SMF Metrics
chf-service Metrics Reference
CCF Data Consistency Check Category
ccf_datacheck_stats
Description: Total number of sessions checked for consistency
Sample Query: 'ccf_datacheck_stats{rat_type="NR", status="failed"}'
Labels:
  • Label: procedure_type
    Label Description: Procedure Name
    Example: N40 Charging Data Request Create, N40 Charging Data Request Release SMF Initiated, N40 Session Modify SMF Initiated, N40 Session Notify - Abort,N40 Session Notify - Reauth, N28 Spending Limit Subscribe, N28 Spending Limit Subscribe Update, N28 Spending Limit UnSubscribe, N28 Spending Limit Notify Status, N28 Spending Limit Terminate Status, N28 Next Reval Notify, N40 Next Reval Notify
  • Label: rat_type
    Label Description: Type of the radio access associated
    Example: EUTRA, NR, WLAN, VIRTUAL, rat_type_unknown
  • Label: pdu_type
    Label Description: Type of PDU session
    Example: ipv4, ipv6, ipv4v6, unknown
  • Label: status
    Label Description: Procedure status after data consistency check
    Example: success, failed
  • Label: reason
    Label Description: Failure reason of data inconsistency
    Example: String format for failed reason
CCF Procedure Category
ccf_service_stats
Description: CCF call flow procedure counters
Sample Query: 'ccf_service_stats{procedure_type="pdu_sess_create"}'
Labels:
    Label Description: The procedure type associated with an call flow procedure
    Example: pdu_sess_create, smf_req_pdu_sess_mod, smf_req_pdu_sess_rel, pdu_sess_notify_abort, pdu_sess_notify_reauth, spending_limit_notify_terminate, spending_limit_notify_status, spending_limit_create, spending_limit_update, spending_limit_delete
  • Label: status
    Label Description: call flow procedure counter
    Example: attempted, success, failures
  • Label: dnn
    Label Description: Dnn configured in dnn-policy, also can have virtual_dnn if configured, separated by #
    Example: intershat, intershat#cisco.com
  • Label: reason
    Label Description: Reason for failure status. For sucessess and attempted it will be Empty
    Example: proc_pdu_not_established, proc_pdu_ctx_not_found, internal_error, reason_unknown, pdn_create_over_created_pdn, auth_grpc_failed, maintenance_mode, quota_grpc_failed, auth_failed, cc_relay_failed
  • Label: rat_type
    Label Description: RAT Type of the Session
    Example: EUTRA, NR, WLAN, rat_type_unknown
  • Label: roaming_status
    Label Description: Roaming status of the subscriber session
    Example: IN_BOUND, OUT_BOUND, none
  • Label: ccf_current_procedure
    Label Description: Current Procedure Name for Message Level Stats
    Example:
CCF Procedure Collision Category
ccf_procedure_collision
Description: Total number of procedures collided
Sample Query: sum(ccf_procedure_collision) by (ccf_current_procedure, ccf_current_state, ccf_new_procedure, ccf_current_procedure_action)
Labels:
    Example: PDU Session Release - SMF initiated, PDU 5G to 4G Handover, PDU Session Modify - PCF initiated, PDU UE Sync Procedure, PDU Idle Mode Entry - RAN initiated
  • Label: ccf_current_state
    Label Description: Current Procedure State
    Example: String format for procedure stat
  • Label: ccf_new_procedure
    Label Description: New Procedure Name
    Example: String format for new procedure
  • Label: ccf_current_procedure_action
    Label Description: Current Procedure Action on Collision
    Example: Ignore, Suspend, Resume, Abort, Cleanup, Continue, Ready, INVALID ACTION
CCF Procedure Total Time Statistics Category
ccf_procedure_seconds
Description: Total number of seconds taken to complete the procedure
Sample Query: 'ccf_procedure_seconds{ccf_proc_status="Aborted"}'
Labels:
  • Label: ccf_proc_type
  • Label: ccf_proc_status
    Label Description: Procedure Status
    Example: Queued, Running, Aborted, Suspended, Invalid, Cleanedup, RequireSuspend, RequireCleanup, RequireAbort, ProcStatusComplete, Unknown
CCF Start Procedure Statistics Category
ccf_procedure_start
Description: Total number of procedures started
Sample Query: 'ccf_procedure_start{ccf_proc_type="PDN Connect"}'
Labels:
CCF Stop Procedure Statistics Category
ccf_procedure_stop
Description: Total number of procedures stopped
Sample Query: 'ccf_procedure_stop{ccf_proc_type="PDU Session Establishment"}'
Labels:
CCF Total Procedure Count Category
ccf_procedure_total
Description: Total number of procedures executed
Sample Query: 'ccf_procedure_total{ccf_proc_status="Running"}'
Labels:
CCF Total Timedout Procedure Count Category
ccf_procedure_timeout
Description: Total number of procedures executed more than 10sec
Sample Query: 'ccf_procedure_timeout{ccf_proc_status="Running"}'
Labels:
CCF Total Timedout Procedure Time Category
ccf_procedure_timeout_seconds
Description: Total number of seconds taken by procedures executed more than 10sec
Sample Query: 'ccf_procedure_timeout_seconds{ccf_proc_status="Running"}'
Labels:
CCF Total Unhandled Event Statistics Category
ccf_procedure_unhndl_event
Description: Total number of unhandled events per procedure type
Sample Query: 'ccf_procedure_unhndl_event{ccf_proc_type="PDU Session Release - SMF initiated"}'
Labels:
  • Label: message_type
    Label Description: Type of Request/Response Message associated with Unhandled Event
    Example: String format for event details
    Example: String format for procedure state
  • Label: guard_timer
    Label Description: This is a check for Guard Timeout. TRUE if Guard Timer has expired, else FALSE
    Example: TRUE, FALSE
CCF Total Unhandled Transaction Statistics Category
ccf_procedure_unhndl_trans
Description: Total number of unhandled transactions per procedure type
Sample Query: 'xxf_procedure_unhndl_trans{message_type="RadiusCoaDisconnectReq"}'
Labels:
    Label Description: Type of Request/Response Message associated with Unhandled Transaction
CCF Usage Report Stats Category
ccf_usage_trigger_stats
Description: The current count for Used unit Container Recieved from SMF
Sample Query: 'ccf_usage_trigger_stats{ccf_proc_type="N40 Session Modify SMF Initiated"}'
Labels:
  • Label: rating_group
    Label Description: Rating Group for which usage is being reported
    Example: Any string
  • Label: service_identifier
    Label Description: Service Identifier for which usage is being reported
    Example: Any string
    Label Description: Which kind of procedure usage is reported to CCF
    Example: Some String
  • Label: trigger
    Label Description: Trigger associated with UUC
    Example: Triggers defined as per Specs 32.291
SLA Transaction Category
ccf_sla_transaction_stats
Description: Transaction SLA stats
Sample Query: sum(ccf_sla_transaction_stats) by (ccf_sla_transaction_stats,ccf_proc_type,status, message_type)
Labels:
  • Label: status
    Label Description: gives status of the procedure
    Example: Queued, Running, Aborted, Suspended, Invalid, Cleanedup, RequireSuspend, RequireCleanup, RequireAbort, Unknown
    Label Description: gives the message type received during sla transaction
    Example: IntSelfTxnSla
diameter-ep statistics Category
diam_base_msg_seconds_total
Description: Cumulative response time in seconds of diameter base message requests processed by diameter endpoint
Sample Query: 'diam_base_msg_seconds_total{message_name="DPR"}'
Labels:
  • Label: message_name
    Label Description: name of interface message
    Example: DPR
  • Label: origin_host
    Label Description: name of the origin host
    Example: 192.168.169.107
  • Label: origin_realm
    Label Description: name of the origin realm
    Example: xyz.com
  • Label: disconnect_cause
    Label Description: reason for the disconnection
    Example: REBOOTING, BUSY, DO_NOT_WANT_TO_TALK_TO_YOU
  • Label: result_code
    Label Description: result_code describes the error that the diameter node encountered in its processing
    Example: 2001, 5012
  • Label: gr_instance
    Label Description: GR Instance ID
    Example: 1 or 2
diam_base_msg_total
Description: Count of diameter base message requests processed by diameter endpoint
Sample Query: 'diam_base_msg_total{message_name="DPR"}'
Labels:
    Example: DPR
    Example: xyz.com
    Example: 2001, 5012
    Example: 1 or 2
diameter_decode_message_total
Description: Count of decoding done by diameter endpoint
Sample Query: 'diameter_decode_message_total{interface="gx"}'
Labels:
  • Label: interface
    Label Description: name of the interface
    Example: gx, gy
Labels:
    Example: ccai, ccau, ccat, rar, asr
  • Label: endpoint_name
    Label Description: name of endpoint profile used during processing
    Example: gxProf1
  • Label: dict_name
    Label Description: name of the dictionary used
    Example: gx_cust
  • Label: status
    Label Description: status of the request
    Example: success, failure, partial
  • Label: unknown_avp
    Label Description: unknown_avp indicates if any unknow AVPs were found during encoding where 0 indicates not found and 1 indicates found
    Example: 0,1
    Example: 1 or 2
diameter_encode_message_total
Description: Count of encoding done by diameter endpoint
Sample Query: 'diameter_encode_message_total{interface="gx"}'
Labels:
  • Label: interface
    Example: gx, gy
Labels:
    Example: ccri, ccru, ccrt, raa, asa
Labels:
    Example: gxProf1
  • Label: dict_name
    Example: gx_cust
  • Label: status
    Example: 0,1
    Example: 1 or 2
diameter_pod_status
Description: Pod status as active/standby
Sample Query: 'diameter_pod_status{vip="10.0.0.1"}'
Labels:
  • Label: vip
    Label Description: any ip
    Example: 10.0.0.1
diameter_request_message_total
Description: Count of diameter requests processed by diameter endpoint
Sample Query: 'diameter_request_message_total{interface="gx"}'
Labels:
  • Label: interface
    Example: gx, gy
Labels:
    Example: ccri, ccru, ccrt, rar, asr
Labels:
  • Label: peer_address
    Label Description: peer_address will be empty for inbound requests, could be empty for outbound requests depending on point of failure
    Example: 10.1.2.110:3868
Labels:
  • Label: status
    Example: attempted, peer_down, err_cfg, err_maxout, timeout_ipc, err_ipc, err_unmarshal
Labels:
  • Label: retry
    Label Description: retry count
    Example: 0
    Example: 1 or 2
  • Label: transaction_type
    Label Description: transaction type
    Example: origin
    Example: gxProf1
  • Label: message_direction
    Label Description: direction of message from Diameter perspective
    Example: inbound, outbound
diameter_response_message_seconds_total
Description: Cumulative response time in seconds of diameter requests processed by diameter endpoint
Sample Query: 'diameter_response_message_seconds_total{interface="gx"}'
Labels:
  • Label: interface
    Example: gx, gy
Labels:
    Example: ccai, ccau, ccat, raa, asa
Labels:
Labels:
  • Label: status
    Example: success, err_cfg, err_maxout, err_send, timeout_res, timeout_ipc, err_ipc, err_unmarshal, err_rc, err_exp_rc
Labels:
    Label Description: result_code describes the result-code or experimental-result-code that the diameter node encountered during response processing
    Example: 1001, 2001, 3001, 4001, 5001
