Configuration Command Reference
aaa
Configures AAA based user management parameters.
Privilege Level
Security Administrator, Administrator
Command Mode
Exec
Syntax
aaa { authentication { users list_of_local_users admin change-password old-password user_password new-password user_password confirm-password user_password } }
Specify the user name.
Must be a string.
Specifies the current password of the user.
Must be a string.
Specifies a new password of the user.
Must be a string.
Enter the new password once again to change the password.
Must be a string.
Usage Guidelines
Use this command to configure the AAA based user management parameters.
active-charging service
Configures Active Charging Service (ACS) parameters.
Command Mode
Exec > Global Configuration (config)
Syntax
active-charging service service_name
Specify name of the Active Charging Service.
Must be a string of 1-15 characters.
Usage Guidelines
Use this command to configure the ACS parameters.
You can configure a maximum of one element with this command.
active-charging service bandwidth-policy
Configures ACS bandwidth policy parameters.
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name )
Syntax
bandwidth-policy bandwidth_policy_name
Specify name of the ACS Bandwidth Policy.
Must be a string of 1-63 characters.
Usage Guidelines
Use this command to configure ACS bandwidth policy parameters. The CLI prompt changes to the Bandwidth Policy Configuration mode (config-bandwidth-policy-<policy_name>).
You can configure a maximum of 64 elements with this command.
active-charging service bandwidth-policy flow limit-for-bandwidth id
Configures bandwidth ID and bandwidth policy group parameters.
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > Bandwidth Policy Configuration (config-bandwidth-policy-policy_name )
Syntax
flow limit-for-bandwidth id id group-id group_id
group-id group_id
Specify the bandwidth policy group ID.
Must be an integer in the range of 1-65535.
id id
Specify the bandwidth ID.
Usage Guidelines
Use this command to configure the bandwidth ID and bandwidth policy group parameters.
You can configure a maximum of 1000 elements with this command.
active-charging service bandwidth-policy group-id
Configures bandwidth policy group ID.
Command Mode
Syntax
group-id group_id
group-id group_id
Usage Guidelines
Use this command to configure the bandwidth policy group ID.
active-charging service bandwidth-policy group-id direction downlink grpPeakBwp
Configures peak bandwidth parameters.
Command Mode
Syntax
group-id group_id direction downlink peak-data-rate-kbps peak_data_rate peak-burst-size peak_burst_size violate-action lower-ip-precedence committed-data-rate-kbps
Syntax
group-id group_id direction uplink peak-data-rate-kbps peak_data_rate peak-burst-size peak_burst_size violate-action lower-ip-precedence committed-data-rate-kbps
committed-burst-size committed_burst_size
Specify the committed burst size in bytes.
Must be an integer in the range of 1-4294967295.
committed-options committed_option
Specify the committed option.
Must be one of the following:
  • committed-data-rate-kbps : Specify Committed Data Rate in kilo bits per second. This can also be used to specify GBR for Bearer Binding (without the exceed-action).
  • committed-data-rate : Specify Committed Data Rate in bits per second. This can also be used to specify GBR for flow Binding (without the exceed-action).
committed-value committed_value
Specify the bandwidth in bits per second.
exceed-action exceed_action
Specify the action to be taken if committed data rate is surpassed.
  • discard : Specify to discard the packet.
  • lower-ip-precedence : Specify to lower the IP precedence of the packet.
Specify the burst size in bytes.
peak-options peak_options
Specify the peak data rate option.
  • peak-data-rate-kbps : Specify Peak Data Rate in kilo bits per second.
  • peak-data-rate : Specify Peak Data Rate in bits per second.
peak-value peak_value
violate-action violate_action
Specify the action to be taken if Peak Data Rate is surpassed.
Usage Guidelines
Configures bandwidth control in downlink or uplink directions. Use this command to configure the peak bandwidth parameters.
active-charging service bandwidth-policy group-id direction uplink grpPeakBwp
Command Mode
Syntax
Syntax
Usage Guidelines
active-charging service buffering-limit
Configures flow/session-based packet buffering.
Command Mode
Syntax
buffering-limit { [ flow-max-packets flow_max_packets ] [ subscriber-max-packets subscriber_max_packets ] }
Specify the maximum number of packets to be buffered per flow.
Must be an integer in the range of 1-255.
Specify the maximum number of packets to be buffered per subscriber.
Usage Guidelines
Use this command to configure flow/session-based packet buffering configuration.
active-charging service charging-action
Configures ACS charging actions.
Command Mode
Syntax
charging-action charging_action_name [ [ content-id content_id ] [ nexthop-forwarding-address { ipv4_address | ipv6_address } [ qos-class-identifier qos_class_id ] [ service-identifier service_id ] [ ft-notify-ue ] ]
Specify name of the charging action.
Specify the content ID to use in the generated billing records, as well as the AVP used by the Credit Control Application, such as the "Rating-Group" AVP for use by the Diameter Credit Control Application (DCCA). This identifier assists the carrier's billing post processing and is also used by the credit-control system to use independent quotas for different value of content-id.
Must be an integer in the range of 1-2147483647.
Specify the nexthop forwarding address for this charging action. When an uplink packet matches a rule and a charging action is applied to it this nexthop forwarding address is used.
Must be a string in the ipv4-address pattern. For information on the ipv4-address pattern, see the Input Pattern Types chapter.
-Or-
Must be a string in the ipv6-address pattern. For information on the ipv6-address pattern, see the Input Pattern Types chapter.
Specify the QoS Class Identifier (QCI).
Must be an integer in the range of 1-9.
Specify the service identifier to use in the generated billing records, as well as the AVP used by the Credit Control Application, such as the "Service-Identifier" AVP for use by DCCA. This is a more general classifier than content-id.
tft-notify-ue
Specify whether or not TFT updates are sent to UE. Use this command to suppress the selected TFT updates from being sent to the UE. This helps to identify if the appropriate TFT defined in the charging action needs to be sent to the UE or not.
Usage Guidelines
Use this command to create and configure an ACS charging action. A charging action represents actions to be taken when a configured rule is matched. Actions could range from generating an accounting record (for example, an EDR) to dropping the IP packet, etc. The charging action will also determine the metering principle whether to count retransmitted packets and which protocol field to use for billing (L3/L4/L7 etc).
Example
The following command creates a charging action named action123 and changes to the ACS Charging Action Configuration Mode:
charging-action action123
active-charging service charging-action allocation-retention-priority
Configures the Allocation Retention Priority (ARP).
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > Charging Action Configuration (config-charging-action-charging_action_name )
Syntax
allocation-retention-priority priority_level { pci preemption_capability_indicator | pvi preemption_vulnerability_indicator }
Specify the priority.
Must be an integer in the range of 1-15.
Specify the Pre-emption Capability Indicator (PCI).
  • MAY_PREEMPT
  • NOT_PREEMPT
Specify the Pre-emption Vulnerability Indicator (PVI).
  • NOT_PREEMPTABLE
  • PREEMPTABLE
Usage Guidelines
This command configures the ARP, which indicates the priority of allocation and retention of the service data flow. The ARP resolves conflicts in demand for network resources. At the time of resource crunch, this parameter prioritizes allocation of resources during bearer establishment and modification. In a congestion situation, a lower ARP flow may be dropped to free up capacity. Once a service flow is successfully established, this parameter plays no role in quality of service (QoS) experienced by the flow.
Example
The following command sets the ARP to 10:
allocation-retention-priority 10
active-charging service charging-action billing-action
Configures the billing action for packets that match specific ruledefs.
Command Mode
Syntax
billing-action egcdr
egcdr
Specify to enable eG-CDR billing.
Usage Guidelines
Use this command to enable eG-CDR type of billing for content matching this charging action.
active-charging service charging-action cca charging credit
Configures the Credit Control Charging Credit behavior.
Command Mode
Syntax
cca charging credit [ rating-group coupon_id ] [ preemptively-request ]
Specify preemptively requested charging credit behavior.
Specify the coupon ID used in prepaid charging as rating-group which maps to the coupon ID for prepaid customer. This option also assigns different content-types for the same charging action depending upon whether or not prepaid is enabled. This rating-group overrides the content ID, if present in the same charging-action for the prepaid customer in Diameter Credit Control Application (DCCA). But, only the content IDs will be used in eG-CDRs irrespective of the presence of rating-group in that charging action.
Must be an integer in the range of 0-65535.
Usage Guidelines
Use this command to configure RADIUS/Diameter Prepaid Credit Control Charging Credit behavior.
active-charging service charging-action flow action
Configures to take the redirect-url or terminate-flow action on packets that match ruledefs.
Command Mode
Syntax
flow action { redirect-url redirect_url | terminate-flow }
Specify to redirect URL.
Must be a string.
terminate-flow
Specify to terminate flow.
Usage Guidelines
Use this command to specify the action to take on packets, for example to terminate.
Example
The following command sets the flow action to terminate:
flow action terminate-flow
active-charging service charging-action flow action discard
Configures discard action on packets that match ruledefs.
Command Mode
Syntax
flow action discard [ downlink | uplink ]
downlink
Specify only downlink packets.
uplink
Specify only uplink packets.
Usage Guidelines
Use this command to configure discard action on packets that match ruledefs.
active-charging service charging-action flow action readdress
Configures the readdress server for this charging action.
Command Mode
Syntax
flow action readdress server { ipv4_address | ipv6_address }
Specify IP address of the readdress server.
-Or-
Usage Guidelines
Use this command to configure the readdress server for this charging action.
active-charging service charging-action flow limit-for-bandwidth
For Session Control functionality, this command allows you to enable or disable bandwidth limiting.
Command Mode
Syntax
flow limit-for-bandwidth { direction | id bw_limit_id }
id bw_limit_id
Specify the bandwidth limiting ID.
Usage Guidelines
Use this command to limit the bandwidth a subscriber uses in the uplink and downlink directions under Session Control.
active-charging service charging-action flow limit-for-bandwidth direction downlink peak-data-rate
Configures the peak data rate in bits per second.
Command Mode
Syntax
flow limit-for-bandwidth direction downlink peak-data-rate peak_data_rate peak-burst-size peak_burst_size violate-action violate_action [ committed-data-rate committed_data_rate committed-burst-size committed_burst_size exceed-action exceed_action ]
Syntax
flow limit-for-bandwidth direction uplink peak-data-rate peak_data_rate peak-burst-size peak_burst_size violate-action violate_action [ committed-data-rate committed_data_rate committed-burst-size committed_burst_size exceed-action exceed_action ]
Default Value: 3000.
Specify the Committed Data Rate in bits per second. This can also be used to specify GBR for Bearer Binding (without the exceed-action).
Default Value: 144000.
Specify the action to be taken if the Committed Data Rate is surpassed.
Specify the peak burst size in bytes.
Specify the action to be taken if the Peak Data Rate is surpassed.
peak_data_rate
Specify the peak data rate in bits per second.
Usage Guidelines
Configures bandwidth control in downlink or uplink directions. Use this command to configure the peak data rate in bits per second.
active-charging service charging-action flow limit-for-bandwidth direction uplink peak-data-rate
Command Mode
Syntax
Syntax
peak_data_rate
Usage Guidelines
active-charging service charging-action tft packet-filter
Configures the packet filter to use in Traffic Flow Template (TFT) sent to the MS.
Command Mode
Syntax
tft packet-filter packet_filter_name
Specify name of the packet filter.
Usage Guidelines
Use this command to configure the packet filter to be sent to the MS. Up to eight packet filters can be specified in a charging action.
You can configure a maximum of eight elements with this command.
Example
The following command configures the packet filter filter23 to be sent to the MS:
tft packet-filter filter23
active-charging service charging-action tos af11
Configures using Assured Forwarding 11 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af11 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 11 Per Hop Behavior (PHB).
active-charging service charging-action tos af12
Configures using Assured Forwarding 12 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af12 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 12 Per Hop Behavior (PHB).
active-charging service charging-action tos af13
Configures using Assured Forwarding 13 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af13 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 13 Per Hop Behavior (PHB).
active-charging service charging-action tos af21
Configures using Assured Forwarding 21 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af21 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 21 Per Hop Behavior (PHB).
active-charging service charging-action tos af22
Configures using Assured Forwarding 22 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af22 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 22 Per Hop Behavior (PHB).
active-charging service charging-action tos af23
Configures using Assured Forwarding 23 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af23 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 23 Per Hop Behavior (PHB).
active-charging service charging-action tos af31
Configures using Assured Forwarding 31 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af31 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 31 Per Hop Behavior (PHB).
active-charging service charging-action tos af32
Configures using Assured Forwarding 32 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af32 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 32 Per Hop Behavior (PHB).
active-charging service charging-action tos af33
Configures using Assured Forwarding 33 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af33 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 33 Per Hop Behavior (PHB).
active-charging service charging-action tos af41
Configures using Assured Forwarding 41 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af41 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 41 Per Hop Behavior (PHB).
active-charging service charging-action tos af42
Configures using Assured Forwarding 42 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af42 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 42 Per Hop Behavior (PHB).
active-charging service charging-action tos af43
Configures using Assured Forwarding 43 Per Hop Behavior (PHB).
Command Mode
Syntax
tos af43 [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Assured Forwarding 43 Per Hop Behavior (PHB).
active-charging service charging-action tos be
Configures using Best Effort Forwarding PHB.
Command Mode
Syntax
tos be [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Best Effort Forwarding Per Hop Behavior (PHB).
active-charging service charging-action tos ef
Configures using Expedited Forwarding PHB.
Command Mode
Syntax
tos ef [ downlink | uplink ]
downlink
uplink
Usage Guidelines
Use this command to configure using Expedited Forwarding Per Hop Behavior (PHB).
active-charging service charging-action tos lower-bits
Configures the least-significant six bits in the ToS byte with the specified numeric value.
Command Mode
Syntax
tos lower-bits value [ downlink | uplink ]
downlink
Specify the ToS only for downlink packets.
lower-bits value
Specify the value.
Must be an integer in the range of 0-63.
uplink
Specify the ToS only for uplink packets.
Usage Guidelines
Use this command to configure the least-significant six bits in the ToS byte with the specified numeric value.
active-charging service content-filtering category policy-id
Configures Content Filtering Category Policy ID.
Command Mode
Syntax
content-filtering category policy-id cf_category_policy_id
Specify the Content Filtering Category Policy ID.
Usage Guidelines
Use this command to configure the Content Filtering Category Policy ID. The CLI prompt changes to the Content Filtering Category Policy Configuration mode (config-policy-id-<content_filtering_policy_id>).
active-charging service content-filtering category policy-id analyze priority
Assigns priority to a Content Filtering Category in the Content Filtering Policy.
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > Content Filtering Category Policy Configuration (config-policy-id-content_filtering_policy_id )
Syntax
analyze priority cf_category_priority
Specify priority of the Content Filtering Category in the Content Filtering Policy.
Usage Guidelines
Use this command to assign priority to a Content Filtering Category in a Content Filtering Policy.
active-charging service content-filtering category policy-id analyze priority all
Configures all content to be rated.
Command Mode
Syntax
analyze priority cf_category_priority all action { allow | content-insert content_to_insert }
action
Specify an action.
allow
Specify the allow action.
Specify the content insert action, and the content string to insert.
Must be a string.
Usage Guidelines
Use this command to configure the all content to be rated.
active-charging service content-filtering category policy-id analyze priority category
Configures category of the content to be rated.
Command Mode
Syntax
analyze priority cf_category_priority category category_name action { allow | content-insert content_to_insert }
action
Specify an action.
allow
Specify name of the category.
  • ABOR
  • ADULT
  • ADVERT
  • ANON
  • ART
  • AUTO
  • BACKUP
  • BLACK
  • BLOG
  • BUSI
  • CAR
  • CDN
  • CHAT
  • CMC
  • CRIME
  • CULT
  • DRUG
  • DYNAM
  • EDU
  • ENERGY
  • ENT
  • FIN
  • FORUM
  • GAMB
  • GAME
  • GLAM
  • GOVERN
  • HACK
  • HATE
  • HEALTH
  • HOBBY
  • HOSTS
  • KIDS
  • LEGAL
  • LIFES
  • MAIL
  • MIL
  • NEWS
  • OCCULT
  • PEER
  • PERS
  • PHOTO
  • PLAG
  • POLTIC
  • PORN
  • PORTAL
  • PROXY
  • REF
  • REL
  • SCI
  • SEARCH
  • SHOP
  • SPORT
  • STREAM
  • SUIC
  • SXED
  • TECH
  • TRAVE
  • UNKNOW
  • VIOL
  • VOIP
  • WEAP
  • WHITE
Must be a string.
Usage Guidelines
Use this command to configure the category of the content to be rated.
active-charging service content-filtering category policy-id analyze priority x-category
Configures unclassified categories to be rated.
Command Mode
Syntax
analyze priority cf_category_priority x-category xcategory_name action { allow | content-insert content_to_insert }
action
Specify an action.
allow
Must be a string.
Specify name of the x-category.
Must be a string of 1-6 characters.
Usage Guidelines
Use this command to configure unclassified categories to be rated.
active-charging service credit-control group
Configures prepaid services for Diameter/RADIUS applications.
Command Mode
Syntax
credit-control group cc_group_name
group cc_group_name
Specify name of the credit control group.
Usage Guidelines
Use this command to enable/disable Prepaid Credit Control Configuration for RADIUS/Diameter charging mode, and specify the credit control group.
active-charging service credit-control group associate
Associates the failure handling template.
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > Credit Control Group Configuration (config-group-credit_control_group_name )
Syntax
associate failure-handling-template template_name
Specify name of the failure handling template.
Usage Guidelines
Use this command to associate the failure handling template.
active-charging service credit-control group diameter
Configures accepting/ignoring service ID in the Service-Identifier AVP defined in the Diameter dictionaries.
Command Mode
Syntax
diameter ignore-service-id { false | true }
Specify to enable or disable usage of service ID. To disable, set to true.
  • false
  • true
Default Value: false.
Usage Guidelines
Use this command to ignore/accept service ID value in the Service-Identifier AVP in the Diameter dictionaries.
Example
The following command specifies to ignore service ID in the Diameter dictionaries:
active-charging service credit-control group diameter origin
Configures the Diameter Credit Control Origin Endpoint parameter.
Command Mode
Syntax
diameter origin endpoint origin_endpoint_name
Specify name of the Diameter Credit Control Origin Endpoint.
Usage Guidelines
Use this command to configure the Diameter Credit Control Origin Endpoint parameter.
active-charging service credit-control group diameter service-context-id
Configures the value to be sent in the Service-Context-Id AVP, which defines the context in which DCCA is used.
Command Mode
Syntax
diameter service-context-id service_context_id
Specify the value to be sent in the Service-Context-Id AVP.
Usage Guidelines
Use this command to specify the value to be sent in the Service-Context-Id AVP, which defines the context in which DCCA is used.
active-charging service credit-control group diameter session
Configures Diameter Credit Control Session Failover configuration.
Command Mode
Syntax
diameter session failover
failover
Specify Diameter Credit Control Session Failover.
Usage Guidelines
Use this command to configure Diameter Credit Control Session Failover.
active-charging service credit-control group failure-handling initial-request continue
Configures Diameter Credit Control Failure Handling action to continue.
Command Mode
Syntax
failure-handling initial-request continue continue_action
Syntax
failure-handling terminate-request continue continue_action
Syntax
failure-handling update-request continue continue_action
Specify the continue action.
  • go-offline-after-tx-expiry : After Tx expiry, start offline charging.
  • retry-after-tx-expiry : After Tx expiry, retry.
Usage Guidelines
Use this command to configure Diameter Credit Control Failure Handling action for CCR-Initial/CCR-Terminate/CR-Update to continue.
active-charging service credit-control group failure-handling initial-request retry-and-terminate
Configures Diameter Credit Control Failure Handling action to retry, and in case of failure, to terminate.
Command Mode
Syntax
failure-handling initial-request retry-and-terminate retry_and_terminate_action
Syntax
failure-handling terminate-request retry-and-terminate retry_and_terminate_action
Syntax
failure-handling update-request retry-and-terminate retry_and_terminate_action
Specify the retry-and-terminate action.
Usage Guidelines
Configures Diameter Credit Control Failure Handling action for CCR-Initial/CCR-Terminate/CR-Update to retry, and in case of failure, to terminate.
active-charging service credit-control group failure-handling initial-request terminate
Configures Diameter Credit Control Failure Handling action as terminate.
Command Mode
Syntax
Syntax
failure-handling terminate-request terminate
Syntax
failure-handling update-request terminate
Usage Guidelines
Configures Diameter Credit Control Failure Handling action for CCR-Initial/CCR-Terminate/CR-Update to terminate.
active-charging service credit-control group failure-handling terminate-request continue
Command Mode
Syntax
Syntax
Syntax
Usage Guidelines
active-charging service credit-control group failure-handling terminate-request retry-and-terminate
Command Mode
Syntax
Syntax
Syntax
Usage Guidelines
active-charging service credit-control group failure-handling terminate-request terminate
Command Mode
Syntax
Syntax
Syntax
Usage Guidelines
active-charging service credit-control group failure-handling update-request continue
Command Mode
Syntax
Syntax
Syntax
Usage Guidelines
active-charging service credit-control group failure-handling update-request retry-and-terminate
Command Mode
Syntax
Syntax
Syntax
Usage Guidelines
active-charging service credit-control group failure-handling update-request terminate
Command Mode
Syntax
Syntax
Syntax
Usage Guidelines
active-charging service credit-control group pending-traffic-treatment forced-reauth
Configures the Diameter Credit Control pending traffic treatment to forced reauthorization.
Command Mode
Syntax
pending-traffic-treatment forced-reauth { drop | pass }
drop
Specify to drop.
pass
Specify to pass.
Usage Guidelines
Use this command to configure the Diameter Credit Control pending traffic treatment to forced reauthorization.
active-charging service credit-control group pending-traffic-treatment noquota
Configures the Diameter Credit Control Pending Traffic Treatment.
Command Mode
Syntax
pending-traffic-treatment noquota { buffer | drop | pass }
buffer
Specify to tentatively count/time traffic, and then buffer traffic pending arrival of quota. Buffered traffic will be forwarded and fully charged against the quota when the quota is eventually obtained and the traffic is passed.
drop
Specify to drop any traffic when there is no quota present.
pass
Specify to pass all traffic more or less regardless of quota state.
Usage Guidelines
Controls the pass/drop treatment of traffic while waiting for definitive credit information from the server. Use this command to configure the Credit Control pending traffic treatment.
active-charging service credit-control group pending-traffic-treatment noquota limited-pass
Enables limited access for subscribers when the OCS is unreachable.
Command Mode
Syntax
pending-traffic-treatment noquota limited-pass volume volume
volume volume
Specify limited volume access to subscriber in case OCS is unreachable.
Usage Guidelines
Use this command to enable limited access for subscribers when the OCS is unreachable.
active-charging service credit-control group pending-traffic-treatment quota-exhausted
Configures the Diameter Credit Control Pending Traffic Treatment parameter for quota exhaustion.
Command Mode
Syntax
pending-traffic-treatment quota-exhausted { buffer | drop | pass }
buffer
drop
Specify to drops any traffic when there is no quota present.
pass
Usage Guidelines
Use this command to configure the Diameter Credit Control Pending Traffic Treatment for quota exhaustion.
active-charging service credit-control group pending-traffic-treatment trigger
Configures the Diameter Credit Control pending traffic treatment to trigger.
Command Mode
Syntax
pending-traffic-treatment trigger { drop | pass }
drop
Specify to drop.
pass
Specify to pass.
Usage Guidelines
Use this command to configure the Diameter Credit Control pending traffic treatment to trigger.
active-charging service credit-control group pending-traffic-treatment validity-expired
Configures the Diameter Credit Control pending traffic treatment to validity-expired.
Command Mode
Syntax
pending-traffic-treatment validity-expired { drop | pass }
drop
Specify to drop.
pass
Specify to pass.
Usage Guidelines
Use this command to configure the Diameter Credit Control pending traffic treatment to validity-expired.
active-charging service credit-control group quota holding-time
Configures the Credit Control Quota Holding Time (QHT).
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > Credit Control Configuration (config-group-credit_control_group_name )
Syntax
quota holding-time holding_time
Specify the quota holding time in seconds.
Must be an integer in the range of 1-4000000000.
Usage Guidelines
This command configures the time-based quotas in the prepaid credit control service. Use this command to configure the Credit Control Quota Holding Time.
active-charging service credit-control group quota request-trigger
Configures Credit Control include/exclude packet causing threshold.
Syntax
quota request-trigger { exclude-packet-causing-trigger | include-packet-causing-trigger }
Specify to exclude packet causing trigger.
Specify to include packet causing trigger.
Usage Guidelines
This command sets the time-based quotas in the prepaid credit control service. Use this command to configure the Credit Control include/exclude packet causing threshold.
active-charging service credit-control group timestamp-rounding
Configures the timestamp rounding mechanism for quota consumption.
Command Mode
Syntax
timestamp-rounding timestamp_rounding_mechanism
Specify the timestamp rounding mechanism for quota consumption.
  • ceiling : Specify to round off to the smallest integer greater than the fraction.
  • floor : Specify to always discard the fraction.
  • roundoff : If the fractional part is greater than or equal to 0.5, specify to round off to the smallest integer greater than the fraction.
Usage Guidelines
Use this command to configure the timestamp rounding mechanism for quota consumption.
active-charging service credit-control group usage-reporting quotas-to-report based-on-grant
Configures the ACS Credit Control usage reporting type.
Command Mode
Syntax
usage-reporting quotas-to-report based-on-grant [ report-only-granted-volume ]
Suppresses the input and output octets. If the Granted-Service-Unit (GSU) AVP comes with CC-Total-Octets, then the device will send total, input and output octets in Used-Service-Unit (USU) AVP. If it comes with Total-Octets, the device will send only Total-Octets in USU.
Usage Guidelines
Use this command to configure reporting usage only for granted quota. On issuing this command, the Used-Service-Unit AVP will report quotas based on grant i.e, only the quotas present in the Granted-Service-Unit AVP. With this command only the units for which the quota was granted by the DCCA server will be reported irrespective of the reporting reason.
active-charging service group-of-ruledefs
Configures ACS group-of-ruledefs parameters.
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > Group of Ruledefs Configuration (config-group-of-ruledefs-group_name )
Syntax
group-of-ruledefs group_of_ruledefs_name
Specify name of the group-of-ruledefs.
Must be a string.
Usage Guidelines
Use this command to create/configure a group-of-ruledefs. A group-of-ruledefs is a collection of ruledefs to use in access policy creation. Maximum of 384 group-of-ruledefs can be created.
You can configure a maximum of 384 elements with this command.
Example
The following command creates a group-of-ruledefs named group1:
group-of-ruledefs group1
active-charging service group-of-ruledefs add-ruledef priority
Configures the priority of the ruledef in the current group-of-ruledefs.
Command Mode
Syntax
add-ruledef priority ruledef_priority ruledef ruledef_name
Specify the priority of the ruledef. The priority must be unique within the group-of-ruledefs.
Must be an integer in the range of 1-10000.
Specify name of the ruledef to add to the current group-of-ruledefs.
Usage Guidelines
Use this command to add ruledefs to a group-of-ruledefs, and configure the priority of the ruledef in the current group-of-ruledefs. A maximum of 512 ruledefs can be added to a group of ruledefs.
You can configure a maximum of 512 elements with this command.
active-charging service p2p-detection attribute ssl-renegotiation
Specify the supported attribute of configurable P2P detection attributes populated from the currently loaded P2P plugin.
Command Mode
Syntax
p2p-detection attribute ssl-renegotiation { [ id-reduce-factor id_reduce_factor ] [ max-entry-per-sessmgr max_entry_per_sessmgr ] }
Specify by what factor the SSL ID is stored in the SSL Session ID Tracker table.
Specify maximum SSL Session IDs tracked per session manager.
Usage Guidelines
Configures the detection of SSL renegotiation flows. Use this command to specify the supported attribute of configurable P2P detection attributes populated from the currently loaded P2P plugin.
Example
The following command enables SSL renegotiation with SSL session IDs as 40000 and factor as 4:
p2p-detection attribute ssl-renegotiation max-entry-per-sessmgr 40000 id-reduce-factor 4
active-charging service p2p-detection ecs-analysis
Enables or disables ACS analysis for all or specified analyzer.
Command Mode
Syntax
p2p-detection ecs-analysis analyzer
Specify the ACS analyzers.
  • all : ACS analysis for all analyzers.
  • ftp : ACS analysis for FTP analyzer.
  • http : ACS analysis for HTTP analyzer.
  • https : ACS analysis for HTTPS analyzer.
  • rtsp : ACS analysis for RTSP analyzer.
  • sip : ACS analysis for SIP analyzer.
Usage Guidelines
Use this command to enable or disable ACS analysis for analyzers. This feature is enabled by default if P2P protocols are enabled.
Example
The following command enables ACS analysis for the FTP analyzer:
p2p-detection ecs-analysis ftp
active-charging service p2p-detection protocol
Enables or disables the detection of all or specified peer-to-peer (P2P) protocols.
Command Mode
Syntax
p2p-detection protocol p2p_protocol
Specify the P2P protocol.
  • all
  • cisco-jabber
  • eros
  • fasttrack
  • googlemaps
  • skype
  • teamspeak
  • uber
  • ufc
  • yahoo
Usage Guidelines
Use this command to configure detection of all or specified P2P protocol.
Example
The following command enables detection of all P2P protocols:
p2p-detection protocol all
active-charging service packet-filter
Configures ACS Packet Filter parameters.
Command Mode
Syntax
direction direction
Specify the direction in which the current packet filter will be applied.
  • bi-directional : Specify to apply the filter both in the uplink and downlink directions. This is the default value.
  • downlink : Specify to apply the filter only in the downlink direction.
  • uplink : Specify to apply the filter only in the uplink direction.
Default Value: bi-directional.
priority priority
Specify the priority of the packet filter.
Must be an integer in the range of 0-255.
Usage Guidelines
Use this command to configure ACS Packet Filter parameters.
active-charging service packet-filter ip local-port operator
Configures the port number of the local or remote transport protocol.
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > Packet Filter Configuration (config-service-packet-filter-packet_filter_name )
Syntax
ip local-port operator port_number
Syntax
ip remote-port operator port_number
operator
Specify how to match.
  • = : Equals.
port_number
Specify the port number of the transport protocol.
Usage Guidelines
Configures the IP 5-tuple port(s) for the current packet filter. Use this command to configure the port number of the local or remote transport protocol.
active-charging service packet-filter ip local-port range
Configures a range of port numbers of the local or remote transport protocol.
Command Mode
Syntax
ip local-port range start_port_number to end_port_number
Syntax
ip remote-port range start_port_number to end_port_number
to end_port_number
Specify the ending port number for the port number range. The ending port number must be greater than the starting port number.
start_port_number
Specify the starting port number for the port number range. The starting port number must be lesser than the ending port number.
Usage Guidelines
Use this command to configure a range of port number of the local or remote transport protocol.
active-charging service packet-filter ip protocol
Configures the IP protocol(s) for the current packet filter.
Command Mode
Syntax
ip protocol operator protocol_number
operator
  • = : Equals.
protocol_number
Specify the protocol number.
Usage Guidelines
Configures the IP 5-tuple local port(s) for the current packet filter. Use this command to configure the protocol(s) for a packet filter.
Example
The following command configures the protocol assignment number 300:
ip protocol = 300
active-charging service packet-filter ip remote-address
Configures the IP remote address(es) for the current packet filter.
Command Mode
Syntax
ip remote-address operator ip_address/mask
ip_address_mask
Specify the IP address and mask.
Must be a string in the ipv4-prefix pattern. For information on the ipv4-prefix pattern, see the Input Pattern Types chapter.
-Or-
Must be a string in the ipv6-prefix pattern. For information on the ipv6-prefix pattern, see the Input Pattern Types chapter.
operator
  • = : Equals.
Usage Guidelines
Configures the IP 5-tuple local port(s) for the current packet filter. Use this command to configure the remote address(es) for a packet filter.
Example
The following command configures the IP remote address as 10.2.3.4/24:
ip remote-address = 10.2.3.4/24
active-charging service packet-filter ip remote-port operator
Command Mode
Syntax
Syntax
operator
  • = : Equals.
port_number
Usage Guidelines
active-charging service packet-filter ip remote-port range
Command Mode
Syntax
Syntax
to end_port_number
start_port_number
Usage Guidelines
active-charging service packet-filter ip tos-traffic-class
Configures the type of service (TOS) traffic class under charging action in the Packet filter mode.
Command Mode
Syntax
ip tos-traffic-class tos_traffic_class_operator traffic_class mask mask_operator mask_field_value
mask mask_operator
Specify how to match the specified mask.
  • = : Equals.
mask_field_value
Specify the traffic-class mask field.
Specify how to match the specified TOS Traffic Class.
  • = : Equals.
traffic_class
Specify the traffic class value to filter the traffic.
Usage Guidelines
Use this command to configure the TOS traffic class under charging action in the Packet filter mode.
active-charging service rulebase
Configures ACS rulebases.
Command Mode
Syntax
rulebase rulebase_name [ retransmissions-counted | transactional-rule-matching ]
retransmissions-counted { false | true }
Specify whether to count retransmissions in all charging modules.
  • false
  • true
Default Value: true.
Specify name of the rulebase. If the named rulebase does not exist, it is created, and the CLI mode changes to the ACS Rulebase Configuration Mode wherein the rulebase can be configured. If the named rulebase already exists, the CLI mode changes to the ACS Rulebase Configuration Mode for that rulebase.
Must be a string.
Specify to enable or disable transactional rule matching (TRM), which allows the ACS to bypass per-packet rule matching on a transaction once the transaction is fully classified.
Usage Guidelines
Use this command to create/configure an ACS rulebase. A rulebase is a collection of protocol rules to match a flow and associated actions to be taken for matching flow. The default rulebase is used when a subscriber/APN is not configured with a specific rulebase to use.
Example
The following command creates a rulebase named test1:
rulebase test1
active-charging service rulebase action
Configures the action priority for a ruledef or group-of-ruledefs in the current rulebase.
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > Rulebase Configuration (config-rulebase-rulebase_name )
Syntax
action priority action_priority { dynamic-only | static-and-dynamic | timedef timedef_name }
Usage Guidelines
Use this command to configure action priorities for ruledefs / group-of-ruledefs in a rulebase. This CLI command can be entered multiple times to specify multiple ruledefs and charging actions. The ruledefs are examined in priority order, until a match is found and the corresponding charging action is applied.
Example
The following command assigns a rule and action with the action priority of 23, a ruledef named test, and a charging action named test1 to the current rulebase:
action priority 23 ruledef test charging-action test1
active-charging service rulebase action priority
Configures priority for the specified ruledef or group-of-ruledefs in the current rulebase.
Command Mode
Syntax
Specify the action priority.
Usage Guidelines
Use this command to assign priority to a rule in a rulebase.
active-charging service rulebase action priority dynamic-only
Enables matching of dynamic rules with static rules for this action priority on a flow.
Command Mode
Syntax
dynamic-only
Usage Guidelines
Use this command to enable matching of dynamic rules with static rules for this action priority on a flow.
active-charging service rulebase action priority dynamic-only adc group-of-ruledefs
Assigns a group-of-ruledefs to the rulebase.
Command Mode
Syntax
adc ruledef ruledef_name { [ charging-action charging_action_name ] [ description description ] [ monitoring-key monitoring_key ] [ umid instance_id ] }
Syntax
Assigns the specified charging action to the rulebase.
Adds specified text to the rule and action.
Associates the specified monitoring-key with ruledefs for usage monitoring.
Must be an integer in the range of 1-134217727.
umid um_id
Specify the Usage Monitoring Control Instance Identifier as required for usage reporting over N7.
Usage Guidelines
Use this command to assign a group-of-ruledefs to the rulebase.
active-charging service rulebase action priority dynamic-only adc ruledef
Assigns ruledefs to the rulebase.
Command Mode
Syntax
Specify name of the ruledef.
umid um_id
Usage Guidelines
Use this command to assign ruledefs to the rulebase.
active-charging service rulebase action priority dynamic-only group-of-ruledefs
Command Mode
Syntax
Syntax
umid um_id
Usage Guidelines
active-charging service rulebase action priority dynamic-only ruledef
Command Mode
Syntax
umid um_id
Usage Guidelines
active-charging service rulebase action priority group-of-ruledefs
Assigns a group-of-ruledefs to the rulebase. Or, associates a time definition with a group-of-ruledefs.
Command Mode
Syntax
action priority action_priority static-and-dynamic group-of-ruledefs group_of_ruledefs_name
Syntax
action priority action_priority timedef group-of-ruledefs group_of_ruledefs_name charging-action charging_action_name [ description description ] [ monitoring-key monitoring_key ]
Usage Guidelines
Use this command to assign a group-of-ruledefs to the rulebase. Or, associate a time definition with a group-of-ruledefs. Timedefs activate or deactivate groups-of-ruledefs, making them available for rule matching only when they are active.
active-charging service rulebase action priority ruledef
Assigns ruledefs to the rulebase. Or, associates a time definition with a ruledef.
Command Mode
Syntax
action priority action_priority static-and-dynamic ruledef ruledef_name charging-action charging_action_name ruledef ruledef_name [ description description ] [ monitoring-key monitoring_key ]
Syntax
action priority action_priority timedef ruledef ruledef_name charging-action charging_action_name [ description description ] [ monitoring-key monitoring_key ]
Usage Guidelines
Use this command to assign ruledefs to the rulebase. Or, associate a time definition with a ruledef. Timedefs activate or deactivate ruledefs, making them available for rule matching only when they are active.
active-charging service rulebase action priority static-and-dynamic group-of-ruledefs
Command Mode
Syntax
Syntax
Usage Guidelines
active-charging service rulebase action priority static-and-dynamic ruledef
Command Mode
Syntax
Syntax
Usage Guidelines
active-charging service rulebase action priority timedef group-of-ruledefs
Command Mode
Syntax
Syntax
Usage Guidelines
active-charging service rulebase action priority timedef ruledef
Command Mode
Syntax
Syntax
Usage Guidelines
active-charging service rulebase bandwidth
Configures rulebase bandwidth policy parameters.
Command Mode
Syntax
bandwidth default-policy default_firewall_policy_name
Specify the default firewall policy.
Usage Guidelines
Use this command to configure the rulebase bandwidth policy parameter for default firewall policy.
active-charging service rulebase billing-records
Configures the type of billing to be performed for subscriber sessions.
Command Mode
Syntax
billing-records { [ egcdr ] [ radius ] [ rf ] }
egcdr
Generates an enhanced G-CDR (eG-CDR) for GGSN / P-GW-CDR for P-GW, and/or UDR with specified format on the occurrence of an interim trigger condition at the end of a subscriber session, or an SGSN-to-SGSN handoff
radius
Generates postpaid RADIUS accounting records at the start and end of a subscriber session, and on the occurrence of an interim trigger condition. RADIUS accounting records are generated for each content ID.
rf
Specify to enable Rf accounting.
Usage Guidelines
Use this command to generate enhanced G-CDRs (eG-CDRs), P-GW-CDR for P-GW, RADIUS CDRs and/or UDRs for billing records. The format of eG-CDRs for the default GTPP group is controlled by the inspector command in the Context Configuration Mode.
active-charging service rulebase billing-records udr
Generates Usage Data Record (UDR) with specified the format on the occurrence of an interim trigger condition, at the end of a subscriber session, or a handoff.
Command Mode
Syntax
billing-records udr udr-format udr_format_name
Specify name of the UDR format.
Usage Guidelines
Use this command to enable Usage Data Record.
Example
The following command sets the billing record to UDR with UDR format named udr_format1:
billing-records udr udr-format udr_format1
active-charging service rulebase cca diameter requested-service-unit sub-avp time
Configures the ACS Diameter Credit Control Requesting Service Unit - time values.
Command Mode
Syntax
cca diameter requested-service-unit sub-avp time cc-time cc_time
cc-time cc_time
Specify requested service unit for charging time duration in seconds in included sub-AVP.
Usage Guidelines
Configures the Diameter sub-AVPs to be included in "Requested-Service-Unit", the Diameter group AVP sent with DCCA Credit Control Requests (CCRs). Use this command to configure the ACS Diameter Credit Control requesting service unit - time values.
active-charging service rulebase cca diameter requested-service-unit sub-avp units
Configures ACS Diameter Credit Control Requesting Service Unit - Service-specific values.
Command Mode
Syntax
cca diameter requested-service-unit sub-avp units cc-service-specific-units charging_unit
Specify the service-specific charging units.
Usage Guidelines
Configures sub-AVP of the Requested-Service-Unit AVP. Use this command to configure the ACS Diameter Credit Control Requesting Service Unit - Service-specific values.
active-charging service rulebase cca diameter requested-service-unit sub-avp volume
Configures the ACS Diameter Credit Control Requesting Service Unit - Time values.
Command Mode
Syntax
cca diameter requested-service-unit sub-avp volume { [ cc-input-octets cc_input_octets ] [ cc-output-octets cc_output_octets [ cc-total-octets cc_total_octets ] }
Specify the volume in bytes.
Specify the output charging octets in bytes.
Specify the total charging octets in bytes.
Usage Guidelines
Configures sub-AVP of the Requested-Service-Unit AVP. Use this command to configure the ACS Diameter Credit Control Requesting Service Unit - Time values.
active-charging service rulebase cca quota holding-time
Configures the Quota Holding Time (QHT). QHT is used with both time- and volume-based quotas.
Command Mode
Syntax
cca quota holding-time holding_time content-id content_id
Specify the content ID (Rating group AVP) to use for the Quota holding time for the current rulebase. Must be the content ID specified for Credit Control Service in the ACS.
Specify the holding time.
Usage Guidelines
Configures various time and threshold-based quotas in the Prepaid Credit Control Service (Credit Control Application). Use this command to configure the value for the Quota Holding Time (QHT). QHT is used with both time- and volume-based quotas. After the configured number of seconds has passed without user traffic, the quota is reported back and the charging stops until new traffic starts.
active-charging service rulebase cca quota retry-time
Configures the retry time for the quota request.
Command Mode
Syntax
cca quota retry-time retry_time [ max-retries max_retries ]
Specify the maximum number of retries allowed for blacklisted categories.
Specify the retry interval in seconds.
Must be an integer in the range of 0-86400.
Usage Guidelines
Use this command to configure credit control quota retry time.
active-charging service rulebase cca quota time-duration
Configures the algorithm to compute time duration for Prepaid Credit Control Application quotas in the current rulebase.
Command Mode
Syntax
cca quota time-duration algorithm { consumed-time consumed_time [ plus-idle ] | continuous-time-periods continuous_time_periods | parking-meter parking_meter } [ content-id content_id ]
algorithm
Specify the Credit Control Quota Time Duration algorithm.
Specify the Credit Control consumed time.
Specify the Content ID.
Specify the continuous time periods.
Specify the Credit Control Parking Meter.
plus-idle
Specify the Credit Control idle time.
Usage Guidelines
Use this command to configure the various time charging algorithms/schemes for prepaid credit control charging. If operator chooses parking-meter style charging, then time is billed in seconds chunks.
Example
The following command configures the QCT to consumed-time duration of 400 seconds:
cca quota time-duration algorithm consumed-time 400
active-charging service rulebase content-filtering category
Configures the Content Filtering Category Policy Identifier for Policy-based Content Filtering support in the current rulebase.
Command Mode
Syntax
content-filtering category policy-id cf_policy_id
Specify the Content Filtering Policy ID.
Usage Guidelines
Use this command to configure the Content Filtering Category Policy ID for Policy-based Content Filtering support in the rulebase.
Example
The following command configures the Content Filtering Category Policy ID 101 in the rulebase:
content-filtering category policy-id 101
active-charging service rulebase content-filtering flow-any-error
Configures the action to take on Content Filtering packets in the case of ACS error scenarios.
Command Mode
Syntax
content-filtering flow-any-error { deny | permit }
deny
Specify the flow-any-error configuration as deny. All the denied packets will be accounted for by the discarded-flow-content-id configuration in the Content Filtering Policy Configuration Mode. This content ID will be used to generate UDRs for packets denied via content filtering.
permit
Specify the flow-any-error configuration as permit.
Usage Guidelines
Use this command to allow/discard content filtering packets in case of ACS error scenarios.
Example
The following command allows content filtering packets in case of an ACS error:
content-filtering flow-any-error permit
active-charging service rulebase content-filtering mode
Enables or disables the specified Category-based Content Filtering mode in the current rulebase.
Syntax
content-filtering mode { category { static-and-dynamic | static-only } | server-group cf_server_group_name }
Using Category-based Content Filtering support requires Content Filtering Category configuration in the Global Configuration Mode.
  • static-and-dynamic : Configures Category-based Content Filtering in Static-and-Dynamic mode, wherein a static rating of the URL is first performed, and only if the static rating fails to find a match, dynamic rating of the content that the server returns is then performed.
  • static-only : Configures Category-based Content Filtering in static only mode, wherein all URLs are compared against an internal database to categorize the requested content.
server-group server_group_name
Specify name of the Content Filtering Server Group.
Usage Guidelines
Use this command to enable and apply the content filtering mode in the rulebase to manage a content filtering server with an ICAP client system.
Example
The following command enables the content filtering mode for external content filtering server group cf_server1 in the rulebase:
content-filtering mode server-group cf_server1
active-charging service rulebase credit-control-group
Configures the credit control group to be used for subscribers who use this rulebase.
Command Mode
Syntax
credit-control-group cc_group_name
Usage Guidelines
Use this command to specify the desired CC group whenever the rulebase is selected during the subscriber session setup. This is an optional CLI configuration, and used only when customized Assume Positive behavior is required for subscribers. This CLI configuration is applicable only during the session setup. Mid-session change in the CC group is not allowed.
Example
The following command configures the association of a credit-control group named test for the current rulebase:
credit-control-group test
active-charging service rulebase dynamic-rule
Configfures whether dynamic rules are matched before statically configured rules.
Command Mode
Syntax
dynamic-rule order dynamic_rule_order
Specify dynamic rule order.
  • always-first : Specify to match all the dynamic rules against the flow prior to any static rule. This is the default value.
  • first-if-tied : Specify to match rules against the flow based on their priority with the condition that dynamic rules match before a static rule of the same priority. A rule is a combination of a ruledef, charging action, and precedence. Static rules are defined by the "action" CLI command in the ACS Rulebase Configuration Mode, and are applicable to all subscribers that are associated with the rulebase. Dynamic rules are obtained via a dynamic protocol, such as, the Gx-interface for a particular subscriber session.
Usage Guidelines
Use this command to configure the order in which rules are selected for matching in between dynamic rules (per subscriber) and static rules (from rulebase).
Example
The following command matches all dynamic rules against the flow prior to any static rule:
dynamic-rule order always-first
active-charging service rulebase edr transaction-complete
Configures EDR-related parameters.
Command Mode
Syntax
edr transaction-complete { dns | http } [ charging-edr charging_edr_format_name | edr-format edr_format_name | reporting-edr reporting_edr_format_name ]
Specify to generate charging EDR on transaction completion.
dns
DNS protocol-related configuration.
Specify to generate EDR on transaction completion for DNS or HTTP protocol.
http
HTTP protocol-related configuration.
Specify the reporting EDR format name to generate reporting EDR on transaction completion.
Usage Guidelines
Configures the generation of an EDR on the completion of a transaction. Use this command to configure the generation of an EDR when certain application transactions (for example, request/response pairs) complete. EDR generation is supported for DNS or HTTP protocol. Note that these EDRs are in addition to those that might be generated due to other conditions, for example, EDR configurations in a charging action.
Example
The following command configures the generation of charging EDRs on the completion of transactions for HTTP protocol specifying the EDR format as test123:
edr transaction-complete http charging-edr test123
active-charging service rulebase egcdr threshold
Assigns volume or interval values to the interim G-CDRs.
Command Mode
Syntax
egcdr threshold interval duration
interval duration
Specify the time interval, in seconds, for closing the G-CDR/PGW-CDR if the minimum time duration thresholds are satisfied.
Must be an integer in the range of 60-40000000.
Usage Guidelines
Configures the thresholds for generating eG-CDRs for GGSN and PGW-CDRs for P-GW. Use this command to assign the interval values to the interim G-CDRs.
Example
The following command defines an eG-CDR threshold interval of 600 seconds:
egcdr threshold interval 600
active-charging service rulebase egcdr threshold volume
Configures the uplink/downlink volume octet counts for the generation of the interim G-CDRs/PGW-CDRs.
Command Mode
Syntax
egcdr threshold volume { downlink | total | uplink } bytes
downlink bytes
Specify the limit for the number of downlink (from network to subscriber) octets after which the G-CDR/PGW-CDR is closed.
Must be an integer in the range of 100000-4000000000.
total bytes
Specify the limit for the total number of octets (uplink+downlink) after which the G-CDR/PGW-CDR is closed.
uplink bytes
Specify the limit for the number of uplink (from subscriber to network) octets after which the G-CDR/PGW-CDR is closed.
Usage Guidelines
Configures the thresholds for generating G-CDRs and PGW-CDRs. Use this command to configure the uplink/downlink volume octet counts for the generation of the interim G-CDRs.
active-charging service rulebase flow control-handshaking
Specify control protocol handshake packets.
Command Mode
Syntax
flow control-handshaking charge-separate-from-application
Specify the charging action to separate the charging of the initial control packets or all subsequent control packets from regular charging.
Usage Guidelines
Configures the charge for the control traffic associated with an application. Use this command to specify control protocol handshake packets.
active-charging service rulebase flow control-handshaking charge-to-application
Configures the charging action to include the flow control packets either during initial handshaking only or specified control packets during session for charging.
Command Mode
Syntax
flow control-handshaking charge-to-application { [ all-packets ] [ initial-packets ] [ mid-session-packets ] [ tear-down-packets ] }
all-packets
Specify that the initial setup packets will wait until the application has been determined before assigning the content-id, and all mid-session ACK packets as well as the final tear-down packets will use that content-id.
initial-packets
Specify that only the initial setup packets will wait for content-id assignment.
mid-session-packets
Specify that the ACK packets after the initial setup will use the application's or content-id assignment.
tear-down-packets
Specify that the final tear-down packets (TCP or WAP) will use the application's or content-id assignment.
Usage Guidelines
Use this command to charge control packets to application ruledefs.
active-charging service rulebase flow end-condition
Configures the end condition of the session flows related to a user session and triggers EDR generation.
Command Mode
Syntax
flow end-condition { normal-end-signaling | session-end | timeout } [ charging-edr charging_edr_format_name ]
Specify name of the charging EDR format.
Creates an EDR with the specified EDR format whenever flow end is signaled normally, for example like detecting FIN and ACK for a TCP flow, or a WSP-DISCONNECT terminating a connection-oriented WSP flow over UDP) and create an EDR for the flow using the specified EDR format.
session-end
Creates an EDR with the specified EDR format whenever a subscriber session ends. By this option ACS creates an EDR with the specified format name for every flow that has had any activity since last EDR was created for the flow on session end.
timeout
Creates an EDR with the specified EDR format whenever a flow ends due to a timeout condition.
Usage Guidelines
Use this command to enable or disable the capturing of EDRs based on flow end condition.
active-charging service rulebase flow limit-across-applications
This command allows you to limit the total number of simultaneous flows per Subscriber/APN sent to a rulebase regardless of the flow type, or limit flows based on the protocol type under the Session Control feature.
Command Mode
Syntax
flow limit-across-applications { limit | non-tcp non_tcp_limit | tcp tcp_limit }
Specify the maximum limit of non-TCP type flows.
tcp tcp_limit
Specify the maximum limit of TCP flows.
limit
Specify the maximum limit.
Usage Guidelines
Use this command to limit the total number of flows allowed per subscriber for a rulebase regardless of flow type, or limit flows based on the protocol non-TCP (connection-less) or TCP (connection-oriented).
Example
The following command configures the maximum number of 200000 flows for the rulebase:
flow limit-across-applications 200000
active-charging service rulebase ip
Configures IP parameters related to user session.
Command Mode
Syntax
ip reassembly-timeout reassembly_timeout
Specify the maximum duration for which ip packet fragments are retained, in milliseconds.
Must be an integer in the range of 100-30000.
Default Value: 5000.
Usage Guidelines
Use this command to configure IP parameters related to user session.
active-charging service rulebase p2p
Enables or disables the P2P analyzer to detect peer-to-peer (P2P) applications.
Command Mode
Syntax
p2p dynamic-flow-detection
Enables dynamic-flow detection, allowing the P2P analyzer to detect the P2P applications configured for the ACS.
Usage Guidelines
Use this command to enable/disable the P2P analyzer to detect peer-to-peer (P2P) applications.
active-charging service rulebase post-processing priority
Configures the post-processing priority of a specific ruledef in the current rulebase.
Command Mode
Syntax
post-processing priority post_processing_priority
Specify the post-processing priority.
Must be an integer in the range of 1-65535.
Usage Guidelines
Use this command to configure the post-processing priority of a specific ruledef in the current rulebase.
Example
The following command configures the ruledef named test_ruledef with a priority of 10:
post-processing priority 10
active-charging service rulebase post-processing priority group-of-ruledefs
Configures group-of-ruledefs parameters.
Command Mode
Syntax
post-processing priority post_processing_priority group-of-ruledefs group_of_ruledefs_name charging-action charging_action [ description description ]
Must be a string of 1-63 characters.
Specify an optional description for this configuration.
Usage Guidelines
Use this command to configure group-of-ruledefs parameters.
active-charging service rulebase post-processing priority ruledef
Assigns ruledefs to the current rulebase.
Command Mode
Syntax
post-processing priority post_processing_priority ruledef ruledef_name charging-action charging_action_name [ description description ]
Usage Guidelines
Use this command to assign ruledefs to the current rulebase.
active-charging service rulebase route priority
Configures the priority of the route in the rulebase.
Command Mode
Syntax
priority route_priority
Specify the route priority.
Usage Guidelines
Configures the routing of packets to protocol analyzers. Use this command to configure the priority of the route in the rulebase.
active-charging service rulebase route priority ruledef
Configures the ruledef to evaluate packets to determine analyzer.
Command Mode
Syntax
route priority route_priority ruledef ruledef_name analyzer analyzer
analyzer analyzer
Specify the analyzer for the ruledef.
Must be one of the following:
  • dns : Route to DNS protocol.
