipv4 address
Displays IPv4 Address received from the discovery response for this NF profile.
ipv6 address
Displays the IPv6 Address received from the discovery response for this NF profile.
show nrf discovery-info AMF discovery-filter <discovery_name> nf-discovery-profile <nf_discovery_profile> nf-service
Table 12. show nrf discovery-info AMF discovery-filter <discovery_name> nf-discovery-profile <nf_discovery_profile> nf-service Command Output Description
Field
Description
ServiceInstanceId
Displays the NF Service Instance ID.
ServiceName
Displays the NF Service Name.
UriScheme
Displays the Uri Scheme Information.
show peers all
Use this command to display the list all external inbound and outbound connections that are established by SMF. Only the key information is displayed. The following sample output is for the show peers all command:
[smf] smf# show peers all
GR        POD                CONNECTED                                   INTERFACE
INSTANCE  ENDPOINT      LOCAL ADDRESS   PEER ADDRESS     DIRECTION  INSTANCE     TYPE  TIME       RPC     ADDITIONAL DETAILS       NAME       VRF
1         <none>        xx.xx.xx.xx    xx.xx.xx.xx:0000  Outbound   rest-ep-0    Rest  25 hours   UDM     <none>                     n10
1         <none>        xx.xx.xx.xx    xx.xx.xx.xx:0000  Outbound   rest-ep-0    Rest  25 hours   CHF     <none>                     n40
1         <none>        xx.xx.xx.xx    xx.xx.xx.xx:0000  Outbound   rest-ep-0    Rest  25 hours   PCF     <none>                     n7
1         <none>        xx.xx.xx.xx    xx.xx.xx.xx:0000  Outbound   rest-ep-0    Rest  25 hours   AMF     <none>                     n11
Table 13. Output Fields Description for the show peers all Command
Field
Description
Additional Details
Specifies the additional details for the peer such as status or type.
Connected Time
Specifies the duration of the connected peer.
Direction
Specifies if peer connection direction is inbound or outbound.
Endpoint
GR Instance
Interface Name
Specifies the interface name for the endpoint.
Local Address
Specifies the local IP address and port of the instance. For endpoint, it is the endpoint address and port. For RPC, it is the instance IP.
Peer Address|
Specifies the host and port of peer address.
Pod Instance
Specifies the pod for the peer.
RPC
Specifies the rpc of the specific peer.
Type
Specifies the type of peer.
show resources
Use this command to display the list of resource information for all pods in the cluster. The following sample output is for the show resources command:
[smf] show resources
                          TOTAL   USED    DISK
                          NODE    POD     USAGE  GO               GC
                   CPU    MEMORY  MEMORY  IN     ROUTINES  GC     PAUSE
POD INSTANCE       USAGE  IN MB   IN MB   KBPS   COUNT     COUNT  IN NS
bfdmgr-1           0      32117   56      0      56        1950   56
bfdmgr-2           0      32117   55      0      56        1935   55
bfdmgr-3           1      32117   54      0      56        2636   54
bfdmgr-4           0      32117   55      0      56        1946   55
bgpspeaker-pod-1   1      32117   104     0      94        9315   104
bgpspeaker-pod-2   1      32117   102     0      78        9300   102
cache-pod-1        4      7962    96      0      325       778    96
cache-pod-2        10     32117   91      0      325       778    91
gtpc-ep-0          2      32117   82      0      160       777    82
internal-gr-pod-1  2      32117   124     0      317       63     124
internal-gr-pod-2  1      32117   93      0      182       63     93
li-ep-0            0      32117   64      0      68        2723   64
nodemgr-0          3      32117   113     0      270       784    113
nodemgr-1          2      32117   115     0      252       784    115
oam-pod-0          3      7962    121     0      249       2110   121
protocol-0         2      32117   82      0      159       777    82
radius-ep-0        5      32117   76      0      145       782    76
rest-ep-0          3      32117   105     0      298       779    105
sgw-service-0      9      32117   138     0      262       779    138
smf-service-0      3      32117   228     0      347       2645   228
udp-proxy-0        0      32117   72      0      112       778    72
udp-proxy-1        0      32117   72      0      112       778    72
Table 14. Output Field Descriptions for the show resources Command
Field
Description
CPU Usage
Specifies CPU Usage In Percentage.
Disk Usage In Kbps
Specifies disk usage in Kbps.
GC Count
Specifies garbage collection cycle count.
GC Pause In NS
Specifies garbage collection pause in nanoseconds.
Go Routines Count
Specifies count of go routines.
Pod Instance
Specifies the instance info of the pod.
Total Node Memory In MB
Specifies total node memory usage in MB.
Used Pod Memory In MB
Specifies the consumption of pod memory in MB.
show rpc all
Use the show rpc all command to display the list of all the RPCs from all the pods with RPC and remote host information.
The following sample output is for the show rpc all command:
[smf] smf# show rpc all | tab | nomore
        PROCESSING
        CONNECTED  DISCONNECTED  MONITOR  INSTANCE
POD INSTANCE       NAME                        REMOTE ADDRESS             REMOTE HOST         TYPE                    SET NAME         STATUS    TIME       TIME          RPCHOST  INFO                                              VERSION
cache-pod-1        cache-pod-affinity          xx.xx.xx.xx:0000           cache-pod_20        Grpc                    cache-pod_2      Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-1        cache-pod-affinity          xx.xx.xx.xx:0000           cache-pod_10        Grpc                    cache-pod_1      Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-1        stream_cache-pod-affinity   xx.xx.xx.xx:0000           cache-pod_10        GrpcServerClientStream  cache-pod_1      Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-1        stream_cache-pod-affinity   xx.xx.xx.xx:0000           cache-pod_20        GrpcServerClientStream  cache-pod_2      Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-1        oam-pod                     xx.xx.xx.xx:0000           oam-pod             GrpcStream              <none>           Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-1        Replication                 xx.xx.xx.xx:0000           cachepod_1          GrpcStream              <none>           Started   3 weeks    <none>        false    <none>                                            <none>
cache-pod-1        Replication                 xx.xx.xx.xx:0000           cachepod_2          GrpcStream              <none>           Started   3 weeks    <none>        false    <none>                                            <none>
cache-pod-2        cache-pod-affinity          xx.xx.xx.xx:0000           cache-pod_10        Grpc                    cache-pod_1      Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-2        cache-pod-affinity          xx.xx.xx.xx:0000           cache-pod_20        Grpc                    cache-pod_2      Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-2        stream_cache-pod-affinity   xx.xx.xx.xx:0000           cache-pod_20        GrpcServerClientStream  cache-pod_2      Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-2        stream_cache-pod-affinity   xx.xx.xx.xx:0000           cache-pod_10        GrpcServerClientStream  cache-pod_1      Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-2        oam-pod                     xx.xx.xx.xx:0000           oam-pod             GrpcStream              <none>           Started   4 weeks    <none>        false    <none>                                            <none>
cache-pod-2        Replication                 xx.xx.xx.xx:0000           cachepod_1          GrpcStream              <none>           Started   3 weeks    <none>        false    <none>                                            <none>
cache-pod-2        Replication                 xx.xx.xx.xx:0000           cachepod_2          GrpcStream              <none>           Started   3 weeks    <none>        false    <none>                                            <none>
example-rest-ep-1  example-service             example-service:0000       example-service0    Grpc                    example-service  Started   2 weeks    <none>        true     example.example-service.cluster1.example-data.12  <none>
Table 15. Output Field Descriptions for the show rpc Command
Field
Description
Connected Time
Specifies the duration when the RPC host is connected.
Disconnected Time
Specifies the duration when the RPC host is disconnected.
Monitor RPC Host
Indicates whether the RPC host is being monitored for connection status.
Name
Displays the name of the RPC registered in pod.
Pod Instance
Displays the instance information of the pod.
Processing Instance Info
Indicates the processing instance name, if available.
Remote Address
Displays IP address and port of remote endpoint.
Remote Host
Displays the name of the RPC host.
Set Name
Displays the RPC set name for a group of RPC hosts.
Status
Displays the current status of the RPC host. The status values are Started, Starting, and Stopped.
Type
Displays the type of connection such as Rest, Grpc, and GrpcStream.
Version
Displays the version of the RPC host API, if available.
show running-status
Use this command to display the running status related information for all the pods in system. The following sample output is for the show running-status command:
[smf] smf# show running-status
                   RUNNING  SYSTEM  START
POD INSTANCE       STATUS   HEALTH  TIME
bfdmgr-1           Started  Normal  2 hours
bfdmgr-2           Started  Normal  2 hours
bgpspeaker-pod-1   Started  Normal  2 hours
bgpspeaker-pod-2   Started  Normal  2 hours
cache-pod-1        Started  Normal  2 hours
cache-pod-2        Started  Normal  2 hours
dns-proxy-0        Started  Normal  2 hours
dns-proxy-1        Started  Normal  2 hours
gtpc-ep1-1         Started  Normal  2 hours
gtpc-ep1-2         Started  Normal  2 hours
gtpc-ep2-1         Started  Normal  2 hours
gtpc-ep2-2         Started  Normal  2 hours
internal-gr-pod-1  Started  Normal  2 hours
internal-gr-pod-2  Started  Normal  2 hours
li-ep-0            Started  Normal  2 hours
li-ep-1            Started  Normal  2 hours
nodemgr-0          Started  Normal  2 hours
nodemgr-1          Started  Normal  2 hours
oam-pod-0          Started  Normal  2 hours
protocol1-1        Started  Normal  2 hours
protocol1-2        Started  Normal  2 hours
protocol2-1        Started  Normal  2 hours
protocol2-2        Started  Normal  2 hours
radius-ep-0        Started  Normal  2 hours
radius-ep-1        Started  Normal  2 hours
rest-ep-0          Started  Normal  2 hours
rest-ep-1          Started  Normal  2 hours
sgw-service-0      Started  Normal  2 hours
sgw-service-1      Started  Normal  2 hours
sgw-service-2      Started  Normal  2 hours
sgw-service-3      Started  Normal  2 hours
sgw-service-4      Started  Normal  2 hours
sgw-service-5      Started  Normal  2 hours
smf-service-0      Started  Normal  2 hours
smf-service-1      Started  Normal  2 hours
smf-service-2      Started  Normal  2 hours
smf-service-3      Started  Normal  2 hours
smf-service-4      Started  Normal  2 hours
smf-service-5      Started  Normal  2 hours
udp-proxy-0        Started  Normal  2 hours
udp-proxy-1        Started  Normal  2 hours
Table 16. Output Field Descriptions for the show running-status Command
Field
Description
Pod Instance
Running Status
Specifies the system running status (Starting, Started, Stopping, or Stopped).
