smf-service Metrics Reference
CHF Notification Statistics Category
smf_chf_notification_stats
Description: SMF Charging CHF Notification stats
Sample Query: 'smf_chf_notification_stats{notification_type="reauthorization"}'
Labels:
Label:
notification_type
Label Description: Type of notification request
Example: reauthorization, abort_charging
Label:
dnn
Label Description: DNN for which the flow is created
Example: cisco.com
Label:
status
Label Description: Status of notify message processing
Example: attempted, success, failures
Label:
rat_type
Label Description: RAT type on which the flow is created
Example: EUTRA, NR, WLAN, VIRTUAL, rat_type_unknown
Label:
reason
Label Description: Reason for notify message failure
Example: pdu_session_not_established, charging_failed, offline_converted
Charging final unit indication statistics Category
chf_recieved_fui_stats
Description: Statistics for final unit indication with final unit action
Sample Query: 'sum (chf_recieved_fui_stats{interface_type="Gy"})'
Labels:
Label:
chf_type
Label Description: Type of CHF with which message is exchanged
Example: online, offline
Label:
interface_type
Label Description: Type of Interface communicate with PGW
Example: N40, Gy
Label:
fua_type
Label Description: Type of final unit action
Example: FinalUnitActionType_TERMINATE", "FinalUnitActionType_REDIRECT", "FinalUnitActionType_RESTRICT_ACCESS
Discover Messages Time statistics Category
nf_discover_total_time
Description: Discover Messages Total time statistics
Sample Query: 'nf_discover_total_time{nf_type="amf", host="http://10.105.227.109:8082/nnrf-nfm/v1", result="timeouOrRPCError"}'
Labels:
Label:
nf_type
Label Description: Network Function type
Example: nrf, udm, amf, pcf, chf, ciscocontrol
Label:
host
Label Description: End Point address
Example: http://10.105.227.109:8082/nnrf-nfm/v1
Label:
result
Label Description: result of discover message
Example: 200, 201, 204, success, timeout_rpc_error, response_parse_failure
Discover Messages statistics Category
nf_discover_messages_total
Description: Discover Messages statistics
Sample Query: 'nf_discover_messages_total{nf_type="amf", host="http://10.105.227.109:8082/nnrf-nfm/v1", result="timeouOrRPCError"}'
Labels:
Label:
nf_type
Label:
host
Label:
result
Dropped Charging Data Requests Statistics Category
cdr_dropped_stats
Description: The current count for charging data requests dropped due to zero usage
Sample Query: 'cdr_dropped_stats{procedure_type="pdu_sess_create"}'
Labels:
Label:
procedure_type
Label Description: The procedure type associated with an call flow procedure
Example: pdu_sess_create, ue_req_pdu_sess_mod, smf_req_pdu_sess_mod, pcf_req_pdu_sess_mod, udm_req_pdu_sess_mod, gnb_req_pdu_sess_mod, ue_req_pdu_sess_rel, smf_req_pdu_sess_rel, pcf_req_pdu_sess_rel, amf_req_pdu_sess_rel, udm_req_pdu_sess_rel, gnb_req_pdu_sess_rel, chf_req_pdu_sess_rel, admin_req_pdu_sess_rel, ue_req_active_to_idle, ue_req_idle_to_active, nw_req_service_active, upf_notify_downlink_data, xn_path_switch,pdn_sess_create,pdn_5g_4g_handover,pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, n2_handover, xn_handover, n26_4g_to_5g_handover, n26_4g_to_5g_im_mobility, pdu_im, pdn_sess_create, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, pcf_initiated_pdn_detach, smf_initiated_pdn_detach, upf_initiated_pdn_detach
GTPC Message stats Category
smf_gtpc_msg_stats
Description: Stats for GTPC interface messages
Sample Query: 'smf_gtpc_msg_stats{message_type="create_bearer_request"}'
Labels:
Label:
message_type
Label Description: GTPC Message Type
Example: delete_bearer_request, create_bearer_request, delete_bearer_request_async, suspend_notification, resume_notification, change_notification
Label:
status
Label Description: GTPC message status
Label:
reason
Label Description: The reason associated with failure
Example: ipc_failed, sgw_failure, EGTP_CAUSE_LOCAL_DETACH, EGTP_CAUSE_RAT_CHANGED_FROM_3GPP_TO_NON_3GPP, EGTP_CAUSE_COMPLETE_DETACH, EGTP_CAUSE_ISR_DEACTIVATION, EGTP_CAUSE_ERROR_IND_RCVD_RNC_ENODE, EGTP_CAUSE_IMSI_DETACH_ONLY, EGTP_CAUSE_REACTIVATION_REQUESTED, EGTP_CAUSE_PDN_RECONNECTION_TO_THIS_APN_DISALLOWED, EGTP_CAUSE_ACCESS_CHANGED_FROM_NON_3GPP_TO_3GPP, EGTP_CAUSE_PDN_CONN_INACTIVITY_TIMER_EXPIRED, EGTP_CAUSE_PGW_NOT_RESPONDING, EGTP_CAUSE_NETWORK_FAILURE, EGTP_CAUSE_QOS_PARAMETER_MISMATCH, EGTP_CAUSE_REQ_ACCEPTED, EGTP_CAUSE_REQ_ACCEPTED_PARTIALLY, EGTP_CAUSE_NEW_PDN_TYPE_NETWORK_PREFERENCE, EGTP_CAUSE_NEW_PDN_TYPE_SINGLE_ADDR_BEARER_ONLY, EGTP_CAUSE_CONTEXT_NOT_FOUND, EGTP_CAUSE_INVALID_MESSAGE_FORMAT, EGTP_CAUSE_VERSION_NOT_SUPPORTED_BY_NEXT_PEER, EGTP_CAUSE_INVALID_LENGTH, EGTP_CAUSE_SERVICE_NOT_SUPPORTED, EGTP_CAUSE_MANDATORY_IE_INCORRECT, EGTP_CAUSE_MANDATORY_IE_MISSING, EGTP_CAUSE_SYSTEM_FAILURE, EGTP_CAUSE_NO_RESOURCES_AVAILABLE, EGTP_CAUSE_SEMANTIC_ERROR_IN_TFT_OPERATION, EGTP_CAUSE_SYNTACTIC_ERROR_IN_TFT_OPERATION, EGTP_CAUSE_SEMANTIC_ERROR_IN_PKT_FILTERS, EGTP_CAUSE_SYNTACTIC_ERROR_IN_PKT_FILTERS, EGTP_CAUSE_MISSING_OR_UNKNOWN_APN, EGTP_CAUSE_UNEXPECTED_REPEATED_IE, EGTP_CAUSE_GRE_KEY_NOT_FOUND, EGTP_CAUSE_REALLOCATION_FAILURE, EGTP_CAUSE_DENIED_IN_RAT, EGTP_CAUSE_PREFERRED_PDN_TYPE_UNSUPPORTED, EGTP_CAUSE_ALL_DYNAMIC_ADDR_OCCPUPIED, EGTP_CAUSE_UE_CTX_WO_TFT_ALREADY_ACTIVATED, EGTP_CAUSE_PROTOCOL_TYPE_NOT_SUPPORTED, EGTP_CAUSE_UE_NOT_RESPONDING, EGTP_CAUSE_UE_REFUSES, EGTP_CAUSE_SERVICE_DENIED, EGTP_CAUSE_UNABLE_TO_PAGE_UE, EGTP_CAUSE_NO_MEMORY_AVAILABLE, EGTP_CAUSE_USER_AUTHENTICATION_FAILED, EGTP_CAUSE_APN_DENIED_NO_SUBSCRIPTION, EGTP_CAUSE_REQUEST_REJECTED, EGTP_CAUSE_PTMSI_SIGNATURE_MISMATCH, EGTP_CAUSE_IMSI_IMEI_NOT_KNOWN, EGTP_CAUSE_SEMANTIC_ERROR_IN_TAD_OPERATION, EGTP_CAUSE_SYNTACTIC_ERROR_IN_TAD_OPERATION, EGTP_CAUSE_RESERVED_MESSAGE_VALUE_RECEIVED, EGTP_CAUSE_PEER_NOT_RESPONDING, EGTP_CAUSE_COLLISION_WITH_NETWORK_INIT_REQUEST, EGTP_CAUSE_UNABLE_TO_PAGE_UE_DUE_TO_SUSPENSION, EGTP_CAUSE_CONDITIONAL_IE_MISSING, EGTP_CAUSE_INCOMPATIBLE_APN_REST_TYPE, EGTP_CAUSE_INVALID_LENGTH_WITH_PIGGYBACK_MSG, EGTP_CAUSE_DATA_FORWARDING_NOT_SUPPORTED, EGTP_CAUSE_INVALID_REPLY_FROM_REMOTE_PEER, EGTP_CAUSE_FALLBACK_TO_GTPV1, EGTP_CAUSE_INVALID_PEER, EGTP_CAUSE_TEMP_REJECTED_DUE_TO_HANDOVER_IN_PROGRESS, EGTP_CAUSE_REQ_REJECTED_FOR_PMIPV6_REASON, EGTP_CAUSE_APN_CONGESTION, EGTP_CAUSE_BEARER_HANDLING_NOT_SUPPORTED, EGTP_CAUSE_UE_ALREADY_REATTACHED, EGTP_CAUSE_MULTI_PDN_CONNECTION_FOR_APN_NOT_ALLOWED, EGTP_CAUSE_MME_SGSN_REFUSES_DUE_TO_VPLMN_POLICY, EGTP_CAUSE_GTPC_ENTITY_CONGESTION, EGTP_CAUSE_TARGET_ACCESS_RESTRICTED_FOR_THE_SUBSCRIBER, EGTP_CAUSE_UE_TEMP_NOT_REACHABLE_DUE_TO_POWER_SAVING, EGTP_CAUSE_RELOC_FAILURE_DUE_TO_NAS_MSG_REDIRECTION, EGTP_CAUSE_MISSING_TIMESTAMP_OPTION, EGTP_CAUSE_MULTIPLE_HNP_NOT_ALLOWED, EGTP_CAUSE_SN_MALFORMED_MSG, EGTP_CAUSE_INT_TIMEOUT, cbr_fail_upstate_inactive, ubr_fail_upstate_inactive, mbc_retransmit_msg, change_notification_retransmit_msg
Label:
qos_5qi
Label Description: 5Qi applicable for the QoS flow
Example: 1, 2, 5
Label:
rat_type
Label Description: Type of the radio access associated with the request
Example: EUTRA, NR, WLAN, rat_type_unknown
Label:
smf_current_procedure
Label Description: Current Procedure Name for Message Level Stats
Example: nr_to_untrusted_wifi_handover, eps_fb_ded_brr, PdnDisconnectProcedure, enb_to_untrusted_wifi_handover, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, smf_initiated_pdn_detach, untrusted_wifi_to_enb_handover, upf_sess_report_srir_sess_rel, utn3gpp_to_5g_handover
Gy Online charging destination host change statistics Category
ocs_dest_host_change_stats
Description: Statistics for charging destination host change
Sample Query: 'sum (ocs_dest_host_change_stats)'
Gy Online charging reporting reason statistics Category
ocs_reporting_reason_stats
Description: Statistics for reporting reason to OCS
Sample Query: 'sum (ocs_reporting_reason_stats{Reporting_Reason="THRESHOLD"})'
Labels:
Label:
rating_group
Label Description: Rating Group for which usage is being reported
Example: Any string
Label:
service_identifier
Label Description: Service Identifier for which usage is being reported
Example: Any string
Label:
Reporting_Reason
Label Description: Type of 3GPP reporting reason from OCS
Example: THRESHOLD, QHT, FINAL, QUOTA_EXHAUSTED, VALIDITY_TIME, OTHER_QUOTA_TYPE, RATING_CONDITION_CHANGE, FORCED_REAUTHORISATION, POOL_EXHAUSTED
Gz Offline CDR drop statistics Category
ofcs_cdr_drop_stats
Description: Statistics for CDR drop with trigger reason
Sample Query: 'sum (ofcs_cdr_drop_stats{TriggerType="final-cdr"})'
Labels:
Label:
procedure_type
Label Description: The procedure name associated with a call flow procedure
Example: Any string
Label:
TriggerType
Label Description: Trigger reason
Example: final-cdr", "external-trigger-cdr", "internal-trigger-cdr
Label:
dnn
Example: cisco.com
Gz Offline CDR message statistics Category
ofcs_cdr_message_stats
Description: Statistics for CDR message with record closure reason to OFCS
Sample Query: 'sum (ofcs_cdr_message_stats{record_closure_reason="normalRelease"})'
Labels:
Label:
gtpp_profile
Label Description: gtpp profile name used for bearer
Example: Any string
Label:
RuleBase
Label Description: RuleBase name used for bearer
Example: Any string
Label:
Label Description: CDR closure reason
Example: normalRelease", "abnormalRelease", "cAMELInitCallRelease", "volumeLimit", "timeLimit", "servingNodeChange", "maxChangeCond", "managementIntervention", "intraSGSNIntersystemChange", "rATChange", "mSTimeZoneChange","sGSNPLMNIDChange
Label:
dnn
Example: cisco.com
Label:
TriggerType
Example: GZ_SECONDARY_RAT_USAGE_LIMIT_REACHED
Gz Offline SDF Containers statistics Category
ofcs_sdf_container_stats
Description: Statistics for SDF Container with service condition change to OFCS
Sample Query: 'sum (ofcs_sdf_container_stats{service_condition_change="PdpContextRelease"})'
Labels:
Label:
Label Description: Service condition Change for SDF container
Example: QoSChange", "SgsnChange", "SgsnPlmnIdChange", "TariffTimeSwitch", "PdpContextRelease", "RatChange", "ServiceIdleOut", "ConfigurationChange", "ServiceStop", "DccaTimeThresholdReached", "DccaVolumeThresholdReached", "DccaServiceSpecificUnitThresholdReached", "DccaTimeExhausted", "DccaVolumeExhausted", "DccaValidityTimeout", "DccaReauthorisationRequest", "DccaContinueOngoingSession", "DccaRetryAndTerminateOngoingSession", "DccaTerminateOngoingSession", "CgiSaiChange", "RaiChange", "DccaServiceSpecificUnitExhausted", "RecordClosure", "TimeLimit", "VolumeLimit", "ServiceSpecificUnitLimit", "EnvelopeClosure", "EcgiChange", "TaiChange", "UserLocationChange
Label:
dnn
Example: cisco.com