  • file-transfer : Route to file analyzer.
  • ftp-control : Route to FTP Control protocol.
  • ftp-data : Route to FTP Data protocol.
  • h323 : Route to H323 protocol.
  • http : Route to HTTP protocol.
  • imap : Route to IMAP protocol analyzer.
  • mipv6 : Route to MIPv6 protocol analyzer.
  • mms : Route to MMS protocol analyzer.
  • pop3 : Route to POP3 protocol analyzer.
  • pptp : Route to PPTP protocol analyzer.
  • radius : Route to light-weight RADIUS protocol analyzer.
  • rtcp : Route to RTCP protocol analyzer.
  • rtp : Route to RTP protocol analyzer.
  • rtsp : Route to RTSP protocol analyzer.
  • sdp : Route to SDP protocol analyzer.
  • secure-http : Route to secure HTTP protocol analyzer.
  • sip : Route to SIP protocol analyzer.
  • smtp : Route to SMTP protocol analyzer.
  • tftp : Route to TFTP protocol analyzer.
  • wsp-connection-less : Route to WSP connection-less protocol analyzer.
  • wsp-connection-oriented : Route to WSP connection-oriented protocol analyzer.
Specify to add a description to the rule and action in the saved configuration file for later reference.
Must be a string of 1-31 characters.
Usage Guidelines
Use this command to assign a ruledef to a rulebase,
active-charging service rulebase rtp
Configures the Real Time Streaming Protocol (RTSP) and Session Description Protocol (SDP) analyzers to detect the start/stop of RTP and RTCP flows.
Command Mode
Syntax
rtp dynamic-flow-detection
Specify to enable dynamic RTP/RTCP flow detection.
Usage Guidelines
Use this command to enable the RTSP and SDP analyzers to detect the start/stop of RTP and RTCP flows. This command is used in conjunction with the route priority command.
active-charging service rulebase tcp
Configures TCP window size checking.
Command Mode
Syntax
tcp check-window-size
check-window-size
Specify to enable TCP window-size checking.
Usage Guidelines
Use this command to enable/disable TCP window-size check for packets out of TCP window.
Example
The following command enables TCP window-size check:
active-charging service rulebase tcp mss
Configures the TCP Maximum Segment Size (MSS) in TCP SYN packets.
Command Mode
Syntax
tcp mss tcp_mss { [ add-if-not-present ] [ limit-if-present ] }
add-if-not-present
Specify to add the TCP MSS if not present in the packet.
limit-if-present
Specify to limit the TCP MSS if present in the packet.
mss tcp_mss
Specify the TCP MSS.
Must be an integer in the range of 496-65535.
Usage Guidelines
Using this command, TCP MSS can be limited if already present in the TCP SYN packets. If there are no errors detected in IP header/TCP mandatory header and there are no memory allocation failures, TCP optional header is parsed. If TCP MSS is present in the optional header and its value is greater than the configured MSS value, the value present in the TCP packet is replaced with the configured one.
Example
The following command limits the TCP maximum segment size to 3000, and if not present adds it to the packets:
tcp mss 3000 limit-if-present add-if-not-present
active-charging service rulebase tcp packets-out-of-order
Configures processing of TCP packets that are out of order, while waiting for the earlier packet(s) to arrive.
Command Mode
Syntax
tcp packets-out-of-order timeout timeout_duration
Specify the timeout duration for re-assembly of TCP out-of-order packets in milliseconds.
Usage Guidelines
Use this command to configure how to process TCP packets that are out of order, while waiting for the earlier packet(s) to arrive.
Example
The following command sets the timeout timer to 10000 milliseconds:
tcp packets-out-of-order timeout 10000
active-charging service rulebase tcp packets-out-of-order transmit
Configures the TCP out-of-order segment behavior after buffering a copy.
Command Mode
Syntax
tcp packets-out-of-order transmit transmit_behavior
Specify the TCP out-of-order segment behavior after buffering a copy.
  • after-reordering : Specify to deliver the TCP out-of-order segments in-sequence to the ACS analyzer after all packets are received and successfully reordered. The "after-reordering" option is doing this by buffering out-of-order packets, and only releasing them after the missing out-of-order packets are received (or after OOO timeout). When the missing packet is received, complete deep packet inspection of all the packets and all relevant in-line services is done, and then the last packet is forwarded (as the latest). If reordering is not successful within the specified OOO timeout, all the subsequent received packets in that TCP flow are forwarded without being passed through the analysers (except the L3/L4 analyzer). As a consequence, only L3/L4 rule matching will take place. If memory allocation fails or the received packet is partial retransmitted data, the packet will also be forwarded immediately without being passed through the protocol analyzers, except for the L3/L4 analyzers.
  • immediately : Specify to deliver the TCP out-of-order segments in-sequence to the ACS analyzer after all packets are received and successfully reordered. The "immediately" option is accomplishing this by making a copy of out-of-order packets, and buffering those, while transmitting the original data packets through the outgoing interface immediately. When the missing packet is received, complete deep packet inspection of all the packets and all relevant in-line services is done, and then the last packet is forwarded. If reordering of the buffered packets is not successful within the specified OOO timeout, all the subsequent received packets in that TCP flow are forwarded without being passed through the analysers (except the L3/L4 analyzer). As a consequence only L3/L4 rule matching will take place. If memory allocation fails or the received packet is partial retransmitted data, the packet will also be forwarded immediately without being passed through the protocol analyzers, except for the L3/L4 analysers.
Usage Guidelines
Use this command to configure the TCP out-of-order segment behavior after buffering a copy.
active-charging service rulebase tethering-detection
Enables or disables the Tethering Detection feature for the current rulebase, and specifies the database to use.
Command Mode
Syntax
tethering-detection { application | dns-based | ip-ttl-value ttl_value | max-syn-packet-in-flow max_syn_packets | tethering_database }
application
Specify to perform tethering detection based on App-based method.
dns-based
Specify to perform tethering detection based on DNS-based method.
Specify the number of SYN packets applicable for tethering detection in a flow.
Must be an integer in the range of 1-3.
tethering_database
Specify to perform tethering detection using the specified database.
  • os-db-only : Specify to perform tethering detection using IPv4 and IPv6 OS signature databases.
  • os-ua-db : Specify to perform tethering detection using IPv4 OS, IPv6 OS, and UA signature databases.
  • ua-db-only : Specify to perform tethering detection using only the UA signature database.
Usage Guidelines
Use this command to enable/disable the Tethering Detection feature for a rulebase, and configures the database to use. Tethering Detection can be done for IPv4, IPv6, TCP and UDP flows.
Example
The following command enables the Tethering Detection feature in the rulebase, and specifies to use only the OS database:
tethering-detection os-db-only
active-charging service rulebase url-blacklisting action
Configures URL Blacklisting action.
Command Mode
Syntax
url-blacklisting action { discard | redirect-url redirect_url | terminate-flow | www-reply-code-and-terminate-flow reply_code } [ content-id content_id ]
Specify the content ID, a number assigned to URL Blacklisting.
discard
Specify the URL Blacklisting action as "discard".
Specify the redirect URL/URI, which must be a fully qualified URL/URI.
Must be a string.
terminate-flow
Specify the URL Blacklisting action as "terminate-flow".
Specify the URL Blacklisting action as "terminate-flow action with reply code".
Must be an integer in the range of 400-599.
Usage Guidelines
Enables or disables URL Blacklisting functionality for the current rulebase, and configures the action to be taken when there is a URL match. Use this command to configure the URL Blacklisting action.
active-charging service rulebase url-blacklisting match-method
Configures URL Blacklisting match-method.
Command Mode
Syntax
url-blacklisting match-method match_method
Specify the match method.
  • exact : URL Blacklisting performs an exact match of URL.
  • generic : URL Blacklisting performs generic match of URL.
Usage Guidelines
Use this command to configure the URL Blacklisting match method.
active-charging service ruledef
Configures ACS rule definitions (ruledef).
Command Mode
Syntax
ruledef ruledef_name [ rule-application ruledef_purpose ]
Specify the purpose of the ruledef. When a ruledef is evaluated, if the multi-line-or all-lines command is configured, the logical OR.
  • charging : Specify that the current ruledef is for charging purposes.
  • post-processing : Specify that the current ruledef is for post-processing purposes. This enables processing of packets even if the rule matching for them has been disabled.
  • routing : Specify that the current ruledef is for routing purposes. Up to 256 ruledefs can be defined for routing in an ACS.
Specify name of the ruledef. If the named ruledef does not exist, it is created, and the CLI mode changes to the ACS Ruledef Configuration Mode wherein the ruledef can be configured. If the named ruledef already exists, the CLI mode changes to the ACS Ruledef Configuration Mode for that ruledef.
Must be a string.
Usage Guidelines
Use this command to create/configure an ACS ruledef. A ruledef represents a set of matching conditions across multiple L3 L7 protocol based on protocol fields and state information. Each ruledef can be used across multiple rulebases within the ACS.
Example
The following command creates/configures an ACS ruledef named test1:
ruledef test1
active-charging service ruledef bearer service-3gpp rat-type
Specify RAT type associated with the bearer flow.
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > Ruledef Configuration (config-ruledef-ruledef_name )
Syntax
bearer service-3gpp rat-type operator rat_type
operator
  • != : Does not equal.
  • = : Equals.
rat_type
Specify the RAT type.
  • geran : GSM EDGE Radio Access Network type.
  • utran : UMTS Terrestrial Radio Access Network type.
  • wlan : Wireless LAN type.
Usage Guidelines
Configures rule expression to match Radio Access Technology (RAT) in the bearer flow. Use this command to configure the RAT type associated with the bearer flow.
active-charging service ruledef dns answer-name
Configures ruledef to match DNS answer name.
Command Mode
Syntax
dns answer-name operator value
operator
  • !contains : Does not contains.
  • !ends-with : Does not end with.
  • !starts-with : Does not start with.
  • = : Equals.
  • case-sensitive : Strings will be matched in case-sensitive manner.
  • contains : Contains.
  • ends-with : Ends with.
  • starts-with : Starts with.
value
Specify the value.
Must be a string of 1-127 characters.
Usage Guidelines
Configures ruledef to match answer name in the answer section of DNS response messages.
active-charging service ruledef dns any-match
Configures rule expression to match all packets of the specified protocol.
Command Mode
Syntax
dns any-match operator condition
Syntax
icmpv6 any-match operator condition
Syntax
rtp any-match operator condition
Syntax
rtsp any-match operator condition
Syntax
secure-http any-match operator condition
Syntax
tcp any-match operator condition
Syntax
udp any-match operator condition
Syntax
wsp any-match operator condition
Syntax
wtp any-match operator condition
condition
Specify the condition.
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Use this command to configure rule expression to match all packets of a specified protocol.
Example
The following command defines a rule expression to match all RTP packets:
rtp any-match = TRUE
active-charging service ruledef dns previous-state
Configures rule expression to match previous state of the DNS FSM.
Command Mode
Syntax
dns previous-state operator previous_state
operator
  • = : Equals.
previous_state
Specify the previous state to match.
  • dns-timeout : DNS timeout.
  • init : Init.
  • req-sent : Request sent.
  • resp-error : Response error.
  • resp-success : Response success.
Usage Guidelines
Use this command to define rule expressions to match previous state of DNS FSM.
Example
The following command defines a rule expression to match the DNS FSM previous state "req-sent":
dns previous-state = req-sent
active-charging service ruledef dns query-name
Configures rule expression to match query name in DNS request messages.
Command Mode
Syntax
dns query-name [ case-sensitive ] operator query_name
operator
  • !contains : Does not contain.
  • = : Equals.
query_name
Specify the query name to match.
Usage Guidelines
Use this command to define rule expressions to match query name in DNS request messages.
Example
The following command defines a rule expression to match DNS query name "test":
dns query-name = test
active-charging service ruledef dns query-type
Configures rule expression to match the query type in the DNS request messages.
Command Mode
Syntax
dns query-type operator query_type
operator
  • = : Equals.
query_type
Specify the DNS query type to match.
  • a : Support query-type A.
  • aaaa : Support query-type AAAA.
  • cname : Support query-type CNAME.
  • ns : Support query-type NS.
  • null : Support query-type NULL.
  • ptr : Support query-type PTR.
  • srv : Support query-type SRV.
  • txt : Support query-type TXT.
Usage Guidelines
Use this command to define rule expressions to match the query type in the DNS request messages.
Example
The following command defines a rule expression to match the DNS query type "txt":
dns query-type = txt
active-charging service ruledef dns return-code
Configures rule expression to match response code in DNS response messages.
Command Mode
Syntax
dns return-code operator return_code
operator
  • = : Equals.
return_code
Specify the response code to match.
  • format-error : DNS response: Format Error.
  • name-error : DNS response: Name Error.
  • no-error : DNS response: No Error.
  • not-implemented : DNS response: Name server does not support the requested query.
  • refused : DNS response: Refused to perform specified operation.
  • server-failure : DNS response: Server Failure.
Usage Guidelines
Use this command to define rule expressions to match response code in DNS response messages.
Example
The following command defines a rule expression to match a DNS response code "refused":
dns return-code = refused
active-charging service ruledef dns state
Configures rule expressions to match current state of DNS FSM.
Command Mode
Syntax
dns state operator current_state
current_state
Specify the state to match.
  • dns-timeout
  • init
  • req-sent
  • resp-error
  • resp-success
operator
  • = : Equals.
Usage Guidelines
Use this command to define rule expressions to match DNS FSM current state.
Example
The following command defines a rule expression to match DNS FSM current state of "req-sent":
dns state = req-sent
active-charging service ruledef dns tid
Configures rule expressions to match Transaction Identifier (TID) field in DNS messages.
Command Mode
Syntax
dns tid operator tid_value
operator
  • >= : Greater than or equals.
  • <= : Lesser than or equals.
  • = : Equals.
tid_value
Specify the DNS TID field value to match.
Must be an integer in the range of 0-65535.
Usage Guidelines
Use this command to define rule expressions to match a TID field of DNS messages.
Example
The following command defines a rule expression to match DNS TID field value of "test":
dns tid = test
active-charging service ruledef http content type
Configures rule expression to match value in HTTP Content-Type entity-header field.
Syntax
http content type [ case-sensitive ] operator content_type
case-sensitive
Specify the rule expression must be case-sensitive. By default, rule expressions are not case-sensitive.
content_type
Specify the content type to match.
operator
  • = : Equals.
Usage Guidelines
Use this command to configure rule expressions to match HTTP content type.
active-charging service ruledef http host
Configures rule expression to match value in HTTP Host Request header field.
Command Mode
Syntax
http host [ case-sensitive ] operator host_name
case-sensitive
host_name
Specify the host name to match.
operator
  • = : Equals.
  • regex : Regular expression.
Usage Guidelines
Use this command to define rule expressions to match value in HTTP Host request-header field.
Example
The following command defines a rule expression to match "host1" in HTTP Host request-header field:
http host = host1
active-charging service ruledef http referer
Configures rule expression to match the value in the HTTP Referer request-header field.
Command Mode
Syntax
http referer [ case-sensitive ] operator referer_name
case-sensitive
operator
  • !present : Not present.
  • = : Equals.
referer_name
Specify the HTTP referer name to match.
Usage Guidelines
Use this command to define rule expressions to match value in HTTP Referer request-header field. This feature allows an operator to collect or track all URLs visited during a particular subscriber session. These URLs include the entire string of visited URLs, including all referral links. This information is output in an Event Data Record (EDR) format to support reporting or billing functions.
Example
The following command defines a rule expression to match the HTTP referer "cricket.espn.com":
http referer = cricket.espn.com
active-charging service ruledef http url
Configures rule expression to match HTTP URL.
Command Mode
Syntax
http url [ case-sensitive ] operator url
operator
  • !present : Does not present.
  • = : Equals.
  • case-sensitive : Is case sensitive.
url
Specify the HTTP URL to match.
Usage Guidelines
Use this command to define rule expressions to match HTTP URL.
active-charging service ruledef http user-agent
Configures rule expressions to match the User-Agent.
Command Mode
Syntax
http user-agent [ case-sensitive ] operator user_agent_value
case-sensitive
operator
  • = : Equal.
  • present : Present.
user_agent_value
Specify the HTTP user agent value to match.
Usage Guidelines
Use this command to configure rule expressions to match user agent.
active-charging service ruledef icmpv6 any-match
Command Mode
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Example
active-charging service ruledef ip any-match
Configures rule expressions to match all IPv4/IPv6 packets.
Syntax
ip any-match operator condition
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Use this command to define rule expressions to match IPv4/IPv6 packets.
Example
The following command defines a rule expression to match IPv4/IPv6 packets:
ip any-match = TRUE
active-charging service ruledef ip dst-address
Configures rule expressions to match IP destination address field within IP headers.
Command Mode
Syntax
ip dst-address operator { ip_address | ip_prefix_length | address-group ipv6_address | host-pool host_pool_name }
address-group ipv6_address_group_name
Specify a group of IPv6 addresses configured with wildcard input and/or specialized range input. Input is accepted as a string and parsed. Multiple wildcard characters can be accepted as input and only one 2-byte range input will be accepted. Both wildcard character input and 2-byte range input can be configured together within an IPv6 address. For example, 2607:7700:*:[2020-3040]::ce1d:b083/128. * is a wildcard input. [2020-3040] is a 2-byte specialized range input.
Must be a string of 1-56 characters.
Specify name of the host pool.
ip-address-prefix prefix
Specify the IP address prefix.
-Or-
-Or-
Must be a string in the ipv4-address pattern. For information on the ipv4-address pattern, see the Input Pattern Types chapter.
-Or-
Must be a string in the ipv6-address pattern. For information on the ipv6-address pattern, see the Input Pattern Types chapter.
ip_address
Specify the destination IP address.
  • dst-address : DST address.
operator
  • !range : Not in the range.
  • >= : Greater than or equal to.
  • <= : Lesser than or equal to.
  • = : Equals.
  • range : In the range.
Usage Guidelines
Use this command to define rule expressions to match the IP destination address field within IP headers.
Example
The following command defines a rule expression to match user traffic based on the IPv4 destination address 10.1.1.1:
ip dst-address = 10.1.1.1
active-charging service ruledef ip protocol
Configures rule expression to match based on protocol being transported by IP packet.
Command Mode
Syntax
operator
  • = : Equals.
protocol
Specify the protocol.
-Or-
  • ah
  • esp
  • gre
  • icmp
  • icmpv6
  • tcp
  • udp
Usage Guidelines
Use this command to define rule expressions to match based on protocol being transported by IP packet.
active-charging service ruledef ip server-ip-addr
Configure the server's IP address.
Command Mode
Syntax
ip server-ip-address operator { { { ipv4_address | ipv6_address } ip-address-prefix prefix | address-group ipv6_address_group_name } | host-pool host_pool_name }
-Or-
-Or-
-Or-
Specify IP address of the server.
  • server-ip-address : server-ip-address.
operator
  • = : Equals.
Usage Guidelines
Use this command to configure the server's IP address.
active-charging service ruledef ip uplink
Configures rule expression to match IP uplink packets.
Command Mode
Syntax
ip uplink operator condition
condition
Specify the condition to match.
  • FALSE : Not analyzed.
  • TRUE : Analyzed.
operator
  • = : Equals.
Usage Guidelines
Use this command to configure matching IP uplink packets based on condition.
active-charging service ruledef ip version
Configures rule expression to match based on IP version.
Command Mode
Syntax
ip version operator ip_version
ip_version
  • ipv4
  • ipv6
operator
  • = : Equals.
Usage Guidelines
Use this command to configure rule expression to match based on the IP version.
active-charging service ruledef multi-line-or
This command applies the OR operator to all lines in the current ruledef.
Command Mode
Syntax
all-lines
Applies the OR operator to all lines in the current ruledef.
Usage Guidelines
When a ruledef is evaluated, if the multi-line-or all-lines command is configured, the logical OR operator is applied to all the rule expressions in the ruledef to decide if the ruledef matches or not. If the multi-line-or all-lines command is not configured, the logical AND operator is applied to all the rule expressions.
active-charging service ruledef p2p
This command allows you to define rule expressions to match P2P protocol. This command must be used for charging purposes. It must not be used for detection purposes.
Command Mode
Syntax
p2p set-app-proto app_protocol_name
Specify name of the custom-defined protocol (CDP). CDP name specifies the name of the custom defined protocol (CDP) for TLS/SSL flows, QUIC flows or any app-identifier matching the ruledef. If the flow/packet matches the rule, the CDP name specified in the ruledef will be taken and the flow will be marked as CDP. If no CDP is configured in the rule, then the flow will be treated as TLS/SSL or QUIC flow.
Must be a string of 1-19 characters.
Usage Guidelines
Use this command to define rule expressions to detect P2P protocols for charging purposes. For detection purposes use the "p2p-detection protocol" command in the ACS Configuration Mode.
active-charging service ruledef p2p app-identifier
Configures application identifiers populated from the plugin and mark the matching flows to a custom-defined protocol (CDP) name.
Command Mode
Syntax
p2p app-identifier app_type operator app_identifier
app_identifier
Specify the app identifier.
app_type
Specify the application type.
  • quic-sni : Specify the QUIC Server Name Indication (SNI) field value.
  • tls-cname : Specify the common name in the Server Hello message of TLS. SSL renegotiation is supported for the flows that are marked using "tls-cname" rules.
  • tls-sni : Specify the TLS/SSL Server Name Indication (SNI) field.
operator
  • != : Not equals.
  • = : Equals.
Usage Guidelines
Use this command to configure application identifiers populated from the plugin and mark the matching flows to a custom-defined protocol (CDP) name. The SNI ruledef supports multi-line-or all-lines or default multi-line-and rule lines. The rule lines configured with "!=" operator will not be optimized.
Example
The following command configures the QUIC SNI app-identifier that is set to fb.com:
p2p app-identifier quic-sni = fb.com
active-charging service ruledef p2p protocol
Configures the protocol to match parameter.
Command Mode
Syntax
p2p protocol operator p2p_protocol
operator
  • = : Equals.
p2p_protocol
  • 8tracks : P2P detection protocol for "8tracks" application.
  • actionvoip : P2P detection protocol for "actionvoip" application.
  • actsync : P2P detection protocol for "actsync" application.
  • adobeconnect : P2P detection protocol for "adobeconnect" application.
  • aimini : P2P detection protocol for "aimini" application.
  • amazoncloud : P2P detection protocol for "amazoncloud" application.
  • amazonmusic : P2P detection protocol for "amazonmusic" application.
  • amazonvideo : P2P detection protocol for "amazonvideo" application.
  • antsp2p : P2P detection protocol for "antsp2p" application.
  • apple-push : P2P detection protocol for "apple-push" application.
  • apple-store : P2P detection protocol for "apple-store" application.
  • applejuice : P2P detection protocol for "applejuice" application.
  • applemaps : P2P detection protocol for "applemaps" application.
  • ares : P2P detection protocol for "ares" application.
  • armagettron : P2P detection protocol for "armagettron" application.
  • avi : P2P detection protocol for "avi" application.
  • badoo : P2P detection protocol for "badoo" application.
  • baidumovie : P2P detection protocol for "baidumovie" application.
  • battlefld : P2P detection protocol for "battlefld" application.
  • bbm : P2P detection protocol for "bbm" application.
  • beatport : P2P detection protocol for "beatport" application.
  • bitcasa : P2P detection protocol for "bitcasa" application.
  • bittorrent-sync : P2P detection protocol for "bittorrent-sync" application.
  • bittorrent : P2P detection protocol for "bittorrent" application.
  • blackberry-store : P2P detection protocol for "blackberry-store" application.
  • blackberry : P2P detection protocol for "blackberry" application.
  • blackdialer : P2P detection protocol for "blackdialer" application.
  • box : P2P detection protocol for "box" application.
  • callofduty : P2P detection protocol for "callofduty" application.
  • chikka : P2P detection protocol for "chikka" application.
  • cisco-jabber : P2P detection protocol for "cisco-jabber" application.
  • citrix : P2P detection protocol for "citrix" application.
  • clubbox : P2P detection protocol for "clubbox" application.
  • clubpenguin : P2P detection protocol for "clubpenguin" application.
  • comodounite : P2P detection protocol for "comodounite" application.
  • crackle : P2P detection protocol for "crackle" application.
  • crossfire : P2P detection protocol for "crossfire" application.
  • curiosity-stream : P2P detection protocol for "curiosity-stream" application.
  • cyberghost : P2P detection protocol for "cyberghost" application.
  • ddlink : P2P detection protocol for "ddlink" application.
  • didi : P2P detection protocol for "didi" application.
  • directconnect : P2P detection protocol for "directconnect" application.
  • dish-anywhere : P2P detection protocol for "dish-anywhere" application.
  • dns-tunneling : P2P detection protocol for "dns-tunneling" application.
  • dofus : P2P detection protocol for "dofus" application.
  • dropbox : P2P detection protocol for "dropbox" application.
  • ebuddy : P2P detection protocol for "ebuddy" application.
  • edonkey : P2P detection protocol for "edonkey" application.
  • espn : P2P detection protocol for "espn" application.
  • facebook : P2P detection protocol for "facebook" application.
  • facetime : P2P detection protocol for "facetime" application.
  • fandor : P2P detection protocol for "fandor" application.
  • fasttrack : P2P detection protocol for "fasttrack" application.
  • feidian : P2P detection protocol for "feidian" application.
  • ficall : P2P detection protocol for "ficall" application.
  • fiesta : P2P detection protocol for "fiesta" application.
  • filetopia : P2P detection protocol for "filetopia" application.
  • flash : P2P detection protocol for "flash" application.
  • flickr : P2P detection protocol for "flickr" application.
  • florensia : P2P detection protocol for "florensia" application.
  • foursquare : P2P detection protocol for "foursquare" application.
  • fox-sports : P2P detection protocol for "fox-sports" application.
  • freenet : P2P detection protocol for "freenet" application.
  • friendster : P2P detection protocol for "friendster" application.
  • fring : P2P detection protocol for "fring" application.
  • fubotv : P2P detection protocol for "fubotv" application.
  • funshion : P2P detection protocol for "funshion" application.
  • gadugadu : P2P detection protocol for "gadugadu" application.
  • gamekit : P2P detection protocol for "gamekit" application.
  • gmail : P2P detection protocol for "gmail" application.
  • gnutella : P2P detection protocol for "gnutella" application.
  • go90 : P2P detection protocol for "go90" application.
  • goober : P2P detection protocol for "goober" application.
  • google-music : P2P detection protocol for "google-music" application.
  • google-push : P2P detection protocol for "google-push" application.
  • google : P2P detection protocol for "google" application.
  • googleplay : P2P detection protocol for "googleplay" application.
  • googleplus : P2P detection protocol for "googleplus" application.
  • gotomeeting : P2P detection protocol for "gotomeeting" application.
  • gtalk : P2P detection protocol for "gtalk" application.
  • guildwars : P2P detection protocol for "guildwars" application.
  • halflife2 : P2P detection protocol for "halflife2" application.
  • hamachivpn : P2P detection protocol for "hamachivpn" application.
  • hbogo : P2P detection protocol for "hbogo" application.
  • hbonow : P2P detection protocol for "hbonow" application.
  • heytell : P2P detection protocol for "heytell" application.
  • hgtv : P2P detection protocol for "hgtv" application.
  • hike-messenger : P2P detection protocol for "hike-messenger" application.
  • hls : P2P detection protocol for "hls" application.
  • hotspotvpn : P2P detection protocol for "hotspotvpn" application.
  • http : P2P detection protocol for "http" application.
  • hulu : P2P detection protocol for "hulu" application.
  • hyves : P2P detection protocol for "hyves" application.
  • iax : P2P detection protocol for "iax" application.
  • icall : P2P detection protocol for "icall" application.
  • icecast : P2P detection protocol for "icecast" application.
  • icloud : P2P detection protocol for "icloud" application.
  • idrive : P2P detection protocol for "idrive" application.
  • igo : P2P detection protocol for "igo" application.
  • iheartradio : P2P detection protocol for "iheartradio" application.
  • imesh : P2P detection protocol for "imesh" application.
  • imessage : P2P detection protocol for "imessage" application.
  • imgur : P2P detection protocol for "imgur" application.
  • imo : P2P detection protocol for "imo" application.
  • implus : P2P detection protocol for "implus" application.
  • instagram : P2P detection protocol for "instagram" application.
  • iplayer : P2P detection protocol for "iplayer" application.
  • iptv : P2P detection protocol for "iptv" application.
  • irc : P2P detection protocol for "irc" application.
  • isakmp : P2P detection protocol for "isakmp" application.
  • iskoot : P2P detection protocol for "iskoot" application.
  • itunes : P2P detection protocol for "itunes" application.
  • jabber : P2P detection protocol for "jabber" application.
  • jap : P2P detection protocol for "jap" application.
  • jumblo : P2P detection protocol for "jumblo" application.
  • kakaotalk : P2P detection protocol for "kakaotalk" application.
  • kidoodle : P2P detection protocol for "kidoodle" application.
  • kik-messenger : P2P detection protocol for "kik-messenger" application.
  • kontiki : P2P detection protocol for "kontiki" application.
  • kugou : P2P detection protocol for "kugou" application.
  • kuro : P2P detection protocol for "kuro" application.
  • linkedin : P2P detection protocol for "linkedin" application.
  • lync : P2P detection protocol for "lync" application.
  • magicjack : P2P detection protocol for "magicjack" application.
  • manolito : P2P detection protocol for "manolito" application.
  • mapfactor : P2P detection protocol for "mapfactor" application.
  • mapi : P2P detection protocol for "mapi" application.
  • maplestory : P2P detection protocol for "maplestory" application.
  • meebo : P2P detection protocol for "meebo" application.
  • mega : P2P detection protocol for "mega" application.
  • mgcp : P2P detection protocol for "mgcp" application.
  • mig33 : P2P detection protocol for "mig33" application.
  • mlb : P2P detection protocol for "mlb" application.
  • mojo : P2P detection protocol for "mojo" application.
  • monkey3 : P2P detection protocol for "monkey3" application.
  • mozy : P2P detection protocol for "mozy" application.
  • msn : P2P detection protocol for "msn" application.
  • msrp : P2P detection protocol for "msrp" application.
  • mute : P2P detection protocol for "mute" application.
  • mypeople : P2P detection protocol for "mypeople" application.
  • myspace : P2P detection protocol for "myspace" application.
  • nateontalk : P2P detection protocol for "nateontalk" application.
  • naverline : P2P detection protocol for "naverline" application.
  • navigon : P2P detection protocol for "navigon" application.
  • nbc-sports : P2P detection protocol for "nbc-sports" application.
  • netflix : P2P detection protocol for "netflix" application.
  • netmotion : P2P detection protocol for "netmotion" application.
  • newsy : P2P detection protocol for "newsy" application.
  • nimbuzz : P2P detection protocol for "nimbuzz" application.
  • nokia-store : P2P detection protocol for "nokia-store" application.
  • octoshape : P2P detection protocol for "octoshape" application.
  • odnoklassniki : P2P detection protocol for "odnoklassniki" application.
  • off : P2P detection protocol for "off" application.
  • ogg : P2P detection protocol for "ogg" application.
  • oist : P2P detection protocol for "oist" application.
  • oovoo : P2P detection protocol for "oovoo" application.
  • opendrive : P2P detection protocol for "opendrive" application.
  • openft : P2P detection protocol for "openft" application.
  • openvpn : P2P detection protocol for "openvpn" application.
  • operamini : P2P detection protocol for "operamini" application.
  • orb : P2P detection protocol for "orb" application.
  • oscar : P2P detection protocol for "oscar" application.
  • outlook : P2P detection protocol for "outlook" application.
  • paltalk : P2P detection protocol for "paltalk" application.
  • pando : P2P detection protocol for "pando" application.
  • pandora : P2P detection protocol for "pandora" application.
  • path : P2P detection protocol for "path" application.
  • pcanywhere : P2P detection protocol for "pcanywhere" application.
  • periscope : P2P detection protocol for "periscope" application.
  • pinterest : P2P detection protocol for "pinterest" application.
  • plingm : P2P detection protocol for "plingm" application.
  • poco : P2P detection protocol for "poco" application.
  • popo : P2P detection protocol for "popo" application.
  • pplive : P2P detection protocol for "pplive" application.
  • ppstream : P2P detection protocol for "ppstream" application.
  • ps3 : P2P detection protocol for "ps3" application.
  • qq : P2P detection protocol for "qq" application.
  • qqgame : P2P detection protocol for "qqgame" application.
  • qqlive : P2P detection protocol for "qqlive" application.
  • quake : P2P detection protocol for "quake" application.
  • quic : P2P detection protocol for "quic" application.
  • quicktime : P2P detection protocol for "quicktime" application.
  • radio-paradise : P2P detection protocol for "radio-paradise" application.
  • rdp : P2P detection protocol for "rdp" application.
  • rdt : P2P detection protocol for "rdt" application.
  • regram : P2P detection protocol for "regram" application.
  • rfactor : P2P detection protocol for "rfactor" application.
  • rhapsody : P2P detection protocol for "rhapsody" application.
  • rmstream : P2P detection protocol for "rmstream" application.
  • rodi : P2P detection protocol for "rodi" application.
  • rynga : P2P detection protocol for "rynga" application.
  • samsung-store : P2P detection protocol for "samsung-store" application.
  • scydo : P2P detection protocol for "scydo" application.
  • secondlife : P2P detection protocol for "secondlife" application.
  • shoutcast : P2P detection protocol for "shoutcast" application.
  • showtime : P2P detection protocol for "showtime" application.
  • silverlight : P2P detection protocol for "silverlight" application.
  • siri : P2P detection protocol for "siri" application.
  • skinny : P2P detection protocol for "skinny" application.
  • skydrive : P2P detection protocol for "skydrive" application.
  • skype : P2P detection protocol for "Skype" application.
  • slacker-radio : P2P detection protocol for "slacker-radio" application.
  • slingbox : P2P detection protocol for "slingbox" application.
  • slingtv : P2P detection protocol for "slingtv" application.
  • smartvoip : P2P detection protocol for "smartvoip" application.
  • snapchat : P2P detection protocol for "snapchat" application.
  • softether : P2P detection protocol for "softether" application.
  • sopcast : P2P detection protocol for "sopcast" application.
  • soribada : P2P detection protocol for "soribada" application.
  • soulseek : P2P detection protocol for "soulseek" application.
  • soundcloud : P2P detection protocol for "soundcloud" application.
  • spdy : P2P detection protocol for "spdy" application.
  • speedtest : P2P detection protocol for "speedtest" application.
  • splashfighter : P2P detection protocol for "splashfighter" application.
  • spotify : P2P detection protocol for "spotify" application.
  • ssdp : P2P detection protocol for "ssdp" application.
  • ssl : P2P detection protocol for "ssl" application.
  • starz : P2P detection protocol for "starz" application.
  • stealthnet : P2P detection protocol for "stealthnet" application.
  • steam : P2P detection protocol for "steam" application.
  • stun : P2P detection protocol for "stun" application.
  • sudaphone : P2P detection protocol for "sudaphone" application.
  • svtplay : P2P detection protocol for "svtplay" application.
  • tagged : P2P detection protocol for "tagged" application.
  • talkatone : P2P detection protocol for "talkatone" application.
  • tango : P2P detection protocol for "tango" application.
  • teamspeak : P2P detection protocol for "teamspeak" application.
  • teamviewer : P2P detection protocol for "teamviewer" application.
  • telegram : P2P detection protocol for "telegram" application.
  • thunder : P2P detection protocol for "thunder" application.
  • thunderhs : P2P detection protocol for "thunderhs" application.
  • tmo-tv : P2P detection protocol for "tmo-tv" application.
  • tor : P2P detection protocol for "tor" application.
  • truecaller : P2P detection protocol for "truecaller" application.
  • truphone : P2P detection protocol for "truphone" application.
  • tumblr : P2P detection protocol for "tumblr" application.
  • tunein-radio : P2P detection protocol for "tunein-radio" application.
  • tunnelvoice : P2P detection protocol for "tunnelvoice" application.
  • tvants : P2P detection protocol for "tvants" application.
  • tvuplayer : P2P detection protocol for "tvuplayer" application.
  • twitch : P2P detection protocol for "twitch" application.
  • twitter : P2P detection protocol for "twitter" application.
  • ultrabac : P2P detection protocol for "ultrabac" application.
  • ultrasurf : P2P detection protocol for "ultrasurf" application.
  • univision : P2P detection protocol for "univision" application.
  • upc-phone : P2P detection protocol for "upc-phone" application.
  • usenet : P2P detection protocol for "usenet" application.
  • ustream : P2P detection protocol for "ustream" application.
  • uusee : P2P detection protocol for "uusee" application.
  • vchat : P2P detection protocol for "vchat" application.
  • veohtv : P2P detection protocol for "veohtv" application.
  • vessel : P2P detection protocol for "vessel" application.
  • vevo : P2P detection protocol for "vevo" application.
  • viber : P2P detection protocol for "viber" application.
  • vine : P2P detection protocol for "vine" application.
  • voipdiscount : P2P detection protocol for "voipdiscount" application.
  • vopium : P2P detection protocol for "vopium" application.
  • voxer : P2P detection protocol for "voxer" application.
  • vpnx : P2P detection protocol for "vpnx" application.
  • vtok : P2P detection protocol for "vtok" application.
  • vtun : P2P detection protocol for "vtun" application.
  • vudu : P2P detection protocol for "vudu" application.
  • warcft3 : P2P detection protocol for "warcft3" application.
  • waze : P2P detection protocol for "waze" application.
  • webex : P2P detection protocol for "webex" application.
  • wechat : P2P detection protocol for "wechat" application.
  • weibo : P2P detection protocol for "weibo" application.
  • whatsapp : P2P detection protocol for "whatsapp" application.
  • wii : P2P detection protocol for "wii" application.
  • windows-azure : P2P detection protocol for "windows-azure" application.
  • windows-store : P2P detection protocol for "windows-store" application.
  • winmx : P2P detection protocol for "winmx" application.
  • winny : P2P detection protocol for "winny" application.
  • wmstream : P2P detection protocol for "wmstream" application.
  • wofkungfu : P2P detection protocol for "wofkungfu" application.
  • wofwarcraft : P2P detection protocol for "wofwarcraft" application.
  • wuala : P2P detection protocol for "wuala" application.
  • wwe : P2P detection protocol for "wwe" application.
  • xbox : P2P detection protocol for "xbox" application.
  • xdcc : P2P detection protocol for "xdcc" application.
  • xing : P2P detection protocol for "xing" application.
  • yahoo : P2P detection protocol for "yahoo" application.
  • yahoomail : P2P detection protocol for "yahoomail" application.
  • youku : P2P detection protocol for "youku" application.
  • yourfreetunnel : P2P detection protocol for "yourfreetunnel" application.
  • youtube : P2P detection protocol for "youtube" application.
  • zattoo : P2P detection protocol for "zattoo" application.
Usage Guidelines
Use this command to specify the protocol to match.
active-charging service ruledef p2p traffic-type
Configures rule expression to match the traffic type.
Command Mode
Syntax
p2p traffic-type operator traffic_type
operator
Specify how to match.
  • = : Equals.
traffic_type
Specify the traffic type to match.
  • ads
  • audio
  • file-transfer
  • im
  • streaming-audio
  • streaming-video
  • tunnel
  • unclassified
  • video
  • voipout
Usage Guidelines
Use this command to configure the system to detect voice or non-voice P2P traffic. When the detection of a protocol is enabled then the detection of sub-type is enabled by default.
Example
The following command configures the system to detect video traffic:
p2p traffic-type = video
active-charging service ruledef rtp any-match
Command Mode
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Example
active-charging service ruledef rtsp any-match
Command Mode
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Example
active-charging service ruledef secure-http any-match
Command Mode
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Example
active-charging service ruledef secure-http uplink
Configures rule expression to match HTTPS uplink (subscriber to network) packets.
Command Mode
Syntax
secure-http uplink operator condition
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Use this command to specify the HTTPS uplink packets.
active-charging service ruledef tcp any-match
Command Mode
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Example
active-charging service ruledef tcp either-port with-portMap-range
Configures port selection with port map range.
Command Mode
Syntax
tcp either-port operator port-map port_map_name
Syntax
udp either-port operator port-map port_map_name
Specify name of the port map.
operator
  • !range : Not in the range of.
  • range : In the range of.
Usage Guidelines
Use this command to configure with port map range.
active-charging service ruledef tcp either-port with-range
Configures port configuration with range.
Command Mode
Syntax
tcp either-port operator start_range to end_range
Syntax
udp either-port operator start_range to end_range
to
Specify until node.
  • to
end_range
Specify the end range.
operator
start_range
Specify the start range.
Usage Guidelines
Use this command to configure port configuration with range.
active-charging service ruledef tcp either-port without-range
Configures port configuration without range.
Command Mode
Syntax
tcp either-port operator port port_number
Syntax
udp either-port operator port port_number
port port_number
Specify the port number.
operator
  • = : Equals.
Usage Guidelines
Use this command to configure port configuration without range.
active-charging service ruledef tcp flag
Configures rule expression to match bit within the Flag field of TCP headers.
Command Mode
Syntax
tcp flag operator flag
flag
Specify the flag to match.
  • ack
  • fin
  • push
  • reset
  • sync
operator
  • = : Equals.
Usage Guidelines
Use this command to configure rule expression to match bit within the Flag field of TCP headers.
active-charging service ruledef tcp state
Configures rule expression to match current state of TCP connections.
Command Mode
Syntax
tcp state operator current_state
current_state
  • close-wait
  • close
  • closing
  • established
  • fin-wait1
  • fin-wait2
  • last-ack
  • listen
  • syn-received
  • syn-sent
  • time-wait
operator
  • = : Equals.
Usage Guidelines
Use this command to define rule expressions to match a current state of TCP connections.
Example
The following command defines a rule expression to match user traffic based on current state "close":
tcp state = close
active-charging service ruledef tethering-detection
Configures rule expression to match tethered or non-tethered flows.
Command Mode
Syntax
tethering-detection flow_option
flow_option
Specify the flow option.
  • flow-not-tethered : If tethering is not detected on flow.
  • flow-tethered : If tethering is detected on flow.
Usage Guidelines
Use this command to define rule expressions to match tethered/non-tethered flows. Note that in order for the rule containing the tethering-detection configuration to get matched, at least one valid rule line has to be present in it.
Example
The following command defines a rule expression to match tethered flows:
tethering-detection flow-tethered
active-charging service ruledef tethering-detection application
Configures application-based tethering detection.
Command Mode
Syntax
tethering-detection application flow_option
flow_option
Usage Guidelines
Use this command to select flows that were tethered or non-tethered based on application-based detection solution.
active-charging service ruledef tethering-detection dns-based
Configures DNS query pattern based tethering detection.
Command Mode
Syntax
tethering-detection dns-based flow_option
flow_option
Usage Guidelines
Use this command to select flows that were tethered or non-tethered based on DNS-based detection solution.
active-charging service ruledef tethering-detection ip-ttl
Configures IP-TTL based tethering detection.
Command Mode
Syntax
tethering-detection ip-ttl flow_option
flow_option
Usage Guidelines
Use this command to select flows that were tethered or non-tethered as per IP-TTL values.
active-charging service ruledef tethering-detection os-ua
Configures OS-UA based tethering detection.
Command Mode
Syntax
tethering-detection os-ua flow_option
flow_option
Usage Guidelines
Use this command to select flows that were tethered or non-tethered as per OS-UA lookups.
active-charging service ruledef udp any-match
Command Mode
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Example
active-charging service ruledef udp either-port with-portMap-range
Command Mode
Syntax
Syntax
operator
Usage Guidelines
active-charging service ruledef udp either-port with-range
Command Mode
Syntax
Syntax
to
Specify until node.
  • to
end_range
operator
start_range
Usage Guidelines
active-charging service ruledef udp either-port without-range
Command Mode
Syntax
Syntax
port port_number
operator
  • = : Equals.
Usage Guidelines
active-charging service ruledef wsp any-match
Command Mode
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Example
active-charging service ruledef wtp any-match
Command Mode
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
Syntax
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Example
active-charging service ruledef www any-match
Configures rule expression to match all WWW packets. It is true for HTTP, WAP1.x, and WAP2.0 protocols.
Command Mode
Syntax
www any-match operator condition
condition
  • FALSE
  • TRUE
operator
  • = : Equals.
Usage Guidelines
Use this command to define rule expressions to match all WWW packets. This expression is true for HTTP, WAP1.x, and WAP2.0 protocols
Example
The following command defines a rule expression to match all WWW packets:
www any-match = TRUE
active-charging service ruledef www host
Configures rule expression to match the "host name" header field present in HTTP/WSP headers.
Command Mode
Syntax
www host [ case-sensitive ] operator host_name
case-sensitive
host_name
Specify the WWW host name to match.
operator
  • = : Equals.
Usage Guidelines
Use this command to define rule expressions to match the host name header field present in HTTP/WSP headers.
Example
The following command defines a rule expression to match user traffic based on WWW host name "host1":
www host = host1
active-charging service ruledef www url
Configures rule expressions to match URL.
Command Mode
Syntax
www url [ case-sensitive ] operator url
case-sensitive
operator
  • = : Equals.
url
Specify the URL to match.
Usage Guidelines
Use this command to configure the rule expressions to match URLsfor any Web protocol analyzer HTTP, WAP1.X, WAP2.0.
active-charging service url-blacklisting
Enable URL Blacklisting functionality.
Command Mode
Syntax
Specify the match method to look up for URLs in the URL Blacklisting database.
  • exact : URL Blacklisting is performed only on exact match with a URL present in the URL.
  • generic : URL Blacklisting is performed on a generic match with URLs present in the URL Blacklisting database.
Default Value: exact.
Usage Guidelines
Use this command to enable URL Blacklisting functionality.
active-charging service urr-list
Configures ACS URR List configuration.
Command Mode
Syntax
urr-list urr_list_name
urr_list_name
Specify name of the URR list.
Usage Guidelines
Use this command to configure the ACS URR List configuration. Enters the URR List Configuration mode (config-urr-list-<urr_list_name>). This mode allows mapping of URR-ID with Rating Group and Service-ID.
You can configure a maximum of one element with this command.
active-charging service urr-list urr-list-data
Configures URR list data.
Command Mode
Exec > Global Configuration (config) > ACS Configuration (config-service-acs_name ) > URR List Configuration (config-urr-list-urr_list_name )
Syntax
rating-group rating_id urr-id urr_id
rating group rating_id
Specify the rating ID used in prepaid charging.
Must be an integer in the range of 0-2147483647.
urr-id urr_id
Specify the URR identifier for rating/service group.
Must be an integer in the range of 1-8388607.
Usage Guidelines
Use this command to configure the URR list data.
active-charging service urr-list urr-list-data service-identifier
Configures the URR ID service identifier parameter.
Command Mode
Syntax
rating-group rating_id urr-id urr_id service-identifier service_id urr-id urr_id
Specify the service ID, the number given to the service.
urr-id urr_id
Usage Guidelines
Use this command to configure the URR ID service identifier parameter.
apn
Configures Access Point Name (APN) templates.
Command Mode
Syntax
apn apn_name
apn apn_name
Specify name of the APN.
Must be a string in the pattern '[A-Za-z0-9]{1}[A-za-z0-9.-]{1,61}'.
Usage Guidelines
Use this command to create and configure an APN.
Example
The following command creates an APN template named isp1:
apn isp1
apn active-charging
Enables a configured ACS rulebase.
Command Mode
Exec > Global Configuration (config) > APN Configuration (config-apn-apn_name )
Syntax
active-charging rulebase rulebase_name
Specify name of the rulebase.
Usage Guidelines
Use this command to enable a configured ACS rulebase.
apn authorize-with-hss
Configures S6b authentication.
Command Mode
Syntax
authorize-with-hss [ report-ipv6-addr ]
report-ipv6-addr
Specify to enable IPv6 reporting through AAR towards S6b interface.
Usage Guidelines
Use this command to configure S6b authentication. Enables IPv6 reporting through AAR towards S6b interface.
apn authorize-with-hss egtp
Enables S6b authorization for all the interfaces of EGTP along with GN-GP Handover except 3G initial attach.
Command Mode
Syntax
authorize-with-hss egtp [ report-ipv6-addr ]
report-ipv6-addr
Usage Guidelines
Use this command to enable S6b authorization for all the interfaces of EGTP along with GN-GP Handover except 3G initial attach.
apn authorize-with-hss egtp gn-gp-enabled
Enables S6b authorization for 3G Initial Attach and GnGp Handover.
Command Mode
Syntax
authorize-with-hss egtp gn-gp-enabled report-ipv6-addr
report-ipv6-addr
Usage Guidelines
Use this command to enable S6b authorization for 3G Initial Attach and GnGp Handover.
apn authorize-with-hss egtp s2b
Enables S6b authorization for egtp-s2b.
Command Mode
Syntax
authorize-with-hss egtp s2b report-ipv6-addr
report-ipv6-addr
Usage Guidelines
Use this command to enable S6b authorization for egtp-s2b.
apn authorize-with-hss egtp s2b gn-gp-enabled
Command Mode
Syntax
authorize-with-hss egtp s2b gn-gp-enabled report-ipv6-addr
report-ipv6-addr
Usage Guidelines
apn authorize-with-hss egtp s2b s5-s8
Enables S6b authorization for egtp-s5s8.
Command Mode
Syntax
authorize-with-hss egtp s2b s5-s8 [ gn_gp_option | report-ipv6-addr ]
report-ipv6-addr
Specify to enable IPv6 reporting through AAR towards s6b interface.
gn_gp_option
Specify to enable or disable S6b authorization for 3G Initial Attach and GnGp Handover.
  • gn-gp-disabled : Disables S6b authorization for 3G Initial Attach and GnGp Handover.
  • gn-gp-enabled : Enables S6b authorization for 3G Initial Attach and GnGp Handover.
Usage Guidelines
Use this command to enable S6b authorization for egtp-s5s8.
apn authorize-with-hss egtp s5-s8
Command Mode
Syntax
authorize-with-hss egtp s5-s8 [ gn_gp_option ] [ report-ipv6-addr ]
report-ipv6-addr
gn_gp_option
Usage Guidelines
apn authorize-with-hss egtp s5-s8 s2b
Command Mode
Syntax
authorize-with-hss egtp s5-s8 s2b [ gn_gp_option ] [ report-ipv6-addr ]
report-ipv6-addr
gn_gp_option
Usage Guidelines
apn authorize-with-hss lma
Enables IPv6 reporting through AAR towards S6b.
Command Mode
Syntax
authorize-with-hss lma [ report-ipv6-addr | s6b-aaa-group group_name ]
report-ipv6-addr
Specify the AAA group name for S6b authorization.
Usage Guidelines
Use this command to enable IPv6 reporting through AAR towards S6b.
apn cc-profile
Configures the subscriber charging characteristics profile parameters.
Command Mode
Syntax
cc-profile index { credit-control-group cc_group_name | prepaid-prohibited }
cc-profile index
Specify the charging characterstics profile index.
Must be an integer.
-Or-
  • any
Specify name of the credit control group.
prepaid-prohibited
Specify to disable prepaid for the configured profile index.
Usage Guidelines
Use this command to configure the subscriber charging characteristics profile parameters.
apn content-filtering category
Configures Content Filtering category.
Command Mode
Syntax
content-filtering category policy-id policy_id
policy-id policy_id
Specify the Content Filtering Policy ID.
Must be an integer in the range of 1-4294967295.
Usage Guidelines
Use this command to configure Content Filtering category.
apn data-tunnel
Configures the data tunnel MTU parameter.
Command Mode
Syntax
data-tunnel mtu max_transmission_unit
Specify the data tunnel MTU value, in octets.
Must be an integer.
Usage Guidelines
Use this command to configure the data tunnel MTU parameter.
apn gtpp group
Enables and configures the GTPP group to be used by this APN.
Command Mode
Syntax
gtpp group gtpp_group_name
Specify name of the GTPP group.
Usage Guidelines
Use this command to enable and configure the GTPP group to be used by this APN.
apn ip access-group
Configures an IPv4/IPv6 access group for the current APN profile.
Command Mode
Syntax
ip access-group acl_group_name [ in | out ]
Specify name of the IPv4/IPv6 access group.
Must be a string of 1-47 characters.
in
Specify the access group as inbound.
out
Specify the access group as outbound.
Usage Guidelines
Use this command to apply a single IPv4/IPv6 access control list to multiple subscribers via this APN for inbound or outbound IPv4/IPv6 traffic. If no traffic direction is specified, the selected access control list will be applied to both directions.
You can configure a maximum of eight elements with this command.
apn ip source-violation
Enables or disables packet source validation for the current APN.
Command Mode
Syntax
ip source-violation ignore
ignore
Disables source address checking for the APN.
Usage Guidelines
Use this command to enable packet source validation. Source validation is useful if packet spoofing is suspected or for verifying packet routing and labeling within the network. Source validation requires the source address of received packets to match the IP address assigned to the subscriber (either statically or dynamically) during the session.
Example
The following command enables source address validation for the APN and configures a drop-limit of 15:
ip source-violation check drop-limit 15
apn ppp
Configures PPP parameters for specified APN.
Command Mode
Syntax
ppp mtu max_transmission_unit
Specify the maximum transmission unit. Default Value: 1500.
Must be an integer.
Usage Guidelines
Use this command to configure the PPP parameters for specified APN.
apn timeout
Configures session timeout parameters for the current APN.
Command Mode
Syntax
timeout idle idle_timeout
idle idle_timeout
Specify the session idle timeout period for the current APN.
Must be an integer in the range of 0-4294967295.
Usage Guidelines
Use this command to configure the session timeout parameters for the current APN.
cd
Configures the change directory command.
Privilege Level
Security Administrator, Administrator
Command Mode
Exec
Syntax
cd directory.ssh
directory
Specify the directory path.
Must be an alphanumeric string.
Usage Guidelines
Use this command to configure the change directory command.
cdl clear
Deletes the CDL database sessions.
Privilege Level
Command Mode
Exec
Syntax
cdl clear sessions [ db-name db_name | filter { condition { ends-with | match | starts-with } key key_value } | map-id map_id ]
db-name db_name
Specifies the database name to be queried for deleting the data.
Must be a string of 1 to 16 characters.
key key_value
Specifies the query value.
Must be a string of 0 to 512 characters.
map-id map_id
Specifies the map ID to delete the data for a map.