Start Time
System Health
Specifies the health status of the application.
show sessions affinity
Use this command to display affinity count, pod instance wise. This affinity count defines the affinity of sessions toward the pod. The following sample output is for the show sessions affinity command:
[smf] smf# show sessions affinity
POD
INSTANCE    COUNT
service-1   10
service-11  12
service-12  15
service-13  12
service-14  15
service-2   15
service-3   14
service-4   19
Table 17. Output Field Descriptions for the show sessions affinity Command
Field
Description
Count
Specifies the affinity count.
Pod Instance
show sessions commit-pending
Use this command to display the current number of sessions per pod along with the sessions that are pending commit in the database. The following sample output is for the show sessions commit-pending command:
[smf] smf# show sessions commit-pending
                                         DB
               GR               PENDING  BINARY  LAST DB SYNC
POD INSTANCE   INSTANCE  COUNT  COMMIT   SIZE    TIME
sgw-service-1  1         0      0        0       Less than a second
sgw-service-1  2         0      0        0       Less than a second
sgw-service-2  1         0      0        0       Less than a second
sgw-service-2  2         0      0        0       Less than a second
sgw-service-4  1         0      0        0       Less than a second
sgw-service-4  2         0      0        0       Less than a second
sgw-service-5  1         0      0        0       Less than a second
sgw-service-5  2         0      0        0       Less than a second
smf-service-0  1         0      0        0       Less than a second
smf-service-0  2         0      0        0       Less than a second
smf-service-1  1         0      0        0       Less than a second
smf-service-1  2         0      0        0       Less than a second
smf-service-2  1         0      0        0       Less than a second
smf-service-2  2         0      0        0       Less than a second
smf-service-4  1         0      0        0       Less than a second
smf-service-4  2         0      0        0       Less than a second
smf-service-5  1         0      0        0       Less than a second
smf-service-5  2         0      0        0       Less than a second
Table 18. Output Field Descriptions for the show sessions commit-pending Command
Field
Description
Count
Specifies the count.
DB Binary Size
Specifies the DB binary Size.
GR Instance
Specifies the GR Instance ID.
Last DB Sync Time
Specifies the previous DB sync time.
Pod Instance
show subscriber
This commands displays the existing show subscriber CLI output with the newly added CLI output.
Table 19. show subscriber Command Output Description
Field
Description
all
Displays the information for all SUPIs or IMEIs.
amf
Displays the AMF address.
chf
Displays the CHF address.
count
Displays the number of sessions.
debug
Displays the debugging information.
dnn
Displays the DNN value.
gr-instance
Displays the Geographic Redundancy (GR) instance.
gtp-peer
Displays the GTP-peer address.
imei
Displays the IMEI containing 15 or 16 digits.
namespace
Important
This keyword is deprecated in release 2021.02.0 and replaced with the nf-service keyword.
Displays the product namespace under which to search. Default: none.
nf-service { none | sgw | smf }
Displays the network function service under which to search. Default: none.
pcf
Displays the PCF address.
rat
Displays the RAT type as 4G or 5G.
roaming-status
Displays the UE roaming status—homer, visitor-lbo, visitor-hr, roamer.
supi
Displays the SUPI value.
udm
Displays the UDM address.
upf
Displays the UPF address.
rulebase
Displays the subscriber using the rulebase.
The output modifiers.
show subscriber all
Use this command to display all the sessions for all the SUPIs and NF services. The following sample output is for the show subscriber all command:
[smf] smf# show subscriber all
subscriber-details
  "subResponses": [
      "id-index:1:0:32768",
      "id-value:16777505",
      "imsi:imsi-123456123456123",
      "msisdn:msisdn-123456123456123",
      "imei:imei-310220000000000",
      "upf:xx.xx.xx.xx",
      "upfEpKey: xx.xx.xx.xx: xx.xx.xx.xx ",
      "s5s8Ipv4: xx.xx.xx.xx ",
      "s11Ipv4: xx.xx.xx.xx",
      "namespace:sgw",
      "nf-service:sgw"
      "roaming-status:roamer",
      "ue-type:4g-only",
      "supi:imsi-123456123456123",
      "gpsi:msisdn-123456123456123",
      "pei:imei-310220000000000",
      "psid:69",
      "dnn:papn1.com",
      "emergency:false",
      "rat:e-utran",
      "access:3gpp access",
      "connectivity:4g",
      "auth-status:authenticated",
      "pcfGroupId:PCF-*",
      "policy:2",
      "pcf: xx.xx.xx.xx",
      "ipv4-addr:pool-static1-v4/xx.xx.xx.xx",
      "ipv4-pool:pool-static1-v4",
      "ipv4-range:pool-static1-v4/xx.xx.xx.xx",
      "ipv4-startrange:pool-static1-v4/",
      "id-value:8/310",
      "upf:xx.xx.xx.xx",
      "chfGroupId:CHF-*",
      "chf:209.165.202.133",
      "gtp-peer:xx.xx.xx.xx",
      "peerGtpuEpKey:xx.xx.xx.xx:xx.xx.xx.xx",
      "namespace:smf",
      "nf-service:smf"
Table 20. show subscriber Command Output Description
Field
Description
subscriber-details
Displays the details for all subscribers in JSON format.
show subscriber count
This command displays the CLI options for the count CLI command.
Table 21. show subscriber count Command Output Description
Field
Description
all
Displays all the SUPIs.
amf
apn
Displays the APN value.
auth-status
Displays the RADIUS Authentication Status - authenticated or unauth status.
chf
connectivity
Displays the connectivity - 4g or 5g.
dnn
emergency
Displays the Emergency Session indication - true or false.
gpsi
Displays the GPSI value.
gr-instance
Displays the subscriber's from the provided GR Instance.
gtp-peer
Displays the GTP peer address.
ipv4-addr
Displays IPv4 address in the format:- <poolName> or <ipv4-addr>.
ipv4-pool
Displays the IPv4 pool name.
ipv4-range
Displays the IPv4 address range.
ipv6-pfx
Displays IPv6 prefix in the format <poolName> or <ipv6-pfx>
ipv6-pool
Displays the IPv6 pool name.
ipv6-range
Displays the IPv6 prefix range.
msid
Displays the MSID value.
msisdn
Displays the MSISDN value
namespace
Displays the deprecated option, use nf-service instead (default: none).
nf-service
Displays the network function service (SMF, S-GW) under which to search (default: none).
This parameter can be used with the slice name or the NSSAI filter for SMF in the following format:
nf-service smf slice-name or nf-service smf nssai .
pcf
peerGtpuEpKey
Displays the GTPU peer address in <upf_addr:gptu-peer-addr> format.
pei
Displays the PEI - Permanent Equipment Identifier.
policy
Displays the Subscriber Policy Information.
rat
roaming-status
Displays the UE roaming status – homer/roamer/visitor-hr/lbo-visitor.
smf
Displays the SMF address.
supi
Displays the specific SUPI value.
udm-sdm
Displays the UDM-SDM Address.
udm-uecm
Displays the UDM-UECM Address.
ue-type
Displays the device capability - 4g-only or nr-capable.
upf
rulebase
Displays the output modifiers.
show subscriber count all
Use this command to display the total number of sessions for all the SUPIs. The following sample output is for the show subscriber count all command:
[smf] smf# show subscriber count all
subscriber-details
  "sessionCount": 20
Table 22. Output Field Descriptions for the show subscriber count all Command
Field
Description
subscriber-details
Displays the count for all subscribers in JSON format.
show subscriber debug-info
This command displays the debug information for the specific SUPI value where the PSID value is optional.
Table 23. show subscriber debug-info Command Output Description
Field
Description
gpsi
Displays GPSI value.
gr-instance
imsi
Displays the IMSI value.
msid
msisdn
Displays the MSISDN value.
namespace
Deprecated option, Use nf-service instead (default: none)
nf-service
Displays the network function service (SMF, SGW) under which to search (default: none).
pei
Displays the PEI or IMEI value.
supi
Displays the SUPI value, value must include the imsi- prefix.
show subscriber gpsi
Table 24. show subscriber gpsi
Field
Description
policy
Displays the policy information.
ipv4-addr
dnn
pcf
Displays the PCF Address.
rat
Displays the RAT Type—nr, e-utran, or wlan information.
connectivity
Displays the connectivity—4G or 5G.
ipv4-range
chf
pei
Displays the Permanent Equipment Identifier (PEI).
udm
upfEpKey
Displays the UPF address EP key information.
ipv6-pfx
Displays the IPv6 prefix information.
ipv6-pool
chfGroupId
Displays the CHF address group ID information.
gpsi
Displays the Generic Public Subscription Identifier (GPSI).
pcfGroupId
Specifies PCF Address group ID.
upf
ipv4-pool
ipv6-range
amf
supi
access
Displays the access information.
gr-instance
Displays the GR instance.
Important
The wildcard input is not supported with the listed filters.
Table 25. show subscriber nf-service smf Command Output Description
Field
Description
apn
msid
msisdn
roaming-status
smf
Displays the subscriber details based on the IP address value of the vSMF or hSMF.
For example:
[smf] smf# show subscriber nf-service smf smf <smf_url>
                                    subscriber-details
rulebase
show subscriber pei
Table 26. show subscriber pei
Field
Description
policy
ipv4-addr
dnn
pcf
rat
connectivity
ipv4-range
chf
pei
udm
upfEpKey
ipv6-pfx
ipv6-pool
Displays the IPv6 Pool name.
chfGroupId
gpsi
pcfGroupId
Displays the PCF address group ID.
upf
ipv4-pool
ipv6-range
amf
supi
access
gr-instance
rulebase
show subscriber supi <supi_value> nf-service smf psid <psid_value> full
This command displays detailed subscriber information.