Incoming Message Throttling Statistics Category
smf_inc_msg_throttling_stats
Description: Stats of throttled incoming messages
Sample Query: 'smf_inc_msg_throttling_stats{message_type="S5S8CreateSessReq"}'
Labels:
Label:
interface
Label Description: Interface Type
Example: S5, S8, S2B
Label:
message_type
Label Description: Message type corresponding to given interface
Example: S5S8CreateSessReq, S5S8DeleteSessReq, S5S8ModifyBearerReq, S5S8ModifyBearerCmd, S5S8BearerResourceCmd, S5S8DeleteBearerCmd
Label:
Cause
Label Description: Cause of Message Throttling
Example: EGTP_CAUSE_GTPC_ENTITY_CONGESTION
NF End point selections Category
nf_endpoint_selections_total
Description: NF End Point Selection Statistics
Sample Query: 'nf_endpoint_selections_total{nf_type="amf", host="http://10.105.227.109:8082/nnrf-nfm/v1", req="initial"}'
Labels:
Label:
nf_type
Label:
host
Label:
req
Label Description: req type
Example: initial, fallback,
NF failure handling stats Category
nf_failure_handling_stats_total
Description: NF Failure handling stats
Sample Query: 'nf_failure_handling_stats_total{nf_type="amf", host="http://10.105.227.109:8082/nnrf-nfm/v1", req="initial", response="202",
status="final"}'
Labels:
Label:
nf_type
Label:
host
Label:
req
Label Description: Request type
Label:
response
Label Description: Response from the server
Example: 200, 201, 204, timeout_rpc_error,
Label:
status
Label Description: Status from the server
Example: retry, final
NF management message time statistics Category
nf_management_total_time
Description: NF management messages total time taken
Sample Query: 'nf_management_total_time{host="http://10.105.227.109:8082/nnrf-nfm/v1", direction="outbound", message_type="registration",result="timeouOrRPCError"
Labels:
Label:
host
Label:
direction
Label Description: Direction indicates about the message going out or coming in
Example: inbound, outbound
Label:
message_type
Label Description: Type of Message
Example: registration, hearbeat, subscription, notification
Label:
result
Example: 200, 201, 204, success, timeout_rpc_error, response_parse_failure, request_parse_failure, invalid_notify_event, invalid_nf_instance_uri, internal_error
NF management messages statistics Category
nf_management_stats_total
Description: NF management messages statistics
Sample Query: 'nf_management_stats_total{host="http://10.105.227.109:8082/nnrf-nfm/v1", direction="outbound", message_type="registration",result="timeouOrRPCError"
Labels:
Label:
host
Label:
direction
Label:
message_type
Label:
result
NRF Discovery Category
nf_discover_events_total
Description: NF Discover Stats
Sample Query: 'nf_discover_events_total{nf_type="pcf", response_type="local"}'
Labels:
Label:
nf_type
Label:
response_type
Label Description: Discovery response choosen from
Example: local, cache, expired-cache
PDU UE Sync Procedure Category
pdu_ue_sync_proc
Description: PDU UE Sync Procedure counter
Sample Query: 'pdu_ue_sync_proc{status="attempted"}'
Labels:
Label:
status
Label Description: call flow procedure status counter
Example: attempted, success, failures, suspend, resume, abort
Policy control ADC pcc rule statistics Category
policy_adc_total
Description: PCC Rule total statistics for ADC
Sample Query: 'sum (policy_adc_total{app_id="abc"})'
Labels:
Label:
app_id
Label Description: ADC Application ID for pcc rule
Example: Any string
Label:
mute
Label Description: Mute for ADC rule
Example: true, false
Label:
operation
Label Description: Operation performed on the ADC pcc rule
Example: install, modify, remove
Label:
event
Label Description: Event associated with the operation performed on the ADC pcc rule
Example: attempted, success, failure, abort
Label:
gr_instance_id
Label Description: GR instance ID
Example: Any string
Label:
interface_type
Example: pcf, pcrf
Policy control NRF fail action statistics Category
policy_msg_nrf_fail_action
Description: NRF fail action stats for policy messages
Sample Query: 'sum (policy_msg_nrf_fail_action{policy_control_msg="SmPolicyCreate"})'
Labels:
Label:
policy_control_msg
Label Description: Type of policy control message
Example: SmPolicyCreate, SmPolicyUpdate, SmPolicyDelete
Label:
policy_nrf_action
Label Description: NRF failure action
Example: ignore, continue, terminate
Label:
pcf_end_point
Label Description: PCF IP Address
Example: 10.84.17.11
Label:
interface_type
Example: pcf, pcrf
Policy control PCF update statistics Category
policy_pcf_updates_total
Description: Statistics for triggers sent to PCF in SmPolicyUpdate Request to PCF
Sample Query: 'sum (policy_pcf_updates_total{trigger="rat_change"})'
Labels:
Label:
trigger
Label Description: Trigger sent in the policy update request sent to PCF
Example: ue_ip_change, plmn_change, res_mod_req, access_type_change , ue_ip_change , credit_mon_sess_fail , def_qos_change , sess_ambr_change , no_credit , serving_area_change , revalidation_timeout ,resoure_release,resource_alloc, rat_change
Label:
Label Description: Current procedure associated with the operation performed on the pcc rule
Example: pdn_sess_create, pdu_sess_create, smf_initiated_pdn_detach, disc_pdurel_smf_init_release, pcf_req_pdu_sess_mod, pcf_req_ded_brr_mod, enb_to_untrusted_wifi_handover, untrusted_wifi_to_enb_handover, nr_to_untrusted_wifi_handover, utn3gpp_to_5g_handover, xn_handover, n26_4g_to_5g_handover, pdn_5g_4g_handover, n26_4g_to_5g_im_mobility
Label:
interface_type
Example: pcf, pcrf
Policy control active PCF statistics Category
session_policy_type_total
Description: Stats for PCF active Sessions
Sample Query: 'sum (session_policy_type_total{policy_type="local"})'
Labels:
Label:
policy_type
Label Description: Policy type
Example: local, pcf
Label:
pcf_address
Label:
access_type
Label Description: Access type
Example: Ipv4PduSession, Ipv6PduSession, Ipv4V6PduSession
Label:
interface_type
Example: pcf, pcrf
Policy control current flow Category
policy_pdu_flows_current
Description: QoS flow current counts
Sample Query: 'sum (policy_pdu_flows_current{flow_type="gbr"}) by(qos_5qi, arp)'
Labels:
Label:
rat_type
Example: nr, WLAN, EUTRA
Label:
ssc_mode
Label Description: SSC mode for the session which created the QoS flow
Example: one, two, three
Label:
pdn_type
Label Description: PDN type of the session which created the QoS flow
Example: v4, v6, v4v6
Label:
dnn
Example: cisco.com
Label:
flow_type
Label Description: Flow type for the QoS flow
Example: gbr, non_gbr
Label:
qos_5qi
Example: 1, 2, 5
Label:
arp
Label Description: Priority level of ARP applicable for the QoS flow
Example: 10, 20
Label:
Example: pdn_sess_create, pdu_sess_create, pcf_req_pdu_sess_mod, pcf_req_ded_brr_mod, enb_to_untrusted_wifi_handover, untrusted_wifi_to_enb_handover, nr_to_untrusted_wifi_handover, utn3gpp_to_5g_handover, xn_handover, n26_4g_to_5g_handover, pdn_5g_4g_handover, n26_4g_to_5g_im_mobility
Label:
interface_type
Example: pcf, pcrf
Label:
mapped_flow
Label Description: flow has mapped 5Qi or not
Example: true , false
Label:
policy_type
Label Description: policy type for the subscriber session
Example: pcrf,pcf,optimized,local_policy
Policy control dynamic pcc rule statistics Category
policy_dynamic_pcc_rules_total
Description: PCC Rule total statistics for dynamic rules pushed from PCF
Sample Query: 'sum (policy_dynamic_pcc_rules_total{rule_id="Rule-1"}) by(qos_5qi, arp)'
Labels:
Label:
rule_id
Label Description: Rule Id for the received dynamic pcc rule
Example: PccRule-1
Label:
operation
Label Description: Operation performed on the dynamic pcc rule
Label:
event
Label Description: Event associated with the operation performed on the pcc rule
Label:
qos_5qi
Label Description: 5Qi applied on the dynamic pcc rule
Example: 1, 2, 5
Label:
arp
Label Description: Priority level of ARP applied on the dynamic pcc rule
Example: 10, 20
Label:
tc_event
Label Description: Traffic Control event applied on the dynamic pcc rule
Example: enabled_ul, enabled_dl, enabled, disabled, removed
Label:
charging_type
Label Description: Charging type applied on the dynamic pcc rule
Example: online, offline, online-offline
Label:
charging_method
Label Description: Charging method applied on the dynamic pcc rule
Example: volume, time, vol_time
Label:
details
Label Description: Details on the operation applied on the dynamic pcc rule
Example: success, failed, validation_failed
Label:
Label:
pccrule_change_type
Label Description: pcc rule parameter change type
Example: NA, binding_param_change, no_binding_param_change
Label:
interface_type
Example: pcf, pcrf
Label:
rule_fail_reason
Label Description: PCC Rule Fail Reason
Example: Rulebase is inactive, Rulebase is not configured, Predefined rule is inactive, Predefined rule is not configured, Pcc Rule recvd w/o RefQos, Pcc Rule recvd with invalid RefQos, Delete Pcc Rule recvd with policy create, Pcc Rule Does not exist, Pcc Rule recvd with reserved precedence, Pcc Rule name and id mismatch, Pcc Rule id is invalid, Pcc Rule recvd with invalid flow direction, Pcc Rule recvd without expected RefQos, Pcc Rule recvd Max filters(16) overflow, Max supported filters reached, Pcc Rule recvd with mismatch RefQoS, Pcc Rule recvd with unexpeted qos desc, Skipped due to Charging Description validation, Pcc Rule recvd with missing charging descriptor, Pcc Rule recvd with invalid charging desc, Qos Desc unexpected content, Pcc Rule recvd with multiple RefQos, Pcc Rule recvd without Flow Information, Pcc Rule recvd with RefQos having invalid, binding params, Sess Rule recvd w/o sess rule id, Sess Rule recvd w/o uplink AMBR, Sess Rule recvd w/o downlink AMBR, Sess Rule recvd with non standard 5QI, Sess Rule Auth def Qos recvd w/o ARP, Sess Rule and Auth def Qos mismatch, Sess Rule Auth def Qos recvd from non default flow, Sess Rule Auth def Qos QCI present in other Qos Desc, Sess Rule name and id mismatch, ARP recvd with invalid params, Flow desc recvd with invalid format(Invalid ipaddr class), Expected format: permit <direction> <protocol> from <Srouce IP> <Srouce Port> to <Dest IP> <Dest Port>, Flow desc recvd with action not supported, Flow desc recvd with direction not supported, Flow desc recvd with protocol not supported, Flow desc recvd with protocol missing, Flow desc recvd with remote IP or mask invalid, Flow desc recvd with source IP or mask invalid, Flow desc invert modifier not allowed, Flow desc assigned not supported for remote IP, Qos Desc Qos ID mismatch, Qos Desc recvd with Non Std 5QI, Qos Desc recvd with Non invalid bitrate, Qos Desc MBR value should be more than GBR value, Qos Desc recvd with invalid QoSID, Qos Desc recvd w/o ARP, Received exisiting Qos Desc with different binding parameters, Policy Trig