Event Detail Records
Summary Data
Table 1. Summary Data
Applicable Products or Functional Area
SMF
Applicable Platforms
SMI
Feature Default Setting
Disabled - Configuration Required
Related Changes in this Release
Not Applicable
Related Documentation
Not Applicable
Revision History
Table 2. Revision History
Revision Details
Release
Introduced support for the following enhancements:
  • EDR generation for dedicated bearer and handover (pathswitchreq (Xn handover), pdun2ho, pdn5g4gHo, nrtountrustwifiho, pdun26ho, utn3gppto5g) procedures
  • Archival of EDR files in OAM pod
  • New commands to
    • Enable EDR for all subscribers
    • Configure transaction EDR rate, CPU threshold, session threshold, and file archival policy
2022.04.0
Introduced EDR support for PDU session modification procedure for roaming and non-roaming scenarios
2021.02.2
Provided support for event-level EDR generation
2021.02.0
Custom EDR Generation
2021.01.0
Feature Description
Event Data Records (EDRs) collect information that you can use to perform the following functions:
  • Debug or understand the application behavior
  • Diagnose the call flow for the specific subscribers
The SMF supports logging of EDRs for both 4G and 5G subscriber sessions including non-roaming and roaming sessions. If the EDR Support feature is enabled, then in a roaming scenario, hSMF and vSMF generate EDRs for PDU session establishment and release procedures. The SMF generates EDR files in comma-separated value (CSV) format. The SMF stores one CSV record per line. The CSV files can be optionally compressed before sending to an external server.
The SMF treats a request message and response message as one EDR event record. For example, N11SmContextCreateReq and N11SmContextCreateResp attributes are logged as an EDR event.
The SMF supports EDR file generation for transaction and transaction-collision level details for subscriber sessions. By default, the EDR generation is disabled.
In release 2021.02.0, the SMF generates EDRs with procedure-level details, event-level details, and field-level details. These granular details help in debugging errors and issues.
EDR Format
In addition to the existing Transaction EDR fields, the application appends procedure-id and event-id along with the respective field values. Application registers the procedure-id, event-id, and field-id along with the corresponding names. This mapping is used to format the CSV event entry in the EDR. Each event entry consists of comma-separated procedure-id, event-id, and field-value. These registered mappings can also be used in CLI commands to disable EDRs at procedure, event, or field level. You can enable or disable the EDRs dynamically during runtime. The existing EDR records remain the same and the runtime changes get reflected only in the newly generated EDR records.
Transaction EDR Format
Transaction-EDR-Fields, list of event-entries [ ]
Event Entries
Procedure-id1, Event-id1, list of field-id1-values [ ]
The following is a sample transaction entry along with a list of events in the CSV format.
Version, Field-Count, Transaction-id-value, Start-Time, Elapsed-Time, ……,
Procedure-id1, event-id1, field-id1-value, field-id2-value……,
Procedure-id1, event-id2, field-id1-value, field-id2-value……,
Procedure-id1, event-id3, field-id1-value, field-id2-value……
Note
There might be different set of fields for a combination of procedure-id and event-id. You can enable or disable the EDRs dynamically during runtime by using a CLI command. For configuration details, see the Configure EDR Files for Generation section in this guide.
EDR File Storage Location
This section provides details on the archival location of EDR files in SMF service pod and EDR monitor pod.
EDR Files in SMF Service Pod
The EDR file is generated in each SMF service pod where the subscriber sessions and events are processed. Based on the EDR file size, the files are archived periodically in non-persistent volume, that is, the SMF service pod. A new file is created before archiving the existing file.
The format of the transaction EDR file name and transaction collision EDR file name are as follows:
<pod-name>_<pod_instance>_<PodStartTime>.transaction.csv
<pod-name>_<pod_instance>_<PodStartTime>.transaction_collision.csv
The directory path of service pod is /tmp/edr/.
Example:
smf-service-n0-0_0_ 20220730233455.transaction.csv
Where the pod name is smf-service-n0-0, pod instance is 0, and the pod start time "20220730181014" means 30nd July 2022 18:10:14 UTC.
The format of compressed file name is as follows:
<pod-name>_<pod_instance>_<PodStartTime>.transaction.csv.<fileArchivedTime>.<FileRotationCounter>.gz
Example:
example-service-n0-0_1_20220730181014.transaction.csv.20220730181844.1.gz
EDR Files in EDR Monitor Pod
The SMF service pod sends all the EDR files to edr-monitor pod every 30 seconds. The EDR files remain in edr-monitor pod persistent directory as .csv file. When the total size of all the files exceeds the configured maximum file size, the oldest file is deleted.
The format of file name in edr-monitor pod is <pod-name>_<pod_instance>_<PodStartTime>.transaction.csv.
Example:
edr-monitor pod-n0-0_0_ 20220730233455.transaction.csv
The directory path of edr-monitor pod is /logs/edr/.
The EDR file size, maximum archived EDR file count, and maximum persistent volune size are configured through CLI commands. For information on the configuration commands, see the Configure EDR Parameters section.
To access the files in the persistent volume of EDR monitor pod, log on to the Ops center with required credentials, and use the edr-monitor pod ingress URL.
To determine the ingress URL, use the following command:
kubectl get ingress -n namespace | grep edr
Example:
cloud-user@svi-cndp-tb41-gr-setup-smf-cluster-2-cndp-server-1:~$ kubectl get ingress -n smf-smf | grep edr
edr-archives-smf-smf nginx edr-archives.smf-smf.172.18.128.82.nip.io 10.109.13.65 80, 443 4d5h
EDR Transaction File
The EDR transaction file dumps the transaction information at the end of the transaction. By default, the file generation is disabled.
The following table provides the information that is stored in the file.
Table 3. EDR Transaction File Fields
Field Number
Field Name
Field Description
Version
EDR version number. Default value is v1.
Note
The version will change only when there is a change in the encoding order of transaction header fields or change in encoding procedure of any individual field.
Field Count
Total number of fields in transaction EDR header. The default value is 15.
Transaction ID
Transaction ID
Start Time
The transaction start time in yyyy/MM/dd HH:mm:ss.SSS format.
Elapsed Ms
The time taken for transaction to end in milliseconds.
6
Subscriber ID
The subscriber ID. For example, imsi-123456789012345
7
Transaction Type
The transaction type (integer) which is defined internally in the application.
8
Transaction Description
The transaction description in string format.
9
Session Primary Key
The primary key of the session.
Session Unique Keys
The unique keys for the session separated by |.
11
Session Non Unique Keys
The non-unique keys for the session separated by |.
12
Status
The transaction status (success or error).
13
Status Code
The transaction status code to indicate the failure reason.
14
Procedure Name
The procedure name for which the transaction is submitted.
15
Sub Procedure Name
The sub procedure name for which the transaction is submitted.
16
State
The transaction state. It can be:
  • Started
  • New
  • Ready
  • Active
  • Pending
  • Suspend
  • SuspendWaitingForResponse
  • SuspendWaitingForLock
  • Abort
  • Finished
  • Timeout
  • Unknown
17
Execution stages
The list of stages the transaction went through its lifecycle separated by |
NOTES:
  • Each field is separated by comma (,).
  • Fields session_uks, session_nuks, execution_stages are a list. These fields are separated by pipe (|). For example, session_uks is denoted as uk1|uk2|uk3.
CSV Format Examples:
V1,15,1,2022/08/03 22:12:19.482,292,imsi-123456789012345,2051,S5S8CreateSessReq,imsi-123456789012345:5,imsi-123456789012345:12.0.0.1|intershat:12.0.0.1|imsi-123456789012345:2001:db0::|intershat:2001:db0::|1|imsi-123456789012345:ebi-5|imsi-
123456789012345:intershat,roaming-status:homer|ue-type:nr-capable|supi:imsi-123456789012345|gpsi:msisdn-223310101010101|pei:imei-123456786666660|psid:5|snssai:002abf123|dnn:intershat|emergency:false|rat:wlan|access:untrusted non-3gpp access|
connectivity:4g|udm-uecm:10.1.29.66|udm-sdm:10.1.29.66|auth-status:unauthenticated|pcfGroupId:PCF-*|policy:2|pcf:10.1.29.66|upf:198.18.1.3|upfEpKey:198.18.1.3:198.18.1.4|ipv4-addr:poolv4/12.0.0.1|ipv4-pool:poolv4|ipv4-range:poolv4/12.0.0.1|
ipv4-startrange:poolv4/12.0.0.1|ipv6-pfx:poolv6/2001:db0::|ipv6-pool:poolv6|ipv6-range:poolv6/2001:db0::|ipv6-startrange:poolv6/2001:db0::|id-index:1:0:32768|id-value:0/1|chfGroupId:CHF-dnn=intershat;|chf:10.1.29.66|gtp-peer:198.18.1.100|
peerGtpuEpKey:198.18.1.3:198.17.1.6,success,success,PDN Connect [LTE],S5S8CreateSessReq,Active,init_done|4G SETUP: Idle|4G SETUP: Await UDM Registration|4G SETUP: Await UDM Subscription Fetch|4G SETUP: Await UDM Subscribe for Notification|
4G SETUP: Await PCF Create|4G SETUP: Await Address Allocation|4G SETUP: Await PCF Update|4G SETUP: Await Charging Create|finished,3,1313,V2,4,Success,201,3,,3,1316,V2,4,Success,200,3,,3,1319,V2,4,Success,201,3,,3,3329,V2,9,imsi-123456789012345,
imei-123456786666660,msisdn-223310101010101,Success,201,3,||3|1;2;2|3000 mbps|4000 mbps|1000 mbps|2000 mbps,200000 kbps|400000 kbps,,3,3332,V2,4,Success,204,3,,3,1003,V2,4,Success,201,3,,3,524,V2,4,Success,,3,Request_Accepted,3,2051,V2,18,
imsi-123456789012345,imei-123456786666660,123456789012345,223310101010101,msisdn-223310101010101,Success,,APCO|||||||2;Abf123;;|||1;1|1;0|0|,3,1,intershat,,||5|0;0;15||||,200 mbps|400 mbps,16,12.0.0.1|2001:db0::b46d:47ff:fe47:4747,2|Abf123||,
WLAN,3,1000,V2,40,imsi-123456789012345,imei-123456786666660,123456789012345,223310101010101,msisdn-223310101010101,123|456,Eutra|Ecgi:123;456;1234567|Tai:123;456;1820,2022-08-03 22:12:19.485844223 +0000 UTC,2022-08-03 22:12:19.772243364
+0000 UTC,Ue,,198.18.1.100,Success,3,,intershat,WLAN,+00:15+1,3,123|456,100000000,125000000,5,1|1|15,12.0.0.1|2001:db0::b46d:47ff:fe47:4747,4611115543,6755399441055921,1,5,,2,2|Abf123||,16,1,NR Capable UE,1580,198.17.1.6,6168582,198.17.1.3,intershat
Procedure-level EDR Generation
The Event Logging feature captures procedure-level information per subscriber. Upon completing a procedure, either successfully or unsuccessfully, the SMF generates event data records capturing the details of procedures and events.
