gtpc-ep
gtpc-ep Metrics Reference
GTPC Golang Enc Dec Stats Category
gtpc_golang_enc_dec_stats
Description: GTPC Golang Enc Dec Stats
Sample Query: 'gtpc_golang_enc_dec_stats{namespace="$namespace"}'
Labels:
Label:
gtpc_msg_type
Label Description: Gtpc Message type
Example: ModifyBearerReq, ModifyBearerRes etc
Label:
gtpc_interface_type
Label Description: Interface type
Example: S5, S11, S5E, S2B, S8
Label:
gtpc_msg_operation
Label Description: Operation
Example: encode, decode
Label:
gtpc_msg_status
Label Description: Status
Example: success, error
GTPC Roaming Peer Path Mgmt Stats Category
gtpc_roaming_peer_path_mgmt
Description: GTPC Roaming Peer Path Mgmt Stats
Sample Query: 'gtpc_roaming_peer_path_mgmt{service_name="gtpc-ep",status="suppressed"}'
Labels:
Label:
gtpc_peer_type
Label Description: Gtpc Peer type
Example: ROAMER
Label:
gtpc_interface_type
Label:
gtpc_msg_type
desciption: Gtpc Message type
Example: gtpc_echo_req, gtpc_echo_res
label:
gtpc_msg_status
Description: Status
Example: suppressed
GTPC Short Circuit Map Count Category
gtpc_short_circuit_map_count
Description: GTPC Short Circuit MBReq Map Gauge
Sample Query: 'gtpc_short_circuit_map_count{gtpc_msg_type="RxModifyBearerReq"}'
Labels:
Label:
gtpc_msg_type
Example: RxModifyBearerReq
GTPC Short Circuit Message Stats Category
gtpc_msg_short_circuit_stats
Description: GTPC Short Circuit MBResp Stats
Sample Query: 'gtpc_msg_short_circuit_stats{gtpc_msg_type="TxModifyBearerRes"}'
Labels:
Label:
gtpc_msg_type
Example: TxModifyBearerRes
Label:
gtpc_short_circuit_category
Label Description: Category
Example: WithServingNetwork, WithIndication, WithBearerContext
Processing Time of SMF GTPC Messages Category
gtpc_msg_seconds
Description: Time taken for GTPC message processing
Sample Query: 'gtpc_msg_seconds{message_name="S5S8_MSG_CREATE_SESSION_REQUEST"}'
Labels:
Label:
message_name
Label Description: Message Name
Example: S5S8_MSG_CREATE_SESSION_REQUEST, S5S8_MSG_CREATE_SESSION_RESPONSE, S5S8_MSG_MODIFY_BEARER_REQUEST, S5S8_MSG_MODIFY_BEARER_RESPONSE, S5S8_MSG_DELETE_BEARER_REQUEST, S5S8_MSG_DELETE_BEARER_RESPONSE, S5S8_MSG_DELETE_SESSION_REQUEST, S5S8_MSG_DELETE_SESSION_RESPONSE
Label:
message_direction
Label Description: Direction
Example: inbound, outbound
Label:
status
Example: no_rsp_received_tx, accepted
Label:
transport_type
Label Description: Transport Type
Example: origin, retransmitted
SMF GTPC Echo Stats Category
gtpc_echo_msg_stats
Description: GTPC Echo Req Rx and Echo Resp Tx
Sample Query: 'gtpc_echo_msg_stats{gtpc_msg_type="gtpc_echo_req_rx"}'
Labels:
Label:
gtpc_peer_ip
Label Description: Gtpc Peer IP of nodes like SGW,ePDG etc
Example: 1.2.3.4
Label:
gtpc_msg_type
Example: gtpc_echo_req_rx, gtpc_echo_res_tx
SMF GTPC Golang Encode Decode Stats Category
Description: Messages Encoded/Decoded using Golang
Sample Query: 'gtpc_golang_enc_dec_stats{gtpc_msg_type="RxModifyBearerReq"}'
Labels:
Label:
gtpc_msg_type
Example: RxModifyBearerReq, TxModifyBearerRes