lastreq data unavailable, Charging Desc not referred by any PCC Rule Or referred by invalid PCC Rule, Received Charging Id different from charging desc map key, Charging Desc not referred by any PCC Rule Or referred by invalid PCC Rule, Received Charging Id not referred by any PCC Rule, Existing Charging Desc unsupported modify, Invalid Input, Missing Charging ID information from Charging Descriptor, Missing RatingGroup information for Charging Id, Neither Online nor Offline charging method is enabled for charging descriptor Missing Service ID inforamtion for Charging Desc, Missing Service ID inforamtion for Charging Desc, URR ID not found for rating group, URR ID not found for rating group and service ID, Received Charging Desc conflicts with another charging descriptor, Charging Desc skipped due to Pcc Rule, Conflicting with dynamic chargng descriptor, Duplicate report function data invalid, IsMatching function data invalid, Conflicting RG service ID, PCC Rule Dropped due to charging association, Last Rule data not available, PCC Rule Invalid due to Ref TC Data, TC ID - Name mismatch, Missing Redirect Server address, Invalid Address Type, Session Rule recvd with Invalid 5QI, Qos Desc recvd with Invalid 5QI, Pcc Rule recvd with RefQos having invalid Flow for Non-Std QCI, Received Qos Desc with different Flow parameters between same flow for Non-Std QCI, Received exisiting Qos Desc with different Flow parameters for Non-Std QCI, Received Std-QCI Non-Gbr Flow with GBR value, Received Std-QCI Gbr Flow without GBR value, Predefine Pcc Rule recvd without AppID but its configs as ADC Rule, Predefine Pcc Rule recvd with AppID but its configs as Non-ADC Rule, Application Id change is not supported for Predefine Pcc Rule, PCC Rule rcvd with missing rule name, PCC Rule rcvd with invlaid Flow Description, PCC Rule rcvd with Invalid ToS Traffic Class, PCC Rule rcvd with Invalid SecurityParameterIndex, PCC Rule rcvd with Invalid Flow Label, PCC Rule rcvd with missing precedence, PCC Rule rcvd with missing QoS Information, PCC Rule rcvd with missing QCI in QoS Information, PCC Rule rcvd with invalid or unsupported QCI in QoS Information, PCC Rule rcvd with missing ARP priority level in QoS Information, PCC Rule rcvd with invalid ARP priority level, PCC Rule rcvd with invalid reporting level, PCC Rule rcvd with invalid flow status, Def Bearer Qos received with missing QCI, Def Bearer Qos received with invalid or unsupported QCI, Def Bearer Qos received with invalid ARP priority level, Invalid BCM received, Failure due Result Code AVP, Failure due to Experimental Result Code AVP, Invalid or Missing Supported Feature AVP, Usage Monitoring data instance is not defined, Invalid Usage Monitoring data referenced in Sess or PCC rule, Pcc Rule recvd with invalid refUmData, Sess Rule recvd with invalid refUmData, Gx Session release cause received
Policy control message statistics Category
policy_msg_processing_status
Description: Policy message handling Stats
Sample Query: 'sum (policy_msg_processing_status{policy_notification_msg="SmPolicyUpdateNotify"})'
Labels:
Label:
Label Description: Policy message type
Example: SmPolicyUpdateNotify, SmPolicyTerminate, SmPolicyCreate, SmPolicyUpdate, SmPolicyDelete
Label:
msg_status
Label Description: Policy processing message status
Example: accepted, rejected, skipped, attempted, failed, exp_attempted, exp_accepted, exp_rejected, exp_failed
Label:
pcf_end_point
Label:
rat_type
Label Description: RAT type of the flow
Label:
result
Label Description: result of policy message processing
Example: cfg_issue, max_outsatnding, send_failure, timeout, proc_timeout, rc_with_err, ex_rc_with_err, none
Label:
policy_fh_action
Label Description: Policy CHF action
Example: continue, terminate, none
Label:
policy_fh_subaction
Label Description: Policy CHF subaction
Example: discard_traffic, local_fallback, retryserver_on_event, sendccrt_call_term, with_term_req, without_term_req, none
Label:
interface_type
Example: pcf, pcrf
Label:
sess_rel_cause
Label Description: Session release cause received from policy server in policy response or policy request
Example: unspecified, ue_subscription, insuff_server_res, ip_can_sess_term, ue_ip_addr_rel
Label:
termination_cause
Label Description: Termination cause sent in terminate request towards policy server
Example: logout, service_not_provided, bad_answer, administrative, link_broken, auth_expired, user_moved, session_timeout
Policy control pre-defined pcc rule statistics Category
policy_predefined_pcc_rules_total
Description: PCC Rule total statistics for pre-defined rules activated by PCF
Sample Query: 'sum (policy_predefined_pcc_rules_total{rule_id="Rule-1"}) by(event, operation)'
Labels:
Label:
rulebase
Label Description: Rulebase to which this pre-defined rule belongs
Example: Rulebase-1
Label:
operation
Label Description: Operation performed on the pre-defined pcc rule
Label:
event
Label Description: Event associated with the operation performed on the pre-defined rule
Label:
qos_5qi
Label Description: 5Qi applied on the pre-defined pcc rule
Example: 1, 2, 5
Label:
arp
Label Description: Priority level of ARP applied on the pre-defined pcc rule
Example: 10, 20
Label:
charging_type
Label Description: Charging type applied on the pre-defined pcc rule
Label:
charging_method
Label Description: Charging method applied on the pre-defined pcc rule
Label:
Label:
interface_type
Example: pcf, pcrf
Label:
rule_fail_reason
Policy control rule report statistics Category
pcf_rule_report_stats
Description: Statistics for Rule Report sent to PCF
Sample Query: 'sum (pcf_rule_report_stats{pcf_rule_report_fail_code="INCOR_FLOW_INFO"})'
Labels:
Label:
Label Description: Failure code sent in RuleReport
Example: INCOR_FLOW_INFO
Label:
interface_type
Example: pcf, pcrf
Policy control session rule statistics Category
policy_session_rules_total
Description: Session total statistics for session rules applied
Sample Query: 'sum (policy_session_rules_total{rule_id="SessRule-1"})'
Labels:
Label:
rule_id
Label Description: Rule Id for the received session rule from PCF
Example: SessRule-1
Label:
operation
Label Description: Operation performed on the session rule
Label:
event
Label Description: Event associated with the operation performed on the rulebase
Label:
Label:
interface_type
Example: pcf, pcrf
Policy control static pcc rule statistics Category
policy_static_pcc_rules_total
Description: PCC Rule total statistics for static rules activated via rulebase
Sample Query: 'sum (policy_static_pcc_rules_total{rulebase="Rulebase-1"})'
Labels:
Label:
rulebase
Label Description: Rulebase to which the static rules belong
Example: Rulebase-1
Label:
operation
Label Description: Operation performed on the rulebase
Example: install, remove
Label:
event
Label:
Label:
interface_type
Example: pcf, pcrf
Label:
rule_fail_reason
Policy control total flow statistics Category
policy_pdu_flows_total
Description: QoS flow total statistics
Sample Query: 'sum (policy_pdu_flows_total{flow_type="gbr"}) by(qos_5qi, arp)'
Labels:
Label:
operation
Label Description: Operation performed on the QoS flow
Label:
event
Label Description: Event associated with the operation performed on QoS flow
Label:
rat_type
Label:
ssc_mode
Label:
pdn_type
Label:
dnn
Example: cisco.com
Label:
flow_type
Label:
init_or_ho
Label Description: Flow operation phase
Example: initial, ho
Label:
qos_5qi
Example: 1, 2, 5
Label:
arp
Example: 10, 20
Label:
interface_type
Example: pcf, pcrf
Label:
mapped_flow
Label:
policy_type
Policy destination host change statistics Category
policy_pcrf_dest_host_change
Description: Statistics for Policy destination host change
Sample Query: 'sum (policy_pcrf_dest_host_change{gr_instance_id="1"})'
Labels:
Label:
gr_instance_id
Example: Any string
Label:
interface_type
Example: pcf, pcrf
Radius Authentication Message Stats Category
radius_authentication_message_stats
Description: Stats for Radius Authentication messages
Sample Query: 'radius_authentication_message_stats{radius_auth_algorithm="radius_auth_algorithm_pap"}'
Labels:
Label:
dnn
Label Description: name of the dnn associated with the request
Example: Any string
Label:
Label Description: Radius Authentication Algorithm used
Example: radius_auth_algorithm_pap, radius_auth_algorithm_chap, radius_auth_algorithm_mschap, radius_auth_algorithm_default
Label:
status
Label Description: Radius Auth message status
Example: attempted, success, encode_failed, decode_failed, failed
Label:
reason
Example: timeout, parse_error, invalid_code, invalid_pco, invalid_apco, invalid_epco, write_error
Label:
rat_type
Radius Message stats Category
smf_radius_message_stats
Description: Stats for Radius interface messages
Sample Query: 'smf_radius_message_stats{message_type="radius_access_request"}'
Labels:
Label:
direction
Label:
message_type
Label Description: Radius Message Type
Example: radius_access_request, radius_access_accept
Label:
radius_avp_type
Label Description: Radius AVP Type
Example: radius_avp_pap_username, radius_avp_pap_user_password, radius_avp_chap_challenge, radius_avp_chap_response, radius_avp_mschap_challenge, radius_avp_mschap_response, radius_avp_idle_timeout, radius_avp_session_timeout
Label:
rat_type
SLA Transaction Category
smf_sla_transaction_stats
Description: Transaction SLA stats
Sample Query: sum(smf_sla_transaction_stats) by (smf_sla_transaction_stats,smf_proc_type,status, message_type)
Labels:
Label:
smf_proc_type
Label Description: Procedure Name
Example: PDU Session Release - SMF initiated, PDU 5G to 4G Handover, PDU Session Modify - PCF initiated, PDU UE Sync Procedure, PDU Idle Mode Entry - RAN initiated, PDN Session Modify - PCRF initiated
Label:
status
Label Description: gives status of the procedure
Example: Queued, Running, Aborted, Suspended, Invalid, Cleanedup, RequireSuspend, RequireCleanup, RequireAbort, Unknown
Label:
message_type
Label Description: gives the message type received during sla transaction
Example: IntSelfTxnSla
SMF ADC URR Statistics Category
smf_pfcp_adc_report_stats
Description: The current count of PFCP adc reports towards PCF
Sample Query: 'smf_pfcp_adc_report_stats{adc_report_type="async"}'
Labels:
Label:
adc_report_type
Label Description: Synchronus adc report or Asynchronous adc report
Example: async, sync
Label:
status
Label Description: ADC report status
Example: dropped, processed
SMF ALWAYS ON PDU SESSION Category
smf_always_on_session_stats
Description: Always On Pdu Session Statistics
Sample Query: 'smf_always_on_session_stats{status="pdusetup_req_alwayson_requested"}'
Labels:
Label:
status
Label Description: always on status statistics