Table 27. show subscriber supi <supi_value> nf-service smfpsid <psid_value> full Command Output Description
Field
Description
sessTimeStamp
Displays the connected time of the session.
callDuration
Displays the call duration.
commonId
Displays the call ID equivalent for the session (common ID).
ipPool, ipv6Pool
Displays the IP pool from which the address has been allocated.
linkedEbi
Displays the linked EBI for a session.
snssai
Displays the sNssai details.
smfIwkEpsInd
Displays the SMF EPS IWK decision based on AMF and UDM data.
TotalNumberOfPdrs
Displays the number of associated PDRs.
TotalNumberOfFars
Displays the number of associated FARs.
TotalNumberOfQers
Displays the number of associated QERs.
TotalNumberOfUrrs
Displays the number of associated URRs.
upfSeid
Displays the remote SEID for a particular UPF session.
epsInterworking Indication
Displays the EPS interworking indication status of AMF.
ebi
Displays the ERAB ID allocated for each flow.
revalidationTime
Displays the revalidation timer information for a session.
show subscriber supi <supi_value> nf-service smfpsid <psid_value> summary
This command displays detailed information about subscriber sessions. This command improves usability and can be used for debugging purposes.
Table 28. show subscriber supi <supi_value> nf-service smf psid <psid_value> summary Command Output Description
Field
Description
supi
Displays the 5G Subscription Permanent Identifier.
pduSessionId
Displays the PDU session identifier.
pduSesstype
Displays the PDU session type.
accessType
Displays the access type.
dnn
Displays the DNN profile name.
allocatedIp/ allocatedIpv6
Displays the allocated IP address details.
ratType
Displays the RAT type.
sessTimeStamp
Displays the connected Time of the session.
TotalDynamicRules/ TotalStaticRules/ TotalPredefinedRules
Displays the number of Dynamic rules or Static rules or Predefined rules.
TotalGBRFlows/ TotalNonGBRFlows
Displays the number of GBR flows or non-GBR flows.
pcfInteraction
Displays the PCF interaction status.
ruleBase
Displays the rulebase name.
chargingId
Displays the charging descriptor name.
offlineConverted
Displays the online charging parameters converted to offline.
chargingDisabled
Displays the charging parameters when charging is disabled.
dropTraffic
Displays the charging parameters when traffic is dropped.
gtppGrp
Displays the EGCDR configuration for GTPP name.
profileName
Displays the charging profile name.
deferredUsageCount
Displays the number of deferred multi-unit usages.
smfSeid
Displays the local SEID for a particular UPF session.
upfSeid
TunnelID
Displays the GTPU peer tunnel ID.
TunnelName
Displays the GTPU peer tunnel name.
RemoteTeid (teid/ipAddr)
Displays the GTPU peer TEID and IP address.
TotalNumberOfPdrs
TotalNumberOfFars
TotalNumberOfQers
TotalNumberOfUrrs
clear Commands
This section lists some of the key clear commands that are available for troubleshooting the issues.
Important
The SMF Ops center allows you to issue only one clear subscriber all command at a time. The Ops center restricts the subsequent clear subscriber all and other variants of clear subscriber commands until the ongoing clear subscriber all command is complete.
Note
The Ops Center displays the expected waiting time for an ongoing bulk clear subscriber CLI command. In addition, the clear subscriber CLI gets blocked while the processing of the earlier CLI is in progress.
clear subscriber
"clear subscriber" command displays the list of subscriber SMF fields.
Table 29. clear subscriber Command Output Description
Field
Description
all
Clears all the session information.
amf
Clears subscriber based on AMF address information.
chf
Clears subscriber based on CHF address information.
dnn
Clears subscriber based on DNN value.
gr-instance
Clears subscriber based on the specified Geographic Redundancy (GR) instance information.
gtp-peer
Clears subscriber based on GTP peer address information.
ipv4-pool
Clears subscriber based on IPv4 pool name.
ipv4-range
Clears subscriber based on IPv4 address-range value.
ipv6-pool
Clears subscriber based on IPv6 pool name information.
ipv4-range
Clears subscriber based on IPv4 prefix-range value.
ipv6-range
Clears subscriber based on IPv6 prefix-range value.
namespace
Important
This keyword is deprecated in release 2021.02.0 and is replaced with the nf-service keyword.
Clears subscriber based on the respective namespace. Default: none.
Clears subscriber based on the specified network function service. Default: none.
pcf
Clears subscriber based on PCF address information.
policy
Clears subscriber information based on policy.
purge
Clears subscriber information, if purged locally.
reactivation [ true | false ]
Clears subscriber based on the Reactivation Required cause value. This option is set to true if reactivation is requested.
roaming-status
Clears subscriber based on the UE roaming status—homer, visitor-lbo, visitor-hr, roamer values.
sgw
Clears subscriber information based on the S-GW address information.
smf
Clears subscriber information based on the SMF address information.
supi
Clears subscriber based on the SUPI value.
rulebase
Clears subscriber using the rulebase.
Important
"clear subscriber nf-service smf " command displays the list of nf-service SMF fields.
Table 30. clear subscriber nf-service smf Command Output Description
Field
Description
apn
Clears subscriber based on the APN value.
dnn
Clears subscriber based on the DNN value.
msid
Clears subscriber based on the MSID value.
msisdn
Clears subscriber based on the MSISDN value.
Clears subscriber based on the Reactivation Required cause. This option is set to true if reactivation is requested.
roaming-status
Clears subscriber based on the UE roaming status—homer, visitor-lbo, visitor-hr, roamer.
rulebase
Clears subscriber based on the rulebase value.
This keyword is used as a secondary filter. Ensure that the rulebase value includes the rulebase prefix.
For example:
[smf] smf# clear subscriber nf-service smf dnn <dnn_val> rulebase <rulebase_value>
   result
   ClearSubscriber Request submitted
rulename
Modifies session based on the rulename value.
This keyword is used as a secondary filter. Ensure that the rulename value includes the rulename prefix.
For example:
[smf] smf# clear subscriber nf-service smf dnn <dnn_val> rulename <rulename_value>
result
smf
Clears subscriber based on the IP address value of the vSMF or hSMF.
For example:
[smf] smf# clear subscriber nf-service smf smf <smf_url>
 result
x5qi
Modifies session based on 5QI for 5G sessions, and QCI for 4G and WLAN sessions. This keyword is used as a secondary filter.
For example:
smf] smf# clear subscriber supi <supi_val> x5qi <x5qi_value>
result
[smf] smf# clear subscriber apn <apn_val> x5qi <x5qi_value>
result
clear subscriber supi imsi <imsi_value>
"clear subscriber supi imsi imsi_value" command displays the list of subscriber SUPI IMSI value SMF fields.
Table 31. clear subscriber supi imsi <imsi_value> Command Output Description
Field
Description
ebi
Clears subscriber based on EPS bearer ID value.
imsi
Clears subscriber based on IMSI information.
purge
Clears true, if purged locally.
Output modifier.
clear subscriber supi imsi <imsi_value> psid <psid_value>
"clear subscriber supi imsi imsi_value psid psid_value" command displays the list of subscriber SUPI IMSI and PSID value SMF fields.
Table 32. clear subscriber supi imsi <imsi_value> psid <psid_value> Command Output Description
Field
Description
ebi
imsi
psid
Clears subscriber based on Service ID value.
purge
Output modifier.
Monitor Subscriber and Monitor Protocol
Feature Description
The SMF supports the Monitor Subscriber and Monitor Protocol on the Kubernetes environment. The monitor tools allow you to capture messages of subscribers and protocols.
This section provides information on CLI commands for monitoring the health of SMF.
Configuring the Monitor Subscriber and Monitor Protocol Feature
Monitoring the Subscriber Session
To monitor the subscriber in the SMF, use the following CLI command:
monitor subscriber [ capture-duration duration  | gr-instance gr_instance_id  | imei imei_id | imsi imsi_value | internal-messages [ yes ] | namespace [ sgw | smf ] | nf-service [ sgw | smf ] | supi supi_id | transaction-logs [ yes ] ]
NOTES:
  • capture-duration duration : Specify the duration in seconds during which monitor subscriber is enabled. The default value is 300 seconds (5 minutes). This is an optional parameter.
  • gr-instance gr_instance_id : Specify the GR instance ID. The instance ID 1 denotes the local instance ID.
  • imei imei_id : Specify the subscriber IMEI. For example: 123456789012345, *
  • imsi imsi_value : Specify the subscriber IMSI. For example: 123456789, *
  • internal-messages [ yes ] : Enable internal messages when set to yes . By default, it is disabled. This is an optional parameter.
  • namespace [ sgw | smf ] : Enable the specified namespace. By default, namespace is set to none. This is an optional parameter.
    Important
    This keyword is deprecated in release 2021.02.0 and replaced with nf-service keyword.
  • nf-service [ sgw | smf ] : Enable the specified NF service. By default, nf-service is set to none.
    Important
    The nf-service keyword replaces the namespace keyword in release 2021.02 and beyond.
  • supi supi_id : Specify the subscriber identifier. For example: imsi-123456789, imsi-123*
  • transaction-logs [ yes ] : Enable transaction logs when set to yes . By default, it is disabled. This is an optional parameter.
    To view the transaction history logs, use the dump transactionhistory command.
    Note
    The most recent transaction logs are stored in a circular queue of size 1024 transaction logs.
The monitor subscriber CLI command can be run simultaneously on multiple terminals. For example, run the CLI simultaneously in two SMF Ops Center terminals for two subscribers (for example, imsi-123456789012345 and imsi-456780123456789) to implement the following:
  • Monitor the duration when the monitor subscriber is enabled
  • View internal messages for the specified subscriber
  • View transaction logs for the specified subscriber
Terminal 1: The following command monitors and displays subscriber messages for the specified subscriber.
monitor subscriber supi imsi-123456789012345 capture-duration 1000 internal-messages yes
Terminal 2: The following command monitors and displays transaction logs for the specified subscriber.
monitor subscriber supi imsi-456780123456789 capture-duration 500 internal-messages yes transaction-logs yes
After the capture duration is completed, stop the CLI by using the Ctrl+C keys. The captured messages are reordered and stored in a file. To retrieve the list of stored files, use the monitor subscriber list CLI command.