Labels:
  • Label: action
    Label Description: action
    Example: continue, terminate
Labels:
  • Label: sub_action
    Label Description: sub action
    Example: discard-traffic, local-fallback, retry-server-on-event, send-ccrt-on-call-termination, with-term-req, without-term-req
    Example: 1 or 2
    Example: gxProf1
diameter_response_message_total
Description: Count of diameter responses processed by diameter endpoint
Sample Query: 'diameter_response_message_total{interface="gx"}'
Labels:
  • Label: interface
    Example: gx, gy
Labels:
Labels:
Labels:
  • Label: status
Labels:
Labels:
  • Label: action
Labels:
  • Label: sub_action
Labels:
    Example: 1 or 2
Labels:
    Example: gxProf1
Labels:
diameter_route_expires_total
Description: Count of all dynamic routes expired
Sample Query: 'diameter_route_expires_total{gr_instance="1"}'
Labels:
  • Label: route
    Label Description: route identified by host, realm and peer
    Example: OCS1:OCS.COM:DRA1
Labels:
  • Label: peer_name
    Label Description: peer name used by the route
    Example: DRA1
Labels:
    Example: 1 or 2
diameter_route_hits_total
Description: Count of all route hits for messages processed by diameter endpoint
Sample Query: 'diameter_route_hits_total{route_type="S"}'
Labels:
  • Label: route
Labels:
  • Label: route_type
    Label Description: type of the route
    Example: S or D
Labels:
  • Label: peer_name
    Example: DRA1
Labels:
  • Label: wild_carded_route
    Label Description: route with wild carded host or realm
    Example: *:OCS.COM:DRA1
Labels:
    Example: 1 or 2
diameter_route_misses_total
Description: Count of all route misses for messages processed by diameter endpoint
Sample Query: 'diameter_route_misses_total{route="OCS1:OCS.COM:DRA1"}'
Labels:
  • Label: route
Labels:
  • Label: route_type
    Example: S or D
Labels:
  • Label: peer_name
    Example: DRA1
Labels:
    Example: 1 or 2
diameter_route_status
Description: Status of a route
Sample Query: 'diameter_route_status{route="OCS1:OCS.COM:DRA1"}'
Labels:
  • Label: route
Labels:
  • Label: route_type
    Example: S or D
Labels:
  • Label: peer_name
    Example: DRA1
Labels:
    Example: 1 or 2
Labels:
  • Label: route_status
    Label Description: status of the route
    Example: Pending or Active or Inactive or Failed or Deleted or Expired or Cloned
{{- end}}
diameter_routes_total
Description: Count of all diameter routes added by diameter endpoint
Sample Query: 'diameter_routes_total{gr_instance="1"}'
Labels:
  • Label: route_type
    Example: S or D
Labels:
  • Label: peer_name
    Example: DRA1
Labels:
    Example: 1 or 2
dispatch_error_seconds_total
Description: Cumulative time in seconds spent during dispatching of inbound requests to service that had error or timeout
Sample Query: 'dispatch_error_seconds_total{gr_instance="1"}'
Labels:
  • Label: application
    Label Description: name of the application
    Example: diameter
Labels:
  • Label: command_code
    Label Description: command code
    Example: RAR
Labels:
  • Label: error_code
    Label Description: error code
    Example: 3002
Labels:
    Example: 1 or 2
dispatch_error_total
Description: Count of inbound requests that had error or timeout during dispatch to service
Sample Query: 'dispatch_error_total{gr_instance="1"}'
Labels:
    Example: diameter
Labels:
    Example: RAR
Labels:
  • Label: error_code
    Example: 3002
Labels:
    Example: 1 or 2
policy_engine_message_seconds_total
Description: Cumulative time in seconds spent during processing of message sent to service
Sample Query: 'policy_engine_message_seconds_total{gr_instance="1"}'
Labels:
    Example: diameter
Labels:
    Example: RAR
Labels:
    Example: 1 or 2
policy_engine_message_total
Description: Count of messages sent to service for which response is received
Sample Query: 'policy_engine_message_total{gr_instance="1"}'
Labels:
    Example: diameter
Labels:
    Example: RAR
Labels:
    Example: 1 or 2
dns-proxy Metrics Reference
DNS Lookup Request Statistics Category
DNS_Lookup_Requests_Statistics
Description: Total dns packets processed
Sample Query: 'DNS_Lookup_Requests_Statistics{dnsPacketDir="Rx",dnsProtocol="udp",dnsQueryType="ipv4",dnsResult="Success",dnsSvrIP="172.17.0.2",dnsSvrPort="53",grInstId="1"}'
Labels:
  • Label: dnsPacketDir
    Label Description: Direction
    Example: Tx, Rx
  • Label: dnsProtocol
    Label Description: Protocol
    Example: udp, tcp
  • Label: dnsQueryType
    Label Description: DNS Lookup Query type
  • Label: dnsResult
    Label Description: Result
    Example: Success, Failure, Timeout, Failure_No_Response
  • Label: dnsSvrIP
    Label Description: DNS Server IP Address
    Example: Any string
  • Label: dnsSvrPort
    Label Description: DNS Server Port
    Example: Any string
  • Label: grInstId
    Label Description: GR Instance Id
    Example: 1 or 2
gtpc-ep Metrics Reference
GTPC BGP Routed Count Stats Category
gtpc_app_bgp_routes_count
Description: BGP routes add counter
Sample Query: 'gtpc_app_bgp_routes_count{status="success"}'
Labels:
  • Label: status
  • Label: gr_instance_id
    Label Description: GR instance ID
    Example: 1, 2
GTPC Roaming Peer Path Mgmt Stats Category
gtpc_roaming_peer_path_mgmt
Description: GTPC Roaming Peer Path Mgmt Stats
Sample Query: 'gtpc_roaming_peer_path_mgmt{service_name="gtpc-ep",status="suppressed"}'
Labels:
  • Label: gtpc_peer_type
    Label Description: Gtpc Peer type
    Example: ROAMER, HOMER, VISITOR
  • Label: interface_type
    Label Description: Gtpc Interface type
    Example: S5, S11, S5E, S2B, S8
  • Label: gtpc_msg_type
    desciption: Gtpc Message type
    Example: NumEchoMsg, NumControlMsg
  • Label: status
    Label Description: Status
    Example: suppressed
    Example: 1, 2
GTPC Short Circuit Map Count Category
gtpc_short_circuit_map_count
Description: GTPC Short Circuit Map operation counter
Sample Query: 'gtpc_short_circuit_map_count{message_name="TxModifyBearerRes"}'
Labels:
    Label Description: Message Name
    Example: TxCreateBearerReq, TxUpdateBearerReq, TxDeleteBearerReq, TxModifyBearerRes, TxDeleteSessRsp, TxCreateSessionRsp, RecordExpired
  • Label: gtpc_short_circuit_map_operation
    Label Description: Gtpc short circuit counter type
    Example: increment, decrement
  • Label: gtpc_short_circuit_map_teid_changed
    Label Description: Gtpc short circuit teid cache operation type
    Example: added, updated, deleted
    Example: 1, 2
GTPC Short Circuit Message Stats Category
gtpc_msg_short_circuit_stats
Description: GTPC Short Circuit MBResp Stats
Sample Query: 'gtpc_msg_short_circuit_stats{gtpc_msg_type="RxModifyBearerReq"}'
Labels:
    Label Description: Gtpc Message type
    Example: RxModifyBearerReq, SkippingShortCircuit
  • Label: gtpc_short_circuit_category
    Label Description: Category
    Example: WithServingNetwork, WithIndication, WithBearerContext, MBREventExpired, SendSCMBResp, GetSCMBRespFailed, LastSequenceNumberSame
Processing Time of SMF GTPC Messages Category
gtpc_msg_seconds
Description: Time taken for GTPC message processing
Sample Query: 'gtpc_msg_seconds{message_name="S5S8_MSG_CREATE_SESSION_REQUEST"}'
Labels:
    Example: S5S8_MSG_CREATE_SESSION_REQUEST, S5S8_MSG_CREATE_SESSION_RESPONSE, S5S8_MSG_MODIFY_BEARER_REQUEST, S5S8_MSG_MODIFY_BEARER_RESPONSE, S5S8_MSG_DELETE_BEARER_REQUEST, S5S8_MSG_DELETE_BEARER_RESPONSE, S5S8_MSG_DELETE_SESSION_REQUEST, S5S8_MSG_DELETE_SESSION_RESPONSE
  • Label: status
    Example: no_rsp_received_tx, accepted
  • Label: transport_type
    Label Description: Transport Type
    Example: origin, retransmitted
    Example: 1, 2
Processing time of GTPC messages Category
gtpc_app_events_seconds
Description: Total time taken by GTPC messages
Sample Query: 'gtpc_app_events_seconds{event_type="csreq"}'
Labels:
  • Label: event_type
    Label Description: Gtpc Event type
    Example: csreq, mbreq, cbreq, ubreq, dbreq, dsreq, rabreq, cidftreq, didftreq, changenotfreq, mbreqlist
    Example: 1, 2
SGW TEID Cache Operation Stats Category
sgw_teid_cache_total
Description: SGW TEID cache operation counter
Sample Query: 'sgw_teid_cache_total{action="create"}'
Labels:
  • Label: action
    Label Description: TEID cache operation type
    Example: create, update, delete, cache_found, expired, no_cache, cache_full
    Example: 1, 2
SMF GTPC Echo Stats Category
gtpc_echo_msg_stats
Description: GTPC Echo Req Rx and Echo Resp Tx
Sample Query: 'gtpc_echo_msg_stats{gtpc_msg_type="gtpc_echo_req_rx"}'
Labels:
  • Label: gtpc_peer_ip
    Label Description: Gtpc Peer IP of nodes like SGW, ePDG etc.
    Example: 1.2.3.4
    Example: gtpc_echo_req_rx, gtpc_echo_res_tx
    Example: 1, 2
SMF GTPC Golang Encode Decode Stats Category
gtpc_golang_enc_dec_stats
Description: Messages Encoded/Decoded using Golang
Sample Query: 'gtpc_golang_enc_dec_stats{gtpc_msg_type="RxModifyBearerReq"}'
Labels:
    Example: NumRxEchoReq, NumTxEchoReq, NumRxEchoRes, NumTxEchoRes, NumRxCreateSessionReq, NumTxCreateSessionReq, NumRxCreateSessionRes, NumTxCreateSessionRes, NumRxDeleteSessionReq, NumTxDeleteSessionReq, NumRxDeleteSessionRes, NumTxDeleteSessionRes, NumRxModifyBearerReq, NumTxModifyBearerReq, NumRxModifyBearerRes, NumTxModifyBearerRes, NumRxDeleteBearerReq, NumTxDeleteBearerReq, NumRxDeleteBearerRes, NumTxDeleteBearerRes, NumTxCreateBearerReq, NumRxCreateBearerReq, NumTxCreateBearerRes, NumRxCreateBearerRes, NumTxUpdateBearerReq, NumRxUpdateBearerReq, NumTxUpdateBearerRes, NumRxUpdateBearerRes, NumRxModifyBearerCmd, NumTxModifyBearerCmd, NumRxModifyBearerFail, NumTxModifyBearerFail, NumRxDeleteBearerCmd, NumTxDeleteBearerCmd, NumRxDeleteBearerFail, NumTxDeleteBearerFail, NumTxChangeNotfReq, NumRxChangeNotfReq, NumRxChangeNotfRes, NumTxChangeNotfRes, NumRxSuspendNotf, NumTxSuspendNotf, NumRxSuspendAck, NumTxSuspendAck, NumRxResumeNotf, NumTxResumeNotf, NumRxResumeAck, NumTxResumeAck, NumTxReleaseAccessBearerRsp, NumRxReleaseAccessBearerReq, NumRxContextReq, NumTxContextReq, NumRxContextAck, NumTxContextAck, NumRxDDN, NumTxDDn, NumRxIDReq, NumTxIDReq, NumRxIDRsp, NumTxIDRsp, NumRxDDNFail, NumTxDDnFail, NumRxCreateIDFTReq, NumTxCreateIDFTRsp, NumRxDeletIDFTReq, NumTxDeleteIDFTRsp, NumRxBearerResCmd
  • Label: gtpc_msg_len
    Label Description: Message Length
    Example: 36, 24, 45
  • Label: gtpc_msg_operation
    Label Description: Operation
    Example: encode, decode
  • Label: gtpc_msg_status
    Example: success, error
  • Label: gtpc_msg_status_cause
    Label Description: Error Cause
    Example: HeaderDecodeFailure, ParseIEsFromPayloadFailure, MBRFromIEFailure
SMF GTPC Messages Total Category
gtpc_msg_total
Description: Total GTPC Messages
Sample Query: 'gtpc_msg_total{message_name="S5S8_MSG_CREATE_SESSION_REQUEST"}'
Labels:
  • Label: status
    Example: 1, 2
SMF GTPC Unexpected Messages Category
gtpc_app_total_unexpected_gtpc_msg_events
Description: Unexpected GTPC Messages received
Sample Query: 'gtpc_app_total_unexpected_gtpc_msg_events{service_name="gtpc-ep"}'
Labels:
    Example: unexpected_gtpc_message
    Example: 1, 2
SMF GTPC Validation Fail Stats Category