Example: pdusetup_req_alwayson_requested, pdusetup_acc_alwayson_allowed, pdusetup_acc_alwayson_not_allowed, pdumod_req_alwayson_requested, pdumod_cmd_alwayson_allowed, pdumod_cmd_alwayson_not_allowed, pdumod_cmd_nw_init_alwayson_allowed, pdu_utwifi_to_nr_alwayson_requested, pdu_utwifi_to_nr_alwayson_allowed, pdu_utwifi_to_nr_alwayson_not_allowed
Label:
rat_type
Label:
pdu_type
Label Description: pdu connection type
Example: ipv4, ipv6, ipv4v6, unknown
Label:
dnn
Example: Any string
Label:
ssc_mode
Label Description: Type of ssc mode associated with the request
Example: ssc_mode_1, ssc_mode_2, ssc_mode_3, ssc_mode_unknown
SMF Charging Descriptor Delete Stats Category
smf_chrg_desc_del_stats
Description: The current count of charging descriptors deleted because of all associate Rule Ids are deleted
Sample Query: 'smf_chrg_desc_del_stats{rating_group="10"}'
Labels:
Label:
charging_id
Label Description: Charging Descriptor Identifier
Example: Any string
Label:
rating_group
Label Description: Rating Group for which charging descriptors is dropped
Example: Any string
Label:
configured
Label Description: Configured signifies if a Rule Id is configured or is dynamic
Label:
reason
Label Description: Reason for the charing descriptor delete
Example: Error string value
SMF Charging Descriptor Drop Stats Category
smf_chrg_desc_drop_stats
Description: The current count of charging descriptors dropped due to validation error on Rule Id
Sample Query: 'smf_chrg_desc_drop_stats{rating_group="10"}'
Labels:
Label:
rating_group
Example: Any string
Label:
service_identifier
Label Description: Service Identifier for which charging descriptors is dropped
Example: Any string
Label:
action
Label Description: Action with respect to Rule Id
Example: add, mod, del
Label:
configured
Label Description: Configured signifies if Rule Id is configured or is dynamic
Label:
reason
Label Description: Reason for the charging descriptor drop
SMF Charging Failure Handling Stats Category
chf_failure_handling_stats
Description: Statistics for application error received from CHF
Sample Query: 'chf_failure_handling_stats{appl_err_code="HTTP_STATUS_CODE_403_FORBIDDEN"}'
Labels:
Label:
http2_err_code
Label Description: HTTP2 error code received from CHF
Example: HTTP_STATUS_CODE_403_FORBIDDEN
Label:
appl_err_code
Label Description: Application error code received from CHF
Example: END_USER_REQUEST_REJECTED, QUOTA_LIMIT_REACHED,CHARGING_FAILED, USER_UNKNOWN, END_USER_REQUEST_DENIED, QUOTA_LIMIT_REACHED, CHARGING_NOT_APPLICABLE
Label:
fh_action
Label Description: Action taken on failure from CHF
Example: Terminate, Drop Traffic, Disable Charging
Label:
fh_exchg_type
Label Description: CHF Exchange in which failure occurred
Example: update, initial
Label:
disposition
Label Description: SMF action on failure
Example: disable-charging, drop-traffic, terminate, convert-offline, allocate-max-quota
Label:
procedure_type
SMF Charging Message Stats Category
chf_message_stats
Description: Charging Message Statistics
Sample Query: 'chf_message_stats{procedure_type="charging_initial"}'
Labels:
Label:
procedure_type
Label Description: Charging message type
Example: charging_initial, charging_update, charging_terminate
Label:
dnn
Example: cisco.com
Label:
status
Label Description: Status of OOO usage report processing
Example: attempted, success, timeout
Label:
rat_type
Label:
chf_type
Label:
Label:
interface_type
Example: N40, Gy
SMF Charging OOO Usage Report Stats Category
smf_ooo_usage_report
Description: The current count for OOO usage report
Sample Query: 'smf_ooo_usage_report{procedure_type="pdu_sess_create"}'
Labels:
Label:
procedure_type
Label:
dnn
Example: cisco.com
Label:
status
SMF Charging PFCP usage Report Stats Category
smf_pfcp_usage_report_stats
Description: The current count of PFCP usage reports towards CHF
Sample Query: 'smf_pfcp_usage_report_stats{usage_report_type="async"}'
Labels:
Label:
usage_report_type
Label Description: Synchronus usage report or Asynchronous usage report
Label:
status
Label Description: Usage report status
Example: recieved, dropped, ignored, processed
Label:
procedure_type
Label:
usage_report_discard_reason
Label Description: Reason for usage report rejection
Example: uuc_encd_cond_not_met, charg_parm_not_found, start_of_traffic_rcvd, ignore_rule_base_urr, no_valid_trgr_present, ignore_immd_trgr, urr_not_present, no_term_and_drop_traffic, onlinerpt_false_or_drop_traffic, mandatory_ie_incorrect, session_ctxt_not_found, radius_accounting, radius_accounting_not_enabled, urr_or_radius_accounting_missing
SMF Charging Quota Event Stats Category
chf_quota_event_stats
Description: The current count for quota event received from CHF
Sample Query: 'chf_quota_event_stats{quota_type="initial"}'
Labels:
Label:
rating_group
Label Description: Rating group for which quota is received from CHF
Example: Any string
Label:
quota_type
Label Description: Quota type as received from CHF
Example: initial, update, initial_final, update_final, fail
Label:
quota_method
Label Description: Quota method received from CHF
Example: time, volume, time_volume
Label:
quota_status
Label Description: Result for the quota received from CHF
Example: SUCCESS, END_USER_SERVICE_DENIED, QUOTA_MANAGEMENT_NOT_APPLICABLE, QUOTA_LIMIT_REACHED, END_USER_SERVICE_REJECTED, RATING_FAILED
Label:
quota_fail_action
Label Description: Action on quota failure
Example: No Action , Disable charging, Drop Traffic, Offline Converted
Label:
service_identifier
Label Description: Service Identifier for CHF quota event
Example: Any string
SMF Charging Radius Accounting Message Stats Category
radius_accounting_message_stats
Description: SMF Radius accounting message stats
Sample Query: 'radius_accounting_message_stats{procedure_type="radius_initial"}'
Labels:
Label:
procedure_type
Label Description: Charging Radius message type
Example: radius_initial, radius_update, radius_terminate
Label:
dnn
Example: cisco.com
Label:
status
Label Description: Status of Radius charging message processing
Label:
reason
Label Description: Reason for Radius message failure
Example: error, reject, timeout, invalid_arg
Label:
rat_type
SMF Charging Session Limit Dynamic Stats Category
chf_sess_limit_dynamic_stats
Description: SMF Charging Session Limit stats
Sample Query: 'chf_sess_limit_dynamic_stats{chf_sess_limit_dyn_reason="chf_sess_limit_dyn_del_all_trig_disabled"}'
Labels:
Label:
Label Description: Reason for Charging session limit stats
Example: chf_sess_limit_dyn_del_all_trig_disabled, chf_sess_limit_dyn_del_vol_time_nil, chf_sess_limit_dyn_add_in_cdru
SMF Charging Usage Report Stats Category
chf_usage_report_stats
Description: The current count for usage reports towards CHF
Sample Query: 'chf_usage_report_stats{charging_method="offline"}'
Labels:
Label:
rating_group
Example: Any string
Label:
service_identifier
Example: Any string
Label:
charging_method
Label Description: Metering method for the PDU Session
Example: online, offline, online_offline
Label:
charging_trigger_type
Label Description: Trigger for usage report
Example: QUOTA_THRESHOLD, QHT, FINAL, QUOTA_EXHAUSTED, VALIDITY_TIME, OTHER_QUOTA_TYPE, FORCED_REAUTHORISATION, UNIT_COUNT_INACTIVITY _TIMER, ABNORMAL_RELEASE, QOS_CHANGE, VOLUME_LIMIT, TIME_LIMIT, EVENT_LIMIT, PLMN,CHANGE, USER_LOCATION_CHANGE, RAT_CHANGE, UE_TIMEZONE_CHANGE, TARIFF_TIME_CHANGE, MAX_NUMBER_OF_CHANGES_IN_CHARGING_CONDITIONS, MANAGEMENT_INTERVENTION, CHANGE_OF_UE_PRESENCE_IN_PRESENCE_REPORTING_AREA, CHANGE_OF_3GPP_PS_DATA_OFF_STATUS, SERVING_NODE_CHANGE, REMOVAL_OF_UPF, ADDITION_OF_UPF, START_OF_SERVICE_DATA_FLOW, AMBR_CHANGE
Label:
procedure_type
SMF Charging Zero Usage Report Stats Category
chf_zero_usage_report_stats
Description: The current count for usage reports dropped due to zero usage
Sample Query: 'chf_zero_usage_report_stats{measurement_type="volume"}'
Labels:
Label:
measurement_type
Label Description: Measurement type
Example: volume, duration, duration-volume
Label:
SMF DB Marshal Category
smf_db_marshal_stats
Description: SMF DB marshal stats
Sample Query: sum(smf_db_marshal_stats) by (module)
Labels:
Label:
module
Label Description: module type counter
Example: policy, charging, upserv, access, generic
SMF Data Consistency Check Category
smf_datacheck_stats
Description: Total number of sessions checked for consistency
Sample Query: 'smf_datacheck_stats{rat_type="NR", status="failed"}'
Labels:
Label:
procedure_type
Label:
rat_type
Label:
pdu_type
Label Description: Type of PDU session
Label:
status
Label Description: Procedure status after data consistency check
Label:
reason
Label Description: Failure reason of data inconsistency
Example: invalid_n4_data_in_txn_start, invalid_n4_data_in_txn_end, invalid_n7_data_in_txn_start, invalid_n7_data_in_txn_end, invalid_n40_data_in_txn_start, invalid_n40_data_in_txn_end
SMF Disconnect stats Category
smf_disconnect_stats
Description: SMF Disconnect stats counters
Sample Query: 'smf_disconnect_stats{reason="disc_pdurel_amf_init_detach"}'
Labels:
Label:
rat_type
Label Description: RAT Type of the Session
Label:
reason
Label Description: The reason associated with an call disconnect