Must be an integer in the range of 0-1024.
filter condition { ends-with | match | starts-with }
Specify the query expression to filter the results of query.
Usage Guidelines
Use this command to clear the CDL database sessions.
cdl show sessions
Displays the CDL session details.
Privilege Level
Command Mode
Exec
Syntax
cdl show sessions count { detailed { db-name db_name | filter { condition { ends-with | match | starts-with } | key key_value } | limit limit | map-id map_id } | summary { db-name db_name | filter { condition { ends-with | match | starts-with } | key key_value } | limit limit | map-id map_id }
count
Displays the session count information.
detailed
Displays the session details with data.
summary
Displays the session details without data.
db-name db_name
Specifies the database name to be queried for displaying the session details.
key key_value
map-id map_id
Specifies the map ID to display the data for a map.
limit limit
Specifies the maximum number of records to display.
Must be an integer in the range of 1 to 500 characters.
Usage Guidelines
Use this command to display the session details.
cdl show status
Displays the status of the CDL database.
Privilege Level
Command Mode
Exec
Syntax
cdl status db-name db_name
db-name db_name
Specifies the database name for displaying the corresponding status.
Usage Guidelines
Use this command to display the status of the queried database.
clear diameter routes dynamic
Clears the dynamic routes.
Command Mode
Exec
Syntax
clear diameter routes dynamic [ interface  interface_name profilename profile_name ]
Interface interface_name
Specify the diameter interface name, example: Gx or Gy. This is mandatory field.
Specify the profile name and is an optional field. If the profile-name is not provided, then it clears all the dynamic routes for the interface.
Usage Guidelines
Use this command to clears the diameter dynamic routes.
clear ipam
Clears IPAM operational data.
Command Mode
Exec
Syntax
clear ipam
Usage Guidelines
Use this command to clear IPAM operational data.
clear ipam
Clears the IPAM operational data.
Privilege Level
Command Mode
Exec
Syntax
clear ipam
Usage Guidelines
Use this command to clear the IPAM operational data.
clear lawful-intercept stats
Clears Lawful Interception IRI Send and IRI Drop counters.
Command Mode
Exec
Syntax
Usage Guidelines
Use this command to clear Lawful Interception IRI Send and IRI Drop counters.
clear subscriber
Clears subscriber data.
Command Mode
Exec
Syntax
clear subscriber { all    | gr-instance gr_instance | imei imei_id | namespace namespace | nf-service nf_service | supi supi_id | config_specific_options }
all
Specify to remove all subscriber data.
Specify the subscribers from the GR instance.
imei imei_id
Specify the International Mobile Equipment Identity.
Must be a string of 15-16 characters.
imsi imsi
Specify the International Mobile Subscriber Identifier (IMSI).
Must be a string.
msid msid
Specify the Mobile Station Identifier (MSID).
Must be a string.
namespace namespace
NOTE: This keyword is deprecated, use nf-service instead. Specifies the product namespace under which to search.
Default Value: cisco-mobile-infra:none.
Specify the network function service under which to search.
supi supi_id
Specify to remove subscriber data associated with the SUPI ID.
Must be a string of 1-63 characters.
clear subscriber supi-opt
Clears subscriber data based on SUPI.
Command Mode
Exec
Syntax
clear subscriber supi supi_id [ psid pdu_session_id | ebi eps_bearer_id | reactivation { false | true } } ]
all
ebi eps_bearer_id
Specify the EPS Bearer ID.
Must be a string.
imei imei_id
imsi imsi
Must be a string.
msid msid
Must be a string.
namespace namespace
psid pdu_session_id
Specify the PDU Session ID.
Must be an integer in the range of 1-255.
Specify if reactivation is requested.
Must be one of the following:
  • false
  • true
supi supi_id
Usage Guidelines
Use this command to clear subscriber data.
Usage Guidelines
Use this command to clear subscriber data based on SUPI.
clear subscriber imsi-opt
Clears subscriber data based on IMSI.
Command Mode
Exec
Syntax
clear subscriber imsi-options imsi_option [ ebi eps_bearer_id ]
ebi eps_bearer_id
Must be a string.
Usage Guidelines
Use this command to clear subscriber data based on IMSI.
Command Mode
Exec
Syntax
ebi eps_bearer_id
Must be a string.
psid pdu_session_id
  • false
  • true
clear ipam
Command Mode
Exec
Syntax
clear ipam
Usage Guidelines
Usage Guidelines
client http header
Configures HTTP header parameters.
Command Mode
Syntax
client http header user-agent user_agent_header
Specify the user agent header.
  • app-name
  • cluster-name
  • disable
Default Value: app-name.
Usage Guidelines
Use this command to configure HTTP header parameters.
client http ping
Configures HTTP ping parameters.
Command Mode
Syntax
client http ping { [ timeout ping_timeout ] [ interval ping_interval ] }
Specify, in milliseconds, the time interval between two HTTP pings.
Must be an integer in the range of 0-30000.
Default Value: 10000.
Specify, in milliseconds, the ping timeout duration to detect if remote host is down.
Must be an integer in the range of 0-15000.
Default Value: 5000.
Usage Guidelines
Use this command to configure HTTP ping parameters.
client inbound interface
Configures inbound client interface parameters.
Command Mode
Syntax
client inbound interface interface_name
Specify name of the interface.
Note
Specify scp interface to detect a dead SCP.
Usage Guidelines
Use this command to configure inbound client interface parameters. The CLI prompt changes to the Interface Configuration mode (config-interface-<interface_name>).
client inbound interface limit overload
Configures Overload configuration parameters.
Command Mode
Exec > Global Configuration (config) > Interface Configuration (config-interface-interface_name )
Syntax
limit overload reject-code response_code
Specify the response code to be used when pending limit exceeds.
Must be an integer.
Usage Guidelines
Use this command to configure Overload configuration parameters.
client inbound interface limit pending
Configures pending limit configuration.
Command Mode
Syntax
limit pending request max_pending_request_limit
Specify the maximum pending request limit to allow.
Must be an integer.
Default Value: 10240.
Usage Guidelines
Use this command to configure pending limit configuration.
client inbound limit overload
Command Mode
Syntax
Must be an integer.
Usage Guidelines
client inbound limit pending
Command Mode
Syntax
Must be an integer.
Usage Guidelines
client outbound host ping
Configures outbound host ping parameter.
Command Mode
Syntax
client outbound host ping { [ timeout ping_timeout ] [ interval ping_interval ] [ backoff backoff_interval ] }
Command Mode
Syntax
host ping { [ timeout ping_timeout ] [ interval ping_interval ] }
Specify, in milliseconds, the backoff time interval to wait when remote host was detected down before start pinging again.
Must be an integer in the range of 0-3600000.
Default Value: 0.
Specify, in milliseconds, the time interval between two pings.
Default Value: 0.
Specify, in milliseconds, the ping timeout duration to detect remote host down.
Default Value: 0.
Usage Guidelines
Use this command to configure outbound host ping parameter.
client outbound interface
Configures outbound client interface parameters.
Command Mode
Syntax
client outbound interface interface_name
Specify the interface.
Usage Guidelines
Use this command to configure outbound client interface parameters. The CLI prompt changes to the Interface Configuration mode (config-interface-<interface_name>).
client outbound interface host ping
Command Mode
Syntax
Command Mode
Syntax
Default Value: 0.
Default Value: 0.
Default Value: 0.
Usage Guidelines
client outbound interface limit consecutive failure
Configures consecutive failure configuration parameters.
Command Mode
Syntax
consecutive failure count failure_limit_count codes failure_codes
codes failure_codes
Specify the list of failure codes to be considered, such as timeout, 503, etc.
Must be a string.
You can configure a maximum of 10 elements with this keyword.
Specify the consecutive failure limit count to detect remote host as down.
Must be an integer.
Default Value: 0.
Usage Guidelines
Use this command to configure consecutive failure configuration parameters.
client outbound interface limit pending
Command Mode
Syntax
client outbound limit pending response response_message_limit
Command Mode
Syntax
Specify the pending response message limit to detect remote host as down.
Must be an integer.
Default Value: 1024.
Usage Guidelines
client outbound limit consecutive failure
Command Mode
Syntax
codes failure_codes
Must be a string.
Must be an integer.
Default Value: 0.
Usage Guidelines
Command Mode
Syntax
Command Mode
Syntax
Must be an integer.
Usage Guidelines
commit
Configures the commit parameters.
Privilege Level
Command Mode
Exec
Syntax
commit [ abort { persist-id persist_id } | confirm { persist-id persist_id  } | persist-id persist_id ]
abort persist-id persist_id
Specify to abort commit. Specify the persistence ID for the commit operation.
Must be an integer.
confirm persist-id persist_id
Specify to confirm commit. Specify the persistence ID for the commit operation.
Must be an integer.
Must be an integer.
Usage Guidelines
Use this command to configure the commit parameters.
compare
Compares the running configuration to another configuration or a file.
Privilege Level
Command Mode
Exec
Syntax
compare file { filename[.kube | .ssh/] | configuration }
Specify the file name or the directory path of the file to be compared.
Must be a string.
configuration
Specify the desired configuration to be compared against.
Must be a string.
Usage Guidelines
Use this command to compare the files.
config
Manipulates the software configuration information.
Privilege Level
Command Mode
Exec
Syntax
config [ exclusive | no-confirm | shared | terminal ]
exclusive
Specify to enter the exclusive configuration mode.
no-confirm
Specify to apply the command without asking for confirmation.
shared
Specify to enter the shared configuration mode.
terminal
Specify to enter the terminal configuration mode.
Usage Guidelines
Use this command to manipulate the software configuration information.
config-error info
Displays configuration error information.
Command Mode
Exec
Syntax
show config-error [ info ]
Usage Guidelines
Use this command to view configuration error information.
datastore dbs
Configures DBS parameters.
Command Mode
Syntax
datastore dbs dbs_name
dbs dbs_name
Specify name of the DBS.
Must be a string.
Usage Guidelines
Use this command to configure the DBS parameters.
datastore dbs endpoints
Configures endpoint parameters.
Command Mode
Syntax
datastore session-db endpoints host_name port port_number
Command Mode
Exec > Global Configuration (config) > DBS Configuration (config-dbs-dbs_name )
Syntax
endpoints host_name
Specify name of the host.
Must be a string.
port port_number
Must be an integer.
Usage Guidelines
Use this command to configure endpoint parameters.
datastore notification-ep
Configures notification endpoint parameters.
Command Mode
Syntax
datastore notification-ep { [ host host_name ] [ port port_number ] }
host host_name
Must be a string.
port port_number
Must be an integer.
Usage Guidelines
Use this command to configure notification endpoint parameters.
Configures Session DB parameters.
Command Mode
Syntax
datastore session-db slice-name slice_name
Specify name of the slice.
Must be a string.
Usage Guidelines
Use this command to configure Session DB parameters.
Command Mode
Syntax
Command Mode
Syntax
endpoints host_name
Must be a string.
port port_number
Must be an integer.
Usage Guidelines
deployment
Configures the deployment parameters.
Command Mode
Syntax
deployment [ app-name application_name | cluster-name cluster_name | dc-name datacenter_name | logical-nf-instance-id logical_nf_instance_id | model deployment_model ]
Specify name of the application.
Must be a string.
Specify name of the cluster.
Must be a string.
Specify name of the datacenter.
Must be a string.
Specify the logical NF instance ID.
Must be an integer.
Default Value: 0.
Specify the deployment model.
  • small
Usage Guidelines
Use this command to configure the deployment parameters.
deployment resource
Configures the deployment CPU resource parameter.
Command Mode
Exec > Global Configuration (config) > Deployment Configuration (config-deployment)
Syntax
resource cpu cpu_size
cpu cpu_size
Specify the CPU size in millicores.
Must be an integer in the range of 2000-1000000.
Default Value: 18000.
Usage Guidelines
Use this command to configure the deployment CPU resource parameter.
describe
Displays the command information.
Privilege Level
Command Mode
Exec
Syntax
describe command
command
Specify the command name to display detailed information about the command.
The command must be one of the following:
  • aaa
  • cd
  • cdl
  • commit
  • compare
  • config
  • describe
  • dump
  • exit
  • help
  • history
  • id
  • idle-timeout
  • ignore-leading-space
  • job
  • leaf-prompting
  • license
  • logout
  • monitor
  • no
  • paginate
  • quit
  • rcm
  • screen-length
  • screen-width
  • send
  • show
  • show-defaults
  • smiuser
  • system
  • terminal
  • timestamp
  • who
Usage Guidelines
Use this command to display the command specific information.
diagnostics info
Displays diagnostics information.
Command Mode
Exec
Syntax
show diagnostics [ info ]
Usage Guidelines
Use this command to view diagnostics information.
dump
Removes the transaction history.
Privilege Level
Command Mode
Exec
Syntax
dump transactionhistory
Usage Guidelines
Use this command to remove the transaction history.
dump core
Enables and configures inconsistency checks on session data.
Command Mode
Syntax
dump core [ [ count max_core_count_per_interval ] [ expires expiration_time ] [ file-detail file_name_line_number ] [ interval interval_duration ] [ pod-name pod_names ] ]
Specify the maximum number of times core can be generated in an interval.
Must be an integer in the range of 0-50.
Specify the time after which the core agent will stop core dump generation. For example, 2020-03-24T23:15:00+05:30.
Must be a string in the date-and-time pattern. For information on the date-and-time pattern, see the Input Pattern Types chapter.
Specify the file name and line number to specific core dump. For example, procedures/pduim/procedure.go:1902.
Must be a string.
Specify the duration of the interval in minutes.
Must be an integer in the range of 1-3600.
pod-name pod_names
Specify the names of the pods to enable core dump.
Must be a string.
Usage Guidelines
Use this command to enable and configure inconsistency checks on session data.
Creates dump of transaction history.
Command Mode
Exec
Syntax
Usage Guidelines
Use this command to create dump of transaction history.
edr
Configures EDR parameters.
Command Mode
Syntax
edr { [ reporting reporting_status ] [ all | subscribers subscribers_for_edr_reporting ] }
Specify to enable or disable EDR reporting.
  • disable
  • enable
Default Value: disable.
reporting all
Specify to enable EDR reporting for all subscribers.
Specify the subscribers for whom EDR reporting must be enabled.
Must be a string.
Note
The edr reporting all command takes precedence over the edr reporting subscribers command when enabled.
Usage Guidelines
Use this command to configure EDR parameters.
edr file files
Configures EDR file parameters.
Command Mode
Syntax
edr file { transaction | transaction-collision } [ reporting reporting_status ] [ verbose verbosity_status ]
Specify to enable or disable reporting of this file.
  • disable
  • enable
Specify to enable or disable field description or long names in the file.
  • disable
  • enable
Specify name of the EDR file.
Usage Guidelines
Use this command to configure EDR file parameters.
edr file files disable
Disables procedure IDs.
Command Mode
Exec > Global Configuration (config) > EDR File Configuration (config-file-transaction_transaction-collision )
Syntax
disable procedure-id procedure_ids
Specify the procedure ID value(s)/name(s).
Must be a string.
Usage Guidelines
Use this command to disable specific procedure IDs.
edr file files flush
Configures EDR file flush parameters.
Command Mode
Syntax
flush interval file_flush_interval
Specify, in milliseconds, the file flush interval.
Must be an integer.
Default Value: 1000.
Usage Guidelines
Use this command to configure the EDR file flush parameters.
edr file files limit
Configures EDR file limit parameters.
Command Mode
Syntax
limit { [ count max_files_to_preserve ] [ size max_single_file_size ] }
Specify the maximum number of files to be preserved.
Must be an integer.
Default Value: 10.
Specify the maximum single file size limit in MB.
Must be an integer.
Default Value: 100.
Usage Guidelines
Use this command to configure the EDR file limit parameters.
edr file files procedure-id disable-event-id
Disables transaction-level procedure ID configuration.
Command Mode
Syntax
procedure procedure_id
Specify the procedure ID value/name.
Must be a string.
Usage Guidelines
Use this command to disable transaction-level procedure ID configuration.
edr file files procedure-id disable-event-id disable-inner disable
Disables event IDs.
Command Mode
Exec > Global Configuration (config) > EDR File Configuration (config-file-transaction_transaction-collision ) > Procedure ID Configuration (config-procedure-id-procedure_id )
Syntax
disable event-id event_ids
event-id event_ids
Specify the event ID value(s)/name(s).
Must be a string.
Usage Guidelines
Use this command to disable event IDs.
edr file files procedure-id disable-event-id disable-inner event-id disable-field-id
Disables procedure-level event ID configuration.
Command Mode
Syntax
event-id event_id
event event_id
Specify the event ID value/name.
Must be a string.
Usage Guidelines
Use this command to disable procedure-level event ID configuration.
edr file files procedure-id disable-event-id disable-inner event-id disable-field-id disable
Disables field IDs.
Command Mode
Syntax
disable field-id field_ids
field-id field_ids
Specify the field ID value(s)/name(s).
Must be a string.
Usage Guidelines
Use this command to disable field IDs.
edr file transaction field priorityClass
Configures the priority class of the transaction EDR file.
Command Mode
Syntax
[ no ] edr file transaction field priorityClass
field priorityClass
Specify the priority class of the message. The message can be a default priority message or a high-priority message. Enabling this CLI displays an additional field in the EDR transaction files with an additional field containing one of the following two values:
  • DefaultPriority
  • HighPriority
Usage Guidelines
Use this command to configure the priority class of the transaction EDR file.
endpoint all
Displays endpoint status information.
Command Mode
Exec
Syntax
show endpoint [ all ]
Usage Guidelines
Use this command to view endpoint status information.
endpoint info
Displays endpoint information.
Command Mode
Exec
Syntax
show endpoint info [ endpoint_name | endpoint_address | Interface interface_name | grInstance gr_instance_id | internal type_of_endpoint | startTime start_time | status endpoint_status | stoppedTime stop_time | type endpoint_type ]
Specify the interface name of the endpoint.
Must be a string.
Specify the GR instance ID.
Must be a string.
Specify whether the endpoint is of internal or external type.
Must be a string.
Specify the time at which the endpoint started.
Must be a string.
Specify the current status of the endpoint.
Must be a string.
Specify the time at which the endpoint stopped.
Must be a string.
type endpoint_type
Specify the endpoint type.
Must be a string.
endpoint_address
Specify the host address and port number.
Must be a string.
endpoint_name
Specify the name of the endpoint.
Must be a string.
Usage Guidelines
Use this command to view endpoint information.
exit
Exits the current configuration mode and returns to the previous configuration mode.
Privilege Level
Command Mode
Exec
Syntax
exit
Usage Guidelines
Use this command to exit the current configuration mode and return to the previous configuration mode. When used in the Exec mode, exits the management session.
geo maintenance
Configures Geo Admin Controller to enable or disable maintenance mode.
Command Mode
Exec
Syntax
maintenance enable { false | true }
Specify whether to enable or disable maintenance mode. To enable, set to true.
  • false
  • true
Default Value: false.
Usage Guidelines
Use this command to configure Geo Admin Controller to enable or disable maintenance mode.
geo replication-pull
geo replication-pull pulls the replication data from the peer rack and syncs it with the local rack.
Command Mode
Exec
Syntax
geo replication-pull instance-id gr_instanceId
It pulls the replication data from the peer rack and syncs it with the local rack.
instance-id instance_id
Specify the instance ID for geo command.
Usage Guidelines
Use this command to pull the replication data from the peer rack and sync it with the local rack.
geo reset-role
Configures Geo Admin Controller for reset role.
Command Mode
Exec
Syntax
geo reset-role instance-id instance_id role new_role
role new_role
Specify the new role for the specified site.
Usage Guidelines
Use this command to configure Geo Admin Controller for reset role.
geo switch-role
Geo switch-role switches the role to peer rack.
Command Mode
Exec
Syntax
geo switch-role  instance-id instance_id role new_role [ failback-interval failback_interval ]
Specify the instance ID for the geo command.
role new_role
The recommended value is 0.
Note
The CLI [ failback-interval ] is an optional command to provide backward compatibility of upgrades between releases. It is deprecated from the current release and will be discontinued from the subsequent releases.
Usage Guidelines
Use this command to switch the role to peer rack.
geomonitor podmonitor pods
Configures configuration of pods to be monitored.
Command Mode
Syntax
geomonitor podmonitor pods pod_name retryCount retry_count retryInterval retry_interval retryFailOverInterval retry_interval failedReplicaPercent failed_replica_precentage
Specify the percentage of failed replica after which GR failover will get triggered.
Must be an integer in the range of 10-100.
pods pod_name
Specify the name of the pod to be monitored.
Must be a string.
Specify the counter value to retry if pod failed to ping after which pod is marked as down.
Must be an integer in the range of 1-10.
Specify, in milliseconds, the retry interval if pod ping fails.
Must be an integer in the range of 200-10000.
Specify, in milliseconds, the retry interval if pod ping is successful.
Usage Guidelines
Use this command to configure configuration of pods to be monitored.
geomonitor remoteclustermonitor
Configures remote cluster monitoring parameters.
Command Mode
Syntax
remoteclustermonitor retryCount retry_count retryInterval retry_interval
Specify the counter value to retry if remote clsuter is not reachable. To discable, set to 0.
Must be an integer in the range of 0-10.
Default Value: 3.
Specify, in milliseconds, the retry interval after which the remote site's status will be fetched.
Must be an integer in the range of 200-50000.
Default Value: 3000.
Usage Guidelines
Use this command to configure remote cluster monitoring parameters.
geomonitor trafficMonitor
Configures traffic monitoring parameters.
Command Mode
Syntax
trafficMonitor thresholdCount threshold_count thresholdInterval threshold_interval
Specify, in milliseconds, the maximum duration window to hit the threshold count value.
Must be an integer in the range of 0-10000.
Default Value: 0.
Must be an integer in the range of 100-10000.
Usage Guidelines
Use this command to configure traffic monitoring parameters.
geomonitor vipmonitor instance
Configures VIP monitoring parameters.
Command Mode
Syntax
vipmonitor instance instance-id instance_id
Specify the instance ID.
Must be an integer in the range of 1-8.
Usage Guidelines
Configuration of VIPs to be monitored. Use this command to configure the instance ID.
geomonitor vipmonitor instance vips
Configures VIP interface parameters.
Command Mode
Syntax
vips vipInterface vip_interface vipIp vip_ip vipPort vip_port retryCount retry_count retryInterval retry_interval retryFailOverInterval retry_failover_interval
Specify the counter value to retry if VIP failed to ping after which VIP is marked as down.
Specify, in milliseconds, the retry interval if VIP ping fails.
Specify, in milliseconds, the retry interval if VIP ping is successful.
Specify the name of the interface to monitor.
Must be a string.
vipIp vip_ip
Specify the IPv4 address.
Must be a string.
vipPort vip_port
Specify the diagnostic port number.
Must be an integer.
Usage Guidelines
Use this command to configure VIP interface parameters.
group nf-mgmt
Configures NF management group name.
Command Mode
Syntax
nf-mgmt mgmt_group_name { nrf-mgmt-group nrf_mgmt_group_name | failure-handling-profile fh_profile_name | nrf-auth-group nrf_auth_group_name | locality locality_name | re-register { false | true } }
Specify name of the Failure Handling profile for the NRF Management functionality.
Must be a string.
Specify the locality information.
Must be a string.
Specify name of the NRF management group.
Must be a string.
Must be a string.
Usage Guidelines
Use this command to configure NF management group name.
group nf-mgmt heartbeat
Configures heartbeat interval.
Command Mode
Syntax
heartbeat interval heartbeat_interval
Specify the heartbeat interval in seconds.
Must be an integer.
Usage Guidelines
Use this command to configure the heartbeat interval.
group nrf discovery
Configures NRF discovery group parameters.
Command Mode
Syntax
discovery group_name [ nrf-type nrf_type ]
Specify name of the NRF discovery group.
Must be a string.
nrf-type nrf_type
Specify the NRF type.
  • PLMN : PLMN.
  • SHARED : SHARED.
  • SLICE-LOCAL : SLICE-LOCAL.
Usage Guidelines
Use this command to configure the NRF discovery group configuration.
group nrf discovery service type nrf
Configures the NRF discovery service name.
Command Mode
Syntax
nrf nrf_service_name [ responsetimeout response_timeout ]
Specify name of the NRF discovery service.
  • nnrf-disc
Specify the response timeout interval in milliseconds.
Must be an integer.
Default Value: 2000.
Usage Guidelines
Use this command to configure the NRF discovery service name.
group nrf discovery service type nrf endpoint-profile
Configures endpoint profile parameters.
Command Mode
Syntax
endpoint-profile endpoint_profile_name { api-uri-prefix api_uri_prefix | api-root api_root | uri-scheme uri_scheme }
api-root api_root
Specify the API root.
Must be a string.
Specify the API URI prefix.
Must be a string.
Specify name of the endpoint profile.
Must be a string.
Specify the URI scheme.
  • http
  • https
Usage Guidelines
Use this command to configure endpoint profile parameters.
group nrf discovery service type nrf endpoint-profile endpoint-name
Command Mode
Syntax
endpoint-name endpoint_name [ priority priority | capacity endpoint_capacity ]
Specify the endpoint capacity.
Must be an integer in the range of 0-65535.
Default Value: 10.
priority priority
Specify the node priority for endpoint.
endpoint_name
Specify name of the endpoint.
Must be a string.
Usage Guidelines
group nrf discovery service type nrf endpoint-profile endpoint-name primary ip-address
Configures the endpoint IP address and port number.
Command Mode
Syntax
ip-address { { ipv4 ipv4_address | ipv6 ipv6_address } | port port_number }
ipv4 ipv4_address
Must be a string in the ipv4-address pattern. For information on the ipv4-address pattern, see the Input Pattern Types chapter.
ipv6 ipv6_address
Specify the IPv6 address.
Must be a string in the ipv6-address pattern. For information on the ipv6-address pattern, see the Input Pattern Types chapter.
port port_number
Usage Guidelines
Use this command to configure the endpoint IP address and port number.
group nrf discovery service type nrf endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
group nrf discovery service type nrf endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
group nrf discovery service type nrf endpoint-profile version uri-version
Configures URI version information.
Command Mode
Syntax
uri-version uri_version [ full-version full_version ]
Specify the full version in the format major-version .minor-version .patch-version .[alpha-draft-number ]
Must be a string.
Specify the URI version.
Must be a string in the pattern v\d.
Usage Guidelines
Use this command to configure URI version information.
group nrf mgmt
Configures the NRF self-management group parameters.
Command Mode
Syntax
mgmt group_name [ nrf-type nrf_type ]
mgmt group_name
Specify name of the NRF self-management group.
Must be a string.
nrf-type nrf_type
  • PLMN : PLMN.
  • SHARED : SHARED.
Usage Guidelines
Use this command to configure the NRF self-management group parameters.
group nrf mgmt service type nrf
Configures the NRF self-management service information.
Command Mode
Syntax
nrf nrf-service-name nrf_service_name [ responsetimeout response_timeout ]
Specify name of the NRF service.
  • nnrf-nfm
Must be an integer.
Usage Guidelines
Use this command to configure the NRF self-management service information.
group nrf mgmt service type nrf endpoint-profile
Command Mode
Syntax
api-root api_root
Must be a string.
Must be a string.
Must be a string.
  • http
  • https
Usage Guidelines
group nrf mgmt service type nrf endpoint-profile endpoint-name
Configures name of the endpoint.
Command Mode
Syntax
endpoint-name endpoint_name [ priority endpoint_priority ]
max-retry-count max_retry_count
Specify the maximum retry count.
Default Value: 3.
endpoint_name
Must be a string.
Usage Guidelines
Use this command to configure the name of the endpoint.
group nrf mgmt service type nrf endpoint-profile endpoint-name primary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
group nrf mgmt service type nrf endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
group nrf mgmt service type nrf endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
group nrf mgmt service type nrf endpoint-profile version uri-version
Configures version information.
Command Mode
Syntax
Must be a string.
Usage Guidelines
Use this command to configure the version information.
gtpp group
Configures GTPP group related parameters.
Command Mode
Syntax
gtpp gtpp_group_name
gtpp_group_name
Usage Guidelines
Use this command to configure GTPP group related parameters.
gtpp group gtpp egcdr final-record closing-cause
Configures closing cause for final EGCDR.
Command Mode
Exec > Global Configuration (config) > GTPP Group Configuration (config-group-gtpp_group_name )
Syntax
gtpp egcdr final-record closing-cause { same-in-all-partials | unique }
Specify same closing cause for multiple final EGCDR(s).
unique
Specify unique closing cause for final EGCDR.
Usage Guidelines
Use this command to configure closing cause for final EGCDR.
gtpp group gtpp egcdr losdv-max-containers
Configures maximum number of LoSDV containers in one EGCDR.
Command Mode
Syntax
gtpp egcdr losdv-max-containers max_containers
Specify the number of LOSDV containers.
Usage Guidelines
Use this command to configure the maximum number of LoSDV containers in one EGCDR.
gtpp group gtpp egcdr service-data-flow threshold
Configures service data flow related parameters.
Command Mode
Syntax
gtpp egcdr service-data-flow threshold interval duration
interval duration
Specify the time interval, in seconds, to close the eG-CDR/P-CDR if the minimum time duration thresholds for service data flow containers satisfied in flow-based charging. By default, this option is disabled.
Must be an integer in the range of 60-40000000.
Usage Guidelines
Use this command to assign volume or interval values to the interim GCDRs.
gtpp group gtpp egcdr service-data-flow threshold volume
Configures the uplink/downlink volume octet counts for the generation of interim GCDRs.
Command Mode
Syntax
gtpp egcdr service-data-flow threshold volume { [ downlink bytes ] [ total bytes ] [ uplink bytes ] }
downlink bytes
Specify the limit for the number of downlink octets after which the eG-CDR/P-CDR is closed.
Must be an integer in the range of 100000-4000000000.
total bytes
Specify the limit for the total number of octets (uplink+downlink) after which the eG-CDR/P-CDR is closed.
uplink bytes
Specify the limit for the number of uplink octets after which the eG-CDR/P-CDR is closed.
Usage Guidelines
Use this command to configure the uplink/downlink volume octet counts for the generation of interim GCDRs.
gtpp group gtpp egcdr service-idle-timeout
Enables configuration for service idle out closure of LOSDV container.
Command Mode
Syntax
gtpp egcdr service-idle-timeout { 0 | service_idle_timeout }
Specify no service-idle-timeout trigger.
  • 0
Specify time limit in seconds for service-idle-timeout.
Must be an integer in the range of 10-86400.
Usage Guidelines
Use this command to enable configuration for service idle out closure.
gtpp group gtpp trigger
Configures triggers for CDR.
Command Mode
Syntax
gtpp trigger { time-limit | volume-limit }
time-limit
When this trigger is disabled, no partial record closure occurs when the configured time limit is reached. Default: Enabled.
volume-limit
When this trigger is disabled no partial record closure occurs when volume limit is reached. Default: Enabled.
Usage Guidelines
Use this command to configure triggers for CDR.
gtpp group gtpp trigger egcdr
Enables or disables and configures eGCDR-related parameters.
Command Mode
Syntax
gtpp trigger egcdr max-losdv
max-losdv
Enable trigger for eGCDR release at MAX LoSDV containers.
Usage Guidelines
Use this command to enable or disable and configure eGCDR-related parameters.
help
Displays help information for a specified command.
Privilege Level
Command Mode
Exec
Syntax
help command
command
Specify the command name to display the corresponding help information.
  • aaa
  • cd
  • cdl
  • commit
  • compare
  • config
  • describe
  • dump
  • exit
  • help
  • history
  • id
  • idle-timeout
  • job
  • leaf-prompting
  • license
  • logout
  • monitor
  • no
  • paginate
  • quit
  • rcm
  • screen-length
  • screen-width
  • send
  • show
  • show-defaults
  • smiuser
  • system
  • terminal
  • timestamp
  • who
Usage Guidelines
Use this command to view help information for a specified command.
history
Configures the command history cache size.
Privilege Level
Command Mode
Exec
Syntax
history history_size
history_size
Specify the command history cache size.
Must be an integer in the range of 0-1000.
Usage Guidelines
Use this command to configure the command history cache size.
id
Displays user ID information.
Privilege Level
Command Mode
Exec
Syntax
id
Usage Guidelines
Use this command to view the user ID information.
idle-timeout
Configures the maximum duration a command can remain idle in seconds after which the system automatically terminates the connection.
Privilege Level
Command Mode
Exec
Syntax
idle-timeout duration
duration
Specify the idle timeout duration in seconds.
Must be an integer in the range of 1-8192.
Usage Guidelines
Use this command to configure the maximum duration a command can remain idle.
Configures whether to ignore or consider the leading whitespace at the beginning of a command.
Privilege Level
Command Mode
Exec
Syntax
ignore-leading-space { false | true }
{ false | true }
Specify false to ignore the leading whitespace, and true to consider it.
Must be either "false" or "true".
Usage Guidelines
Use this command to configure whether to ignore or consider leading whitespace at the beginning of a command.
infra metrics experimental
Configures the experimental configuration parameters.
Command Mode
Syntax
infra metrics experimental version experimental_metrics_version
Specify the experimental metrics version to be enabled.
Must be an integer in the range of 0-4.
Default Value: 0.
Usage Guidelines
Use this command to configure the experimental configuration parameters.
infra metrics verbose verboseLevels
Configures verbose configuration parameters.
Command Mode
Syntax
infra metrics verbose podType pod_type level verbose_level
level verbose_level
Specify the default verbosity level.
  • debug
  • off
  • production
  • trace
Default Value: trace.
podType pod_type
Specify the pod type.
  • application
  • load-balancer
  • protocol
  • service
Usage Guidelines
Use this command to configure verbose configuration parameters.
infra metrics verbose verboseLevels metrics metricsList
Configures the metrics verbose level configuration.
Command Mode
Syntax
metrics metric_name level metric_verbose_level granular-labels granular_labels
Specify the granular labels.
Must be a string.
Specify the metric verbosity level.
  • debug
  • off
  • production
  • trace
metric_name
Specify name of the metric.
Must be a string.
Usage Guidelines
Use this command to configure the metrics verbose level configuration.
infra transaction limit
Configures the maximum stage limit per transaction.
Command Mode
Syntax
infra transaction limit stage max_stage_limit
Specify the maximum stage limit per transaction.
Must be an integer.
Default Value: 100.
Usage Guidelines
Use this command to configure the maximum stage limit per transaction.
infra transaction limit consecutive same
Configures the maximum consecutive stage limit per transaction.
Command Mode
Syntax
infra transaction limit consecutive same stage max_consecutive_stage_limit
Specify the maximum consecutive stage limit per transaction.
Must be an integer.
Default Value: 10.
Usage Guidelines
Use this command to configure the maximum consecutive stage limit per transaction.
infra transaction loop
Configures the transaction loop detection parameters.
Command Mode
Syntax
infra transaction loop detection detection_status
Specify to enable or disable loop detection.
  • disable
  • enable
Usage Guidelines
Use this command to configure the transaction loop detection parameter.
infra transaction loop category
Configures the loop category.
Command Mode
Syntax
infra transaction loop category loop_category
Specify the category.
Usage Guidelines
Use this command to configure the loop category.
infra transaction loop category threshold
Configures the loop detection interval parameter.
Command Mode
Syntax
infra transaction threshold interval loop_detect_interval
Specify, in seconds, the loop detection interval.
Must be an integer.
Default Value: 5.
Usage Guidelines
Use this command to configure the loop detection interval parameter.
infra transaction loop category threshold thresholds
Configures thresholds.
Command Mode
Syntax
thresholds threshold_level count max_transactions action threshold_action
Specify the action to take on threshold breach.
  • kill-session
  • log-event
  • noop
Default Value: noop.
Specify the maximum number of transactions for the threshold interval.
Must be an integer.
Default Value: 100.
Specify the threshold level.
  • high
  • low
Usage Guidelines
Use this command to configure thresholds.
Configures instance ID.
Command Mode
Syntax
id instance_id
Usage Guidelines
Use this command to configure the instance ID. The CLI prompt changes to the Instance ID Configuration mode (config-instance-id-<instance_id>).
endpoint-gtpprime
Sets the storage size limit (default 1 GB), which is applicable when k8s use-volume-claim Pod is set to true.
Command Mode
Exec
Syntax
   endpoint gtpprime
      storage storage_capacity
      replicas replicas_count
      nodes nodes_count
      interface Gz
        vip-ip   vip_ip vip-port
endpoint gtpprime
Specifiy the following parameters to configure an endpoint.
  • storage storage_capacity —Specify the storage size of persistent volume in GB. Must be an integer in the range of 1-100.
    Note
    CLI doesn't allow changing storage size while system is running. To change the storage size, bring the system down first.
  • replicas replicas_count —Specify the number of replicas per node. Must be an integer.
  • nodes nodes_count —This property is ignored. You may skip configuring it.
  • interface Gz : Configure the Gz interface details, such as vip IPv4 address, vip port, vip interface, and VRF details.
    Note
    When the system is active and under the Gz Interface, if there are any add or update vip configurations to use a new value, ensure to restart the udp-proxy.
Usage Guidelines
Use this command to set the storage size limit (default 1 GB), which is applicable when k8s use-volume-claim Pod is set to true.
Ensure to configure GTPP profiles charging agent ip address and ports in the Endpoint under the Gz interface.
Note
The gtpp-ep always ignores nodes config. When k8s single-node is set to false, it spawns 2 replicas of gtpp-ep in the Active or Standby mode independent of replicas and nodes configuration.
instance instance-id endpoint ep
Command Mode
Exec > Global Configuration (config) > Instance ID Configuration (config-instance-id-instance_id )
Syntax
endpoint endpoint_type [ instancetype instance_type | loopbackEth interface_name_host_ip | loopbackPort port_number | nodes node_replicas_for_resiliency | replicas replicas_per_node | internal-vip{ smf_udp_proxy_internal_vip }| vip-ip{ client_ipv4_address }]
certificate-name certificate_alias_name
Specify the alias name for the certificate.
dscp dscp_value
Specify the DSCP value.
Must be a string in the hex-stringdscp pattern. For information on the hex-stringdscp pattern, see the Input Pattern Types chapter.
enable-cpu-optimization { false | true }
Specify whether to enable CPU optimization in PFCP and GTP protocol message handling. By default, it is enabled.
  • false
  • true
Default Value: true.
enable-go-encdec { false | true }
Specify whether to enable Go-based encoder-decoder in GTP protocol message handling or not. By default, it is disabled.
  • false
  • true
Specify the endpoint local interface type.
  • Dual
  • IPv4
  • IPv6
Default Value: IPv4.
internal-vip { smf_udp_proxy_internal_vip }
Specify the internal VIP.
Must be a string.
vip-ip { client_ipv4_address }
Specify the IP address of the dynamic authorization client. ipv4_address must be in standard IPv4 dotted decimal notation.
Specify the endpoint local interface name or host IP address.
Must be a string.
Specify the endpoint local port number.
Must be an integer.
Specify the number of node replicas for resiliency.
Must be an integer.
Default Value: 1.
Must be an integer.
Default Value: 1.
storage persistent_volume_storage_size
Specify the storage size of the persistent volume in gibibyte (GiB).
Must be an integer in the range of 1-20.
Default Value: 1.
  • http
  • https
Default Value: http.
Usage Guidelines
instance instance-id endpoint diameter
Configures the Diameter endpoint parameters.
Command Mode
Exec > Global Configuration (config) > Instance ID Configuration (config-instance-id-instance_idendpoint diameter )
Syntax
endpoint diameter [ interface { gx | gy }  [ vip-ip  ip_address [ vip-interface  interface_name| vip-port vip_port | vrf vrf_name ] ] ]
endpoint diameter
Specify the endpoint name as Diameter.
For Diameter endpoint, select gx or gy interface.
vip-ip ip_address
Specify the IPv4 address of the configured endpoint.
Specify the interface name.
Note
vip-interface is a bonded interface which is associated with VRF.
vip-port vip_port
Specify the port number of endpoint.
vrf vrf_name
Specify the VRF name defined using global VRF configuration.
instance instance-id endpoint ep cpu
Configures K8 pod CPU configuration.
Command Mode
Syntax
cpu request cpu_resource_request max-process max_processes
Specify the maximum number of parallel OS threads to use.
Must be an integer in the range of 1-32.
Specify the CPU resource request in millicores.
Must be an integer in the range of 100-1000000.
Usage Guidelines
Use this command to configure the K8 pod CPU configuration.
instance instance-id endpoint ep extended-service
Enables service pod to run on Session VM.
Command Mode
Syntax
extended-service replicas replicas_per_node nodes node_replicas
nodes node_replicas
Must be an integer.
Default Value: 2.
Must be an integer.
Default Value: 2.
Usage Guidelines
Use this command to enable service pod to run on session VM. Service pods are spawned in Session VM.
instance instance-id endpoint ep heartbeat
Configures PFCP path management.
Command Mode
Syntax
heartbeat interval heartbeat_interval max-retransmissions max_retransmissions retransmission-timeout retransmission_timeout
Must be an integer from the following: 0, 60-360.
Default Value: 60.
Specify the maximum number of retries for PFCP heartbeat request.
Default Value: 3.
Specify the heartbeat retransmission timeout in seconds.
Default Value: 5.
Usage Guidelines
Use this command to configure PFCP path management.
instance instance-id endpoint gtpprime
Configures GTP Prime endpoint parameters.
Command Mode
Exec > Global Configuration (config) > Instance ID Configuration (config-instance-id-instance_idendpoint gtpprime )
Syntax
endpoint gtpprime [ storage storage_capacity| replicas replicas_count| nodes nodes_count  | interface Gz [ vip-ip  vip_ip vip-port vip-port vip-interface vip-interface vrf vrf ] ]
storagestorage_capacity
Note
CLI doesn't allow changing storage size while system is running. To change the storage size, you must make the system inactive.
nodes nodes_count
(Optional) This property is ignored. You may skip configuring it.
Note
When the system is active and under the Gz interface, if there are any add or update vip configurations to use a new value, ensure to restart the udp-proxy.
instance instance-id endpoint ep interface
Configures the endpoint interface.
Command Mode
Exec > Global Configuration (config) > Instance ID Configuration (config-instance-id-instance_id ) > Endpoint endpoint_type Configuration (config-endpoint-endpoint_type )
Syntax
interface interface_type
Specify the alias name for certificate.
dscp dscp_value
Specify whether to enable Go-based encoder-decoder in GTP protocol message handling. By default, it is enabled.
  • false
  • true
instancetype ep_local_interface_type
  • Dual
  • IPv4
  • IPv6
Specify the interface type.
loopbackEth pod_interface
Specify the pod interface.
Must be a string.
Specify the port number.
Must be an integer.
  • http
  • https
Usage Guidelines
Use this command to configure the interface.
instance instance-id endpoint ep interface dispatcher
Displays the dispatcher queue support details for the interface.
Command Mode
Exec > Global Configuration (config) > Instance ID Configuration (config-instance-id-instance_id ) > Endpoint endpoint_type Configuration (config-endpoint-endpoint_type ) > Interface interface_type Configuration (config-interface-interface_type )
Syntax
dispatcher { cache { false | true } | capacity queue_capacity | count dispatcher_queues_count | expiry cache_entry_expiry_duration | nonresponsive cache_entry_expiry_duration | outbound { false | true } |rate-limit queue_rate_limit | threshold outstanding_requests_per_queue_cache }
Specify to enable or disable disable retransmission cache support.
  • false
  • true
Specify the capacity of each queue.
Must be an integer.
Specify the count of dispatcher queues.
Must be an integer.
Default Value: 0.
Specify, in milliseconds, the responded cache entry expiry duration.
Must be an integer.
Default Value: 60000.
Specify, in milliseconds, the non-responsive cache entry expiry duration.
Must be an integer.
Default Value: 30000.
Specify to enable or disable queue support for outbound messages.
  • false
  • true
Specify the rate limit for each queue.
Must be an integer.
Default Value: 0.
Specify the outstanding requests per queue cache.
Must be an integer.
Usage Guidelines
Use this command to view dispatcher queue support details for the interface.
instance instance-id endpoint ep interface echo
Configures GTP-C path management.
Command Mode
Syntax
echo interval echo_interval retransmission-timeout retransmission_timeout max-retransmissions max_retransmissions
Specify the echo interval in seconds.
Specify the maximum number of retries for GTP echo request.
Specify the echo retransmission timeout in seconds.
Usage Guidelines
Use this command to configure GTP-C path management.
instance instance-id endpoint ep interface heartbeat
Enables PFCP path management.
Command Mode
Syntax
heartbeat interval heartbeat_interval retransmission-timeout retransmission_timeout max-retransmissions max_retransmissions
Specify the heartbeat interval in seconds. To disable, configure to 0.
Must be an integer from the following: 0, 1-3600.
Default Value: 60.
Must be an integer in the range of 0-15.
Default Value: 4.
Default Value: 5.
Usage Guidelines
Use this command to enable PFCP path management.
instance instance-id endpoint ep interface internal base-port
Configures the internal base-port to start endpoint parameter.
Command Mode
Syntax
internal base-port start base_port_to_start_ep
Specify the base port to start endpoint.
Must be an integer in the range of 1024-65535.
Usage Guidelines
Use this command to configure the internal base-port to start endpoint parameter.
instance instance-id endpoint ep interface overload-control client threshold critical
Configures critical threshold parameters for overload control protection.
Command Mode
Syntax
critical critical_threshold action critical_threshold_action
Specify the action to be taken when critical threshold limit is hit.
Specify the critical threshold limit for outstanding requests.
Must be an integer in the range of 10-100000.
drop
Specify to drop if threshold is hit.
exclude
Specify to not apply Overload Control Mechanism for priority messages.
message-priority message_priority
Specify message priorities higher or equal to the configured value.
redirect-code redirect_status_code
Specify the redirect status code if threshold is hit.
Must be an integer in the range of 100-600.
redirect
Specify to redirect if threshold is hit.
reject-code reject_status_code
Specify reject status code if threshold is hit.
reject
Specify to reject if threshold is hit.
url redirection_url
Specify the redirection URL of new host.
Must be a string.
Usage Guidelines
Use this command to configure critical threshold parameters for overload control protection.
instance instance-id endpoint ep interface overload-control client threshold high
Configures high threshold parameters for overload control protection.
Command Mode
Syntax
high high_threshold action high_threshold_action
Specify the action to be taken when high threshold limit is hit.
drop
exclude
high high_threshold
Specify the high threshold limit for outstanding requests.
redirect
reject
url redirection_url
Must be a string.
Usage Guidelines
Use this command to configure high threshold parameters for overload control protection.
instance instance-id endpoint ep interface overload-control client threshold low
Configures low threshold parameters for overload control protection.
Command Mode
Syntax
low low_threshold action low_threshold_action
Specify the action to be taken when low threshold limit is hit.
drop
exclude
low low_threshold
Specify the low threshold limit for outstanding requests.
redirect
reject
url redirection_url
Must be a string.
Usage Guidelines
Use this command to configure low threshold parameters for overload control protection.
instance instance-id endpoint ep interface overload-control endpoint threshold critical
Command Mode
Syntax
drop
exclude
redirect
reject
url redirection_url
Must be a string.
Usage Guidelines
instance instance-id endpoint ep interface overload-control endpoint threshold high
Command Mode
Syntax
drop
exclude
high high_threshold
redirect
reject
url redirection_url
Must be a string.
Usage Guidelines
instance instance-id endpoint ep interface overload-control endpoint threshold low
Command Mode
Syntax
drop
exclude
low low_threshold
redirect
reject
url redirection_url
Must be a string.
Usage Guidelines
instance instance-id endpoint ep interface overload-control msg-type messageConfigs
Configures the message configuration parameters.
Command Mode
Syntax
messageConfigs msg-type message_type msg-priority message_priority pending-request pending_requests priority message_priority queue-size queue_size rate-limit rate_limit reject-threshold reject_threshold reject-action { drop-req | reject-req }
Specify the priority of the message.
  • high
  • low
Specify the message type.
  • session-report —This message type is applicable for PFCP endpoint and Sxa interface.
  • create-session-request —This message type is applicable for GTP endpoint and S11 and S5 interfaces.
Specify the pending requests count in virtual queue.
Must be an integer.
Specify the priority of messages to start rejecting if overload is reached.
Must be an integer.
Specify the capacity of each virtual queue.
Must be an integer.
Specify the rate limit for virtual queue.
Must be an integer.
Specify the limit to reject incoming messages if this threshold percentage of pending requests are present.
Must be an integer.
Specify to drop or reject the create session request messages when the threshold reached for requests in virtual queue.
Usage Guidelines
Use this command to configure the message configuration parameters.
Important
If the rate limiting configuration is enabled for S11 or S5 interface, it will also apply to emergency calls and WPS sessions, potentially causing Create Session Request messages for these calls to be rejected or dropped.
instance instance-id endpoint ep interface path-failure
Configures the GTP Path Failure Detection Policy profile.
Command Mode
Syntax
path-failure detection-policy detection_policy_name
Specify the failure detection policy name.
Must be a string.
Usage Guidelines
Use this command to configure the GTP Path Failure Detection Policy profile.
instance instance-id endpoint ep interface retransmission
Configures retransmission parameters.
Command Mode
Syntax
retransmission timeout retransmission_interval max-retry max_retry
max-retry max_retry
Specify the maximum number of times to request retry attempts. To disable retransmission, set to 0.
Must be an integer in the range of 0-5.
Specify the retransmission interval in seconds. To disable retransmission, set to 0.
Usage Guidelines
Use this command to configure retransmission parameters.
instance instance-id endpoint ep interface secondary-ip
Configures secondary IP address used in FTIED creation for new requests.
Command Mode
Syntax
secondary-ip list-entry secondary_ip_addresses
Specify the list of secondary IP addresses.
-Or-
Usage Guidelines
Use this command to configure secondary IP address used in FTIED creation for new requests.
instance instance-id endpoint ep interface sla
Configures the SLA parameters.
Command Mode
Syntax
sla response response_time procedure procedure_time
Specify, in milliseconds, the procedure time.
Must be an integer in the range of 1000-120000.
Specify, in milliseconds, the response time.
Must be an integer in the range of 1000-180000.
Usage Guidelines
Use this command to configure the SLA parameters.
instance instance-id endpoint ep interface supported-features
Enables supported features.
Command Mode
Syntax
supported-features load-control overload-control
load-control
Specify to enable load control.
overload-control
Specify to enable overload control.
Usage Guidelines
Use this command to enable supported features.
instance instance-id endpoint ep interface sx-path-failure
Configures the SX Path Failure Detection Policy profile.
Command Mode
Syntax
sx-path-failure sx-detection-policy policy_profile_name
Specify name of the SX Path Failure Detection Policy profile.
Must be a string.
Usage Guidelines
Use this command to configure the SX Path Failure Detection Policy profile.
instance instance-id endpoint ep interface vip
Configures the virtual IP address (VIP) parameters.
Command Mode
Syntax
vip { vip-ip host_address | vip-port port_number } offline
offline
Specify when the virtual IP address (VIP) is offline.
Specify the interface name to advertise BGP router.
Must be a string.
vip-ip host_address
Specify the host address.
Must be a string.
Must be an integer.
Usage Guidelines
Use this command to configure the VIP address parameters.
instance instance-id endpoint ep interface vip6
Configures VIP IP6 parameters.
Command Mode
Syntax
vip6 vip-ip6 vip_ip6 vip-ipv6-port port_number offline
offline
Specify the VIP IP as offline.
vip-ip6 vip_ip6
Specify the host detail.
Must be a string.
Must be an integer.
Usage Guidelines
Use this command to configure VIP IP6 parameters.
instance instance-id endpoint ep internal base-port
Command Mode
Syntax
Usage Guidelines
instance instance-id endpoint ep labels pod-config
Configures K8 node affinity label configuration.
Command Mode
Syntax
pod-config key label_key value label_value
key label_key
Specify the key for the label.
Must be a string.
value label_value
Specify the value of the label.
Must be a string.
Usage Guidelines
Use this command to configure the K8 node affinity label configuration.
instance instance-id endpoint ep memory
Configures K8 pod memory configuration.
Command Mode
Syntax
memory request memory_request limit memory_limit
limit memory_limit
Specify the maximum memory resource in use, in megabytes.
Must be an integer in the range of 100-200000.
Specify the memory resource request, in megabytes.
Usage Guidelines
Use this command to configure the K8 pod memory configuration.
instance instance-id endpoint ep path-failure
Configures GTP path failure detection policy profile.
Command Mode
Syntax
Specify the detection policy profile.
Must be a string.
Usage Guidelines
Use this command to configure the GTP path failure detection policy profile.
instance instance-id endpoint ep retransmission
Command Mode
Syntax
retransmission max-retry max_retry timeout retransmission_interval
max-retry max_retry
Default Value: 3.
Default Value: 2.
Usage Guidelines
instance instance-id endpoint ep secondary-ip
Command Mode
Syntax
-Or-
Usage Guidelines
instance instance-id endpoint ep sla
Configures the response and procedure duration parameters.
Command Mode
Syntax
sla response response_duration procedure procedure_duration
Specify the procedure duration in milliseconds.
Specify the response duration in milliseconds.
Usage Guidelines
Use this command to configure the response and procedure duration parameters.
instance instance-id endpoint ep sx-path-failure
Configures Sx Path Failure Detection Policy Profile parameter.
Command Mode
Syntax
sx-path-failure sx-detection-policy sx_detection_policy_name
Specify name of the Sx Path Failure Detection policy.
Must be a string.
Usage Guidelines
Use this command to configure the Sx Path Failure Detection Policy Profile parameter.
instance instance-id endpoint ep system-health-level crash
Configures system health crash parameters.
Command Mode
Syntax
crash cpu-percent cpu_percentage memory-in-mbs memory num-of-goroutine goroutine_per_core
Specify the CPU percentage.
Must be an integer.
Default Value: 80.
Specify the memory in MBs.
Must be an integer.
Default Value: 2048.
Specify the number of goroutine per core.
Must be an integer.
Default Value: 45000.
Usage Guidelines
Use this command to configure system health crash parameters.
instance instance-id endpoint ep system-health-level critical
Configures system health critical parameters.
Command Mode
Syntax
critical cpu-percent cpu_percentage memory-in-mbs memory num-of-goroutine goroutine_per_core
Must be an integer.
Default Value: 60.