gtpc_app_validation_events
Description: Stats of Message decode failures
Sample Query: 'gtpc_app_validation_events{service_name="gtpc-ep"}'
Labels:
    Example: csreq, csrsp, mbreq, mbrsp, cbreq, cbrsp, ubreq, ubrsp, dbreq, dbrsp, dsreq, dsrsp, mbcmd, mbcfi, dbcmd, dbcfi, ddnfi, ddnack, rabreq, upcreq
    Example: sgw_ingress, pgw_ingress, S5, S11, S5E, S2B, S8
  • Label: failure_type
    Label Description: Failure Type
    Example: msg_validation_fail, hdr_decode_failure
  • Label: hdr_decode_fail_reason
    Label Description: Header Decode Fail Reason
    Example: incorrect_gtp_version, unsupported_message, incorrect_msg_len, invalid_msg_format, invalid_seq_no, hdr_decode_fail_reason
  • Label: action_type
    Label Description: Action Type
    Example: discarded, rejected
  • Label: reject_cause
    Label Description: Reject Cause
    Example: invalid_msg_format, version_not_supported, invalid_len, mandatory_ie_missing, conditional_ie_missing, mandatory_ie_incorrect, service_not_supported, imsi_imei_not_known, preferred_pdn_type_unsupported, unknown
SMF GTPC messages Category
gtpc_app_events
Description: GTPC message counter
Sample Query: 'gtpc_app_events{service_name="gtpc-ep"}'
Labels:
  • Label: event_type
    Example: NumRxCreateSessionReq, NumTxCreateSessionRes, NumRxDeleteSessionReq, NumTxDeleteSessionRes, NumRxModifyBearerReq, NumTxModifyBearerRes, NumTxDeleteBearerReq, NumRxDeleteBearerRsp, NumTxCreateBearerReq, NumRxCreateBearerRes, NumTxUpdateBearerReq, NumRxUpdateBearerRes, NumTxModifyBearerFailureInd, NumModifyBearerTimeout, NumRxDeleteBearerCmd, NumCreateBearerFailure, NumCreateBearerSuccess, NumCreateSessionSuccess, NumCreateSessionFailure, NumDeleteSessionSuccess, NumDeleteSessionFailure, NumCreateBearerReqRetrans, NumUpdateBearerReqRetrans, NumDeleteBearerReqRetrans
  • Label: gtpc_msg_fail_cause
    Label Description: Contains Gtpc message fail cause
    Example: send_to_service_error, nil_raw_response, unmarshal_fail, rej_req_throttled_pending_req_limit, drop_req_throttled_pending_req_limit, rej_req_throttled_queue_full, drop_req_throttled_queue_full
    Example: 1, 2
SMF GTPC priority messages Category
gtpc_app_priority_events
Description: GTPC priority message counter
Sample Query: 'gtpc_app_priority_events{service_name="gtpc-ep"}'
Labels:
  • Label: event_type
  • Label: priority_msg
    Label Description: priority
    Example: true
    Example: 1, 2
gtpp-ep Metrics Reference
ASN1 Encoding stats Category
gtpp_asn1field_encoding_failures_total
Description: A counter for total number of fields failed to be ASN1 encoded
Sample Query: 'gtpp_asn1field_encoding_failures_total{gtpp_profile="pf1"}'
Labels:
  • Label: gtpp_profile
    Label Description: Gtpp Profile Name
    Example: pf1, pf2
  • Label: dictionary
    Label Description: Gtpp Dictionary Used
    Example: custom6, custom24
  • Label: asn1_field
    Label Description: ASN1 Field
    Example: ServedIMSI, ChargingID, ServingNodeAddress, ChargingCharacteristics
  • Label: reason
    Example: Constraint Violation
CDR Batch flush duration stats Category
gtpp_batch_flush_duration_histogram_total
Description: Histogram time bins of batch flush time
Sample Query: 'gtpp_batch_flush_duration_histogram_total{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: dictionary
  • Label: status
    Label Description: Status of the operation
    Example: batch_success,batch_error
CDR Batch flush stats Category
gtpp_batch_flush_millis_total
Description: A Histogram for the time CDRs remain in batch before flushed
Sample Query: 'gtpp_batch_flush_millis_total{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: dictionary
  • Label: status
CDR Batching Stats Category
gtpp_batched_cdrs_total
Description: No.of CDRs in a batch for a given profile
Sample Query: 'gtpp_batched_cdrs_total{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: dictionary
  • Label: status
DupReqList buffer gauge Category
gtpp_dup_reqlist_counter
Description: GTPP Dup Req List
Sample Query: 'gtpp_dup_reqlist_counter{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: cgf_addr
    Label Description: Cgf Server Address
    Example: 1.2.3.4
  • Label: state
    Label Description: Request Process State
    Example: empty_cdr_rsp_wait,dup_cdr_rel_rsp_wait,dup_cdr_can_rsp_wait,to_send_empty_rsp_wait
File based CDR Read Category
gtpp_file_record_read
Description: GTPP CDR file based reads
Sample Query: 'gtpp_file_record_read{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: status
    Label Description: CDR read operation status
    Example: success,failure
  • Label: pod_status
    Label Description: Active/StandBy
    Example: active,standby
File based CDR Write Category
gtpp_file_record_write
Description: GTPP CDR file based writes
Sample Query: 'gtpp_file_record_write{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: status
    Label Description: CDR write operation status
  • Label: pod_status
GTPP Archive List gauge Category
gtpp_archive_list_counter
Description: GTPP Archive List
Sample Query: 'gtpp_archive_list_counter{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: pod_status
GTPP Messages Stats Category
gtpp_msg_stats
Description: GTPP MSG Stats
Sample Query: 'gtpp_msg_stats{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: msg_type
    Label Description: GTPP Msg Name
    Example: DataRecTransReq, DataRecTransReqPossibleDup, DataRecTransReqCancel, DataRecTransReqRelease, DataRecTransReqEmpty, DataRecTransReqRetried, DataRecTransReqPossibleDuplRetried, DataRecTransReqCancelRetried, DataRecTransReqReleaseRetried, DataRecTransReqEmptyRetried, DataRecTransRsp, DataRecTransPossibleDuplRsp, DataRecTransCancelRsp, DataRecTransReleaseRsp, DataRecTransEmptyRsp, EchoReqSent, EchoReqRcvd, EchoRspSent, EchoRspRcvd, NodeAliveReqSent, NodeAliveReqRcvd, NodeAliveRspSent, NodeAliveRspRcvd, TestEchoReqSent, TestEchoRspRcvd
  • Label: status
    Label Description: Request/Response Message Handling Status
  • Label: cause
    Label Description: GTPP Messages Response Cause
    Example: accepted, mandatory_ie_incorrect, mandatory_ie_missing, invalid_message_format, optional_ie_incorrect, no_resources_available, system_failure, service_not_supported, version_not_supported, not_fulfilled, already_fulfilled, cdr_decode_error, sequence_numbers_incorrect,buffer_full,internal_failure,ipc_err
  • Label: cgf_addr
    Example: 1.2.3.4
  • Label: trigger_type
    Label Description: Trigger for this Message
    Example: normal cdr, pod_switchover, peer_restart, cgf_down
GTPP Replication Msg Stats Category
gtpp_replication_stats
Description: GTPP Replication Data Msg
Sample Query: 'gtpp_replication_stats{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: cgf_addr
    Example: 1.2.3.4
  • Label: item
    Label Description: Peer Struct Replicated Item
    Example: SndReqListTx,DupReqListTx,SeqPoolTx,SndReqListRx,DupReqListRx,SeqPoolRx,ArchiveListTx,ArchiveListRx,FileCdrTx,FileCdrRx
  • Label: op_type
    Label Description: Operation Type
    Example: Add,Update,Delete
  • Label: status
    Label Description: Peer Replication Msg Handling Status
Inbound CDR Requests Category
gtpp_received_cdrs_total
Description: A counter for total number of CDRs received in request
Sample Query: 'gtpp_received_cdrs_total{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: dictionary
Processed CDR Requests Category
gtpp_processed_cdrs_total
Description: A counter for total number of CDRs processed in transaction
Sample Query: 'gtpp_processed_cdrs_total{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: dictionary
  • Label: status
    Label Description: Status of processed CDR request
    Example: Success, profile_error, not_leader_pod_error
Read from GTPP Archive List Stats Category
gtpp_archive_list_read
Description: GTPP Archive List Read
Sample Query: 'gtpp_archive_list_read{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: status
    Label Description: Status of CDR read from Archive
  • Label: sub_status
    Label Description: Sub Status of CDR read from Archive
    Example: lookup, send_to_cgf, send_to_hdd, purge
  • Label: pod_status
SendReqList buffer gauge Category
gtpp_send_reqlist_counter
Description: GTPP Send Req List
Sample Query: 'gtpp_send_reqlist_counter{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: cgf_addr
    Example: 1.2.3.4
  • Label: state
    Example: Normal_CDR_Rsp_Wait,Duplicate_CDR_Rsp_Wait
Write to GTPP Archive List Stats Category
gtpp_archive_list_write
Description: GTPP Archive List Write
Sample Query: 'gtpp_archive_list_write{gtpp_profile="pf1"}'
Labels:
    Example: pf1, pf2
  • Label: status
    Label Description: Status of CDR write to Archive
  • Label: sub_status
    Label Description: Sub Status of CDR write to Archive
    Example: purge_oldest_cdr
  • Label: pod_status
nodemgr Metrics Reference
Nodemgr UPF Path failure reasons Category
nodemgr_up_pathfail_reasons
Description: Node manager userplane heart beat message failure reasons stats
Sample Query: 'nodemgr_up_pathfail_reasons{app_name="smf",cluster="cn",data_center="cn",instance_id="0",service_name="nodemgr",up_pathfail_reason="up_pathfail_ignored_hb_retry"} 1'
Labels:
  • Label: up_pathfail_reasons
    Label Description: Node manager UPF Path Failure reasons due to restransmission failure, RTS change and Sx Release from peer node
    Example: up_pathfail_ignored_hb_retry,up_pathfail_reason_hb_retry,up_pathfail_ignored_hb_rt_change,up_pathfail_reason_hb_rt_change,up_pathfail_reason_association_release
    Example: 1, 2
Nodemgr UPF Peer status Category
nodemgr_up_peer_status
Sample Query: 'nodemgr_up_peer_status{app_name="smf",cluster="cn",data_center="cn",instance_id="1",interface_type="SXA",service_name="nodemgr",up_peer_ip="20.20.20.66:20.20.20.42",up_peer_status="up_peer_path_up"} 1'
Labels:
  • Label: up_peer_ip
    Label Description: unique key to identify UPF YYY.YYY.YYY.YYY:XXX.XXX.XXX.XXX where XXX.XXX.XXX.XXX is Ip address of the NF service like SGW / SMF and YYY.YYY.YYY.YYY is the IP address of UPF
    Example: 20.20.20.66:20.20.20.42
  • Label: up_peer_status
    Label Description: Node manager UPF Peer status
    Example: up_peer_path_down,up_peer_path_up
    Label Description: nterface type between Peer Node (UPF)
    Example: SXA
    Example: 1, 2
Nodemgr UPF ip address threshol hit stats Category
nodemgr_up_threshold_stats
Description: When particular IP address pool threshold hit for usage of ip addresses of a particular address type,this stats will be recorded
Sample Query: 'nodemgr_up_threshold_stats{up_ep_key="192.168.10.2:192.168.20.3", dnn="sampleDNN",threshold_hit="yes",ip_ver_type="IP_TYPE_V4"}'
Labels:
  • Label: up_ep_key
    Label Description: unique key to identify UPF XXX.XXX.XXX.XXX:YYY.YYY.YYY.YYY where XXX.XXX.XXX.XXX is Ip address of the NF service like SGW / SMF and YYY.YYY.YYY.YYY is the IP address of UPF
    Example: 192.168.10.2:192.168.20.3
  • Label: dnn
    Label Description: DNN of which ip pool reached the configured threshold usgae.
    Example: sampleDNN
  • Label: threshold_hit
    Label Description: Indicates if threhold hit is yes or no.