For example:
RELEASE_NAMESPACE: 'smf'
'monsublogs/subscriberID_imsi-*_AT_2019-10-22T09:19:05.586237087.txt.sorted'
monsublogs/subscriberID_imsi-123456789012345_AT_2019-10-22T09:20:11.122225534.txt.sorted
Monitoring Subscriber Dump
To view the sorted file on the SMF Ops Center screen, use the following CLI command:
monitor subscriber dump filename filename
For example:
monitor subscriber dump filename monsublogs/subscriberID_imsi-123456789012345_AT_2019-10-22T09:20:11.122225534.txt.sorted
Monitoring the Interface Protocol
To monitor the interface protocol on the SMF, use the following CLI command:
monitor protocol { interface interface_name [ capture-duration duration  | gr-instancegr_instance | pcacp yes | | ] | list [ | ] }
NOTES:
  • interface interface_name —Specify the interface name on which PCAP is captured. This CLI allows the configuration of multiple interface names in a single CLI command.
  • capture-duration duration —Specify the duration in seconds during which pcap is captured. The default is 300 seconds (5 minutes).
  • The configured interface names can be retrieved using the show endpoint CLI command.
  • gr-instance gr_instance_id —Specify the GR instance ID. The instance ID 1 denotes the local instance ID.
  • pcap yes —Configure this option to enable PCAP file generation. By default, this option is disabled.
  • list —Monitor protocol list files.
Important
The monitor protocol command in Exec mode is restricted based on pod's CPU utilization configured through monitor protocol cpu-limit threshold_percentage command in the Global Configuration mode.
The monitor protocol CLI can be run simultaneously on multiple terminals. Also, the interface interface_name CLI allows the configuration of multiple endpoint names in a single CLI command.
For example:
monitor protocol interface sbi,N4:209.165.200.241:8805,gtpc capture-duration 1000
Feature Description
SMF sends the tracing trigger to the selected UPF automatically. Sending the trigger from SMF facilitates in parsing minimum files for troubleshooting across Control Plane and User Plane.
Note
  • The operator can configure a maximum of five subscribers at a time on SMF for monitoring.
  • When the data tracing is enabled, the available VPP, FCAP, and MEH are captured on the UPF PCAP.
  • When the protocol tracing is enabled, the following options are enabled on UPF:
    • Rulematch Events
    • L3 Data
    • PFCP Events Tracing
    • EDR
    • SessMGR
    • Subscriber Summary After Call Disconnect
  • After SMF GR switchover, the existing sessions of the monitored subscribers aren't impacted on UPF. As monitor nf CLI exists in the config mode, an operator needs to configure the CLI on both the SMF instances.
For UPF reload and switchover scenarios, see the UPF troubleshooting guide for monitor NF.
This section provides information on CLI commands for configuring the UPF monitor subscriber from SMF.
Configuring UPF Monitor Subscriber from SMF
Use the following configuration to enable or disable the UPF Monitor Subscriber protocol from SMF.
Use the following configuration to enable UPF Monitor Subscriber from SMF.
config
    monitor nf subscriber  [ gpsi gpsi_value |imei imei_id|imsiimsi_value control { true | false }  data { true | false } target-nf { sgwu | upf } ]
    end
NOTES:
  • monitor nf —Specify the NF that you want to monitor.
  • gpsi gpsi_value —Specify the subscriber GPSI.
  • imsi imsi_value —Specify the subscriber IMSI. For example: 123456789, *
  • imei imei_id —Specify the subscriber IMEI. For example: 123456789012345, *
  • control { true | false } —Specify whether to enable or disable the control event tracing.
  • data { true | false } —Specify whether to enable or disable the data event tracing.
  • target-nf { sgwu | upf } —Specify the target NF as SGW-U or UPF. target-nf is an optional parameter and if an operator doesn't configure this parameter, monitor subscriber is enabled on both the UPF and SGW-U.
Configuration Example
The following is an example configuration.
[smf] smf(config)# monitor nf subscriber
   imsi 234150999999999
      control true
      data true
      target-nf upf
exit
Disabling UPF Monitor Subscriber from SMF
Use the following configuration to disable UPF Monitor Subscriber from SMF.
config
    [ no ]monitor nf subscriber  [ gpsi gpsi_value |imei imei_id | imsiimsi_value ]
    end
NOTES:
Alerts
Feature Description
When the system detects an anomaly, CEE Ops Center generates an alert notification. The system statistics are the cause for these alert notifications. You can set an expression to trigger an alert when the expression becomes true.
How it Works
The Common Execution Environment (CEE) uses the Prometheus Alert Manager for alerting operations. The CEE YANG model - either through CLI or API - allows users to view the active alerts, silenced alerts, and alert history. Also, the applications can call the alert API directly to add or clear alerts. The Prometheus Alert Manager API (v2) is the standard API used.
The Prometheus Alerts Manager includes the following options:
  • Defining Alert Rules: This option defines the types of alerts that the Alert Manager should trigger. Use the Prometheus Query Language (PromQL) to define the alerts.
  • Defining Alert Routing: This option defines the action the Alert Manager should take after receiving the alerts. At present, the SNMP Trapper is supported as the outbound alerting. Also, the CEE provides an Alert Logger for storing the generated alerts.
Configuring Alert Rules
Use the following sample configuration to configure the alert rules:
config
   alerts rules group alert_group_name
   interval-seconds seconds
   rule rule_name
      expression promql_expression
      duration duration
      severity severity_level
      type alert-type
      annotation annotation_name
      value annotation_value
      exit
   exit
NOTES:
  • alerts rules : Specifies the Prometheus alerting rules.
  • group alert_group_name : Specifies the Prometheus alerting rule group. One alert group can have multiple lists of rules. alert-group-name is the name of the alert group. The alert-group-name must be a string in the range of 0–64 characters.
  • interval-seconds seconds : Specifies the evaluation interval of the rule group in seconds.
  • rule rule_name : Specifies the alerting rule definition. rule_name is the name of the rule.
  • expression promql_expression : Specifies the PromQL alerting rule expression. promql_expression is the alert rule query expressed in PromQL syntax.
  • duration duration : Specifies the duration of a true condition before it is considered true. duration is the time interval before the alert is triggered.
  • severity severity_level : Specifies the severity of the alert. severity-level is the severity level of the alert. The severity levels are critical, major, minor, and warning.
  • type alert_type : Specifies the type of the alert. alert_type is the user-defined alert type. For example, Communications Alarm, Environmental Alarm, Equipment Alarm, Indeterminate Integrity Violation Alarm, Operational Violation Alarm, Physical Violation Alarm, Processing Error Alarm, Quality of Service Alarm, Security Service Alarm, Mechanism Violation Alarm, or Time Domain Violation Alarm.
  • annotation annotation_name : Specifies the annotation to attach to the alerts. annotation_name is the name of the annotation.
  • value annotation_value : Specifies the annotation value. annotation_value is the value of the annotation.
The following example configures an alert, which is triggered when the percentage of Unified Data Management (UDM) responses is less than the specified threshold limit.
Example:
	config terminal
		alerts rules group SMFUDMchk_incr
		interval-seconds 300
		rule SMFUDMchk_incr
		expression "sum(increase(smf_restep_http_msg_total{nf_type=\"udm\", message_direction=\"outbound\", response_status=~\"2..\"}[3m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"udm\", message_direction=\"outbound\"}[3m])) < 0.95"
		severity major
		type "Communications Alarm"
		annotation summary
		value "This alert is fired when the percentage of UDM responses is less than threshold“
		exit
	exit
exit
You can view the configured alert using the show running-config alerts command.
Example:
The following example displays the alerts configured in the running configuration:
		rule SMFUDMchk_incr
		severity major
		annotation summary
		exit
	exit
exit
Viewing Alert Logger
The Alert Logger stores all the generated alerts by default. You can view the stored alerts using the following command.
show alert history [ filtering ]
You can narrow down the result using the following filtering options:
  • annotations: Specifies the annotations of the alert.
  • endsAt: Specifies the end time of the alert.
  • labels: Specifies the additional labels of the alert.
  • severity: Specifies the severity of the alert.
  • source: Specifies the source of the alert.
  • startsAt: Specifies the start time of the alert.
  • type: Specifies the type of the alert.
The following example history of the alerts configured in the system appears:
Example:
show alerts history
alerts active SMFUDMchk_incr ac2a970ab621
state active
severity major
startsAt 2019-11-15T08:26:48.283Z
source System
annotations [ "summary:This alert is fired when the percentage of UDM responses is less than threshold.” ]
You can view the active and silenced alerts with the show alerts active command.
The following active alerts example appears. The alerts remain active as long as the evaluated expression is true.
Example:
show alerts active
state active
severity major
source System
Call Flow Procedure Alerts
This section provides detail of commands that are required to configure alerts related to various call flow procedures.
The alerts, which are specific to SMF, are configured on the Common Execution Environment (CEE). The expressions are developed and new counters are created. Based on the user requirements, the call flow procedure alerts are configured in CEE. These alerts are triggered when the conditions, as specified by users, are met.
4G PDN Modify
Use the following sample configuration to configure alerts related to the 4G PDN Modify procedure:
alerts rules group SMFPDN
   rule SMFPDNModify
   expression “sum(smf_service_stats{procedure_type=~\”pdn_ho_location_changed| pdn_ho_rat_type_changed|pdn_inter_sgw_handover|pdn_mbr\” , status=\“success\”})/sum(smf_service_stats{procedure_type=~ \”pdn_ho_location_changed|pdn_ho_rat_type_changed |pdn_inter_sgw_handover|pdn_mbr\” , status=\“attempted\”}) < 0.95”
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 4G PDN Modify is below threshold”
   exit
exit
4G PDN Release Success
Use the following sample configuration to configure alerts related to the 4G PDN Release Success procedure:
   rule SMFPDNRelease
   expression “sum(smf_service_stats{procedure_type=~\“.*pdn_sess_rel\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“.*pdn_sess_rel\” , status=\“attempted\”} < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 4G PDN Release is below threshold.”
   exit
exit
4G PDN Setup Success
Use the following sample configuration to configure alerts related to the 4G PDN Setup Success procedure:
   rule SMFPDNSetup
   expression “sum(smf_service_stats{procedure_type=\”pdn_sess_create\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\”pdn_sess_create\” , status=\“attempted\”} < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 4G PDN Setup is below threshold.”
   exit
exit
4G to 5G HO Success
Use the following configuration to configure alerts related to the 4G to 5G HO Success procedure:
alerts rules group Handover
   rule 4gTo5gHOSuccess
   expression “sum(smf_service_stats{procedure_type=~\“n26_4g_to_5g_handover|n26_4g_to_5g_im_mobility\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“n26_4g_to_5g_handover|n26_4g_to_5g_im_mobility\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 4G to 5G HO is below threshold.”