Must be an integer.
Must be an integer.
Default Value: 35000.
Usage Guidelines
Use this command to configure system health critical parameters.
instance instance-id endpoint ep system-health-level warn
Configures system health warning parameters.
Command Mode
Syntax
warn cpu-percent cpu_percentage memory-in-mbs memory num-of-goroutine goroutine_per_core
Must be an integer.
Default Value: 50.
Must be an integer.
Default Value: 512.
Must be an integer.
Default Value: 25000.
Usage Guidelines
Use this command to configure system health warning parameters.
instance instance-id endpoint ep vip
Configures virtual IP (VIP) parameters.
Command Mode
Syntax
vip-ip vip_ipv4_detail [ vip-port vip_port_number | vip-interface vip_interface_name | offline ]
offline
Specify the VIP-IP as offline.
Must be a string.
Specify the IPv4 detail.
Must be a string.
Specify the VIP port number.
Must be an integer.
Usage Guidelines
Use this command to configure VIP parameters.
instance instance-id endpoint ep vip6
Configures VIP IPv6 parameters.
Command Mode
Syntax
vip-ipv6 vip_ipv6_detail [ vip-ipv6-port vip_ipv6_port_number | offline ]
offline
Must be an integer.
Specify the IPv6 detail.
Must be a string.
Usage Guidelines
Use this command to configure VIP IPv6 parameters.
instance instance-id endpoint fqdn
Configures the FQDN at endpoint level.
Command Mode
Exec > Global Configuration (config) > Instance Configuration (config-instance-instance-idinstance_id )
Syntax
endpoint  endpoint_name { fqdn fqdn_value }
  • endpoint endpoint_name —Specify the endpoint name within the instance. For example: SBI interface.
  • fqdn fqdn_value —Specify the FQDN value for the specified endpoint. FQDN value must be string.
Usage Guidelines
Use this command to configure FQDN at endpoint level.
instance instance-id endpoint gtp interface interface-name
Configures encoder and decoder for the IEs that are associated with the GTPC endpoint pod.
Command Mode
Syntax
endpoint gtp interface  interface_name  enable-direct-encdec true | false
Specify the interface name, such as s5e and s11.
enable-direct-encdec { true | false } dscp_value
Specify whether to enable the encoder and decoder to optimize the encoding and decoding of the IEs that are associated with the GTPC endpoint pod. By default, it is disabled.
  • false
  • true
Usage Guidelines
Use this command to configure the encoder and decoder for the IEs that are associated with the GTPC endpoint pod.
instance instance-id endpoint pfcp interface n4 reactivate-peer condition
Reactivates the blocked UPF associated with the PFCP endpoint pod.
Command Mode
Syntax
endpoint pfcp interface interface_name reactivate-peer condition [ blocked ] attributes [ frequency  frequency_timer ]
Specify the condition as blocked to reactivate the blocked UPF.
attributes
Specify the attributes to configure to reactivate the blocked UPF.
Configure the frequency timer to reactivate the blocked UPF once the timer is over.
The value of the command frequency ranges between 60 to 86400.
The frequency parameter does not have any default values.
Note
It is mandatory to configure the frequency parameter within the defined range. If the frequency parameter is not configured within the range, the system by default takes zero as the input. As a result, the identified UPF does not get blocklisted even if the alarm is triggered.
Usage Guidelines
Use this command to reactivate the blocked UPF once the timer is over.
instance instance-id endpoint radius
Configures the RADIUS endpoint parameters.
Command Mode
Exec > Global Configuration (config) > Instance ID Configuration (config-instance-id-instance_idendpoint radius )
Syntax
endpoint radius enable-async { false | true }
endpoint radius
Specify the endpoint name as RADIUS.
Specify whether to enable asynchronous communication to send RADIUS Authentication and Accounting messages towards udp-proxy and CoA message towards smf-service. By default, it is disabled.
  • false
  • true
Default value is false.
Note
Any modifications to this configuration require a restart of the radius-ep pods.
instances instance
Configures SMF instance.
Command Mode
Syntax
instances instance instance_id system-id system_id cluster-id cluster_id slice-name slice_name
Specify the instance cluster ID.
Must be a string.
Specify the CDL slice name associated with instance ID.
Must be a string.
system-id system_id
Specify the instance system ID.
Must be a string.
Usage Guidelines
Use this command to configure SMF instance.
instance instance-id interface fqdn
Configures the FQDN at interface level.
Command Mode
Syntax
endpoint  endpoint_name { interface interface_name { fqdn fqdn_value } }
  • interface interface_name —Specify the interface for which the FQDN is being configured. For example: N7, N10, or N11 interface.
Usage Guidelines
Use this command to configure FQDN at interface level.
instance instance-id smf-fqdn
Configures the FQDN for SMF instance.
Command Mode
Exec > Global Configuration (config) > SMF Profile Configuration (config-profile-smf-profile_name )
Syntax
 instance instance_id smf-fqdn fqdn_value
  • instance instance_id —Specifiy the instance identifier for the SMF. Replace instance-id with the appropriate instance number, such as 1.
  • smf-fqdn fqdn_value —Specify the FQDN for the SMF.
Usage Guidelines
Use this command to configure SMF’s FQDN under SMF profile for each instance.
ipam
Configures IP Address Management (IPAM) configuration parameters.
Command Mode
Syntax
ipam
Usage Guidelines
Use this command to configure IPAM configuration parameters.
exec-ipam reclaim-chunk
Configures SMF to instantly reclaim under-utilized IP chunks.
Command Mode
Exec
Syntax
exec-ipam reclaim-chunk { utilization-threshold utilization_threshold inactivity-threshold inactivity_threshold [ instance grInstance ] [ pool-name poolName ] [ chunk-start-ip ip ] }
exec-ipam
Executes IPAM commands.
reclaim-chunk
Executes IP-chunk reclamation procedure.
Configures the utilization threshold for reclamation.
Configures inactivity threshold for reclamation in seconds.
instance grInstance
Configures the GR Instance for which the auto-reclamation process is to be executed.
pool-name poolName
Specifies the pool for which the auto-reclamation process is to be executed.
chunk-start-ip ip
Specifies the IP with which the chunk starts for which the auto-reclamation process is to be executed.
Usage Guidelines
Use this command to instantly re-claim under-utilized IP chunks.
ipam dp
Displays IPAM data-plane allocations.
Command Mode
Exec
Syntax
show ipam dp dp_name [ options ]
Usage Guidelines
Use this command to view IPAM data-plane allocations.
ipam instance
Configures the instance configuration parameters.
Command Mode
Exec > Global Configuration (config) > IPAM Configuration (config-ipam)
Syntax
Usage Guidelines
Use this command to configure the instance configuration parameters.
ipam instance address-pool
Configures IPAM address pools.
Command Mode
Exec > Global Configuration > IPAM Configuration
Syntax
address-pool address_pool_name [ static | offline  | dhcp  | vrf-name vrf_name ]
Specify name of the address pool.
Must be a string of 1-128 characters in the ipam-str pattern. For information on the ipam-str pattern, see the Input Pattern Types chapter.
address-quarantine-qsize max_ips_in_quarantine_queue
Specify the maximum number of IPs to be held in quarantine queue per-dp, per-af, per-instance.
Must be an integer.
address-quarantine-timer address_quarantine_timer_interval
Specify the address quarantine timer interval in seconds.
Must be an integer in the range of 4-3600.
Default Value: 4.
offline
Specify the pool as an offline pool.
static
Specify the pool as a static pool.
dhcp
Specify the pool as the DHCP pool.
vrf-name vrf_name
Specify name of the VRF.
Usage Guidelines
Use this command to configure IPAM address pools.
ipam instance address-pool ipv4
Configures IPv4 parameters.
Command Mode
Exec > Global Configuration (config) > IPAM Configuration (config-ipam) > Instance Configuration (config-instance-instance_id ) > Address Pool Configuration (config-address-pool-address_pool_name )
Syntax
ipv4
Usage Guidelines
Use this command to configure IPv4 parameters.
ipam instance address-pool ipv4 address-range
Configures IPv4 address ranges.
Command Mode
Exec > Global Configuration (config) > IPAM Configuration (config-ipam) > Instance Configuration (config-instance-instance_id ) > Address Pool Configuration (config-address-pool-address_pool_name ) > IPv4 Configuration (config-ipv4)
Syntax
address-range start_ipv4_address end_ipv4_address [ offline ]
Specify the start address of the IPv4 address range.
nexthop-forwarding-address nexthop_forwarding_address
Specify the nexthop forwarding address.
offline
Specify the IPv4 address range as offline.
end_ipv4_address
Specify the end address of the IPv4 address range.
Usage Guidelines
Use this command to configure IPv4 address ranges.
ipam instance address-pool ipv4 chunk-group
Configures IPv4 chunk group size for a pool.
Command Mode
Syntax
chunk-group { chunks-per-group { 2 | 4| 8 } reserve-contiguous-groups }
chunk-group
Allows to configure chunk-groups for a pool.
Defines the number of chunks in a chunk group. The values can be either 2, 4, or 8.
Allows reserving contiguous chunk-groups as per max-upf-session defined in the UPF or DNN profile.
Usage Guidelines
Use this command to configure IPv4 chunk group.
ipam instance address-pool ipv4 prefix-range
Configures prefix range parameters.
Command Mode
Syntax
prefix-range prefix_value length prefix_length [ offline ]
Specify the prefix length.
Must be an integer in the range of 1-31.
offline
Specify to set the IPv4 prefix to offline mode.
prefix prefix_value
Specify the prefix value.
Usage Guidelines
Use this command to configure prefix range parameters.
ipam instance address-pool ipv4 split-size
Configures chunk split size.
Command Mode
Command Mode
Exec > Global Configuration (config) > IPAM Configuration (config-ipam) > Instance Configuration (config-instance-instance_id ) > Address Pool Configuration (config-address-pool-address_pool_name ) > IPv6 Configuration (config-ipv6) > Address Range Configuration (config-address-ranges)
Syntax
split-size [ [ no-split ] [ per-cache number_of_addresses ] [ per-dp number_of_addresses ] ]
no-split
Specify not to split the address range into smaller chunks.
Specify the number of addresses per chunk for IPAM cache allocation. Specify in power of 2.
Must be an integer in the range of 2-262144.
Specify the number of addresses per chunk for data-plane allocation. Specify in power of 2.
Usage Guidelines
Use this command to configure chunk split sizes.
ipam instance address-pool ipv4 threshold
Configures pool thresholds.
Command Mode
Exec > Global Configuration (config) > IPAM Configuration (config-ipam) > Instance Configuration (config-instance-instance_id ) > Address Pool Configuration (config-address-pool-address_pool_name ) > IPv4 Configuration (config-ipv4) > Address Range Configuration (config-address-ranges)
Command Mode
Syntax
threshold upper-threshold upper_threshold
Specify the upper threshold in percentage.
Usage Guidelines
Use this command to configure pool thresholds.
ipam instance address-pool ipv4 vlan
Configures the VLAN ID to receive the IPv4 addresses.
Command Mode
Syntax
vlan vlan_id
vlan vlan_id
Configure the VLAN ID to receive the IPv4 address.
Usage Guidelines
Use this CLI to configure VLAN ID.
ipam instance address-pool ipv6
Configures IPv6 parameters.
Command Mode
Syntax
address-range
Usage Guidelines
Use this command to configure IPv6 parameters.
ipam instance address-pool ipv6 address-ranges address-range
Configures IPv6 address ranges.
Command Mode
Syntax
address-ranges address-range start_ipv6_address end_ipv6_address [ offline ]
offline
Specify the IPv6 address range as offline.
end_ipv6_address
Specify the end address of the IPv6 address range.
start_ipv6_address
Specify the start address of the IPv6 address range.
Usage Guidelines
Use this command to configure IPv6 address ranges.
ipam instance address-pool ipv6 address-ranges prefix-range
Command Mode
Syntax
prefix-ranges prefix-range [ prefix prefix_value ] [ length prefix_length ] [ offline ]
Must be an integer in the range of 96-127.
offline
Specify to set the IPv6 prefix to offline mode.
prefix prefix_value
Usage Guidelines
ipam instance address-pool ipv6 prefix-ranges prefix-length
Configures IPv6 prefix length that should be used for IP allocation.
Command Mode
Exec > Global Configuration > IPAM Configuration > Address Pool Configuration > Prefix Ranges Configuration
Syntax
prefix-length prefix_length
Specify the prefix length for IP allocation. The system will always allocate IPs from the pool with the specified prefix.
Must be an integer in the range of 2-64.
Usage Guidelines
Use this command to configure IPv6 prefix length.
ipam instance address-pool ipv6 address-ranges chunk-group
Configures chunk group for IPv6 address ranges.
Command Mode
Syntax
chunk-group
This CLI allows to configure chunk-groups for a pool.
Usage Guidelines
Use this command to configure IPv6 chunk group size for address range.
ipam instance address-pool ipv6 address-ranges split-size
Command Mode
Command Mode
Syntax
no-split
Usage Guidelines
ipam instance address-pool ipv6 address-ranges threshold
Command Mode
Command Mode
Syntax
Usage Guidelines
ipam instance address-pool ipv6 vlan
Configures the VLAN ID to receive the IPv6 addresses.
Command Mode
Syntax
vlan vlan_id
vlan vlan_id
Configure the VLAN ID to receive the IPv6 address.
Usage Guidelines
ipam instance address-pool ipv6 prefix-ranges prefix-range
Configures IPv6 prefix ranges.
Command Mode
Syntax
Must be an integer in the range of 1-63.
offline
Specify the IPv6 prefix range as offline.
Specify the IPv6 prefix range.
Usage Guidelines
Use this command to configure IPv6 prefix ranges.
ipam instance address-pool ipv6 prefix-ranges chunk-group
Configures chunk group for IPv6 prefix ranges.
Command Mode
Syntax
chunk-group
Usage Guidelines
Use this command to configure IPv6 chunk group size for prefix range.
ipam instance address-pool ipv6 prefix-ranges split-size
Command Mode
Command Mode
Syntax
no-split
Usage Guidelines
ipam instance address-pool ipv6 prefix-ranges threshold
Command Mode
Command Mode
Syntax
Usage Guidelines
ipam instance address-pool tags
Configures address pool tags.
Command Mode
Syntax
tags [ [ dnn dnn ] [ nssai nssai ] [ serving-area serving_area ] ]
dnn dnn
Specify the DNN.
Must be a string.
nssai nssai
Specify the NSSAI.
Must be a string.
Specify the serving area.
Must be a string.
Usage Guidelines
Use this command to configure address pool tags.
ipam instance audit chunk
Configures IPAM to enable or disable the reconciliation of IP chunks between SMF and UPF.
Command Mode
Syntax
audit chunk [ local | none ]
Configures audit activity on IPAM. It has two possible values:
  • local —Enables the feature.
  • none —Disables the feature.
Default value is none .
Usage Guidelines
Use this command to enable or disable the reconciliation of IP chunks between SMF and UPF.
ipam instance chunk throttling
Configure the IP chunk allocation throttling feature.
Command Mode
Syntax
chunk-throttling { false | true }
Specify to enable or disable the IP chunk throttling. To disable the throttling, set to false.
Default value: true
The IP chunk allocation throttle feature triggers throttling checks based on the maximum UPF sessions supported. However, throttling checks occur even if the maximum UPF sessions are not configured, causing unnecessary processing overhead. To address this issue, you shoud disable the IP throttling explicitly.
Usage Guidelines
Use this command to enable or disable IP chunk throttling.
ipam instance chunk-reclamation
Configures SMF to auto re-claim under-utilized IP chunks.
Command Mode
Syntax
chunk-reclamation { schedule tod-hour tod_hour_value schedule tod-minute tod_min_value utilization-threshold utilization_threshold inactivity-threshold inactivity_threshold }
chunk-reclamation
Configures periodic IP chunk reclamation process.
schedule
Configure the Time-of-day values for the chunk-reclamation process.
Configure the Time-of-day hour value for the chunk-reclamation process. The value range for schedule tod-hour is <0-23>.
This CLI configures the Time-of-day minute value for the chunk-reclamation process. The value range for tod-minute is <0-59>.
This CLI configures the utilization threshold for reclamation. The value range for utilization-threshold is <0-20>. The default value is 2.
This CLI configures the inactivity threshold for reclamation. The value range for inactivity-threshold is <0-3600>. The default value is 1800.
Usage Guidelines
Use this command to auto re-claim under-utilized IP chunks.
ipam instance data-sharding
Enable IPAM cache data sharding.
Command Mode
Syntax
data-sharding num-shards shards_number
Specify the number of shards for IPAM cache data. The value of shards_number must be an integer between 2 and 16.
To disable data sharding, use the no data-sharding command. By default, the data sharding is disabled.
Important
You must restart SMF for the configuration to take effect.
Usage Guidelines
Use this command to enable IPAM cache data sharding and configure the number of shards based on the number of IP pools, UPFs, and address types deployed. This configuration improves the IPAM performance and scalability.
ipam instance failure-handling route-updates
Configures the failure-handling of IP chunk operations between Session Management Function (SMF) and User Plane Function (UPF) in IP Address Management (IPAM).
failure-handling route-updates deactivate
no failure-handling route-updates deactivate
Syntax Description
Syntax
Description
Deactivate failure-handling configuration in IPAM.
Enable the failure-handling configuration in IPAM explicitly and remove the deactivation configuration.
Command Default
The failure-handling route-updates configuration in IPAM is enabled by default.
Command Modes
Global Configuration (# config)
IPAM Configuration (# config-ipam)
Instance Configuration (# config-instance-instance_id)
Usage Guidelines
Use this configuration to deactivate the failure-handling configuration in IPAM. To explicitly activate the configuration, remove the deactivation setting in IPAM.
Example:
[smf] smf(config-instance-1)# failure-handling route-updates deactivate
Example:
[smf] smf(config-instance-1)# no failure-handling route-updates deactivate
ipam instance min-dp-addr-size
Configures the minimum number of addresses to reserve per upf, per nm, per pool/tag.
Command Mode
Syntax
min-dp-addr-size [ [ ipv4-addr min_to_reserve ] [ ipv6-addr min_to_reserve ] [ ipv6-prefix min_to_reserve ] ]
Specify the minimum number of IPv4 address to reserve.
Must be an integer in the range of 16-262144.
Specify the minimum number of IPv6 address to reserve.
Must be an integer in the range of 32-262144.
Specify the minimum number of IPv6 prefix to reserve.
Usage Guidelines
Use this command to configure the minimum number of addresses to reserve per upf, per nm, per pool/tag.
ipam instance source
Configures pool-datastore source selection.
Command Mode
Syntax
source local
local
Specify to use local address pool datastore.
Usage Guidelines
Use this command to configure pool-datastore source selection.
ipam instance source external ipam
Configures external IPAM server for pool information.
Command Mode
Syntax
source external ipam [ [ host ip_address ] [ port port_number ] [ vendor vendor_id ] ]
host ip_address
Specify IP address of the IPAM server.
-Or-
port port_number
Specify port number of the IPAM server.
Must be an integer in the range of 1-65535.
vendor vendor_id
Specify the IPAM server's vendor ID. Default: cisco.
Must be one of the following:
  • cisco
Usage Guidelines
Use this command to configure external IPAM server for pool information.
ipam instance threshold
Configures global upper thresholds.
Command Mode
Syntax
threshold [ [ ipv4-addr ipv4_address_threshold ] | [ ipv6-addr ipv6_address_threshold ] | [ ipv6-prefix ipv6_prefix_threshold ] ]
Specify the IPv4 address threshold in percentage.
Specify the IPv6 address threshold in percentage.
Specify the IPv6 prefix threshold in percentage.
Usage Guidelines
Use this command to configure global upper thresholds.
ipam pool
Displays IPAM pool allocation information.
Command Mode
Exec
Syntax
show ipam pool pool_name
Usage Guidelines
Use this command to view IPAM pool allocation information.
ipam pool ipv4-addr
Displays IPAM pool IPv4 address information.
Command Mode
Exec
Syntax
show ipam pool pool_name ipv4-addr
Usage Guidelines
Use this command to view IPAM pool IPv4 address information.
ipam pool ipv6-addr
Displays IPAM pool IPv6 address information.
Command Mode
Exec
Syntax
show ipam pool pool_name ipv6-addr
Usage Guidelines
Use this command to view IPAM pool IPv6 address information.
job
Suspends the jobs that are running in the background.
Privilege Level
Security Administrator, Administrator
Command Mode
Exec
Syntax
job stop job_id
job_id
Specify the job ID for suspending the corresponding job.
Must be an integer.
Usage Guidelines
Use this command to suspend the jobs that are running in the background.
k8 ccg
Configures coverage build parameters.
Command Mode
Syntax
k8 ccg coverage-build { false | true }
Specify whether to enable or disable coverage build.
  • false
  • true
Default Value: false.
Usage Guidelines
Use this command to configure the coverage build parameters.
k8 ccg coverage
Configures Code Coverage Utils parameters.
Command Mode
Syntax
k8 ccg coverage container-stop container_stop
Specify container stop.
Must be a string.
Usage Guidelines
Use this command to configure the Code Coverage Utils parameters.
k8 label pod-group-config
Configures the K8 node affinity label parameters.
Command Mode
Syntax
k8 label vm_group key label_key value label_value
key label_key
Specify the label key.
Must be a string.
value label_value
Specify the label value.
Must be a string.
vm_group
Specify the VM group.
  • cdl-layer
  • oam-layer
  • protocol-layer
  • service-layer
Usage Guidelines
Use this command to configure the K8 node affinity label parameters.
leaf-prompting
Enables or disables automatic querying for leaf values.
Privilege Level
Command Mode
Exec
Syntax
leaf-prompting { false | true }
{ false | true }
Specify false to disable leaf prompting, and true to enable.
Usage Guidelines
Use this command to automatically query for leaf values.
license smart deregister
Configures the license parameters for the VNF deregistration.
Privilege Level
Command Mode
Exec
Syntax
deregister
Specify to deregister the VNF for smart licensing.
Usage Guidelines
Use this command to configure the license parameters for the VNF deregistration.
license smart register
Configures the license parameters for the VNF registration.
Privilege Level
Command Mode
Exec
Syntax
license smart register force idtoken token_id
register
Specify to register the VNF for Smart Licensing.
force
Specify to enable the force registration of the agent.
idtoken token_id
Specify the ID token to register the agent with.
Must be an integer.
Usage Guidelines
Use this command to configure the license parameters for the VNF registration.
license smart renew
Configures the license parameters for the VNF renewal.
Privilege Level
Command Mode
Exec
Syntax
license smart renew { ID | auth }
renew
Renew the smart agent IDs and authentication.
ID
Specify to renew the smart agent license registration information.
auth
Initiate the manual update of the license usage information with Cisco.
Usage Guidelines
Use this command to configure the license parameters for the VNF renewal.
local-instance
Configures local instance parameters.
Command Mode
Syntax
local-instance instance instance_id
Specify the local instance ID.
Usage Guidelines
Use this command to configure local instance parameters.
load factor
Configures the load factor frequency calculation parameters.
Command Mode
Syntax
load factor { calc-frequency calc_frequency_time | exclude-pods exclude_pod_name }
load factor
Configures the load factor calculation parameters.
Configures the load factor frequency time.
Must be an integer.
Configures the specific service pods to be excluded. It must be one of the following:
  • bfdmgr
  • bgpspeaker-pod
  • cache-pod
  • edr-monitor
  • georeplication-pod
Usage Guidelines
Use this command to configure the load factor for the system.
logging async application enable
Enables async logging.
Command Mode
Syntax
enable buffer-size buffer_size
Specify the buffer size for async logging.
Must be an integer.
Usage Guidelines
Use this command to enable async logging.
logging async monitor-subscriber enable
Command Mode
Syntax
Must be an integer.
Usage Guidelines
logging async tracing enable
Command Mode
Syntax
Must be an integer.
Usage Guidelines
logging async transaction enable
Command Mode
Syntax
Must be an integer.
Usage Guidelines
logging error
Configures error logging parameters.
Command Mode
Syntax
logging error stack status
stack status
Specify to enable or disable error stack.
  • disable
  • enable
Default Value: enable.
Usage Guidelines
Use this command to configure error logging parameters.
logging json-logging
Configures JSON logging in pod logs.
Command Mode
Syntax
[no] logging json-logging [ application | monitor-subscriber | transaction ]
no
Disables the JSON logging in the pod logs.
Enables the SMF-based application pods to start logging in the JSON format for the application , monitor-subscriber , and transaction log types.
Usage Guidelines
Use this command to enable or disable the JSON logging in pod logs.
logging level
Configures the logging level.
Command Mode
Syntax
logging level { application application_log_level | monitor-subscriber monitor_subscriber_log_level | tracing tracing_log_level | transaction transaction_log_level }
Specify the log level for application log type.
  • debug
  • error
  • info
  • off
  • trace
  • warn
Specify the log level for subscriber monitoring.
  • debug
  • error
  • info
  • off
  • trace
  • warn
Specify the log level for tracing log type.
  • debug
  • error
  • info
  • off
  • trace
  • warn
Specify the log level for transaction log type.
  • debug
  • error
  • info
  • off
  • trace
  • warn
Usage Guidelines
Configures logging parameters. Use this command to configure the logging level.
logging logger
Configures logger parameters.
Command Mode
Syntax
logging name logger_name
logger_name
Specify the logger name in the format "module.component.interface".
Must be a string.
Usage Guidelines
Use this command to configure logger parameters.
logging logger level
Command Mode
Syntax
logging name logger_name level { application application_log_level | tracing tracing_log_level | transaction transaction_log_level }
  • debug
  • error
  • info
  • off
  • trace
  • warn
  • debug
  • error
  • info
  • off
  • trace
  • warn
  • debug
  • error
  • info
  • off
  • trace
  • warn
  • debug
  • error
  • info
  • off
  • trace
  • warn
Usage Guidelines
Use this command to configure the logging level type.
logging transaction
Configures the transaction logging parameters.
Command Mode
Syntax
logging transaction { duplicate { enable | disable } | max-file-size max_file_size | max-rotation max_rotations | message { enable | disable } | persist { enable | disable } }
Specify whether to enable or disable duplicate logs in transaction logging.
  • disable
  • enable
Default Value: disable.
Specify the maximum transaction file size in MB.
Must be an integer in the range of 1-10000.
Default Value: 50.
max-rotation max_max_rotations
Specify the maximum number of file rotations.
Must be an integer in the range of 2-1000.
Default Value: 10.
Specify whether to enable or disable messages in transaction logging.
  • disable
  • enable
Specify whether to enable or disable file-based transaction logging.
  • disable
  • enable
Usage Guidelines
Use this command to configure the transaction logging parameters.
logout
Logout a specific session or a specific user from all sessions.
Privilege Level
Command Mode
Exec
Syntax
logout [ session session_id | user user_name ]
session session_id
Specify the session ID from the possible completion options.
Must be a string.
user user_name
Specify the user name or the user process from the possible completion options.
Must be a string.
Usage Guidelines
Use this command to log out a specific session or a specific user from all sessions.
message type
Configures the UDM message types.
Command Mode
Exec > UDM Service Configuration (config)
Syntax
message type { UdmRegistrationReq | UdmSdmGetUESMSubscriptionData | UdmSdmSubscribeToNotification | UdmSdmUnsubscribeToNotification | UdmSubscriptionReq | UdmUecmRegisterSMF  skip optional-ies [ epdgInd | registrationTime ]  | UdmUecmUnregisterSMF }
Configures any one of the following udm subscription message types:
  • UdmRegistrationReq
  • UdmSdmGetUESMSubscriptionData
  • UdmSdmSubscribeToNotification
  • UdmSdmUnsubscribeToNotification UdmSubscriptionReq
  • UdmUecmRegisterSMF
skip optional-ies [ epdgInd | registrationTime ] —Skips ePDG indication or Resgistration Time in the N10 Registration Request.
Note
The skip optional-ies [ epdgInd | registrationTime ] command is available only with UdmUecmRegisterSMF message.
Usage Guidelines
Use this command to configure the UDM message types.
mode debug exec action release-resource
Triggers the resource releasing process for N4 interface per UPF from SMF.
Command Mode
Exec
Syntax
mode debug exec  action release-resource attributes { interface n4 peer { ip upf_ip } } condition { dnn matches dnn-name }
debug
This keyword indicates that this is a debug mode operational CLI.
exec
This command executes the command to trigger N4 release per UPF from SMF.
action
Triggers an action to be performed.
release-resource
This is an optional command. Upon executing release-resource , the SMF triggers clean-up of subscriber/pool resources to the peer provided.
attributes
Defines the attributes to perform an action.
peer
The UPF peer can be defined using UPF IP address.
interface
Specifies the interface name to trigger the operation for.
condition
Specifies the additional condition to filter the data for selected operation. This is an optional filter.
dnn
Pools associated to this dnn-name will be cleared based on the given operator.
matches
This command verifies the DNN that matches the output modifiers.
Usage Guidelines
Use this command to trigger N4 resources or associations release process per UPF from the SMF.
monitor protocol
Configures the SMF to monitor the protocol.
Privilege Level
Command Mode
Exec
Syntax
monitor protocol { interface interface_name  [ capture-duration duration | gr-instance gr_instance | pcacp yes | | ] | list [ | ] }
Warning
Use the monitor protocol interface command cautiously, as it may disrupt user services. When used in a live network, it can cause session delays, call drops, and degrade system performance.
Specifies the name of interface on which PCAP is captured.
interface_name must be a string of possible values sbi, pfcp, gtpu, gtpc, gtp, radius, and diameter.
Note
For the Diameter interface, SMF uses the Monitor Protocol for packets.
duration Specifies the duration, in seconds, during which PCAP is captured.
Must be an integer.
The default value is 300 seconds.
Specifies the monitor protocol for given gr-instance only.
grinstance_monitorprotocol must be a string.
pcap yes
Enables PCAP file generation.
The default value is no.
list
Lists monitor protocol files.
Specifies output options:
  • append
  • begin
  • count
  • exclude
  • include
  • linnum
  • more
  • nomore
  • save
  • until
monitor active-instance-traffic
Configures the SMF to monitor the traffic on an active GR instance.
Privilege Level
Command Mode
Syntax
active-instance-traffic {  no-traffic-duration no_traffic_duration session-threshold session_threshold action { pod-restart | trigger-switch-over  } }
It is the CLI to configure active traffic monitoring on the pod.
Specifies the maximum allowed time (in seconds) of no traffic on an active instance. The value range is 10-300.
Minimum session count to start the active instance traffic monitoring. The value range is 10-10000000. The default value is 1000.
Action to take on condition fulfillment. The possible values for this command are pod-restart or trigger-switch-over . The default value is pod-restart .
Usage Guidelines
Use this command to monitor the traffic on an active GR instance.
monitor-protocol cpu-limit
Configures the CPU utilization of pods.
Privilege Level
Command Mode
Syntax
monitor protocol cpu-limit threshold_percentage
Specifies the CPU utilization threshold percentage, based on which the monitor ptotocol command in the Exec mode is restricted.
Must be an integer in the range of 1 - 100.
The default value is 70%.
monitor subscriber
Configures the SMF to monitor the subscribers.
Privilege Level
Command Mode
Exec
Syntax
monitor subscriber [ supi supi | imsi imsi | imei imei [ capture-duration duration  | gr-instancegr_instance | internal-messages yes |  namespace namespace  | nf-service nf-service | transaction-logs yes internal-messages yes | [ | ] ] ]
supi supi
Specify the subscriber identifier.
Must be a string.
imsi imsi
Specifyes the subscriber IMSI.
Must be a string.
imei imei
Specifyes the subscriber IMEI.
Must be a string.
Specifyes the duration in seconds during which PCAP is captured.
Must be an integer.
Specifyes the monitor subscriber for given gr-instance only.
Must be an integer.
Specifyes yes in order to enable internal messages.
By default it is disabled.
namespace namespace
Specify sgw or smf.
Specify sgw or smf.
Sets to yes in order to enable internal messages.
msid-opt
Clears subscriber data based on MSID.
Command Mode
Exec
Syntax
clear subscriber msid msid [ ebi eps_bearer_id | reactivation { false | true } ]
ebi eps_bearer_id
Specify the EPS Bearer ID.
Must be a string.
Specify if reactivation is requested.
  • false
  • true
Usage Guidelines
Use this command to subscriber data based on MSID.
nf-tls ca-certificates
Configures NF TLS certificate name and data configuration parameters.
Command Mode
Syntax
nf-tls ca-certificates certificate_alias_name [ cert-data certificate_data ]
Must be a string.
Specify the certificate data in PEM format.
Must be a string.
Usage Guidelines
Use this command to configure certificate name and data configuration parameters.
nf-tls certificate-status
Displays NF TLS certificate status.
Command Mode
Exec
Syntax
show nf-tls certificate-status [ [ certificate_name ] [ days days_to_expire ] [ podInstance pod_instance ] ]
days days_to_expire
Specify the number of days for the certificate to expire.
Must be a string.
Specify the Pod instance.
Must be a string.
certificate_name
Specify name of the certificate.
Must be a string.
Usage Guidelines
Use this command to view certificate status.
nf-tls certificates
Configures NF TLS certificate parameters.
Command Mode
Syntax
nf-tls certificates certificate_alias_name [ [ cert-data certificate_data ] [ private-key private_key ] ]
Must be a string.
Must be a string.
Specify the certificate private key in PEM format.
Must be a string.
Usage Guidelines
Use this command to configure NF TLS certificate parameters.
no
Restores the command history cache size to its default setting. See the history command.
Privilege Level
Command Mode
Exec
Syntax
no history
Usage Guidelines
Use this command to configure the command history cache size to its default setting. For more details, see the history command.
nodemonitor
Configures the nodemonitor pod to periodically check the operating state of other nodes.
Privilege Level
Command Mode
Syntax
nodemonitor mode { 0 | 1 | 2 | 3 interval wait_time }
mode { 0 | 1 | 2 | 3 interval wait_time}
Enable the node monitoring pod to switch to different modes depending on the operating state of nodes.
  • mode 0 —Disables the node monitoring functionality.
  • mode 1 —Enables the node monitoring and performs self-reboot only after reaching a hardcoded value of 2 seconds when two or more nodes are not reachable. This is the default setting.
  • mode 2 —Enables the node monitoring and performs self-reboot when two or more nodes are not reachable but not all the nodes.
  • mode 3 interval wait_time —Specify the time interval in seconds, after which the node monitoring pod is rebooted when two or more nodes are not reachable.
    wait_time must be an integer in the range of 5–300.
Usage Guidelines
Use this command to configure nodemonitor pod to periodically check the operating state of other nodes.
nrf discovery-info discovery-filter
Displays NF discovery filter information.
Command Mode
Syntax
show discovery-filter
Usage Guidelines
Use this command to view NF discovery filter information.
nrf discovery-info discovery-filter nf-discovery-profile
Displays discovery profile information.
Command Mode
Syntax
show nf-discovery-profile
Usage Guidelines
Use this command to view NF discovery profile information.
nrf discovery-info discovery-filter nf-discovery-profile nf-service
Displays NF service information.
Command Mode
Syntax
show nf-service
Usage Guidelines
Use this command to view NF service information.
nrf registration-info
Displays NRF registration information.
Command Mode
Exec
Syntax
show nrf [ registration-info [ gr-instance gr_instance ] ]
Specify the GR instance ID.
Must be a string.
Usage Guidelines
Use this command to view registration information.
nrf subscription-info
Displays NF subscription information.
Command Mode
Syntax
show nrf subscription-info
Usage Guidelines
Use this command to view NF subscription information.
nssai
Configures the list of DNN profile names.
Command Mode
Syntax
nssai name slice_name [ [ dnn profile_names_list ] [ sdt slice_differentiator_type ] [ sst slice_service_type ] [ tai-group-list tai_group_list ] ]
Specify the list of actual DNN profile names configured.
Must be a string.
name slice_name
Specify name of the slice.
Must be a string.
Specify the Slice Differentiator Type (SDT).
Must be a string in the octet-string24 pattern. For information on the octet-string24 pattern, see the Input Pattern Types chapter.
Specify the Slice/Service Type (SST).
Must be a string in the sst-string255 pattern. For information on the sst-string255 pattern, see the Input Pattern Types chapter.
Specify the list of TAI groups for this NSSAI.
Must be a string.
Usage Guidelines
Use this command to configure the list of actual DNN profile names.
paginate
Configures whether or not to paginate CLI command output.
Privilege Level
Command Mode
Exec
Syntax
paginate { false | true }
{ false | true }
Specify false to disable paginating CLI command output, and true to enable.
Must be either "false" or "true".
Usage Guidelines
Use this command to paginate the command output.
pcscf mark-online
Marks the failed P-CSCF addresses online.
Command Mode
Exec
Syntax
pcscf mark-online [ all | fqdn fqdn  | mw-ipv4 IPv4_address | mw-ipv6  IPv6_address ]
pcscf mark-online
Allows marking the failed P-CSCF address online. It has four possible values:
  • all — This command marks all the P-CSCF addresses online.
  • fqdn fqdn — This command specifies the FQDN to mark online.
  • mw-ipv4 IPv4_address — This command specifies the failed P-CSCF IPv4 address to mark online.
  • | mw-ipv6 IPv6_address — This command specifies the failed P-CSCF IPv6 address to mark online.
Usage Guidelines
Use this command to activate the failed P-CSCF addresses.
peers all
Displays the peer configuration information.
Command Mode
Exec
Syntax
show peers [ all ]
Usage Guidelines
Use this command to view peer configuration information.
policy
Configures the policy for PCF interaction or the N7 optimization.
Syntax
policy [ local | optimized ] rat-type [ nr | wlan | eutra ]
[local|optimized]
Specify the policy.
  • local
  • optimized
Note
In case you configure both policy local and policy optimized together, then policy local takes the precendence.
Specify the RAT type.
  • nr
  • wlan
  • eutra
Note
This keyword is optional. If rat-type is not configured then the policy local or policy optimized is valid for all the three RAT types, which are NR, WLAN, and EUTRA.
Usage Guidelines
Use this command to configure the policy for PCF interaction or the N7 optimization.
policy actionmgmt
This configuration adds action definition policies.
Command Mode
Syntax
policy actionmgmt policy_actionmgmt_name { actiondef actiondef_name { priority priority_number action action_name [ attributes { rulebase rulebase_name [ rules rules_name ] } ]
Configures the action to be executed.
Defines the action attributes to be executed.
Defines the priority in which the actions are to be executed. priority_number must be an integer from 1 to 127.
action action_name
Defines the actions associated with an actiondef in the order of priority. The action name can be one of the following:
  • activate-rulebase
  • continue-session
  • create-bearer
  • release-flow
  • release-flow-ho
  • release-session
  • terminate-session
  • extended-buffering
Note
The Reduced Capability feature supports the action extended-buffering .
For sematic and syntactic error handling, it supports release-session , release-flow , and release-flow-ho as actions.
attributes
Defines the attributes of a particular action. This is an optional command.
Defines a collection of protocol rules to match a flow and associated actions to be taken for matching flow.
rules rules_name
Defines a list of rules to be executed.
Usage Guidelines
This configuration is used to add action definition policies.
policy call-control-profile
Configures SGW call control profile for operator policy.
Syntax
call-control-profile sgw_cc_profile_name charging-mode sgw_charging_mode sgw-charging-profile sgw_charging_profile_name
Specify name of the SGW Call Control Profile for operator policy.
Must be a string.
Specify the SGW charging mode.
  • gtpp
  • none
Specify name of the associated SGW charging profile.
Usage Guidelines
Use this command to configure SGW call control profile for operator policy.
policy call-control-profile cc
Configures charging characteristics selection preference parameter.
Syntax
cc prefer cc_selection_preference
Specify the preference for selecting charging characteristics.
  • hlr-hss-value : Specify hlr-hss-value - value received from serving node.
  • local-value : Specify local-value - value defined locally.
Default Value: hlr-hss-value.
Usage Guidelines
Use this command to configure charging characteristics selection preference parameter.
policy call-control-profile cc local-value
Configures local value for charging characteristics.
Syntax
local-value profile profile_index
Specify the local profile index.
Must be an integer in the range of 1-15.
Default Value: 8.
Usage Guidelines
Use this command to configure local value for charging characteristics.
policy dnn
Configures the virtual DNN to operator DNN mapping.
Command Mode
Syntax
dnn dnn_policy_name [ profile dnn_profile_name ]
dnn dnn_policy_name
Specify name of the DNN policy.
Must be a string.
Specify name of the DNN profile.
Must be a string.
Usage Guidelines
Use this command to configure the virtual DNN to operator DNN mapping.
policy dnn dnn dnn
Configures the virtual DNN to a network DNN.
Syntax
dnn dnn_name [ profile dnn_profile_name ] dnn-list dnn_list
dnn-list dnn_list
Specify the additional list of DNNs to be associated for the DNN profile.
Must be a string.
dnn dnn_name
Specify name of the DNN.
Must be a string.
Must be a string.
Usage Guidelines
Use this command to configure the virtual DNN to a network DNN.
policy dnn dnn network-identifier
Configures the network identifier.
Command Mode
Exec > Global Configuration (config) > DNN Configuration (config-dnn-policy_name )
Syntax
dnn network-identifier network_identifier [ profile profile_name ] [ dnn-list dnn_list ]
Specify the network identifier.
Must be a string.
Specify name of the profile.
Must be a string.
Usage Guidelines
Use this command to configure the network identifier.
policy dnn dnn network-identifier operator-identifier
Configures the operator identifier.
Command Mode
Syntax
dnn network-identifier network_identifier operator-identifier operator_identifier [ profile profile_name ]
Specify the operator identifier.
Must be a string.
Must be a string.
Usage Guidelines
Use this command to configure the operator identifier.
policy dnn dnn operator-identifier
Command Mode
Syntax
dnn operator-identifier operator_identifier [ profile profile_name ] [ dnn-list dnn_list ]
Must be a string.
Must be a string.
Usage Guidelines
policy eventmgmt
Configures the event management policies and defines the attributes.
Command Modes
Syntax
policy eventmgmt eventmgmt_name priority event_priority   ruledef ruledef_name  actiondef actdef_name event  event_type
eventmgmt policy_eventmgmt_name
Configures the event management policies and attributes.
Defines the priority of a particular event management policy.
Defines a rule for a local policy that when matched an action is performed.
Configures the action name to be executed.
event event_type
Defines an event for which a particular action is to be performed. It supports the following events:
  • cb-resp
  • imexit
  • n1-modify
  • new-call
  • plmn-ch
  • subscription-change
  • ub-resp
  • xnho
  • imentry
  • paging-failure
Note
In the Reduced Capability feature, the command condition supports two options imentry and paging-failure .
For sematic and syntactic error handling, it supports n1-modify , cbr-resp , and ubr-resp event names.
For UDM data change notification, it supports subscription-change event name.
Usage Guidelines
This configuration is used for adding the event management policy.
policy extended-buffering
Configures the policy and attributes for extended buffering.
Command Modes
Syntax
policy extended-buffering extbuff { sbpc sbpc_count  ddnd ddnd_count } { dbpc dbpc_count dbd dbd_duration  }
Note
SBPC and DDND values are used during the Idle mode entry. DBPC and DBD values are used during Idle mode exit.
Specify the name of the instance for extended buffering policy.
sbpc sbpc_count
Define the value for SBPC.
ddnd ddnd_count
Define the value for DDND.
dbpc dbpc_count
Define the value for DBPC.
dbd dbd_duration
Define the DBD value.
policy network-capability
Configures Network Capability Policy configuration.
Command Mode
Syntax
policy network-capability policy_name [ link-mtu link_mtu | max-supported-pkt-filter max_supported_pkt_filter | nw-support-local-address-tft { false | true } ]
link-mtu link_mtu
Specify name of the Network Capability Policy.
Must be an integer in the range of 1280-2000.
Default Value: 1500.
Specify the maximum supported packet filters.
Must be an integer in the range of 16-256.
Default Value: 16.
Must be a string.
Enable or disable network support for local address in TFT.
  • false
  • true
Usage Guidelines
Use this command to configure Network Capability Policy configuration.
policy operator
Configures the operator policy configuration.
Command Mode
Syntax
policy operator policy_name call-control-profile sgw_cc_profile_name roaming-status roaming_status
Specify name of the associated SGW Call Control profile.
Specify name of the operator policy.
Must be a string.
Specify the roaming status.
  • roamer
  • visitor-lbo
Usage Guidelines
Use this command to configure the operator policy specific configuration.
Configures DNN policy parameters.
Command Mode
Exec > Global Configuration (config) > Operator Policy Configuration (config-operator-policy_name )
Syntax
policy dnn dnn_policy_name [ network-capability network_capability ]
dnn dnn_policy_name
Must be a string.
Specify the network capability.
Must be a string.
secondary secondary
Specify the secondary.
Must be a string.
Usage Guidelines
Use this command to configure DNN policy parameters.
policy path-failure-detection
Configures path failure detection policy-specific configuration.
Command Mode
Syntax
policy path-failure-detection policy_name max-remote-rc-change max_remote_rc_change
Specify the maximum remote restart counter change.
Must be an integer in the range of 1-255.
Specify name of the Path Failure Detection policy.
Must be a string.
Usage Guidelines
Use this command to configure path failure detection policy-specific configuration.
policy path-failure-detection ignore
Configures to ignore counter values, echo timeouts, or echo failures.
Command Mode
Exec > Global Configuration (config) > Path Failure Detection Policy Configuration (config-path-failure-detection-policy_name )
Syntax
ignore type ignore_type
type ignore_type
Specify to ignore restart counter values, echo timeouts, or echo failures.
  • control-rc-change
  • echo-failure
  • echo-rc-change
Usage Guidelines
Use this command to configure ignoring counter values, echo timeouts, or echo failures.
policy rulemgmt
This configuration allows adding rule definition policies.
Command Mode
Syntax
policy rulemgmt policy_rulemgmt_name ruledef rule_def condition condition_string
Defines a rule to be added in the policies.
ruledef rule_def
Configures a rule attribute. A ruledef is declared when the conditions match.
Defines the use cases for a rule. It supports the following conditions:
  • an-type
  • any
  • cause
  • duplicate-ip
  • sarea
  • rat matches redcap
  • hlcom is true
Note
In the Reduced Capability feature, the command condition supports two options rat matches redcap and hlcom is true .
For sematic and syntactic error handling, it supports cause-value matches and cause-source matches conditions.
Use the condition duplicate-ip to detect duplicate static IP addresses received from AAA or UDM.
Usage Guidelines
policy subscriber
Configures SMF policy parameters.
Command Mode
Syntax
policy subscriber policy_name
Specify name of the subscriber policy.
Must be a string.
Usage Guidelines
Use this command to configure SMF policy parameters.
policy subscriber list-entry
Configures operator policy selection match criteria definition.
Command Mode
Exec > Global Configuration (config) > Subscriber Policy Configuration (config-subscriber-policy_name )
Syntax
precedence precedence_number [ sst slice_service_type | sdt slice_differentiator_type | supi-start-range supi_start_range | supi-stop-range supi_stop_range   | instance-start-range instance_start_range | instance-stop-range instance_stop_range  | gpsi-start-range gpsi_start_range | gpsi-stop-range gpsi_stop_range | pei-start-range pei_start_range | pei-stop-range pei_stop_range | operator-policy operator_policy_name ]
Specify the GPSI start range.
Must be an integer in the range of 1000000000-999999999999999.
Specify the GPSI stop range.
imsi-start-range imsi_start_range
Specify the IMSI start range.
Must be an integer in the range of 100000000000000-9999999999999999.
imsi-stop-range imsi_stop_range
Specify the IMSI stop range.
Must be a string.
Specify the PEI start range.
Must be an integer in the range of 1000000000000-9999999999999999.
Specify the PEI stop range.
Specify the precedence for entry.
Must be an integer in the range of 1-2048.
Must be a string in the octet-string8 pattern. For information on the octet-string8 pattern, see the Input Pattern Types chapter.
Specify the SUPI start range.
Must be an integer in the range of 100000000000000-999999999999999.
Specify the SUPI stop range.
Specify the SMF instance start range for the DNN profile selection. Must be an integer in the range of 1 to 8.
Specify the SMF instance stop range for the DNN profile selection. Must be an integer in the range of 1 to 8.
Usage Guidelines
Use this command to configure operator policy selection match criteria definition.
policy subscriber list-entry imsi
Configures subscriber International Mobile Station Identification (IMSI).
Command Mode
Exec > Global Configuration (config) > Subscriber Policy Configuration (config-subscriber-policy_name ) > Subscriber Policy Precedence Configuration (config-subscriber-precedence )
Syntax
imsi mcc mobile_country_code mnc mobile_network_code
Specify the Mobile Country Code (MCC).
Must be a string in the three-digit pattern. For information on the three-digit pattern, see the Input Pattern Types chapter.
Specify the Mobile Network Code (MNC).
Must be a string in the two-or-three-digit pattern. For information on the two-or-three-digit pattern, see the Input Pattern Types chapter.
Usage Guidelines
Use this command to configure subscriber IMSI.
policy subscriber list-entry imsi msin
Configures MSIN range for mobile subscriber identification number.
Command Mode
Syntax
imsi msin first start_msin_range last end_msin_range
Specify starting value of the MSIN range.
Must be an integer in the range of 1-9999999999.
last end_msin_range
Specify the ending value of the MSIN range.
Usage Guidelines
Use this command to configure MSIN range for mobile subscriber identification number.
policy subscriber list-entry serving-plmn
Configures serving PLMN parameters.
Command Mode
Syntax
serving-plmn [ mcc mobile_country_code | mnc mobile_network_code | mnc-list mnc_list ]
Specify the Mobile Country Code (MCC) portion of the PLMN ID.
mnc-list mnc_list
Specify the MNC list.
Specify the Mobile Network Code (MNC) portion of the PLMN ID.
Usage Guidelines
Use this command to configure serving PLMN parameters.
policy sx-path-failure-detection
Configures Sx Path Failure Detection Policy-specific configuration.
Command Mode
Syntax
policy sx-path-failure-detection policy_name
Must be a string.
Usage Guidelines
Use this command to configure Sx Path Failure Detection Policy-specific configuration.
policy sx-path-failure-detection ignore
Configures to ignore heartbeat-retry-failure or the heartbeat-recovery-timestamp-change configuration.
Command Mode
Exec > Global Configuration (config) > Sx Path Failure Detection Policy Configuration (config-sx-path-failure-detection-policy_name )
Syntax
ignore ignore_type
ignore ignore_type
Specify to ignore heartbeat-retry-failure or the heartbeat-recovery-timestamp-change configuration.
  • heartbeat-recovery-timestamp-change
  • heartbeat-retry-failure
Usage Guidelines
Use this command to configure ignoring the heartbeat-retry-failure or the heartbeat-recovery-timestamp-change configuration.
policy upf-selection
Configures UPF selection policy parameters.
Command Mode
Syntax
policy upf-selection policy_name
Specify name of the UPF selection policy.
Must be a string.
Usage Guidelines
Use this command to configure UPF selection policy parameters.
policy upf-selection list-entry
Configures UPF selection match criteria definition.
Command Mode
Exec > Global Configuration (config) > UPF Selection Policy Configuration (config-upf-selection-policy_name )
Syntax
precedence entry_precedence
Must be an integer in the range of 1-4.
Usage Guidelines
Use this command to configure UPF selection match criteria definition.
policy upf-selection list-entry query-params
Configures the query parameter for UPF selection.
Command Mode
Exec > Global Configuration (config) > UPF Selection Policy Configuration (config-upf-selection-policy_name ) > UPF Selection Policy Precedence Configuration (config-upf-selection-precedence )
Syntax
query-params query_params
Specify the query parameters. If both pdn-type-subscription and pdn-type-session are configured, pdn-type-subscription will be considered.
  • dcnr
  • dnn
  • location
  • pdn-type-session
  • pdn-type-subscription
  • slice
Usage Guidelines
Use this command to configure the query parameter for UPF selection.
profile access
Configures the access profile.
Command Mode
Syntax
profile access access_profile_name
Specify name of the access profile.
Must be a string.
Usage Guidelines
Use this command to configure the access profile.
profile access eps-fallback cbr
Configures Create Dedicated Bearer parameters.
Command Mode
Exec > Global Configuration (config) > Access Profile Configuration (config-access-profile_name )
Syntax
eps-fallback cbr delay delay_duration max-retry max_retry timeout timeout_interval
Specify the Create Dedicated Bearer delay duration in milliseconds.
Must be an integer in the range of 0-10000.
Default Value: 0.
max-retry max_retry
Specify the Create Dedicated Bearer maximum retry count.
Must be an integer in the range of 0-10.
Default Value: 0.
Specify the Create Dedicated Bearer Retry interval in seconds.
Must be an integer in the range of 1-3.
Default Value: 1.
Usage Guidelines
Use this command to configure Create Dedicated Bearer parameters.
profile access eps-fallback guard
Configures handling EPS fallback expiry.
Command Mode
Syntax
eps-fallback guard timeout eps_fallback_timer
Specify the EPS fallback guard timer in milliseconds.
Must be an integer in the range of 500-15000.
Default Value: 10000.
Usage Guidelines
Use this command to configure handling EPS fallback expiry.
profile access eps-fallback trigger-cause group
Configures the cause to trigger EPSFallback.
Command Mode
Syntax
trigger-cause group cause-group cause_group value cause_types
Specify the cause group.
  • misc
  • nas
  • protocol
  • radioNetwork
  • transport
value cause_types
Specify the list of cause types for which EPSFallback can be triggered.
Must be an integer in the range of 0-46.
You can configure a maximum of four elements with this keyword.
Usage Guidelines
Use this command to configure the cause to trigger EPSFallback.
profile access erir
Configures the ERIR parameters.
Command Mode
Syntax
erir delay erir_delay
delay erir_delay
Specify the ERIR delay duration for 4G/WIFI sessions in milliseconds.
Must be an integer in the range of 0-3000.
Default Value: 0.
Usage Guidelines
Use this command to configure the ERIR parameters.
profile access gtpc
Configures the GTPC Failure Handling profile.
Command Mode
Syntax
gtpc { class-map-cause-profile profile_name | gtpc-failure-profile profile_name }
Specify name of the Class Map Cause profile.
Must be a string.
Specify name of the GTPC Failure Handling profile.