Example: disc_pdusetup_create_over_create, disc_pdusetup_release_over_create, disc_pdusetup_admin_clear, disc_pdusetup_n1_decode_failure, disc_pdusetup_n1_content_not_found, disc_pdusetup_sess_abs_timeout, disc_pdusetup_sess_idle_timeout, disc_pdusetup_sess_cp_idle_timeout, disc_pdusetup_sess_default_flow_only_timeout, disc_pdusetup_ssc_mode_not_supported, disc_pdusetup_ssc_mode_denied, disc_pdusetup_identity_conflict, disc_pdusetup_pdutype_unsupported, disc_pdusetup_pdutype_denied, disc_pdusetup_snssai_denied, disc_pdusetup_dnn_denied, disc_pdusetup_iwf_denied, disc_pdusetup_subscription_denied, disc_pdusetup_dnn_not_supported, disc_pdusetup_dnn_not_supported_in_slice, disc_pdusetup_network_failure, disc_pdusetup_pdu_sess_does_not_exist, disc_init_chg_data_err, disc_pdusetup_ip_alloc_failed, disc_pdusetup_static_ip_alloc_failed, disc_pdusetup_pdu_fetch_failure, disc_pdusetup_udm_reg_failed, disc_pdusetup_udm_sub_fetch_failure, disc_pdusetup_udm_sub_fetch_resp_failed, disc_pdusetup_udm_sub_notify_failed, disc_pdusetup_upf_setup_cause_not_accepted, disc_pdusetup_secondary_auth_failed, disc_pdusetup_secondary_auth_resp_failed, disc_pdusetup_sm_cxt_invalid, disc_pdusetup_sm_cxt_invalid_ie, disc_pdusetup_sm_cxt_sess_id_err, disc_pdusetup_sm_cxt_invalid_json, disc_pdusetup_sm_cxt_n1_process_failed, disc_pdusetup_sm_cxt_man_param_missing, disc_pdusetup_pcf_create_exchg_failure, disc_pdusetup_pcf_create_rsp_failure, disc_pdusetup_rm_exchg_failure, disc_pdusetup_rm_rsp_failure, disc_pdusetup_pcf_update_exchg_failure, disc_pdusetup_pcf_update_rsp_failure, disc_chf_data_exchg_failure, disc_chf_data_rsp_failure, disc_pdusetup_upf_setup_exchg_failure, disc_pdusetup_upf_setup_rsp_failure, disc_pdusetup_n1n2_transfer_exchg_failure, disc_pdusetup_n1n2_transfer_rsp_failure, disc_pdusetup_n2_setup_failed, disc_pdusetup_ue_init_release, disc_pdusetup_amf_assign_ebi_failure, disc_pdusetup_upf_modify_exchg_failure, disc_pdusetup_upf_modify_rsp_failure, disc_pdusetup_upf_modify_failed, disc_pdusetup_upf_serv_data_nill, disc_pdusetup_upf_dl_tunnel_info_not_found, disc_pdusetup_upf_tunnel_id_not_found, disc_pdusetup_upf_mod_gnb_tun_params_failed, disc_pdusetup_upf_mod_rsra_tun_params_failed, disc_pdusetup_upf_mod_tun_param_tos-failed, disc_pdusetup_smf_mop_offline, disc_pdusetup_sm_context_nssai_not_supported, disc_pdusetup_sm_context_network_failure, disc_pdusetup_lbo_rejected, disc_pdusetup_home_route_not_supported, disc_pdusetup_internal_error, disc_pdusetup_plmn_not_supported, disc_pdurel_amf_sends_ue_not_found, disc_pdusetup_dnn_missing, disc_pdusetup_udm_dnn_missing, disc_pdusetup_resource_mgr_rsp_failed, disc_pdusetup_apply_wps_failed, disc_pdurel_ue_init_release, disc_pdurel_amf_init_release, disc_pdurel_amf_init_release_404, disc_pdurel_amf_init_release_mod_req, disc_pdurel_pcf_reconciliation, disc_rel_chf_err, disc_pdurel_pcf_init_release, disc_pdurel_udm_init_release, disc_pdurel_gnb_init_release, disc_pdurel_smf_init_release, disc_pdurel_upf_init_association_release, disc_pdurel_radius_init_release, disc_pdurel_upf_init_path_failure, disc_pdurel_upf_recovered, disc_pdurel_config_change, disc_db_conflict_release, disc_pdurel_pcf_reconciliation, disc_n2ho_n4_modify_failed, disc_n2ho_failure, disc_n2ho_guard_timer_expiry, disc_n2ho_idft_timer_expiry, disc_n26_4g_5g_ho_n4_modify_failed, disc_n26_4g_5g_im_mobility_n4_modify_failed, disc_pdumodify_context_not_found, disc_pdumodify_invalid_pdu_sess_identity, disc_pdurelease_invalid_pdu_sess_identity, disc_pduim_context_not_found, disc_n26_4g_5g_ho, disc_n26_5g_4g_ho, disc_n26_5g_4g_ho_timer_expired_post_exec, disc_n26_4g_5g_ho_udm_reg_failed, disc_n26_5g_4g_ho_mbr_failed, disc_pdusetup_upf_rule_creation_mod_failure, disc_non3gpp_utn_5g_ho, disc_5gtonon3gpp_utn_ho, disc_4g_non3gpp_utn_ho, disc_non3gpp_utn_4g_ho, disc_enb_wifi_ho_failed, disc_utn3gpp_5g_ho_failed, disc_sess_report_srsr_pdu_sess_rel, disc_pdn_ue_init_release, disc_pdn_mme_init_release, disc_pdn_chf_reconciliation, disc_pdn_pcf_reconciliation, disc_pdn_pcf_init_release, disc_pdn_pcf_fallback, disc_pdn_udm_init_release, disc_pdn_chf_init_release, disc_pdn_upf_init_release, disc_admin_init_release, disc_sess_time_exp_release, disc_sess_cp_idle_time_exp_release, disc_session_recreate, disc_gtpc_peer_pathfail, disc_gtpc_peer_restart, disc_upf_init_path_failure, disc_transaction_timedout, disc_upf_recovered, disc_sgw_ctx_failure, disc_pdn_internal_release, disc_reason_unknown,, disc_pdnsetup_iwk_5gs_flag_false, disc_pdnsetup_pduid_init_failed, disc_pdnsetup_csr_invalid, disc_pdnsetup_udm_reg_failed, disc_pdnsetup_udm_reg_req_create_failed, disc_pdnsetup_udm_rpc_failed, disc_pdnsetup_udm_dnn_missing, disc_pdnsetup_udm_reg_resp_failed, disc_pdnsetup_udm_sub_fetch_failed, disc_pdnsetup_udm_sub_fetch_resp_failed, disc_pdnsetup_udm_sub_notify_failed, disc_pdnsetup_udm_sub_notify_resp_failed, disc_pdnsetup_udm_sgw_u_teid_missing, disc_pdnsetup_secondary_auth_failed, disc_pdnsetup_secondary_auth_resp_failed, disc_pdnsetup_secondary_auth_ip_addr_conflict, disc_pdnsetup_pcf_create_failed, disc_pdnsetup_pcf_create_resp_failed, disc_pdnsetup_pcf_update_req_create_failed, disc_pdnsetup_pcf_update_exchg_failed, disc_pdnsetup_pcf_update_resp_failed, disc_pdnsetup_resource_mgr_exchg_failed, disc_pdnsetup_resource_mgr_resp_failed, disc_pdnsetup_upf_sess_setup_exchg_failed, disc_pdnsetup_upf_sess_setup_resp_failed, disc_pdnsetup_upf_sgw_tunnelid_error, disc_pdnsetup_upf_local_fteid_error, disc_pdnsetup_ssc_mode_denied, disc_pdnsetup_pdu_type_denied, disc_pdnsetup_pdu_type_not_supported, disc_pdnsetup_ssc_mode_not_supported, disc_pdnsetup_subscription_denied, disc_pdnsetup_smf_mop_offline, disc_pdnsetup_plmn_not_supported, disc_pdnsetup_non5gcapableue_not_allowed, disc_pdnsetup_default_flow_only_timeout, disc_affinity_add_error, disc_pdnsetup_sgwctx_brr_data_invalid, disc_ue_int_n1_5g_sm_status, disc_pdu_ctx_not_found, disc_internal_affinity_add_error, upf_sess_report_gter_pdn_sess_rel, upf_sess_report_srir_pdn_sess_rel, upf_sess_report_spter_pdn_sess_rel, upf_sess_report_srsr_pdn_sess_rel, upf_sess_report_erir_pdn_sess_rel, upf_sess_report_upir_pdn_sess_rel, disc_sess_report_srsr_pdn_sess_rel, disc_originatingEntity_request_timed_out, disc_new_pdn_type_due_to_single_addr_bearer_only, disc_new_pdn_type_due_to_network_preference, disc_pdnsetup_dnn_missing_or_unknown, disc_request_timeout_at_originating_entry, disc_pdusetup_integrity_protected_mdr_not_acceptable, disc_pdnsetup_upip_status_req_denied_in_rat, disc_pdn_pcrf_init_release, disc_pdnsetup_pcrf_create_resp_failed, disc_pdnsetup_charging_create_resp_failed, disc_vsmf_insert_dtssa_acscr_not_configured, disc_vsmf_insert_interplmn_ho_not_configured, disc_vsm_insert_hsmf_retrieve_failure, disc_ro2ho_n2ho_interplmn_ho_not_configured, disc_ro2ho_n4_modify_failed, disc_ho2ro_n4_modify_failed, disc_ho2ro_failure disc_ro2ho_failure, disc_ro2ho_guard_timer_expiry, disc_ho2ro_guard_timer_expiry
SMF EBI stats Category
smf_ebi_stats
Description: Stats for the EBI Assignement
Sample Query: 'smf_ebi_stats{status="success"}'
Labels:
Label:
procedure_type
Example: pdusetup_ebi_assignment
Label:
status
Label Description: status of EBI Assignment
SMF IPAM Address Events Current Counter Category
IPAM_address_allocations_current
Description: Current state of SMF IPAM Address allocations
Sample Query: 'IPAM_address_allocations_current{dnn="dnn1",servingArea="area1",nssai="slice1",pool="p1",allocationType="dynamic",addressType="IPv4",upf="dp1",grInstId="1"}'
Labels:
Label:
dnn
Example: Any string
Label:
servingArea
Label Description: name of the serving area associated with the request
Example: Any string
Label:
nssai
Label Description: name of the nssai associated with the request
Example: Any string
Label:
pool
Label Description: name of the pool associated with the request
Example: Any string
Label:
allocationType
Label Description: type of allocation associated with the request
Example: static/dynamic
Label:
addressType
Label Description: address type associated with the request
Example: IPv4/IPv6PD
Label:
upf
Label Description: upf identifier associated with the request
Example: Any string
Label:
grInstId
Label Description: GR Instance ID
Example: 1 or 2
SMF IPAM Address Events Total Counter Category
IPAM_address_events_total
Description: Total number of SMF IPAM Address events
Sample Query: 'IPAM_address_events_total{dnn="dnn1",servingArea="area1",nssai="slice1",pool="p1",eventType="Allocation",allocationType="dynamic",addressType="IPv4",upf="dp1",grInstId="1"}'
Labels:
Label:
dnn
Example: Any string
Label:
servingArea
Example: Any string
Label:
nssai
Example: Any string
Label:
pool
Example: Any string
Label:
eventType
Label Description: type of event associated with the request
Example: Allocation/Release
Label:
allocationType
Label:
addressType
Label:
upf
Example: Any string
Label:
grInstId
Example: 1 or 2
SMF IPAM Chunk Events Current Counter Category
IPAM_chunk_allocations_current
Description: Current state of SMF IPAM Address Chunk allocations
Sample Query: 'IPAM_chunk_allocations_current{dnn="dnn1",servingArea="area1",nssai="slice1",pool="p1",addressType="IPv4",upf="dp1",grInstId="1",forRemoteSmf="true"}'
Labels:
Label:
dnn
Example: Any string
Label:
servingArea
Label Description: name of the serving Area associated with the request
Example: Any string
Label:
nssai
Example: Any string
Label:
pool
Example: Any string
Label:
addressType
Label:
upf
Example: Any string
Label:
grInstId
Example: 1 or 2
Label:
forRemoteSmf
Label Description: Indicates if chunk is reserved for Remote SMF
Example: true/false
Labels:
Label:
dnn
Example: Any string
Label:
servingArea
Example: Any string
Label:
nssai
Example: Any string
Label:
pool
Example: Any string
Label:
eventType
Label:
allocationType
Label:
addressType
Label:
upf
Example: Any string
Label:
grInstId
Example: 1 or 2
SMF N1 Message stats Category
smf_n1_message_stats
Description: Stats for N1 Messages
Sample Query: 'smf_n1_message_stats{procedure_type="pcf_req_pdu_sess_mod"}'
Labels:
Label:
procedure_type
Example: pdu_sess_create, ue_req_pdu_sess_mod, smf_req_pdu_sess_mod, pcf_req_pdu_sess_mod, udm_req_pdu_sess_mod, gnb_req_pdu_sess_mod, ue_req_pdu_sess_rel, smf_req_pdu_sess_rel, pcf_req_pdu_sess_rel, amf_req_pdu_sess_rel, udm_req_pdu_sess_rel, gnb_req_pdu_sess_rel, chf_req_pdu_sess_rel, admin_req_pdu_sess_rel, ue_req_active_to_idle, ue_req_idle_to_active, nw_req_service_active, upf_notify_downlink_data, xn_path_switch,pdn_sess_create,pdn_5g_4g_handover,pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, n2_handover, xn_handover, n26_4g_to_5g_handover, n26_4g_to_5g_im_mobility, pdu_im, pdn_sess_create, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, pcf_initiated_pdn_detach, smf_initiated_pdn_detach, upf_initiated_pdn_detach, smf_eps_fb
Label:
direction
Label Description: Direction of N1 message
Example: outbound, inbound
Label:
message_type
Label Description: The N1 message type
Example: pdu_session_establishment_reject, pdu_session_release_request, pdu_session_modification_command_reject, pdu_session_modification_reject, pdu_session_release_reject, 5g_sm_status_msg_release, 5g_sm_status_msg_no_action, 5g_sm_status_msg_invalid_pti
Label:
n1_cause
Label Description: N1 cause assosiated with the message
Example: OPERATOR_DETERMINED_BARRING, INSUFFICIENT_RESOURCES, MISSING_OR_UNKNOWN_DNN, UNKNOWN_PDU_SESSION_TYPE, USER_AUTHENTICATION_OR_AUTHORIZATION_FAILED, REQUEST_REJECTED_UNSPECIFIED, SERVICE_OPTION_NOT_SUPPORTED, REQUESTED_SERVICE_OPTION_NOT_SUBSCRIBED, SERVICE_OPTION_TEMPORARILY_OUT_OF_ORDER, PTI_ALREADY_IN_USE, REGULAR_DEACTIVATION, NETWORK_FAILURE, REACTIVATION_REQUESTED, SEMANTIC_ERROR_IN_THE_TFT_OPERATION, SYNTACTICAL_ERROR_IN_THE_TFT_OPERATION, INVALID_PDU_SESSION_IDENTITY, SEMANTIC_ERRORS_IN_PACKET_FILTER, SYNTACTICAL_ERROR_IN_PACKET_FILTER, OUT_OF_LADN_SERVICE_AREA, PTI_MISMATCH, PDU_SESSION_TYPE_IPV4_ONLY_ALLOWED, PDU_SESSION_TYPE_IPV6_ONLY_ALLOWED, PDU_SESSION_DOES_NOT_EXIST, INSUFFICIENT_RESOURCES_FOR_SPECIFIC_SLICE_AND_DNN, NOT_SUPPORTED_SSC_MODE, INSUFFICIENT_RESOURCES_FOR_SPECIFIC_SLICE, MISSING_OR_UNKNOWN_DNN_IN_A_SLICE, INVALID_PTI_VALUE, MAXIMUM_DATA_RATE_PER_UE_FOR_USER_PLANE_INTEGRITY_PROTECTION_IS_TOO_LOW, SEMANTIC_ERROR_IN_THE_QOS_OPERATION, SYNTACTICAL_ERROR_IN_THE_QOS_OPERATION, INVALID_MAPPED_EPS_BEARER_IDENTITY, SEMANTICALLY_INCORRECT_MESSAGE, INVALID_MANDATORY_INFORMATION, MESSAGE_TYPE_NON_EXISTENT_OR_NOT_IMPLEMENTED, MESSAGE_TYPE_NOT_COMPATIBLE_WITH_THE_PROTOCOL_STATE, INFORMATION_ELEMENT_NON_EXISTENT_OR_NOT_IMPLEMENTED, CONDITIONAL_IE_ERROR, MESSAGE_NOT_COMPATIBLE_WITH_THE_PROTOCOL_STATE, PROTOCOL_ERROR_UNSPECIFIED