The EDR generation per procedure is configurable. For configuration details, see the Configure EDR Files for Generation section in this guide.
The following table lists the supported procedures and the corresponding IDs.
Table 4. Procedure List
Procedure Procedure-ID
PDN-SESSION-CREATE or PDU-SESSION-CREATE
PDN-SESSION-DELETE or PDU-SESSION-DELETE
PDU-SESSION-MODIFY
DEDICATEDBEARER
6
HANDOVER
7
Note
The procedure IDs remain the same for both roaming and non-roaming procedures.
Further, the SMF captures event-level information per procedure. The following table provides details on the subscriber events and the respective event IDs.
The events captured per procedure are configurable. For configuration details, see the Configure EDR Files for Generation section in this guide.
Table 5. Event IDs
EVENT EVENT-ID Applicability of Events to Procedures
Create Release Modify Dedicated Bearer Handover
N11SmContext CreateReq
1287 Yes Yes
N11SmContext UpdateReq
1290 Yes Yes Yes Yes
N11N1N2Message TransferReq
1299 Yes Yes Yes Yes
N11SmContext UpdateModifyReq
1293
N11Ebi AssignmentReq
1302 Yes Yes
N11SmContext ReleaseReq
1304 Yes
N11SmContext StatusNotifyReq
1310 Yes Yes
N11N1N2Message TransferFail NotificationReq
1339 Yes Yes
N4Session ModificationReq
527 Yes Yes Yes Yes Yes
N4Session ReleaseReq
530 Yes Yes
N4Session EstablishmentReq
524 Yes
N7SmPolicy CreateReq
3329 Yes
N7SmPolicy DeleteReq
3335 Yes Yes
N7SmPolicy UpdateReq
3332 Yes Yes Yes Yes
N7SmPolicy TerminateNotify Req
3341 Yes
N7SmPolicy UpdateNotifyReq
3338 Yes Yes Yes
N10UnsubscribeFor NotificationReq
1432 Yes
N10SubscribeFor NotificationReq
1319 Yes
N10Registration Request
1313 Yes
N10Subscription FetchReq
1316 Yes
N10Deregistration Request
1325 Yes Yes
S5S8Delete BearerCmd
2066 Yes Yes
N10Update NotifyReq
1322 Yes Yes
N40Charging DataCreateReq
1003 Yes Yes
N40Charging DataUpdateReq
1004 Yes Yes
N40Charging DataReleaseReq
1005 Yes Yes
N40Charging NotificationReq
3588 Yes Yes
Secondary AuthenReq
2307 Yes
S5S8Create SessReq
2051 Yes Yes
S5S8Delete BearerReq
2057 Yes Yes Yes
S5S8Delete SessReq
2055 Yes Yes
RadiusCoa DisconnectReq
2313 Yes
RadiusAcctReq
2309 Yes Yes Yes Yes
metaData
1000 Yes Yes Yes Yes
N16PduSession CreateReq
1444 Yes Yes
N16VsmfPdu SessionRelease Req
1471 Yes Yes
N16PduSession HsmfUpdateReq
1447 Yes Yes Yes Yes Yes
N16PduSession HsmfUpdateReq Client
1477 Yes Yes Yes Yes Yes
N16VsmfPdu SessionCreateReq
1468 Yes Yes
N16PduSession VsmfUpdateReq
1451 Yes Yes Yes Yes
N16PduSession NotifyReq
1458 Yes
N11SmContext RetrieveReq
1307 Yes Yes
N16PduSession VsmfUpdateReq Client
1478 Yes Yes Yes Yes
N16PduSession NotifyReqClient
1488 Yes
S5S8Update BearerReq
2062 Yes Yes
S5S8Create BearerReq
2059 Yes Yes
S5S8Bearer ResourceCmd
2061 Yes
S5S8Modify BearerCmd
2064 Yes
N4GtpuRouter AdvertisementReq
542 Yes
S5S8Modify BearerReq
2053 Yes
NInternalTxnMsg¹
1001(xxxx) Yes Yes Yes Yes Yes
Ntimer NotificationMsg¹
1002(xxxx) Yes Yes Yes Yes Yes
¹ - SMF uses several internal messages for handling 3GPP call flows. These internal events are sent and received by SMF and are not 3GPP compliant. NInternalTxnMsg and NTimerNotificationMsg are two generic event IDs defined to represent such internal messages used by SMF. The xxxx in the Event IDs represent the original message type that is used by SMF internally for easy debuggability.
The SMF uses N40ChargingDataCreateReq, N40ChargingDataUpdateReq, and N40ChargingDataReleaseReq instead of N40ChargingDataReq for PDU/PDN create and release.
The following tables list the detailed event record for the PDU Session Create, Modify, Delete, Handover, and Dedicated Bearer procedures.
Table 6. PDU Session Create Events
Number
Attribute Name Presence Type Description
TXN EDR fields M
PROCEDURE ID
EVENT-ID VERSION M Event=N11SmContext CreateReq
FIELD-COUNT M
SUPI M
IMEI/PEI M
IMSI M
MSISDN M
GPSI M
STATUS M
STATUS-CODE O
N1-REQ-PDU(PDN)- SESSION-TYPE
O PduSessionType
N1-REQ-SSC-MODE O
CAUSE O
N1-PCO O PCO
N1-REQ-MSG-TYPE O N1N2MSGREQ CONTENT PDU-SESSION- ESTB-REQUEST
N2-REQ-MSG-TYPE O N1N2MSGREQ CONTENT
N1-RSP-MSG-TYPE O N1N2MSGRSP CONTENT
N2-RSP-MSG-TYPE O N1N2MSGRSP CONTENT
N1-REQ-MAX- SUPP-FILTERS O
N1-ALWAYS-ON O
RAT-TYPE M
S-NSSAI- REQUESTED O NSSAI
GUAMI O
REQUEST-TYPE O
AN-TYPE O
OLD-PDU-SESS-ID O
N1-DNN/APN O
SERVING-NFID O
SERVING-PLMN O
UNAUTH-SUPI O
S-NSSAI-ASSIGNED O NSSAI
UP-CONTEXT-STATE O
N1-PDU-SESS-ID O
INDIRECTFWD FLAG O
DIRECTFWD FLAG O
HO-STATE
O
PROCEDURE ID
EVENT-ID VERSION M Client Event=N11Sm ContextUpdateReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
SUPI M
IMEI M
IMSI M
MSISDN M
PDU(PDN)- SESSION-TYPE O
N1-REQ-MSG-TYPE O N1N2MSG REQCONTENT
pdu_session_ modification_request
pdu_sess_ modification _command
pdu_session_ release_req
pdu_session_ release_command
pdu_session_ release_complete
pdu_session_ modification_reject
pdu_session_ modification_ complete
pdu_session_ release_reject
N2-REQ-MSG-TYPE O N1N2MSG REQCONTENT
N1-RSP-MSG-TYPE O N1N2MSG RSPCONTENT
pdu_sess_modification _command
N2-RSP-MSG-TYPE O N1N2MSG RSPCONTENT
N1-PCO NA PCO
N1-QOS-RULE O QOS-RULE
N1-QOS-DESC O QOS-DESC
CAUSE O
N1-ALWAYS-ON O
5G-SM-CAP O
N1-RSP-MAX- SUPP-FILTERS O
RAT-TYPE O
UP-CONTEXT -STATE O
HO-STATE O
N1-BACKOFF-TIME NA
N1-PDU-SESS-ID O
N1-VGSM-RE -ATTEMPT-IND NA
N1-RE-ATTEMPT -IND NA
N1-SESS-AMBR O
N1-CONG-RE- ATTEMPT-IND O
N1-RSP-ALWAYS-ON
PROCEDURE ID
EVENT-ID VERSION M Event=N11N1N2 MessageTransfer Req
FIELD-COUNT M
STATUS M
STATUS-CODE O
PDU-SESSION-TYPE M
PDU-SESSION- ESTB-ACCEPT
PDU-SESSION- ESTB-REJECT
PDU_SESSION_ RELEASE_ COMMAND
PDU_SESSION_ MODIFICATION_ COMMAND
N2-REQ-MSG-TYPE N1N2MSG REQCONTENT
N1-RSP-MSG-TYPE O N1N2MSG REQCONTENT
N2-RSP-MSG-TYPE N1N2MSG RSPCONTENT
N1-PCO O PCO
CAUSE O
N1-ALWAYS-ON O
N1-SESSION-AMBR O SESS-AMBR
N1-PAA O PAA
N1-S-NSSAI O NSSAI
N1-PDU-SESS-ID O
N1-DNN/APN O
N1-BACKOFF-TIME NA
N1-REQ-SSC- MODE-SELECTED O
N1-REQ-PDU(PDN)- SESSION-TYPE- SELECTED O
N1-SSC-MODE -ALLOWED O
N1-RSP-AN-TYPE NA
PROCEDURE ID
EVENT-ID VERSION M
Event=N7SmPolicy CreateReq
FIELD-COUNT M