   exit
exit
4G To WiFi HO Success
Use the following configuration to configure alerts related to the 4G to WiFi HO Success procedure:
   rule 4GtoWifiHOSuccess
   expression “sum(smf_service_stats{procedure_type=\”enb_to_untrusted_wifi_handover\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\“enb_to_untrusted_wifi_handover\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage of N4 responses sent is lesser than 95 %."
   exit
exit
5G N2 HO Success
Use the following configuration to configure alerts related to the 5G N2 HO Success procedure:
   rule N2HOSuccess
   expression “sum(smf_service_stats{procedure_type=\“n2_handover\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\“n2_handover\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G N2 HO is below threshold.”
   exit
exit
5G PDU Idle Success
Use the following configuration to configure alerts related to the 5G PDU Idle Success procedure:
alerts rules group SMFPDU
   rule SMFPDUIdleSuccess
   expression “sum(smf_service_stats{procedure_type=~\“.*idle\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“.*idle\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G PDU Idle is below threshold”
   exit
exit
5G PDU Modify Success
Use the following configuration to configure alerts related to the 5G PDU Modify Success procedure:
   rule SMFSessionModifySuccess
   expression “sum(smf_service_stats{procedure_type=~\“.*pdu_sess_mod\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“.*pdu_sess_mod\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G PDU Modify is below threshold”
   exit
exit
5G PDU Release Success
Use the following configuration to configure alerts related to the 5G PDU Release Success procedure.
   rule SMFSessionReleaseFailure
   expression “sum(smf_service_stats{procedure_type=~\“.*pdu_sess_rel\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“.*pdu_sess_rel\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G PDU Setup is below threshold”
   exit
exit
5G PDU Setup Success
Use the following configuration to configure alerts related to the 5G PDU Setup Success procedure:
   rule SMFSessionSetupFailure
   expression “sum(smf_service_stats{procedure_type=\”pdu_sess_create\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\”pdu_sess_create\” , status=\“attempted\”} < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when failed to setup sessions is more than 5%”
   exit
exit
5G to 4G HO Success
Use the following configuration to configure alerts related to the 5G to 4G HO Success procedure:
   rule 5gTo4gHOSuccess
   expression “sum(smf_service_stats{procedure_type=~\“pdn_5g_4g_handover |pdn_5g_4g_handover_dft|eps_fb_5g_4g_handover_dft|eps_fb_5g_4g_handover_idft |pdn_5g_4g_handover_idft\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=~\“pdn_5g_4g_handover  |pdn_5g_4g_handover_dft|eps_fb_5g_4g_handover_dft| eps_fb_5g_4g_handover_idft|pdn_5g_4g_handover_idft\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G to 4G HO is below threshold.”
   exit
exit
5G To WiFi HO Success
Use the following sample configuration to configure alerts related to the 5G to WiFi HO Success procedure:
   rule 5GtoWifiHOSuccess
   expression “sum(smf_service_stats{procedure_type=\”nr_to_untrusted_wifi_handover\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\“nr_to_untrusted_wifi_handover\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   exit
exit
5G Xn HO Success
Use the following sample configuration to configure alerts related to the 5G Xn HO Success procedure:
   rule XnHOSuccess
   expression “sum(smf_service_stats{procedure_type=\“xn_handover\” , status=\“success\”}) / sum(smf_service_stats{procedure_type=\“xn_handover\” , status=\“attempted\”}) < 0.95 “
   severity major
   annotation summary
   value "This alert is fired when the percentage successful 5G Xn HO is below threshold.”
   exit
exit
PDN Session Create
Use the following sample configuration to configure alerts related to the PDN Session Create procedure.
alerts rules group SMFProcStatus
   rule PDNSessCreate
   expression "sum(increase(smf_service_stats{app_name=\"SMF\",procedure_type=  /\"pdn_sess_create\",status=\"success\”}[5m])) / sum(increase(smf_service_stats{app_name=\"SMF\  /",procedure_type=\"pdn_sess_create\",status=\"  /attempted\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the success percentage of pdn_sess_create procedure is lesser threshold.”
   exit
exit
PDU Session Create
Use the following sample configuration to configure alerts related to the PDU Session Create procedure.
   rule PDUSessCreate
   expression "sum(increase(smf_service_stats{app_name=\"SMF\",procedure_type=  /\"pdu_sess_create\",status=\"success\”}[5m]))sum  /(increase(smf_service_stats{app_name=\"SMF\",  /procedure_type=\"pdu_sess_create\",status=\  /"attempted\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the success percentage of pdu_sess_create procedure is lesser threshold.”
   exit
exit
PDU Session Modify
Use the following sample configuration to configure alerts related to the PDU Session Modify procedure.
   rule PDUSessModify
   expression "sum(increase(smf_service_stats{app_name=\"SMF\",procedure_type=~\".  /*req_pdu_sess_mod\",status=\"success\”}[5m]))sum(increase  /(smf_service_stats{app_name=\"SMF\",procedure_type=~  /\”.*req_pdu_sess_mod\",status=\"attempted\”}[5m]))  / < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the success percentage of req_pdu_sess_mod procedure is lesser threshold.”
   exit
exit
PDU Session Release
Use the following sample configuration to configure alerts related to the PDU Session Release procedure:
   rule PDUSessRelease
   expression "sum(increase(smf_service_stats{app_name=\"SMF\",procedure_type=~\".*req_pdu_sess_rel\",status=\  /"success\”}[5m]))sum(increase(smf_service_stats{app_name=\"SMF  /\",procedure_type=~\”.*req_pdu_sess_rel\",status=\  /"attempted\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the success percentage of req_pdu_sess_rel procedure is lesser threshold.”
   exit
exit
Interface Specific Alerts
This section provides detail of commands that are required to configure alerts related to various interfaces.
GTPC Peer Down
Use the following commands to configure alerts related to the GTPC Peer Down procedure.
alerts rules group GTPCPeerDown
   rule GTPCPeerDown
   expression nodemgr_gtpc_peer_status{gtpc_peer_status=\“gtpc_peer_path_down\”})
   severity major
   annotation summary
   value “This alert is fired when the GTPC Path failure detected for peer crosses threshold”
   exit
exit
N4 Message Success
Use the following commands to configure alerts related to the N4 Message Success procedure.
alerts rules group SMFSvcStatus
   rule SMFN4MessageSuccess
   expression "sum(protocol_udp_res_msg_total{message_direction=\"inbound\", status=\”accepted\”}) / sum(protocol_udp_res_msg_total{message_direction=\"inbound\”, status=~\”accepted|denied\”}) < 0.95"
   severity major
   annotation summary
   exit
exit
N4 UPF Association Down
Use the following commands to configure alerts related to the N4 UPF Association Down query by N4 address.
alerts rules group N4Association
   rule SMFAssociationRelease
   expression ”proto_udp_res_msg_total{procedure_type=\“n4_association_release_res\”, message_direction= \“inbound\”, status=\“accepted\”}) ”
   severity major
   annotation summary
   value “This alert is fired when the N4 Association with UPF is released”
   exit
exit
N4 UPF Association Up
Use the following commands to configure alerts related to the N4 UPF Association Up query by N4 address.
   rule N4AssociationUP
   expression ”proto_udp_res_msg_total{procedure_type=\“n4_association_setup_res\”, message_direction= \“inbound\”, status=\“accepted\”}”
   severity major
   annotation summary
   value “This alert is fired when the N4 Association with UPF is established”
   exit
exit
N7 Interface Outbound
Use the following commands to configure alerts related to an outbound N7 interface.
   rule SMFN7Outbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"pcf\", message_direction=\"outbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"pcf\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N7 responses received is lesser threshold.”
   exit
exit
N7 Interface Inbound
Use the following commands to configure alerts related to an inbound N7 interface.
   rule SMFN7Inbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"pcf\", message_direction=\"inbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"pcf\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N7 responses sent is lesser threshold.”
   exit
exit
N7 Message Timed Out
Use the following commands to configure alerts related to the N7 Message Timed Out procedure.
alerts rules group MessageTimeout
   rule SMFN7Timeout
   expression ”sum(irate(smf_restep_http_msg_total{nf_type=\“pcf\”, message_direction=\”inbound\”, response_status=\”504\”}[5m])) > 5”
   severity major
   annotation summary
   value “This alert is fired when the increase in timeout for N7 messages toward PCF crosses threshold”
   exit
exit
N10 Interface
Use the following commands to configure alerts related to the N10 interface.
   rule SMFN10
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"udm\", message_direction=\"outbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"udm\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N10 responses received is lesser threshold.”
   exit
exit
N11 Interface Inbound
Use the following commands to configure alerts related to an inbound N11 interface.
   rule SMFN11Inbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"amf\", message_direction=\"inbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"amf\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N11 responses sent is lesser threshold.”
   exit
exit
N11 Interface Outbound
Use the following commands to configure alerts related to an outbound N11 interface.
   interval-seconds 60
   rule SMFN11Outbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"amf\", message_direction=\"outbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"amf\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N11 responses received is lesser threshold.”
   exit
exit
N11 Message Timed Out
Use the following commands to configure alerts related to the N11 Message Timed Out procedure.
   rule SMFN40Timeout
   expression ”sum(irate(smf_restep_http_msg_total{nf_type=\“chf\”, message_direction=\”inbound\”, response_status=\”504\”}[5m])) > 5”
   severity major
   annotation summary
   value “This alert is fired when the increase in timeout for N11 messages toward AMF crosses threshold”
   exit
exit
N40 Interface Inbound
Use the following commands to configure alerts related to an inbound N40 interface.
   rule SMFN40Inbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"chf\", message_direction=\"inbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"chf\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N40 responses sent is lesser threshold.”
   exit
exit
N40 Interface Outbound
Use the following commands to configure alerts related to an outbound N40 interface.
   rule SMFN40Outbound
   expression "sum(increase(smf_restep_http_msg_total{nf_type=\"chf\", message_direction=\"outbound\", response_status=~\”2..\”}[5m])) /  sum(increase(smf_restep_http_msg_total{nf_type=\"chf\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of N40 responses received is lesser threshold.”
   exit
exit
N40 Message Timed Out
Use the following commands to configure alerts related to the N40 Message Timed Out procedure.
   rule SMFN11Timeout
   severity major
   annotation summary
   value “This alert is fired the increase in timeout for N40 messages toward CHF crosses threshold”
   exit
exit
NRF Discovery
Use the following commands to configure alerts related to the NRF Discovery procedure.
alerts rules group NRF
   rule NRFDiscovery
   expression “sum(nf_discover_messages_total{result=~\”success|failure\”,svc_name=\”nnrf-disc\”, service_name=\”smf-rest-ep\”}) < 0.95”
   severity major
   annotation summary
   exit
exit
SMF Service Start
Use the following commands to configure alerts related to the SMF Service Start procedure.
alerts rules group SMFService
   rule SMFServiceStart
   expression “irate(outgoing_response_msg_total{msg_type=\”NrfNfmRegistration\”}[5m])”
   severity major
   annotation summary
   value "This alert is fired when SMF-Service starts upon registration with NRF”
   exit
exit
IP Pool
This section provides detail of commands that are required to configure alerts related to IP Pool.