Usage Guidelines
Use this command to configure the GTPC Failure Handling profile.
profile access gtpc message-handling create-session-request ho-ind
Configures handling of Create Session Request received with HO Indicator.
Command Mode
Syntax
gtpc message-handling create-session-request ho-ind [ new-call-reject ]
create-session-request ho-ind new-call-reject
Specify to reject Create Session Request received with HO Indicator, if session is not present.
Usage Guidelines
Use this command to configure handling of Create Session Request received with HO Indicator.
profile access gtpc message-handling create-session-response action
Configures action for GTPC message.
Command Mode
Syntax
gtpc message-handling create-session-response action [ apn-ambr ]
apn-ambr
Specify APN Aggregate Maximum Bit Rate (APN-AMBR).
Usage Guidelines
Use this command to configure action for GTPC message.
profile access gtpc message-handling create-session-response condition
Configures IP Exhaust condition.
Command Mode
Syntax
n1 message-handling pdu-establishment condition [ ip-exhaust [ action action [ cause cause_in_response ] ] ]
action action
Specify the action.
  • backoff
Specify the cause in response. Check the specification for the integer value.
Must be an integer in the range of 0-255.
Default Value: 0.
ip-exhaust
Specify the IP exhaust condition.
Usage Guidelines
Use this command to configure IP Exhaust condition.
profile access n1 message-handling pdu-establishment condition
Command Mode
Syntax
gtpc message-handling create-session-response condition [ ip-exhaust [ action action [ cause cause_in_response ] ] ]
action action
Specify the action.
  • backoff
Must be an integer in the range of 0-40.
Default Value: 0.
ip-exhaust
Usage Guidelines
profile access n1 message-handling pdu-release condition
Configures N4 Path Fail condition.
Command Mode
Syntax
n1 message-handling pdu-release condition [ n4-pathfail [ action action [ cause cause_in_response ] ] ]
action action
Specify the action.
  • backoff
n4-pathfail
Specify the N4 Path Fail condition.
Usage Guidelines
Use this command to configure N4 Path Fail condition.
profile access n1 t3591-pdu-mod-cmd
Configures the N1 timer t3591 - PDU Session Modify Command Retransmission Timer.
Command Mode
Syntax
n1 t3591-pdu-mod-cmd timeout timeout_period max-retry max_retries
Specify the PDU Modify Command maximum retry count.
Default Value: 2.
Specify the PDU Modify Command timer in seconds.
Must be an integer in the range of 1-16.
Default Value: 2.
Usage Guidelines
Use this command to configure the n1 timer t3591 - PDU Session Modify Command Retransmission Timer.
profile access n1 t3592-pdu-rel-cmd
Configures the N1 timer t3592 - PDU Sess Rel Command retransmission timer for cause 39 - retransmission required.
Command Mode
Syntax
n1 t3592-pdu-rel-cmd timeout timeout max-retry max_retry
max-retry max_retry
Specify the PDU Release Command Max Retry Count.
Default Value: 4.
timeout timeout
Specify the PDU Release Command timer in seconds for cause 39.
Default Value: 4.
Usage Guidelines
Use this command to configure the n1 timer t3592 - PDU Sess Rel Command retransmission timer for cause 39 - retransmission required.
profile access n1
Configures the N1 interface.
Command Mode
Syntax
n1 n1-failure-profile n1_failure_profile [ class-map-cause-profile class_map_cause_profile ]
Specify the class map cause profile.
Must be a string.
Specify the N1 failure profile.
Usage Guidelines
Use this command to configure the N1 interface.
profile access n2
Configures the N2 interface.
Command Mode
Syntax
n2 n2-failure-profile n2_failure_profile [ class-map-cause-profile class_map_cause_profile ]
Must be a string.
Specify the N2 failure profile.
Usage Guidelines
Use this command to configure the N2 interface.
profile access n11
Configures the N11 interface.
Command Mode
Syntax
n11 n11-failure-profile n11_failure_profile [ class-map-cause-profile class_map_cause_profile ]
Must be a string.
Specify the N11 failure profile.
Usage Guidelines
Use this command to configure the N11 interface.
profile access n2 idft
Configures N2 or N26 Indirect Data Forwarding Tunnel (IDFT) support.
Command Mode
Syntax
n2 idft enable timeout idft_timeout
Syntax
n26 idft enable timeout idft_timeout
enable
Specify to enable IDFT support.
Specify the IDFT timeout period in seconds.
Must be an integer in the range of 15-60.
Usage Guidelines
Use this command to configure N2 or N26 IDFT support.
profile access n26 idft
Command Mode
Syntax
Syntax
enable
Usage Guidelines
profile charging
Configures the charging profile.
Command Mode
Syntax
profile charging profile_name [ max-charging-condition max_changes | max-deferred-urr max_deferred_urr | max-secondary-rat-reports max_secondary_rat_reports | metering-method metering_method | method charging_method | offline-interim-timer timer_duration | ooo-retry-interval ooo_report_retry_interval | query-all-urr { false | true } | tight-interworking-mode { false | true } ]
Specify the charging profile configuration.
Must be a string.
Specify the maximum number of charging condition changes.
Must be an integer in the range of 0-500.
Default Value: 20.
Specify the maximum number of deferred USU containers.
Must be an integer in the range of 1-200.
Default Value: 50.
Specify the maximum number of secondaryRatDataUsageReports to trigger CHF update.
Must be an integer in the range of 0-50.
Default Value: 0.
Specify the parameters to be metered.
  • duration-volume
  • duration
  • volume
Default Value: duration-volume.
Specify the charging method. Default Value: offline.
  • none
  • offline
  • online
Specify the offline interim timer duration in seconds.
Must be an integer.
Default Value: 60.
Specify the interval, in milliseconds, at which OOO report will be retried.
Must be an integer in the range of 5-5000.
You can configure a maximum of five elements with this keyword.
Specify to enable or disable query all URRs.
  • false
  • true
Default Value: true.
Specify to enable or disable tight interworking mode for online/offline charging methods.
  • false
  • true
Usage Guidelines
Use this command to configure the charging profile.
profile charging accounting limit
Configures the duration threshold for accounting.
Command Mode
Exec > Global Configuration (config) > Charging Profile Configuration (config-charging-profile_name )
Syntax
accounting limit duration threshold
duration threshold
Specify the duration threshold for accounting.
Must be an integer in the range of 0-2147483647.
Usage Guidelines
Use this command to configure the duration threshold for accounting.
profile charging accounting limit volume
Configures the volume threshold for accounting.
Command Mode
Syntax
accounting limit volume { downlink downlink_volume_limit | total total_volume_limit | uplink uplink_volume_limit }
Specify the downlink volume limit in bytes for interim generation.
Must be an integer in the range of 100000-4000000000.
Specify the total volume limit in bytes for interim generation.
Specify the uplink volume limit in bytes for interim generation.
Usage Guidelines
Use this command to configure the volume threshold for accounting.
profile charging dynamic-rules request-quota
Configures the dynamic rules request quota.
Command Mode
Syntax
dynamic-rules request-quota { on-receiving-rule | on-traffic-match }
on-receiving-rule
Specify this value to send CCR-I message with RSU on receiving the dynamic rule.
on-traffic-match
Specify this value to send CCR-I message with RSU on receiving the start of traffic.
Default Value: on-receiving-rule .
Usage Guidelines
Use this command to configure dynamic rules request quota.
profile charging failure-handling error-type
Configures the failure handling error type for Rating Group-level and application-level errors.
Command Mode
Syntax
failure-handling error-type [ rg | app ] error-value error_value action action_value
Specify this value to configure the failure handling error type as Rating Group or Application.
For the application-level errors, specify one of the following values for action_value
  • drop-data —Specify this value to drop data corresponding to the charging ID.
  • terminate —Specify this value to release the PDU session.
  • continue —Specify this value to disable charging.
For the Rating Group-level errors, enter one of the following values for action_value :
  • convert-offline —Specify this value to convert to offline charging.
  • delete-flow —Specify this value to delete the flow or rule associated with the Rating Group.
  • drop-data —Specify this value to drop data corresponding to the Rating Group.
Note
  • If you haven't configured an action for the Rating Group-level and application-level errors, the SMF continues with the default behavior.
  • SMF doesn’t allow mapping of multiple QoS flows to the same Rating Group for dynamic rules.
  • The drop-data action is applicable to all the flows that are associated to the Rating Group.
Usage Guidelines
Use this command to configure failure handling error type for Rating Group-level and application-level errors.
profile charging limit
Configures the duration and volume thresholds.
Command Mode
Syntax
limit { duration duration_threshold | volume volume_threshold }
Specify the duration threshold for charging.
Must be an integer in the range of 60-40000000.
Specify the volume threshold for charging.
Must be an integer in the range of 10000-4000000000.
Usage Guidelines
Use this command to configure the duration and volume thresholds.
profile charging limit rating-group
Configures the rating group volume and duration thresholds.
Command Mode
Syntax
limit rating-group { duration duration_threshold | volume volume_threshold }
Usage Guidelines
Use this command to configure the rating group duration and volume thresholds.
profile charging mscc-final-unit-action terminate session
Terminates the session when MSCC final unit action is terminate.
Command Mode
Syntax
Terminate the session when MSCC final unit action is terminate.
Usage Guidelines
Use this command to terminate the session when the MSCC final unit action is terminate.
profile charging offline zero-usage
Configures offline charging zero-usage parameters.
Command Mode
Syntax
offline zero-usage [ drop suppress_for_zero_usage | measurement parameters_to_suppress | trigger triggers_to_suppress ]
Specify the parameters to suppress for zero usage.
  • cdr
  • uuc
Specify the parameters to be suppressed.
  • duration
  • volume
Specify the list of triggers to be suppressed.
  • external
  • final
  • internal
Usage Guidelines
Use this command to configure offline charging zero-usage parameters.
profile charging quota
Configures the charging quota parameters.
Command Mode
Syntax
quota request request_quota
Specify the request quota from CHF.
  • always
  • standard
Default Value: standard.
Usage Guidelines
Use this command to configure the charging quota parameters.
profile charging quota suppress
Configures the list of triggers to be suppressed.
Command Mode
Syntax
quota suppress triggers triggers_to_suppress
  • qht
Usage Guidelines
Use this command to configure the list of triggers to be suppressed.
profile charging quota validity-time
Configures the validity lifetime of the quota.
Command Mode
Syntax
quota validity-time validity_time
validity-time validity-time
Specify the validity lifetime of the quota.
Must be an integer in the range of 1 through 4000000 seconds.
Usage Guidelines
Use this command to configure the charging validity lifetime of the quota.
profile charging quota volume-threshold percent
Configures the volume threshold value as a percentage of the volume quota.
Command Mode
Syntax
quota volume-threshold percent  volume-threshold percent
Specify the volume threshold value as a percentage of the volume quota.
Must be an integer in the range of 1 through 100.
Usage Guidelines
Use this command to configure the charging volume threshold value as a percentage of the volume quota.
profile charging reporting-level
Configures the usage reporting level to be used if not sent by the PCF.
Command Mode
Syntax
reporting-level { offline reporting_level | online reporting_level }
Specify the reporting level configuration for offline.
  • rating-group
  • service-id
Default Value: rating-group.
Specify the reporting level configuration for online.
  • rating-group
  • service-id
Usage Guidelines
Use this command to configure the usage reporting level to be used if not sent by the PCF.
profile charging requested-service-unit
Configures the Requested Service Unit time parameter.
Command Mode
Syntax
requested-service-unit time rsu_time
time rsu_time
Specify the Requested Service Unit time value in seconds.
Must be an integer in the range of 1-4000000000.
Usage Guidelines
Use this command to configure the Requested Service Unit time parameter.
profile charging requested-service-unit volume
Configures the Requested Service Unit Volume parameters.
Command Mode
Syntax
requested-service-unit volume { uplink uplink_volume | downlink downlink_volume | total total_volume }
Specify the downlink volume in bytes.
total total_volume
Specify the total volume in bytes.
Specify the uplink volume in bytes.
Usage Guidelines
Use this command to configure the Requested Service Unit Volume parameters.
profile charging send charging-initial
Configures the option to send CCR-I message towards OCS when dynamic and predefined rules are received or when the usage report is received with the start of traffic.
Command Mode
Syntax
send charging-initial { session-start | traffic-start }
session-start
Specify whether to send CCR-I message towards OCS on receiving the dynamic and predefined rules.
traffic-start
Specify whether to send the CCR-I message towards OCS on receiving the usage report with the start of traffic.
The default value is session-start .
Usage Guidelines
Use this command to configure an option for sending CCR-I message towards OCS when dynamic and predefined rules are received or when the usage report is received with the start of traffic.
profile charging session-failover
Configure the Diameter session failover for the Gy interface.
Command Mode
Syntax
session-failover { false | true }
false
Disable the Diameter session failover for Gy.
true
Enable the Diameter session failover for Gy.
Usage Guidelines
Use this command to configure Diameter session failover for Gy.
profile charging tariff-time-change
Configures timestamps for tariff-time change.
Command Mode
Syntax
tariff-time-change { hour hour | minute minute }
hour hour
Specify the hour timestamp for tariff-time change.
Must be an integer in the range of 0-23.
minute minute
Specify the minute timestamp for tariff-time change.
Must be an integer in the range of 0-59.
Usage Guidelines
Use this command to configure timestamps for tariff-time change.
profile charging triggers
Configures the list of triggers.
Command Mode
Syntax
triggers session triggers
session triggers
Specify the list of session-level triggers.
  • 3gpp-ps-change
  • ambr-change
  • max-number-of-changes-in-charging-conditions
  • plmn-change
  • qos-change
  • rat-change
  • serv-node-change
  • tarrif-time-change
  • ue-pra-change
  • ue-time-change
  • upf-add
  • upf-rem
  • user-loc-change
Usage Guidelines
Use this command to configure the list of triggers.
profile charging-characteristics
Configures the charging characteristics profile.
Command Mode
Syntax
profile charging-characteristics cc_profile_name [ [ charging-profile charging_profile_name ] [ charging-qbc-profile charging_qbc_profile_name ] ]
Specify name of the charging characteristics profile. For example, 1, 2, 3, 12, 14, till 16.
Must be a string of 1-2 characters in the pattern '[0-9]*'.
Specify name of the Charging profile.
Must be a string.
Specify name of the Charging QBC profile.
Must be a string.
Usage Guidelines
Use this command to configure the charging characteristics profile.
profile charging-characteristics network-element-profile-list
Configures the network elements profile list.
Command Mode
Exec > Global Configuration (config) > Charging Characteristics Profile Configuration (config-charging-characteristics-profile_name )
Syntax
network-element-profile-list chf charging_server
chf charging_server
Specify the list of charging servers.
Must be a string.
Usage Guidelines
Use this command to configure the network elements profile list.
profile charging-qbc
Configures the Charging QBC profile.
Command Mode
Syntax
charging-qbc charging_qbc_profile_name [ [ max-charging-condition max_charging_condition_changes ] [ max-deferred-urr max_deferred_urr ] [ ooo-retry-interval ooo_report_retry_interval ] [ triggers bearer_level_triggers ] ]
Must be a string.
Default Value: 20.
Default Value: 50.
Specify the list intervals at which OOO report will be retried in miliseconds. Default: 5 50 2000.
Specify the list of bearer level triggers.
  • 3gpp-ps-change
  • ambr-change
  • plmn-change
  • qos-change
  • rat-change
  • serv-node-change
  • ue-pra-change
  • ue-time-change
  • upf-add
  • upf-rem
  • user-loc-change
Usage Guidelines
Use this command to configure the Charging QBC profile.
profile charging-qbc limit
Configures the thresholds.
Command Mode
Syntax
Usage Guidelines
Use this command to configure the thresholds.
profile charging usage-reporting quota-to-report based-on-grant
Configures the charging usage reporting quota to report volume or duration in Used Service Unit to OCS if it is granted in Granted Service Unit by OCS server.
Command Mode
Syntax
usage-reporting quota-to-report based-on-grant { report-only-granted-volume }
quota-to-report based-on-grant {report-only-granted-volume}
The based-on-grant option specifies the report volume or duration in Used Service Unit to OCS if only it is granted in Granted Service Unit by OCS server. The report-only-granted-volume option specifies the filter for sending Used Volume quota to OCS base on Input, Output, or Total Octets granted in Granted Service Unit by OCS server.
Usage Guidelines
Use this command to configure the charging usage reporting quota to report volume or duration in Used Service Unit to OCS if it is granted in Granted Service Unit by OCS server.
profile compliance
Configures 3GPP compliance configuration.
Command Mode
Syntax
compliance profile_name
Specify name of the compliance profile.
Must be a string.
Usage Guidelines
Use this command to configure the 3GPP compliance configuration.
profile compliance service
Configures the SMF service names.
Command Mode
Exec > Global Configuration (config) > Compliance Profile Configuration (config-compliance-profile_name )
Syntax
service service_name
service_name
Specify the service names.
  • n1
  • n2
  • namf-comm
  • nchf-convergedcharging
  • nnrf-disc
  • nnrf-nfm
  • npcf-smpolicycontrol
  • nsmf-pdusession
  • nudm-sdm
  • nudm-uecm
  • threegpp23502
Usage Guidelines
Use this command to configure the SMF service names. The service names are specified in 3GPPTS 29.510 V15.2.0, Section 6.1.6.3.11.
profile compliance service n1
Configures the 3GPP n1 specification version number.
Command Mode
Syntax
service n1 version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
Specify the 3GPP compliance version to configure. It allows only one compliance version to be configured at a time.
full full_version
Specify the full version in the format major-version .minor-version .patch-version .[alpha-draft-number ].
Must be a string in the pattern '\d+.\d+.\d+^?(.alpha-\d+)?'.
Specify the 3GPP N1 specification version number.
  • 15.2.0
  • 15.4.0
Default Value: 15.2.0.
uri version_uri
Specify the version URI.
Must be a string in the pattern 'v\d'.
Specify the 3GPP compliance versions to configure. It allows a maximum of two compliance versions to be configured at a time.
Specify the status of configured 3GPP compliance versions. mode is an optional configuration. The default value is active . If version-list version is configured with two versions, then at least one version should be active .
Usage Guidelines
Use this command to configure the 3GPP n1 specification version number.
profile compliance service n2
Configures the 3GPP n2 service specification version number.
Command Mode
Syntax
service n2 version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP n2 service specification version number.
  • 15.0.0
  • 15.2.0
  • 15.4.0
Default Value: 15.0.0.
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP N2 service specification version number.
profile compliance service namf-comm
Configures the 3GPP namf-comm specification version number.
Command Mode
Syntax
service namf-comm version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP namf-comm specification version number.
  • 15.0.0
  • 15.2.0
  • 15.4.0
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP namf-comm specification version number.
profile compliance service nchf-convergedcharging
Configures the 3GPP nchf-convergedcharging service specification version number.
Command Mode
Syntax
service nchf-convergedcharging version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP nchf-convergedcharging service specification version number.
  • 15.0.0
  • 15.1.0
  • 15.2.1
  • 15.3.0.std
  • 15.3.0 custom
  • 15.3.0
  • 15.4.0
  • 16.8.1
  • 17.0.0
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP nchf-convergedcharging service specification version number.
profile compliance service nnrf-disc
Configures the 3GPP nnrf-disc service specification version number.
Command Mode
Syntax
service nnrf-disc version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP nnrf-disc service specification version number.
Must be one of the following:
  • 15.0.0
  • 15.2.0
  • 15.4.0
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP nnrf-disc service specification version number.
profile compliance service nnrf-nfm
Configures the 3GPP nnrf-nfm service specification version number.
Command Mode
Syntax
service nnrf-nfm version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP nnrf-nfm service specification version number.
  • 15.0.0
  • 15.2.0
  • 15.4.0
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP nnrf-nfm service specification version number.
profile compliance service npcf-smpolicycontrol
Configures the 3GPP npcf-smpolicycontrol service specification version number.
Command Mode
Syntax
service npcf-smpolicycontrol version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP npcf-smpolicycontrol service specification version number.
  • 15.0.0
  • 15.2.0
  • 15.4.0
  • 16.10.0
  • 17.3.0
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP npcf-smpolicycontrol service specification version number.
profile compliance service nsmf-pdusession
Configures the 3GPP nsmf-pdusession specification version number.
Command Mode
Syntax
service nsmf-pdusession version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP nsmf-pdusession specification version number.
  • 15.0.0
  • 15.2.0
  • 15.4.0
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP nsmf-pdusession specification version number.
profile compliance service nudm-sdm
Configures the 3GPP nudm-sdm service specification version number.
Command Mode
Syntax
service nudm-sdm version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP nudm-sdm service specification version number.
  • 15.1.0
  • 15.2.1
  • 15.4.0
Default Value: 15.2.1.
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP nudm-sdm service specification version number.
profile compliance service nudm-uecm
Configures the 3GPP nudm-uecm service specification version number.
Command Mode
Syntax
service nudm-uecm version { full full_version | spec 3gpp_spec_version | uri version_uri } | version-list version version_name { full full_version | mode { active | offline } | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP nudm-uecm service specification version number.
  • 15.1.0
  • 15.2.1
  • 15.4.0
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP nudm-uecm service specification version number.
profile compliance service threegpp23502
Configures the 3GPP 23.502 Stage-2 5GS specification version number.
Command Mode
Syntax
service threegpp23502 version { full full_version | spec 3gpp_spec_version | uri version_uri }
version
full full_version
Specify the 3GPP 23.502 Stage-2 5GS specification version number.
  • 15.4.0
  • 15.6.0
Default Value: 15.4.0.
uri version_uri
Usage Guidelines
Use this command to configure the 3GPP 23.502 Stage-2 5GS specification version number.
profile content-filtering category database
Configures the Content Filtering database parameter.
Command Mode
Syntax
content-filtering category database max-versions max_versions
Specify the maximum number of Content-Filtering database versions.
Usage Guidelines
Use this command to configure the Content Filtering database parameter.
profile content-filtering category database directory
Configures the Content Filtering database directory parameter.
Command Mode
Syntax
content-filtering category database directory path cf_directory_path
Specify the Content-Filtering directory path.
Must be a string of 1-255 characters.
Usage Guidelines
Use this command to configure the Content Filtering database directory parameter.
profile converged-core activated-features
Enables the specific feature in converged core.
Command Mode
Exec > Global Configuration (config) > Converged Core (config-converged-core cc_profile_name )
Syntax
profile converged-core cc_profile_name activated-features 2g3g | upf-blocklisting [ use-alert custom_rule_name ]
Specify the 2g3g feature.
activated-features upf-blocklisting
Specify the UPF blocklisting feature.
Specify the custom rule name for the alerts.
The default value of the Command [ use-alert custom_rule_name ] , is “upf_inactive”. If the custom rule name is not configured, the system takes “upf_inactive” for blocklisting the UPF.
Note
  • Changing the custom rule name during run-time requires the previous rule name to be removed. Configuring the new custom rule name before removing the previous rule name, results in activating both the both the rule names.
  • The new alert configuration parameters should be configured with the new rule name in CEE alert configuration (CEE ops-center).
Usage Guidelines
Use this CLI to enable the UPF blocking feature on SMF.
profile converged-core session-hold duration
Configures the session hold timer duration to enable the IP reuse feature.
Command Mode
Exec > Global Configuration (config) > Converged Core Configuration (config-converged-core-ccg_profile_name )
Syntax
session-hold duration hold_timer
Specify the session hold duration in seconds. By default this feature is disabled.
hold_timer must be an integer in the range of 30 to 300.
Note
SMF does not support dynamic change in configuration of session hold timer for ongoing sessions. Any change in the timer value will be applicable only for new sessions.
SMF allows you to configure the session hold timer both at the converged core profile level and DNN level. When the timer is configured at both levels, the timer value configured in DNN overrides the value in converged core profile.
Use no session-hold duration command to disable the IP reuse feature.
Usage Guidelines
Use this command to configure the session hold timer. If the user reattaches within the configured session hold timer after session release, SMF allocates the same IP address and session ID to the user session.
profile converged-core supported-features
Enables the supported features for a rolling upgrade and Enhanced PFCP Association Release.
Command Mode
Syntax
profile converged-core cc_profile_name  supported-features [ app-rx-retx-cache | app-tx-retx | epfar | rolling-upgrade-all | rolling-upgrade-enhancement-infra ]
supported-features [ app-rx-retx-cache | app-tx-retx | rolling-upgrade-all | rolling-upgrade-enhancement-infra ]
Specify one of following options to enable the supported features for the rolling upgrade.
  • app-rx-retx-cache : Enable retransmission cache for inbound messages at application.
  • app-tx-retx : Enable retransmission for outbound messages at application.
  • rolling-upgrade-all : Enable the rolling-upgrade-enhancement-infra , app-rx-retx-cache , and app-tx-retxrolling upgrade features.
  • rolling-upgrade-enhancement-infra : Enable infra level features.
Note
By default, the rolling upgrade features are disabled.
supported-features epfar
Specify the epfar option to enable the support for Enhanced PFCP Association Release.
Note
By default, the epfar feature is disabled.
Usage Guidelines
Use this command to enable the supported features for a rolling upgrade and Enhanced PFCP Association Release.
profile diameter-client
Configures Diameter client.
Command Mode
Syntax
profile diameter-client  diameter_client_name [ dictionary-name { dcca-custom8 | default | r8-gx-standard } | endpoint | failure-handling-profile | host-selection | request-timeout ]
Specify a Diameter client profile name.
Specify one of the following dictionaries to be used.
  • dcca-custom8 : This is the standard Gy dictionary.
  • default : This is the default dictionary.
  • r8-gx-standard : This is the standard Gx dictionary.
endpoint
Specify the associated diameter endpoint profile.
Specify the associated diameter failure handling profile.
host-selection
Specify the Diameter host selection profile.
request-timeout
Indicate the time out of the request.
profile diameter-endpoint
Specify a Diameter endpoint on the Gx or Gy interface.
Command Mode
Syntax
profile diameter-endpoint interface_name instance instance-id instance_id_value internal-vip ip_address[ destination-host-avp message_type| vsa-support vendorId-source| max-outstanding number_of_messages| response-timeout response_timeout_value| connection-timeout connection-timeout_value| basemsg retransmission-timeout retransmission_timeout_value| basemsg retransmissions max_retry_value| basemsg watchdog-interval interval_value| dscp [ dscp_value | af11 | af12 | af13 | af21 | af22 | af23 | af31 | af32 | af33 | af41 | af42 | af43 | be | cs1 | cs2 | cs3 | cs4 | cs5 | cs6 | cs7 | ef ] | origin realm realm_name| origin host host_name address ipv4 ip_address | origin peer origin_peer_name | realm  realm_name| address ipv4 ip_address| port peer_port| destination-host-name  destination_host_name| load-balancing-algorithm highest-weight| route-entry host [ host-name | * ] realm [ realm-name | * ] peer peer_name weight weight_value| route-failure deadtime deadtime_value result-code result_code_value threshold  number| route-failure result-code result_codes_value| route-failure threshold  threshold_number| route-failure recovery-threshold percent  recovery_threshold_percentage| dynamic-route expiry-timeout  expiry_timeout_value | dynamic-route expiry-timeout  | dynamic-origin-state-id  boolean_value | disconnect peer request| busy time time_duration| do not talk time time_interval| drain time time_interval| reboot time time_duration]
Specify a Diameter profile for the Gx or Gy interface.
Specify the value of the instance ID.
internal-vip
Internal VIP IP address. This parameter is mandatory
Specify the type of message in which the destination host AVP is to be encoded.
Note
SMF supports always and session-binding values for the message_type .
Specify the source of vendor IDs DIABASE to be used for negotiation of Diameter peer capabilities.
Note
SMF supports only the all-from-dictionary value for the vendorId-source .
Specify the maximum number of Diameter messages to be sent to any peer in the profile, while awaiting the responses. The default value is 256. number_of_messages must be in the range of 1–4096.
Specify the maximum allowed response time for request messages that the Diameter applications send to the Diameter server. The default value is 60. response_timeout_value must be in the range of 1–300.
Specify the maximum allowed time for establishing the transport layer connectivity, such as the TCP connection, toward the Diameter server. The default value is 30. connection-timeout_value must be in the range of 1–300.
Specify the timeout value between retransmissions of the base messages, such as Device Watchdog Request (DWR) and Capability Exchange Request (CER), toward the Diameter server. The default value is 30.
retransmission_timeout_value must be in the range of 1–120.
Specify the maximum number of times the base messages must be retransmitted. The default value is 1. max-retries must be in the range of 1–10.
Specify the time interval between the two DWR messages that are sent toward the Diameter server. The default value is 30. interval_value must be in the range of 6–30.
dscp [ dscp_value| af11 | af12 | af13 | af21 | af22 | af23 | af31 | af32 | af33 | af41 | af42 | af43 | be | cs1 | cs2 | cs3 | cs4 | cs5 | cs6 | cs7 | ef ]
Specify the Differential Services Code Point (DSCP) value in the IP header of the Diameter messages that are sent toward the Diameter server. The default value is be . dscp_value must be in the range of 0–63. Choose in the following other DSCP values, as required:
  • af xx: Specify this value for the use of an assured forwarding xx per hop behavior (PHB).
  • be : Specify this value for the use of best effort forwarding PHB. be is the default value.
  • cs x: Specify this value for the use of class selector x per PHB.
  • ef : Specify this value for the use of expedited forwarding PHB.
Specify the name of the realm for the Diameter endpoint. This parameter is mandatory.
Specify the host name, which is the FQDN of the Diameter endpoint. Specify the IPv4 address, which is the Diameter endpoint Bind IP address for the Diameter client connections.
Specify the identifier for a Diameter peer. This parameter is mandatory.
realm realm_name
Specify the name of the realm for a peer with the name of the peer. This parameter is mandatory.
Specify the IP address of the Diameter peer.
port peer_port
Specify the port of the Diameter peer. This parameter is mandatory.
Specify the custom destination host name to be used in destination host AVP. This parameter is optional.
Choose an idle server with the highest weight in failure scenarios. If multiple servers have the same high weight, then the load balancing happens among those servers.
Use this command to configure two static entries, such as a peer in the route table. If you configure an entry with the existing same flag, host, realm, then only the weight is updated with higher of two of them. The host and realm parameters allow wildcard character values. The weight is an optional parameter with the default value as 10. The peer is a mandatory parameter.
Note
You can configure multiple route entries with the same host and realm but a different peer without being overridden.
Specify the duration in seconds for which the system keeps the route in the FAILED status. After the configured duration expires, the system changes the status to AVAILABLE . deadtime_value must be an integer in the range of 1–86400. The default value is 60.
Specify the answer messages that are to be considered as failures, in addition to the requests that time out.
Note
You can specify up to 16 result codes.
Specify the number of errors that cause the FAILED status. The default value is 16.
Note
The error counter begins at zero. In a case of a good response, the error counter decrements or increments. This counter does not decrement below zero or increment above the configured threshold number.
Specify the percentage value at which the failure counter is reset when provisionally changing the status from FAILED to AVAILABLE . For example, a failure counter of 16 caused the AVAILABLE status to change to FAILED status. After the configured deadtime expires, the status changes to AVAILABLE . If recovery_threshold_percentage is configured with 75 percent, the failure counter resets to 12, which is 75 percent of 16. The default value is 90.
Specify the expiration time for dynamic routes that you created after reaching the Diameter destination host. The default value is 86400 secs, which equals one day.
Specify whether you want to enable or disable the dynamic origin state ID. The default value is true.
The Disconnect-Peer-Request (DPR) is sent to a peer to inform its intentions to disconnect the connection from the peer nodes.
Specify the time duration after which the connection is reattempted to peer. The time duration value must be an integer in the range of 1–300 seconds. The default value is 3 seconds.
Specify the time interval between receiving of DPR by diameter endpoint and sending of DPA response. The time interval value must be the integer in the range of 1–300 seconds. The default value is 3 seconds.
Specify the time interval between receiving of DPR by diameter endpoint and sending of DPA response. The time interval value must be an integer in the range of 1 to 10 seconds. The default value is 3 seconds.
profile diameter-host-selection
Configures the data of an individual profile name with algorithm and list of primary and secondary host details.
Command Mode
Syntax
profile diameter-host-selection host_selection_name  algorithm hosts hosts_precedence  [ primary host host_ip_address  primary realm realm_name |  secondary host host_ip_address secondary realm realm_name ]
profile diameter-host-selectionhost_selection_name
Specify the Diameter host selection profile name.
algorithm
Choose the algorithm to select the host.
  • ipaddr-modulus
  • msisdn-modulus
  • round-robin
Specify the precedence of the host in the form of index from 1-64
Must be in the range of 1 to 64.
Specify the primary host name.
Specify the primary host realm.
Specify the secondary host name.
Specify the secondary host realm.
profile dnn
Configures DNN profile.
Command Mode
Syntax
profile dnn dnn_profile_name  intershat  dnn_intershat[ always-on { false | true } | charging-profile profile_name | dcnr { false | true } | dnn-selection-mode dnn_selection_mode | dnn profile_name | emergency { false | true } | mode dnn_mode | only-nr-capable-ue { false | true } | pcc-ue-rule-precedence-mapping { false | true } | pcf-interaction { false | true } | pcscf-profile profile_name | ppd-profile profile_name | presence-reporting { false | true } | qci-qos-profile qci_qos_profile | qos-profile profile_name  | eventmgmt-policy  eventmgmt_policy_name   | suppress-uli-reporting-on-s5 { disable | enable } | upf-selection-policy upf_selection_policy | userplane-inactivity-timer timeout_period | virtual-mac mac_address | wps-profile profile_name ]
    supported-features   [ inter-plmn-ho nat-binding-update  ]
Specify to enable or disable Always On PDU session.
  • false
  • true
Default Value: false.
charging-characteristics-id cc_id
Specify the charging characteristics ID.
Specify name of the charging profile.
Must be a string.
charging-qbc-profile profile_name
Specify name of the charging QBC profile.
Must be a string.
Specify to enable or disable support for dual connectivity with new radio.
  • false
  • true
Specify the selection mode for subscription. The default mode is "verified".
  • network-provided
  • ue-provided
  • verified
Must be a string.
Specify whether the DNN is emergency DNN or not.
  • false
  • true
hsmf-uri hsmf_uri
Specify the override hsmfURI.
Must be a string.
mode dnn_mode
Specify the DNN mode of operation.
  • offline : Offline. DNN in offline mode, new sessions are rejected.
Specify whether to allow only 5G capable UE, and reject calls from non-5G capable UE.
  • false
  • true
override profiles
Specify the list of profiles for local preference.
  • charging-characteristics-id
  • charging-profile
  • charging-qbc-profile
Specify whether to map PCC rule precedence to SMF-assigned TFT and auth rule precedence values. If disabled, values sent by PCF are used.
  • false
  • true
Specify to enable or disable PCF interaction.
  • false
  • true
Specify the P-CSCF profile association.
Must be a string.
Specify the Paging-Policy differentition.
Must be a string.
Specify whether to enable or disable presence reporting for this DNN.
  • false
  • true
Specify the QCI QoS Profile configuration related to QCI to QoS mapping.
Must be a string.
qos-profile qos_profile
Specify the QoS Profile configuration.
Must be a string.
allows configuring priority-based event handling associated to a DNN.
Specify whether to suppress ULI only MBR towards the S5 interface.
  • disable
  • enable
Specify the UPF selection policy specific configuration.
Must be a string.
Specify the user plane inactivity timer in seconds.
Must be an integer in the range of 0-86400.
Default Value: 0.
Specify the remote virtual MAC address used to generate interface ID for UE.
Must be a string in the mac-address pattern. For information on the mac-address pattern, see the Input Pattern Types chapter.
Specify name of the Wireless Priority Service (WPS) profile.
Must be a string.
Configure NAT binding update procedure in SMF.
Usage Guidelines
Use this command to configure the DNN profile. The CLI prompt changes to the DNN Profile Configuration mode (config-dnn-<profile_name>).
profile dnn ipam dhcp
Configures DHCP as the IPAM under DNN profile.
Command Mode
Exec > Global Configuration (config) > DNN Profile Configuration (config-dnn-profile_name )
Syntax
profile dnn dnn_profile_name ipam dhcp
ipam dhcp
Specify the DHCP as IPAM.
Note
It is mandatory to have one IP pool to UPF mapping for DHCP based IPAM.
Usage Guidelines
Use this command to indicate IPAM as DHCP.
profile dnn accounting
Configures accounting parameters.
Command Mode
Syntax
accounting server-group radius_server_group_name
Specify name of the RADIUS server group.
Usage Guidelines
Use this command to configure the accounting parameters.
profile dnn authentication algorithm
Configures the authentication algorithm.
Command Mode
Syntax
authentication algorithm { chap chap_preference | convert-to-mschap | mschap mschap_preference | pap pap_preference | password-use-pco }
Specify the Challenge Handshake Authentication Protocol (CHAP) and preference. Lower value means higher preference. To disable, set it to 0.
Must be an integer in the range of 0-3.
Default Value: 0.
convert-to-mschap
Specify conversion of CHAP to MSCHAP when CHAP response length is 49 bytes.
Specify the Microsoft Challenge Handshake Authentication Protocol (MS-CHAP) and preference. Lower value means higher preference. To disable, set it to 0.
Default Value: 0.
pap pap_preference
Specify the Password Authentication Protocol (PAP) and preference. Lower value means higher preference. To disable, set it to 0.
Default Value: 0.
password-use-pco
Specify to override password with PCO password.
Usage Guidelines
Use this command to configure the authentication algorithm.
profile dnn authentication secondary
Configures the secondary authentication method.
Command Mode
Syntax
authentication secondary radius group radius_server_group_name
radius
Specify to use RADIUS as secondary authentication method.
Usage Guidelines
Use this command to configure the secondary authentication method.
profile dnn authorization
Configures the authorization method.
Command Mode
Syntax
authorization local   rat-type  rat_types
local
Specify to use local policy configuration.
rat-type rat_types
Specify the RAT types.
  • eutra
  • nr
  • wlan
Usage Guidelines
Use this command to configure the authorization method.
profile dnn dnn
Configures a Virtual DNN profile under a DNN profile and NF user list.
Command Mode
Syntax
dnn profile_name
Usage Guidelines
Use this command to configure a DNN profile that is used to map a UE-requested DNN to a Virtual DNN. The SMF sends "Mapped" DNNs for configured network functions and "UE-requested" DNNs for other network functions. The UE-requested DNN is always sent on the N1 interface.
profile dnn dnn nw-fu-conf
Configures network function parameters.
Command Mode
Syntax
dnn dnn_name network-function-list nf_list
dnn dnn_name
Must be a string.
Specify the list of network functions that the selected DNN profile will be sent. The list of network functions supported are CHF, OCS, PCF, PCRF, RADIUS and UPF.
Must be a string.
Usage Guidelines
Configures a Virtual DNN profile under a DNN profile and NF user list. Use this command to configure the network function parameters.
profile dnn dnn rmgr-conf
Configures the RMGR parameters.
Command Mode
Syntax
dnn rmgr rmgr_nf
rmgr rmgr_nf
Specify the RMGR Network Function.
Must be a string.
Usage Guidelines
Use this command to configure the RMGR parameters.
profile dnn dns primary
Configures the primary DNS server details.
Command Mode
Syntax
dns primary { ipv4 ipv4_address | ipv6 ipv6_address }
ipv4 ipv4_address
Specify the primary DNS server's IPv4 address.
Must be a string in the ipv4-address pattern. For information on the ipv4-address pattern, see the Input Pattern Types chapter.
ipv6 ipv6_address
Specify the primary DNS server's IPv6 address.
Must be a string in the ipv6-address pattern. For information on the ipv6-address pattern, see the Input Pattern Types chapter.
Usage Guidelines
Use this command to configure the primary DNS server details.
profile dnn dns secondary
Configures the secondary DNS server details.
Command Mode
Syntax
dns secondary { ipv4 ipv4_address | ipv6 ipv6_address }
ipv4 ipv4_address
Specify the secondary DNS server's IPv4 address.
ipv6 ipv6_address
Specify the secondary DNS server's IPv6 address.
Usage Guidelines
Use this command to configure the secondary DNS server details.
profile dnn ims mark
Configures marking QCI value as IMS media.
Command Mode
Syntax
ims mark qci qos_class_id
qci qos_class_id
Specify the standard QoS Class Identifiers.
Must be an integer from the following: 1-9, 65, 66, 69, 70, 80, 82, 83, 128-254.
Usage Guidelines
Use this command to configure marking QCI value as IMS media.
profile dnn ipv6-prefix-delegation
Configures the prefix delegation feature for the DNN.
Command Mode
Exec > Global Configuration (config)> DNN Profile Configuration (config-dnn-profile_name)
Syntax
ipv6-prefix-delegation prefix length prefix_length dnn prefix-delegation  vdnn
Specify the length of the IPv6 prefix being delegated. The supported range of prefix length is from 48 to 62.
When UPF sends Session Report for DIPR without requested PD-Prefix-Length, SMF will use this value as the prefix length.
Configure the Prefix Delegation (PD) for a virtual Dual-Stack Network Node (vDNN).
This configuration is mandatory because separate IP address pools are required for the delegated prefixes.
Usage Guidelines
Use this command to configure the prefix delegation feature for the DNN.
profile dnn max-upf-sessions
Configures maximum UPF sessions at DNN level.
Command Mode
Syntax
profile dnn dnn_profile_namemax-upf-sessions max_upf_sessions_count
Configures maximum supported session per vDnn per UPF on SMF.
Usage Guidelines
Use this command to configure maximum UPF sessions on a DNN level.
profile dnn network-element-profiles
Configures network element profiles.
Command Mode
Syntax
network-element-profiles { amf | chf | pcf  | pcrf | ocs   | sepp | udm }profile_name
amf profile_name
Specify name of the AMF network element profile. Changing the current profile name may impact existing calls. Requires DNN in offline mode.
Must be a string.
chf profile_name
Specify name of the CHF network element profile. Changing the current profile name may impact existing calls. Requires DNN in offline mode.
Must be a string.
pcf profile_name
Specify name of the PCF network element profile. Changing the current profile name may impact existing calls. Requires DNN in offline mode.
Must be a string.
pcrf profile_name
Specify name of the PCRF network element profile to enable Gx interface.
Must be a string.
ocs profile_name
Specify name of the OCS network element profile to enable Gy interface.
Must be a string.
sepp profile_name
Specify name of the SEPP network element profile.
Must be a string.
udm profile_name
Specify name of the UDM network element profile. Changing the current profile name may impact existing calls. Requires DNN in offline mode.
Must be a string.
Usage Guidelines
Use this command to configure network element profiles. Changing the current profile name may impact existing calls. Requires DNN in offline mode.
profile dnn nexthop-forwarding-address
Configures the Redirect Service/NextHop IP address.
Command Mode
Syntax
nexthop-forwarding-address { ipv4 ipv4_address | ipv6 ipv6_address }
ipv4 ipv4_address
Specify the IPv4 address.
ipv6 ipv6_address
Specify the IPv6 address.
Usage Guidelines
Use this command to configure the Redirect Service/NextHop IP address.
profile dnn nssai
Configures the default NSSAI configuration.
Command Mode
Syntax
nssai { [ sd slice_differentiator ] [ sst slice_service_type ] }
Specify the S-NSSAI Slice Differentiator (SD).
Must be a string in the hex-string6 pattern. For information on the hex-string6 pattern, see the Input Pattern Types chapter.
Specify the S-NSSAI Slice/Service Type (SST).
Usage Guidelines
Use this command to configure the default NSSAI configuration.
profile dnn outbound
Configures DNN host password for PPP session authentication.
Command Mode
Syntax
outbound password dnn_host_password
Specify the DNN host password.
Must be a string.
Usage Guidelines
Use this command to configure designating the DNN host password for PPP session authentication.
profile dnn primary-plmn
Configures the primary PLMN configuration.
Command Mode
Syntax
primary-plmn { [ mcc mobile_country_code ] [ mnc mobile_network_code ] }
Specify the 3-digit Mobile Country Code.
Specify the 2- or 3-digit Mobile Country Network.
Usage Guidelines
Use this command to configure the primary PLMN configuration.
profile dnn session-hold duration
Command Mode
Exec > Global Configuration (config) > DNN Profile Configuration (config-dnn-dnn_profile_name )
Syntax
Note
SMF allows you to configure the session hold timer both at the DNN profile level and converged core level. When the timer is configured at both levels, the timer value configured in DNN overrides the value in converged core profile.
Usage Guidelines
profile dnn session type
Configures the PDU session type.
Command Mode
Syntax
session type default_session_type [ allowed allowed_session_type ]
Specify the SMF allowed session types. Up to two allowed session types can be configured in addition to the default session type. The same session type cannot be configured both as allowed and default.
  • IPV4
  • IPV4V6
  • IPV6
You can configure a maximum of two elements with this keyword.
Specify the default session type.
  • IPV4
  • IPV4V6
  • IPV6
Usage Guidelines
Use this command to configure the PDU session type.
profile dnn skip-n10-registration
Ignores the UE registration messages towards UDM during the PDU setup and Wi-Fi attach procedures.
Command Mode
Syntax
profile dnn dnn_profile_name { skip-n10-registration rat-type [ NR | WIFI | ALL ] }
Specify one of the following RAT types to ignore the UDM registration.
  • NR
  • WIFI
  • ALL
Note
When you configure this CLI command, the SMF ignores the UDM registration during session creation in the 5G and Wi-Fi network. The handover between 5G and Wi-Fi fails because ePDG doesn't find the target SMF that was handling the session. If the UE registration fails during 5G or Wi-Fi attach and if the UDM failure handling template (FHT) is configured as continue or ignore, then SMF reattempts the registration during Wi-Fi-to 5G and 5G to Wi-Fi handovers.
Usage Guidelines
Use this command to ignore the UDM registration messages during the PDU setup and Wi-Fi attach procedures.
profile dnn subscription
Allows you to choose and change a subscription method. This CLI command allows you to delete a configured subscription method.
Command Mode
Syntax
subscription [ local | notify-immediate ] rat-type [ nr | eutra | wlan ]
Specify one of the following subscription options.
  • local —Uses Local Policy for Subscription.
  • notify-immediate—Skips Subscription Fetch and Continue with Subscribe to Notify with ImmediateReport.
Specify one of the following RAT types.
  • nr
  • eutra
  • wlan
Usage Guidelines
Use this command to choose and change a subscription method, and delete a configured subscription method.
profile dnn ssc-mode
Configures Session and Service Continuity (SSC) Mode parameters.
Command Mode
Syntax
ssc-mode default_ssc_mode [ allowed allowed_ssc_mode ]
Specify the allowed SSC Modes. Up to two allowed modes can be configured in addition to the default SSC mode. The same SSC mode cannot be configured both as allowed and default.
Specify the default SSC mode.
Usage Guidelines
Use this command to configure SSC mode parameters.
profile dnn timeout
Configures session time-to-live (TTL) configuration.
Command Mode
Syntax
timeout { [ absolute max_duration ] [ backoff backoff_timer_duration ] [ cp-idle cp_idle_duration ] [ default-flow-only default_flow_only_duration ] [ jitter jitter_duration ] [ setup setup_duration ] [ up-idle up_idle_duration ] }
absolute max_session_duration
Specify the maximum duration of the session in seconds, before the system automatically terminates the session. Value 0 indicates the function is disabled.
Default Value: 0.
Specify the maximum duration in seconds for backoff timer during IP Exhaustion and N4 Path Failure cases.
Must be an integer in the range of 0-576000.
Default Value: 0.
Specify the maximum duration after a 5G session has moved to idle (controlplane) state, before the system automatically terminates it. Value 0 indicates the function is disabled.
Default Value: 0.
Specify the maximum allowed duration for a PDU/PDN session to be in idle state, after which the system automatically terminates it. Value 0 indicates the function is disabled.
Must be an integer in the range of 0-604800000.
Default Value: 0.
jitter jitter_value
Specify the jitter value in seconds.
Must be an integer in the range of 0-1000.
Default Value: 0.
setup max_setup_duration
Specify the maximum setup time duration in milliseconds, after which the system automatically aborts the request.
Must be an integer in the range of 5000-60000.
Specify the maximum duration after a 5G session has moved to idle (userplane) state, before the system automatically terminates it. Value 0 indicates the function is disabled.
Default Value: 0.
Usage Guidelines
Use this command to configure session time-to-live (TTL) configuration.
profile dnn timeout bearer-inactivity
Checks for low activity for a bearer.
Command Mode
Syntax
bearer-inactivity [ exclude-default-bearer { false | true } ]
Specify whether to exclude default bearer from the Bearer Inactivity feature.
  • false
  • true
Usage Guidelines
Use this command to configure checking for low activity for a bearer.
profile dnn timeout bearer-inactivity gbr
Checks for low activity for a GBR bearer.
Command Mode
Syntax
gbr duration bearer_inactivity_timer
Specify the bearer inactivity timeout period in seconds.
Must be an integer in the range of 300-2592000.
Usage Guidelines
Use this command to configure checking for low activity for a GBR bearer.
profile dnn timeout bearer-inactivity gbr volume
Configures data traffic threshold values for a bearer.
Command Mode
Syntax
volume { [ downlink downlink_data_traffic ] [ total total_data_traffic ] [ uplink uplink_data_traffic ] }
Specify the downlink data traffic for a bearer in bytes.
Must be an integer in the range of 1-4294967295.
Specify the total uplink and downlink data traffic for a bearer in bytes.
Specify the uplink data traffic for a bearer in bytes.
Usage Guidelines
Use this command to configure the data traffic threshold values for a bearer.
profile dnn timeout bearer-inactivity non-gbr
Checks for low activity for a non-GBR bearer.
Command Mode
Syntax
Usage Guidelines
Use this command to configure checking for low activity for a non-GBR bearer.
profile dnn timeout bearer-inactivity non-gbr volume
Command Mode
Syntax
Usage Guidelines
profile dnn upf
Configures the UPF APN profile.
Command Mode
Syntax
upf apn apn_name
apn apn_name
Specify name of the APN.
Must be a string of 1-63 characters.
Usage Guidelines
Use this command to configure the UPF APN profile.
profile dnn upcp status
Configures the User Plane Confidentiality Protection support on SMF and its parameters.
Command Mode
Syntax
[ no ] upcp status { required | preferred | not-needed }
Configures the UPCP status. There are three options in this command:
  • Required
  • Preferred
  • Not needed
[ no ]
This is an optional command. It removes the local configuration for UPCP status.
Usage Guidelines
Use this command to configure the UPCP locally on SMF.
profile dnn user-plane-buffering-mgmt
Creates BAR and links the FARs to it.
Command Mode
Syntax
user-plane-buffering-mgmt true hlcom true
Creates BAR and links the FARs to it under profile DNN.
hlcom true
Sends ExtBuffSupport IE in the N1N2 messag for enabling extended buffering.
Usage Guidelines
Use this command to enable the HLCOM for a RedCap session.
profile dnn qos-profile
Associates a specific QoS profile with the DNN profile.
Command Modes
Syntax
profile dnn dnnprof-ims.roaming  { qos-profile vplmn-qos  }
Specify the name of the dnn roaming profile.
Specify the quality of service profile name for the vplmn profile.
Usage Guidelines
This command associates a specific QoS profile, named "vplmn-qos," with the DNN profile "dnnprof-ims.roaming." By doing this, all traffic using the "dnnprof-ims.roaming" DNN will apply the quality of service parameters defined in the "vplmn-qos" profile, ensuring consistent network performance and policy enforcement for that data network name in a roaming scenario.
profile dns-proxy
Configures DNS proxy profile parameters.
Command Mode
Syntax
profile dns-proxy [ cache-ttl ttl | query-type query_type | randomize-answers | round-robin-answers | timeout dns_timeout ]
cache-ttl ttl
Specify the TTL value of DNS responses in cache, in seconds.
Must be an integer in the range of 60-86400.
Specify the DNS query type.
  • ipv4-ipv6
  • ipv4
  • ipv6
Default Value: ipv4.
randomize-answers
Specify to enable randomizing address fetch.
round-robin-answers
Specify to enable round-robin address fetch.
timeout dns_timeout
Specify the DNS timeout.
Must be an integer in the range of 200-10000.
Default Value: 500.
Usage Guidelines
Use this command to enable and configure DNS proxy parameters.
profile dns-proxy servers
Configures DNS server parameters.
Command Mode
Exec > Global Configuration (config) > DNS Proxy Configuration (config-dns-proxy)
Syntax
servers dns_server_name [ ip dns_server_ip_address | port dns_server_port_number | priority dns_server_priority | protocol dns_server_protocol ]
Specify the IP address of the DNS server.
-Or-
Specify the port number of the DNS server.
Must be an integer in the range of 1-65535.
Specify the priority for the DNS server.
Must be an integer in the range of 1-100.
Specify the protocol type for the DNS server.
  • tcp
  • udp
Default Value: tcp.
Specify the name of the DNS server.
Must be a string.
Usage Guidelines
Use this command to configure the DNS server parameters.
profile ecgi-group
Configures ECGI group profile parameters.
Command Mode
Syntax
profile ecgi-group group_name
Specify name of the ECGI group.
Must be a string.
Usage Guidelines
Use this command to configure ECGI group profile parameters.
profile ecgi-group ecgis
Configures the list of MCC, MNC, TAC, and ECGI groups.
Command Mode
Exec > Global Configuration (config) > ECGI Group Configuration (config-ecgi-group-profile_name )
Syntax
mcc mobile_country_code mnc mobile_network_code
Specify the Mobile Country Code (MCC).
Must be a string in the three-digit pattern. For information on the three-digit pattern, see the Input Pattern Types chapter.
Specify the Mobile Network Code (MNC).
Must be a string in the two-or-three-digit pattern. For information on the two-or-three-digit pattern, see the Input Pattern Types chapter.
Usage Guidelines
Use this command to configure the list of MCC, MNC, TAC, and ECGI groups.
You can configure a maximum of 16 elements with this command.
profile ecgi-group ecgis ecgi
Configures ECGI group parameters.
Command Mode
Exec > Global Configuration (config) > ECGI Group Configuration (config-ecgi-group-profile_name ) > ECGI Group MCC/MNC Configuration (config-ecgi-group-mcc_mnc )
Syntax
ecgi list ecgi_values
list ecgi_values
Specify the list of ECGI values - 7 digit hex string Eutra Cell ID. For example, A12345f.
Must be a string in the hex-stringecgi pattern. For information on the hex-stringecgi pattern, see the Input Pattern Types chapter.