SUPI M
IMEI/PEI M
GPSI M
STATUS M
STATUS-CODE O
QOS-DESC O QOS-DESC
CAUSE O
PROCEDURE ID EVENT-ID VERSION M
EVENT= N4Session ModificationReq
N10Unsubscribe ForNotificationReq
SecondaryAuthenReq
RadiusAcctReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
PDU-SESSION -TYPE M
CAUSE O
6
PROCEDURE ID
EVENT-ID VERSION M Event=S5S8Create SessReq
FIELD-COUNT M
SUPI M
IMEI/PEI M
IMSI M
MSISDN M
GPSI M
STATUS M
STATUS-CODE O
PCO O PCO
PDU-SESSION-TYPE O
SSC-MODE O
DNN/APN O
QOS-RULE O QOS-RULE
QOS-DESC O QOS-DESC
CAUSE O
PAA O PAA
S-NSSAI O NSSAI
RAT-TYPE M
HO-INDICATION
7
PROCEDURE ID
EVENT-ID VERSION M
Event=N16Pdu SessionCreateReq
FIELD-COUNT M
SUPI O
IMEI/PEI O
GPSI O
GUAMI O GUAMI
REQUEST-TYPE M RequestType
STATUS M
STATUS-CODE O
PDU/PDN-SESSION -TYPE O PduSessionType
DNN/APN M
RAT-TYPE O
S-NSSAI O NSSAI
SERVING-PLMN M PLMN-ID
VSMF-ID M
VCNTUNNEL-INFO M TUNNEL-INFO
HO-PREP- INDICATION O
PGW-S8-CFTEID O
ALWAYS-ON -REQUESTED O
UE-LOCATION O UE-LOCATION
ROAMING-CHRG- PROF-REQUESTED O CHARGING-PROF
ALWAYS-ON- GRANTED O
SSC-MODE O
HCNTUNNEL-INFO M TUNNEL-INFO
UE-IPV4-ADDRESS O
UE-IPV6-PREFIX O
QOS-FLOWS- SETUP-LIST O QFS
ROAMING-CHRG -PROF- SELECTED O CHARGING-PROF
CAUSE O
N1SM-CAUSE O
UE-IPV6-INTERFACE -ID O
N1-REQ-MSG-TYPE O PDU_SESSION_ ESTABLISHMENT _REQ
N2-REQ-MSG-TYPE O
N1-RSP-MSG-TYPE O PDU_SESSION_ ESTABLISHMENT _ACCEPT
N2-RSP-MSG-TYPE O
N1-PDU-SESS-ID O
N1-REQ-PDU(PDN)- SESSION-TYPE O
N1-REQ-SSC -MODE O
N1-PCO O
N1-REQ-MAX-SUPP -FILTERS O
N1-ALWAYS-ON O
N1-REQ-SSC-MODE -SELECTED O
N1-QOS-RULES O
N1-QOS-DESC O
N1-SESS-AMBR O
N1-REQ-ALWAYS-ON O
N1-REQ-SSC-MODE -ALLOWED O
N1-RSP-RE- ATTEMPT-IND O
N1-DNN/APN O
8
PROCEDURE ID
EVENT-ID VERSION M Event= N16VsmfPdu SessionReleaseReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
CAUSE O
VGMM-CAUSE O
NGAP-CAUSE O NGAP-CAUSE
9
Event= N16PduSession VsmfUpdateReq
N16PduSession VsmfUpdate ReqClient
FIELD-COUNT M
STATUS M
STATUS-CODE O
REQUEST- INDICATION O N1N2MSG REQCONTENT
SESSION-AMBR O N1N2MSG REQCONTENT
ALWAYS-ON- GRANTED O RequestIndication
CAUSE O SESS-AMBR
N1SM-CAUSE O
BACKOFF-TIMER
N1-REQ-MSG-TYPE O
PDU_SESSION_ MODIFICATION _COMMAND
PDU_SESSION_ MODIFICATION _COMMAND_REJECT
N1-RSP-MSG-TYPE
PDU_SESSION_ MODIFICATION _REJECT
N1-PCO O
N1-QOS-RULE O
N1-QOS-DESC O
N1-PDU-SESS-ID O
N1-ALWAYS-ON O
N1-SESSION-AMBR O
Event=N16Pdu SessionHsmf UpdateReq
N16PduSessionHsmf UpdateReqClient
FIELD-COUNT M
STATUS M
STATUS-CODE O
IMEI/PEI O
REQUEST- INDICATION M RequestIndication
VCNTUNNEL-INFO O TUNNEL-INFO
SERVING-PLMN O
AN-TYPE O AccessType
RAT-TYPE O
CAUSE O
VGMM-CAUSE O
ALWAYS-ON O
EPS-IWK O
AN-TYPE-CAN -BE-CHANGED O
N1-REQ-MSG-TYPE O
PDU_SESSION_ MODIFICATION _REQUEST
PDU_SESSION_ RELEASE_REQUEST
N1-RSP-MSG-TYPE O
N1-PDU-SESS-ID O
N1-PCO O
N1-REQ-ALWAYS-ON O
N1-QOS-RULES O
N1-QOS-DESC O
12
PROCEDURE ID
EVENT-ID=1000 VERSION M Event=META DATA
FIELD-COUNT M
SUPI M
IMEI/PEI M
IMSI M
MSISDN M
GPSI
SERVING-PLMN M
UE-LOCATION M UE-LOCATION
START-TIME M
END-TIME M
TRIGGER-NF M
TRIGGER-EVENT M
SGW-ID O
STATUS M
USERPLANE- STATUS O Userplane-status
DISCONNECT -REASON O
DNN/APN M
RAT-TYPE M
UE-TIMEZONE M
PDU/PDN-SESSION -TYPE M
UE-PLMN M
SUBSCRIBED-SESS -AMBR-UPLINK M
SUBSCRIBED-SESS -AMBR-DOWNLINK M
SUBSCRIBED-5QI M
SUBSCRIBED-ARP M
PAA M
LOCAL-SEID M
REMOTE-SEID M
ROAMING-STATUS M
PDU/PDN-SESSION -ID O
ALWAYS-ON O
EPS-IWK O
S-NSSAI O
MAX-SUPP- FILTERS O
SSC-MODE O
UE-TYPE O
LOCAL-CFTEID- TEID O
LOCAL-CFTEID -IP O
REMOTE-CFTEID- TEID O
REMOTE-CFTEID -IP O
VIRTUAL-DNN/APN O
Table 7. PDU Session Modify Events
Attribute Name Presence Description
TIME-STAMP EVENT-ID1=1290 PROCEDURE-ID M N11SmContextUpdateReq
EVENT-LIST VERSION M
PduSessionModification Request (MESSAGE-ID=201)
5G-SM-CAP
MAX-SUPP-FILTERS
PCO
ALWAYS-ON
QOS-RULE
QOS-DESC
CAUSE
FIELD-COUNT M
STATUS M
STATUS-CODE O
SUPI M
IMEI M
IMSI M
MSISDN M
PDU(PDN)-SESSION -TYPE O
N1-PCO NA PCO
CAUSE O
N1-ALWAYS-ON O
5G-SM-CAP O
N1-RSP-MAX-SUPP -FILTERS O
RAT-TYPE O
UP-CONTEXT-STATE O
HO-STATE O
N1-BACKOFF-TIME NA
N1-PDU-SESS-ID M
N1-VGSM-RE- ATTEMPT-IND NA
N1-RE-ATTEMPT-IND NA
N1-SESS-AMBR O
N1-RSP-ALWAYS-ON NA
DATAFORWARDING O
EVENT-ID PROCEDURE-ID M N10UpdateNotifyReq
VERSION M
FIELD-COUNT M
STATUS M
STATUS-CODE O
PDU(PDN)-SESSION -TYPE M
CAUSE O
EVENT-ID4=1299 PROCEDURE-ID M N11N1N2Message TransferReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
PDU-SESSION-TYPE M
N1MSGREQTYPE O N1N2MSGREQ CONTENT
N2MSGREQTYPE O N1N2MSGREQ CONTENT
N1-PCO O PCO
CAUSE O
N1-ALWAYS-ON O
N1-PAA O PAA
N1-S-NSSAI O NSSAI
N1-PDU-SESS-ID
N1-DNN/APN O
N1-BACKOFF-TIME NA
N1-REQ-PDU(PDN) -SESSION-TYPE -SELECTED O
N1-SSC-MODE-ALLOWED O
N1-RSP-RE- ATTEMPT-IND NA
N1-RSP-AN-TYPE NA
PROCEDURE-ID EVENT-ID VERSION M
Event=N16PduSession HsmfUpdateReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
IMEI/PEI O
REQUEST-INDICATION M RequestIndication
SERVING-PLMN O
RAT-TYPE O
HO-PREP-INDICATION O
CAUSE O
VGMM-CAUSE O
ALWAYS-ON O
EPS-IWK O
AN-TYPE-CAN-BE -CHANGED O
N1-PDU-SESS-ID O
N1-PCO O
N1-RSP-MAX- SUPP-FILTERS- REQUESTED O
N1-ALWAYS-ON O
N1-QOS-RULES O
N1-QOS-DESC O
N16PduSessionVsmf UpdateReqClient
FIELD-COUNT M
STATUS M
STATUS-CODE O
REQUEST-INDICATION O N1N2MSGREQ CONTENT
SESSION-AMBR O N1N2MSGREQ CONTENT
ALWAYS-ON-GRANTED O RequestIndication
CAUSE O SESS-AMBR
N1SM-CAUSE O
BACKOFF-TIMER O
N1-REQ-MSG-TYPE O
PDU_SESSION_ MODIFICATION_ COMMAND_REJECT
N1-RSP-MSG-TYPE
PDU_SESSION_ MODIFICATION_REJECT
N1-PCO O
N1-QOS-RULE O
N1-QOS-DESC O
N1-PDU-SESS-ID O
N1-ALWAYS-ON O
N1-SESSION-AMBR O
N11N1N2MessageTransfer FailNotificationReq
RadiusAcctReq
N40ChargingData CreateReq
N40ChargingData UpdateReq
N40ChargingData ReleaseReq
N11EbiAssignmentReq
N7SmPolicyUpdate NotifyReq
N7SmPolicyUpdateReq
VERSION M
FIELD-COUNT M
STATUS M
STATUS-CODE O
PDU-SESSION-TYPE O
CAUSE O
EVENT-ID1=1000 PROCEDURE-ID M META-DATA
VERSION M
FIELD-COUNT M
SUPI M
IMEI/PEI M
IMSI M
MSISDN M
GPSI M
SERVING-PLMN M
UE-LOCATION M
START-TIME M
END-TIME M
TRIGGER-NF M
TRIGGER-EVENT M
USERPLANE-STATUS M
SGW-ID O
DISCONNECT-REASON NA
STATUS M
ALWAYS-ON O
MAX-SUPP-FILTERS O