IP Pool Used
Use the following commands to configure alerts related to the IP Pool used procedure.
alerts rules group IPPool
   rule IPPool
   expression “sum(IPAM_address_allocations_current) > THRESHOLD”
   severity major
   annotation summary
   value “This alert is fired when the percentage IP pool addresses used is above the threshold”
   exit
exit
Message Level Alerts
This section provides detail of commands that are required to configure alerts related to various messages.
N11 SM Create
Use the following commands to configure alerts related to N11 SM Create.
   rule SMFN11Success
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_create_sm_context\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_create_sm_context\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_create_sm_context responses sent is lesser threshold.”
   exit
exit
N11 SM Update
Use the following commands to configure alerts related to N11 SM Update.
   rule SMFN11Update
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_update_sm_context\", message_direction=\"inbound\", response_status=\"200\"}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_update_sm_context\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_update_sm_context responses sent is lesser threshold.”
   exit
exit
N11 SM Release
Use the following commands to configure alerts related to N11 SM Release.
   rule SMFN11Release
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_release_sm_context\", message_direction=\"inbound\", response_status=\"204\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_release_sm_context\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_release_sm_context responses sent is lesser threshold.”
   exit
exit
N1 N2 Message Transfer
Use the following commands to configure alerts related to N1 N2 Message Transfer.
   rule SMFN1N2Transfer
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_n1_n2_transfer\", message_direction=\"outbound\", response_status=\"200\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_n1_n2_transfer\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_n1_n2_transfer responses received is lesser threshold.”
   exit
exit
N11 EBI Assignment
Use the following commands to configure alerts related to N11 EBI Assignment.
   rule SMFN11EBI
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_assign_ebi\", message_direction=\"outbound\", response_status=\"200\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_assign_ebi\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_assign_ebi responses received is lesser threshold.”
   exit
exit
N11 SM Status Notify
Use the following commands to configure alerts related to N11 SM Status Notify.
   rule SMFN11StatusNotify
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_status_notify\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_status_notify\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_status_notify responses received is lesser threshold.”
   exit
exit
N11 SM Context Retrieve
Use the following commands to configure alerts related to N11 SM Context Retrieve.
   rule SMFN11ContextRetrieve
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"amf_retrieve_sm_context\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"amf_retrieve_sm_context\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of amf_retrieve_sm_context responses sent is lesser threshold.”
   exit
exit
N7 SM Policy Create
Use the following commands to configure alerts related to N7 SM Policy Create.
   rule SMFN7PolicyCreate
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_create\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_create\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_create responses received is lesser threshold.”
   exit
exit
N7 SM Policy Update
Use the following commands to configure alerts related to N7 SM Policy Update.
   rule SMFN7PolicyUpdate
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_update\", message_direction=\"outbound\", response_status=\"200\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_update\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_update responses received is lesser threshold.”
   exit
exit
N7 SM Policy Delete
Use the following commands to configure alerts related to N7 SM Policy Delete.
   rule SMFN7PolicyDelete
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_delete\", message_direction=\"outbound\", response_status=\"204\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_delete\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_delete responses received is lesser threshold.”
   exit
exit
N7 SM Policy Notify Update
Use the following commands to configure alerts related to N7 SM Policy Notify Update.
   rule SMFN7PolicyUpdateNotify
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_update_notify\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_update_notify\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_update_notify responses sent is lesser threshold.”
   exit
exit
N7 SM Policy Notify Terminate
Use the following commands to configure alerts related to N7 SM Policy Terminate.
   rule SMFN7PolicyTerminateNotify
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_terminate_notify\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"pcf_sm_policy_control_terminate_notify\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of pcf_sm_policy_control_terminate_notify responses sent is lesser threshold.”
   exit
exit
N10 UE Register
Use the following commands to configure alerts related to N10 UE Register.
   rule SMFN10UERegister
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"register_ue\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"register_ue\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of register_ue responses received is lesser threshold.”
   exit
exit
N10 UE DeRegister
Use the following commands to configure alerts related to N10 UE DeRegister.
   rule SMFN10UEDeRegister
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"deregister_ue\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"deregister_ue\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of deregister_ue responses received is lesser threshold.”
   exit
exit
N10 SM Subscription Fetch
Use the following commands to configure alerts related to N10 Subscription Fetch.
   rule SMFN10SubscriptionFetch
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"subscription_req\", message_direction=\"outbound\", response_status=\"200\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"subscription_req\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of subscription_req responses received is lesser threshold.”
   exit
exit
N10 SM Subscribe for Notification
Use the following commands to configure alerts related to N10 Subscribe for Notification.
   rule SMFN10SubscriptionNotification
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"sdm_subscription_req\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"sdm_subscription_req\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of sdm_subscription_req responses received is lesser threshold.”
   exit
exit
N10 Charging Data Request
Use the following commands to configure alerts related to N10 Charging Data Request.
   rule SMFN10ChargingRequest
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"chf_charging_data_request\", message_direction=\"outbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"chf_charging_data_request\", message_direction=\"outbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of chf_charging_data_request responses received is lesser threshold.”
   exit
exit
N10 Charging Data Notify
Use the following commands to configure alerts related to N10 Charging Data Notify.
   rule SMFN10ChargingDataNotify
   expression "sum(increase(smf_restep_http_msg_total{api_name=\"chf_abort_notify\", message_direction=\"inbound\", response_status=\"201\”}[5m])) /  sum(increase(smf_restep_http_msg_total{api_name=\"chf_abort_notify\", message_direction=\"inbound\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of chf_abort_notify responses sent is lesser threshold.”
   exit
exit
Policy Rule Alerts
This section provides detail of commands that are required to configure alerts related to various policy rules.
Addition of Dynamic PCC Rules
Use the following commands to configure alerts related to addition of dynamic PCC rules.
alerts rules group SMFPolicyStatus
   rule AddPCCRule
   expression "sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"success\",operation=\"install\”}[5m]))  / sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"attempted\",operation=\"install\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of successful addition of dynamic pcc rules is lesser threshold.”
   exit
exit
Modification of Dynamic PCC Rules
Use the following commands to configure alerts related to modification of dynamic PCC rules.
   rule ModifyPCCRule
   expression "sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"success\",operation=\"modify\”}[5m]))  / sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"attempted\",operation=\"modify\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of successful modification of dynamic pcc rules is lesser threshold.”
   exit
exit
Removal of Dynamic PCC Rules
Use the following commands to configure alerts related to removal of dynamic PCC rules.
   rule RemovePCCRule
   expression "sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"success\",operation=\"remove\”}[5m]))  / sum(increase(policy_dynamic_pcc_rules_total{app_name=\"SMF\",event=\"attempted\",operation=\"remove\”}[5m])) < 0.95"
   severity major
   annotation summary
   value "This alert is fired when the percentage of successful removal of dynamic pcc rules is lesser threshold.”
   exit
exit
SMF Overload/Congestion
This section provides detail of commands that are required to configure alerts related to various SMF Overload/Congestion.
SMF Overload
Use the following commands to configure alerts related to the SMF Overload procedure.
   rule SMFOverload
   expression “sum by (component) (system_overload_status) == true”
   severity major
   annotation summary
   value "This alert is fired when increase in events not processed due to system overload”
   exit
exit
SMF Sessions
This section provides detail of commands that are required to configure alerts related to various SMF sessions.
Session Release Rate
Use the following commands to configure alerts related to the Session Release Rate procedure.
alerts rules group SMFSession
   rule SMFSessionReleaseRate
   expression “sum(rate(smf_service_stats{procedure_type=~\“.*pdu_sess_rel|.*pdn_sess_rel\” , status=\“attempted\”}[5m])) >  THRESHOLD ”
   severity major
   annotation summary
   value “This alert is fired when the session release rate exceeds the threshold”
   exit
exit
Session Setup Failure
Use the following commands to configure alerts related to the Session Setup Failure procedure.
   expression “sum(smf_service_stats{procedure_type=~\”pdu_sess_create|pdn_sess_create\” , status=\“failures\”}) / sum(smf_service_stats{procedure_type=\”pdu_sess_create|pdn_sess_create\” , status=\“attempted\”}) >  0.05 “
   severity major
   annotation summary
   exit
exit
Session Setup Rate
Use the following commands to configure alerts related to the Session Setup Rate procedure.
   rule SMFSessionSetupRate
   expression “sum(rate(smf_service_stats{procedure_type=~\”pdu_sess_create|pdn_sess_create\” , status=\“attempted\”}[5m]))>  THRESHOLD ”
   severity major
   annotation summary
   value “This alert is fired when the session setup rate exceeds the threshold”
   exit
exit
Subscriber Limit
Use the following commands to configure alerts related to the Subscriber Limit procedure.
   rule SMFSubscriberLimit
   expression “sum(smf_session_counters{pdu_type=~\”ipv4v6|ipv4|ipv6\”}) > THRESHOLD”
   severity major
   annotation summary
   value "This alert is fired when the max number of subscribers is more
   than the threshold”
   exit
exit
Metrics
Feature Description
You can a monitor wide range of application and system statistics, and key performance indicators (KPI) within the SMF infrastructure. KPIs are useful to gain insight into the overall health of the SMF environment. Statistics offer a simplified representation of the SMF configurations and utilization-specific data.