    Example: yes
  • Label: threshold_clear
    Label Description: Indicates if threhold hit is cleared or not
    Example: yes
  • Label: nodemgr_id
    Label Description: Indicates which instance of nodemgr hit the threshold
    Example: 1
    Example: 1, 2
  • Label: ip_ver_type
    Label Description: Type of IP addresses for which threshold is hit or clear
    Example: IP_TYPE_V4, IP_TYPE_V6
Nodemgr diagnostics address validation counter Category
nodemgr_diag_ip_verify
Description: Node manager diagnostics address validation counter
Sample Query: 'nodemgr_diag_ip_verify{status="success"}'
Labels:
  • Label: status
    Label Description: diagnostics address validation status
    Example: success, unknown, cdl_ipc_failure, ipv4_alloc_failed, ipv6_alloc_failed, ip_mismatch_ignored, duplicate_record_found
Nodemgr gtpc message statistics Category
nodemgr_gtpc_msg_stats
Description: Node manager gtpc message statistics for updating node status to gtpc peers like SGW, PGW or ePDG
Sample Query: 'nodemgr_gtpc_msg_stats{gtpc_peer_ip="192.168.10.2", gtpc_msg_type="gtpc_echo_res_rx", interface_type="S11"}'
Labels:
    Label Description: IP address of a gtpc peer like SGW, PGW or ePDG
    Label Description: GTPC message triggered by the current node, or triggered by peer node
    Example: gtpc_echo_res_rx, gtpc_echo_res_tx, gtpc_echo_req_rx, gtpc_echo_req_tx,gtpc_false_peer_restart_cfg_echo_rc_change,gtpc_false_peer_restart_ignore_echo_rc_cfg,gtpc_false_peer_restart_cfg_ctrl_rc_change,gtpc_false_peer_restart_ignore_ctrl_rc_cfg,gtpc_ignore_echo_timeout,pathfail_echo_rc_change,pathfail_no_echo_rcv,pathfail_ctrl_rc_change
    Label Description: Interfaces on which the gtpc message is recieved or sent PGW, SGW-Egress, SGW-Ingress etc
    Example: S11, S5E, S5, S8, S2B
    Example: 1, 2
Nodemgr gtpc peer status statistics Category
nodemgr_gtpc_peer_status
Description: Node manager gtpc peer status statistics for keeping track of gtpc peers like SGW, PGW or ePDG via keep alive or restart counter tracking
Sample Query: 'nodemgr_gtpc_peer_status{gtpc_peer_ip="192.168.10.2", gtpc_msg_type="gtpc_echo_res_rx", interface_type="S11"}'
Labels:
  • Label: gtpc_peer_status
    Label Description: GTPC peer current status as a result of keep alive success/failure or restart counter tracking
    Example: gtpc_peer_path_down, gtpc_peer_path_up, gtpc_peer_restarted
  • Label: restart_time
    Label Description: Gtpc peer restart time
    Example: 2022-09-30 14:32:52 +0000 UTC
    Example: 1, 2
Nodemgr gtpp message statistics Category
nodemgr_gtpp_msg_stats
Description: Node manager gtpp message statistics to update stats for msg triggered by NodeMgr
Sample Query: 'nodemgr_gtpp_msg_stats{ca_ip="10.65.45.181",ca_port="2222",cgf_ip="10.78.41.152",cgf_port="3386",gtpp_msg_type="gtpp_echo_req"}'
Labels:
  • Label: ca_ip
    Label Description: Charging agent ip address
    Example: 10.65.45.181
  • Label: ca_port
    Label Description: Charging agent port number
    Example: 2222
  • Label: cgf_ip
    Label Description: Cgf ip address
    Example: 10.78.41.152
  • Label: cgf_port
    Label Description: Cgf port number
    Example: 3386
  • Label: gtpp_msg_type
    Label Description: Msg triggered towards gtpp-ep like echo req/path up/path down/peer restart
    Example: gtpp_echo_req, gtpp_peer_path_up, gtpp_peer_path_down, gtpp_peer_restarted
Nodemgr gtpp peer status statistics Category
nodemgr_gtpp_peer_status
Description: Node manager gtpp peer status statistics for keeping track of cgf nodes via node alive/echo/gtpp control message success/failure or restart counter tracking
Sample Query: 'nodemgr_gtpp_peer_status{ca_ip="10.65.45.181",ca_port="2222",cgf_ip="10.78.41.152",cgf_port="3386",gtpp_peer_reason="PEER_ADD",gtpp_peer_status="gtpp_peer_path_up",restart_time="2023-03-29 15:46:27 +0530 IST"}'
Labels:
  • Label: ca_ip
  • Label: ca_port
    Example: 2222
  • Label: cgf_ip
  • Label: cgf_port
    Example: 3386
  • Label: gtpp_peer_reason
    Label Description: Cgf update reason (add/update/delete) as a result of node alive/echo/gtpp control message success/failure or restart counter tracking
    Example: PEER_ADD, PEER_UP, PEER_DELETE, NO_ECHO_RESPONSE, NO_CTRL_MSG_RESPONSE
  • Label: gtpp_peer_status
    Label Description: Cgf status (up/down/restart) as a result of node alive/echo/gtpp control message success/failure or restart counter tracking
    Example: gtpp_peer_path_down, gtpp_peer_path_up, gtpp_peer_restarted
    Label Description: Cgf restart time
    Example: 2023-03-29 15:46:27 +0530 IST
Nodemgr Messages Category
nodemgr_msg_stats
Description: Node Manager Resource management message counters
Sample Query: 'nodemgr_msg_stats{nodemgr_id="0", id_req_type="ID_REQ_ALLOC", ip_req_type="IP_REQ_ALLOC", ip_version="IP_TYPE_V4",sent_to_owner="0", service_user="SERVICE_USER_SMF"}'
Labels:
  • Label: nodemgr_id
    Label Description: Node Manager instance for which statistics are to be checked
    Example: 0, 1, 2, 3, 4, 5, 6, 7, 8
  • Label: id_req_type
    Label Description: Type of request recieved at node manager message
    Example: ID_REQ_NONE, ID_REQ_ALLOC, ID_REQ_REL, ID_REQ_REALLOC
  • Label: ip_req_type
    Label Description: Type of request recieved at node manager for IP address
    Example: IP_REQ_NONE, IP_REQ_ALLOC, IP_REQ_REL, IP_REQ_REALLOC, IP_REQ_STATIC
  • Label: ip_version
    Label Description: IP address type for which request was recieved
    Example: IP_TYPE_NONE, IP_TYPE_V4, IP_TYPE_V6, IP_TYPE_V4V6
  • Label: sent_to_owner
    Label Description: Current Node Manager instance for which statistics are to be checked
  • Label: service_user
    Label Description: Node Type which has requested the Node Manager services
    Example: SERVICE_USER_NONE, SERVICE_USER_SMF, SERVICE_USER_SGW
    Example: 1, 2
Nodemgr node report message hanlding timer stats Category
nodemgr_node_rpt_timer_stats
Description: Timer to handle Node Manager handling of node report from UPF about the status of NR's or gNB's having sessions with the UPF
Sample Query: 'nodemgr_node_rpt_timer_stats{up_ep_key="192.168.10.2:192.168.20.3", node_report_peer_gtpu="192.168.30.4", node_report_no_of_sess="0", status="success", node_report_type="", backlog_tmr="1564555678270689300"}'
Labels:
  • Label: up_ep_key
  • Label: node_report_peer_gtpu
    Label Description: Peer GTPU IP address of gNB or NR to which UPF has established the userplane session
    Example: 192.168.30.4
  • Label: node_report_no_of_sess
    Label Description: Total number of session established for the Peer GTPU gNB or NR via the UPF
    Example: 0
  • Label: status
    Label Description: Node report message handling status by Node manager
  • Label: node_report_type
    Label Description: Type of node report message being handled
    Example: tmr_start_failed, dbg_tmr, retry_clrBlkSubs
  • Label: backlog_tmr
    Label Description: Current time stamp in unix epoch value for node report message processing
    Example: 1564555678270689300
    Example: 1, 2
Nodemgr Resource Management Batch Reconciliation Counter Category
nodemgr_rmgr_batch_reconcile_stats
Description: Node manager resource management batch reconciliation counter
Sample Query: 'nodemgr_rmgr_batch_reconcile_stats{status="success"}'
Labels:
  • Label: status
    Label Description: reconciliation status
Nodemgr resource management response statistics Category
nodemgr_resource_mgmt_resp_stats
Description: Node Manager resource management response statistics
Sample Query: 'nodemgr_resource_mgmt_resp_stats{req_type="1", ip_ver_type="1", status="attempted", error=""}'
Labels:
  • Label: req_type
    Label Description: The request for which this response is being sent, Request with no operation = 0, Request with IP allocation = 1, Request with IP release = 2, Request with IP reallocation = 3, Request with Static IP allocation = 4
    Label Description: Type of IP addresses requested in the message, IP type requested NONE = 0, IP type requeseted V4 = 1, IP type requeseted V6 = 2, IP type requeseted V4V6 = 3
    Example: 0, 1, 2, 3
  • Label: status
    Label Description: Status of the request
    Example: attempted, success, failed
  • Label: error
    Label Description: A non unique error String in case of Status is failure, for other cases use this value as empty string
    Example: Unable to get UpfKey for upf
    Example: 1, 2
Nodemgr userplane heart beat message failure due to retransmission stats Category
nodemgr_up_heartbeat_fail_stats
Description: Node Manager userplane heart beat message failure counters between UPF node and SMF/PGW/SGW node as retransmission requests exhausted to UPF
Sample Query: 'nodemgr_up_heartbeat_fail_stats{up_ep_key="192.168.10.2:192.168.20.3", primary_nodemgr_id="0", current_nodemgr_id="0", up_msg_type="up_heartbeat_req_tx", interface_type="SXB"}'
Labels:
  • Label: up_ep_key
    Label Description: Interface type between current node (SMF/SGW) and Peer Node (UPF)
    Example: SXA, SXB, SXAB, SXC, N4
    Example: 1, 2
Nodemgr userplane heart beat message failure stats Category
nodemgr_up_hb_msg_fail_stats
Description: Node Manager userplane heart beat message failure counters between UPF node and SMF/PGW/SGW node as unable to send request to UPF
Sample Query: 'nodemgr_up_hb_msg_fail_stats{up_ep_key="192.168.10.2:192.168.20.3", primary_nodemgr_id="0", current_nodemgr_id="0", up_msg_type="up_heartbeat_req_tx", interface_type="SXB"}'
Labels:
  • Label: up_ep_key
  • Label: primary_nodemgr_id
    Label Description: Node Manager instance Identifier of SGW/SMF service which originally established interaction with UPF
  • Label: current_nodemgr_id
    Label Description: Current Node Manager instance Identifier of SGW/SMF service which is currently established and interacting with UPF
  • Label: up_msg_type
    Label Description: Message type which is received or sent for heartbeat messaging
    Example: up_heartbeat_req_tx, up_heartbeat_req_retx, up_heartbeat_rsp_rx
    Example: 1, 2
Nodemgr userplane heart beat message stats Category
nodemgr_up_hb_msg_stats
Description: Node Manager userplane heart beat message counters between UPF node and SMF/PGW/SGW node
Sample Query: 'nodemgr_up_hb_msg_stats{up_ep_key="192.168.10.2:192.168.20.3", primary_nodemgr_id="0", current_nodemgr_id="0", up_msg_type="up_heartbeat_req_tx", interface_type="SXB"}'
Labels:
  • Label: up_ep_key
    Example: 1, 2
Nodemgr userplane stats Category
nodemgr_up_stats
Description: Node Manager to userplane (UPF) link status up guage counters
Sample Query: 'nodemgr_up_stats{up_ep_key="192.168.10.2:192.168.20.3", primary_nodemgr_id="0", peer_nodemgr_id="0", interface_type="SXB"}'
Labels:
  • Label: up_ep_key
  • Label: peer_nodemgr_id
    Label Description: Peer Node Manager instance Identifier of UPF service
    Example: 1, 2
SMF Recovery Value stats Category
smf_recovery_value
Description: SMF Recovery Value stats
Sample Query: 'smf_recovery_value{smf_ip="192.168.10.2"}'
Labels:
  • Label: smf_ip
    Label Description: smf ip address
oam Metrics Reference
Node level LCI metric Category
node_lci_metric
Description: Total node level LCI metric
Sample Query: node_lci_metric{}
Node level OCI metric Category
node_oci_metric
Description: Total node level OCI reduction metric
Sample Query: node_oci_metric{}
Node level overload state Category
node_overload_status
Description: Total node level overload state
Sample Query: node_overload_status{}
protocol Metrics Reference
PFCP Decoded Messages Category
proto_pfcp_decode_msg_total
Description: Total number of pfcp decode by type,size
Sample Query: 'proto_pfcp_decode_msg_total{message_name="session_modification_res"}'
Labels:
    Label Description: PFCP Message name
    Example: session_modification_res, session_report_req, session_deletion_res, heartbeat_res, heartbeat_req
  • Label: optimised
    Label Description: PFCP Message decode optimised
    Example: true, false
  • Label: status
    Label Description: PFCP Message status - accepted/denied/discarded
    Example: accepted, denied, discarded
    Example: 1, 2
PFCP Encoded Messages Category
proto_pfcp_encode_msg_total
Description: Total number of pfcp encode by type,size
Sample Query: 'proto_pfcp_encode_msg_total{message_name="session_modification_req"}'
Labels:
    Example: session_establishment_req, session_modification_req, session_report_req, session_deletion_req, heartbeat_req, heartbeat_res, session_report_res
  • Label: msgbufsize
    Label Description: PFCP Message buffer size
    Example: little, jumbo, optimized
  • Label: status
    Example: 1, 2
PFCP Message Retransmission from SMF Category
proto_udp_retrans_msg_total
Description: Total number of retransmitted message at pfcp
Sample Query: 'proto_udp_retrans_msg_total{message_name="association_setup_req"}'
Labels:
    Example: association_setup_req, association_update_req, association_release_req, prime_pfd_management_req, heartbeat_req, node_report_req, session_report_res, association_setup_res, association_update_res, association_release_res, heartbeat_res, node_report_res, gtpu_router_advertisement_req, gtpu_router_solicitation_req
    Label Description: PFCP Message direction
  • Label: status
    Label Description: PFCP Message original or retransmission
    Example: origin, retransmited
  • Label: msgpriority
    Label Description: PFCP Message priority
    Example: true
    Label Description: PFCP Message Interface Type
  • Label: peer_info
    Label Description: PFCP Message Peer Info
    Example: SMFIP:1.2.3.4:UPFIP:5.6.7.8
    Example: 1, 2