LOCAL-CFTEID-TEID O
LOCAL-CFTEID-IP O
REMOTE-CFTEID-TEID O
REMOTE-CFTEID-IP O
Table 8. PDU Session Delete Events
Number
TXN EDR fields M
EVENT=N11Sm ContextReleaseReq
N7SmPolicy TerminateNotifyReq
RadiusAcctReq
N10Update NotifyReq
S5S8DeleteSessReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
CAUSE O
PROCEDURE ID
EVENT-ID VERSION M Event=N11SmContext UpdateReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
SUPI M
IMEI M
IMSI M
MSISDN M
pdu_session_ modification _complete
pdu_session_ modification_complete
N1-PCO NA PCO
CAUSE O
N1-ALWAYS-ON O
5G-SM-CAP O
RAT-TYPE O
UP-CONTEXT-STATE O
HO-STATE O
N1-BACKOFF-TIME NA
N1-PDU-SESS-ID O
N1-SESS-AMBR O
N1-RSP-ALWAYS -ON NA
DATAFORWARDING O
PROCEDURE ID
FIELD-COUNT M
STATUS M
STATUS-CODE O
PDU-SESSION-TYPE M
N1-RSP-MSG-TYPE N1N2MSGREQ CONTENT
N2-RSP-MSG-TYPE N1N2MSGREQ CONTENT
N1-PCO O PCO
CAUSE O
N1-ALWAYS-ON O
N1-PAA O PAA
N1-S-NSSAI O NSSAI
N1-PDU-SESS-ID
N1-DNN/APN O
N1-BACKOFF-TIME NA
N1-REQ-PDU(PDN)- SESSION-TYPE -SELECTED O
N1-SSC-MODE- ALLOWED O
N1-RSP-AN-TYPE NA
FIELD-COUNT M
STATUS M
STATUS-CODE O
IMEI/PEI O
SERVING-PLMN O
RAT-TYPE O
CAUSE O
VGMM-CAUSE O
ALWAYS-ON O
EPS-IWK O
AN-TYPE-CAN- BE-CHANGED O
N1-PDU-SESS-ID O
N1-PCO O
N1-ALWAYS-ON O
N1-QOS-RULES O
N1-QOS-DESC O
FIELD-COUNT M
STATUS M
STATUS-CODE O
REQUEST- INDICATION O N1N2MSGREQ CONTENT
CAUSE O SESS-AMBR
N1SM-CAUSE O
BACKOFF-TIMER O
N1-REQ-MSG-TYPE O
N1-RSP-MSG-TYPE O
N1-PCO O
N1-QOS-RULE O
N1-QOS-DESC O
N1-PDU-SESS-ID O
N1-ALWAYS-ON O
N1-SESSION-AMBR O
6
PROCEDURE ID
EVENT-ID VERSION M
Event= N16Vsmf PduSession ReleaseReq
FIELD-COUNT M
STATUS O
STATUS-CODE O
CAUSE O
VGMM-CAUSE O
NGAP-CAUSE O
7
PROCEDURE ID
EVENT-ID VERSION M
Event=N16Pdu SessionNotify ReqClient
FIELD-COUNT M
STATUS M
STATUS-CODE O
RESOURCE-STATUS O Resourcestatus
CAUSE O
8
PROCEDURE ID
EVENT-ID VERSION M Event=S5S8Delete BearerReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
LBI-REQUESTED O
EBIS O
FAILED-BEARER -CTX O BEARER-CTX
CAUSE-REQUESTED O
PCO O
CAUSE-RESPONDED O
LBI-RESPONDED O
UE-LOCAL-IP O
UE-UDP-PORT O
BEARER-CTX O
PROCEDURE ID EVENT-ID=1000 VERSION M Event= META-DATA
FIELD-COUNT M
SUPI M
IMEI/PEI M
IMSI M
MSISDN M
GPSI
SERVING-PLMN M
UE-LOCATION M
START-TIME M
END-TIME M
TRIGGER-NF M
TRIGGER-EVENT M
SGW-ID O
STATUS M
USERPLANE -STATUS M
STATUS M
UPDATE-TIME
Table 9. Dedicated Bearer Events
TXN EDR fields M
PROCEDURE ID
EVENT-ID VERSION M
Event=N7SmPolicy UpdateNotifyReq
N10UpdateNotify Req
FIELD-COUNT M
STATUS M
STATUS-CODE O
PDU-SESSION -TYPE O
CAUSE O
PROCEDURE ID
EVENT-ID VERSION M Event=S5S8Delete BearerCmd
FIELD-COUNT M
STATUS M
STATUS-CODE O
BEARER-CTX- REQUESTED O BEARER-CTX
CAUSE O
BEARER-CTX- RESPONDED O BEARER-CTX
RECOVERY O
PROCEDURE ID
EVENT-ID VERSION M Event= S5S8Bearer ResourceCmd
FIELD-COUNT M
STATUS M
STATUS-CODE O
LBI-REQUESTED O
RAT-TYPE O
SERVING-PLMN O
EBI O
PROCEDURE ID
EVENT-ID VERSION M Event=S5S8Modify BearerCmd
FIELD-COUNT M
STATUS M
STATUS-CODE O
APN-AMBR O
BEARER-CTX O BEARER-CTX
CAUSE O
RECOVERY O
PROCEDURE ID
EVENT-ID VERSION M Event=S5S8Update BearerReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
AMBR O
CAUSE O
RECOVERY O
PROCEDURE ID
EVENT-ID VERSION M Event=S5S8Create BearerReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
LINKED-BEARER -ID O
PCO O
CAUSE O
PROCEDURE ID
FIELD-COUNT M
STATUS M
STATUS-CODE O
LBI-REQUESTED O
EBIS O
CAUSE- REQUESTED O
PCO O
CAUSE- RESPONDED O
LBI-RESPONDED O
UE-LOCAL-IP O
UE-UDP-PORT O
BEARER-CTX O
PROCEDURE ID
EVENT-ID VERSION M Event=Metadata
FIELD-COUNT M
STATUS M
STATUS-CODE O
SUPI M
IMEI/PEI O
IMSI M
MSISDN O
GPSI O
SERVING-PLMN O
UE-LOCATION O
START-TIME O
END-TIME O
TRIGGER-NF O
TRIGGER-EVENT O
SGW-ID O
STATUS O
SUBSCRIBED-SESS -AMBR-UPLINK O
SUBSCRIBED-SESS -AMBR-DOWNLINK O
LOCAL-CFTEID -TEID O
LOCAL-CFTEID -IP O
REMOTE-CFTEID -TEID O
REMOTE-CFTEID -IP O
Table 10. Handover Events
TXN EDR fields M
RadiusAcctReq
S5S8Delete SessReq
N11EbiAssignment Req
N11SmContextStatus NotifyReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
CAUSE O
PROCEDURE ID
FIELD-COUNT M
STATUS M
STATUS-CODE O
SUPI M
IMEI/PEI M
IMSI M
MSISDN M
N1-PCO NA PCO
CAUSE O
N1-ALWAYS-ON O
5G-SM-CAP O
RAT-TYPE O
UP-CONTEXT -STATE O
HO-STATE O Hostate
N1-BACKOFF-TIME NA
N1-PDU-SESS-ID O
N1-SESS-AMBR O
N1-CONG-RE-ATTEMPT -IND O
N1-RSP-ALWAYS-ON NA
DATAFORWARDING O
PROCEDURE ID
FIELD-COUNT M
STATUS M
STATUS-CODE O
PDU-SESSION-TYPE M
N1-RSP-MSG-TYPE O N1N2MSGREQ CONTENT
N2-RSP-MSG-TYPE O N1N2MSGREQ CONTENT
N1-PCO O PCO
CAUSE O
N1-ALWAYS-ON O
N1-PAA O PAA
N1-S-NSSAI O NSSAI
N1-PDU-SESS-ID O
N1-DNN/APN O
N1-BACKOFF-TIME NA
N1-RSP-AN-TYPE NA
PROCEDURE ID
FIELD-COUNT M
SUPI M
IMEI/PEI M
IMSI M
MSISDN M
GPSI M
STATUS M
STATUS-CODE O
PCO O PCO
PDU-SESSION-TYPE O
SSC-MODE O
DNN/APN O
QOS-RULE O QOS-RULE
QOS-DESC O QOS-DESC
CAUSE O
PAA O PAA
S-NSSAI O NSSAI
RAT-TYPE M
HO-INDICATION
O
PROCEDURE ID
FIELD-COUNT M
STATUS M
STATUS-CODE O
AMBR O
CAUSE O
RECOVERY O
PROCEDURE ID
FIELD-COUNT M
STATUS M
STATUS-CODE O
LINKED-BEARER -ID O
PCO O
CAUSE O
PROCEDURE ID
FIELD-COUNT M
STATUS M
STATUS-CODE O
LBI-REQUESTED O
EBIS O
CAUSE-REQUESTED O
PCO O
CAUSE-RESPONDED O
LBI-RESPONDED O
UE-LOCAL-IP O
UE-UDP-PORT O
BEARER-CTX O
PROCEDURE ID
FIELD-COUNT M
STATUS M
STATUS-CODE O
CAUSE O
RECOVERY O
PROCEDURE ID
EVENT-ID VERSION M Event=S5S8Modify BearerReq
FIELD-COUNT M
STATUS M
STATUS-CODE O
MEI O
SERVING-PLMN O
RAT-TYPE
O
FQ_TEID O
AMBR- REQUESTED O
MME-S4SGSN-ID O
M-MBR O
UE-LOCAL-ADDR O
HENB-LOCAL -ADDR O
UE-UDP-PORT O
CAUSE O
RECOVERY O
LINKED-EBI O
MSISDN O
AMBR-RESP O
APN-RESTRICT O
N16PduSession HsmfUpdate ReqClient
FIELD-COUNT M
STATUS M
STATUS-CODE O
IMEI/PEI O
SERVING-PLMN O
RAT-TYPE O
CAUSE O
VGMM-CAUSE O
ALWAYS-ON O
EPS-IWK O
N1-REQ-MSG-TYPE O
N1-RSP-MSG-TYPE O
N1-PDU-SESS-ID O
N1-PCO O
N1-REQ-ALWAYS-ON O
N1-QOS-RULES O
N1-QOS-DESC O
PROCEDURE ID
EVENT-ID VERSION M
FIELD-COUNT M
SUPI O
IMEI/PEI O
GPSI O
GUAMI O GUAMI
STATUS M
STATUS-CODE O
DNN/APN M
RAT-TYPE O
S-NSSAI O NSSAI
VSMF-ID M
PGW-S8-CFTEID O
ALWAYS-ON- REQUESTED O
SSC-MODE O
UE-IPV4-ADDRESS O