SMF N2 Message stats Category
smf_n2_message_stats
Description: Stats for N2 Messages
Sample Query: 'smf_n2_message_stats{procedure_type="pcf_req_pdu_sess_mod"}'
Labels:
Label:
procedure_type
Label:
direction
Label Description: Direction of N2 message
Label:
n2_Ngap_ie_type
Label Description: The N2 Ngap IE type
Example: N2_PDU_SESSION_RESOURCE_RELEASE_COMMAND_TRANSFER, N2_PDU_SESSION_PATH_SWITCH_REQUEST_TRANSFER, N2_INVALID_OR_UNSUPPORTED_NGAP_IE_TYPE, N2_PDU_SESSION_PATH_SWITCH_REQUEST_SETUP_FAILED_TRANSFER, N2_PDU_SESSION_RESOURCE_SETUP_UNSUCCESS_TRANSFER, N2_PDU_SESSION_RESOURCE_NOTIFY_RELEASED_TRANSFER, N2_PDU_SESSION_RESOURCE_MODIFY_UNSUCCESS_TRANSFER, N2_PDU_SESSION_HANDOVER_REQUEST_ACK_TRANSFER, N2_PDU_SESSION_HANDOVER_RESOURCE_ALLOC_UNSUCCESS_TRANSFER, N2_INVALID_OR_UNSUPPORTED_NGAP_TYPE, N2_PDU_SESSION_RESOURCE_SETUP_RESPONSE_TRANSFER
Label:
n2_cause_group
Label Description: The N2 Cause Group
Example: NgapCauseGroupEnum_RadioNetworkCause, NgapCauseGroupEnum_TransportLayerCause, NgapCauseGroupEnum_NASCause, NgapCauseGroupEnum_ProtocolCause, NgapCauseGroupEnum_MiscCause, NgapCauseGroupEnum_NgapCauseGroupDummy
Label:
n2_cause
Label Description: N2 cause assosiated with the message
Example: NgapCauseEnum_RadioNetwork_DummyEnum, NgapCauseEnum_RadioNetwork_Unspecified, NgapCauseEnum_RadioNetwork_TXnRELOCOverall_expiry, NgapCauseEnum_RadioNetwork_Successful_handover, NgapCauseEnum_RadioNetwork_Release_due_to_NG_RAN_generated_reason, NgapCauseEnum_RadioNetwork_Release_due_to_5GC_generated_reason, NgapCauseEnum_RadioNetwork_Handover_cancelled, NgapCauseEnum_RadioNetwork_Partial_handover, NgapCauseEnum_RadioNetwork_Handover_failure_in_target_5GC_NG_RAN_node_or_target_system, NgapCauseEnum_RadioNetwork_Handover_target_not_allowed, NgapCauseEnum_RadioNetwork_TNGRELOCoverall_expiry, NgapCauseEnum_RadioNetwork_TNGRELOCprep_expiry, NgapCauseEnum_RadioNetwork_Cell_not_available, NgapCauseEnum_RadioNetwork_Unknown_target_ID, NgapCauseEnum_RadioNetwork_No_radio_resources_available_in_target_cell, NgapCauseEnum_RadioNetwork_Unknown_local_UE_NGAP_ID, NgapCauseEnum_RadioNetwork_Inconsistent_remote_UE_NGAP_ID, NgapCauseEnum_RadioNetwork_Handover_desirable_for_radio_reasons, NgapCauseEnum_RadioNetwork_Time_critical_handover, NgapCauseEnum_RadioNetwork_Resource_optimisation_handover, NgapCauseEnum_RadioNetwork_Reduce_load_in_serving_cell, NgapCauseEnum_RadioNetwork_User_inactivity, NgapCauseEnum_RadioNetwork_Radio_connection_with_UE_lost, NgapCauseEnum_RadioNetwork_Radio_resources_not_available, NgapCauseEnum_RadioNetwork_Invalid_QoS_combination, NgapCauseEnum_RadioNetwork_Failure_in_the_radio_interface_procedure, NgapCauseEnum_RadioNetwork_Interaction_with_other_procedure, NgapCauseEnum_RadioNetwork_Unknown_PDU_Session_ID, NgapCauseEnum_RadioNetwork_Unknown_QoS_Flow_ID, NgapCauseEnum_RadioNetwork_Multiple_PDU_Session_ID_Instances, NgapCauseEnum_RadioNetwork_Multiple_QoS_Flow_ID_Instances, NgapCauseEnum_RadioNetwork_Encryption_and_or_integrity_protection_algorithms_not_supported, NgapCauseEnum_RadioNetwork_NG_intra_system_handover_triggered, NgapCauseEnum_RadioNetwork_NG_inter_system_handover_triggered, NgapCauseEnum_RadioNetwork_Xn_handover_triggered, NgapCauseEnum_RadioNetwork_Not_supported_5QI_value, NgapCauseEnum_RadioNetwork_UE_context_transfer, NgapCauseEnum_RadioNetwork_IMS_voice_EPS_fallback_or_RAT_fallback_triggered, NgapCauseEnum_RadioNetwork_UP_integrity_protection_not_possible, NgapCauseEnum_RadioNetwork_UP_confidentiality_protection_not_possible, NgapCauseEnum_RadioNetwork_Slice_not_supported, NgapCauseEnum_RadioNetwork_UE_in_RRC_INACTIVE_state_not_reachable, NgapCauseEnum_RadioNetwork_Redirection, NgapCauseEnum_RadioNetwork_Resources_not_available_for_the_slice, NgapCauseEnum_RadioNetwork_UE_maximum_integrity_protected_data_rate_reason, NgapCauseEnum_RadioNetwork_Release_due_to_CN_detected_mobility, NgapCauseEnum_RadioNetwork_N26_Interface_Not_Available, NgapCauseEnum_RadioNetwork_Release_Due_To_Pre_Emption, NgapCauseEnum_Transport_resource_unavailable, NgapCauseEnum_Transport_Unspecified, NgapCauseEnum_Nas_Normal_release, NgapCauseEnum_Nas_Authentication_failure, NgapCauseEnum_Nas_Deregister, NgapCauseEnum_Nas_Nas_Unspecified, NgapCauseEnum_Protocol_Transfer_syntax_error, NgapCauseEnum_Protocol_Abstract_syntax_error_reject, NgapCauseEnum_Protocol_Abstract_syntax_error_ignore_and_notify, NgapCauseEnum_Protocol_Message_not_compatible_with_receiver_state, NgapCauseEnum_Protocol_Semantic_error, NgapCauseEnum_Protocol_Abstract_syntax_error_falsely_constructed_message, NgapCauseEnum_Protocol_Proto_Unspecified, NgapCauseEnum_Misc_Control_processing_overload, NgapCauseEnum_Misc_Not_enough_user_plane_processing_resources, NgapCauseEnum_Misc_Hardware_failure, NgapCauseEnum_Misc_O_M_intervention, NgapCauseEnum_Misc_Unknown_PLMN, NgapCauseEnum_Misc_Unspecified, NgapCauseEnum_UP_integrity_protection_not_possible, NgapCauseEnum_Encryption_and_or_integrity_protection_algorithms_not_supported
Label:
n2_fail_reason
Label Description: N2 failure reason
Example: None, N2 Decode Failed, Invalid N2 Container, upfServData is Nil, DL TunnelInfo is Not Found, UPF Tunnel ID lookup Failed, UPF MOD GNB Tunnel Params Failed, UPF MOD RSRA Tunnel Params Failed, UPF MOD Apply WPS Failed, MOD Tunnel LI Params Failed, Qos Mod Info Failed, Missing N2 SM Info, PDU Context Not Found, Default QFI (1) present in failed QosFlowList, RSRA Tunnel Recreation Failed For HO, Update QER Rule Map Failed, Rollback N2 Failed, Invalid Cause N2 SM Info, Mandatory IE incorrect in N2 SM Info, Xn HO Tobe Switch Flag Is Not Set in SmContextUpdateData, Invalid QFI List in PathSwitchRequest, QoS Flow Accepted List not found in XnHO, at least one Qfi to be accepted, PDU Session is Not Established, Missing T-gNB DL UP TunnelInfo, Missing S-gNB DL UP TunnelInfo, Default QFI is present in the Failed QFI List, N4 Session Modification failed, SLA Timeout
SMF Node Manager stats Category
smf_service_node_mgr_stats
Description: Stats for SMF Node Manager
Sample Query: 'smf_service_node_mgr_stats{ip_req_type="ip-alloc"}'
Labels:
Label:
upf_ep_key
Label Description: UPF Endpoint Key
Example: IP String Value
Label:
first_nodemgr_inst
Label Description: First Nodemgr instance ID
Example: unsigned integer
Label:
second_nodemgr_inst
Label Description: Second Nodemgr instance ID
Label:
error
Label Description: Error in case of Node Mgr failure
Example: None, Both associated nodemgr instances are down, Second nodeMgr down and First NodeMgr responded with SmfRspFailure, Second nodeMgr down and First NodeMgr failed with IpcError, First NodeMgr responded with SmfRspFailure, First NodeMgr failed with IpcError, Second NodeMgr failed with IpcError, Second NodeMgr responded with SmfRspFailure
Label:
retransmit
Label Description: Is retransmit message
Label:
ip_req_type
Label Description: Type of IP request
Example: ip-alloc, ip-dealloc, ip-static, ip-static-subscription, ip-static-radius
Label:
pdu_type
SMF PCSCF Server Stats Category
smf_pcscf_server_stats
Description: Stats for SMF PCSCF Server
Sample Query: 'smf_pcscf_server_stats{PrimaryIPv4="1.2.3.4"}'
Labels:
Label:
PrimaryIPv4
Label Description: Primary PCSCF IPV4 address
Example: 1.2.3.4
Label:
SecondaryIPv4
Label Description: Secondary PCSCF IPV4 address
Example: 1.2.3.4
Label:
TertiaryIPv4
Label Description: Tertiary PCSCF IPV4 address
Example: 1.2.3.4
Label:
PrimaryIPv6
Label Description: Primary PCSCF IPV6 address
Example: IPv6 IP
Label:
SecondaryIPv6
Label Description: Secondary PCSCF IPV6 address
Example: IPv6 IP
Label:
TertiaryIPv6
Label Description: Tertiary PCSCF IPV6 address
Example: IPv6 IP
Label:
ResolvedFrom
Label Description: Info used to resolve PCSCF Address
Example: DNS, LocalConfig
SMF PDU Status Category
smf_service_counters
Description: The current count of SMF pdu sessions
Sample Query: 'smf_service_counters{pdu_state="all_pdu"}'
Labels:
Label:
pdu_state
Label Description: PDU session status indicated by N3 UPF tunnel status
Example: all_pdu, idle, connected
Label:
rat_type
Label:
dnn
Label Description: Dnn configured in dnn-policy, also can have virtual_dnn if configured, separated by #
Example: intershat, intershat#cisco.com
Label:
roaming_status
Label Description: Roaming status of the subscriber session
Example: visitor-lbo, visitor-hr, roamer, homer, none
Label:
ssc_mode
Label Description: SSC Mode of the session
Label:
flow_type
Label Description: Indicates whether it's total bearer or dedicated bearer
Example: dedicated_bearer, total_bearer
SMF Procedure Category
smf_service_stats
Description: SMF call flow procedure counters
Sample Query: 'smf_service_stats{procedure_type="pdu_sess_create"}'
Labels:
Label:
procedure_type
Example: pdu_sess_create, ue_req_pdu_sess_mod, smf_req_pdu_sess_mod, pcf_req_pdu_sess_mod, udm_req_pdu_sess_mod, gnb_req_pdu_sess_mod, ue_req_pdu_sess_rel, smf_req_pdu_sess_rel, pcf_req_pdu_sess_rel, amf_req_pdu_sess_rel, udm_req_pdu_sess_rel, gnb_req_pdu_sess_rel, chf_req_pdu_sess_rel, admin_req_pdu_sess_rel, ue_req_active_to_idle, ue_req_idle_to_active, nw_req_service_active, upf_notify_downlink_data, xn_path_switch,pdn_sess_create,pdn_5g_4g_handover,pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, n2_handover, xn_handover, n26_4g_to_5g_handover, n26_4g_to_5g_im_mobility, pdu_im, pdn_sess_create, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, pcf_initiated_pdn_detach, smf_initiated_pdn_detach, upf_initiated_pdn_detach, smf_eps_fb, misc_pdu_sess_rel, pcrf_req_ded_brr_mod, pcrf_req_ded_brr_create, pcrf_req_ded_brr_delete, suspend_notification, resume_notification, change_notification, gx_validation_failure_pdn_sess_rel, smf_inter_plmn_ro2ho_n2ho, smf_inter_plmn_ho2ro_n2ho, smf_idft_inter_plmn_ro2ho_n2ho, smf_dft_inter_plmn_ro2ho_n2ho, smf_idft_inter_plmn_ho2ro_n2ho smf_dft_inter_plmn_ho2ro_n2ho
Label:
status
Label Description: call flow procedure counter
Example: attempted, success, failures, pcrf_failure
Label:
pdu_type
Label:
dnn
Label:
reason
Label Description: Reason for failure status. For sucessess and attempted it will be Empty