PFCP Messages Category
proto_pfcp_msg_total
Description: Total number of pcfp messages by type
Sample Query: 'proto_pfcp_msg_total{message_name="session_establishment_req"}'
Labels:
    Example: session_establishment_req, session_modification_req, session_report_req, session_deletion_req, association_setup_req, association_update_req, association_release_req, prime_pfd_management_req, heartbeat_req, node_report_req, gtpu_router_advertisement_req, gtpu_router_solicitation_req
  • Label: status
    Example: true
    Example: 1, 2
PFCP Messages Decode Time Category
proto_decode_msg_seconds_total
Description: Time Taken for pcfp decode by message type
Sample Query: 'proto_decode_msg_seconds_total{message_name="session_establishment_res"}'
Labels:
  • Label: status
    Example: true
    Example: 1, 2
PFCP Messages processing time Category
proto_pfcp_msg_seconds_total
Description: Time Taken for pcfp messages by type
Sample Query: 'proto_pfcp_msg_seconds_total{message_name="session_establishment_req"}'
Labels:
  • Label: status
    Example: true
    Example: 1, 2
PFCP Request Messages Category
proto_udp_req_msg_total
Description: Total number of pfcp request messages processed
Sample Query: 'proto_udp_req_msg_total{message_name="session_establishment_req"}'
Labels:
  • Label: status
    Example: true
  • Label: peer_info
  • Label: sec_pdr_present
    Label Description: Indicate whether secondary PDR present
    Example: 1, 2
PFCP Response Messages Category
proto_udp_res_msg_total
Description: Total number of pfcp response messages processed
Sample Query: 'proto_udp_res_msg_total{message_name="session_establishment_res"}'
Labels:
    Example: session_establishment_res, session_modification_res, session_report_res, session_deletion_res, association_setup_res, association_update_res, association_release_res, prime_pfd_management_res,heartbeat_res, node_report_res
  • Label: status
  • Label: cause
    Label Description: PFCP Message Response cause
    Example: 1, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 101
    Example: true
  • Label: peer_info
    Example: 1, 2
PFCP Response Messages processing time Category
proto_udp_msg_seconds_total
Description: Total number of seconds taken by message
Sample Query: 'proto_udp_msg_seconds_total{message_name="session_establishment_res"}'
Labels:
  • Label: status
  • Label: cause
    Example: true
  • Label: peer_info
    Example: 1, 2
radius-ep Metrics Reference
Radius COA and DM packet statistics Category
Radius_CoaDM_Requests_Current
Description: Current outstanding radius COA/DM requests
Sample Query: 'Radius_CoaDM_Requests_Current{radSvrIp="1.1.1.1",radMsgCode="CoaReq",grInstId="1"}'
Labels:
  • Label: radSvrIp
    Label Description: Radius Server IP address
    Example: Any string
  • Label: radMsgCode
    Example: DisconnectRequest, CoARequest
  • Label: grInstId
    Example: 1 or 2
Radius_CoaDM_Requests_Statistics
Description: Total number of radius COA and DM packets sent and received
Sample Query: 'Radius_CoaDM_Requests_Statistics{radSvrIp="1.1.1.1",radMsgCode="CoaRequest",grInstId="1"}'
Labels:
  • Label: radSvrIp
    Example: Any string
  • Label: radMsgCode
    Example: DisconnectRequest, DisconnectACK, DisconnectNAK, CoARequest, CoaDMReq, CoAACK
  • Label: radPacketType
    Example: Tx, Rx
  • Label: radResult
    Example: Success, Failure_Invalid_Request
  • Label: grInstId
    Example: 1 or 2
Radius Server status Category
Radius_Server_Status
Description: Display active/inactive status of radius-server
Sample Query: 'Radius_Server_Status{radSvrIp="1.1.1.1",radSvrPort="1812",radSvrPortType="Auth"}'
Labels:
  • Label: radSvrIP
    Example: Any string
  • Label: radSvrPort
    Label Description: Radius Server Port
    Example: Any string
  • Label: radSvrPortType
    Label Description: Type of server
    Example: Auth, Acct
Radius packet statistics Category
Radius_requests_current
Description: Current outstanding radius requests
Sample Query: 'Radius_requests_current{radSvrIp="1.1.1.1",radSvrPort="1812",radSvrPortType="Auth",grInstId="1"}'
Labels:
  • Label: radSvrIp
    Example: Any string
  • Label: radSvrPort
    Example: Any string
    Example: Auth, Acct
  • Label: radMsgCode
    Example: SecondaryAuthenReq, RadiusAcctReq, TestAuth, TestAcct
    Example: Tx, Rx
  • Label: dnn
    Label Description: DNN of session
    Example: Any string
  • Label: procType
    Label Description: Procedure type
    Example: Any string
  • Label: ratType
    Example: Any string
  • Label: sessType
    Label Description: Session type
    Example: Any string
  • Label: grInstId
    Example: 1 or 2
Radius_requests_statistics
Description: Total number of radius packets sent and received
Sample Query: 'Radius_requests_statistics{radSvrIp="1.1.1.1",radSvrPort="1812",radSvrPortType="Auth",grInstId="1"}'
Labels:
  • Label: radSvrIp
    Example: Any string
  • Label: radSvrPort
    Example: Any string
    Example: Auth, Acct
  • Label: radMsgCode
    Example: Tx, Retry_Tx, Rx
  • Label: radResult
    Example: Success, Timeout, Failure_Reject, Failure_NoServer
  • Label: dnn
    Example: Any string
  • Label: procType
    Example: Any string
  • Label: ratType
    Example: Any string
  • Label: sessType
    Example: Any string
  • Label: grInstId
    Example: 1 or 2
rest-ep Metrics Reference
Discover Messages Time statistics Category
nf_discover_total_time
Description: Discover Messages Total time statistics
Sample Query: nf_discover_total_time{nf_type=\"udm\", host=\"10.105.227.109:8082\", svc_name=\"nudm-sdm\", version=\"v1\", result=\"timeouOrRPCError\"}
Labels:
  • Label: nf_type
    Label Description: Network Function type
    Example: nrf, udm, amf, pcf, chf, ciscocontrol
  • Label: host
    Label Description: End Point address
    Example: 10.105.227.109:8082
  • Label: svc_name
    Label Description: Network function service name
    Example: nudm-sdm, namf-comm
  • Label: version
    Label Description: Api version info
    Example: v1, v2,
  • Label: result
    Label Description: result of discover message
    Example: 200, 201, 204, success, timeout_rpc_error, response_parse_failure
Discover Messages statistics Category
nf_discover_messages_total
Description: Discover Messages statistics
Sample Query: nf_discover_messages_total{nf_type=\"udm\", host=\"10.105.227.109:8082\", svc_name=\"nudm-sdm\", version=\"v1\", result=\"timeouOrRPCError\"}
Labels:
  • Label: nf_type
  • Label: host
  • Label: svc_name
  • Label: version
    Example: v1, v2,
  • Label: result
NF End point selections Category
nf_endpoint_selections_total
Description: NF End Point Selection Statistics
Sample Query: nf_endpoint_selections_total{nf_type=\"udm\", host=\"10.105.227.109:8097\", svc_name=\"nudm-sdm\", version=\"v1\", req=\"initial\"}
Labels:
  • Label: nf_type
  • Label: host
    Example: 10.105.227.109:8097
  • Label: svc_name
  • Label: version
    Example: v1, v2,
  • Label: req
    Label Description: req type
    Example: initial, fallback,
NF Send messages statistics Category
nf_req_recieved_messages_total
Description: NF recieved messages to NRF client library
Sample Query: nf_req_recieved_messages_total{nf_type=\"udm\", svc_name=\"nudm-sdm\", message_type=\"UdmUecmRegisterSMF\"}
Labels:
  • Label: nf_type
    Example: udm, amf, pcf, chf, ciscocontrol
  • Label: svc_name
    Label Description: Message Type
    Example: UdmUecmRegisterSMF, UdmSdmGetUESMSubscriptionData
nf_resp_sent_messages_total
Description: NF message responses sent from NRF client library
Sample Query: nf_resp_sent_messages_total{nf_type=\"udm\", svc_name=\"nudm-sdm\", message_type=\"UdmUecmRegisterSMF\",result=\"SendSuccess\", status_code=\"200\"}
Labels:
  • Label: nf_type
  • Label: svc_name
  • Label: result
    Example: SendSuccess, SendFailure
  • Label: status_code
    Label Description: result of NF send message
nf_send_message_total_time
Description: NF send message total time taken
Sample Query: nf_send_message_total_time{nf_type=\"udm\", svc_name=\"nudm-sdm\", message_type=\"UdmUecmRegisterSMF\",result=\"SendSuccess\", status_code=\"200\"}
Labels:
  • Label: nf_type
Labels:
  • Label: svc_name
  • Label: result
NF failure handling stats Category
nf_failure_handling_stats_total
Description: NF Failure handling stats
Sample Query: nf_failure_handling_stats_total{nf_type=\"udm\", host=\"10.105.227.109:8097\", svc_name=\"nudm-sdm\", version=\"v1\", message_type=\"UdmUecmRegisterSMF\",req=\"initial\", response=\"202\", status=\"final\"}
Labels:
  • Label: nf_type
  • Label: host
  • Label: svc_name
  • Label: version
    Example: v1, v2,
  • Label: req
    Label Description: Request type
  • Label: response
    Label Description: Response from the server
    Example: 200, 201, 204, timeout_rpc_error,
  • Label: status
    Label Description: Status from the server
    Example: retry, final
NF management message time statistics Category
nf_management_total_time
Description: NF management messages total time taken
Sample Query: nf_management_total_time{host=\"10.105.227.109:8082\", svc_name=\"nudm-sdm\", version=\"v1\",direction=\"outbound\", message_type=\"registration\",result=\"timeouOrRPCError\" }
Labels:
  • Label: host
  • Label: svc_name
  • Label: version
    Example: v1, v2,
  • Label: direction
    Label Description: Direction indicates about the message going out or coming in
    Label Description: Type of Message
    Example: registration, hearbeat, subscription, notification
  • Label: result
    Example: 200, 201, 204, success, timeout_rpc_error, response_parse_failure, request_parse_failure, invalid_notify_event, invalid_nf_instance_uri, internal_error
NF management messages statistics Category
nf_management_stats_total
Description: NF management messages statistics
Sample Query: nf_management_stats_total{host=\"10.105.227.109:8082\", svc_name=\"nudm-sdm\", version=\"v1\",direction=\"outbound\", message_type=\"registration\",result=\"timeouOrRPCError\" }
Labels:
  • Label: host
  • Label: svc_name
  • Label: version
    Example: v1, v2,
  • Label: direction
  • Label: result
NRF Discovery Category
nf_discover_events_total
Description: NF Discover Stats
Sample Query: nf_discover_events_total{nf_type=\"pcf\", response_type=\"local\"}
Labels:
  • Label: nf_type
  • Label: response_type
    Label Description: Discovery response choosen from
    Example: local, cache, expired-cache
NRF subscription messages statistics Category
nrf_subscription_send_messages_total
Description: NRF Subscription send messages total
Sample Query: nrf_subscription_send_messages_total{host=\"10.105.227.109:8082\", message_type=\"subscription\", req=\"initial\"}
Labels:
  • Label: host
    Label Description: subscription message typwe
    Example: unsubscription,subscription,updateSubscription
  • Label: req
    Example: resourceUri, initial,retry_2
REST EP message Exchange Time Category
smf_restep_http_msg_seconds
Description: SMF REST time between request and response messages
Sample Query: 'smf_restep_http_msg_seconds{message_direction="inbound",nf_type="amf"}'
Labels:
  • Label: nf_type
    Label Description: direction of message from SMF perspective
  • Label: api_name
    Label Description: API name
    Example: register_ue, deregister_ue, subscription_req, sdm_subscription_req, sdm_data_change_notify, nf_registration, nf_discovery, slice_selection, amf_create_sm_context, amf_update_sm_context, amf_release_sm_context, amf_n1_n2_transfer, amf_n1_n2_transfer_notify_failure, amf_assign_ebi, amf_status_notify, pcf_sm_policy_control_create, chf_charging_data_request, pcf_sm_policy_control_update, pcf_sm_policy_control_delete, pcf_sm_policy_control_update_notify, cisco_control_clear_subscriber, cisco_control_show_subscriber, pcf_sm_policy_control_terminate_notify, chf_abort_notify
  • Label: nf_uri
    Label Description: Network Function URI
    Example: actual HTTP URI of the message
  • Label: response_status
    Label Description: HTTP response status code
  • Label: response_cause
    Label Description: HTTP response cause code
    Example: cause string as received from peer nf
REST EP messages Category
smf_restep_http_msg_total
Description: SMF REST message counter
Sample Query: 'smf_restep_http_msg_total{message_direction="inbound",nf_type="amf"}'
Labels:
  • Label: nf_type
  • Label: api_name
  • Label: nf_uri
REST EP messages Decode Status Category
smf_restep_http_msg_decode
Description: SMF REST number of decoding failures
Sample Query: 'smf_restep_http_msg_decode{nf_type="amf",api_name="register_ue",decoding_status="decoding_failure"}'
Labels:
  • Label: nf_type
  • Label: api_name
  • Label: decoding_status
    Label Description: Decoding status
    Example: decoding_failure
    Label Description: Iterface Type
    Example: N11, N1, N2
  • Label: application_error
    Label Description: Application error
smf-service Metrics Reference
CHF Notification Statistics Category
smf_chf_notification_stats
Description: SMF Charging CHF Notification stats
Sample Query: 'smf_chf_notification_stats{notification_type="reauthorization"}'
Labels:
  • Label: notification_type
    Label Description: Type of notification request
    Example: reauthorization, abort_charging
  • Label: dnn
    Label Description: DNN for which the flow is created
    Example: cisco.com
  • Label: status
    Label Description: Status of notify message processing
  • Label: rat_type
    Label Description: RAT type on which the flow is created
  • Label: reason
    Label Description: Reason for notify message failure