UE-IPV6-PREFIX O
ROAMING-CHRG- PROF-SELECTED O CHARGING- PROF
CAUSE O
N1SM-CAUSE O
UE-IPV6- INTERFACE-ID O
N2-REQ-MSG-TYPE O
N2-RSP-MSG-TYPE O
N1-PDU-SESS-ID O
N1-REQ-PDU(PDN) -SESSION-TYPE O
N1-REQ-SSC-MODE O
N1-PCO O
N1-ALWAYS-ON O
N1-QOS-RULES O
N1-QOS-DESC O
N1-SESS-AMBR O
N1-REQ-ALWAYS -ON O
N1-DNN/APN O
PROCEDURE ID
FIELD-COUNT M
SUPI M
IMEI/PEI M
IMSI M
MSISDN M
GPSI M
STATUS M
STATUS-CODE O
N1-REQ-PDU(PDN) -SESSION-TYPE O PduSessionType
N1-REQ-SSC-MODE O
CAUSE O
N1-PCO O PCO
N1-REQ-MSG-TYPE O N1N2MSGREQ CONTENT PDU-SESSION -ESTB-REQUEST
N1-ALWAYS-ON O
RAT-TYPE M
GUAMI O
REQUEST-TYPE O
AN-TYPE O
OLD-PDU-SESS-ID O
N1-DNN/APN O
SERVING-NFID O
SERVING-PLMN O
UNAUTH-SUPI O
S-NSSAI- ASSIGNED O NSSAI
UP-CONTEXT -STATE O
N1-PDU-SESS -ID O
INDIRECTFWDFLAG O
DIRECTFWDFLAG O
HO-STATE
O
PROCEDURE ID
FIELD-COUNT M
SUPI M
IMEI/PEI O
IMSI M
MSISDN O
GPSI O
SERVING-PLMN O
UE-LOCATION O
START-TIME O
END-TIME O
TRIGGER-NF O
TRIGGER-EVENT O
SGW-ID O
STATUS O
RAT-TYPE O
UE-TIMEZONE O
SESS-AMBR- UPLINK O
SESS-AMBR- DOWNLINK O
LINKED-EBI O
USERPLANE- STATUS O
LOCAL-CFTEID -IP O
REMOTE-CFTEID -IP O
NOTES:
  • subscribed-sess-ambr-uplink and subscribed-sess-ambr-downlink: These fields are captured in the metadata event for some of the procedures. The values for these fields are printed as saved in pducontext. Bitrates in the metadata event are without any unit such as bps, kbps, or mbps. The default bitrate is read as bits per second (bps).
  • Status: In event METADATA (id = 1000), this field indicates the status of the procedure. For other events, it indicates the type of received response message or intended outgoing response type. The status can be one of the following:
    • Success
    • Failed
    • PartialFailure
    • NoRspValidation: This status is used in case the request is sent in ASYNC (fire and forget) mode and the response is neither expected nor processed in SMF.
  • Status-code: This field indicates HTTP status-code of the response message. This field should be empty for outgoing response messages as smf-service is unaware of the actual status-code filled by rest-ep. In such cases, the status field indicates the response type that SMF intended to send, such as success or failure response.
  • Userplane-status is of type number. The number can be one of the following:
    • UpStateNone = 0
    • UpStateEstablishing = 1 // UPF Session is being established or setup
    • UpStateActivating = 2 // UPF Session is being modified to Activate Access Tunnel
    • UpStateActivated = 3 // UPF Session Active for Access & Core Tunnel
    • UpStateDeactivating = 4 // UPF Session is being modified to Deactivate Access Tunnel
    • UpStateDeactivated = 5 // UPF Session Deactivated for Access, valid Core Tunnel Only
    • UpStateModifying = 6 // UPF Session is being modified for QoS or flow parameters
    • UpStateDeleting = 7 // UPF Session is being Released
    • UpStateDeleted = 8 // UPF Session is Released
  • PduSessionType is of type number. The number can be one of the following:
    • UnknownSessionType or Invalid = 0
    • Ipv4PduSession = 1
    • Ipv6PduSession = 2
    • Ipv4V6PduSession = 3
    • Unstrutured = 4
    • Ethernet = 5
    • FutureUsePduSessionType = 7
  • SSC mode is of type number. The number can be one of the following:
    • UnknownSscMode = 0
    • SscMode1 = 1
    • SscMode2 = 2
    • SscMode3 = 3
    • DupSscMode1 = 4
    • DupSscMode2 = 5
    • DupSscMode3 = 6
    • FutureUseSscMode = 7
  • Eps Iwk (Type: Number)
    • EpsInterworkingIndication_DummyEnum = 0
    • EpsInterworkingIndication_NONE = 1
    • EpsInterworkingIndication_WITH_N26 = 2
    • EpsInterworkingIndication_WITHOUT_N26 = 3
  • Roaming status (Type: Number)
    • ROAMING_STATUS_NONE = 0
    • ROAMING_STATUS_HOMER =1 //HOMER
    • ROAMING_STATUS_VISITOR_LBO =2 //LBO
    • ROAMING_STATUS_VISITOR_HR = 3 //IN-HR
    • ROAMING_STATUS_ROMER = 4 //OUT-HR
  • PreemptionCapability (type: Number)
    5G:
    • 0: "PreemptionCapability_DummyEnum"
    • 1: "NOT_PREEMPT"
    • 2: "MAY_PREEMPT"
    4G and Wi-Fi:
    • 0: Disabled
    • 1: Enabled
  • PreemptionVulnerability (type: Number)
    5G:
    • 0: "PreemptionVulnerability_DummyEnum"
    • 1: "NOT_PREEMPTABLE"
    • 2: "PREEMPTABLE"
    4G and Wi-Fi:
    • 0: Disabled
    • 1: Enabled
  • Disconnect-Reason (type: String)
    Disconnect-Reason contains a self-explanatory string. If it holds a number, then the string interpretation is as follows:
    • PduRelReason_Error = 1
    • PduRelReason_SessIdleTimeout = 2
    • PduRelReason_SessCpIdleTimeout = 3
    • PduRelReason_SessAbsoluteTimeout = 4
  • RequestType (type: Number)
    • RequestType_DummyEnum = 0
    • INITIAL_REQUEST = 1
    • EXISTING_PDU_SESSION = 2
    • INITIAL_EMERGENCY_REQUEST = 3
    • EXISTING_EMERGENCY_PDU_SESSION = 4
  • RequestIndication (type: Number)
    • RequestIndication_DummyEnum = 0
    • UE_REQ_PDU_SES_MOD = 1
    • UE_REQ_PDU_SES_REL = 2
    • PDU_SES_MOB = 3
    • NW_REQ_PDU_SES_AUTH = 4
    • NW_REQ_PDU_SES_MOD = 5
    • NW_REQ_PDU_SES_REL = 6
    • EBI_ASSIGNMENT_REQ = 7
  • AccessType (type: Number)
    • AccessType_DummyEnum = 0
    • AccessType_3GPP_ACCESS = 1
    • AccessType_NON_3GPP_ACCESS AccessType = 2
  • PartialRecordMethod (type: Number)
    • PartialRecordMethod_DummyEnum = 0
    • DEFAULT = 1
    • INDIVIDUAL = 2
  • TriggerCategory (type : Number)
    • TriggerCategory_DummyEnum = 0
    • IMMEDIATE_REPORT = 1
    • DEFERRED_REPORT = 2
  • TriggerType (type: Number)
    • TriggerType_DummyEnum = 0
    • QUOTA_THRESHOLD = 1
    • QHT = 2
    • FINAL = 3
    • QUOTA_EXHAUSTED = 4
    • VALIDITY_TIME = 5
    • OTHER_QUOTA_TYPE = 6
    • FORCED_REAUTHORISATION = 7
    • UNUSED_QUOTA_TIMER = 8
    • UNIT_COUNT_INACTIVITY_TIMER = 9
    • ABNORMAL_RELEASE = 10
    • QOS_CHANGE = 11
    • VOLUME_LIMIT = 12
    • TIME_LIMIT = 13
    • PLMN_CHANGE = 14
    • USER_LOCATION_CHANGE = 15
    • RAT_CHANGE = 16
    • UE_TIMEZONE_CHANGE = 17
    • TARIFF_TIME_CHANGE = 18