The SMF integrates with Prometheus, a third-party monitoring and alerting solution to capture and preserve the performance data. This data is reported as statistics and can be viewed in the web-based dashboard. Grafana provides a graphical or text-based representation of statistics and counters, which the Prometheus database collects. The Grafana dashboard projects a comprehensive set of quantitative and qualitative data that encourages you to analyze SMF metrics in the reporting tool of your choice and take informed decisions.
By default, the monitoring solution is enabled, which indicates that Prometheus continually monitors your SMF environment and the Prometheus data source is associated with Grafana. You must have the administrative privileges to access Grafana. However, to view a specific dashboard, run the Prometheus queries. The queries are available in the built-in and custom format.
The following snapshot is a sample of the Grafana dashboard.
Figure 1. Grafana Dashboard
How it Works
KPIs constitute of metrics, such as statistics and counters. These metrics represent the performance improvement or degradation. By default, Prometheus is enabled on the system where SMF is deployed, and configured with Grafana. Prometheus dynamically starts monitoring the data sources that are available on the system. For new dashboard panels, execute queries in Prometheus.
For more information about Prometheus, consult the Prometheus documentation at https://prometheus.io/docs/introduction/overview/.
Configuring Metrics Collection
The labels of each SMF metrics are classified into the following three categories:
  • Production
  • Debug
  • Granular
All the SMF application metrics are controlled through the CLI command for performance optimization.
To collect the necessary SMF metrics and labels, use the following sample configuration:
config
   infra metrics verbose { service | protocol | load-balancer | application } [ level { debug | off | production | trace } | metrics metrics_name [ granular-labels label_name| level { debug | off | production | trace } | pod pod_name | level { debug | off | production | trace }  ] ]
   end
NOTES:
  • If the metrics verbosity is not configured, then the default verbosity level for pod type is as follows.
    • LoadBalancer = Production
    • Protocol = Trace
    • Service = Trace
    • Application = Debug
  • The order of the level for verbose metrics is in the following priority order:
    • metrics [ [metrics_name] level [production|debug|trace|off]: [Priority 1]
    • pod [[pod_Name]] level [ production | debug | trace | off]] [Priority 2]
    • level [production | debug | trace | off] [Priority 3]
  • infra metrics verbose { service | protocol | load-balancer | application } : Enable the metric collection. This configuration helps to collect the required application metrics and labels. By default, this command captures the debug labels of metrics.
  • level { debug | off | production | trace } : Specify the application metrics category to capture the required application metrics and labels.
    • debug : Capture all the labels that are classified as production and debug categories. This option is the default configuration.
    • off : Disable the application level metrics collection.
      For example, configuring the infra metrics verbose application smf_service_stats level off command disables the smf_service_stats application metrics.
    • production : Capture the labels that are classified as production category.
    • trace : This option is not supported for SMF application metrics. If this option is configured, the SMF treats this option as debug .
  • If production and debug classification is empty for a metrics, then all the labels except granular-labels (if configured) are classified as debug.
  • metrics metrics_name : Specify the metrics name to capture only the labels that correspond to the given metrics. The metric-level configuration takes precedence over the application-level configuration. If the metrics level is not configured, the labels are captured at the application level.
  • granular-labels : Capture only the granular labels. By default, this option is disabled.
    If a granular label is required for KPI, then that label must be configured. For example, to capture dnn labels of smf_service_stats metrics, you must configure the following CLI command:
    infra metrics verbose application metrics smf_service_stats level debug granular-labels [ dnn ]
The following is an example configuration to enable only production level for all the application metrics.
infra metrics verbose application level production
The following is an example configuration to enable production level for smf_service_stats application metrics and debug level for all other application metrics.
infra metrics verbose application smf_service_stats level production
The following is an example configuration to enable debug level for smf_service_stats application metrics along with granular labels and production level for all other application metrics.
infra metrics verbose application level production smf_service_stats level debug granular-labels [ dnn ]
The following is an example configuration to enable production level for smf_service_stats application metrics along with granular labels and debug level for all other application metrics.
infra metrics verbose application smf_service_stats level production granular-labels [ dnn ]
The following is an example configuration to disable smf_service_stats application metrics and debug level for all other application metrics.
The following is an example configuration to configure NSSAI labels of smf_service_stats metrics.
infra metrics verbose application metrics smf_service_stats level debug granular-labels [ snssai ]
Note
The NSSAI statistics are not pegged without configuring the NSSAI label in the granular-labels configuration.
Configuration Verification
To verify the configuration, use the following show command:
show running-config infra metrics verbose application
The following are example outputs of the show running-config infra metrics verbose application command.
[smf] smf# show running-config infra metrics verbose application
  level production
 exit
exit
The preceding output indicates that the configuration to capture production labels for smf_service_stats application metrics along with granular labels and debug levels of all other application metrics is enabled.
  level production
   level debug
   granular-labels [ [dnn] ]
  exit
exit
The preceding output indicates that the configuration to capture debug labels for smf_service_stats application metrics along with granular labels and production level of all other application metrics is enabled.
To verify the slice information on procedure and session statistics, use the following show command:
  level debug
 exit
Bulk Statistics and Key Performance Indicators
Feature Description
This section provides details of bulk statistics, and Key Performance Indicators (KPIs) used for performance analysis on SMF.
There are two types of bulk statistics:
  • Gauge - A snapshot value that shows the statistic at that reporting moment (for example, the number of current PDP contexts, simultaneous Active EPS Bearers). Gauge statistics can increment or decrement continuously.
  • Counter - A historic value that shows the statistic that accumulated over time (for example, the total number of CSR requests received). Counter values can only increment except in two cases:
    • Rollover - where a counter exceeds its maximum value and rolls over to zero.
    • Reset - where a counter is manually reset to zero.
Important
For the complete list of supported bulk statistics and KPIs, see the UCC 5G SMF Metrics Reference applicable for this release.
Logs
Feature Description
The system logging feature provides a common way to log the log messages across applications. Each log consists of the following components:
  • Timestamp—Shows the date and time of the log creation.
  • Log message—Shows the message of a specific log.
  • Log level—Shows the level of importance of log message.
  • Log tag—Shows the details of module name, component name, and interface name. A log tag is pre-created and passes during logging.
SMF provides various types of logging to log the messages. These logging types are application logging, transaction logging, monitor subscriber logging, and trace logging.
The SMF maintains various logs, such as trace logs and event logs. Use the kubectl get pods -n namespace CLI command to check all the pods and the services that are currently running. Then, use the kubectl logs podname -n namespace CLI command to display the log in a pod.
If you encounter any error during the operation of this feature, use the SMF service logs for a particular subscriber session to identify the issues and determine the solution to your problem.
Download OAM and EDR Monitor Pod Files
Feature Description
Files that are generated using the monitor subscriber command, monitor protocol command, and transaction logs are stored in the OAM pod. The files that are generated in OAM pod are collected and stored in an internal Apache server. You can view and download the files by using a web browser, after user authentication.
Note
Use the same credentials as ops-center to authenticate user access to the files present in the oam-pod and edr-monitor pod using a browser.
The files are created in separate folders, as and when their respective commands are executed. You can download the following OAM and EDR pod files:
  • Monitor subscriber files: These files are generated using the monitor subscriber CLI option to trace messages that are related to a specified subscriber. The files that are generated for the monitor protocol command are present in the monsublogs/ directory.
  • Monitor protocol files: These files are using the monitor protocol CLI option to capture packets on a specific interface provided under the CLI command. The files that are generated for the monitor protocol command are present in monprologs/ directory.
  • Transaction logs: When transaction logging is enabled, the transaction logs are sent to oam-pod and can be downloaded from there. The files generated for transaction logging when enabled and are present in the transactionlogs/ directory.
  • EDR files: These files are generated in smf service pod and periodically copied to edr-monitor pod. The files are available in /edr directory.
How it Works
This section describes how to view and download the log files in the oam-pod and edr-monitor pod.
Downloading OAM Pod Files
Open a browser and log on to the Apache server using the https://oam-files.<ReleaseName>.<Ingress-host-name>.nip.io/ URL. Use the ops-center user credentials. Replace <ReleaseName> and <Ingress-host-name> with the release name and ingress host name respectively.
The oam-pod directory comprises folders to archive the monitor protocol logs, monitor subscriber logs, and transaction logs.
The directory folders are visible as per the commands executed.
To download the monitor protocol files, use the following URL:
https://oam-files.<ReleaseName>.<Ingress-host-name>.nip.io/ monprologs/
In the preceding URL, replace monprologs with monsublogs for monitor subscriber files and with transactionlogs for the transaction log files.
Downloading EDR Files
To access the EDR files in the persistent volume of EDR monitor pod, log on to the Ops center with required credentials, and use the edr-monitor pod ingress URL.
To determine the ingress URL, use the following command:
kubectl get ingress -n namespace | grep edr
Example:
cloud-user@svi-cndp-tb41-gr-setup-smf-cluster-2-cndp-server-1:~$ kubectl get ingress -n smf-smf | grep edr
Configuring the Logs
This section describes how to configure the logs.
Enabling or Disabling the Transaction Messages
To enable or disable the presence of request response messages in the transaction logs, use the following sample configuration:
config
  logging transaction message { disable | enable }
  commit
end
NOTES:
  • logging transaction message { disable | enable } : Specify whether to enable or disable messages in transaction logging.
Viewing Transaction History Logs
To view the transaction history on an OAM pod shell, use the following CLI command in the SMF Ops Center:
Note
To display the logs in a pod, use the following command on the Kubernetes master node:
kubectl logs -n <SMF namespace> podname
Sample Transaction Log
The following is an example of transaction log collected in Monitor Subscriber during SMF PDU session establishment.