Example: proc_pdu_not_established, proc_pdu_ctx_not_found, n2ho_ie_validation_failed, n2ho_n4_ho_preparing_failed, n2ho_n4_ho_prepared_failed, n2ho_n4_ho_completed_failed, n2ho_ho_cancelled, n2ho_resource_alloc_unsuccess_transfer, n2ho_invalid_state, n2ho_preparation_unsuccess_transfer, n2ho_n1n2_transfer_failure, n2ho_dft_intra_amf, n2ho_dft_inter_amf, n2ho_idft_intra_amf, n2ho_idft_inter_amf, n2ho_default_flow_failed, n2ho_n2_decode_failiure, n2ho_chf_update_failure, n2ho_invalid_response, xnho_tobe_switched_flag_not_set, xnho_dl_tunnel_info_not_found, xnho_invalid_accepted_qfi_list, xnho_n4_modification_failed, xnho_n1n2_transfer_failure//NotUsedtoberemoved, xnho_n2_decode_failiure, xnho_pdu_state_error, n26ho_4g_5g_n1n2_transfer_failure, n26ho_4g_5g_invalid_state, n26ho_4g_5g_n4_failed_prepared_state, n26ho_4g_5g_resource_alloc_unsuccess_transfer, n26ho_4g_5g_timedout_in_post_exec_state, n26ho_4g_5g_n4_failed_completed_state, n26ho_4g_5g_handover_cancelled, n26ho_4g_5g_send_n4mod_failed_preparing_state, n26ho_4g_5g_n4mod_rsp_failed_preparing_state, n26ho_4g_5g_n4mod_rsp_timeout_preparing_state, n26ho_4g_5g_im_mobility_send_n4mod_failed, n26ho_4g_5g_im_mobility_n4mod_rsp_failed, n26ho_4g_5g_im_mobility_n4mod_rsp_timeout, n26ho_4g_5g_invalid_eps_pdn_connlist, n26ho_4g_5g_udm_reg_failed, n26ho_4g_5g_dft, n26ho_4g_5g_idft, n26ho_5g_4g_dft, n26ho_5g_4g_idft, n26ho_5g_4g_ctxrtrive_rec_for_4g_session, n26ho_5g_4g_handover_cancel, n26ho_4g_5g_no_eps_5gs_continuity, n26ho_default_flow_failed, n26ho_n2_decode_failiure, n26ho_chf_update_failure, n26im_mobility_4g_5g_no_eps_5gs_continuity, n26im_mobility_4g_5g_default_eps_bearer_inactive, pduim_n1n2_transfer_failure, pduim_n2_setup_response_failure, pduim_n1n2_txfr_failure_notification, pduim_n4_modification_failed, pduim_misc_error, pduim_n1n2ack_decode_error, pduim_n1n2ack_unhndl_cause, pduim_n1n2ack_unhndl_rsp_code, pduim_n1n2ack_unhndl_prb_cause, pduim_suspended_procedure, pduim_amf_ctx_not_found, pduim_internal_error, pduim_upstate_not_in_deactivated_state, pduim_pdu_access_type_mismatch, pduim_pdu_gnb_tunnel_not_available, pduim_pdu_n4_deactivated_state, pduim_sla_timer_expired, pduim_temp_reject_max_retry, upf_failure, pcf_failure, idft_release_failure, access_4g_already, idft_setup_failure, mbr_setup_failure, sgw_failure, udm_registration_failure, udm_subscription_fetch_failure, udm_subscribe_notify_failure, udm_update_notify_failure, aaa_subscribe_auth_failure, aaa_framed_ip_addr_conflict, pcf_create_failure, pcf_update_failure, charging_data_failure, no_rule_matched, invalid_protocol, invalid_dst_mask, invalid_src_mask, invalid_5qi, invalid_arp, invalid_other, internal_error, invalid_ebi, invalid_framed_ipv6_pfx_length, invalid_acct_sess_id_radius_dm, reason_unknown, invalid_rat_type, session_associated_to_online_chf, session_not_in_state, unknown, n4_release_failed, gtpu_peer_path_failed, rel_received_for_non_5g_session, qfi_failed_to_setup, utn3gppto5gho_n4_failed_completed_state, utn3gppto5gho_n4_failed_prepared_state, utn3gppto5gho_resource_alloc_unsuccess_transfer, utn3gppto5gho_invalid_state, utn3gppto5gho_policy_update_failure, utn3gppto5gho_charging_update_failure, utn3gppto5gho_n1n2_transfer_failure, utn3gppto5gho_pcf_update_failed_post_ho, utn3gppto5gho_chf_update_failed_post_ho, utn3gppto5gho_n4_failed_post_ho, utn3gppto5gho_del_bearer_failed, utn3gppto5gho_partial_flow_failure, utn3gppto5gho_default_flow_failed, utn3gppto5gho_eps_fallback, utn3gppto5gho_setup_unsuccess_transfer, utn3gppto5gho_fail_due_n2msg_rsp_not_rcvd, utn3gppto5gho_ctxt_create_res_failure, utn3gppto5gho_invalid_ctxt_create_req, utn3gpp_epsfallback_failed_during_5g_4g_ho, utn3gpp_epsfallback_failed_guard_timer_expiry, nr_to_untrusted_wifi_invalid_sess_state, nr_to_untrusted_wifi_invalid_json, nr_to_untrusted_wifi_invalid_paa, nr_to_untrusted_wifi_invalid_msg, nr_to_untrusted_wifi_pcf_failed, nr_to_untrusted_wifi_n40_failed, nr_to_untrusted_wifi_n4_failed, nr_to_untrusted_wifi_pcf_failed_post_cb, nr_to_untrusted_wifi_n40_failed_post_cb, nr_to_untrusted_wifi_n4_failed_post_cb, nr_to_untrusted_wifi_cbr_failed, nr_to_untrusted_wifi_ubr_failed, nr_to_untrusted_wifi_cb_res_failed, nr_to_untrusted_wifi_n1n2_release_failed, nr_to_untrusted_wifi_n4_failed_post_ho, nr_to_untrusted_wifi_pcf_update_failed_post_ho, nr_to_untrusted_wifi_chf_update_failed_post_ho, nr_to_untrusted_wifi_sla_timer_expired, nr_to_untrusted_wifi_dbr_failed, enb_to_untrusted_wifi_to_enb_ho_reject, enb_to_untrusted_wifi_to_enb_invalid_sess_state, enb_to_untrusted_wifi_to_enb_invalid_json, enb_to_untrusted_wifi_to_enb_invalid_paa, enb_to_untrusted_wifi_to_enb_invalid_msg, enb_to_untrusted_wifi_to_enb_udm_failed, enb_to_untrusted_wifi_to_enb_pcf_failed, enb_to_untrusted_wifi_to_enb_n40_failed, enb_to_untrusted_wifi_to_enb_n4_failed, enb_to_untrusted_wifi_to_enb_pcf_failed_post_cb, enb_to_untrusted_wifi_to_enb_mbr_failed, enb_to_untrusted_wifi_to_enb_n4_failed_post_mbr, enb_to_untrusted_wifi_to_enb_n40_failed_post_cb, enb_to_untrusted_wifi_to_enb_n4_failed_post_cb, enb_to_untrusted_wifi_to_enb_n40_failed_post_db, enb_to_untrusted_wifi_to_enb_pcf_failed_post_db, enb_to_untrusted_wifi_to_enb_cbr_failed, enb_to_untrusted_wifi_to_enb_dbr_failed, enb_to_untrusted_wifi_to_enb_ubr_failed, dsr_target_rat_rejected, upip_req_denied_in_rat, nr_to_untrusted_wifi_upip_status_req_denied_in_rat, pcrf_create_failure, cbr_fail_upstate_inactive, ubr_fail_upstate_inactive, pdnrel_conditional_ie_missing, pdn_create_over_created_pdn, interplmn_ho_not_configured, dtssa_acscr_not_supported, ho2ro_invalid_state, ro2ho_invalid_state, mbc_retransmit_msg, change_notification_retransmit_msg
Label:
emergency_call
Label Description: Flag indicating if it is an emergency call
Label:
rat_type
Example: EUTRA, NR, WLAN, rat_type_unknown
Label:
roaming_status
Label:
up_state
Label Description: Userplane connection status of the session
Example: UpState_None, UpState_Establishing, UpState_Activating, UpState_Activated, UpState_Deactivating, UpState_Deactivated, UpState_Modifying, UpState_Deleting, UpState_Deleted
Label:
qos_5qi
Label Description: 5Qi applicable for the QoS flow
Example: 1, 2, 5
Label:
always_on
Example: enable, disable
Label:
dcnr
Label Description: UE DCNR status
Label:
smf_current_procedure
Label Description: Current Procedure Name for Message Level Stats
Example: DedBearerProc, eps_fb_ded_brr, ue_req_ded_brr_mod, udm_req_ded_brr_mod, smf_req_ded_brr_del, upf_req_ded_brr_del, mme_req_ded_brr_del, mme_req_ded_brr_mod, pcf_req_ded_brr_mod, pcf_req_ded_brr_create, pcf_req_ded_brr_delete
Label:
fourg_only_ue
Label Description: Only 4g capable UE flag
Label:
pra
Label Description: Presence Reporting Area Information
Example: enable, none
Label:
upip_active
Label Description: UPIP activated for the session or not
Label:
local_policy
Label Description: Flows or Bearers created based on local policy config
SMF Procedure Collision Category
smf_procedure_collision
Description: Total number of procedures collided
Sample Query: sum(smf_procedure_collision) by (smf_current_procedure, smf_current_state, smf_new_procedure, smf_current_procedure_action)
Labels:
Label:
Label:
smf_current_state
Label Description: Current Procedure State
Example: DEDICATED BEARER: Await N7 Policy Update, PDN5G4GHO: Await UPF Modify Response, 4G RELEASE: Idle, MODIFY: Await N2 Update, RELEASE: Await PCF Delete, SETUP: Post UPF Modify
Label:
smf_new_procedure
Label Description: New Procedure Name
Label:
Label Description: Current Procedure Action on Collision
Example: Ignore, Suspend, Resume, Abort, Cleanup, Continue, Ready, INVALID ACTION
SMF Procedure Total Time Statistics Category
smf_procedure_seconds
Description: Total number of seconds taken to complete the procedure
Sample Query: 'smf_procedure_seconds{smf_proc_status="Aborted"}'
Labels:
Label:
smf_proc_type
Label:
smf_proc_status
Label Description: Procedure Status
Example: Queued, Running, Aborted, Suspended, Invalid, Cleanedup, RequireSuspend, RequireCleanup, RequireAbort, ProcStatusComplete, Unknown
SMF Protocol message counters Category
smf_proto_udp_msg_total
Description: SMF Protocol message statistics
Sample Query: 'smf_proto_udp_msg_total{message_direction="inbound",nf_type="amf"}'
Labels:
Label:
message_name
Label Description: name of N4 interface message
Example: n4_session_establishment_req, n4_session_establishment_res, n4_session_modification_req, n4_session_modification_res, n4_session_report_req, n4_session_report_res, n4_session_deletion_req, n4_session_deletion_res, n4_association_setup_req, n4_association_setup_res, n4_association_update_req, n4_association_update_res, n4_association_release_req, n4_association_release_res, n4_prime_pfd_management_req, n4_prime_pfd_management_res, n4_heartbeat_req, n4_heartbeat_res, n4_node_report_req, n4_node_report_res
Label:
message_direction
Label Description: direction of message from SMF perspective
Example: inbound, outbound
Label:
status
Label Description: status of message processing
Example: accepted, denied, discarded
SMF RAN failed stats Category
smf_ran_failed_flows
Description: Stats for the failed QFIs sent in UE Sync
Sample Query: 'smf_ran_failed_flows{procedure_type="pdu_ue_sync_proc"}'
Labels:
Label:
procedure_type
Label Description: The procedure type associated with an call flow procedure
Example: pdu_ue_sync_proc
Label:
reason
Label Description: The reason associated with failure
Example: qfi_failed_to_setup
SMF RSRA stats Category
smf_service_rsra_stats
Description: Stats for SMF Service RSRA
Sample Query: 'smf_service_rsra_stats{rat_type="NR"}'
Labels:
Label:
procedure_type
Label Description: The RSRA procedure type
Example: router_advt_solicit_request, router_advt_unsolicit_request, router_solicit_request
Label:
status
Label Description: status of RSRA
Example: failed, sent, retransmit, received
Label:
rat_type
Label Description: Type of the radio access associated with the request
Label:
upf_ep_key
Label:
reason
Label Description: reason for the failed status
Example: userplane_error, ho_in_progress, ipc_failed, userplane_error, encode_failed, decode_failed
SMF Secondary RAT Usage Report Stats Category
smf_secondary_rat_usage_report_stats
Description: Stats for SMF Secondary RAT Usage Report
Sample Query: 'smf_secondary_rat_usage_report_stats{rat_type="NR"}'
Labels:
Label:
status
Label Description: Status of Sec RAT Usage Report
Example: ReceivedFromSgw
Label:
reason
Label Description: The reason associated with status
Example: success
Label:
rat_type
Example: NR
Label:
ebi
Label Description: ebi number as string
Example: unsigned int as string or NA