    • MAX_NUMBER_OF_CHANGES_IN_CHARGING_CONDITIONS = 19
    • MANAGEMENT_INTERVENTION = 20
    • CHANGE_OF_UE_PRESENCE_IN_PRESENCE_REPORTING_AREA = 21
    • CHANGE_OF_3GPP_PS_DATA_OFF_STATUS = 22
    • SERVING_NODE_CHANGE = 23
    • REMOVAL_OF_UPF = 24
    • ADDITION_OF_UPF = 25
    • START_OF_SERVICE_DATA_FLOW = 26
    • AMBR_CHANGE = 27
  • Resourcestatus (type: Number)
    • DummyEnum = 0
    • RELEASED = 1
  • HoState (type: Number)
    • DummyEnum = 0
    • NONE = 1
    • PREPARING = 2
    • PREPARED = 3
    • COMPLETED = 4
    • CANCELLED = 5
For details on the listed attributes, see the tables in the EDR Attributes section.
Procedure EDR Example:
V1,15,28514,10:36.1,97,imsi-310310120106401,1287,N11SmContextCreateReq,imsi-310310120106401:5,,roaming-status:homer|ue-type:nr-capable|supi:imsi-310310120106401
|gpsi:msisdn-12000006001|pei:imeisv-1031014232100100|psid:5|snssai:001|dnn:fast.t-mobile.com|emergency:false|rat:nr|access:3gpp access|connectivity:5g|udm-uecm:10.178.118.192
|udm-sdm:10.178.118.192|auth-status:unauthenticated,success,success,PDU Session Establishment,N11SmContextCreateReq,Active,init_done|SETUP: Idle|SETUP: Await UDM Registration|
SETUP: Await UDM Subscription Fetch|finished,3,1287,V2,33,imsi-310310120106401,imeisv-1031014232100100,3.1031E+14,12000006001,msisdn-12000006001,Success,,2,1,,,193|,,,,,,,NR,
1|||,0100BC|310|310,1,1,,fast.t-mobile.com,3ca4528c-851d-4728-856c-1b186ec992e5,310|310,0,,,5,0,0,3,1313,V2,4,Success,201,2,,3,1316,V2,4,Success,200,2,,3,1319,V2,4,Success,201,
2,,,,,,,,,,,,,,,,,,,,,,,,,
V1,15,28528,12:11.5,96,imsi-310310120106401,1304,N11SmContextReleaseReq,imsi-310310120106401:5,imsi-310310120106401:fast.t-mobile.com,snssai:001|emergency:false|peerGtpuEpKey:
10.193.123.12:172.18.90.205|namespace:smf,success,success,PDU Session Release - AMF initiated,N11SmContextReleaseReq,Active,init_done|RELEASE: Idle|RELEASE: Await UPF Release|
prepone_response|prepone_response|RELEASE: Await Charging Terminate|RELEASE: Await PCF Delete|RELEASE: Await UDM Unsubscribe to notify|finished,4,530,V2,4,Success,,2,Request_Accepted,
4,1304,V2,4,Success,,2,,4,3335,V2,4,Success,204,2,,4,1325,V2,4,Success,204,2,,4,1000,V2,15,imsi-310310120106401,imeisv-1031014232100100,3.1031E+14,12000006001,msisdn-12000006001,310|
310,NR|Ncgi:310;310;0147AD5C2|Tai:310;310;025289,2022-09-01 20:12:11.545199056 +0000 UTC,2022-09-01 20:12:11.631685285 +0000 UTC,amf,1304,,Success,8,disc_pdurel_amf_init_release,,
In the preceding example, the initial entries represent the transaction EDRs and last part provided here represents the procedure-level EDRs.
EDR Transaction Collision
This EDR file dumps the transaction collision information whenever the collision occurs. It is useful to debug collision scenarios.
Note
The transaction collision EDRs support only up to a maximum of 10 subscribers and not all subscribers unlike the transaction EDRs. The transaction collision EDRs do not support configuration of EDR generation rate, CPU threshold, session limiting, and procedure or event information.
Table 11. EDR Transaction Collision File Fields
Field Number
Field Name
Field Description
Subscriber ID
Collision Time
Collision time in yyyy/MM/dd HH:mm:ss.SSS format.
Force Resolution
Indicates whether the resolution is forced (true/false).
Collision Cause
The cause of collision.
New Transactions Before Collision
Transactions in the new state before collision handling separated by |.
6
Pending Transactions Before Collision
Transactions in the pending state before collision handling separated by |.
7
Active Transactions Before Collision
Transactions in the active state before collision handling separated by |.
8
Suspended Transactions Before Collision
Transactions in the suspended state before collision handling separated by |.
9
New Transactions After Collision
Transactions in the new state after collision handling separated by |.
Pending Transactions After Collision
Transactions in the pending state after collision handling separated by |.
11
Active Transactions After Collision
Transactions in the active state after collision handling separated by |.
12
Suspended Transactions After Collision
Transactions in the suspended state after collision handling separated by |.
13
Aborted Transactions After Collision
Transactions in the aborted state after collision handling separated by |.
supi:imsi-123456789012345,2020/10/06 16:15:11.801,true,SessionLockSamePriority,17,,,,,,|17,,
supi:imsi-123456789012345,2020/10/06 16:15:11.824,true,SessionLockSamePriority,18,,,,,,|18,,
supi:imsi-123456789012345,2020/10/06 16:15:11.857,true,SessionLockSamePriority,19,,,,,,|19,,
supi:imsi-123456789012345,2020/10/06 16:15:11.883,true,SessionLockSamePriority,20,,,,,,|20,,
supi:imsi-123456789012345,2020/10/06 16:15:11.888,true,SessionLockRelease,,,,,,,,,x
EDR Attributes
This section provides details of the EDR attributes and its sub attributes.
Table 12. QOS-RULE
QOS-RULE-LIST qr-id|qr-opcode|qr-dqr|qr-qfi|qr-prededence|num-filters| filters:flter-id;flter-dir;cmp-type-match-all; cmp-type-proto;proto-id;cmp-type-local-addr;local-ip; local-port;cmp-type-remote-addr;;remote-ip;cmp-type-remote-port; remote-port;cmp-type-tos;tos-trffic-class
Field Sub field Sub-sub field Presence
QOS-RULE
QOS-RULE-ID M
QOS-RULE-OPCODE M
QOS-RULE-DQR M
QOS-RULE-QFI M
QOS-RULE- PRECEDENCE M
NO-PKT-FILTERS
PKT-FILTER-LIST O
PKT-FILTER-ID M
PKT-FILTER- DIRECTION M
CMP-TYPE- MATCH-ALL O
CMP-TYPE-PROTO O
PROTO-ID O
CMP-TYPE- LOCAL -ADDRESS O
LOCAL-IP-ADDRESS O
LOCAL-CMP- TYPE-PORT O
LOCAL-PORT O
CMP-TYPE- REMOTE- ADDRESS O
REMOTE-IP- ADDRESS O
CMP-TYPE- REMOTE-PORT O
REMOTE-PORT O
CMP-TYPE-TOS O
TOS-TRAFFIC-CLASS O
Note
Delimiters subject to change based on the position of QOS-RULE in the attribute.
Table 13. QOS-DESC
QOS-DESC [qfi|opcode|5qi|arp|mbr-ul|mbr-dl|gbr-ul|gbr-dl]
Sub field Type Presence
QFI M
Opcode M
5QI O
ARP ARP O
MBR-UPLINK O
MBR-DOWNLINK O
GBR-UPLINK O
GBR-DOWNLINK O
Note
Delimiters subject to change based on the position of QOS-DESC in the attribute.