Transaction Log received from Instance: smf.smf-rest-ep.unknown.smf.0
************* TRANSACTION: 00010 *************
TRANSACTION SUCCESS:
    Txn Type             : N10RegistrationRequest(33)
    Priority             : 1
    Session State        : No_Session
LOG MESSAGES:
    2020/03/03 05:31:39.345 [DEBUG] [infra.transaction.core] Processing transaction Id: 10 Type: 33 SubscriberID: imsi-123456789012345 Keys: []
    2020/03/03 05:31:39.345 [DEBUG] [infra.transaction.core] Trace is disabled
    2020/03/03 05:31:39.346 [TRACE] [infra.message_log.core] >>>>>>>
IPC message
MessageType: N10RegistrationRequest
Key:
--body--
{"regInfo":{"ueId":"imsi-123456789012345","pduSessionId":5},"regReq":{"dnn":"intershat",
  "pduSessionId":5,"pgwFqdn":"cisco.com.apn.epc.mnc456.mcc123","plmnId":{"mcc":"123","mnc":"456"},
  "smfInstanceId":"c388eec5-e2ff-4bda-8154-b5dd9f10ad97","supportedFeatures":"0","singleNssai":{"sd":"Abf123","sst":2}},
  "msgReq":{"Type":2,"ServiceName":4,"Versions":["v1"],"ProfileName":"UP1","FailureProfile":"FH1","SvcMsgType":3,
  "Filter":{"Bitmapfeilds":2,"Dnn":"intershat"}}}
    2020/03/03 05:31:39.346 [DEBUG] [nrfClient.Discovery.nrf] Message send Metadata [Type:UDM ServiceName:nudm-uecm
Request
Host: http://209.165.200.229:9020/nudm-uecm/v1/imsi-123456789012345/registrations/smf-registrations/5
Method: PUT
RequestURI:
--- Headers ---
Content-Type: application/json
Body:{"dnn":"intershat","pduSessionId":5,"pgwFqdn":"cisco.com.apn.epc.mnc456.mcc123",
"singleNssai":{"sd":"Abf123","sst":2},"smfInstanceId":"c388eec5-e2ff-4bda-8154-b5dd9f10ad97","supportedFeatures":"0"}
    2020/03/03 05:31:39.376 [TRACE] [infra.message_log.core] >>>>>>>
Response
Name:
Response Status 201
--- Headers ---
Location: http://209.165.200.229:9020/nudm-uecm/v1/imsi-123456789012345/registrations/smf-registrations/5
Content-Length: 225
Body:{"pgwFqdn": "cisco.com.apn.epc.mnc456.mcc123", "plmnId": {"mcc": "123", "mnc": "456"}, "dnn": "intershat",
  "smfInstanceId": "524f5f8a-b584-47b8-86f5-a5292eabcdef", "pduSessionId": 5, "singleNssai": {"sd": "Abf123", "sst": 2}}
--body--
{"regRes":{"dnn":"intershat","pduSessionId":5,"pgwFqdn":"cisco.com.apn.epc.mnc456.mcc123",
************* TRANSACTION: 00011 *************
    Txn Type             : N10SubscriptionFetchReq(36)
    Priority             : 1
LOG MESSAGES:
    2020/03/03 05:31:39.384 [DEBUG] [infra.transaction.core] Processing transaction Id: 11 Type: 36 SubscriberID: imsi-123456789012345 Keys: []
    2020/03/03 05:31:39.384 [DEBUG] [infra.transaction.core] Trace is disabled
    2020/03/03 05:31:39.384 [TRACE] [infra.message_log.core] >>>>>>>
IPC message
MessageType: N10SubscriptionFetchReq
Key:
--body--
Request
Host: http://209.165.200.229:9020/nudm-sdm/v1/imsi-123456789012345/sm-data?dnn=intershat&plmn-id=%7B%22mcc%22%3A%22123%22%2C%22mnc%22%3A%2
    2456%22%7D&single-nssai=%7B%22sd%22%3A%22Abf123%22%2C%22sst%22%3A2%7D&supported-features=0
Method: GET
RequestURI:
--- Headers ---
IPC message
MessageType: N10SubscriptionFetchSuccess
Key:
--body--
Configuring the Logging Levels
This section describes how to configure the logging level parameters.
Use the following sample configuration to configure the logging level:
config
  logging level { application | monitor-subscriber | tracing |transaction }
  end
NOTES:
  • logging level { application | monitor-subscriber | tracing | transaction } – Enter the transaction log configuration mode.
    • application – Configures the option application logging level.
    • monitor-subscriber – Configures the option monitor subscriber logging level.
    • tracing – Configures the option logging level tracing
    • transaction – Configures the option transaction logging level.
Configuring Persistent Transaction Logs
This section describes how to configure the persistent transaction log parameters.
The transaction logs are saved in the transaction log file that resides in the transaction logs directory of OAM pod.
Use the following sample configuration to configure the persistent transaction logs:
config
  logging transaction persist enable { max-file-size | max-rotation }
  end
NOTES:
  • logging transaction – Enter the transaction log configuration mode.
  • persist enable { max-file-size | max-rotation } – Configure the option to enable writing of transaction logs to the transaction log file.
    • max-file-size max_filesize – Specify the maximum size (in MB) of the transaction logs that must be preserved in the file. The default size is 50 MB. The accepted range is 1-10000 MB.
    • max-rotation max_rotation – Specify the maximum number of files that must be stored in the folder. After reaching the specified number, the file rotation begins. With this rotation, the oldest file is deleted and the latest log file is added to the folder. For example, if the folder has files a1.txt–a.10.txt and when the a.11.txt is added, then a1.txt is deleted. The default number is 10. The accepted range is 2 -1000.
  • persist enable – Disables writing of transaction logs to the transaction log file.
Viewing Persistent Transaction Logs
This section describes how to view the transaction logs that are stored on the OAM pod.
To view the persistent transaction logs, use the following configuration through the SMF Ops Center:
transaction file dump filename file_path
You can use the transaction log list command to view the list of log files and their paths.
The following is a sample output of the transaction logs:
RELEASE_NAMESPACE: 'example-data'
Dumping file 'transactionlogs/transaction.log.20200907033433.4.gz'
InstanceInfo: example.example-rest-ep.cluster1.example-data.1
TimeStamp: 2020-09-09 00:25:18.379439773 +0000 UTC
************* TRANSACTION: 01371 *************
    Txn Type             : MessageTypeExampleCreate(1)
    Priority             : 1
    Session Namespace    : none(0)
LOG MESSAGES:
    2020/09/09 00:25:18.339 [INFO] [rest_ep.app.n7] Message Example_Create decod
ed
    2020/09/09 00:25:18.339 [INFO] [rest_ep.app.n7] Process init
    2020/09/09 00:25:18.339 [DEBUG] [rest_ep.app.n7] Config from GetConfig is Ve
rsion: 783da2fc038c6bc961a95e2bf3dd6d93f282e36b30e0362698a1de369a2fd15c Services
: [Name: restServer Type: Rest Endpoint: sbi Name: tcpServer Type: Tcp Endpoint:
 tcp-protocol Name: udpServer Type: Udp Endpoint: udp-protocol]
    2020/09/09 00:25:18.339 [INFO] [rest_ep.app.n7] Process continue
    2020/09/09 00:25:18.339 [DEBUG] [rest_ep.app.n7] DerivedConfig from GetConfi
g is DerivedNameToBeTested_cb3383b95927a434d42cd9d5687ccf1b13e2de4b2faf4543287a3
4afb32518fe
    2020/09/09 00:25:18.339 [DEBUG] [rest_ep.udp.n5] Sending message Example_Cre
ate to example-service
    2020/09/09 00:25:18.342 [INFO] [infra.transaction.core] Calling RPC example-
service_ipc_stream on host example-service_1 proc-name example-service_ipc_strea
Dispatcher
Feature Description
Dispatcher is an ingress throttling configuration of rate of admission with number of queues and size of queue configuration at GTP and PFCP.
Configuration Limit for Dispatcher on S11 Interface
When impacted, an IMS bearer results in voice call failures due to S11 interface and GTPv2 message drops at the ingress protocol dispatcher.
The S11 protocol dispatcher configuration at cnSGW is static and requires tuning based on the production requirements. If the configuration isn’t appropriate for the MME pool that is being served, then in the case of high call events per seconds (CEPS), the GTPv2 message drops.
Any GTPv2 -S11 is discarded or dropped due to dispatcher queue limits at the ingress, which includes request or response messages, such as Release Access Bearer (RAB), Modify Bearer Request (MBR), and DDN Acknowledgment. For example, a drop in MBR from MME with an existing voice bearer results in a call drop. A drop of MBR from MME with a voice bearer transfer as part of EPS Fallback (EPSFB) results in an EPSFB call setup failure (Voice Access Failure Rate (AFR)).
Configuring Dispatcher for S11 Interface
To configure a dispatcher for S11 interface, use the following sample configuration:
config
      sla response response_time_value
      dispatcher
         count count_value
         capacity capacity_value
         outbound [ true | false ]
         cache [ true | false ]
         threshold threshold_value
         expiry expiry_time_value
         nonresponsive nonresponsive_time_value
     exit
NOTES:
  • interface interface_name : Specify the interface name as S11.
  • sla response response_time_value : Specify the SLA response time. response_time_value must be an integer.
  • count count_value : Specify the count of dispatcher queues.
  • capacity capacity_value : Specify the capacity of each dispatcher queue.
  • outbound [ true | false ] : Specify this value to enable or disable the queue support for the outbound messages.
  • cache [ true | false ] : Specify this value to enable or disable the retransmission of cache.
  • threshold threshold_value : Specify the threshold value for the outstanding requests per queue cache.
  • expiry expiry_time_value : Specify the responded cache entry expiry duration in milliseconds.
  • nonresponsive nonresponsive_time_value : Specify this value for the non-responsive cache entry expiry duration in milliseconds.
The following is an example configuration of dispatcher for S11 interface.
interface s11
   sla response 5500
   dispatcher
    count         10
    capacity      100000
    outbound      true
    threshold     160000
    expiry        7000
    nonresponsive 6000
   exit
OAM Support
This section details the metrics supported for the dispatcher.
Metrics
Following new metrics is introduced to capture the specific event when the dispatcher queue is configured:
Metric Name: outgoing_drop_queued_total
Description: The metric captures the specific event when the dispatcher queue configured at the UDP client is full and is loaded with too many messages beyond the configured queue capacity
Following labels are added in this metric:
  • local_address: Local UDP address where the UDP endpoint is started.
  • interface: Name of the UDP interface configured in the endpoint configuration.
  • protocol: Name of the protocol configured in the endpoint configuration. For example, UDP
  • queue_id: Queue index number based on the source IP address.
  • peer_address: IP address of the peer endpoint.
  • cause: The reason for the drop of message from the queue. For example, one of the reasons is dispatcher queue being full.
  • queue_type: Type of queue configured in the dispatcher configuration.