Label:
qfi
Label Description: qfi number as string
SMF Service Node Report Stats Category
smf_service_node_report_stats
Description: Stats for SMF Service Node Report
Sample Query: 'smf_service_node_report_stats{procedure_type="upf_node_report_pdu_sess_rel"}'
Labels:
Label:
procedure_type
Label Description: The SMF procedure type
Example: upf_node_report_pdu_sess_rel, upf_node_report_pdn_sess_rel
Label:
status
Label Description: Status of SMF Service Node Report
Example: attempted, failures, success
Label:
pdu_type
Label:
rat_type
Label:
up_state
Label:
peer_gtpu_ep_key
Label Description: GTP Peer
Example: IP String
Label:
upf_endpoint
SMF Service Resource Management Stats Category
smf_service_resource_mgmt_stats
Description: SMF Service Resource Management Stats
Sample Query: 'smf_service_resource_mgmt_stats{ip_req_type="ip-alloc",pdu_type="ipv4",dnn="dnn1"}'
Labels:
Label:
ip_req_type
Label:
procedure_type
Example: pdu_sess_create, ue_req_pdu_sess_mod, smf_req_pdu_sess_mod, pcf_req_pdu_sess_mod, udm_req_pdu_sess_mod, gnb_req_pdu_sess_mod, ue_req_pdu_sess_rel, smf_req_pdu_sess_rel, pcf_req_pdu_sess_rel, amf_req_pdu_sess_rel, udm_req_pdu_sess_rel, gnb_req_pdu_sess_rel, chf_req_pdu_sess_rel, admin_req_pdu_sess_rel, ue_req_active_to_idle, ue_req_idle_to_active, nw_req_service_active, upf_notify_downlink_data, xn_path_switch,pdn_sess_create,pdn_5g_4g_handover,pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, n2_handover, xn_handover, n26_4g_to_5g_handover, n26_4g_to_5g_im_mobility, pdu_im, pdn_sess_create, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, pcf_initiated_pdn_detach, smf_initiated_pdn_detach, upf_initiated_pdn_detach, smf_eps_fb, Cleanuplocal
Label:
status
Label Description: status of resource management request
Label:
pdu_type
Label:
dnn
Example: Any string
Label:
emergency_call
Example: true, false
Label:
rat_type
SMF Service gtpc cache statistics Category
smf_service_gtpc_cache_stats
Description: SMF Service gtpc cache counters
Sample Query: 'smf_service_gtpc_cache_stats{gr_instance_id="1"}'
Labels:
Label:
smf_proc_type
Example: eps_fb_ded_brr, ue_req_ded_brr_mod, udm_req_ded_brr_mod, smf_req_ded_brr_del, mme_req_ded_brr_del, mme_req_ded_brr_mod, mme_req_ded_brr_del, pcrf_req_ded_brr_create, pcf_req_ded_brr_create, pcrf_req_ded_brr_delete, pcf_req_ded_brr_delete, pcrf_req_ded_brr_mod, pcf_req_ded_brr_mod, ProcessNoStateMBR, suspend_acknowledgement
Label:
message_type
Label Description: GTPC Message Type
Example: CreateBearerReq, UpdateBearerReq, DeleteBearerReq, ModifyBearerResp, DeleteSessionResp, ModifyBearerResp, CreateSessionResp, SuspendAck,
Label:
gtpc_cache_operation
Label Description: GTPC cache operation
Example: add, delete
Label:
gr_instance_id
Label Description: GR instance ID
Example: Any string
SMF Session counters Category
smf_session_counters
Description: SMF current active Session counters
Sample Query: 'smf_session_counters{rat_type="NR",pdu_type="ipv4",dnn="dnn1",ssc_mode="ssc_mode_1"}'
Labels:
Label:
rat_type
Label:
pdu_type
Label:
dnn
Label:
ssc_mode
Label:
always_on
Label:
dcnr
Label:
emergency_call
Label:
fourg_only_ue
Label:
unauthenticated_supi
Label Description: indicates if SUPI is unauthenticated
Label:
pra
Label:
roaming_status
Label:
policy_type
Label Description: Policy type of the subscriber session
Example: pcf, pcrf, none
Label:
local_policy
SMF Session stats Category
smf_session_stats
Description: SMF Session stats counters
Sample Query: 'smf_session_stats{rat_type="NR",pdu_type="ipv4",dnn="dnn1",ssc_mode="ssc_mode_1",status="attempted"}'
Labels:
Label:
rat_type
Label:
pdu_type
Label:
dnn
Label:
ssc_mode
Label:
status
Label Description: PDU session status indicated at SMF
Example: attempted, success, setup
Label:
roaming_status
Label:
policy_type
SMF Start Procedure Statistics Category
smf_procedure_start
Description: Total number of procedures started
Sample Query: 'smf_procedure_start{smf_proc_type="PDN Connect"}'
Labels:
Label:
smf_proc_type
SMF Stop Procedure Statistics Category
smf_procedure_stop
Description: Total number of procedures stopped
Sample Query: 'smf_procedure_stop{smf_proc_type="PDU Session Establishment"}'
Labels:
Label:
smf_proc_type
Label:
smf_proc_status
SMF Timeout stats Category
smf_timeout_stats
Description: SMF Timeout stats
Sample Query: 'smf_timeout_stats{timeout_type="SessionSetupTimeout"}'
Labels:
Label:
timeout_type
Label Description: SMF Timeout type
Example: SessionSetupTimeout, SessionCallflowTimeout, SessionEpsFbTimeout, SessionPolicyRevalTimeout, SessionRsRaAdvTime, SessionModifyTimeout, SessionReleaseTimeout, SessionN2HoTimeout, SessionImTimeout, SessionDedBearerTimeout, SessionPdnSetupTimeout, SessionPdnDisconnectTimeout, SessionPdnModifyTimeout, SessionPduIdftTimeout, SessionPdu5G4GHandover, SessionNrToUnTrustWifiHOTimeout, Session4GWifi4GHOTimeout, SessionWifiTo4GHoMBReqTimeout, SessionRouterSolicitTimeout, SessionUsageReportTimeout, SessionPathSwitchTimeout, SessionN1N2RetryAfter, SessionPDUIMN1N2RetryAfter, SessionN2HoIdftTimeout, SessionN26HoIdftTimeout, SessionAbsoluteTimeout, SessionIwfN26IdftTimeout, SessionDedBrrReEstTimer, SessionDedBrrDelayTimer, Session4G5GN26Timeout, SessionN1N2RetryTimeout, SessionN1N2RetransTimeout, SessionPDUIMResumeTimeout, SessionUrrOutOfOrderWaitTimeout, SessionPduRelCmdRetryTimeout, SessionUnTrustWiFiToNrHOTimeout, SessionUbrRetryTimer, SessionDbrRetryTimer, SessionPduUeSyncTimeout, SessionAmfChangeGuardTimeout, SessionPduSetupProcSLA, SessionPduImProcSLA, ProcedureSlaTimeout, SessionN2HOProcSLA, SessionCatchAllTimeout, SessionIdleTimeout, SessionCpIdleTimeout, SessionTempRejectHoTimeout, SessionDefaultFlowOnlyTimeout, SessionErirDelayTimeout
SMF Total Timedout Procedure Count Category
smf_procedure_timeout
Description: Total number of procedures executed more than 10sec
Sample Query: 'smf_procedure_timeout{smf_proc_status="Running"}'
Labels:
Label:
smf_proc_type
Label:
smf_proc_status
Labels:
Label:
smf_proc_type
Label:
smf_proc_status
SMF Total Timedout Procedure Time Category
smf_procedure_timeout_seconds
Description: Total number of seconds taken by procedures executed more than 10sec
Sample Query: 'smf_procedure_timeout_seconds{smf_proc_status="Running"}'
Labels:
Label:
smf_proc_type
Label:
smf_proc_status
SMF Total Unhandled Event Statistics Category
smf_procedure_unhndl_event
Description: Total number of unhandled events per procedure type
Sample Query: 'smf_procedure_unhndl_event{smf_proc_type="PDU Session Release - SMF initiated"}'
Labels:
Label:
smf_proc_type
Label:
message_type
Label Description: Type of Request/Response Message associated with Unhandled Event
Example: N11SmContextUpdateSuccess, N11EbiAssignmentReq, N4HeartBeatFailure, S5CreateSessRsp, NLiSubscriberQueryReq, RadiusCoaDisconnectReq, N7SmPolicyUpdateSuccess
Label:
smf_current_state
Label:
guard_timer
Label Description: This is a check for Guard Timeout. TRUE if Guard Timer has expired, else FALSE
Example: TRUE, FALSE
SMF Total Unhandled Transaction Statistics Category
smf_procedure_unhndl_trans
Description: Total number of unhandled transactions per procedure type
Sample Query: 'smf_procedure_unhndl_trans{message_type="RadiusCoaDisconnectReq"}'
Labels:
Label:
smf_proc_type
Label:
message_type
Label Description: Type of Request/Response Message associated with Unhandled Transaction
Label:
smf_current_state
Label:
guard_timer
SMF User Plane Session counters Category
smf_up_session_counters
Description: SMF current active User Plane Sessions
Sample Query: 'smf_up_session_counters{pdu_type="ipv4",dnn="dnn1",ssc_mode="ssc_mode_1"}'
Labels:
Label:
rat_type
Label:
pdu_type
Label:
dnn
Example: Any string
Label:
ssc_mode
UDM Message Failure Action Stats Category
smf_udm_msg_fail_action
Description: Stats for UDM Message Failure Action
Sample Query: 'smf_udm_msg_fail_action{udm_msg="UdmRegistration"}'
Labels:
Label:
udm_msg
Label Description: Type of UDM Message
Example: UdmRegistration, UdmDeregistration, UdmSmSubscription, UdmSubscribeToNotify, UdmUnSubscribeToNotify
Label:
udm_failure_action
Label Description: Action taken on UDM Message failure
Example: ignore, continue, terminate
Label:
udm_end_point
Label Description: UDM Endpoint
Example: IP String
UDP RPC message statistics Category
udp_rpc_msg_stats
Description: Statistics for UDP RPC
Sample Query: 'sum (udp_rpc_msg_stats{gr_instance_id="1"})'
Labels:
Label:
msgtype
Label Description: message Type
Example: MessageNone, PfcpUdpProxyMsg, UdpProxyMsg, UnknownMsg
Label:
direction
Label Description: Direction of UDP RPC message
Label:
status
Example: success, failures
Label:
transport_type
Label Description: Transport type of message
Example: original, asyncmessage, retransmited,
Label:
gr_instance_id
Example: Any string
Label:
interface_type
Label Description: Type of Interface communicate with PGW
Example: pcf, pcrf
UDP Request Total Message Stats Category
smf_service_udp_req_msg_total
Description: Stats for Total UDP Request Messages
Sample Query: 'smf_service_udp_req_msg_total{status="attempted"}'
Labels:
Label:
message_type
Label Description: Type of UDP Message
Example: N4SessionEstablishmentReq
Label:
upf_endpoint
Label:
status
Label Description: Status of UDP Message
Label:
trans_type
Label Description: Transmission type of UDP Message
Example: trans_type_origin, trans_type_reselected
Label:
cause_code
Label Description: Causecode of UDP Message
Example: Reserved, Request_Accepted, Request_Rejected_Unspecified, Session_Ctx_Not_Found, Mandatory_IE_Missing, Cond_IE_Missing, Invalid_Length, Mandatory_IE_Incorrect, Invalid_FW_Policy, Invalid_FTEID_Alloc_Opt, No_Established_PFCP_Assc, Rule_Creation_Mod_Failure, PFCP_Entity_In_Congestion, No_Resource_Available, Service_Not_Supported, System_failure, No_Response, Duplicate_Userplane_Id, OutOfRange_Userplane_Id
UPF selection stats Category
upf_selection_stats
Description: Stats for the UPF Selection
Sample Query: 'upf_selection_stats{upf_selection_type="preferred"}'
Labels:
Label:
upf_selection_type
Label Description: Type of UPF Selection
Example: preferred
Label:
upf_fqdn
Label Description: FQDN of the UPF selected
Example: string
Label:
status
Label Description: Status the UPF selected
Example: attempted, failed
Label:
reason
Label Description: Reason for status of the UPF selected
Example: upf_not_associated, upf_profile_not_found, upf_not_active
Label:
dnn
Example: Any string
Label:
rat_type
Label:
pdu_session_type
Label Description: PDU Session type
Label:
pdu_subscription_type
Label Description: PDU Subscription type
Label:
snssai
Label Description: SNSSAI of the session having sd and sst
Example: sd:<string> sst:<uint>