You can configure a maximum of 64 elements with this keyword.
Usage Guidelines
Use this command to configure ECGI group parameters.
profile ecgi-group ecgis ecgi range
Configures ECGI range.
Command Mode
Syntax
ecgi range start ecgi_range_start end ecgi_range_end
end ecgi_range_end
Specify the ECGI range end value.
Specify the ECGI range start value.
Usage Guidelines
Use this command to configure an ECGI range.
You can configure a maximum of 64 elements with this command.
profile emergency-profile
Configures emergency profile.
Command Mode
Syntax
profile emergency-profile emergency_profile_name [ udm-profile udm_profile_name ]
Specify name of the emergency profile.
Must be a string.
Specify name of the UDM profile.
Must be a string.
Usage Guidelines
Use this command to configure emergency profiles.
profile failure-handling
Configures the Failure Handling profile.
Command Mode
Syntax
profile failure-handling profile_name
Specify name of the Failure Handling profile.
Must be a string.
Usage Guidelines
Use this command to configure the Failure Handling profile.
profile failure-handling interface diameter
Configures a failure handling profile.
Command Mode
Syntax
profile failure-handling failure_handling_profile_name interface diameter message message_type failure-type [ any | local-error | result-code { result-code-value | result-code-range-start-value | result-code-range-end-value | comma-separated-result-code-value-or-range ]retry count action [ continue action_options | terminate terminate_options ]
Specify a name for the failure handling profile
interface diameter
Specify the failure handling profile for the Diameter interface.
  • any
  • credit-control-initial
  • credit-control-terminate
  • credit-control-update
Specify a Diameter failure type for which an action needs to be taken. Choose a failure type value from the available options. This
  • any
  • local-error
  • result-code
retry count
Specify the number of alternate peers to retry on receiving a failure response.
Default Value: zero.
action continue continue_option
Choose an action value as continue. Choose sub-actions of the selected action from the available options, as required
  • discard-traffic
  • local-fallback
  • retry-server-on-event
  • send-ccrt-on-call-termination
action terminate terminate_option
Choose an action value as terminate. Choose sub-actions of the selected action from the available options, as required
  • with-term-request
  • without-term-request
profile failure-handling interface gtpc message
Configures GTPC failure-handling template message types.
Command Mode
Exec > Global Configuration (config) > Failure Handling Profile Configuration (config-failure-handling-profile_name )
Syntax
interface gtpc message gtpc_message_type
Specify the GTPC message type.
  • S5S8CreateBearerReq
  • S5S8DeleteBearerReq
  • S5S8UpdateBearerReq
Usage Guidelines
Use this command to configure GTPC failure-handling template message types.
profile failure-handling interface gtpc message cause-code-type cause-code
Configures GTPC interface cause code types.
Command Mode
Exec > Global Configuration (config) > Failure Handling Profile Configuration (config-failure-handling-profile_name ) > GTPC Message Configuration (config-message-gtpc_message_type )
Syntax
cause-code gtpc_cause_code_type
Specify the GTPC cause code type.
  • temp-fail
Usage Guidelines
Use this command to configure GTPC interface cause code types.
profile failure-handling interface gtpc message cause-code-type cause-code action
Configures the action type for the cause.
Command Mode
Exec > Global Configuration (config) > Failure Handling Profile Configuration (config-failure-handling-profile_name ) > GTPC Message Configuration (config-message-gtpc_message_type ) > Cause Code Configuration (config-cause-code-cause_code )
Syntax
action action_type [ timeout retry_interval | max-retry max_retry ]
action action_type
Specify the action type for the cause.
  • clear
  • retry
  • terminate
max-retry max_retry
Specify the maximum retry count.
Must be an integer in the range of 0-5.
Default Value: 1.
Specify the retry interval in milliseconds.
Must be an integer in the range of 1000-5000.
Default Value: 1000.
Usage Guidelines
Use this command to configure the action type for the cause.
profile failure-handling interface n11
Configures the N11 interface - SMF/PGW-C timer for reattempting bearer creation/updation.
Command Mode
Syntax
interface n11
Usage Guidelines
Use this command to configure the N11 interface - SMF/PGW-C timer for reattempting bearer creation/updation.
profile failure-handling interface n11 message
Configures N11 message types.
Command Mode
Exec > Global Configuration (config) > Failure Handling Profile Configuration (config-failure-handling-profile_name ) > N11 Interface Configuration (config-n11)
Syntax
Specify the N11 message type.
  • n1n2transfer
Usage Guidelines
Use this command to configure n11 message types.
profile failure-handling interface n11 message cause-code-value cause-code
Configures the N11 interface cause code types.
Command Mode
Exec > Global Configuration (config) > Failure Handling Profile Configuration (config-failure-handling-profile_name ) > N11 Interface Configuration (config-n11) > n1n2transfer Message Configuration (config-message-n1n2transfer)
Syntax
cause-code n11_cause_code_type
Specify the N11 interface cause code type.
  • temp-reject-handover
  • temp-reject-register
Usage Guidelines
Use this command to configure the N11 interface cause code types.
profile failure-handling interface n11 message cause-code-value cause-code action
Command Mode
Exec > Global Configuration (config) > Failure Handling Profile Configuration (config-failure-handling-profile_name ) > N11 Interface Configuration (config-n11) > n1n2transfer Message Configuration (config-message-n1n2transfer) > Cause Code Configuration (config-cause-code-temp-cause_code )
Syntax
action action_type
  • clear
  • retry
  • terminate
max-retry max_retry
Must be an integer in the range of 1-5.
Default Value: 1.
Must be an integer in the range of 100-5000.
Default Value: 300.
Usage Guidelines
profile failure-handling interface pfcp
Configures PFCP Failure Handling template.
Command Mode
Syntax
interface pfcp
Usage Guidelines
Use this command to configure PFCP Failure Handling template.
profile failure-handling interface pfcp message
Configures PFCP message types.
Command Mode
Exec > Global Configuration (config) > Failure Handling Profile Configuration (config-failure-handling-profile_name ) > PFCP Interface Configuration (config-pfcp)
Syntax
message pfcp_message_type
Specify the PFCP message type.
  • N4SessionEstablishmentReq
  • N4SessionModificationReq
  • N4SessionReportReq
  • N4AssociationUpdateReq
Usage Guidelines
Use this command to configure PFCP message types.
profile failure-handling interface pfcp message cause-code-type-est cause-code
Configures PFCP interface cause code types.
Command Mode
Exec > Global Configuration (config) > Failure Handling Profile Configuration (config-failure-handling-profile_name ) > PFCP Interface Configuration (config-pfcp) > PFCP Message Configuration (config-message-message_type )
Syntax
cause-code cause_code_type
Specify the cause code type.
Must be a string.
-Or-
  • no-resource-available
  • no-response-received
  • pfcp-entity-in-congestion
  • reject
  • service-not-supported
  • system-failure
  • peer-overload-reduction
Usage Guidelines
Use this command to configure PFCP interface cause code types.
profile failure-handling interface pfcp message cause-code-type-est cause-code action
Command Mode
Syntax
action action_type [ timeout retry_interval | max-retry max_retry_count ]
action action_type
  • retry-terminate
  • terminate
Specify the maximum retry count for the retry-terminate action.
Default Value: 1.
Usage Guidelines
profile failure-handling interface pfcp message cause-code-type-mod cause-code
Command Mode
Syntax
cause-code-type-mod cause-code pfcp_cause_code_type
Specify the PFCP cause code type.
Must be a string.
-Or-
  • mandatory-ie-incorrect
  • reject
  • session-ctx-not-found
Usage Guidelines
Use this command to configure the PFCP cause code type.
profile failure-handling interface pfcp message cause-code-type-mod cause-code action
Command Mode
Syntax
action action_type condition condition
action action_type
  • terminate
condition condition
Specify the condition.
  • handover-cancel
  • handover-execution
  • handover-preparation
  • idft
  • modify
Usage Guidelines
profile failure-handling interface pfcp message cause-code-type-sessreport cause-code
Configures the PFCP interface cause code types.
Command Mode
Syntax
cause-code-type-sessreport cause-code cause_id
cause-code cause_id
Specify the cause ID or a range of cause IDs separated by either hyphhen (-) or comma (,) or both.
Must be a string.
Usage Guidelines
Use this command to configure the PFCP interface cause-code types.
profile failure-handling interface pfcp message cause-code-type-sessreport cause-code action
Command Mode
Syntax
action action_type
action action_type
  • ignore
  • terminate
Usage Guidelines
profile failure-handling interface sxa message
Configures Sxa message types.
Command Mode
Syntax
sxa message sxa_message_type
Specify the Sxa message type.
  • SessionEstablishmentReq
Usage Guidelines
Use this command to configure Sxa message types.
profile failure-handling interface sxa message cause-code-type-est cause-code
Configures Sxa interface cause code types.
Command Mode
Syntax
cause-code sxa_cause_code_type
Specify the Sxa interface cause code type, or range of cause codes separated by either hyphen (-) or comma (,) or both.
Must be a string.
-Or-
  • reject
  • system-failure
Usage Guidelines
Use this command to configure Sxa interface cause code types.
profile failure-handling interface sxa message cause-code-type-est cause-code action
Command Mode
Syntax
action action_type
  • retry-terminate
  • terminate
Default Value: 1.
Usage Guidelines
profile gtpp-profile gtpp
Configures a GTPP profile.
Command Mode
Syntax
profile gtpp-profile  profile_name gtpp [ dictionary| ignore  ignore_value instance-id [ charging-agent address IPv4_adress port UDP_portserver{ cgf address IPv4_adress max-cdrs max_cdrs { node-alive Enable | Disable } }port UDP_port priority priority deadtime time_interval echo-interval  echo_interval timeout timeout_val max-retry max_retry max-pdu-size max_pdu_size wait-time time_interval }| local-storage | mode[ localstreaming-parallel ]| cgf-server-redundancy-support ]
Specify a profile name for GTPP.
dictionary
Specify a dictionary for ASN.1 based encoding of a CDR.
ignore ignore_value
Specify the configuration to ignore the echo-rc-change. This CLI control option provides a flexibility to detect a CGF path failure due to a change in the echo response RC.
instance-id [ charging-agent address IPv4_adress port UDP_portserver{ cgf address IPv4_adress max-cdrs max_cdrs { node-alive Enable | Disable } }port UDP_port priority priority deadtime time_interval echo-interval echo_interval timeout timeout_val max-retry max_retry max-pdu-size max_pdu_size wait-time time_interval } ]
Specify the instance ID of a GR instance.
  • charging-agent : Configures the charging agent.
    • addressIPv4_address : Specify the IP address of the interface configured within the endpoint that is used to transmit CDR records to the CGF.
    • port : Specify the UDP port.
      Note
      The Charging agent IP address and port configured in GTPP profiles should also be configured in the endpoint gtpprime under the Gz interface. The Runtime configuration update of the Charging agent IP address and port is not recommended. Ensure to add new profile with new Charging agent IP address and port.
  • server : Configure server details.
    • cgf : Configure the CGF server with the following parameters.
      • address IPv4_address: Enter the IPv4 address of CGF server, using dotted-decimal notation range.
      • max : Configures maximum number of unacknowledged CDRs for a CGF. Must be an integer ranging from 1 to 2000.
        Note
        The runtime configuration change of max is not recommended. Follow the Method of procedure:
        1. Delete the cgf having old max and then commit the change.
        2. Add the cgf again with a new max value.
      • node-alive Enable | Disable : Enables or disables sending Node Alive Request to a GTPP Server (such as CGF).
      • port : Specify which port that the CGF is using.
      • priority : Specify the relative priority of this server when system is selecting which CGF server to use.
    • deadtime : Configure the deadtime in seconds. Must be an integer ranging from 1 to 65535. Default value is 120.
    • max-cdrs : Designate the maximum number of CDRs in a GTPP message. Must be an integer ranging from 1 to 255.
    • max-pdu-size : Designate the maximum size of the PDU, in bytes. Must be an ranging from 1024 to 1460.
    • timeout : Specify the number of times the system attempts to communicate with a CGF that is not responding.
    • wait-time : Specify the time to wait before sending the GTPP request.
local-storage
Specify local storage details.
mode [ localstreaming-parallel ]
Specify a storage mode to be used.
  • local : Specify the use of HDD to store CDRs
  • streaming-parallel : Specify the use of HDD to store CDRs, if CGF fails. When CGF comes up, stream the CDRs to the CGF. Streaming is in a parallel and newly generated CDRs are sent to CGF along with CDRs streamed from HDD.
Enable or disable the CGF server redundancy support per GTPP profile. By default this configuration is disabled.
profile icmpv6
Configures ICMPv6 profile parameters.
Command Mode
Syntax
profile icmpv6 profile_name
icmpv6 profile_name
Specify name of the ICMPv6 profile.
Must be a string.
Usage Guidelines
Use this command to configure the ICMPv6 profile parameters.
profile icmpv6 options
Configures ICMPv6 configuration parameters.
Command Mode
Exec > Global Configuration (config) > ICMPv6 Profile Configuration (config-icmpv6-profile_name )
Syntax
options { [ hop-limit hop_limit ] [ mtu mtu_size ] [ reachable-time reachable_period ] [ retrans-timer retransmission_period ] [ router-lifetime lifetime_period ] [ virtual-mac mac_address ] }
hop-limit hop_limit
Specify the hop limit.
Must be an integer in the range of 0-255.
Default Value: 255.
mtu mtu_size
Specify the Maximum Transmission Unit (MTU) size.
Must be an integer in the range of 1280-1500.
Default Value: 1500.
Specify the reachable time in milliseconds.
Must be an integer in the range of 0-3600.
Default Value: 0.
Specify the retransmission time in milliseconds.
Must be an integer in the range of 0-4294968.
Default Value: 0.
Specify the router lifetime in seconds.
Must be an integer in the range of 0-65535.
Default Value: 65535.
Specify the local virtual MAC address.
Usage Guidelines
Use this command to configure the ICMPv6 configuration parameters.
profile icmpv6 ra trigger
Configures trigger to send router advertisements.
Command Mode
Syntax
ra trigger handover { false | true }
Specify whether to disable or enable handovers of Wi-Fi.
  • false
  • true
Usage Guidelines
Use this command to configure trigger to send router advertisements.
profile interface-mapping default interface
This confiuration maps the Gm and Mw interfaces for P-CSCF restoration process.
Command Mode
Syntax
profile interface-mapping default interface [GM] [ ipv4  ipv4_address | ipv6 ipv6_address ] interface [MW] [ ipv4  ipv4_address | ipv6 ipv6_address ]
Enables mapping Gm and Mw interfaces.
interface
Specifies the interfaces to be mapped. It has two possible values GM and MW .
[ ipv4 ipv4_address ]
Specifies the IPv4 address of the Gm or Mw interface to be mapped.
ipv6 ipv6_address
Specifies the IPv6 address of the Gm or Mw interface to be mapped.
Usage Guidelines
Use this command to map Gm and Mw interfaces to send the active P-CSCF addesses after a P-CSCF failure event.
profile load
Configures the load profile for load calculation and publishing.
Command Mode
Syntax
profile load load_profile_name [ load-calc-frequency load_calc_frequency ] [ load-fetch-frequency load_fetch_frequency ]
Specify the system load calculation interval in seconds.
Must be an integer in the range of 5-3600.
Default Value: 10.
Specify the time interval at which Service pod fetches load from Cache pod in seconds.
Default Value: 10.
Specify name of the load profile.
Must be a string.
Usage Guidelines
Use this command to configure the load profile for load calculation and publishing.
You can configure a maximum of one element with this command.
profile load advertise
Configures the advertising action.
Command Mode
Exec > Global Configuration (config) > Load Profile Configuration (config-load-profile_name )
Syntax
advertise [ change-factor change_factor ] [ interval interval ]
Specify the minimum change between current LCI and last indicated LCI, after which only advertising should happen.
Must be an integer in the range of 1-20.
Default Value: 5.
interval interval
Specify the periodicity of sending LCI to the peers in seconds.
Default Value: 300.
Usage Guidelines
Use this command to configure the advertising action.
profile load interface
Configures the list of interfaces.
Command Mode
Syntax
interface interface_type [ action action_on_interface ]
Specify the action on the interface.
  • advertise
Specify the interface type.
  • gtpc
Usage Guidelines
Use this command to configure the list of interfaces.
profile location-area-group
Configures the Location Area Group profile parameters.
Command Mode
Syntax
profile location-area-group profile_name [ ecgi-group ecgi_group_name ] [ ncgi-group ncgi_group_name ] [ tai-group tai_group_name ]
Must be a string.
Specify name of the Location Area Group profile.
Must be a string.
Specify name of the NCGI group.
Must be a string.
Specify name of the TAI group.
Must be a string.
Usage Guidelines
Use this command to configure the Location Area Group profile parameters.
profile message-handling nf type udm mh-profile
Configures the UDM message handling profile.
Command Mode
Syntax
profile message-handling nf type udmmh-profile profile_name
profile message-handling nf type udm mh-profile profile_name
Configure the UDM message handling profile.
Usage Guidelines
Use this command to configure UDM message handling profile at local configuration.
profile n3-tunnel
Configures N3 tunnelling information profile configuration.
Command Mode
Syntax
profile n3-tunnel profile_name [ notify ]
Specify name of the N3 tunnelling profile.
Must be a string.
notify
Specify to enable downlink data notification.
Usage Guidelines
Use this command to configure N3 tunnelling information profile configuration.
profile n3-tunnel buffer
Configures the buffering for downlink direction.
Command Mode
Exec > Global Configuration (config) > N3 Tunnel Profile Configuration (config-n3-tunnel-profile_name )
Syntax
buffer node
buffer node
Specify to enable buffering.
  • upf : Enables buffering in UPF.
Usage Guidelines
Use this command to configure buffering for downlink direction.
profile ncgi-group
Configures NCGI Group profile parameters.
Command Mode
Syntax
profile ncgi-group profile_name
Specify name of the NCGI Group profile.
Must be a string.
Usage Guidelines
Use this command to configure NCGI Group profile parameters.
profile ncgi-group ncgis
Configures the list of MCC, MNC, TAC, and NCGI groups.
Command Mode
Exec > Global Configuration (config) > NCGI Group Profile Configuration (config-ncgi-group-profile_name )
Syntax
Specify the Mobile Country Code (MCC). For example, 01, 001.
Specify the Mobile Network Code (MNC). For example, 23, 456.
Usage Guidelines
Use this command to configure the list of MCC, MNC, TAC, and NCGI groups.
profile ncgi-group ncgis ncgi
Configures NCGI Group parameters.
Command Mode
Exec > Global Configuration (config) > NCGI Group Profile Configuration (config-ncgi-group-profile_name ) > NCGI Group Profile MCC MNC Configuration (config-ncgi-group-mcc /mnc )
Syntax
ncgi list ncgi_values
list ncgi_values
Specify the list of NCGI values - 9 digit hex string NR Cell ID.
Must be a string in the hex-stringncgi pattern. For information on the hex-stringncgi pattern, see the Input Pattern Types chapter.
Usage Guidelines
Use this command to configure NCGI Group parameters.
profile ncgi-group ncgis ncgi range
Configures an NCGI range.
Command Mode
Syntax
ncgi range start ncgi_range_start end ncgi_range_end
end ncgi_range_end
Specify the NCGI range end value.
Specify the NCGI range start value.
Usage Guidelines
Use this command to configure an NCGI range.
profile network-element amf
Configures the AMF profile.
Command Mode
Syntax
profile network-element amf amf_profile_name [ [ failure-handling-profile profile_name ] [ nf-client-profile profile_name ] [ query-target-plmn query_target_plmn ] ]
Specify name of the AMF profile.
Must be a string.
Must be a string.
Specify name of the NF Client profile.
Must be a string.
Specify the query parameter target-plmn to be used.
Must be one of the following:
  • primary
  • serving
  • ue
Usage Guidelines
Use this command to configure the AMF profile. The CLI prompt changes to the AMF Profile Configuration mode (config-amf-<profile_name>).
profile network-element amf discovery
Configures the discovery method.
Command Mode
Exec > Global Configuration (config) > AMF Profile Configuration (config-amf-profile_name )
Command Mode
Exec > Global Configuration (config) > CHF Profile Configuration (config-chf-profile_name )
Command Mode
Exec > Global Configuration (config) > PCF Profile Configuration (config-pcf-profile_name )
Command Mode
Exec > Global Configuration (config) > UDM Profile Configuration (config-udm-profile_name )
Syntax
discovery local
local
Specify to use local configuration for NF discovery. NF discovery through NRF will be skipped.
Usage Guidelines
Use this command to configure the discovery method.
profile network-element amf query-params
Configures query parameter for NF discovery.
Command Mode
Command Mode
Command Mode
Command Mode
Syntax
query-params query_parameters
Specify the query parameters.
  • chf-supported-plmn
  • dnn
  • region-set
  • requester-snssais
  • tai
  • target-nf-instance-id
  • target-plmn
Usage Guidelines
Use this command to configure the query parameter for NF discovery.
profile network-element amf nf-subscription-params
Configures subscription parameters for the NF in a 5G core network.
Command Mode
nf-subscription-params [nfSetCond]
Syntax Description
Specify the NF subscription parameter as NF set.
Usage Guidelines
Use this command to configure the subscription parameters for the NF in a 5G core network.
profile network-element chf
Configures the CHF profile.
Command Mode
Syntax
profile network-element chf chf_profile_name [ [ failure-handling-profile profile_name ] [ failure-handling-profile-offline profile_name ] [ nf-client-profile profile_name ] [ nf-client-profile-offline profile_name ] [ nf-client-profile profile_name ] ]
Specify name of the CHF profile.
Must be a string.
Specify the Failure Handling profile name for offline server.
Must be a string.
Must be a string.
Specify the NF Client profile name for offline server.
Must be a string.
Must be a string.
query-chf-supported-plmn plmn_type
Specify the PLMN type to be used for query parameter chf-supported-plmn.
  • primary
  • serving
  • ue
  • primary
  • serving
  • ue
Usage Guidelines
Use this command to configure the CHF profile. The CLI prompt changes to the CHF Profile Configuration mode (config-chf-<profile_name>).
profile network-element chf discovery
Command Mode
Command Mode
Command Mode
Command Mode
Syntax
discovery local
local
Usage Guidelines
profile network-element chf query-params
Command Mode
Command Mode
Command Mode
Command Mode
Syntax
  • dnn
  • requester-snssais
  • tai
  • target-plmn
Usage Guidelines
profile network-element nrf
Configures NRF profile.
Command Mode
Syntax
profile network-element nrf  nrf_profile_name nf-type nrf message-handling-profileprofile_name nf-type nrf mh-profile mh_profile_nameservice name type { nnrf-at | nnrf-bs | nnrf-nfd | nnrf-nfm } message type { nf-deregister | nf-list-retrieval | nf-profile-retrieval | nf-register | nf-status-notify | nf-status-subscribe | nf-status-unsubscribe | nf-updatenf-register }skip optional-ies locality
  ie smfinfolist tac-based
message-handling-profile profile_name
Specify name of the Message Handling profile.
nf-type nrf
Specify the NF type as NRF.
Specify the NRF message handling profile configuration.
Specify the NRF service name type as nnrf-at, nnrf-bs, nnrf-nfd, and nnrf-nfm.
Specify the message type as as NF Deregister, NF list retrieval, NF profile retrieval, NF register, NF status notify, NF status subscribe, NF status unsubscribe, NF update, and NF regsiter.
Specify the locality parameter to skip for the selected NRF message.
Important
The skip optional-ies locality CLI configuration is currently ineffective and will require backend changes in the future releases. This CLI must be enabled to facilitate seamless rolling upgrade to future releases when this CLI backend support is fully available.
ie smfinfolist
Specify the smfInfoList Information Element name to be grouped.
tac-based
Groups the smfInfo attributes based on TAC Group.
Note
You are recommended to use this configuration only when you want to add new slice or TAC Group information.
Usage Guidelines
Use this command to configure the NRF profile.
profile network-element pcf
Configures the PCF profile.
Command Mode
Syntax
profile network-element pcf pcf_profile_name [ [ cause-map-class-profile profile_name ] [ failure-handling-profile profile_name ] [ nf-client-profile profile_name ] [ predefined-rule-prefix prefix_name ] [ query-target-plmn query_target_plmn ] [ response-timeout response_timeout_duration ] [ rulebase-prefix rulebase_prefix ] [ update-notify update_notify ] [ use-amf-provided-pcf [ false | true ] ]
Specify name of the Cause Map Class profile.
Must be a string.
Must be a string.
Must be a string.
Specify name of the PCF profile.
Must be a string.
Specify the predefined rule prefix string.
Must be a string.
  • primary
  • serving
  • ue
Specify the response timeout duration, in milliseconds.
Must be an integer in the range of 1000-30000.
Default Value: 4000.
Specify the rulebase prefix string.
Must be a string.
Specify the SMF Immediate UpdateNotify Response behavior.
  • expidite-response
use-amf-provided-pcf { false | true }
Specify to enable or disable PCF discovery using PCF ID provided by the AMF.
  • false
  • true
Default Value: true.
Usage Guidelines
Use this command to configure the PCF profile. The CLI prompt changes to the PCF Profile Configuration mode ().
profile network-element pcf bitrates
Configures bitrates round-up parameter.
Command Mode
Syntax
bitrates rounded-up
rounded-up
Specify to round up.
Usage Guidelines
Use this command to configure bitrates round-up parameter.
profile network-element pcf discovery
Command Mode
Command Mode
Command Mode
Command Mode
Syntax
discovery local
local
Usage Guidelines
profile network-element pcf query-params
Command Mode
Command Mode
Command Mode
Command Mode
Syntax
  • dnn
  • requester-snssais
  • tai
  • target-plmn
Usage Guidelines
profile network-element scp
Configures the SCP profile.
Command Mode
Syntax
profile network-element scp scp_profile_name [ nf-client-profile scp_client_profile_name [ discovery-params [ service-names ] | failure-handling-profilefailure_handling_scp_profile_name ]] [ query-target-plmn query_target_plmn ]
profile network-element scpscp_profile_name
Specify the SCP as the network element profile.
scp_profile_name must an alphanumeric string representing the corresponding network element profile name.
Specify the SCP client profile.
scp_client_profile_name must an alphanumeric string representing the corresponding NF client profile name.
Specify this option to include 3gpp-Sbi-Discovery-service-names IE in the SCP header.
Important
If you are downgrading SMF, make sure you first disable this command. If this CLI command is configured after the upgrade, you will observe that only the new sessions will include the discovery service names as one of the headers in SCP.
Specify the SCP failure handling network profile for the configured SCP.
failure_handling_scp_profile_name must an alphanumeric string representing the corresponding SCP failure handling network profile name.
Usage Guidelines
Use this command to configure the SCP profile.
profile network-element sepp
Configures the SEPP profile.
Command Mode
Syntax
profile network-element sepp sepp_profile_name [ [ failure-handling-profile profile_name ] [ nf-client-profile profile_name ] [ query-target-plmn query_target_plmn ] ]
Must be a string.
Must be a string.
  • primary
  • serving
  • ue
Specify name of the SEPP profile.
Must be a string.
Usage Guidelines
Use this command to configure the SEPP profile. The CLI prompt changes to the SEPP Profile Configuration mode (config-sepp-<profile_name>).
profile network-element sepp discovery
Command Mode
Command Mode
Command Mode
Command Mode
Syntax
discovery local
local
Usage Guidelines
profile network-element sepp query-params
Command Mode
Command Mode
Command Mode
Command Mode
Syntax
  • dnn
  • requester-snssais
  • tai
  • target-plmn
Usage Guidelines
profile network-element udm
Configures UDM profile.
Command Mode
Syntax
profile network-element udm udm_profile_name [ [ cause-map-class-profile profile_name ] [ failure-handling-profile profile_name ] [ message-handling-profile profile_name ] [ nf-client-profile profile_name ] ]
Must be a string.
Must be a string.
Must be a string.
  • primary
  • serving
  • ue
Specify the response timeout duration in milliseconds.
Must be a string.
Usage Guidelines
Use this command to configure the UDM profile. The CLI prompt changes to the UDM Profile Configuration mode (config-udm-<profile_name>)
profile network-element udm discovery
Command Mode
Command Mode
Command Mode
Command Mode
Syntax
discovery local
local
Usage Guidelines
profile network-element udm failure-handling-profile-rat
Configures Failure Handling profile specific to RAT type.
Command Mode
Exec > Global Configuration > Profile Configuration
Syntax
failure-handling-profile-rat rat-type rat_type failure-handling-profile failure_handling_profile_name
Specify name of Failure Handling profile.
Must be a string.
rat-type rat_type
Specify the RAT type.
  • eutra
  • nr
  • wlan
Usage Guidelines
Use this command to configure Failure Handling profile specific to RAT type.
profile network-element udm query-params
Command Mode
Command Mode
Command Mode
Command Mode
Syntax
  • dnn
  • requester-snssais
  • tai
  • target-plmn
Usage Guidelines
profile network-element upf
Configures the UPF profile.
Command Mode
Syntax
profile network-element upf upf_profile_name  { max-upf-sessions  max_upf_sessions_count   [ [ capacity lb_capacity ] [ dnn-list dnn_list ] [ downlink-data-buffer { false | true } ] [ downlink-data-report { false | true } ] [ dual-stack-transport { false | true } ]  [ mode mode_of_operation ] [ n4-peer-port port_number ] [ node-id node_id ] [ priority lb_priority ] [ upf-group-profile profile_name ] ] }
Configures maximum UPF sessions on SMF.
Specify the static capacity relative to other UPFs used for load balancing.
Default Value: 10.
dnn-list dnn_list
Specify the list of DNNs supported by the UPF node.
Must be a string.
Specify to enable or disable buffering in UPF for downlink data.
  • false
  • true
Specify to enable or disable notification from UPF for downlink data.
  • false
  • true
Specify to enable or disable the dual stack transport for the N3 interface.
When the dual-stack-transport true command is configured, SMF sends the Outer Header Removal (OHR) IE with the value 6 for the IPv6 address on the supported interfaces.
  • false
  • true
Note
This CLI configuration is applicable for SMF with the legacy interfaces as well.
Specify the UPF mode of operation.
  • offline
Specify the UPF N4 peer port number.
Default Value: 8805.
node-id node_id
Specify the node ID for the UPF peer node.
Must be a string.
Specify the static priority relative to other UPFs used for load balancing.
Default Value: 1.
Specify the name of the UPF Group profile.
Must be a string.
Specify the name of the UPF peer.
Must be a string.
Usage Guidelines
Use this command to configure the UPF profile. When the active profile is removed, clears if any existing sessions and UPF will be detached. The CLI prompt changes to the UPF Profile Configuration mode (config-upf-<profile_name>).
profile network-element upf n4-peer-address
Configures the N4 peer address.
Command Mode
Exec > Global Configuration (config) > UPF Profile Configuration (config-upf-profile_name )
Syntax
n4-peer-address { [ ipv4-address ipv4_address ] [ ipv6-address ipv6_address ] }
Specify the N4 peer IPv4 address.
Specify the N4 peer IPv6 address.
Usage Guidelines
Use this command to confgure the N4 peer address.
profile nf-client nf-type amf amf-profile
Configures AMF profile parameters.
Command Mode
Syntax
profile nf-client nf-type amf amf-profile profile_name
Specify the AMF profile name
Must be a string.
Usage Guidelines
Use this command to configure AMF profile parameters.
profile nf-client nf-type amf amf-profile locality
Configures the AMF profile locality parameter.
Command Mode
Exec > Global Configuration (config) > AMF Profile Configuration (config-amf-profile-profile_name )
Syntax
locality locality_name [ priority locality_priority ]
Specify name of the locality.
Must be a string.
Specify priority of the locality configuration.
Usage Guidelines
Use this command to configure the AMF profile locality parameter.
profile nf-client nf-type amf amf-profile locality service name type
Configures the AMF service name type parameter.
Command Mode
Exec > Global Configuration (config) > AMF Configuration (config-amf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name )
Syntax
type amf_service_name_type
responsetimeout response_timeout
Specify the response timeout interval in milliseconds.
Must be an integer.
Default Value: 2000.
Specify the service name type.
  • namf-comm
  • namf-evts
  • namf-loc
  • namf-mt
Usage Guidelines
Use this command to configure the AMF service name type parameter.
profile nf-client nf-type amf amf-profile locality service name type endpoint-profile
Configures endpoint profile parameters.
Command Mode
Syntax
endpoint-profile endpoint_profile_name { capacity capacity_value | priority profile_priority | api-uri-prefix api_uri_prefix | api-root api_root | uri-scheme uri_scheme }
api-root api_root
Specify the API root.
Must be a string.
Specify the API URI prefix.
Must be a string.
Specify the profile capacity.
Default Value: 10.
Specify name of the endpoint profile.
Must be a string.
Specify the priority of the profile.
Default Value: 1.
Specify the URI scheme.
  • http : HTTP.
  • https : HTTPS.
Usage Guidelines
Use this command to configure endpoint profile parameters.
profile nf-client nf-type amf amf-profile locality service name type endpoint-profile endpoint-name
Configures the endpoint name parameter.
Command Mode
Syntax
endpoint-name endpoint_name [ priority node_priority | capacity node_capacity ]
Specify the node capacity for the endpoint.
Specify name of the endpoint. You can configure the primary, secondary, and tertiary host (IP: Port) within each endpoint for NF server failover handling. The server failover configuration accepts both IPv4 and IPv6 addresses. However, the SMF gives preference to the IPv4 address.
Must be a string.
Specify the node priority for the endpoint.
Usage Guidelines
Use this configuration to configure the endpoint name parameter.
profile nf-client nf-type amf amf-profile locality service name type endpoint-profile endpoint-name primary ip-address
Configures the endpoint IP address and port number.
Command Mode
Syntax
ip-address { { ipv4 ipv4_address | ipv6 ipv6_address } | port port_number }
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Specify the port number.
Usage Guidelines
Use this command to configure the endpoint IP address and port number.
profile nf-client nf-type amf amf-profile locality service name type endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type amf amf-profile locality service name type endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type amf amf-profile locality service name type endpoint-profile version uri-version
Configures the URI version.
Command Mode
Exec > Global Configuration > UDM NF-Client Profile Configuration > UDM Profile Configuration > Locality Configuration > UDM Service Name Type Configuration > Endpoint Profile Configuration > Version Configuration > URL Version Configuration
Syntax
version uri-version { uri_version | full-version full_version }
Specify the full version in the format major-version .minor-version .patch-version .[alpha-draft-number ]
Must be a string.
uri-version uri_version
Specify the URI version.
Must be a string in the pattern v\d.
Usage Guidelines
Use this command to configure the URI version information.
profile nf-client nf-type ausf ausf-profile
Configures AUSF profile parameters.
Command Mode
Syntax
profile nf-client nf-type ausf ausf-profile profile_name
Specify name of the AUSF profile.
Must be a string.
Usage Guidelines
Use this command to configure AUSF profile parameters.
profile nf-client nf-type ausf ausf-profile locality
Configures the AUSF profile locality parameter.
Command Mode
Exec > Global Configuration (config) > AUSF Profile Configuration (config-ausf-profile-profile_name )
Syntax
Must be a string.
Usage Guidelines
Use this command to configure the AUSF profile locality parameter.
profile nf-client nf-type ausf ausf-profile locality service name type
Configures the AUSF service name type parameter.
Command Mode
Exec > Global Configuration (config) > AUSF Configuration (config-ausf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name )
Syntax
type ausf_service_name_type
Must be an integer.
Specify the AUSF service name type.
  • nausf-auth
Usage Guidelines
Use this command to configure the AUSF service name type parameter.
profile nf-client nf-type ausf ausf-profile locality service name type endpoint-profile
Command Mode
Syntax
api-root api_root
Must be a string.
Must be a string.
Default Value: 10.
Must be a string.
Default Value: 1.
  • http : HTTP.
  • https : HTTPS.
Usage Guidelines
profile nf-client nf-type ausf ausf-profile locality service name type endpoint-profile endpoint-name
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type ausf ausf-profile locality service name type endpoint-profile endpoint-name primary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type ausf ausf-profile locality service name type endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type ausf ausf-profile locality service name type endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type ausf ausf-profile locality service name type endpoint-profile version uri-version
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type chf chf-profile
Configures the CHF profile parameters.
Command Mode
Syntax
profile nf-client nf-type chf chf-profile profile_name
Must be a string.
Usage Guidelines
Use this command to configure the CHF profile parameters.
profile nf-client nf-type chf chf-profile locality
Configures the CHF profile locality parameter.
Command Mode
Exec > Global Configuration (config) > CHF Profile Configuration (config-chf-profile-profile_name )
Syntax
Must be a string.
Usage Guidelines
Use this command to configure the CHF profile locality parameter.
profile nf-client nf-type chf chf-profile locality service name type
Configures the CHF service name type parameter.
Command Mode
Exec > Global Configuration (config) > CHF Configuration (config-chf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name )
Syntax
type service_name_type
Must be an integer.
Specify the CHF service name type.
  • nchf-convergedcharging
  • nchf-spendinglimitcontrol
Usage Guidelines
Use this command to configure the CHF service name type parameter.
profile nf-client nf-type chf chf-profile locality service name type endpoint-profile
Command Mode
Syntax
api-root api_root
Must be a string.
Must be a string.
Default Value: 10.
Must be a string.
Default Value: 1.
  • http : HTTP.
  • https : HTTPS.
Usage Guidelines
profile nf-client nf-type chf chf-profile locality service name type endpoint-profile endpoint-name
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type chf chf-profile locality service name type endpoint-profile endpoint-name primary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type chf chf-profile locality service name type endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type chf chf-profile locality service name type endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type chf chf-profile locality service name type endpoint-profile version uri-version
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type eir eir-profile
Configures EIR profile parameters.
Command Mode
Syntax
profile nf-client nf-type eir eir-profile eir_profile_name
Specify name of the EIR profile.
Must be a string.
Usage Guidelines
Use this command to configure the EIR profile parameters.
profile nf-client nf-type eir eir-profile locality
Configures the EIR profile locality parameter.
Command Mode
Exec > Global Configuration (config) > EIR Profile Configuration (config-eir-profile-profile_name )
Syntax
locality locality_name [ priority priority ]
Must be a string.
priority priority
Specify the priority of the locality configuration.
Usage Guidelines
Use this command to configure the EIR profile locality parameter.
profile nf-client nf-type eir eir-profile locality service name type
Configures the EIR service name type parameter.
Command Mode
Exec > Global Configuration (config) > EIR Configuration (config-eir) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name )
Syntax
responsetimeout response_timeout_interval
Must be an integer.
Specify the EIR service name type.
  • n5g-eir-eic
Usage Guidelines
Use this command to configure the EIR service name type parameter.
profile nf-client nf-type eir eir-profile locality service name type endpoint-profile
Command Mode
Syntax
api-root api_root
Must be a string.
Must be a string.
Default Value: 10.
Must be a string.
Default Value: 1.
  • http : HTTP.
  • https : HTTPS.
Usage Guidelines
profile nf-client nf-type eir eir-profile locality service name type endpoint-profile endpoint-name
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type eir eir-profile locality service name type endpoint-profile endpoint-name primary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type eir eir-profile locality service name type endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type eir eir-profile locality service name type endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type eir eir-profile locality service name type endpoint-profile version uri-version
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type endpoint-name fqdn name fqdn port
Configures the fqdn name and port for NF client profile.
Command Mode
Exec > Global Configuration (config) > NF Client Configuration (config-profile nf-client nf-type-client_nf_type )
Syntax
nf-client profile   nf_client_profile_name [ locality  locality_name  [ priority  priority_value  { service name type  service_name_type  { endpoint-profile  endpoint_profile_name [ capacity  capacity_value  | priority  priority_value  | uri-scheme  uri_scheme_name  | endpoint-name  endpoint_name  { fqdn  fqdn_value  | fqdn-port  fqdn_port  } ] } } ] ]
nf-client profile nf_client_profile_name [ locality locality_name [ priority priority_value { service name type service_name_type { endpoint-profile endpoint_profile_name [ capacity capacity_value | priority priority_value | uri-scheme uri_scheme_name | endpoint-name endpoint_name { fqdn fqdn_name | fqdn-port fqdn_port } ] } } ] ]
  • locality locality_name —Specify the locality of the profile.
  • priority priority_value —Specify the priority value.
  • service name type service_name_type —Specify the service name type.
  • uri-scheme uri_scheme_name —Specify the uri-scheme as http or https.
  • fqdn name fqdn_address —Specify the fqdn name.
  • fqdn-port fqdn_port —Specify the fqdn port number. If port is not configured, SMF uses the standard port for FQDN, that is 80 for URI scheme http and 443 for URI scheme https.
Usage Guidelines
Use this command to configure Configures the fqdn name and port for NF client profile.
profile nf-client nf-type pcf pcf-profile
Configures PCF profile parameters.
Command Mode
Syntax
profile nf-client nf-type pcf pcf-profile profile_name
Must be a string.
Usage Guidelines
profile nf-client nf-type pcf pcf-profile locality
Configures the PCF profile locality parameter.
Command Mode
Exec > Global Configuration (config) > PCF Profile Configuration (config-psf-profile-profile_name )
Syntax
Must be a string.
Usage Guidelines
Use this command to configure the PCF profile locality parameter.
profile nf-client nf-type pcf pcf-profile locality service name type
Configures the PCF service name type parameter.
Command Mode
Exec > Global Configuration (config) > PCF Configuration (config-pcf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name )
Syntax
Must be an integer.
Specify the PCF service name parameters.
  • npcf-am-policy-control
  • npcf-bdtpolicycontrol
  • npcf-eventexposure
  • npcf-policyauthorization
  • npcf-smpolicycontrol
  • npcf-ue-policy-control
Usage Guidelines
Use this command to configure the PCF service name type parameter.
profile nf-client nf-type pcf pcf-profile locality service name type endpoint-profile
Command Mode
Syntax
api-root api_root
Must be a string.
Must be a string.
Default Value: 10.
Must be a string.
Default Value: 1.
  • http : HTTP.
  • https : HTTPS.
Usage Guidelines
profile nf-client nf-type pcf pcf-profile locality service name type endpoint-profile endpoint-name
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type pcf pcf-profile locality service name type endpoint-profile endpoint-name primary ip-address
Command Mode
Syntax
ipv4 ipv4_address
Must be a string in the ipv4-address pattern. For information on the ipv4-address pattern, see the Input Pattern Types chapter.
ipv6 ipv6_address
Must be a string in the ipv6-address pattern. For information on the ipv6-address pattern, see the Input Pattern Types chapter.
port port_number
Usage Guidelines
profile nf-client nf-type pcf pcf-profile locality service name type endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type pcf pcf-profile locality service name type endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
Specify the IPv4 address.
ipv6 ipv6_address
Specify the IPv6 address.
port port_number
Usage Guidelines
profile nf-client nf-type pcf pcf-profile locality service name type endpoint-profile version uri-version
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type scp scp-profile
Configures SCP profile parameters.
Command Mode
Syntax
profile nf-client nf-type scp scp-profile profile_name scp-profile scp_profile_namescp-profile scp_profile_namelocality locality_name [ prioritypriority_value service name type service_name_type_value responsetimeout responsetimeout_value endpoint-profile endpoint-profile_name [ capacity capacity_value priority priority_value uri-scheme uri_scheme_value endpoint-name endpoint_name [ priority priority_value capacity endpoint-profile_name primary ip-address ipv4 ipv4_address primary ip-address port port_number] ] ]
Specify the name of the SCP profile.
Must be a string.
Specify the locality of SCP.
Specify the response timeout value.
Specify the SCP endpoint profile name.
Specify the IPv4 address of the primary endpoint.
primary ip-address port primary_port_number
Specify the port number of primary endpoint.
Usage Guidelines
Use this command to configure the SCP profile parameters.
profile nf-client nf-type sepp sepp-profile
Configures SEPP profile parameters.
Command Mode
Syntax
profile nf-client nf-type sepp sepp-profile profile_name
Must be a string.
Usage Guidelines
Use this command to configure SEPP profile parameters.
profile nf-client nf-type sepp sepp-profile locality
Configures the SEPP profile locality parameter.
Command Mode
Exec > Global Configuration (config) > SEPP Profile Configuration (config-sepp-profile-profile_name )
Syntax
Must be a string.
Usage Guidelines
Use this command to configure the SEPP profile locality parameter.
profile nf-client nf-type sepp sepp-profile locality service name type
Configures the SEPP service name type parameter.
Command Mode
Exec > Global Configuration (config) > SEPP Configuration (config-sepp) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name )
Syntax
type service_name_type [ responsetimeout response_timeout ]
Must be an integer.
  • nsmf-pdusession
Usage Guidelines
Use this command to configure the SEPP service name type parameter.
profile nf-client nf-type sepp sepp-profile locality service name type endpoint-profile
Command Mode
Syntax
api-root api_root
Must be a string.
Must be a string.
Default Value: 10.
Must be a string.
Default Value: 1.
  • http : HTTP.
  • https : HTTPS.
Usage Guidelines
profile nf-client nf-type sepp sepp-profile locality service name type endpoint-profile endpoint-name
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type sepp sepp-profile locality service name type endpoint-profile endpoint-name primary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type sepp sepp-profile locality service name type endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type sepp sepp-profile locality service name type endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type sepp sepp-profile locality service name type endpoint-profile version uri-version
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type smf smf-profile
Configures SMF profile parameters.
Command Mode
Syntax
profile nf-client nf-type smf smf-profile smf_profile_name
Specify name of the SMF profile.
Must be a string.
Usage Guidelines
Use this command to configure the SMF profile parameters.
profile nf-client nf-type smf smf-profile locality
Configures the SMF profile locality parameter.
Command Mode
Exec > Global Configuration (config) > SMF Profile Configuration (config-smf-profile-profile_name )
Syntax
Must be a string.
priority priority
Usage Guidelines
Use this command to configure the SMF profile locality parameter.
profile nf-client nf-type smf smf-profile locality service name type
Configures the SMF service name type parameter.
Command Mode
Exec > Global Configuration (config) > SMF Configuration (config-smf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name )
Syntax
type smf_service_name_type
Must be an integer.
  • nsmf-pdusession
Usage Guidelines
Use this command to configure the SMF service name type parameter.
profile nf-client nf-type smf smf-profile locality service name type endpoint-profile
Command Mode
Syntax
api-root api_root
Must be a string.
Must be a string.
Default Value: 10.
Must be a string.
Default Value: 1.
  • http : HTTP.
  • https : HTTPS.
Usage Guidelines
profile nf-client nf-type smf smf-profile locality service name type endpoint-profile endpoint-name
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type smf smf-profile locality service name type endpoint-profile endpoint-name primary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type smf smf-profile locality service name type endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type smf smf-profile locality service name type endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type smf smf-profile locality service name type endpoint-profile version uri-version
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type udm udm-profile
Configures UDM profile parameters.
Command Mode
Syntax
profile nf-client nf-type udm udm-profile udm_profile_name
Must be a string.
Usage Guidelines
Use this command to configure the UDM profile for an NF client.
profile nf-client nf-type udm udm-profile locality
Configures the UDM profile locality parameters.
Command Mode
Exec > Global Configuration (config) > UDM Profile Configuration (config-udm-profile-profile_name )
Syntax
Must be a string.
priority priority
This keyword sets the priority for the locality configuration.
Usage Guidelines
Use this command to configure the UDM profile locality parameter.
profile nf-client nf-type udm udm-profile locality service name type
Configures the UDM service name type parameter.
Command Mode
Exec > Global Configuration (config) > UDM Configuration (config-udm) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name )
Syntax
Must be an integer.
Specify the UDM service name type.
  • nudm-ee
  • nudm-pp
  • nudm-sdm
  • nudm-ueau
  • nudm-uecm
Usage Guidelines
Use this command to configure the UDM service name type parameter.
profile nf-client nf-type udm udm-profile locality service name type endpoint-profile
Command Mode
Syntax
api-root api_root
Must be a string.
Must be a string.
Default Value: 10.
Must be a string.
Default Value: 1.
  • http : HTTP.
  • https : HTTPS.
Usage Guidelines
profile nf-client nf-type udm udm-profile locality service name type endpoint-profile endpoint-name
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client nf-type udm udm-profile locality service name type endpoint-profile endpoint-name primary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type udm udm-profile locality service name type endpoint-profile endpoint-name secondary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type udm udm-profile locality service name type endpoint-profile endpoint-name tertiary ip-address
Command Mode
Syntax
ipv4 ipv4_address
ipv6 ipv6_address
port port_number
Usage Guidelines
profile nf-client nf-type udm udm-profile locality service name type endpoint-profile version uri-version
Command Mode
Syntax
Must be a string.
Usage Guidelines
profile nf-client-failure nf-type amf
Configures the AMF Profile Failure Handling parameters.
Command Mode
Syntax
Usage Guidelines
Use this command to configure the AMF Profile Failure Handling parameters. The CLI prompt changes to the AMF Configuration mode (config-amf).
profile nf-client-failure nf-type amf profile failure-handling
Configures the AMF failure handling template parameter.
Command Mode
Syntax
profile failure-handling fh_template_name
Specify name of the AMF failure handling template.
Must be a string.
Usage Guidelines
Use this command to configure the AMF failure handling template parameter. The CLI prompt changes to the Failure Handling <profile_name> Configuration mode (config-failure-handling-<profile_name>).
profile nf-client-failure nf-type amf profile failure-handling service name type
Command Mode
Syntax
service name type amf_service_name_type
Must be an integer.
Specify the AMF service name type.
  • namf-comm
  • namf-evts
  • namf-loc
  • namf-mt
Usage Guidelines
Use this command to configure AMF service name type parameter. The CLI prompt changes to the Failure Handling Service Name Type Configuration mode (config-type-<service_name_type>)
profile nf-client-failure nf-type amf profile failure-handling service name type message type
Configures the AMF message type parameters.
Command Mode
Exec > Global Configuration (config) > AMF Configuration (config-amf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name ) > Failure Handling Service Name Type Configuration (config-type-service_name_type )
Syntax
message type amf_message_type
Specify the AMF message type.
  • AmfCommCreateUeContext
  • AmfCommEBIAssignment
  • AmfCommN1N2MessageTransfer
  • AmfCommSMStatusChangeNotify
  • AmfCommUeContextTransfer
  • AmfCommUeContextTransferUpdate
Usage Guidelines
Use this command to configure the AMF message type parameters.
profile nf-client-failure nf-type amf profile failure-handling service name type message type status-code httpv2
Configures HTTPv2 status codes.
Command Mode
Syntax
status-code httpv2 range { code code_value | retry retry_value | action action }
action action
Specify the action.
  • continue : Specify to continue the session without any retry. The retry count configuration is invalid with this action.
  • retry-and-continue : Specify to retry as per the configured retry count and continue the session.
  • retry-and-ignore
  • retry-and-terminate : Specify to retry as per the configured retry count and terminate the session in case all retry fails.
  • terminate : Specify to terminate the session without any retry. Retry count configuration is invalid with this action.
code code_value
Specify the code, or a range of status codes separated by either - (hyphen) or , (comma).
Must be an integer.
-Or-
Must be a string.
retransmit-interval retransmit_interval
Specify the retransmit interval in milliseconds.
Must be an integer.
retransmit retransmit
Specify the maximum number of retransmits.
Must be an integer in the range of 1-10.
retry retry_value
Specify the number of times the NF service must retry before proceeding with the action.
Usage Guidelines
Use this command to configure HTTPv2 status codes.
profile nf-client-failure nf-type ausf
Configures AUSF profile failure handling parameters.
Command Mode
Syntax
Usage Guidelines
Use this command to configure AUSF failure handling parameters. The CLI prompt changes to the AUSF Configuration mode (config-ausf).
profile nf-client-failure nf-type ausf profile failure-handling
Configures the AUSF failure handling template parameters.
Command Mode
Syntax
Specify name of the AUSF failure handling template.
Must be a string.
Usage Guidelines
Use this command to configure the AUSF failure handling template parameters. The CLI prompt changes to the Failure Handling Profile Configuration mode (config-failure-handling-<profile_name>).
profile nf-client-failure nf-type ausf profile failure-handling service name type
Configures the AUSF service name type.
Command Mode
Syntax
service name type ausf_service_name_type
Must be an integer.
  • nausf-auth
Usage Guidelines
Use this command to configure the AUSF service name type.
profile nf-client-failure nf-type ausf profile failure-handling service name type message type
Configures the AUSF message type parameters.
Command Mode
Exec > Global Configuration (config) > AUSF Configuration (config-ausf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name ) > Failure Handling Service Name Type Configuration (config-type-service_name_type )
Syntax
message type ausf_message_type
Specify the AUSF message type.
  • AusfAuthenticationCfm
  • AusfAuthenticationReq
Usage Guidelines
Use this command to configure the AUSF message type parameters.
profile nf-client-failure nf-type ausf profile failure-handling service name type message type status-code httpv2
Command Mode
Syntax
action action
Specify the action.
  • retry-and-ignore
code code_value
Must be an integer.
-Or-
Must be a string.
Must be an integer.
retry retry_value
Usage Guidelines
profile nf-client-failure nf-type chf
Configures CHF profile failure handling parameters.
Command Mode
Syntax
Usage Guidelines
Use this command to configure CHF failure handling parameters. The CLI prompt changes to the CHF Configuration mode (config-chf).
profile nf-client-failure nf-type chf profile failure-handling
Configures the CHF failure handling template parameters.
Command Mode
Syntax
Specify name of the CHF failure handling template.
Must be a string.
Usage Guidelines
Use this command to configure the CHF failure handling template for CHF profile.
profile nf-client-failure nf-type chf profile failure-handling service name type
Configures the CHF service name type parameters.
Command Mode
Syntax
type chf_service_name_type
Must be an integer.
Usage Guidelines
Use this command to configure the CHF service name type parameters.
profile nf-client-failure nf-type chf profile failure-handling service name type message type
Configures the CHF message type parameters.
Command Mode
Exec > Global Configuration (config) > CHF Configuration (config-chf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name ) > Failure Handling Service Name Type Configuration (config-type-service_name_type )
Syntax
message type chf_message_type
Specify the CHF message type.