    Example: pdu_session_not_established, charging_failed, offline_converted
Charging final unit indication statistics Category
chf_recieved_fui_stats
Description: Statistics for final unit indication with final unit action
Sample Query: 'sum (chf_recieved_fui_stats{interface_type="Gy"})'
Labels:
  • Label: chf_type
    Label Description: Type of CHF with which message is exchanged
    Example: online, offline
    Label Description: Type of Interface communicate with PGW
    Example: N40, Gy
  • Label: fua_type
    Label Description: Type of final unit action
    Example: FinalUnitActionType_TERMINATE", "FinalUnitActionType_REDIRECT", "FinalUnitActionType_RESTRICT_ACCESS
Sample Query: 'nf_discover_total_time{nf_type="amf", host="http://10.105.227.109:8082/nnrf-nfm/v1", result="timeouOrRPCError"}'
Labels:
  • Label: nf_type
  • Label: host
    Example: http://10.105.227.109:8082/nnrf-nfm/v1
  • Label: result
Sample Query: 'nf_discover_messages_total{nf_type="amf", host="http://10.105.227.109:8082/nnrf-nfm/v1", result="timeouOrRPCError"}'
Labels:
  • Label: nf_type
  • Label: host
  • Label: result
Dropped Charging Data Requests Statistics Category
cdr_dropped_stats
Description: The current count for charging data requests dropped due to zero usage
Sample Query: 'cdr_dropped_stats{procedure_type="pdu_sess_create"}'
Labels:
    Example: pdu_sess_create, ue_req_pdu_sess_mod, smf_req_pdu_sess_mod, pcf_req_pdu_sess_mod, udm_req_pdu_sess_mod, gnb_req_pdu_sess_mod, ue_req_pdu_sess_rel, smf_req_pdu_sess_rel, pcf_req_pdu_sess_rel, amf_req_pdu_sess_rel, udm_req_pdu_sess_rel, gnb_req_pdu_sess_rel, chf_req_pdu_sess_rel, admin_req_pdu_sess_rel, ue_req_active_to_idle, ue_req_idle_to_active, nw_req_service_active, upf_notify_downlink_data, xn_path_switch,pdn_sess_create,pdn_5g_4g_handover,pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, n2_handover, xn_handover, n26_4g_to_5g_handover, n26_4g_to_5g_im_mobility, pdu_im, pdn_sess_create, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, pcf_initiated_pdn_detach, smf_initiated_pdn_detach, upf_initiated_pdn_detach
GTPC Message stats Category
smf_gtpc_msg_stats
Description: Stats for GTPC interface messages
Sample Query: 'smf_gtpc_msg_stats{message_type="create_bearer_request"}'
Labels:
    Label Description: GTPC Message Type
    Example: delete_bearer_request, create_bearer_request, delete_bearer_request_async, suspend_notification, resume_notification, change_notification
  • Label: status
    Label Description: GTPC message status
  • Label: reason
    Label Description: The reason associated with failure
    Example: ipc_failed, sgw_failure, EGTP_CAUSE_LOCAL_DETACH, EGTP_CAUSE_RAT_CHANGED_FROM_3GPP_TO_NON_3GPP, EGTP_CAUSE_COMPLETE_DETACH, EGTP_CAUSE_ISR_DEACTIVATION, EGTP_CAUSE_ERROR_IND_RCVD_RNC_ENODE, EGTP_CAUSE_IMSI_DETACH_ONLY, EGTP_CAUSE_REACTIVATION_REQUESTED, EGTP_CAUSE_PDN_RECONNECTION_TO_THIS_APN_DISALLOWED, EGTP_CAUSE_ACCESS_CHANGED_FROM_NON_3GPP_TO_3GPP, EGTP_CAUSE_PDN_CONN_INACTIVITY_TIMER_EXPIRED, EGTP_CAUSE_PGW_NOT_RESPONDING, EGTP_CAUSE_NETWORK_FAILURE, EGTP_CAUSE_QOS_PARAMETER_MISMATCH, EGTP_CAUSE_REQ_ACCEPTED, EGTP_CAUSE_REQ_ACCEPTED_PARTIALLY, EGTP_CAUSE_NEW_PDN_TYPE_NETWORK_PREFERENCE, EGTP_CAUSE_NEW_PDN_TYPE_SINGLE_ADDR_BEARER_ONLY, EGTP_CAUSE_CONTEXT_NOT_FOUND, EGTP_CAUSE_INVALID_MESSAGE_FORMAT, EGTP_CAUSE_VERSION_NOT_SUPPORTED_BY_NEXT_PEER, EGTP_CAUSE_INVALID_LENGTH, EGTP_CAUSE_SERVICE_NOT_SUPPORTED, EGTP_CAUSE_MANDATORY_IE_INCORRECT, EGTP_CAUSE_MANDATORY_IE_MISSING, EGTP_CAUSE_SYSTEM_FAILURE, EGTP_CAUSE_NO_RESOURCES_AVAILABLE, EGTP_CAUSE_SEMANTIC_ERROR_IN_TFT_OPERATION, EGTP_CAUSE_SYNTACTIC_ERROR_IN_TFT_OPERATION, EGTP_CAUSE_SEMANTIC_ERROR_IN_PKT_FILTERS, EGTP_CAUSE_SYNTACTIC_ERROR_IN_PKT_FILTERS, EGTP_CAUSE_MISSING_OR_UNKNOWN_APN, EGTP_CAUSE_UNEXPECTED_REPEATED_IE, EGTP_CAUSE_GRE_KEY_NOT_FOUND, EGTP_CAUSE_REALLOCATION_FAILURE, EGTP_CAUSE_DENIED_IN_RAT, EGTP_CAUSE_PREFERRED_PDN_TYPE_UNSUPPORTED, EGTP_CAUSE_ALL_DYNAMIC_ADDR_OCCPUPIED, EGTP_CAUSE_UE_CTX_WO_TFT_ALREADY_ACTIVATED, EGTP_CAUSE_PROTOCOL_TYPE_NOT_SUPPORTED, EGTP_CAUSE_UE_NOT_RESPONDING, EGTP_CAUSE_UE_REFUSES, EGTP_CAUSE_SERVICE_DENIED, EGTP_CAUSE_UNABLE_TO_PAGE_UE, EGTP_CAUSE_NO_MEMORY_AVAILABLE, EGTP_CAUSE_USER_AUTHENTICATION_FAILED, EGTP_CAUSE_APN_DENIED_NO_SUBSCRIPTION, EGTP_CAUSE_REQUEST_REJECTED, EGTP_CAUSE_PTMSI_SIGNATURE_MISMATCH, EGTP_CAUSE_IMSI_IMEI_NOT_KNOWN, EGTP_CAUSE_SEMANTIC_ERROR_IN_TAD_OPERATION, EGTP_CAUSE_SYNTACTIC_ERROR_IN_TAD_OPERATION, EGTP_CAUSE_RESERVED_MESSAGE_VALUE_RECEIVED, EGTP_CAUSE_PEER_NOT_RESPONDING, EGTP_CAUSE_COLLISION_WITH_NETWORK_INIT_REQUEST, EGTP_CAUSE_UNABLE_TO_PAGE_UE_DUE_TO_SUSPENSION, EGTP_CAUSE_CONDITIONAL_IE_MISSING, EGTP_CAUSE_INCOMPATIBLE_APN_REST_TYPE, EGTP_CAUSE_INVALID_LENGTH_WITH_PIGGYBACK_MSG, EGTP_CAUSE_DATA_FORWARDING_NOT_SUPPORTED, EGTP_CAUSE_INVALID_REPLY_FROM_REMOTE_PEER, EGTP_CAUSE_FALLBACK_TO_GTPV1, EGTP_CAUSE_INVALID_PEER, EGTP_CAUSE_TEMP_REJECTED_DUE_TO_HANDOVER_IN_PROGRESS, EGTP_CAUSE_REQ_REJECTED_FOR_PMIPV6_REASON, EGTP_CAUSE_APN_CONGESTION, EGTP_CAUSE_BEARER_HANDLING_NOT_SUPPORTED, EGTP_CAUSE_UE_ALREADY_REATTACHED, EGTP_CAUSE_MULTI_PDN_CONNECTION_FOR_APN_NOT_ALLOWED, EGTP_CAUSE_MME_SGSN_REFUSES_DUE_TO_VPLMN_POLICY, EGTP_CAUSE_GTPC_ENTITY_CONGESTION, EGTP_CAUSE_TARGET_ACCESS_RESTRICTED_FOR_THE_SUBSCRIBER, EGTP_CAUSE_UE_TEMP_NOT_REACHABLE_DUE_TO_POWER_SAVING, EGTP_CAUSE_RELOC_FAILURE_DUE_TO_NAS_MSG_REDIRECTION, EGTP_CAUSE_MISSING_TIMESTAMP_OPTION, EGTP_CAUSE_MULTIPLE_HNP_NOT_ALLOWED, EGTP_CAUSE_SN_MALFORMED_MSG, EGTP_CAUSE_INT_TIMEOUT, cbr_fail_upstate_inactive, ubr_fail_upstate_inactive, mbc_retransmit_msg, change_notification_retransmit_msg
  • Label: qos_5qi
    Label Description: 5Qi applicable for the QoS flow
    Example: 1, 2, 5
  • Label: rat_type
    Label Description: Type of the radio access associated with the request
    Example: EUTRA, NR, WLAN, rat_type_unknown
  • Label: smf_current_procedure
    Label Description: Current Procedure Name for Message Level Stats
    Example: nr_to_untrusted_wifi_handover, eps_fb_ded_brr, PdnDisconnectProcedure, enb_to_untrusted_wifi_handover, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, smf_initiated_pdn_detach, untrusted_wifi_to_enb_handover, upf_sess_report_srir_sess_rel, utn3gpp_to_5g_handover
Gy Online charging destination host change statistics Category
ocs_dest_host_change_stats
Description: Statistics for charging destination host change
Sample Query: 'sum (ocs_dest_host_change_stats)'
Gy Online charging reporting reason statistics Category
ocs_reporting_reason_stats
Description: Statistics for reporting reason to OCS
Sample Query: 'sum (ocs_reporting_reason_stats{Reporting_Reason="THRESHOLD"})'
Labels:
    Example: Any string
    Example: Any string
  • Label: Reporting_Reason
    Label Description: Type of 3GPP reporting reason from OCS
    Example: THRESHOLD, QHT, FINAL, QUOTA_EXHAUSTED, VALIDITY_TIME, OTHER_QUOTA_TYPE, RATING_CONDITION_CHANGE, FORCED_REAUTHORISATION, POOL_EXHAUSTED
Gz Offline CDR drop statistics Category
ofcs_cdr_drop_stats
Description: Statistics for CDR drop with trigger reason
Sample Query: 'sum (ofcs_cdr_drop_stats{TriggerType="final-cdr"})'
Labels:
  • Label: procedure_type
    Label Description: The procedure name associated with a call flow procedure
    Example: Any string
  • Label: TriggerType
    Label Description: Trigger reason
    Example: final-cdr", "external-trigger-cdr", "internal-trigger-cdr
  • Label: dnn
    Example: cisco.com
Gz Offline CDR message statistics Category
ofcs_cdr_message_stats
Description: Statistics for CDR message with record closure reason to OFCS
Sample Query: 'sum (ofcs_cdr_message_stats{record_closure_reason="normalRelease"})'
Labels:
    Label Description: gtpp profile name used for bearer
    Example: Any string
  • Label: RuleBase
    Label Description: RuleBase name used for bearer
    Example: Any string
  • Label: record_closure_reason
    Label Description: CDR closure reason
    Example: normalRelease", "abnormalRelease", "cAMELInitCallRelease", "volumeLimit", "timeLimit", "servingNodeChange", "maxChangeCond", "managementIntervention", "intraSGSNIntersystemChange", "rATChange", "mSTimeZoneChange","sGSNPLMNIDChange
  • Label: dnn
    Example: cisco.com
    Example: GZ_SECONDARY_RAT_USAGE_LIMIT_REACHED
Gz Offline SDF Containers statistics Category
ofcs_sdf_container_stats
Description: Statistics for SDF Container with service condition change to OFCS
Sample Query: 'sum (ofcs_sdf_container_stats{service_condition_change="PdpContextRelease"})'
Labels:
  • Label: service_condition_change
    Label Description: Service condition Change for SDF container
    Example: QoSChange", "SgsnChange", "SgsnPlmnIdChange", "TariffTimeSwitch", "PdpContextRelease", "RatChange", "ServiceIdleOut", "ConfigurationChange", "ServiceStop", "DccaTimeThresholdReached", "DccaVolumeThresholdReached", "DccaServiceSpecificUnitThresholdReached", "DccaTimeExhausted", "DccaVolumeExhausted", "DccaValidityTimeout", "DccaReauthorisationRequest", "DccaContinueOngoingSession", "DccaRetryAndTerminateOngoingSession", "DccaTerminateOngoingSession", "CgiSaiChange", "RaiChange", "DccaServiceSpecificUnitExhausted", "RecordClosure", "TimeLimit", "VolumeLimit", "ServiceSpecificUnitLimit", "EnvelopeClosure", "EcgiChange", "TaiChange", "UserLocationChange
  • Label: dnn
    Example: cisco.com
Incoming Message Throttling Statistics Category
smf_inc_msg_throttling_stats
Description: Stats of throttled incoming messages
Sample Query: 'smf_inc_msg_throttling_stats{message_type="S5S8CreateSessReq"}'
Labels:
  • Label: interface
    Label Description: Interface Type
    Example: S5, S8, S2B
  • Label: message_type
    Label Description: Message type corresponding to given interface
    Example: S5S8CreateSessReq, S5S8DeleteSessReq, S5S8ModifyBearerReq, S5S8ModifyBearerCmd, S5S8BearerResourceCmd, S5S8DeleteBearerCmd
  • Label: Cause
    Label Description: Cause of Message Throttling
    Example: EGTP_CAUSE_GTPC_ENTITY_CONGESTION
Sample Query: 'nf_endpoint_selections_total{nf_type="amf", host="http://10.105.227.109:8082/nnrf-nfm/v1", req="initial"}'
Labels:
  • Label: nf_type
  • Label: host
  • Label: req
Sample Query: 'nf_failure_handling_stats_total{nf_type="amf", host="http://10.105.227.109:8082/nnrf-nfm/v1", req="initial", response="202", status="final"}'
Labels:
  • Label: nf_type
  • Label: host
  • Label: req
  • Label: response
  • Label: status
Sample Query: 'nf_management_total_time{host="http://10.105.227.109:8082/nnrf-nfm/v1", direction="outbound", message_type="registration",result="timeouOrRPCError" }'
Labels:
  • Label: host
  • Label: direction
  • Label: result
Sample Query: 'nf_management_stats_total{host="http://10.105.227.109:8082/nnrf-nfm/v1", direction="outbound", message_type="registration",result="timeouOrRPCError" }'
Labels:
  • Label: host
  • Label: direction
  • Label: result
Sample Query: 'nf_discover_events_total{nf_type="pcf", response_type="local"}'
Labels:
  • Label: nf_type
PDU UE Sync Procedure Category
pdu_ue_sync_proc
Description: PDU UE Sync Procedure counter
Sample Query: 'pdu_ue_sync_proc{status="attempted"}'
Labels:
  • Label: status
    Label Description: call flow procedure status counter
    Example: attempted, success, failures, suspend, resume, abort
Policy control ADC pcc rule statistics Category
policy_adc_total
Description: PCC Rule total statistics for ADC
Sample Query: 'sum (policy_adc_total{app_id="abc"})'
Labels:
  • Label: app_id
    Label Description: ADC Application ID for pcc rule
    Example: Any string
  • Label: mute
    Label Description: Mute for ADC rule
  • Label: operation
    Label Description: Operation performed on the ADC pcc rule
    Example: install, modify, remove
  • Label: event
    Label Description: Event associated with the operation performed on the ADC pcc rule
    Example: attempted, success, failure, abort
    Example: Any string
    Example: pcf, pcrf
Policy control NRF fail action statistics Category
policy_msg_nrf_fail_action
Description: NRF fail action stats for policy messages
Sample Query: 'sum (policy_msg_nrf_fail_action{policy_control_msg="SmPolicyCreate"})'
Labels:
  • Label: policy_control_msg
    Label Description: Type of policy control message
    Example: SmPolicyCreate, SmPolicyUpdate, SmPolicyDelete
  • Label: policy_nrf_action
    Label Description: NRF failure action
    Example: ignore, continue, terminate
  • Label: pcf_end_point
    Label Description: PCF IP Address
    Example: 10.84.17.11
    Example: pcf, pcrf
Policy control PCF update statistics Category
policy_pcf_updates_total
Description: Statistics for triggers sent to PCF in SmPolicyUpdate Request to PCF
Sample Query: 'sum (policy_pcf_updates_total{trigger="rat_change"})'
Labels:
  • Label: trigger
    Label Description: Trigger sent in the policy update request sent to PCF
    Example: ue_ip_change, plmn_change, res_mod_req, access_type_change , ue_ip_change , credit_mon_sess_fail , def_qos_change , sess_ambr_change , no_credit , serving_area_change , revalidation_timeout ,resoure_release,resource_alloc, rat_change
    Label Description: Current procedure associated with the operation performed on the pcc rule
    Example: pdn_sess_create, pdu_sess_create, smf_initiated_pdn_detach, disc_pdurel_smf_init_release, pcf_req_pdu_sess_mod, pcf_req_ded_brr_mod, enb_to_untrusted_wifi_handover, untrusted_wifi_to_enb_handover, nr_to_untrusted_wifi_handover, utn3gpp_to_5g_handover, xn_handover, n26_4g_to_5g_handover, pdn_5g_4g_handover, n26_4g_to_5g_im_mobility
    Example: pcf, pcrf