Table 14. PCO
PCO
[type|PCSCF-ADDR-LIST|DNS-ADDR-LIST| pdu-session-id|QOS-RULE-LIST|SESSION-AMBR| QOS-DESC|S-NSSAI|ms-support-nw_addr-tft|nw-support-nw_addr-tft| PCSCF-ADDR-REQ|DNS-ADDR-REQ|mtu-req|mtu-size]
Sub field
Type
Presence
TYPE String M EPCO or PCO or APCO
PCSCF-ADDR-LIST PCSCF-ADDR O From CSR Response being sent from SMF
DNS-ADDR-LIST DNS-ADDR O From CSR Response being sent from SMF
PDU-SESSION-ID O From CSR Response being sent from SMF
QOS-RULE-LIST QOS-RULE O From CSR Response being sent from SMF
SESSION-AMBR SESS-AMBR O From CSR Response being sent from SMF
QOS-DESC QOS-DESC O From CSR Response being sent from SMF
S-NSSAI NSSAI O From CSR Response being sent from SMF
MS-SUPPORT-NW_ADDR-TFT Boolean O From CSR Request being received
NW-SUPPORT-NW_ADDR-TFT Boolean O From CSR Response being sent from SMF
PCSCF-ADDR-REQ PCSCF-ADDR-REQ O From CSR Request being received
DNS-ADDR-REQ DNS-ADDR-REQ O From CSR Request being received
IPV4-MTU-REQUEST Boolean O From CSR Request being received
IPV4-MTU-SIZE String O From CSR Response being sent from SMF
Note
In the preceding table, CSR Request and CSR Response messages refer to 4G and Wi-Fi call flows. N11 SM Context Create Request and Response messages refer to 5G call flows.
Table 15. PCSCF-ADDR-REQ
PCSCF-ADDR-REQ
[pco-pcsf-addr-ipv4-req;pco-pcsf-addr-ipv6-req]
Sub field
Presence
Type
PCO-PCSF-ADDR-IPV4-REQ
M
Boolean
PCO-PCSF-ADDR-IPV6-REQ
M
Boolean
Table 16. PCSCF-ADDR
PCSCF-ADDR
[ipv4-primary;ipv4-secondary;ipv4-tertiary;ipv6-primary;ipv6-secondary;ipv6-tertiary]
Sub field
Presence
Type
PCSF-ADDR-IPV4-LIST
O
List
PCSF-ADDR-IPV6-LIST
O
List
Table 17. DNS-ADDR
DNS-ADDR
Sub field
Presence
Type
DNS-ADDR-IPV4-LIST
O
List
DNS-ADDR-IPV6-LIST
O
List
Table 18. DNS-ADDR-REQ
DNS-ADDR-REQ
Sub field
Presence
Type
M
Boolean
M
Boolean
Table 19. NSSAI
NSSAI
[sst|sd|hplmnsst|hplmnsd]
Sub field
Presence
Type
SST
M
Number
SD
O
String
HPLMN-SST
O
Number
HPLMN-SD
O
String
Note
Delimiters subject to change based on the position of S-NSSAI in the attribute.
Table 20. PAA
PAA
[ipv4-addr|ipv6-addr]
Sub field
Presence
Type
IPV4-ADDR
O
String
IPV6-ADDR
O
String
Table 21. N1N2MSGREQCONTENT or N1N2MSGRSPCONTENT
N1N2MSGREQCONTENT / N1N2MSGRSPCONTENT
[msg-type|cause]
Sub field
Presence
Type
MSG-TYPE
M
SMF N1N2MsgType
Cause
O
String
Example: 195|REQUEST_REJECTED_UNSPECIFIED
Table 22. PLMN-ID
PLMN-ID
[mcc|mnc]
Sub field
Presence
MCC
M
MNC
M
Note
Delimiters subject to change based on the position of PLMN-ID in the parent attribute.
Table 23. GUAMI
GUAMI
[amf-id|plmn-id]
Sub field
Presence
Type
AMF-ID
M
String
PLMN-ID
M
PLMN-ID
Table 24. SESS-AMBR
SESS-AMBR
[ambr-dl|ambr-ul]
Sub field
Presence
Type
AMBR-DL
O
String
AMBR-UL
O
String
Table 25. UE-LOCATION
UE-LOCATION
[locationType|Ecgi: ECGI|Tai:TAI] or
[locationType|Ncgi: NCGI|Tai:TAI]
Sub field
Presence
Type
locationType
M
String
"Eutra" or "NR"
ECGI or NCGI
O
ECGI/NCGI
Tai
O
TAI
Table 26. ECGI or NCGI
ECGI / NCGI [plmn-id;cellId]
Sub field
Presence
Type
Plmn-id
M
PLMN-ID
Cell-id
M
String
Table 27. TAI
TAI
[plmn-id;tac]
Sub field
Presence
Type
Plmn-id
M
PLMN-ID
Tac
M
String
Table 28. ARP
ARP
[preEmpCap;preEmpVul;priority]
PRE-EMP-CAP
M
PRE-EMP-VUL
M
PRIORITY
M
Number
Note
Delimiters subject to change based on the position of ARP in the attribute.
Table 29. NGAP-CAUSE
NGAP-CAUSE
[group|value]
GROUP
O
Number
VALUE
O
Number
Table 30. TUNNEL-INFO
TUNNEL-INFO
[gtp-teid|ipv4-addr|ipv6-addr]
GTP-TEID
O
String
IPV4-ADDR
O
String
IPV6-ADDR
String
Table 31. QFS
QFS
[qos-rule|qos-desc]
Qos-rules
O
QOS-RULE
Qos-desc
O
QOS-DESC
Table 32. CHARGING-PROF
CHARGING-PROF
partial-rec-method|category:max-cc:time-limit;type:vol-limit
PARTIAL-REC-METHOD PartialRecordMethod
TRIGGERS-LIST TRIGGERS CATEGORY TriggerCategory
MAX-CCC
TIME-LIMIT
TYPE TriggerType
VOL-LIMIT
Table 33. BEARER-CTX
BEARER-CTX
[ebi|pkt-flow-id|cause|pco|tft|fqteid|qos-desc|charging-id]
Sub field
Presence
Type
EBI/LBI
M
PKT-FLOW-ID
O
CAUSE
O
PCO
O
PCO
TFT
O
FQTEID
O
QOS-DESC
O
QOS-DESC
CHARGING-ID
O
The SMF generates detailed records with field-level details per event. The following table lists the different N1N2 messages and the associated IDs.
Table 34. SMF N1N2 Message Types
MESSAGE MESSAGE-ID
PDU-SESSION-ESTB-REQUEST 193
PDU-SESSION-ESTB-ACCEPT 194
PDU-SESSION-ESTB-REJECT 195
PDU-SESSION-MOD-REQ 201
PDU-SESSION-MOD-CMD 203
PDU-SESSION-MOD-CMD-REJ 202
PDU-SESSION-MOD-CMD-COMP 204
PDU-SESSION-REL-REQ 209
PDU-SESSION-REL-CMD 211
PDU-SESSION-REL-REJ 210
PDU-SESSION-REL-COMP 212
N2_PDU_SESSION_RESOURCE_RELEASE_COMMAND 76
N2_PDU_SESSION_RESOURCE_RELEASE_RESPONSE 130
N2_PDU_SESSION_RESOURCE_SETUP_REQUEST 77
N2_PDU_SESSION_RESOURCE_SETUP_RESPONSE_TRANSFER 78
N2_PDU_SESSION_RESOURCE_MODIFY_CONFIRM_TRANSFER 62
N2_PDU_SESSION_RESOURCE_MODIFY_INDICATION_TRANSFER 63
N2_PDU_SESSION_RESOURCE_MODIFY_REQUEST_TRANSFER 64
N2_PDU_SESSION_RESOURCE_MODIFY_RESPONSE_TRANSFER 65
N2_PDU_SESSION_RESOURCE_MODIFY_UNSUCCESS_TRANSFER 79
N2_PDU_SESSION_HANDOVER_PREP_UNSUCCESS_TRANSFER 93
N2_PDU_SESSION_HANDOVER_COMMAND_TRANSFER 91
N2_PDU_SESSION_PATH_SWITCH_REQUEST_ACK_TRANSFER 84
N2_PDU_SESSION_PATH_SWITCH_REQUEST_ UNSUCCESS_TRANSFER 97
N2_PDU_SESSION_PATH_SWITCH_REQUEST_TRANSFER 82
N2_PDU_SESSION_HANDOVER_REQUIRED_TRANSFER 85
N2_PDU_SESSION_HANDOVER_REQUEST_ACK_TRANSFER 87
N2_PDU_SESSION_HANDOVER_RESOURCE_ ALLOC_UNSUCCESS_TRANSFER 89
N2_PDU_SESSION_PATH_SWITCH_REQUEST_ SETUP_FAILED_TRANSFER 95
N2_PDU_SESSION_RESOURCE_SETUP_UNSUCCESS_TRANSFER 99
N2_PDU_SESSION_RESOURCE_NOTIFY_TRANSFER 101
N2_PDU_SESSION_SECONDARY_RAT_USAGE_TRANSFER 103
N2_PDU_SESSION_RESOURCE_NOTIFY_RELEASED_TRANSFER 105
N2_PDU_SESSION_RESOURCE_SETUP_FAIL_TRANSFER 107
N2_PDU_SESSION_PATH_SWITCH_SETUP_FAIL_TRANSFER 109
N2_PDU_SESSION_HANDOVER_RESPONSE_ ALLOC_FAIL_TRANSFER 111
Limitations
The EDR Logging feature has the following limitations:
  • Event record generation does not work for the following scenarios:
    • All handover (HO) procedures except Xn HO, N2 HO, 5G to 4G HO, 4G to 5G HO, 5G to Wi-Fi HO, and Wi-Fi to 5G HO
    • Idle-Active transition
    • Active-Idle transition
    • 4G PDN modification
  • The SMF supports only IMSI (SUPI)-based EDR reporting.