  • ChfConvergedchargingCreate
  • ChfConvergedchargingDelete
  • ChfConvergedchargingUpdate
  • ChfSpendingLimitContolSubscribe
  • ChfSpendingLimitContolUnSubscribe
Usage Guidelines
Use this command to configure the CHF message type parameters.
profile nf-client-failure nf-type chf profile failure-handling service name type message type status-code httpv2
Command Mode
Syntax
action action
Specify the action.
  • retry-and-ignore
code code_value
Must be an integer.
-Or-
Must be a string.
Must be an integer.
retry retry_value
Usage Guidelines
profile nf-client-failure nf-type eir
Configures EIR profile failure handling parameters.
Command Mode
Syntax
Usage Guidelines
Use this command to configure EIR failure handling parameters. The CLI prompt changes to the EIR Configuration mode (config-eir).
profile nf-client-failure nf-type eir profile failure-handling
Configures the EIR failure handling template parameters.
Command Mode
Syntax
Specify name of the EIR failure handling template.
Must be a string.
Usage Guidelines
Use this command to configure the EIR failure handling template for EIR profile.
profile nf-client-failure nf-type eir profile failure-handling service name type
Configures the EIR service name type parameters.
Command Mode
Syntax
type eir_service_name_type
Must be an integer.
  • n5g-eir-eic
Usage Guidelines
Use this command to configure the EIR service name type parameters.
profile nf-client-failure nf-type eir profile failure-handling service name type message type
Specify the EIR message type parameters.
Command Mode
Exec > Global Configuration (config) > EIR Configuration (config-eir) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name ) > Failure Handling Service Name Type Configuration (config-type-service_name_type )
Syntax
message type eir_message_type
Specify the EIR message type.
  • EirCheckEquipmentIdentity
Usage Guidelines
Use this command to configure the EIR message type parameters.
profile nf-client-failure nf-type eir profile failure-handling service name type message type status-code httpv2
Command Mode
Syntax
action action
Specify the action.
  • retry-and-ignore
code code_value
Must be an integer.
-Or-
Must be a string.
Must be an integer.
retry retry_value
Usage Guidelines
profile nf-client-failure nf-type nrf
Configures NRF profile failure handling parameters.
Command Mode
Syntax
Usage Guidelines
Use this command to configure NRF failure handling parameters. The CLI prompt changes to the NRF Configuration mode (config-nrf).
profile nf-client-failure nf-type nrf profile failure-handling
Configures the NRF failure handling template parameters.
Command Mode
Exec > Global Configuration (config) > NRF Configuration (config-nrf)
Syntax
Specify name of the NRF failure handling template.
Must be a string.
Usage Guidelines
Use this command to configure the failure handling template parameters.
profile nf-client-failure nf-type nrf profile failure-handling service name type
Configures NRF service name type parameters.
Command Mode
Syntax
type nrf_service_name_type responsetimeout response_timeout
Specify the timeout interval in milliseconds.
Must be an integer.
Specify the NRF service name type.
  • nrf-nfm
Usage Guidelines
Use this command to configure the NRF service name type parameters.
profile nf-client-failure nf-type nrf profile failure-handling service name type message type
Configures NRF message type parameters.
Command Mode
Exec > Global Configuration (config) > NRF Configuration (config-nrf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name ) > Failure Handling Service Name Type Configuration (config-type-service_name_type )
Syntax
type message_type failover-enabled { false | true } re-registration-enabled { false | true }
Specify whether to enable or disable failover to next NRF.
  • false
  • true
Specify whether to enable or disable re-registration.
  • false
  • true
type message_type
Specify the message type.
  • Heartbeat
  • NFUpdate
  • NRFRegistration
Usage Guidelines
Use this command to configure the NRF message type parameters.
profile nf-client-failure nf-type nrf profile failure-handling service name type message type status-code httpv2
Configures HTTPv2 status code.
Command Mode
Syntax
status-code httpv2 { code code_value | action action }
action action
Specify the action.
  • retry-next
  • retry
code code_value
Specify the code value. Ranges of status codes must be separated by either hyphen (-) or comma (,).
Must be an integer.
-Or-
Must be a string.
Usage Guidelines
profile nf-client-failure nf-type pcf
Configures PCF profile failure handling parameters.
Command Mode
Syntax
Usage Guidelines
Use this command to configure PCF failure handling parameters. The CLI prompt changes to the PCF Configuration mode (config-pcf).
profile nf-client-failure nf-type pcf profile failure-handling
Configures the PCF failure handling template parameters.
Command Mode
Syntax
Specify name of the PCF failure handling template.
Must be a string.
Usage Guidelines
Use this command to configure the failure handling template for PCF profile.
profile nf-client-failure nf-type pcf profile failure-handling service name type
Configures PCF service name type.
Command Mode
Syntax
type pcf_service_name_type
Must be an integer.
Specify the PCF service name type.
Usage Guidelines
Use this command to configure the PCF service name type.
profile nf-client-failure nf-type pcf profile failure-handling service name type message type
Configures the PCF message type parameters.
Command Mode
Exec > Global Configuration (config) > PCF Configuration (config-pcf) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name ) > Failure Handling Service Name Type Configuration (config-type-service_name_type )
Syntax
message type pcf_message_type
Specify the PCF message type.
  • PcfAmfPolicyControlCreate
  • PcfAmfPolicyControlDelete
  • PcfSmpolicycontrolCreate
  • PcfSmpolicycontrolDelete
  • PcfSmpolicycontrolUpdate
Usage Guidelines
Use this command to configure the PCF message type parameters.
profile nf-client-failure nf-type pcf profile failure-handling service name type message type status-code httpv2
Command Mode
Syntax
action action
Specify the action.
  • retry-and-ignore
code code_value
Must be an integer.
-Or-
Must be a string.
Must be an integer.
retry retry_value
Usage Guidelines
profile nf-client-failure nf-type scp
Configures the failure handling for NF clients using specific service and error handling parameters.
Command Mode
Exec > Global Configuration (config) > NF Client Failure Configuration (config-nf-client-failure-nf_type )
Syntax
profile nf-client-failure nf-type  nf_type [ profile failure-handling  failure_handlr_profile_name  [ service-name-type service_name_type | message type message_type { status-code status_code | retry retry_count | action { continue | retry-and-continue | retry-and-fallback | retry-and-ignore | retry-and-terminate | terminate } } } ] ] ]
  • profile nf-client-failure nf-type nf_type —Specify the NF client failure configuration.
  • profile failure-handling failure_handling_profile_name —Specify the failure handling profile name.
  • service-name-type service_name_type —Specify the the service name and type.
  • message type message_type —Specify the the message type.
  • status-code status_code —Specify the status code for http2 error or DNS failure.
  • retry retry_count —Specify the retry count.
  • action { continue | retry-and-continue | retry-and-fallback | retry-and-ignore | retry-and-terminate | terminate } —Specify any action from the preceding options for retry.
Usage Guidelines
Use this command to configure failure handling and its related action.
profile nf-client-failure nf-type sepp
Configures SEPP profile failure handling parameters.
Command Mode
Syntax
Usage Guidelines
Use this command to configure SEPP failure handling parameters. The CLI prompt changes to the SEPP Configuration mode (config-epp).
profile nf-client-failure nf-type sepp profile failure-handling
Configures the SEPP failure handling template parameters.
Command Mode
Syntax
Specify name of the SEPP failure handling template.
Must be a string.
Usage Guidelines
Use this command to configure the SEPP failure handling template for SEPP profile.
profile nf-client-failure nf-type sepp profile failure-handling service name type
Configures the SEPP service name type.
Command Mode
Syntax
service name type sepp_service_name_type [ responsetimeout response_timeout ]
Must be an integer.
Specify the SEPP service name type.
  • nsmf-pdusession
Usage Guidelines
Use this command to configure the SEPP service name type.
profile nf-client-failure nf-type sepp profile failure-handling service name type message type
Configures the SEPP message type parameters.
Command Mode
Exec > Global Configuration (config) > SEPP Configuration (config-sepp) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name ) > Failure Handling Service Name Type Configuration (config-type-service_name_type )
Syntax
message type sepp_message_type
Specify the SEPP message type.
  • HsmfPduSessionNotify
  • HsmfPduSessionUpdate
  • VsmfPduSessionCreate
  • VsmfPduSessionRelease
  • VsmfPduSessionUpdate
Usage Guidelines
Use this command to configure the SEPP message type parameters.
profile nf-client-failure nf-type sepp profile failure-handling service name type message type status-code httpv2
Command Mode
Syntax
action action
Specify the action.
  • retry-and-ignore
code code_value
Must be an integer.
-Or-
Must be a string.
Must be an integer.
retry retry_value
Usage Guidelines
profile nf-client-failure nf-type smf
Configures SMF profile failure handling parameters.
Command Mode
Syntax
Usage Guidelines
Use this command to configure SMF failure handling parameters. The CLI prompt changes to the SMF Configuration mode (config-smf).
profile nf-client-failure nf-type smf profile failure-handling
Configures the SMF failure handling template parameters.
Command Mode
Syntax
Specify name of the SMF failure handling template.
Must be a string.
Usage Guidelines
Use this command to configure the SMF failure handling template for SMF profile.
profile nf-client-failure nf-type smf profile failure-handling service name type
Configures the SMF service name type.
Command Mode
Syntax
service name type smf_service_name_type
Must be an integer.
Specify the SMF service name type.
  • nsmf-pdusession
Usage Guidelines
Use this command to configure the SMF service name type.
profile nf-client-failure nf-type smf profile failure-handling service name type message type status-code httpv2
Command Mode
Syntax
action action
Specify the action.
  • retry-and-ignore
code code_value
Must be an integer.
-Or-
Must be a string.
Must be an integer.
retry retry_value
Usage Guidelines
profile nf-client-failure nf-type udm
Configures UDM profile failure handling parameters.
Command Mode
Syntax
Usage Guidelines
Use this command to configure UDM failure handling parameters. The CLI prompt changes to the UDM Configuration mode (config-udm).
profile nf-client-failure nf-type udm profile failure-handling
Configures the UDM failure handling template parameters.
Command Mode
Syntax
Specify name of the UDM failure handling template.
Must be a string.
Usage Guidelines
Use this command to configure the failure handling template for UDM profile.
profile nf-client-failure nf-type udm profile failure-handling service name type
Configures UDM service name type.
Command Mode
Syntax
type udm_service_name_type [ responsetimeout response_timeout ]
Must be an integer.
  • nudm-ee
  • nudm-pp
  • nudm-sdm
  • nudm-ueau
  • nudm-uecm
Usage Guidelines
Use this command to configure the UDM service name type.
profile nf-client-failure nf-type udm profile failure-handling service name type message type
Configures the UDM message type parameters.
Command Mode
Exec > Global Configuration (config) > UDM Configuration (config-udm) > Failure Handling profile_name Configuration mode (config-failure-handling-profile_name ) > Failure Handling Service Name Type Configuration (config-type-service_name_type )
Syntax
message type udm_message_type
Specify the UDM message type.
  • UdmDeRegistrationReq
  • UdmRegistrationReq
  • UdmSdmGetUESMSubscriptionData
  • UdmSdmSubscribeToNotification
  • UdmSdmUnsubscribeToNotification
  • UdmSubscriptionReq
  • UdmUecmRegisterSMF
  • UdmUecmUnregisterSMF
  • UdmUnSubscriptionReq
Usage Guidelines
Use this command to configure the UDM message type parameters.
profile nf-client-failure nf-type udm profile failure-handling service name type message type status-code httpv2
Command Mode
Syntax
action action
Specify the action.
  • retry-and-ignore
code code_value
Must be an integer.
-Or-
Must be a string.
Must be an integer.
retry retry_value
Usage Guidelines
profile nf-pair nf-type
Configures the NF client pair type parameter.
Command Mode
Syntax
profile nf-pair nf-type nf_type [ [ limit max_discovery_profiles ] [ max-payload-size max_payload_size ] [ nrf-discovery-group group_name ] ]
Specify the maximum number of discovery profiles that NRF can send.
Must be an integer in the range of 1-1000.
Default Value: 10.
Specify the maximum payload size of the discovery response.
Must be an integer in the range of 124-2000.
Default Value: 124.
nf-type nf_type
Specify the NF client pair type.
  • 5G_EIR
  • AF
  • AMF
  • AUSF
  • BSF
  • CHF
  • GMLC
  • LMF
  • N3IWF
  • NEF
  • NRF
  • NSSF
  • NWDAF
  • PCF
  • SEPP
  • SMF
  • SMSF
  • UDM
  • UDR
  • UDSF
  • UPF
Specify name of the NRF discovery group.
Must be a string.
Usage Guidelines
Configures NF client pair parameters. Use this command to configure the NF client pair type parameter.
profile nf-pair nf-type cache invalidation true
Configures the invalidation cache for "true" case.
Command Mode
Exec > Global Configuration (config) > NF Type Configuration (config-nf-type-nf_type )
Syntax
cache invalidation { false | true [ timeout timeout_duration ] }
Specify the invalidation cache timeout duration in milliseconds.
Must be an integer.
Default Value: 0.
true
True condition.
Usage Guidelines
Use this command to configure the true case parameters for invaldation cache.
profile nf-pair nf-type locality
Configures client locality parameter.
Command Mode
Syntax
locality { client locality_name | geo-server locality_name | preferred-server locality_name }
Specify the Client Locality information.
Must be a string.
Specify the Geo Service Locality information.
Must be a string.
Specify the preferred server locality information.
Must be a string.
Usage Guidelines
Use this command to configure the client locality parameter.
profile overload
Configures overload protection profile.
Command Mode
Syntax
profile overload profile_name
Specify name of the overload protection profile.
Must be a string.
Usage Guidelines
Use this command to configure overload protection profile. The CLI prompt changes to the Overload Profile Configuration mode (config-overload-<profile_name>)
You can configure a maximum of one element with this command.
profile overload node-level
Configures Overload profile's node-level parameters.
Command Mode
Exec > Global Configuration (config) > Overload Profile Configuration (config-overload-profile_name )
Syntax
node-level
Usage Guidelines
Use this command to configure the overload profile's node-level parameters. The CLI prompt chnages to the Node-level Configuration mode (config-node-level).
profile overload node-level advertise
Configures the advertising action.
Command Mode
Exec > Global Configuration (config) > Overload Profile Configuration (config-overload-profile_name ) > Node Level Configuration (config-node-level)
Syntax
advertise { [ interval advertising_interval ] [ change-factor change_factor ] [ validity-period validity_period ] }
Specify the minimum change between current OCI and last indicated OCI, after which only advertising should happen.
Must be an integer in the range of 1-20.
Default Value: 5.
Specify the advertising interval in seconds.
Must be an integer in the range of 0-3600.
Default Value: 300.
Specify the validity period of the advertised OCI value in seconds.
Must be an integer in the range of 1-3600.
Default Value: 600.
Usage Guidelines
Use this command to configure the advertising action.
profile overload node-level interface
Configures the list of interfaces.
Command Mode
Syntax
interface interface_type [ overloaded-action overloaded_action ]
Specify the type of the interface.
  • gtpc
Specify the action on the interface in overloaded state.
  • advertise
Usage Guidelines
Use this command to configure the list of interfaces.
profile overload node-level reduction-metric
Configures the percentage reduction metric configuration.
Command Mode
Syntax
reduction-metric { [ minimum minimum_reduction ] [ maximum maximum_reduction ] }
Specify the percentage of reduction in tandem with tolerance maximum configuration. Maximum reduction must be greater than minimum reduction.
Must be an integer in the range of 1-100.
Default Value: 100.
Specify the percentage of reduction in tandem with tolerance minimum configuration. Minimum reduction must be lesser than maximum reduction.
Default Value: 10.
Usage Guidelines
Use this command to configure the Percentage Reduction Metric configuration.
profile overload node-level tolerance
Configures the percentage tolerance level configuration.
Command Mode
Exec > Global Configuration (config) > Overload Profile Configuration (config-overload-profile_name ) > Node-level Configuration (config-node-level)
Syntax
tolerance { [ minimum minimum_tolerance ] [ maximum maximum_tolerance ] }
Specify the tolerance level above which the system is considered to be in self-protection state. Maximum tolerance must be greater than minimum tolerance.
Default Value: 95.
Specify the tolerance level below which the system is considered to be in normal state. Minimum tolerance must be lesser than maximum tolerance.
Default Value: 80.
Usage Guidelines
Use this command to configure the percentage tolerance level configuration.
profile overload overload-exclude-profile
Configures excluding profiles for overload scenarios.
Command Mode
Syntax
overload-exclude-profile self-protection exclude_profile_name peer-overload exclude_profile_name
Specify to exclude profile for peer overload.
Must be a string.
Specify to exclude profile for self protection.
Must be a string.
Usage Guidelines
Use this command to configure excluding profiles for overload scenarios.
profile overload peer-level interface
Command Mode
Syntax
interface type interface_type
type interface_type
Specify the interface type.
Must be one of the following:
  • gtpc
Usage Guidelines
profile overload peer-level interface action throttle
Configures the throttling action.
Command Mode
Syntax
throttle duration throttling_duration threshold max_messages
Specify the duration for which messages must be throttled.
Must be an integer.
Specify the maximum percentage of messages to be allowed during throttling.
Usage Guidelines
Use this command to configure the throttling action.
profile overload peer-level message-prioritization
Configures peer-level message prioritization parameter.
Command Mode
Syntax
peer-level message-prioritization group1 message_priority group2 message_priority group3 message_priority group4 message_priority
Specify the message prioritization for group 1.
Must be an integer in the range of 0-100.
Default Value: 50.
Specify the message prioritization for group 2.
Default Value: 50.
Usage Guidelines
Use this command to configure the peer-level message prioritization parameters. The total of all weights must be 100. That is, "group1 + group2 + group3 + group4 = 100".
profile overload-exclude
Configures the list of exclude overloads.
Command Mode
Syntax
profile overload-exclude exclude_profile_name [ [ arp-list arp_list ] [ dnn-list dnn_list ] [ procedure-list procedures_list ] [ qi5-list qi5_list ] ]
arp-list arp_list
Specify the Allocation and Retention Priorities to be excluded from throttling decisions.
You can configure a maximum of eight elements with this keyword.
Must be an integer in the range of 1-15.
dnn-list dnn_list
Specify the DNNs to be excluded from throttling decisions.
You can configure a maximum of three elements with this keyword.
Must be a string.
Specify the name of the exclude profile.
Must be a string.
Specify the procedures to be excluded from throttling decisions. Applicable only for Self-Protection.
  • session-delete
qi5-list qi5_list
Specify the 5G QoS Identifiers to be excluded from throttling decisions.
Usage Guidelines
Use this command to configure the list of exclude overloads.
profile overload-exclude message-priority
Configures the message priorities to be excluded from throttling decisions.
Command Mode
Exec > Global Configuration (config) > Overload Exclude Profile Configuration (config-overload-exclude-profile_name )
Syntax
message-priority interface_type upto message_priority_upto
  • n4
  • n7
  • n10
  • n11
  • n16
  • n40
  • s5
Specify the message priority up to which must be excluded from throttling decisions.
Must be an integer in the range of 0–31 for SBA interface and 0–15 for GTPC and PFCP interfaces.
Usage Guidelines
Use this command to configure the message priorities to be excluded from throttling decisions.
profile overload-exclude procedure-list
Configures the procedures to be performed on messages as part of the overload exclude process.
Command Mode
Syntax
procedure-list [ session-delete | new-call | xnho | modify | chf-reauth | inter-rat-ho | intra-rat-ho | imexit-nw | imexit-ue | usar ]
procedure-list
Specify the procedure type to be performed.
  • session-delete : Session delete procedure. This is the default procedure.
  • new-call : New call procedure.
  • xnho : XNHO procedure.
  • modify : Modify procedure.
  • chf-reauth : CHF Reauth procedure.
  • inter-rat-ho : Inter-RAT HO procedure.
  • intra-rat-ho : Intra RAT HO procedure.
  • imexit-nw : IM Exit NW Initiated procedure.
  • imexit-ue : IM Exit UE Initiated procedure.
  • usar : USAR procedure.
Usage Guidelines
Use this command to configure the procedures to be performed on the messages as part of the overload exclude process.
profile pcscf
Configures the P-CSCF profile.
Command Mode
Syntax
profile pcscf profile_name
pcscf profile_name
Specify name of the P-CSCF profile.
Must be a string.
Usage Guidelines
Use this command to configure the P-CSCF profile. The CLI prompt changes to the P-CSCF Profile Configuration mode (config-pcscf-<profile_name>).
profile pcscf fqdn
Configures the P-CSCF server's Fully Qualified Domain Name (FQDN).
Command Mode
Exec > Global Configuration (config) > P-CSCF Profile Configuration (config-pcscf-profile_name )
Syntax
fqdn fqdn
fqdn fqdn
Specify the P-CSCF server's FQDN.
Must be a string.
Usage Guidelines
Use this command to configure the P-CSCF server's FQDN.
profile pcscf pcscf-selection
Configures the P-CSCF server selection algorithm.
Command Mode
Syntax
pcscf-selection algorithm
Specify the P-CSCF server selection algorithm.
  • round-robin
Default Value: round-robin.
Usage Guidelines
Use this command to configure the P-CSCF server selection method.
profile pcscf pcscf-restoration trigger
Configures SMF to reselect active P-CSCF addresses for UE.
Command Mode
Syntax
pcscf-restoration trigger [ UDM ] [ action [ mark-down ] ]
Enables UDM triggered P-CSCF restoration and reselection. trigger [ UDM ] specifies that the restoration configuration is triggered by UDM.
It is optional and if configured, it can only have [ mark-down ] as the option.
Usage Guidelines
Use this command to configure the P-CSCF to select active P-CSCF addresses post a P-CSCF address failure.
profile pcscf v4-list
Configures the P-CSCF IPv4 server details in the P-CSCF profile.
Command Mode
Syntax
v4-list
Usage Guidelines
Use this command to configure the P-CSCF IPv4 server details in the P-CSCF profile. The CLI prompt changes to the V4 List Configuration mode (config-v4-list).
profile pcscf v4-list list-entry
Configures the P-CSCF IPv4 server list entries.
Command Mode
Exec > Global Configuration (config) > P-CSCF Profile Configuration (config-pcscf-profile_name ) > V4 List Configuration (config-v4-list)
Syntax
precedence precedence_number
Specify the precedence number for P-CSCF IPv4 server configuration.
Must be an integer in the range of 1-64.
Usage Guidelines
Configures the P-CSCF IPv4 server details in the P-CSCF profile. Use this command to configure the P-CSCF IPv4 server list entries.
profile pcscf v4-list list-entry primary
Configures the IPv4 address of the primary P-CSCF server.
Command Mode
Syntax
primary ipv4 ipv4_address
ipv4 ipv4_address
Specify the IPv4 address of the primary P-CSCF server in dotted-decimal notation.
Usage Guidelines
Use this command to configure the IPv4 address of the primary P-CSCF server.
Example
The following command configures the primary P-CSCF server with IPv4 address 30.22.21.44:
primary ipv4 30.22.21.44
profile pcscf v4-list list-entry secondary
Configures the IPv4 address of the secondary P-CSCF server.
Command Mode
Syntax
secondary ipv4 ipv4_address
ipv4 ipv4_address
Specify the IPv4 address of the secondary P-CSCF server in dotted-decimal notation.
Usage Guidelines
Use this to command configure the IPv4 address of the secondary P-CSCF server.
Example
The following command configures the secondary P-CSCF server with IPv4 address 30.22.21.44:
secondary ipv4 30.22.21.44
profile pcscf v4-list list-entry tertiary
Configures the IPv4 address of the tertiary P-CSCF server.
Command Mode
Syntax
tertiary ipv4 ipv4_address
ipv4 ipv4_address
Specify the IPv4 address of the tertiary P-CSCF server in dotted-decimal notation.
Usage Guidelines
Use this to command configure the IPv4 address of the tertiary P-CSCF server.
Example
The following command configures the tertiary P-CSCF server with IPv4 address 30.22.21.44:
tertiary ipv4 30.22.21.44
profile pcscf v4v6-list
Configures the P-CSCF IPv4v6 server details.
Command Mode
Syntax
v4v6-list
Usage Guidelines
Use this command to configure the P-CSCF IPv4v6 server details in the P-CSCF profile. The CLI prompt changes to the v4v6 List Configuration Mode (config-v4v6-list).
profile pcscf v4v6-list list-entry
Configures the P-CSCF IPv4v6 server list entries.
Command Mode
Exec > Global Configuration (config) > P-CSCF Profile Configuration (config-pcscf-profile_name ) > v4v6 Configuration Mode (config-v4v6-list)
Syntax
Specify the precedence of entries in the P-CSCF IPv4v6 server list.
Usage Guidelines
Use this command to configure the P-CSCF IPv4v6 server list entries.
profile pcscf v4v6-list list-entry primary
Configures the IPv4v6 address of the primary P-CSCF server.
Command Mode
Syntax
primary ipv4 ipv4_address ipv6 ipv6_address
ipv4 ipv4_address
ipv6 ipv6_address
Specify the IPv6 address of the primary P-CSCF server in colon-separated hexadecimal notation.
Usage Guidelines
Use this command to configure the IPv4v6 address of the primary P-CSCF server.
Example
The following command configures the primary P-CSCF server with IPv4 address as 30.22.21.44 and IPv6 address as 123:345:456::6578:
primary ipv4 30.22.21.44 ipv6 123:345:456::6578
profile pcscf v4v6-list list-entry secondary
Configures the IPv4v6 address of the secondary P-CSCF server.
Command Mode
Syntax
secondary { [ ipv4 ipv4_address ] [ ipv6 ipv6_address ] }
ipv4 ipv4_address
ipv6 ipv6_address
Specify the IPv6 address of the secondary P-CSCF server in colon-separated hexadecimal notation.
Usage Guidelines
Use this command to configure the IPv4v6 address of the secondary P-CSCF server.
Example
The following command configures the secondary P-CSCF server with IPv4 address as 30.22.21.44 and IPv6 address as 123:345:456::6578:
secondary ipv4 30.22.21.44 ipv6 123:345:456::6578
profile pcscf v4v6-list list-entry tertiary
Configures the IPv4v6 address of the tertiary P-CSCF server.
Command Mode
Syntax
tertiary { [ ipv4 ipv4_address ] [ ipv6 ipv6_address ] }
ipv4 ipv4_address
ipv6 ipv6_address
Specify the IPv6 address of the tertiary P-CSCF server in colon-separated hexadecimal notation.
Usage Guidelines
Use this command to configure the IPv4v6 address of the tertiary P-CSCF server.
Example
The following command configures the tertiary P-CSCF server with IPv4 address as 30.22.21.44 and IPv6 address as 123:345:456::6578:
tertiary ipv4 30.22.21.44 ipv6 123:345:456::6578
profile pcscf v6-list
Configures the P-CSCF IPv6 server details.
Command Mode
Syntax
v6-list
Usage Guidelines
Use this command to configure the P-CSCF IPv6 server details in the P-CSCF profile. The CLI prompt changes to the V6 List Configuration mode (config-v6-list).
profile pcscf v6-list list-entry
Configures the P-CSCF IPv6 server list entries.
Command Mode
Exec > Global Configuration (config) > P-CSCF Profile Configuration (config-pcscf-profile_name ) > V6 List Configuration (config-v6-list)
Syntax
precedence precedence_level
Specify the precedence of entries in the P-CSCF IPv6 server list.
Usage Guidelines
Use this command to configure the P-CSCF IPv6 server list entries.
profile pcscf v6-list list-entry primary
Configures the IPv6 address of the primary P-CSCF server.
Command Mode
Syntax
primary ipv6 ipv6_address
ipv6 ipv6_address
Usage Guidelines
Use this command to configure the IPv6 address of the primary P-CSCF server.
Example
The following command configures the primary P-CSCF server with IPv6 address 123:345:456::6578:
primary ipv6 123:345:456::6578
profile pcscf v6-list list-entry secondary
Configures the IPv6 address of the secondary P-CSCF server.
Command Mode
Syntax
secondary ipv6 ipv6_address
ipv6 ipv6_address
Usage Guidelines
Use this command to configure the IPv6 address of the secondary P-CSCF server.
Example
The following command configures the secondary P-CSCF server with IPv6 address 123:345:456::6578:
secondary ipv6 123:345:456::6578
profile pcscf v6-list list-entry tertiary
Configures the IPv6 address of the tertiary P-CSCF server.
Command Mode
Syntax
tertiary ipv6 ipv6_address
ipv6 ipv6_address
Usage Guidelines
Use this command to configure the IPv6 address of the tertiary P-CSCF server.
Example
The following command configures the tertiary P-CSCF server with the IPv6 address 123:345:456::6578:
tertiary ipv6 123:345:456::6578
profile ppd
Configures the Paging Policy Differentiation (PPD) profile configuration.
Command Mode
Syntax
ppd ppd_profile_name [ fqi 5qi_priority_levels ]
Specify the range of 5qi priority levels.
Must be an integer.
-Or-
Must be a string.
Specify name of the PPD profile.
Must be a string.
Usage Guidelines
Use this command to configure the PPD profile configuration.
profile ppd dscp-list
Configures the Differentiated Services Code Point (DSCP) values.
Command Mode
Exec > Global Configuration (config) > PPD Configuration (config-ppd-profile_name )
Syntax
dscp dscp_value [ ppi ppi_value ]
dscp dscp_value
Specify the DSCP value.
Must be a string in the hex-stringdscp pattern. For information on the hex-stringdscp pattern, see the Input Pattern Types chapter.
ppi ppi_value
Specify the Paging Policy Indicator (PPI) value.
Must be an integer in the range of 0-7.
Usage Guidelines
Use this command to configure the DSCP values.
profile qos
Configures the QoS profile configuration.
Command Mode
Syntax
profile qos qos_profile_name  message-priority-profile profile_name   [ [ priority qi_priority ] [ qi5 qos_id ] ] arp-priority-level arp_value message-priority-profile profile_name
Specify the 5QI priority level.
Must be an integer in the range of 1-127.
Specify name of the QoS profile.
Must be a string.
Associates message priority profile to QoS profile.
qi5 qos_id
Specify the ID for the authorized QoS parameters.
Must be an integer in the range of 0-255.
arp-priority-level arp_value message-priority-profile profile_name : Message priority profile associated to ARP. Specify the ARP value in the range between 1 to 255.
The Message priority profile associated to QCI or ARP or QoS profile, or message priority profile associated to WPS are negotiated to find the one which has the better priority.
vplmn-qos-negotiation { false | true }
Specify whether to enable or disable configured QoS to negotiate for defalut flow.
  • false
  • true
Default Value: false.
Usage Guidelines
Use this command to configure the QoS profile configuration.
profile qos ambr
Configures the Aggregate Maximum Bit Rate (AMBR).
Command Mode
Exec > Global Configuration (config) > QoS Profile Configuration (config-qos-profile_name )
Syntax
ambr { ul ambr_uplink_threshold | dl ambr_downlink_threshold }
Specify the AMBR downlink threshold in bps, Kbps, Mbps, Gbps, or Tbps.
Must be a string in the pattern '[0-9]+.[0-9]+ (bps|Kbps|Mbps|Gbps|Tbps)'.
Specify the AMBR uplink threshold in bps, Kbps, Mbps, Gbps, or Tbps.
Usage Guidelines
Use this command to configure the AMBR.
profile qos arp
Configures the Allocation and Retention Priority (ARP) for the service data.
Command Mode
Syntax
arp priority-level priority_level [ preempt-cap preempttion_capability ] [ preempt-vuln preemption_vulnerability ]
Specify the preemption capability.
  • MAY_PREEMPT
  • NOT_PREEMPT
Default Value: MAY_PREEMPT.
Specify the preemption vulnerability.
  • NOT_PREEMPTABLE
  • PREEMPTABLE
Default Value: NOT_PREEMPTABLE.
Specify the priority level.
Usage Guidelines
Use this command to configure the ARP for the service data.
profile qos dscp-map qi5
Configures the standard 5QI value.
Command Mode
Syntax
dscp-map qi5 standard_qci
qi5 standard_qci
Specify the standard QCI value.
Must be an integer in the range of 1-255.
Usage Guidelines
Configures the 5QI to DSCP-Marking mapping. Use this command to configure the standard 5QI value.
profile qos dscp-map qi5 arp-priority-level
Configures the ARP priority level.
Command Mode
Syntax
arp priority-level arp_priority_level
Command Mode
Exec > Global Configuration (config) > SGW QoS Profile Configuration (config-sgw-qos-profile-profile_name )
Syntax
dscp-map operator-defined-qci operator_defined_qci [ gbr arp-priority-level arp_priority_level ]
Specify the ARP priority level.
Usage Guidelines
Configures the type of the QCI to GBR. Use this command to configure the ARP priority level.
profile qos dscp-map qi5 arp-priority-level dscp-info
Configures the Differentiated Services Code Point (DSCP) type.
Command Mode
Syntax
dscp-info type dscp_type
dl-encap-copy-inner
Specify to copy the inner DSCP to outer.
dl-encap-dscp-marking dscp_marking
Specify the DSCP value to be applied to packets.
dl-encaps-header
Specify the DSCP value be applied to encaps header.
dl-ud-dscp dscp_marking
dl-ud-encap-copy-inner
dl-ud-encap-dscp dscp_marking
encsp-header
Specify the DSCP value to be applied to encaps header.
type dscp_type
Specify the DCSP type.
  • downlink
  • uplink
user-datagram1
Specify the DSCP value be applied to user datagram.
Usage Guidelines
Configures the type of the QCI to GBR. Use this command to configure the DSCP type.
profile qos dscp-map qi5 arp-priority-level dscp-info user-datagram
Configures the Differentiated Services Code Point (DCSP) value to be applied to user datagram.
Command Mode
Syntax
user-datagram ul-uD-dscp-marking dscp_marking
Usage Guidelines
Use this command to configure the DCSP value to be applied to user datagram.
profile qos dscp-map qi5 dscp-info
Command Mode
Syntax
dl-encap-copy-inner
dl-encaps-header
encsp-header
type dscp_type
  • downlink
  • uplink
user-datagram1
Usage Guidelines
profile qos dscp-map qi5 dscp-info user-datagram
Command Mode
Syntax
Usage Guidelines
profile qos max
Configures the maximum data burst volume.
Command Mode
Syntax
max data-burst max_data_burst_volume
Specify the maximum data burst volume.
Must be an integer in the range of 1-4095.
Usage Guidelines
Use this command to configure the maximum data burst volume.
profile qos qos-enforcement
Configures flow-level QoS enforcement configuration.
Command Mode
Syntax
qos-enforcement flow-level
flow-level
Specify flow-level QoS enforcement.
Usage Guidelines
Use this command to configure flow-level QoS enforcement configuration.
profile qos qosflow qi5
Configures Qos flow parameters for 5QI/ARP values.
Command Mode
Syntax
qosflow qi5  qci_value
Specify the QCI value.
Note
If there is no message priority profile associated to a default bearer/flow qci/arp, then message priority value is considered from message priority profile that is associated to a QoS profile for the IMS and emergency calls. When a dedicated bearer/flow gets created, message priority is considered from message priority profile associated to the qci/arp depending on the configuration.
Usage Guidelines
Use this command to configure the Qos flow parameters for 5QI/ARP values.
profile qos qosflow qi5 arp-priority-level
Command Mode
Syntax
arp-priority-level arp-value arp_value
arp-value arp_value
Specify the ARP value.
Usage Guidelines
Use this command to configure the the ARP priority level.
profile qos qosflow qi5 arp-priority-level dscp-info downlink encaps-header
Configures the DSCP value to be applied to encaps header.
Command Mode
Syntax
encaps-header dscp_for_encaps_header
dscp-marking dscp_for_packets
Specify the DSCP value to be applied to packets. For example, 0x3F.
encap-copy-inner
Specify to copy inner DSCP to outer.
encap-copy-outer
Specify to copy outer DSCP to inner.
Usage Guidelines
Configures downlink/uplink DSCP information. Use this command to configure the DSCP value to be applied to encaps header.
profile qos qosflow qi5 arp-priority-level dscp-info downlink user-datagram
Configures the DSCP value to be applied to user datagram.
Command Mode
Syntax
user-datagram ud-dscp dscp_for_packets ud-encaps-header dscp_for_encaps_header
encap-copy-inner
encap-copy-outer
Usage Guidelines
Use this command to the DSCP value to be applied to user datagram.
profile qos qosflow qi5 arp-priority-level dscp-info uplink encaps-header
Command Mode
Syntax
encap-copy-inner
encap-copy-outer
Usage Guidelines
profile qos qosflow qi5 arp-priority-level dscp-info uplink user-datagram
Command Mode
Syntax
encap-copy-inner
encap-copy-outer
Usage Guidelines
profile qos qosflow qi5 arp-priority-level flow-parameter gfbr
Configures the Guaranted Bit Rate (GFBR).
Command Mode
Syntax
flow-parameter gfbr { [ ul gfbr_uplink_threshold ] [ dl gfbr_downlink_threshold ] }
Specify the GFBR downlink threshold.
Specify the GFBR uplink threshold.
Usage Guidelines
Use this command to configure the GFBR.
profile qos qosflow qi5 arp-priority-level flow-parameter mfbr
Configures the Maximum Bit Rate (MFBR).
Command Mode
Syntax
flow-parameter mfbr { [ ul mfbr_uplink_threshold ] [ dl mfbr_downlink_threshold ] }
Specify the MFBR downlink threshold.
Specify the MFBR uplink threshold.
Usage Guidelines
Use this command to configure the MFBR.
profile qos qosflow qi5 dscp-info downlink encaps-header
Command Mode
Syntax
encap-copy-inner
encap-copy-outer
Usage Guidelines
profile qos qosflow qi5 dscp-info downlink user-datagram
Command Mode
Syntax
encap-copy-inner
encap-copy-outer
Usage Guidelines
profile qos qosflow qi5 dscp-info uplink encaps-header
Command Mode
Syntax
encap-copy-inner
encap-copy-outer
Usage Guidelines
profile qos qosflow qi5 dscp-info uplink user-datagram
Command Mode
Syntax
encap-copy-inner
encap-copy-outer
Usage Guidelines
profile qos qosflow qi5 flow-parameter gfbr
Command Mode
Syntax
Usage Guidelines
profile qos qosflow qi5 flow-parameter mfbr
Command Mode
Syntax
Usage Guidelines
profile qos vplmn-qos
Configures the QoS profile its key parameters.
Command Modes
Syntax
profile qos vplmn_qos { ambr ul ambr_ul | ambr dl ambr_dl | qi5 qci_value | arp priority-level  priority_value | arp preempt-cap { not_preempt | may_preempt } | arp preempt-vuln { not_preemptable | preemptable} }
profile-qos vplmn-qos
Specify the quality of service profile name for the vplmn profile.
ambr ul ul_value
Specify the uplink Aggregate Maximum Bit Rate (AMBR).
ambr dl dl_value
Specify the downlink Aggregate Maximum Bit Rate (AMBR).
qi5 qci_value
Specify the QoS Class Identifier (QCI).
Specify the ARP preemption capability.
arp preempt-vuln { not_preemptable | preemptable }
Specify the ARP preemption vulnerability.
Usage Guidelines
This command creates a QoS profile name and defines its key parameters. It sets the uplink and downlink aggregate maximum bit rates (AMBR), specifies a QoS Indicator, and configures the Allocation and Retention Priority (ARP) with priority level, disabling both preemption capability and vulnerability.
profile-qos vplmn-qos-negotiation flow-type default action
Configures the "vplmn-qos" quality of service (QoS) profile to specify how QoS negotiation requests for default flows are handled.
Command Modes
Syntax
profile qos vplmn-qos  { vplmn-qos-negotiation flow-type default action [ override | reject] }
  • override : With this configuration, the VSMF overrides the HPLMN values with the VPLMN values for QoS parameters.
  • terminate : With this configuration, the VSMF rejects the session establishment if the HPLMN has upgraded any of the QoS parameters that are part of the VPLMN QoS.
Usage Guidelines
This command configures the "vplmn-qos" quality of service (QoS) profile to specify how QoS negotiation requests for default flows are handled. By setting the action to either "override" or "reject," it determines whether the system overrides the requested QoS parameters or rejects the negotiation for default flow types when there is a mismatch. This ensures that default flow QoS policies are enforced according to network requirements.
profile radius
Configures RADIUS client profile.
Command Mode
Syntax
profile radius [ [ algorithm server_selection_algorithm ] [ deadtime deadtime_interval ] [ enable-packet-dump ] [ dictionary  dictionary_name  ] [ max-retry max_retries ] [ timeout timeout_interval ] ]
Specify the algorithm for selecting the RADIUS server. Default Value: first-server.
  • first-server
  • round-robin
Specify the time interval, in minutes, between the RADIUS server being marked unreachable and connection can be re-attempted.
Must be an integer in the range of 0-65535.
enable-packet-dump
Specify to enable packet dump.
dictionary
Specify the dictionary name as ISE.
max_retries
Specify the maximum number of times the system will attempt retry with the RADIUS server.
timeout_interval
Specify the time interval to elapse for a response from the RADIUS server before re-transmitting.
Must be an integer in the range of 1-65535.
Usage Guidelines
Use this command to configure RADIUS client profile. The CLI prompt changes to the RADIUS Configuration mode (config-radius).
profile radius accounting
Configures RADIUS accounting parameters.
Command Mode
Syntax
accounting options
  • first-server
  • round-robin
max_retries
timeout_interval
Usage Guidelines
Use this command to configure the RADIUS accounting parameters.
profile radius accounting attribute
Configures RADIUS identification parameters.
Command Mode
Exec > Global Configuration (config) > RADIUS Configuration (config-radius)
Syntax
attribute { nas-identifier nas_id | nas-ip aaa_nas_ipv4_address }
nas-identifier nas_identifier
Specify the attribute name by which the system will be identified in Auth or Accounting Request messages.
Must be a string in the fmtstr pattern. For information on the fmtstr pattern, see the Input Pattern Types chapter.
Specify the AAA NAS IPv4 address.
-Or-
Usage Guidelines
Use this command to configure RADIUS identification parameters.
profile radius accounting attribute instance
Configures instance configuration parameters.
Command Mode
Exec > Global Configuration > RADIUS Configuration (config-radius)
Syntax
attribute instance instance_id nas-ip aaa_nas_ipv4_address
Specify the instance ID.
Must be an integer in the range of 1-8.
-Or-
Usage Guidelines
Use this command to configure instance configuration parameters.
profile radius accounting detect-dead-server
Configures the response timeout duration, in seconds, to wait for a response from the RADIUS server after which it is marked as unreachable/dead.
Command Mode
Syntax
detect-dead-server response-timeout response_timeout
Specify the time interval, in seconds, for response from RADIUS server to mark as unreachable.
Usage Guidelines
Use this command to configure the response timeout duration, in seconds, to wait for a response from the RADIUS server after which it is marked as unreachable/dead.
profile radius allow auth
Configures the allow-auth on RADIUS server.
Command Mode
Syntax
enable-allow-auth
enable-allow-auth
If allow-auth is enabled in the configuration, it allows the ongoing call to continue irrespective of authentication being successful, timed out, or any error message received. The default value is false, configuration is required to enable the allow-auth.
Usage Guidelines
Use this command to enble allow-auth in RADIUS server.
radius profile server group allow auth
Configures the allow-auth on RADIUS server group.
Command Mode
Exec > Global Configuration (config) > RADIUS Configuration (config-radius) > Server Group (config server group)
Syntax
enable-allow-auth
enable-allow-auth
Usage Guidelines
Use this command to enble allow-auth on any of the RADIUS server group.
profile radius attribute
Command Mode
Syntax
Must be a string in the ipv4-address pattern. For information on the ipv4-address pattern, see the Input Pattern Types chapter.
-Or-
Must be a string in the ipv6-address pattern. For information on the ipv6-address pattern, see the Input Pattern Types chapter.
Usage Guidelines
profile radius attribute instance
Command Mode
Syntax
-Or-
Usage Guidelines
profile radius consecutive failure dead server detection
Configures the value of consecutive failreres in the RADIUS server, after the value is reached, the server is marked as unreachable/dead.
Command Mode
Syntax
detect-dead-server consecutive-failures value
When a server's failure count reaches the threshold for consecutive failures, the server is declared as dead server.
value : must be an integer in the range of 1–1000. Default: 10.
It is recommended to configure the consecutive failure value more than the request maxTransmissions value in the setup.
Usage Guidelines
Use this command to configure the failure value before the server is marked as dead.
profile radius detect-dead-server
Command Mode
Syntax
Usage Guidelines
profile radius dictionary
Configures RADIUS dictionary.
Command Mode
Syntax
Specify the name of the dictionary as: Identify Services Engine (ISE) or 3GPP dictionary.
If this dictionary is configured, the SMF service renders the RADIUS configuration and populates the request messages with selected dictionary specific parameters.
Must be a string.
Usage Guidelines
Use this command to configure RADIUS dictionary.
profile radius max transmissions
Configures the max-transmissions in the RADIUS server.
Command Mode
Syntax
max-transmissions value
Max transmission allows to configure the transmission parameters for all the available servers. This feature helps to cross-check if the number of transmissions exceeds the number of retries once the retry cycle for a request is finished, and if so, it begins the subsequent retry cycle on a different server if one is available. If no server is available or if maxtransimissions limit is reached, then the server database sends out the timeout response.
value : must be an integer in the range of 0–65535. Default: 6.
Usage Guidelines
Use this command to configure the value of max-transmissions in the RADIUS server.
profile radius server
Configures the external RADIUS server parameters.
Command Mode
Exec > Global Configuration (config) > RADIUS Configuration (config-radius) > RADIUS Server Group Configuration (config-server-group-group_name )
Syntax
server radius_server_ip_address radius_server_port_number [ [ secret radius_server_secret ] [ priority radius_server_priority ] [ type server_type ] ]
Specify the priority of the RADIUS server.
Specify the RADIUS server secret.
Must be a string.
type server_type
Specify the server type.
  • acct : Specify the server is used for Accounting requests.
  • auth : Specify the server is used for Authentication/Author requests.
Default Value: auth.
Specify the IP address of the RADIUS server.
-Or-
Specify the port number of the RADIUS server.
Usage Guidelines
Use this command to configure the external RADIUS server parameters.
profile radius server-group
Configures association of RADIUS servers to groups.
Command Mode
Syntax
server-group server_group_name
algorithm sever_selection_algorithm
  • first-server
  • round-robin
Specify name of the RADIUS server group.
max_retries
timeout_interval
Usage Guidelines
Use this command to configure the association of RADIUS servers to groups.
profile radius server-group accounting
Command Mode
Syntax
accounting options
  • first-server
  • round-robin
max_retries
timeout_interval
Usage Guidelines
profile radius server-group accounting attribute
Command Mode
Syntax
-Or-
Usage Guidelines
profile radius server-group accounting attribute instance
Command Mode
Syntax
-Or-
Usage Guidelines
profile radius server-group attribute
Command Mode
Syntax
-Or-
Usage Guidelines
profile radius server-group attribute instance
Command Mode
Syntax
-Or-
Usage Guidelines
profile radius server-group server
Configures the RADIUS server parameters.
Command Mode
Syntax
server type server_type radius_server_ip_address radius_server_port_number
type server_type
Specify the RADIUS server type.
Usage Guidelines
Use this command to configure the RADIUS server parameters.
profile radius server group max transmissions
Configures the max-transmissions on the RADIUS server group.
Command Mode
Exec > Global Configuration (config) > RADIUS Configuration (config-radius) > Server Group (config server-group)
Syntax
Max transmission allows to configure the transmission parameters for all the available server groups. This feature helps to cross-check if the number of transmissions exceeds the number of retries once the retry cycle for a request is finished, and if so, it begins the subsequent retry cycle on a different server group if one is available. If no server group is available or if maxtransimissions limit is reached, then the server database sends out the timeout response.
Usage Guidelines
Use this command to configure the value of max-transmissions on the RADIUS server group.
profile radius-dynamic-author
Configures the RADIUS Dynamic Author/COA profile.
Command Mode
Syntax
profile radius-dynamic-author [ client client_ip_address | secret secret_key | nas-identifier nas_identifier ]
Specify the Dynamic Author NAS ID.
secret secret_key
Specify the Dynamic Author server shared secret key.
Must be a string.
Usage Guidelines
Use this command to configure the RADIUS Dynamic Author/COA profile.
profile radius-dynamic-author client
Configures the RADIUS Dynamic Author Client parameters.
Command Mode
Syntax
client ip radius_client_ip_address secret secret_key
Specify the IP address of the RADIUS client.
-Or-
secret secret_key
Specify the client shared secret key.
Must be a string.
Usage Guidelines
Use this command to configure the RADIUS Dynamic Author Client parameters.
profile sgw-qos-profile
Configures the SGW QoS profile configuration.
Command Mode
Syntax
profile sgw-qos-profile sgw_qos_profile_name
Specify name of the SGW QoS profile.
Must be a string.
Usage Guidelines
Use this command to configure the SGW QoS profile configuration.
profile sgw-qos-profile dscp-map operator-defined-qci
Configures the non-standard QCI values.
Command Mode
Syntax
dscp-map operator-defined-qci non_standard_qos_class_id
Specify the non-standard QoS class identifier.
Must be an integer in the range of 128-254.
Usage Guidelines
Use this command to configure the non-standard QCI values.
profile sgw-qos-profile dscp-map operator-defined-qci gbr arp-priority-level
Command Mode
Syntax
dscp-map qi5 qci_name arp-priority-level arp_priority_level
Usage Guidelines
profile sgw-qos-profile dscp-map operator-defined-qci gbr arp-priority-level dscp-info
Command Mode
Syntax
dl-encap-ci-dscp dscp_value
dl-encap-ci-priority priority
Specify the priority.
Must be a string in the pattern '[0-7]{1}'.
dl-encap-ci-user-datagram
Specify DSCP value be applied to user datagram.
dl-encap-co-dscp dscp_value
dl-encap-co-priority priority
dl-encap-co-user-datagram
dl-encap-copy-inner
dl-encap-copy-outer
Specify to copy the outer DSCP to inner.
dl-encap-dscp-marking dscp_value
dl-encap-dscp-priority priority
dl-encap-dscp-user-datagram
dl-encap-dscp dscp_value
dl-encaps-header dscp_value
dl-iq-copy-outer
dl-iq-encap-dscp-marking dscp_value
dl-iq-encap-type
dl-iq-encaps-header
dl-iq-ud-dscp dscp_value
dl-iq-user-datagram
dl-priority dl_priority
dl-ud-dscp dscp_value
dl-ud-encap-copy-outer
dl-ud-encaps-header dscp_value
dl-ud-priority priority
dl-user-datagram
dscp-marking-dl dscp_value
type dscp_type
  • downlink
  • uplink
ul-encap-ci-dscp dscp_value
Specify the DSCP value to be applied to packets. A hexadecimal string starting with "0x". For example, 0x3F.
ul-encap-ci-priority ul_encap_ci_priority
ul-encap-ci-user-datagram
ul-encap-co-dscp dscp_value
ul-encap-co-priority priority
ul-encap-co-user-datagram
ul-encap-copy-inner
ul-encap-copy-outer
ul-encap-dscp-marking dscp_value
ul-encap-dscp-priority priority
ul-encap-dscp-user-datagram dscp_value
ul-encap-dscp dscp_value
ul-encaps-header dscp_value
Specify the DCSP value to be applied to encaps header.
ul-iq-encap-copy-inner
ul-iq-encap-copy-outer
ul-iq-encap-dscp-marking dscp_value
ul-iq-encaps-header
ul-iq-ud-dscp dscp_value
ul-iq-user-datagram dscp_value
ul-priority priority
ul-ud-dscp dscp_value
Specify the DSCP value to be applied to packets. A hexadecimal string starting with 0x. For example, 0x3F.
ul-ud-encap-copy-inner
ul-ud-encap-copy-outer
ul-ud-encap-dscp-marking dscp_value
ul-ud-encaps-header dscp_value
ul-ud-priority priority
ul-user-datagram dscp_value
Usage Guidelines
profile sgw-qos-profile dscp-map operator-defined-qci gbr dscp-info
Command Mode
Syntax
dl-encap-copy-inner
dl-encap-copy-outer
dl-iq-copy-outer
dl-iq-encap-type
dl-iq-encaps-header
dl-iq-user-datagram
dl-user-datagram
type dscp_type
  • downlink
  • uplink
ul-encap-copy-inner
ul-encap-copy-outer
ul-iq-encaps-header
Usage Guidelines
profile sgw-qos-profile dscp-map operator-defined-qci non-gbr
Configures the QCI type to non GBR.
Command Mode
Syntax
non-gbr options
Usage Guidelines
Use this command to configure the QCI type to non GBR.
profile sgw-qos-profile dscp-map operator-defined-qci non-gbr arp-priority-level
Command Mode
Syntax
Usage Guidelines
profile sgw-qos-profile dscp-map operator-defined-qci non-gbr arp-priority-level dscp-info
Command Mode
Syntax
dl-encap-copy-inner
dl-encap-copy-outer
dl-iq-copy-outer
dl-iq-encap-type
dl-iq-encaps-header
dl-iq-user-datagram
dl-user-datagram
type dscp_type
  • downlink
  • uplink
ul-encap-copy-inner
ul-encap-copy-outer
ul-iq-encaps-header
Usage Guidelines
profile sgw-qos-profile dscp-map operator-defined-qci non-gbr dscp-info
Command Mode
Syntax
dl-encap-copy-inner
dl-encap-copy-outer
dl-iq-copy-outer
dl-iq-encap-type
dl-iq-encaps-header
dl-iq-user-datagram
dl-user-datagram
type dscp_type
  • downlink
  • uplink
ul-encap-copy-inner
ul-encap-copy-outer
ul-iq-encaps-header
Usage Guidelines
profile sgw-qos-profile dscp-map qci
Configures the standard QCI value.
Command Mode
Syntax
dscp-map qci standard_qos_class_id options
Specify the standard QoS class identifier.
Must be an integer from the following: 1-9, 65, 66, 69, 70, 80, 82, 83.
Usage Guidelines
Use this command to configure the standard QCI value.
profile sgw-qos-profile dscp-map qci arp-priority-level
Command Mode
Syntax
Usage Guidelines
profile sgw-qos-profile dscp-map qci arp-priority-level dscp-info
Command Mode
Syntax
dl-encap-copy-inner
dl-encap-copy-outer
dl-iq-copy-outer
dl-iq-encap-type
dl-iq-encaps-header
dl-iq-user-datagram
dl-user-datagram
type dscp_type
  • downlink
  • uplink
ul-encap-copy-inner
ul-encap-copy-outer
ul-iq-encaps-header
Usage Guidelines
profile sgw-qos-profile dscp-map qci default
Configures the default QCI parameter.