Policy control active PCF statistics Category
session_policy_type_total
Description: Stats for PCF active Sessions
Sample Query: 'sum (session_policy_type_total{policy_type="local"})'
Labels:
  • Label: policy_type
    Label Description: Policy type
    Example: local, pcf
  • Label: pcf_address
  • Label: access_type
    Label Description: Access type
    Example: Ipv4PduSession, Ipv6PduSession, Ipv4V6PduSession
    Example: pcf, pcrf
Policy control current flow Category
policy_pdu_flows_current
Description: QoS flow current counts
Sample Query: 'sum (policy_pdu_flows_current{flow_type="gbr"}) by(qos_5qi, arp)'
Labels:
  • Label: rat_type
    Example: nr, WLAN, EUTRA
  • Label: ssc_mode
    Label Description: SSC mode for the session which created the QoS flow
    Example: one, two, three
  • Label: pdn_type
    Label Description: PDN type of the session which created the QoS flow
    Example: v4, v6, v4v6
  • Label: dnn
    Example: cisco.com
  • Label: flow_type
    Label Description: Flow type for the QoS flow
    Example: gbr, non_gbr
  • Label: qos_5qi
    Example: 1, 2, 5
  • Label: arp
    Label Description: Priority level of ARP applicable for the QoS flow
    Example: 10, 20
    Example: pdn_sess_create, pdu_sess_create, pcf_req_pdu_sess_mod, pcf_req_ded_brr_mod, enb_to_untrusted_wifi_handover, untrusted_wifi_to_enb_handover, nr_to_untrusted_wifi_handover, utn3gpp_to_5g_handover, xn_handover, n26_4g_to_5g_handover, pdn_5g_4g_handover, n26_4g_to_5g_im_mobility
    Example: pcf, pcrf
  • Label: mapped_flow
    Label Description: flow has mapped 5Qi or not
    Example: true , false
    Label Description: policy type for the subscriber session
    Example: pcrf,pcf,optimized,local_policy
Policy control dynamic pcc rule statistics Category
policy_dynamic_pcc_rules_total
Description: PCC Rule total statistics for dynamic rules pushed from PCF
Sample Query: 'sum (policy_dynamic_pcc_rules_total{rule_id="Rule-1"}) by(qos_5qi, arp)'
Labels:
  • Label: rule_id
    Label Description: Rule Id for the received dynamic pcc rule
    Example: PccRule-1
  • Label: operation
    Label Description: Operation performed on the dynamic pcc rule
  • Label: event
    Label Description: Event associated with the operation performed on the pcc rule
  • Label: qos_5qi
    Label Description: 5Qi applied on the dynamic pcc rule
    Example: 1, 2, 5
  • Label: arp
    Label Description: Priority level of ARP applied on the dynamic pcc rule
    Example: 10, 20
  • Label: tc_event
    Label Description: Traffic Control event applied on the dynamic pcc rule
    Example: enabled_ul, enabled_dl, enabled, disabled, removed
  • Label: charging_type
    Label Description: Charging type applied on the dynamic pcc rule
    Example: online, offline, online-offline
  • Label: charging_method
    Label Description: Charging method applied on the dynamic pcc rule
    Example: volume, time, vol_time
  • Label: details
    Label Description: Details on the operation applied on the dynamic pcc rule
    Example: success, failed, validation_failed
  • Label: pccrule_change_type
    Label Description: pcc rule parameter change type
    Example: NA, binding_param_change, no_binding_param_change
    Example: pcf, pcrf
  • Label: is_adc
    Label Description: Type of rule is ADC or Non-ADC
  • Label: mute
    Label Description: Mute is enabled or disabled for ADC rule
  • Label: rule_fail_reason
    Label Description: PCC Rule Fail Reason
    Example: Rulebase is inactive, Rulebase is not configured, Predefined rule is inactive, Predefined rule is not configured, Pcc Rule recvd w/o RefQos, Pcc Rule recvd with invalid RefQos, Delete Pcc Rule recvd with policy create, Pcc Rule Does not exist, Pcc Rule recvd with reserved precedence, Pcc Rule name and id mismatch, Pcc Rule id is invalid, Pcc Rule recvd with invalid flow direction, Pcc Rule recvd without expected RefQos, Pcc Rule recvd Max filters(16) overflow, Max supported filters reached, Pcc Rule recvd with mismatch RefQoS, Pcc Rule recvd with unexpeted qos desc, Skipped due to Charging Description validation, Pcc Rule recvd with missing charging descriptor, Pcc Rule recvd with invalid charging desc, Qos Desc unexpected content, Pcc Rule recvd with multiple RefQos, Pcc Rule recvd without Flow Information, Pcc Rule recvd with RefQos having invalid, binding params, Sess Rule recvd w/o sess rule id, Sess Rule recvd w/o uplink AMBR, Sess Rule recvd w/o downlink AMBR, Sess Rule recvd with non standard 5QI, Sess Rule Auth def Qos recvd w/o ARP, Sess Rule and Auth def Qos mismatch, Sess Rule Auth def Qos recvd from non default flow, Sess Rule Auth def Qos QCI present in other Qos Desc, Sess Rule name and id mismatch, ARP recvd with invalid params, Flow desc recvd with invalid format(Invalid ipaddr class), Expected format: permit <direction> <protocol> from <Srouce IP> <Srouce Port> to <Dest IP> <Dest Port>, Flow desc recvd with action not supported, Flow desc recvd with direction not supported, Flow desc recvd with protocol not supported, Flow desc recvd with protocol missing, Flow desc recvd with remote IP or mask invalid, Flow desc recvd with source IP or mask invalid, Flow desc invert modifier not allowed, Flow desc assigned not supported for remote IP, Qos Desc Qos ID mismatch, Qos Desc recvd with Non Std 5QI, Qos Desc recvd with Non invalid bitrate, Qos Desc MBR value should be more than GBR value, Qos Desc recvd with invalid QoSID, Qos Desc recvd w/o ARP, Received exisiting Qos Desc with different binding parameters, Policy Trig lastreq data unavailable, Charging Desc not referred by any PCC Rule Or referred by invalid PCC Rule, Received Charging Id different from charging desc map key, Charging Desc not referred by any PCC Rule Or referred by invalid PCC Rule, Received Charging Id not referred by any PCC Rule, Existing Charging Desc unsupported modify, Invalid Input, Missing Charging ID information from Charging Descriptor, Missing RatingGroup information for Charging Id, Neither Online nor Offline charging method is enabled for charging descriptor Missing Service ID inforamtion for Charging Desc, Missing Service ID inforamtion for Charging Desc, URR ID not found for rating group, URR ID not found for rating group and service ID, Received Charging Desc conflicts with another charging descriptor, Charging Desc skipped due to Pcc Rule, Conflicting with dynamic chargng descriptor, Duplicate report function data invalid, IsMatching function data invalid, Conflicting RG service ID, PCC Rule Dropped due to charging association, Last Rule data not available, PCC Rule Invalid due to Ref TC Data, TC ID - Name mismatch, Missing Redirect Server address, Invalid Address Type, Session Rule recvd with Invalid 5QI, Qos Desc recvd with Invalid 5QI, Pcc Rule recvd with RefQos having invalid Flow for Non-Std QCI, Received Qos Desc with different Flow parameters between same flow for Non-Std QCI, Received exisiting Qos Desc with different Flow parameters for Non-Std QCI, Received Std-QCI Non-Gbr Flow with GBR value, Received Std-QCI Gbr Flow without GBR value, Predefine Pcc Rule recvd without AppID but its configs as ADC Rule, Predefine Pcc Rule recvd with AppID but its configs as Non-ADC Rule, Application Id change is not supported for Predefine Pcc Rule, PCC Rule rcvd with missing rule name, PCC Rule rcvd with invlaid Flow Description, PCC Rule rcvd with Invalid ToS Traffic Class, PCC Rule rcvd with Invalid SecurityParameterIndex, PCC Rule rcvd with Invalid Flow Label, PCC Rule rcvd with missing precedence, PCC Rule rcvd with missing QoS Information, PCC Rule rcvd with missing QCI in QoS Information, PCC Rule rcvd with invalid or unsupported QCI in QoS Information, PCC Rule rcvd with missing ARP priority level in QoS Information, PCC Rule rcvd with invalid ARP priority level, PCC Rule rcvd with invalid reporting level, PCC Rule rcvd with invalid flow status, Def Bearer Qos received with missing QCI, Def Bearer Qos received with invalid or unsupported QCI, Def Bearer Qos received with invalid ARP priority level, Invalid BCM received, Failure due Result Code AVP, Failure due to Experimental Result Code AVP, Invalid or Missing Supported Feature AVP, Usage Monitoring data instance is not defined, Invalid Usage Monitoring data referenced in Sess or PCC rule, Pcc Rule recvd with invalid refUmData, Sess Rule recvd with invalid refUmData, Gx Session release cause received, ADC Rule rcvd with both AppID and Flow Info, ADC Rule rcvd with AppID not present in config, ADC Rule rcvd with TDF App ID Modification, ADC Rule rcvd without Mute Notification, ADC Rule rcvd with invalid Mute Notification, Non-ADC Rule rcvd with TDF App ID Modification
Policy control message statistics Category
policy_msg_processing_status
Description: Policy message handling Stats
Sample Query: 'sum (policy_msg_processing_status{policy_notification_msg="SmPolicyUpdateNotify"})'
Labels:
  • Label: policy_notification_msg
    Label Description: Policy message type
    Example: SmPolicyUpdateNotify, SmPolicyTerminate, SmPolicyCreate, SmPolicyUpdate, SmPolicyDelete
  • Label: msg_status
    Label Description: Policy processing message status
    Example: accepted, rejected, skipped, attempted, failed, exp_attempted, exp_accepted, exp_rejected, exp_failed
  • Label: rat_type
    Label Description: RAT type of the flow
  • Label: result
    Label Description: result of policy message processing
    Example: cfg_issue, max_outsatnding, send_failure, timeout, proc_timeout, rc_with_err, ex_rc_with_err, none
  • Label: policy_fh_action
    Label Description: Policy CHF action
    Example: continue, terminate, none
  • Label: policy_fh_subaction
    Label Description: Policy CHF subaction
    Example: discard_traffic, local_fallback, retryserver_on_event, sendccrt_call_term, with_term_req, without_term_req, none
  • Label: interface_type
    Example: pcf, pcrf
  • Label: sess_rel_cause
    Label Description: Session release cause received from policy server in policy response or policy request
    Example: unspecified, ue_subscription, insuff_server_res, ip_can_sess_term, ue_ip_addr_rel
  • Label: termination_cause
    Label Description: Termination cause sent in terminate request towards policy server
    Example: logout, service_not_provided, bad_answer, administrative, link_broken, auth_expired, user_moved, session_timeout
Policy control pre-defined pcc rule statistics Category
policy_predefined_pcc_rules_total
Description: PCC Rule total statistics for pre-defined rules activated by PCF
Sample Query: 'sum (policy_predefined_pcc_rules_total{rule_id="Rule-1"}) by(event, operation)'
Labels:
  • Label: rulebase
    Label Description: Rulebase to which this pre-defined rule belongs
    Example: Rulebase-1
  • Label: operation
    Label Description: Operation performed on the pre-defined pcc rule
  • Label: event
    Label Description: Event associated with the operation performed on the pre-defined rule
  • Label: qos_5qi
    Label Description: 5Qi applied on the pre-defined pcc rule
    Example: 1, 2, 5
  • Label: arp
    Label Description: Priority level of ARP applied on the pre-defined pcc rule
    Example: 10, 20
    Label Description: Charging type applied on the pre-defined pcc rule
    Label Description: Charging method applied on the pre-defined pcc rule
    Example: pcf, pcrf
Policy control rule report statistics Category
pcf_rule_report_stats
Description: Statistics for Rule Report sent to PCF
Sample Query: 'sum (pcf_rule_report_stats{pcf_rule_report_fail_code="INCOR_FLOW_INFO"})'
Labels:
  • Label: pcf_rule_report_fail_code
    Label Description: Failure code sent in RuleReport
    Example: INCOR_FLOW_INFO
    Example: pcf, pcrf
Policy control session rule statistics Category
policy_session_rules_total
Description: Session total statistics for session rules applied
Sample Query: 'sum (policy_session_rules_total{rule_id="SessRule-1"})'
Labels:
  • Label: rule_id
    Label Description: Rule Id for the received session rule from PCF
    Example: SessRule-1
  • Label: operation
    Label Description: Operation performed on the session rule
  • Label: event
    Label Description: Event associated with the operation performed on the rulebase
    Example: pcf, pcrf
Policy control static pcc rule statistics Category
policy_static_pcc_rules_total
Description: PCC Rule total statistics for static rules activated via rulebase
Sample Query: 'sum (policy_static_pcc_rules_total{rulebase="Rulebase-1"})'
Labels:
  • Label: rulebase
    Label Description: Rulebase to which the static rules belong
    Example: Rulebase-1
  • Label: operation
    Label Description: Operation performed on the rulebase
    Example: install, remove
  • Label: event
    Example: pcf, pcrf
Policy control total flow statistics Category
policy_pdu_flows_total
Description: QoS flow total statistics
Sample Query: 'sum (policy_pdu_flows_total{flow_type="gbr"}) by(qos_5qi, arp)'
Labels:
  • Label: operation
    Label Description: Operation performed on the QoS flow
  • Label: event
    Label Description: Event associated with the operation performed on QoS flow
  • Label: rat_type
  • Label: ssc_mode
  • Label: pdn_type
  • Label: dnn
    Example: cisco.com
  • Label: flow_type
  • Label: init_or_ho
    Label Description: Flow operation phase
    Example: initial, ho
  • Label: qos_5qi
    Example: 1, 2, 5
  • Label: arp
    Example: 10, 20
    Example: pcf, pcrf
policy_qci_reject
Description: This metrics gets generated based on the flow rejection due to a 5QI configuration in the rejection list.