Label:
gtpc_msg_len
Label Description: Message Length
Example: 36, 24, 45
Label:
gtpc_msg_operation
Label:
gtpc_msg_status
Label:
gtpc_msg_status_cause
Label Description: Error Cause
Example: HeaderDecodeFailure, ParseIEsFromPayloadFailure, MBRFromIEFailure
SMF GTPC Messages Total Category
gtpc_msg_total
Description: Total GTPC Messages
Sample Query: 'gtpc_msg_total{message_name="S5S8_MSG_CREATE_SESSION_REQUEST"}'
Labels:
Label:
message_name
Label:
message_direction
Label:
status
Label:
transport_type
SMF GTPC Unexpected Messages Category
gtpc_app_total_unexpected_gtpc_msg_events
Description: Unexpected GTPC Messages received
Sample Query: 'gtpc_app_total_unexpected_gtpc_msg_events{service_name="gtpc-ep"}'
Labels:
Label:
message_type
Example: unexpected_gtpc_message
Label:
interface_type
Label Description: Gtpc Interface type
Example: sgw_ingress, pgw_ingress
SMF GTPC Validation Fail Stats Category
gtpc_app_validation_events
Description: Stats of Message decode failures
Sample Query: 'gtpc_app_validation_events{service_name="gtpc-ep"}'
Labels:
Label:
message_type
Example: csreq, csrsp, mbreq, mbrsp, cbreq, cbrsp, ubreq, ubrsp, dbreq, dbrsp, dsreq, dsrsp, mbcmd, mbcfi, dbcmd, dbcfi, ddnfi, ddnack, rabreq, upcreq
Label:
interface_type
Label:
failure_type
Label Description: Failure Type
Example: msg_validation_fail, hdr_decode_failure
Label:
hdr_decode_fail_reason
Label Description: Header Decode Fail Reason
Example: incorrect_gtp_version, unsupported_message, incorrect_msg_len, invalid_msg_format, invalid_seq_no
Label:
action_type
Label Description: Action Type
Example: discarded, rejected
Label:
reject_cause
Label Description: Reject Cause
Example: invalid_msg_format, version_not_supported, invalid_len, mandatory_ie_missing, conditional_ie_missing, mandatory_ie_incorrect, service_not_supported, imsi_imei_not_known, preferred_pdn_type_unsupported, unknown
SMF GTPC messages Category
gtpc_app_events
Description: GTPC message counter
Sample Query: 'gtpc_app_events{service_name="gtpc-ep"}'
Labels:
Label:
event_type
Label Description: Gtpc Event type
Example: NumRxCreateSessionReq, NumTxCreateSessionRes, NumRxDeleteSessionReq, NumTxDeleteSessionRes, NumRxModifyBearerReq, NumTxModifyBearerRes, NumTxDeleteBearerReq, NumRxDeleteBearerRsp, NumTxCreateBearerReq, NumRxCreateBearerRes, NumTxUpdateBearerReq, NumRxUpdateBearerRes, NumTxModifyBearerFailureInd, NumModifyBearerTimeout, NumRxDeleteBearerCmd, NumCreateBearerFailure, NumCreateBearerSuccess, NumCreateSessionSuccess, NumCreateSessionFailure, NumDeleteSessionSuccess, NumDeleteSessionFailure, NumCreateBearerReqRetrans, NumUpdateBearerReqRetrans, NumDeleteBearerReqRetrans
Label:
interface_type
SMF GTPC priority messages Category
gtpc_app_priority_events
Description: GTPC priority message counter
Sample Query: 'gtpc_app_priority_events{service_name="gtpc-ep"}'
Labels:
Label:
event_type
Label:
priority_msg
Label Description: priority
Example: true
Label:
interface_type