  • The SMF currently supports EDR generation in CSV format. The EDR file storage format is not configurable.
  • This feature is not applicable to a procedure that does not send a response explicitly to an incoming request.
Configuring EDRs
This section describes how to configure the EDR Logging feature.
Configure EDR Reporting
Note
EDR generation occurs after you configure the subscriber ID. Then, you can enable EDR reporting for a specific subscriber or for all the subscribers. If you have enabled the EDR reporting for all the subscribers, then the SMF ignores the individual subscriber ID configuration.
Note
To optimize the performance, it is recommended to enable EDR reporting only for a subset of subscribers with specific procedure ID.
To enable or disable the EDR generation for subscribers, use the following sample configuration:
config
    edr reporting { enable [ all subscribers | file [ transaction | transaction-collision ] ] | disable file [ transaction | transaction-collision ] }
    edr all subscribers
    end
NOTES:
  • edr reporting { enable [ all subscribers | file [ transaction | transaction-collision ] ] | disable file [ transaction | transaction-collision ] } —Specify this keyword to configure the EDR reporting on SMF. Use the edr reporting enable command to enable the EDR reporting functionality. Use the edr reporting disablefile command to disable the EDR reporting functionality for a specific file. By default, the EDR reporting is disabled.
  • Use the edr reporting enable all subscribers command or edr all subscribers to enable the EDR for all the subscribers.
    Note
    • To enable EDR reporting for a subscriber, use the edr subscribers subscriber_id command. subscriber_id must be an alphanumeric string. The default value is empty. Ensure to specify the exact subscriber key in this command. The SMF supports only IMSI (SUPI)-based EDR reporting.
    • Configure a minimum of one subscriber upon enabling the EDR reporting.
    • You can configure a maximum of 10 subscribers for generation of transaction collision EDRs.
Use the following sample configuration to generate the EDR events at transaction level.
config
   edr file { transaction | transaction-collision }
      procedure-id procedure_value
         event-id event_value
            field-id field_value
            end
  • edr file { transaction | transaction-collision } : Specify to generate EDR files with transaction or transaction-collision level details for subscriber sessions.
  • procedure-id procedure_value : Specify the procedure ID or procedure name for which the event reporting must be enabled.
  • event-id event_value : Specify the event ID or event name for which the event reporting must be enabled.
  • field-id field_value : Specify the field ID or field name for which the event reporting must be enabled.
  • All procedure IDs, event IDs, and field IDs registered by application, are enabled by default.
  • If one or more procedures are enabled, then all the other procedures will be disabled and will not be populated in the transaction EDR. Similarly, if one or more events are enabled under a procedure, all other events under that procedure will be disabled and will not be populated in the transaction EDR.
  • If a procedure-id is disabled, no event start, add field, or event-end will be honored for the procedure-id.
  • If an event-id is disabled within a procedure id, then event-start, event-end, or add field will not be honored for the procedure-id and event-id combination.
  • If a field-id is disabled for an event-id, then add-field will not be honored, and a blank entry will be present instead of value in CSV entry.
Example Configuration:
edr file transaction
  procedure-id 24 32
  procedure-id 25
    event-id 5 7 8
    event-id 5
      field-id 10 12 14
In the preceding example, event-id 5 7 8 means enable the event-id 5, 7, and 8 for procedure-id 25. The field-id 10 12 14 means enable the field-id 10, 12, and 14 for procedure-id 25 and event-id 5.
To define the EDR parameters, use the following sample configuration:
config
      flush interval file_flush_interval
      limit [ size file_size | count file_count| storage edr_storage_size ]
      procedure procedure_value event event_value field field_value
      rate rate_value
      reporting [ disable | enable ]
      threshold [ cpu cpu_threshold | session session_thresold  ]
      end
NOTES:
  • flush interval file_flush_interval —Specify the time interval, in milliseconds, to flush the EDR files. The default value is 1000 ms.
  • limit [ size file_size | count file_count| storage edr_storage_size] —Specify the file-related limits.
    • Use the limit size file_size command to specify the maximum size of an EDR file, after which the EDR file is compressed and new CSV file is created. The default file size is 100 MB.
      The file_size must be an integer in the range of 1 to 2048.
      Note
      The system periodically monitors the file size of an EDR file once per second or after the configured flush interval, whichever value is higher. After the EDR file reaches its maximum size, it's compressed and new CSV file is created. However, in some scenarios, the data is being continuously written to the EDR file just before the system performs a periodic check based on the previously mentioned threshold limits. This results in an EDR file that might slightly exceed the configured maximum file size.
    • Use the limit count file_count command to specify the maximum number of EDR files to be preserved. The default file count is 10.
      The file_count must be an integer in the range of 2 to 128.
      When the configured file count is reached, the file is moved to persistent volume and then deleted.
    • Use the limit storage edr_storage_size command to specify the EDR storage size of persistent volume in GiB.
      The edr_storage_size must be an integer in the range of 1 to 24. The default storage size is 4 GiB.
      The edr_storage_size must be an integer in the range of 0 to 64. Set the value to 0 to disable persistent volume in edr-monitor pod. The default storage size is 24 GiB.
      Important
      The storage limit can be changed only in “system mode shutdown” mode. Hence, disabling of persistent volume can be done only when the system is in shutdown state.
  • procedure procedure_value event event_value field field_value —Specify the transaction-level procedure ID configuration information. The procedure_value must be a procedure ID or a procedure name. The event_value must be an event ID or an event name along with a field value.
    Note
    • By default, all the procedure IDs, event IDs, and field IDs, which are registered during the application-start, are enabled.
    • If one or more procedures are enabled, then all other procedures are disabled and are not populated in the transaction EDR.
    • If one or more events are enabled in a procedure, then all other events in that procedure are disabled and are not populated in the transaction EDR.
    • If one or more fields are enabled in an event, then all other fields in that event are disabled and are not populated in the transaction EDR.
    • For the disabled procedure IDs, no event-start, add field, or event-end are honored.
    • For the disabled event IDs in a procedure ID, no event-start, event-end, or add field are honored for the procedure ID and event ID combinaton.
    • For a disabled field ID within an event ID, no add-field is honored, and a blank entry is available instead of value in CSV entry.
  • rate rate_value —Specify the allowed rate per second to generate EDR records. The default rate value is 4096.
    rate_value must be an integer in the range of 32 to 65535.
    When the EDR generation rate limit is reached, transaction EDRs are dropped and a metric is added to track EDR generated, dropped, drop reason, and so on. Note that the rate limiting is performed per service (smf-service) pod instance.
  • reporting [ disable | enable ] —Specify the file for which you have to enable or disable reporting.
    Important
    The edr-monitor pods are spawned only when the transaction edr is enabled.
  • threshold [ cpu cpu_threshold | session session_thresold ] —Specify the threshold to limit the EDR generation.
    • Use the threshold cpu cpu_threshold command to configure the CPU threshold in percentage. If the threshold is breached for a SMF service pod instance, then the application stops generating EDRs. The cpu_threshold must be an integer in the range of 1 to 100, with default value of 80%.
    • Use the threshold session session_thresold command to configure session threshold per GR instance. If the threshold is breached for a GR instance, then the application stops generating EDRs. The session_thresold must be an integer in the range of 0 to 1,000,000, with default value of 100,000.
      Note
      If the rack is running with active-active mode, the session threshold is applied individually for both the GR instances.
Verifying EDR Transactions
Use the following show commands to display the currently registered procedures, events, and fields for the application along with their respective IDs.
show edr transaction-procedure procedure_id event event_id
show edr event event_id
You can provide all the procedures and events. Otherwise, you can provide a particular procedure name and event name or procedure-id and event-id.
Note
The show command output is based on the mapping registered by the application.
The following is an example of the show command output.
Procedure-id 20, Procedure-Name: xyz
    Event-id 1, Event-Name: abc
         1 – Field1-Name
         2 – Field2-Name
     Event-id 2, Event-Name: efgh
          1 – Field1-Name
          2 – Field2-Name
Procedure-id 21, Procedure-Name: bbbb
     Event-id 1, Event-Name: cccc
          1 – Field1-Name
          2 – Field2-Name
     Event-id 2, Event-Name: dddd
          1 – Field1-Name
          2 – Field2-Name
This output helps the operator to know current CSV format of a particular procedure-id and event-id pair.
OAM Support for EDR Logging
This section describes operations, administration, and maintenance information for this feature.
Bulk Statistics Support
The SMF maintains the following bulk statistics as part of this feature.
  • edr_error_total
    Labels:
    • error_code – The EDR writing error code
This metric is pegged whenever an error occurs during EDR writing. This metric displays "EdrQueueFull" as the error_code when the writing queue is full and the EDR is dropped.
Following metric is used to monitor the EDR count and status.
  • edr_total
    Labels:
    • name – Name of the transaction EDR.
    • status – Status of the EDR transaction if it is successful or has any errors.
    • status_code – The following status codes are supported:
      • EdrReportingDisabled
      • EdrTxnReportingDisabled
      • EdrSessThreshold
      • EdrCpuThreshold
      • EdrRateLimitExceeded
      • EdrFileWriteFailed
      • EdrInvalidEdrId
      • EdrQueueFull
      • EdrIgnored_NoEventRecorded