Command Mode
Syntax
default options
Usage Guidelines
Use this command to configure the default QCI parameter.
profile sgw-qos-profile dscp-map qci default dscp-info
Command Mode
Syntax
dl-encap-copy-inner
dl-encap-copy-outer
dl-iq-copy-outer
dl-iq-encap-type
dl-iq-encaps-header
dl-iq-user-datagram
dl-user-datagram
type dscp_type
  • downlink
  • uplink
ul-encap-copy-inner
ul-encap-copy-outer
ul-iq-encaps-header
Usage Guidelines
profile sgw-qos-profile dscp-map qci gbr dscp-info
Command Mode
Syntax
dl-encap-copy-inner
dl-encap-copy-outer
dl-iq-copy-outer
dl-iq-encap-type
dl-iq-encaps-header
dl-iq-user-datagram
dl-user-datagram
type dscp_type
  • downlink
  • uplink
ul-encap-copy-inner
ul-encap-copy-outer
ul-iq-encaps-header
Usage Guidelines
profile sgw-qos-profile dscp-map qci non-gbr dscp-info
Command Mode
Syntax
dl-encap-copy-inner
dl-encap-copy-outer
dl-iq-copy-outer
dl-iq-encap-type
dl-iq-encaps-header
dl-iq-user-datagram
dl-user-datagram
type dscp_type
  • downlink
  • uplink
ul-encap-copy-inner
ul-encap-copy-outer
ul-iq-encaps-header
Usage Guidelines
profile smf
Configures SMF profile.
Command Mode
Syntax
smf profile_name [ [ dnn-selection-mode dnn_selection_mode ] [ load-profile load_profile_name ] [ locality locality ] [ mode mode_of_operation ] [ nf-services nf_services ] [ overload-profile overload_profile_name ] [ ue-authorization ue_authorization ] ]
NOTE: This command/keyword is deprecated from SMF Profile and has been added under DNN Profile. Specify the selection mode for subscription.
  • network-provided
  • ue-provided
  • verified
Specify the name of the load profile.
Must be a string.
locality locality
Specify the locality for geo support.
Must be a string.
Specify the mode of operation.
  • offline : Offline mode. New sessions will be rejected.
Specify the NF services.
Must be a string.
Specify the name of the overload profile. Note that the load-profile configuration is mandatory to configure the overload-profile configuration.
Must be a string.
smf profile_name
Specify name of the SMF profile.
Must be a string.
The SMF supports PDU sessions with IPv4v6 type in addition to IPv4 and IPv6 PDU session types for UEs. When a UE requests establishment of PDU session with a specific session type, the SMF checks the UE request against the UE subscription information maintained as default and allowed listPDU session types in the UDM. The SMF performs UE authorization and allocates IP address when the requested PDN type is matching with the values in the UDM. The SMF communicates about the allocated IP address to all other network functions.
  • none
Usage Guidelines
Use this command to configure the SMF network function profile parameters.
profile smf instances
Configures the Geographic Redundancy (GR) instance ID.
Command Mode
Exec > Global Configuration (config) > SMF Profile Configuration (config-smf-profile_name )
Syntax
instances gr_instance_id [ [ allowed-nssai allowed_nssai ] [ fqdn fqdn ] [ inter-plmn-fqdn inter_plmn_fqdn [ node-id node_id] [ supported-features supported_features ] ]
allowed-nssai nssai
Specify the Network Slice Selection Assistance Information (NSSAI).
Must be a string.
fqdn fqdn
Specify the SMF+PGW-C FQDN.
Must be a string.
Specify the inter-PLMN-FQDN, which is used in home and visiting SMF communication via SEPP.
Must be a string.
node-id node_id
Specify the SMF's node ID. For example, 1A2B3c.
Must be a string in the hex-string6 pattern. For information on the hex-string6 pattern, see the Input Pattern Types chapter.
Specify the supported features.
  • vsmf - Configures the SMF to indicate support for vSMF by setting vsmfSupportInd = true in NFRegister and NFUpdate messages.
  • suppress-vsmf - Configures the SMF to indicate it should not be selected as a vSMF by setting vsmfSupportInd = false in NFRegister and NFUpdate messages.
gr_instance_id
Specify the GR instance ID.
Usage Guidelines
Use this command to configure the GR instance ID.
profile smf instances deactivate-features
Disables the UPCP and UPIP features on SMF despite receiving Up security policy from the UDM.
Command Mode
Syntax
profile smf profile_name [ no ] instances gr_instance_iddeactivate-features { upcp | upip }
Specifies the GR instance ID of the SMF.
[ no ]
It is an optional command. It enables the deactivated UPCP or UPIP features on SMF to honor the UDM instructions again.
deactivate-features
Deactivates the UP security mechanism on SMF. It has two options:
  • upcp : Deactivates User-Plane Confidentiality Protection.
  • upip : Deactivates User-Plane Integrity Protection.
Note
The commands deactivate-features and no instances are applicable only on the new sessions. The current sessions are not impacted with these CLIs.
Usage Guidelines
Use this command to disable the UPCP or UPIP features on SMF to ignore the UDM instructions.
profile smf plmn-id
Configures the definition for public land mobile network identifier (PLMN ID) and the preferred radio access technology (RAT). This is one of PLMNs which is considered by the mobile as equivalent to the visited PLMN for cell reselection and network selection. When configured, the equivalent PLMN list will be sent to the UE in NAS ATTACH ACCEPT / TAU ACCEPT messages.
Command Mode
Syntax
plmn-id { [ mcc mobile_country_code ] [ mnc mobile_network_code ] }
Specify the Mobile Country Code (MCC) portion of the PLMN ID.
Must be a string in the three-digit pattern. For information on the three-digit pattern, see the Input Pattern Types chapter.
Specify the Mobile Network Code (MNC) portion of the PLMN ID.
Must be a string in the two-or-three-digit pattern. For information on the two-or-three-digit pattern, see the Input Pattern Types chapter.
Usage Guidelines
Use the command to identify a PLMN and assign it a priority to define the preferred PLMN to be used. This command can be entered multiple times to set priorities of usage.
profile smf plmn-list
Configures the SMF proflie PLMN list parameters.
Command Mode
Syntax
plmn-list mcc mobile_country_code mnc mobile_network_code
Specify the 3-digit Mobile Country Code.
Specify the 2- or 3-digit Mobile Country Network.
Usage Guidelines
Use this command to configure the SMF proflie PLMN list parameters. If configured, both PLMN ID and PLMN list are used.
You can configure a maximum of 32 elements with this command.
profile smf service
Configures the session management network function services.
Command Mode
Syntax
service name service_name [ access-profile profile_name | capacity capacity | compliance-profile compliance_profile_name | icmpv6-profile profile_name | nf-service nf_service_name | priority priority | schema schema_name | service-id service_id | subscriber-policy policy_name | type service_type | version version ]
Specify name of the access profile.
Must be a string.
capacity capacity
Specify the static weight relative to other NFs of the same type.
Default Value: 10.
Specify name of the compliance profile.
Must be a string.
Specify name of the ICMPv6 profile.
Must be a string.
name nf_service_name
Specify name of the NF service.
Must be a string.
priority priority
Specify the priority relative to other NFs of the same type.
Default Value: 1.
schema schema_name
Specify name of the schema.
Must be a string.
Specify the service ID.
Must be a string.
Default Value: 1.
Specify name of the subscriber policy.
Must be a string.
type service_type
Specify the service type.
  • pdu-session
  • sm-event-exposure
version version
Specify the version.
Must be a string.
Usage Guidelines
Use this command to configure the N1, N2, and N11 interfaces in compliance with the 3GPP. The service names are specified in 3GPPTS 29.510 V15.2.0, Section 6.1.6.3.11. The CLI prompt changes to the Service Configuration mode (config-service-<service_name>).
profile smf service http-endpoint
Configures the SMF HTTP REST endpoint parameters.
Command Mode
Exec > Global Configuration (config) > SMF Profile Configuration (config-smf-profile_name ) > Service Configuration (config-service-service_name )
Syntax
http-endpoint base-url base_url
base-url base_url
Specify the SMF base URL that is exposed and accessible externally.
Must be a string.
Usage Guidelines
Use this command to configure the SMF HTTP REST endpoint parameters.
profile tai-group
Configures TAI group profile parameters.
Command Mode
Syntax
profile tai-group tai_group_name [ priority tai_group_priority ]
Specify the priority of this TAI group.
Specify name of the TAI group.
Must be a string.
Usage Guidelines
Use this command to configure the TAI group profile parameters.
profile tai-group tais
Configures the list of MCC and MNC.
Command Mode
Exec > Global Configuration (config) > TAI Group Profile Configuration (config-tai-group-profile_name )
Syntax
tais { mcc mobile_country_code | mnc mobile_network_code }
Specify the Mobile Country Code (MCC).
Specify the Mobile Network Code (MNC).
Usage Guidelines
Use this command to configure the list of MCC and MNC.
You can configure a maximum of 16 elements with this command.
profile tai-group tais tac
Configures the TAC Group parameters.
Command Mode
Syntax
tac tac_values
tac tac_values
Specify the list of TAC values.
Must be a string in the hex-stringtac pattern. For information on the hex-stringtac pattern, see the Input Pattern Types chapter.
You can configure a maximum of 64 elements with this keyword.
Usage Guidelines
Use this command to configure the TAC Group parameters.
profile tai-group tais tac range
Configures TAC ranges.
Command Mode
Syntax
range start tac_range_start end tac_range_end
end tac_range_end
Specify the TAC range end value.
Specify the TAC range start value.
Usage Guidelines
Use this command to configure a TAC range.
You can configure a maximum of 64 elements with this command.
profile upf-group
Configures the UPF group profile.
Command Mode
Syntax
profile upf-group upf_group_name [ dcnr { false | true } | location-area-group-list location_area_group_list | pdn-session-type pdn_session_type | slice-group-list slice_group_list | supported-features supported_features ]
Specify to enable or disable support for dual connectivity with new radio.
  • false
  • true
Specify the list of Location Area Group supported by UPF node.
Must be a string.
Specify the list of PDN session type supported by UPF node.
  • ipv4
  • ipv4v6
  • ipv6
Specify the list of slice group supported by UPF node.
Must be a string.
Specify the list of features supported by the UPF node.
Specify name of the UPF group.
Must be a string.
Usage Guidelines
Use this command to configure the UPF group profile.
profile upf-group failure-profile
Configures the UPF Group failure profile.
Command Mode
Exec > Global Configuration (config) > UPF Group Profile Configuration (config-upf-group-profile_name )
Syntax
failure-profile failure_profile_name
Specify name of the UPF failure profile.
Must be a string.
Usage Guidelines
Use this command to configure the UPF Group failure profile.
profile upf-group heartbeat
Enables PFCP path management.
Command Mode
Syntax
heartbeat [ interval heartbeat_interval | retransmission-timeout retransmission_timeout | max-retransmissions max_retransmissions ]
Specify the heartbeat interval in seconds. To disable, set to 0.
Must be an integer from the following: 0, 60-360.
Specify the maximum number retries for PFCP heartbeat request.
Must be an integer in the range of 0-10.
Specify the heartbeat retransmission timeout period in seconds.
Usage Guidelines
Use this command to enable PFCP path management.
profile wps
Configures the Wireless Priority Service (WPS) profile parameters.
Command Mode
Syntax
profile wps wps_service_name [ arp arp_level_range [ qci ] message-priority-profile  profile_name    ] ]
      profile message-prioritymsg_priority_profile_name
      interface [ any | pfcp | sbi [ { create | update | delete } ] ]
         priority value range
arp arp_level_range
Specify the range of ARP levels (separated by comma (,) or hyphen (-)).
Specify the ARP value in integer from 1 to 15.
-Or-
Must be a string.
qci message-priority-profile profile_name : Wireless Priority session is decided based on the ARP and optionally on the QCI.
message-priority-profile profile_name : This parameter is used only if the message priority profile is not associated. For example, message-priority-profile [ pfcp gtpc ].
Important
If you are upgrading SMF from Release 2023.03.0 to a later release, make sure you manually reconfigure the ARP parameter in the WPS profile after the upgrade is complete.
Specify name of the WPS service.
Must be a string.
  • interface [ any | pfcp | sbi ] : Specify priority value per interface and in case of SBI interface, configure based on a procedure. If procedure is not configured, same value is applied for all procedures. Interface type is optional and if not configured, same value is applied across all interfaces.
  • priority value : Specifies the range of priority levels from 0 to 31 for sbi or 0 to 15 for pfcp, gtp, or any, where 0 indicates the highest priority, while 31 or 15 indicates the lowest priority.
    Note
    Priority is not populated in outbound messages, which are self-triggered. For example, outbound messages triggered by timer expiry.
Usage Guidelines
Use this command to configure the WPS profile parameters. The CLI prompt changes to the WPS Profile Configuration mode (config-wps-<profile_name>).
profile wps dscp
Configures the DSCP marking values.
Command Mode
Exec > Global Configuration (config) > WPS Profile Configuration (config-wps-profile_name )
Syntax
dscp { [ n3 up_dscp_marking ] [ n4 cp_dscp_marking ] [ s2b dscp_marking ] [ s5 dscp_marking ] [ s5e cp_dscp_marking ] [ s8 dscp_marking ] [ s11 cp_dscp_marking ] [ sxa cp_dscp_marking ] ]
message-priority message_priority
Specify the message priority for GTP-C and UP.
  • gtpc
  • pfcp
You can configure a maximum of two elements with this keyword.
n3 up_dscp_marking
Specify the N3 UP DSCP marking value.
n4 cp_dscp_marking
Specify the N4 CP DSCP marking value.
s11 cp_dscp_marking
Specify the S11 CP DSCP marking value.
s2b dscp_marking
Specify the S2B DSCP marking value.
s5 dscp_marking
Specify the S5 DSCP marking value.
s5e cp_dscp_marking
Specify the S5E CP DSCP marking value.
s8 dscp_marking
Specify the S8 DSCP marking value.
sxa cp_dscp_marking
Specify the SXA CP DSCP marking value.
Usage Guidelines
Use this command to configure the DSCP marking values.
service name type
Configures UDM services.
Command Mode
Exec > UDM message handling profile configuration.
Syntax
service name type { nudm-ee | nudm-pp | nudm-sdm | nudm-ueau | nudm-uecm } service_type
Configure the UDM services based on the use case scenario.
SMF allows configuration of these different UDM service types:
  • nudm-ee —Specify this service for NEFs to subscribe to or unsubscribe from UDM event notifications.
  • nudm-pp —Specify this service to provision information, which can be used for the UE in 5GS.
  • nudm-sdm — Specify this service to retrieve UE subscription data relevant to their operation from the UDM. The nudm-sdm service type enables the UDM local configuration.
  • nudm-ueau —Specify this service to inform the UDM of authentication results, to query authentication results, and to purge authentication results.
    Note
    The Nudm_UEAuthentication service is used by SMF to obtain UE authentication vectors from the UDM.
  • nudm-uecm —Specify this service to allow the SMF to register and deregister itself as serving the UE, and to update the UE context information in the UDM.
Usage Guidelines
Use this command to configure different types of UDM services.
radius
Displays RADIUS Client information.
Command Mode
Exec
Syntax
show radius
Usage Guidelines
Use this command to view RADIUS Client information.
radius acct-server
Displays RADIUS Accounting Server information.
Command Mode
Exec
Syntax
show radius acct-server
Usage Guidelines
Use this command to view RADIUS Accounting Server information.
radius auth-server
Displays RADIUS Authentication Server information.
Command Mode
Exec
Syntax
show radius auth-server
Usage Guidelines
Use this command to view RADIUS Authentication Server information.
radius-dyn-auth
Displays RADIUS Dynamic Author data.
Command Mode
Exec
Syntax
show radius-dyn-auth
Usage Guidelines
Use this command to view the RADIUS Dynamic Author data.
radius-dyn-auth clients
Command Mode
Exec
Syntax
Usage Guidelines
Use this command to view RADIUS RADIUS Authentication Server information.
rcm switchover
Configures Redundancy and Configuration Manager (RCM) switchover operation.
Privilege Level
Security Administrator, Administrator
Command Mode
Exec
Syntax
rcm switchover source ip_address destination ip_address
source ip_address
Specify the source IP address.
Must be an IP address.
Specify the destination IP address.
Usage Guidelines
Use this command to configure RCM switchover operation.
reconcile ipam
Reconciles IPAM data with CDL records.
Command Mode
Syntax
reconcile ipam
Usage Guidelines
Use this command to reconcile IPAM data with CDL records.
resource pod
Configures Pod resource parameter.
Command Mode
Syntax
pod podtype pod_type
podtype pod_type
Specify the pod type.
Usage Guidelines
Use this command to configure Pod resource parameter.
resource pod cpu
Configures CPU resource request parameter.
Command Mode
Exec > Global Configuration (config) > Pod Resource Configuration (config-resource-pod_type )
Syntax
cpu request cpu_resource_request
Specify the CPU resource request in millicores.
Must be an integer in the range of 100-1000000.
Usage Guidelines
Use this command to configure CPU resource request parameter.
resource pod labels
Configures K8 Node Affinity label configuration.
Command Mode
Syntax
labels key label_key value label_value
key label_key
Specify the key for the label.
Must be a string.
value label_value
Specify the value for the label.
Must be a string.
Usage Guidelines
Use this command to configure K8 Node affinity label configuration.
resource pod memory
Configures memory resource request parameter.
Command Mode
Syntax
memory request memory_resource_request
Specify the memory resource request in megabytes.
Must be an integer in the range of 100-200000.
Usage Guidelines
Use this command to configure memory resource request parameter.
resources info
Displays resource information.
Command Mode
Exec
Syntax
show resources [ info ]
Usage Guidelines
Use this command to view information about the configured resources.
router bgplist
Configures BGP speaker configuration.
Command Mode
Syntax
router bgp bgp [ learnDefaultRoute { false | true } | loopbackBFDPort bfd_local_port_number | loopbackPort bgp_local_port_number ]
bgp bgp
Specify the BGP.
Must be an integer.
Specify whether to enable or disable learning default route and adding it in kernel space.
  • false
  • true
Specify the BFD local port number.
Must be an integer.
Default Value: 3784.
Specify the BGP local port number.
Must be an integer.
Default Value: 179.
Usage Guidelines
Use this command to configure the BGP speaker configuration.
router bgplist bfd
Configures BFD configuration.
Command Mode
Exec > Global Configuration (config) > Router Configuration (config-router-router )
Syntax
bfd { interval bfd_interval | min_rx bfd_min_rx | multiplier bfd_interval_multiplier }
Specify, in microseconds, the BFD interval.
Must be an integer.
Default Value: 250000.
min_rx bfd_min_rx
Specify, in microseconds, the BFD minimum RX.
Must be an integer.
Specify the BFD interval multiplier.
Must be an integer.
Default Value: 3.
Usage Guidelines
Use this command to configure the BFD configuration.
router bgplist interfaceList
Configures bonding interface configuration.
Command Mode
Syntax
interface bgp_local_interface
Specify the BGP local interface.
Must be a string.
Usage Guidelines
Use this command to configure the bonding interface configuration.
router bgplist interfaceList bondingInterfaces
Command Mode
Exec > Global Configuration (config) > Router Configuration (config-router-router ) > Router Interface Configuration (config-router-interface )
Syntax
bondingInterface linked_bonding_interface
Specify the linked bonding interface.
Must be a string.
Usage Guidelines
router bgplist interfaceList neighbors
Configures neighbor parameters.
Command Mode
Syntax
neighbor neighbor_ip_address [ fail-over failover_type | remote-as remote_as_number ]
Specify the failover type.
  • bfd
Specify the IP address of the neighbor.
Must be a string.
Specify the Autonomous System (AS) number of the BGP neighbor.
Must be an integer.
Default Value: 65000.
Usage Guidelines
Use this command to configure the neighbor parameters.
router bgplist policies
Configures policy parameters.
Command Mode
Syntax
policy-name policy_name [ as-path-set as_path_set | gateWay gateway_address | interface interface | ip-prefix ip_prefix | isStaticRoute { false | true } | mask-range mask_range | modifySourceIp { false | true } ]
Specify the Autonomous System (AS) path set.
Must be a string.
Specify the gateway address.
Must be a string.
interface interface
Specify the interface to set as source ip.
Must be a string.
ip-prefix ip_prefix
Specify the IP prefix.
Must be a string.
Specify whether to enable or disable adding static route into kernel space.
  • false
  • true
Specify the mask range.
Must be a string.
Specify whether to enable or disable modifying source IP of incoming route.
  • false
  • true
Specify name of the policy.
Must be a string.
source-prefix source_ip_prefix
Specify the source IP prefix.
Must be a string.
Usage Guidelines
Use this command to configure the policy parameters.
rpc all
Displays RPC configuration information.
Command Mode
Exec
Syntax
show rpc [ all ]
Usage Guidelines
Use this command to view RPC configuration information for all RPCs.
running-status info
Displays the system's current status information.
Command Mode
Exec
Syntax
show running-status [ info ]
Usage Guidelines
Use this command to view the system's current status information.
screen-length
Configures the number of rows of text that the terminal screen displays.
Privilege Level
Command Mode
Exec
Syntax
screen-length number_of_rows
number_of_rows
Specify the number of rows that the terminal screen displays.
Must be an integer.
Usage Guidelines
Use this command to set the number of rows that the terminal screen displays.
screen-width
Configures the number of columns that the terminal screen displays.
Privilege Level
Command Mode
Exec
Syntax
screen-width number_of_columns
number_of_columns
Specify the number of columns that the terminal screen displays.
Must be an integer.
Usage Guidelines
Use this command to set the number of columns that the terminal screen displays.
send
Sends messages to the terminal of a specific user or all users.
Privilege Level
Command Mode
Exec
Syntax
send user message
user
Specify the user to whom the message must be sent.
Must be a string. Select from the possible completion options.
message
Specify the message that must be sent.
Must be a string.
Usage Guidelines
Use this command to send messages to the terminal of a specific user or to all users.
sessions affinity
Displays the affinity count per instance.
Command Mode
Exec
Syntax
show sessions affinity
Usage Guidelines
Use this command to view the affinity count per instance.
sessions commit-pending
Displays information for sessions for which the commits are in pending state.
Command Mode
Exec
Syntax
show sessions commit-pending
Usage Guidelines
Use this command to view information for sessions that are pending commits.
quit
Exits the management session.
Privilege Level
Command Mode
Exec
Syntax
quit
Usage Guidelines
Use this command to exit the management session.
show
Displays the system information.
Privilege Level
Command Mode
Exec
Syntax
show system_component
system_component
Specify the component to view the information.
Usage Guidelines
Use this command to view the system information.
show bfd-neighbor
Displays Bidirectional Forwarding Detection (BFD) status of neighbors.
Command Mode
Exec
Syntax
show bfd-neigbor [ ip ip_address ]
ip ip_address
Must be a string.
Usage Guidelines
Use this command to view the BFD status of neighbors. If no IP address is specified, the command displays the BFD status for all neighbors.
show bgp-advertised-routes
Displays the BGP routes that are advertised to neighbors.
Command Mode
Exec
Syntax
show bgp-advertised-routes [ ipv4 | ipv6 | vrf vrf_name ]
ipv4
Option to display details for IPv4 address family.
ipv6
Option to display details for IPv6 address family.
vrf vrf_name
Specify the Virtual Routing and Forwarding (VRF) of the advertised routes. vrf_name must be a valid VRF name string.
Usage Guidelines
Use this command to view the BGP routes being advertised to neighbors. You can filter the output by address family (IPv4/IPv6) or by VRF. If no option is specified, the command displays all advertised routes.
show bgp-global
Displays BGP global configuration.
Command Mode
Exec
Syntax
show bgp-global
Usage Guidelines
Use this command to view BGP global configuration.
show bgp-kernel-route
Displays BGP kernel-configured routes.
Command Mode
Exec
Syntax
show bgp-kernel-route [ application { false | true } ]
Specify whether to display application added routes.
Must be one of the following:
  • false
  • true
Usage Guidelines
Use this command to view BGP kernel-configured routes.
show bgp-learned-routes
Displays the BGP routes that are learned from neighbors.
Command Mode
Exec
Syntax
show bgp-learned-routes [ ipv4 | ipv6 | vrf vrf_name ]
ipv4
Option to display details for IPv4 address family. Must be followed by the vrf keyword.
ipv6
Option to display details for IPv6 address family. Must be followed by the vrf keyword.
vrf vrf_name
Usage Guidelines
Use this command to view the BGP routes learned from neighbors. You can filter the output by address family (IPv4/IPv6) or by VRF. If no option is specified, the command displays all learned routes.
show bgp-neighbors
Displays BGP neighbor's status.
Command Mode
Exec
Syntax
show bgp-neighbors [ ip ip_address ]
ip ip_address
Must be a string.
Usage Guidelines
Use this command to view BGP neighbor's status.
show bgp-route-summary
Displays BGP route summary.
Command Mode
Exec
Syntax
Usage Guidelines
Use this command to view BGP route summary.
show bgp-routes
Displays BGP routes information.
Command Mode
Exec
Syntax
show bgp-routes
Usage Guidelines
Use this command to view BGP routes information.
show diameter routes all
Displays the route details.
Command Mode
Exec
Syntax
Usage Guidelines
Use this command to view the diameter route details.
show edr
Displays EDR Transaction Procedure Event fields.
Command Mode
Exec
Syntax
show edr { [ event transaction_procedure_event ] [ transaction-procedure transaction_procedure ] }
Specify the transaction procedure event name/id/all.
Must be a string.
Specify the transaction procedure name/id/all.
Must be a string.
Usage Guidelines
Use this command to view EDR Transaction Procedure Event fields.
show geo-maintenance-mode
Displays maintenance mode enable/disable.
Command Mode
Exec
Syntax
Usage Guidelines
Use this command to view maintenance mode status.
show georeplication-status
Displays result as Pass / Fail after comparing ETCD and Cache checksum with peer rack.
Command Mode
Exec
Syntax
Usage Guidelines
Use this command to view replication status between peer racks for ETCD and cache.
show georeplication
Displays ETCD/Cache checksum.
Command Mode
Exec
Syntax
show georeplication checksum instance-id instance_id
checksum
Specify checksum.
Specify the instance ID for which checksum will be displayed.
Must be a string.
Usage Guidelines
Use this command to view ETCD/Cache checksum.
show idmgr-debug
Displays internal information of IDMGR.
Command Mode
Exec
Syntax
show idmgr-debug all
Usage Guidelines
Use this command to view the internal details of IDMGR.
show ipam dp
Displays IPAM data-plane utilization information for all data planes.
Command Mode
Exec
Syntax
show ipam dp
Usage Guidelines
Use this command to view IPAM data-plane utilization information for all data planes.
show ipam dp name
Displays IPAM data-plane allocations details.
Command Mode
Exec
Syntax
show ipam dp  dp_name
dp dp_name
Specify the IPAM data-plane name.
Usage Guidelines
Use this command to view IPAM data-plane allocations details.
show ipam dp name ipv4-addr
Displays IPv4 address ranges assigned to a data plane.
Command Mode
Exec
Syntax
show ipam dp   dp_name ipv4-addr
Usage Guidelines
Use this command to view the IPv4 address ranges assigned to a data plane.
show ipam dp name ipv6-addr
Displays IPv6 address ranges assigned to a data plane.
Command Mode
Exec
Syntax
show ipam dp   dp_name ipv6-addr
Usage Guidelines
Use this command to view the IPv6 address ranges assigned to a data plane.
show ipam dp name ipv6-prefix
Displays IPv6 prefix ranges assigned to a data plane.
Command Mode
Exec
Syntax
show ipam dp   dp_name ipv6-prefix
Usage Guidelines
Use this command to view the IPv6 prefix ranges assigned to a data plane.
show ipam dp tag
Displays IPAM data-plane utilization information for all data-plane and tag combination. Tag represents DNN, NSSAI, or serving area.
Command Mode
Exec
Syntax
show ipam dp tag   tag_name
dp tag tag_name
Specify the data-plnae tag name.
Usage Guidelines
Use this command to view IPAM data-plane utilization information for all data plane and tag combination.
show ipam dp tag tag-name
Displays IPAM data-plane utilization information for specific DP and tag combination. Tag represents DNN, NSSAI, or serving area.
Command Mode
Exec
Syntax
show ipam dp tag name   tag_name
Specify the specific data-plnae tag name.
Usage Guidelines
Use this command to view IPAM data-plane utilization information for specific dp and tag combination.
show ipam dp tag ipv4-addr
Displays IPv4 address information for specific DP and Tag combination. Tag represents DNN, NSSAI, or serving area.
Command Mode
Exec
Syntax
show ipam dp tag   tag_name ipv4-addr
Usage Guidelines
Use this command to view IPv4 address information for specific DP and Tag combination.
show ipam dp tag ipv6-addr
Displays IPv6 address information for specific DP and Tag combination. Tag represents DNN, NSSAI, or serving area.
Command Mode
Exec
Syntax
show ipam dp tag   tag_name ipv6-addr
Usage Guidelines
Use this command to view IPv6 address information for specific DP and Tag combination.
show ipam dp tag ipv6-prefix
Displays IPv6 prefix ranges for specific DP and Tag combination. Tag represents DNN, NSSAI, or serving area.
Command Mode
Exec
Syntax
show ipam dp tag   tag_name ipv6-prefix
Usage Guidelines
Use this command to view IPv6 prefix ranges for specific DP and Tag combination.
show ipam pool
Displays IPAM pool utilization information for all pools.
Command Mode
Exec
Syntax
show ipam pool
Usage Guidelines
Use this command to view IPAM pool utilization information for all pools.
show ipam pool name
Displays IPAM pool allocation information for specific pool.
Command Mode
Exec
Syntax
show ipam pool  pool_name
pool pool_name
Specify the IPAM pool name.
Usage Guidelines
Use this command to view IPAM pool allocation information for specific pool.
show ipam pool name ipv4-addr
Displays IPAM pool IPv4 address information for specific pool.
Command Mode
Exec
Syntax
show ipam pool   pool_name ipv4-addr
Usage Guidelines
Use this command to view IPAM pool IPv4 address information.
show ipam pool name ipv6-addr
Displays IPAM pool IPv6 address information for specific pool.
Command Mode
Exec
Syntax
show ipam pool   pool_name ipv6-addr
Usage Guidelines
Use this command to view IPAM pool IPv6 address information.
show ipam pool name ipv6-prefix
Displays IPAM pool IPv6 prefix ranges details of specific pool.
Command Mode
Exec
Syntax
show ipam pool   pool_name ipv6-prefix
Usage Guidelines
Use this command to view IPAM pool IPv6 prefix ranges information.
show ipam-staticdb
Displays static IP information of a pool.
Command Mode
Exec
Syntax
show ipam-staticdb pool-name   pool_name [ ipv4-addr | ipv6-addr | ipv6-prefix ] start-index [ index ]
ipv4-addr
Option to display static IP information of Ipv4 address.
ipv6-addr
Option to display static IP information of Ipv6 address.
ipv6-prefix
Option to display static IP information of Ipv6 prefix.
start-index
Option to display subscribe-key and IP. Max 1000 subkeys and IPs are displayed starting from index.
Usage Guidelines
Use this command to view static IP information for a pool.
show peers
Displays additional diameter information.
Command Mode
Exec
Syntax
show peers
Usage Guidelines
Use this command to view additional diameter information.
show role
Displays current role for the specified instance.
Command Mode
Exec
Syntax
show role instance-id instance_id
Specify the instance ID for which role must be displayed.
Usage Guidelines
Use this command to view current role for the specified instance.
show subscriber
Displays subscriber information.
Command Mode
Exec
Syntax
show subscriber { [ all ]     [ gr-instance gr_instance ] [ imei imei_id ] [ nf-service nf_service ] [ supi supi_id ] [ config_specific_options ] }
access access_technology
Specify the access technology.
Must be a string of 11-25 characters.
all
Specify all SUPIs or IMEIs.
amf amf_address
Specify the AMF address.
Must be a string of 7-39 characters.
apn apn_name
Specify name of the APN.
Must be a string of 1-255 characters.
auth-status radius_auth_status
Specify the RADIUS authentication status - authenticated or unauthenticated.
Must be a string of 13, or 15 characters.
chf chf_address
Specify the CHF address.
connectivity connectivity_type
Specify the connectivity type.
Must be a string of 2 characters.
count count
Specify the count.
  • count
debug-info debug_info
Specify print the debug info.
  • debug-info
dnn dnn_value
Specify the DNN value.
emergency { false | true }
Specify emergency session indication.
  • false
  • true
gpsi gpsi
Specify the Generic Public Subscription Identifier (GPSI).
Specify the network function service under which to search.
gtp-peer gtp_peer_address
Specify address of the GTP peer.
imei imei_id
Specify the International Mobile Equipment Identity.
Must be a string of 15-16 characters.
imsi imsi
Specify the International Mobile Subscriber Identifier (IMSI).
Must be a string.
ipv4-addr ipv4_address
Specify the IPv4 address in the format pool_name /ipv4_address .
ipv4-pool ipv4_pool_name
Specify name of the IPv4 pool.
ipv4-range ipv4_address_range
Specify the IPv4 address range in the format pool_name /start_ip_address .
ipv6-pfx ipv6_pfx
Specify the IPv6 prefix in the format pool_name /ipv6_prefix .
ipv6-pool ipv6_pool_name
Specify name of the IPv6 pool.
ipv6-range ipv6_prefix_range
Specify the IPv6 prefix range in the format pool_name /start_prefix .
msid msid
Specify the Mobile Subscriber Identification Number (MSID).
msisdn msisdn
Specify the Mobile Station International Subscriber Directory Number (MSISDN).
namespace namespace
NOTE: This keyword is deprecated, use nf-service instead. Specify the product namespace under which to search.
Default Value: cisco-mobile-infra:none.
pcf pcf_address
Specify the PCF address.
peerGtpuEpKey gtpu_peer_address
Specify address of the GTPU peer in the upf_addr:gptu_peer_addr format.
pei permanent_equipment_id
Specify the Permanent Equipment Identifier.
policy policy_type
Specify the subscriber policy type information.
  • local
  • pcf
rat rat_type
Specify the RAT type.
Must be a string of 2, 4, or 7 characters.
roaming-status ue_roaming_status
Specify the UE roaming status.
Must be a string of 5, 6, 10, or 11 characters.
smf smf_address
Specify address of the SMF.
supi supi_id
Specify the subscriber's SUPI ID.
Must be a string.
udm-sdm udm_sdm_address
Specify the UDM-SDM address.
udm-sdm udm_uecm_address
Specify the UDM-UECM address.
ue-type ue_type
Specify device capability - 4G-only / NR-capable.
Must be a string of 7, or 10 characters.
upf upf_address
Specify the UPF address.
Usage Guidelines
Use this command to view subscriber information by SUPI, IMEI, or all.
show subscriber count-opt
Displays subscriber session count information.
Command Mode
Exec
Syntax
show subscriber count { all | access access_technology | amf amf_address | apn apn_name | auth-status radius_auth_status | chf chf_address | connectivity connectivity_type | dnn dnn_value | emergency { false | true } | gpsi gpsi | gtp-peer gtp_peer_address | ipv4-addr ipv4_address | ipv4-pool ipv4_pool_name | ipv4-range ipv4_address_range | ipv6-pfx ipv6_prefix | ipv6-pool ipv6_pool_name | ipv6-range ipv6_prefix_range | msid msid | msisdn msisdn | pcf pcf_address | peerGtpuEpKey gtpu_peer_address | pei permanent_equipment_id | policy policy_type | psid pdu_session_id | rat rat_type | roaming-status ue_roaming_status | supi supi | udm-sdm udm_sdm_address | udm-uecm udm_uecm_address | upf upf_address }
all
Specify all SUPIs.
amf amf_address
apn apn_name
chf chf_address
dnn dnn_value
  • false
  • true
gpsi gpsi
Must be a string.
ipv6-pfx ipv6_pfx
msid msid
Specify the Mobile Station Identifier (MSID).
Must be a string.
msisdn msisdn
Must be a string.
pcf pcf_address
policy policy_type
  • local
  • pcf
psid pdu_session_id
Specify the PDU Session Identifier.
rat rat_type
smf smf_address
supi supi
Specify the Subscription Permanent Identifier (SUPI), the value must include the IMSI prefix.
Must be a string.
ue-type ue_type
upf upf_address
Usage Guidelines
Use this command to view subscriber session count information.
show subscriber debug-opt
Displays debug option.
Command Mode
Exec
Syntax
debug-opt { supi supi | msid msid | pei pei_imei | gpsi gpsi | msisdn msisdn | imsi imsi }
gpsi gpsi
Specify the GPSI.
Must be a string.
imsi imsi
Must be a string.
msid msid
Must be a string.
msisdn msisdn
Must be a string.
pei pei_imei
Specify the Permanent Equipment Identifier (PEI)/International Mobile Equipment Identifier (IMEI).
Must be a string.
psid psid
Specify the PDU Session ID.
Must be an integer in the range of 1-255.
supi supi
Must be a string.
Usage Guidelines
Use this command to view debug option.
show subscriber gpsi-opt policy-opt
Displays policy option.
Command Mode
Exec
Syntax
show subscriber supi supi_id policy policy_option
Specify the policy option.
  • flow
  • rules
Usage Guidelines
Use this command to view policy option.
show subscriber imsi-opt
Displays subscriber data based on IMSI.
Command Mode
Exec
Syntax
show subscriber imsi-options imsi_option
Specify the IMSI option.
  • full
Usage Guidelines
Use this command to view subscriber data based on IMSI.
show subscriber msid-opt policy-opt
Command Mode
Exec
Syntax
  • flow
  • rules
Usage Guidelines
show subscriber msisdn-opt policy-opt
Command Mode
Exec
Syntax
  • flow
  • rules
Usage Guidelines
show subscriber pei-opt policy-opt
Command Mode
Exec
Syntax
  • flow
  • rules
Usage Guidelines
show subscriber supi-opt
Displays subscriber data.
Command Mode
Exec
Syntax
show subscriber supi [ detail_option | psid pdu_session_id ]
psid pdu_session_id
detail_option
Specify the detail option.
  • charging
  • full
  • policy
  • summary
  • userplane
Usage Guidelines
Use this command to view subscriber data.
show subscriber supi-opt policy-opt
Command Mode
Exec
Syntax
  • flow
  • rules
Usage Guidelines
show userplane userplane
Displays userplane information.
Command Mode
Exec
Syntax
show userplane all
all
Specify all.
Usage Guidelines
Use this command to view userplane information.
show vrf-info
Displays information about Virtual Routing and Forwarding (VRF).
Command Mode
Exec
Syntax
show vrf-info [ all | ipv4 | ipv6 ]
all
Show details for all VRFs.
ipv4
Show details for VRFs associated with the IPv4 address family.
ipv6
Show details for VRFs associated with the IPv6 address family.
Usage Guidelines
Use this command to view VRF information. You can filter the output by selecting all VRFs, IPv4 VRFs, or IPv6 VRFs. If no option is specified, the command displays all VRF details.
show vrf-route-info
Displays detailed routing information for Virtual Routing and Forwarding (VRFs).
Command Mode
Exec
Syntax
show vrf-route-info [ ipv4 | ipv6 | name vrf_name ]
ipv4
Option to display routing information for the IPv4 address family.
ipv6
Option to display routing information for the IPv6 address family.
name vrf_name
Usage Guidelines
Use this command to view the VRF routing information. You can filter the output by choosing the IPv4 or IPv6 address family or by specifying a particular VRF name. If no option is specified, the command displays all VRF routing details.
show-defaults
Displays the default configuration.
Privilege Level
Command Mode
Exec
Syntax
show-defaults { false | true }
{ false | true }
Specify whether to display or hide the default values. To display, select true. Otherwise, select false.
Must be either "false" or "true".
Usage Guidelines
Use this command to view the default configuration.
show confd-state
Displays ConfD status information.
Command Mode
Exec
Syntax
show confd-state
show confd-state
Shows the current status information of the ConfD service.
Usage Guidelines
Use this command to view ConfD status information.
show dns-cache
Displays DNS cache information.
Command Mode
Exec
Syntax
show dns-cache
show dns-cache
Shows the current contents of the DNS cache, including cached domain name resolutions and related details.
Usage Guidelines
Use this command to view DNS cache information.
show dns-query
Displays FQDN resolution.
Command Mode
Exec
Syntax
show dns-query
show dns-query
Shows the resolution details of Fully Qualified Domain Names (FQDN), including information about recent DNS queries and their resolved IP addresses.
Usage Guidelines
Use this command to view FQDN resolution.
show gtpp-ep
Displays information related to GTPP CDR.
Command Mode
Exec
Syntax
show gtpp-ep
show gtpp-ep
Shows information related to GTPP CDR (Call Detail Record) file operations, such as the status, details, or summary of existing GTPP CDR files.
Usage Guidelines
Use this command to view information related to GTPP CDR.
show helm
Displays helm configuration parameters.
Command Mode
Exec
Syntax
show helm
show helm
Shows the current helm configuration parameters, including settings and values used for helm deployments and management.
Usage Guidelines
Use this command to view helm configuration parameters.
show history
Displays CLI command history.
Command Mode
Exec
Syntax
show history
show history
Shows the the history of previously executed CLI commands in the current session.
Usage Guidelines
Use this command to view CLI command history.
show jobs
Displays background jobs.
Command Mode
Exec
Syntax
show jobs
show jobs
Shows a list of background jobs currently running or suspended in the system.
Usage Guidelines
Use this command to view background jobs.
show last-logins
Displays last logged in users.
Command Mode
Exec
Syntax
show last-logins
show last-logins
Shows information about the most recent user login attempts, including details of the last users who logged into the system.
Usage Guidelines
Use this command to view last logged in users.
show license
Displays licensing information.
Command Mode
Exec
Syntax
show license
show license
Shows licensing information for the system, including current license status, types, and expiration details.
Usage Guidelines
Use this command to view licensing information.
show local-interface-status
Displays local interface status.
Command Mode
Exec
Syntax
Shows the status and details of all local network interfaces, including their operational state, IP addresses, and other relevant information.
Usage Guidelines
Use this command to view local interface status.
show mode
Displays privelege based operational CLI.
Command Mode
Exec
Syntax
show mode
show mode
Shows the current operational mode of the CLI based on user privilege level.
Usage Guidelines
Use this command to view privelege based operational CLI.
show nacm
Displays Network Access Control Model (NACM) settings and information.
Command Mode
Exec
Syntax
show nacm
show nacm
Shows Network Access Control Model (NACM) settings and information, including user permissions and access control configurations.
Usage Guidelines
Use this command to view Network Access Control Model (NACM) settings and information.
show netconf-state
Displays NETCONF statistics.
Command Mode
Exec
Syntax
show netconf-state
show netconf-state
Shows statistics and status information about NETCONF operations, including session details, message counts, and related metrics.
Usage Guidelines
Use this command to view NETCONF statistics.
show nf-tls
Displays TLS keystore configuration for interfaces.
Command Mode
Exec
Syntax
show nf-tls
show nf-tls
Shows the TLS keystore configuration for network interfaces, including details about certificates, keys, and their status used for securing interface communications.
Usage Guidelines
Use this command to view TLS keystore configuration for interfaces.
show notification
Displays system notifications.
Command Mode
Exec
Syntax
show notification
show notification
Shows system notifications, including recent alerts and messages generated by the system.
Usage Guidelines
Use this command to view system notifications.
show nrf
Displays operational data for the NRF.
Command Mode
Exec
Syntax
show nrf
show nrf
Shows operational data for the NRF client, including status, registrations, and related information.
Usage Guidelines
Use this command to view operational data for the NRF.
show ops
Displays a list of ops centers installed in the cluster.
Command Mode
Exec
Syntax
show ops
show ops
Shows a list of ops centers installed in the cluster, including their names, statuses, and relevant details.
Usage Guidelines
Use this command to view list of ops centers installed in the cluster.
show overload-info
Displays system overload information.
Command Mode
Exec
Syntax
show overload-info
show overload-info
Shows system overload information, including current overload status, affected components, and relevant metrics.
Usage Guidelines
Use this command to view system overload information.
show parser
Displays information about the system parser.
Command Mode
Exec
Syntax
show parser
show parser
Shows information about the system parser, including its current status, configuration, and recent parsing activities.
Usage Guidelines
Use this command to view information about the system parser.
show pcscf
Displays information about failed Proxy-Call Session Control Function (P-CSCF) addresses.
Command Mode
Exec
Syntax
show pcscf
show pcscf
Shows information about failed P-CSCF addresses, including details on failures and their statuses.
Usage Guidelines
Use this command to view information about failed Proxy-Call Session Control Function (P-CSCF) addresses.
show resources
Displays system resource information.
Command Mode
Exec
Syntax
show resources
show resources
Shows system resource information, including CPU, memory, storage usage, and other relevant resource metrics.
Usage Guidelines
Use this command to view system resource information.
show restconf-state
Displays statistics and status information about RESTCONF operations.
Command Mode
Exec
Syntax
show restconf-state
show restconf-state
Shows statistics and status information about RESTCONF operations, including session details, request counts, and related metrics.
Usage Guidelines
Use this command to view statistics and status information about RESTCONF operations.
show running-config
Displays the current active configuration of the system.
Command Mode
Exec
Syntax
show running-config
show running-config
Shows the current active configuration of the system, including all runtime settings and parameters.
Usage Guidelines
Use this command to view the current active configuration of the system.
smiuser
Configures the Subscriber Microservices Infrastructure (SMI) user account parameters.
Privilege Level
Command Mode
Exec
Syntax
smiuser { add-group groupname group_name | add-user { username username | password password } | change-password { username username | current_password current_password | new_password new_password | confirm_password new_password | password_expire_days expire_days } | change-self-password { current_password current_password | new_password new_password | confirm_password new_password | password_expire_days expire_days } | delete-group groupname group_name | delete-user username username | unassign-user-group { groupname groupname_pam | username username_pam } | update-password-length length password_length }
username username
Specify the username.
Must be a string.
password password
Specify the user password.
Must be a string.
Confirm the new password.
Must be a string.
Specify the current password.
Must be a string.
Specify the new password.
Must be a string.
Specify the number of days before the password expires.
Must be an integer.
Specify the group name.
Must be a string.
Specify the group name in PAM.
Must be a string.
Specify the user name in PAM.
Must be a string.
Specify the minimum password length.
Must be an integer.
Usage Guidelines
Use this command to configure the smiuser parameters.
system
Configures the NF's system operations.
Privilege Level
Command Mode
Exec
Syntax
system { ops-center stop | synch { start | stop } | upgrade | uuid-override new-uuid uuid_value }
ops-center stop
Stop the synching of configuration.
Starts or stops the synching of configuration,
upgrade
Initiates the upgrade of a product.
Change the Universally Unique Identifier (UUID) to a new value.
Must be a string.
Usage Guidelines
Use this command to display the NF's system operations.
system-diagnostics event-trace
Configures Event Trace configuration.
Syntax
system-diagnostics event-trace event_trace_state
Specify to enable or disable Event Trace configuration.
  • disable
  • enable
Usage Guidelines
Use this command to enable or disable Event Trace configuration.
system-diagnostics idmgr-secondary-recon
Configures to trigger secondary reconciliation in NodeMgr using unique key.
Command Mode
Syntax
system-diagnostics idmgr-secondary-recon { false | true }
Triggers secondary reconciliation in NodeMgr using unique key.
Usage Guidelines
Use this command to enable or disable secondary reconciliation in NodeMgr using unique key.
system-diagnostics ip-validation
Configures IP address validation with CDL.
Syntax
ip-validation { enable | ignore-mismatch-responses }
enable
Specify to enable new IP address validation with CDL.
Specify to ignore CDL inconsistencies during address validation.
Usage Guidelines
Use this command to configure IP address validation with CDL.
system-diagnostics pod type
Configures and enables your required pod from a cluster of the supported pods.
Command Mode
Syntax
system-diagnostics pod_type
pod_type
Specify the required type of service pods for system diagnostics.
  • diameter
  • gtp
  • pfcp
  • service
  • sgw-service
Usage Guidelines
Use this command to enable and configure your required pod from a cluster of the supported pods.
system-diagnostics pod type fault
Enables system fault panic recovery while session processing.
Command Mode
Exec > Global Configuration (config) > System Diagnostics Configuration (config-system-diagnostics-pod_type )
Syntax
fault { action action_on_fault | file-detail file_names_line_numbers | interval interval_duration | num max_fault_tolerance }
Specify the action to take on fault occurence.
  • abort
  • cleanup
  • graceful-Reload
  • reload
Specify the list of file names with line number to exclude from recovery. For example, procedures/pduim/procedure.go:1902.
Must be a string.
You can configure a maximum of 10 elements with this keyword.
Specify the duration of the interval in minutes.
Must be an integer in the range of 1-3600.
Specify the maximum number of times fault can be tolerated in an interval.
Must be an integer in the range of 0-50.
Usage Guidelines
Use this command to enable and configure system fault panic recovery while session processing.
system-diagnostics protocol supi
Configures the list of SUPI values for which config has to be applied.
Syntax
supi subscription_permanent_id
Specify the Subscription Permanent Identifier (SUPI).
Must be an integer in the range of 100000000000000-999999999999999.
Usage Guidelines
Use this command to configure the list of SUPI values for which config has to be applied.
system-diagnostics protocol supi preferred-up
Configures the preferred user plane node ID.
Syntax
preferred-up node-id node_id
node-id node_id
Specify node ID of the preferred user plane node.
Must be a string.
Usage Guidelines
Use this command to configure the preferred user plane node ID.
system-diagnostics session-consistency
Enables and configures inconsistency checks on session data.
Syntax
system-diagnostics session-consistency action action_on_inconsistent_data
Specify the action to take on inconsistent data.
  • cleanup
  • disabled
  • monitor
Usage Guidelines
Use this command to enable and configure inconsistency checks on session data.
terminal
Configures the type of terminal.
Privilege Level
Command Mode
Exec
Syntax
terminal terminal_type
terminal_type
Specify the terminal type.
  • ansi
  • generic
  • linux
  • vt100
  • xterm
Usage Guidelines
Use this command to configure the terminal type.
test dns-query
Tests FQDN resolution.
Command Mode
Exec
Syntax
test dns-query { fqdn fqdn | num-ipv4 ipv4_count | num-ipv4v6 ipv4v6_count | num-ipv6 ipv6_count }
fqdn fqdn
Specify the Fully Qualified Domain Name (FQDN) of the node for which DNS query has to be sent.
num-ipv4 ipv4_count
Specify the number of IPv4 to be used for DNS query.
Must be an integer in the range of 1-9.
Specify the number of IPv4v6 to be used for DNS query.
num-ipv6 ipv6_count
Specify the number of IPv6 to be used for DNS query.
Usage Guidelines
Use this command to test FQDN of the node for which dns query has to be sent.
test gtpc echo
Tests the connectivity of GTP-C peer nodes.
Command Mode
Exec
Syntax
test gtpc echo instance-id instance_id interface interface_type peer-address ip_address
Specifies the instance ID of a GR instance that is configured on the system.
Specifies the type of GTP-C interface, such as S11, S5e, S5, S2b, or S8.
Specifies IPv4 or IPv6 address of a specific peer to which GTP-C echo request is sent.
Usage Guidelines
Use this command to test connectivity of GTP-C peer nodes.
test gtpp echo
Tests the connectivity of a CGF server that is not configured in a GTPP profile.
Command Mode
Exec
Syntax
test gtpp echo instance-id instance_id ca-address ip_address [ ca-port port ] [ cgf-address ip_address ] [ cgf-port port ]
Specifies the IPv4 address of charging agent configured within GTPP profile.
ca-port port
Specifies the port of charging agent configured within GTPP profile, ranging 1–65535. By default, the port is 49999.
Specifies the IPv4 address of a specific CGF server to which GTPP echo request is sent.
cgf-port port
Specifies the port of CGF server, ranging from 1– 65535. By default, the port is 3386.
Usage Guidelines
Use this command to check the connectivity of CGF server.
test-radius accounting
Tests RADIUS accounting server function.
Command Mode
Exec
Syntax
test-radius accounting { all [ [ client-nas ip_address ] [ username user_name ] ] | server server_ip_address [ [ client-nas ip_address ] [ port port_number ] [ username user_name ] ] | server-group [ [ client-nas ip_address ] [ username user_name ] ] }
all
Specify to test all configured servers.
  • all
Specify IP address of the client NAS.
Must be a string in the ipv4-address pattern. For information on the ipv4-address pattern, see the Input Pattern Types chapter.
-Or-
Must be a string in the ipv6-address pattern. For information on the ipv6-address pattern, see the Input Pattern Types chapter.
port server_port_number
Specify the port number of the RADIUS server.
Must be an integer in the range of 1-65535.
server-group server_group_name
Specify name of the server group.
Must be a string of 1-64 characters.
Specify the IP address of the RADIUS server.
-Or-
username user_name
Specify the user name.
Default Value: test.
Usage Guidelines
Use this command to test RADIUS accounting server function.
test-radius authentication
Tests RADIUS authentication server function.
Command Mode
Exec
Syntax
test-radius authentication { all [ [ client-nas ip_address ] [ password password ] [ username user_name ] ] | server server_ip_address [ [ client-nas ip_address ] [ password password ] [ port port_number ] [ username user_name ] ] | server-group [ [ client-nas ip_address ] [ password password ] [ username user_name ] ] }
all
  • all
-Or-
password password
Specify the password for user with authentication verified.
-Or-
username user_name
Usage Guidelines
Use this command to test RADIUS authentication server function.
timestamp
Configures the timestamp parameters.
Privilege Level
Command Mode
Exec
Syntax
timestamp { disable | enable }
Enable or disable the timestamp display.
Usage Guidelines
Use this command to configure the timestamp.
who
Displays information on currently logged on users.
Privilege Level
Command Mode
Exec
Syntax
who
Usage Guidelines
Use this command to view information on currently logged on users. The command output displays the Session, User, Context, From (IP address), Protocol, Date, and Mode information.