Sample Query: 'sum (policy_qci_reject {}) by(qos_5qi)'
Labels:
  • Label: qos_5qi
    Label Description: Displays the number of times the 5QIs are rejected.
    The value of qos_5qi ranges between 1 and 255.
    Example: 4,78
Policy destination host change statistics Category
policy_pcrf_dest_host_change
Description: Statistics for Policy destination host change
Sample Query: 'sum (policy_pcrf_dest_host_change{gr_instance_id="1"})'
Labels:
  • Label: gr_instance_id
    Label Description: GR instance ID
    Example: Any string
    Example: pcf, pcrf
Radius Authentication Message Stats Category
radius_authentication_message_stats
Description: Stats for Radius Authentication messages
Sample Query: 'radius_authentication_message_stats{radius_auth_algorithm="radius_auth_algorithm_pap"}'
Labels:
  • Label: dnn
    Label Description: name of the dnn associated with the request
    Example: Any string
  • Label: radius_auth_algorithm
    Label Description: Radius Authentication Algorithm used
    Example: radius_auth_algorithm_pap, radius_auth_algorithm_chap, radius_auth_algorithm_mschap, radius_auth_algorithm_default
  • Label: status
    Label Description: Radius Auth message status
    Example: attempted, success, encode_failed, decode_failed, failed
  • Label: reason
    Example: timeout, parse_error, invalid_code, invalid_pco, invalid_apco, invalid_epco, write_error
  • Label: rat_type
Radius Message stats Category
smf_radius_message_stats
Description: Stats for Radius interface messages
Sample Query: 'smf_radius_message_stats{message_type="radius_access_request"}'
Labels:
  • Label: direction
    Example: inbound, outbound
    Label Description: Radius Message Type
    Example: radius_access_request, radius_access_accept
  • Label: radius_avp_type
    Label Description: Radius AVP Type
    Example: radius_avp_pap_username, radius_avp_pap_user_password, radius_avp_chap_challenge, radius_avp_chap_response, radius_avp_mschap_challenge, radius_avp_mschap_response, radius_avp_idle_timeout, radius_avp_session_timeout
  • Label: rat_type
SLA Transaction Category
smf_sla_transaction_stats
Description: Transaction SLA stats
Sample Query: sum(smf_sla_transaction_stats) by (smf_sla_transaction_stats,smf_proc_type,status, message_type)
Labels:
  • Label: smf_proc_type
    Label Description: Procedure Name
    Example: PDU Session Release - SMF initiated, PDU 5G to 4G Handover, PDU Session Modify - PCF initiated, PDU UE Sync Procedure, PDU Idle Mode Entry - RAN initiated, PDN Session Modify - PCRF initiated
  • Label: status
    Label Description: gives status of the procedure
    Example: Queued, Running, Aborted, Suspended, Invalid, Cleanedup, RequireSuspend, RequireCleanup, RequireAbort, Unknown
    Label Description: gives the message type received during sla transaction
    Example: IntSelfTxnSla
SMF ADC URR Statistics Category
smf_pfcp_adc_report_stats
Description: The current count of PFCP adc reports towards PCF
Sample Query: 'smf_pfcp_adc_report_stats{adc_report_type="async"}'
Labels:
  • Label: adc_report_type
    Label Description: Synchronus adc report or Asynchronous adc report
    Example: async, sync
  • Label: status
    Label Description: ADC report status
    Example: dropped, processed
SMF ALWAYS ON PDU SESSION Category
smf_always_on_session_stats
Description: Always On Pdu Session Statistics
Sample Query: 'smf_always_on_session_stats{status="pdusetup_req_alwayson_requested"}'
Labels:
  • Label: status
    Label Description: always on status statistics
    Example: pdusetup_req_alwayson_requested, pdusetup_acc_alwayson_allowed, pdusetup_acc_alwayson_not_allowed, pdumod_req_alwayson_requested, pdumod_cmd_alwayson_allowed, pdumod_cmd_alwayson_not_allowed, pdumod_cmd_nw_init_alwayson_allowed, pdu_utwifi_to_nr_alwayson_requested, pdu_utwifi_to_nr_alwayson_allowed, pdu_utwifi_to_nr_alwayson_not_allowed
  • Label: rat_type
    Example: EUTRA, NR, WLAN, VIRTUAL, rat_type_unknown
  • Label: pdu_type
    Label Description: pdu connection type
    Example: ipv4, ipv6, ipv4v6, unknown
  • Label: dnn
    Example: Any string
  • Label: ssc_mode
    Label Description: Type of ssc mode associated with the request
    Example: ssc_mode_1, ssc_mode_2, ssc_mode_3, ssc_mode_unknown
SMF Charging Descriptor Delete Stats Category
smf_chrg_desc_del_stats
Description: The current count of charging descriptors deleted because of all associate Rule Ids are deleted
Sample Query: 'smf_chrg_desc_del_stats{rating_group="10"}'
Labels:
  • Label: charging_id
    Label Description: Charging Descriptor Identifier
    Example: Any string
  • Label: rating_group
    Label Description: Rating Group for which charging descriptors is dropped
    Example: Any string
  • Label: configured
    Label Description: Configured signifies if a Rule Id is configured or is dynamic
  • Label: reason
    Label Description: Reason for the charing descriptor delete
    Example: Error string value
SMF Charging Descriptor Drop Stats Category
smf_chrg_desc_drop_stats
Description: The current count of charging descriptors dropped due to validation error on Rule Id
Sample Query: 'smf_chrg_desc_drop_stats{rating_group="10"}'
Labels:
    Example: Any string
  • Label: service_identifier
    Label Description: Service Identifier for which charging descriptors is dropped
    Example: Any string
  • Label: action
    Label Description: Action with respect to Rule Id
    Example: add, mod, del
  • Label: configured
    Label Description: Configured signifies if Rule Id is configured or is dynamic
  • Label: reason
    Label Description: Reason for the charging descriptor drop
SMF Charging Failure Handling Stats Category
chf_failure_handling_stats
Description: Statistics for application error received from CHF
Sample Query: 'chf_failure_handling_stats{appl_err_code="HTTP_STATUS_CODE_403_FORBIDDEN"}'
Labels:
  • Label: http2_err_code
    Label Description: HTTP2 error code received from CHF
    Example: HTTP_STATUS_CODE_403_FORBIDDEN
  • Label: appl_err_code
    Label Description: Application error code received from CHF
    Example: END_USER_REQUEST_REJECTED, QUOTA_LIMIT_REACHED,CHARGING_FAILED, USER_UNKNOWN, END_USER_REQUEST_DENIED, QUOTA_LIMIT_REACHED, CHARGING_NOT_APPLICABLE
  • Label: fh_action
    Label Description: Action taken on failure from CHF
    Example: Terminate, Drop Traffic, Disable Charging
  • Label: fh_exchg_type
    Label Description: CHF Exchange in which failure occurred
    Example: update, initial
  • Label: disposition
    Label Description: SMF action on failure
    Example: disable-charging, drop-traffic, terminate, convert-offline, allocate-max-quota
    Label Description: The procedure type associated with an call flow procedure
SMF Charging Message Stats Category
chf_message_stats
Description: Charging Message Statistics
Sample Query: 'chf_message_stats{procedure_type="charging_initial"}'
Labels:
    Label Description: Charging message type
    Example: charging_initial, charging_update, charging_terminate
  • Label: dnn
    Example: cisco.com
  • Label: status
    Label Description: Status of OOO usage report processing
    Example: attempted, success, timeout
  • Label: rat_type
  • Label: chf_type
    Example: N40, Gy
SMF Charging OOO Usage Report Stats Category
smf_ooo_usage_report
Description: The current count for OOO usage report
Sample Query: 'smf_ooo_usage_report{procedure_type="pdu_sess_create"}'
Labels:
  • Label: dnn
    Example: cisco.com
  • Label: status
SMF Charging PFCP usage Report Stats Category
smf_pfcp_usage_report_stats
Description: The current count of PFCP usage reports towards CHF
Sample Query: 'smf_pfcp_usage_report_stats{usage_report_type="async"}'
Labels:
  • Label: usage_report_type
    Label Description: Synchronus usage report or Asynchronous usage report
  • Label: status
    Label Description: Usage report status
    Example: recieved, dropped, ignored, processed
  • Label: usage_report_discard_reason
    Label Description: Reason for usage report rejection
    Example: uuc_encd_cond_not_met, charg_parm_not_found, start_of_traffic_rcvd, ignore_rule_base_urr, no_valid_trgr_present, ignore_immd_trgr, urr_not_present, no_term_and_drop_traffic, onlinerpt_false_or_drop_traffic, mandatory_ie_incorrect, session_ctxt_not_found, radius_accounting, radius_accounting_not_enabled, urr_or_radius_accounting_missing
SMF Charging Quota Event Stats Category
chf_quota_event_stats
Description: The current count for quota event received from CHF
Sample Query: 'chf_quota_event_stats{quota_type="initial"}'
Labels:
    Label Description: Rating group for which quota is received from CHF
    Example: Any string
  • Label: quota_type
    Label Description: Quota type as received from CHF
    Example: initial, update, initial_final, update_final, fail
  • Label: quota_method
    Label Description: Quota method received from CHF
    Example: time, volume, time_volume
  • Label: quota_status
    Label Description: Result for the quota received from CHF
    Example: SUCCESS, END_USER_SERVICE_DENIED, QUOTA_MANAGEMENT_NOT_APPLICABLE, QUOTA_LIMIT_REACHED, END_USER_SERVICE_REJECTED, RATING_FAILED
  • Label: quota_fail_action
    Label Description: Action on quota failure
    Example: No Action , Disable charging, Drop Traffic, Offline Converted
    Label Description: Service Identifier for CHF quota event
    Example: Any string
SMF Charging Radius Accounting Message Stats Category
radius_accounting_message_stats
Description: SMF Radius accounting message stats
Sample Query: 'radius_accounting_message_stats{procedure_type="radius_initial"}'
Labels:
    Label Description: Charging Radius message type
    Example: radius_initial, radius_update, radius_terminate
  • Label: dnn
    Example: cisco.com
  • Label: status
    Label Description: Status of Radius charging message processing
  • Label: reason
    Label Description: Reason for Radius message failure
    Example: error, reject, timeout, invalid_arg
  • Label: rat_type
SMF Charging Session Limit Dynamic Stats Category
chf_sess_limit_dynamic_stats
Description: SMF Charging Session Limit stats
Sample Query: 'chf_sess_limit_dynamic_stats{chf_sess_limit_dyn_reason="chf_sess_limit_dyn_del_all_trig_disabled"}'
Labels:
  • Label: chf_sess_limit_dyn_reason
    Label Description: Reason for Charging session limit stats
    Example: chf_sess_limit_dyn_del_all_trig_disabled, chf_sess_limit_dyn_del_vol_time_nil, chf_sess_limit_dyn_add_in_cdru
SMF Charging Usage Report Stats Category
chf_usage_report_stats
Description: The current count for usage reports towards CHF
Sample Query: 'chf_usage_report_stats{charging_method="offline"}'
Labels:
    Label Description: Rating Group for which usage is being reported
    Example: Any string
    Label Description: Service Identifier for which usage is being reported
    Example: Any string
    Label Description: Metering method for the PDU Session
    Example: online, offline, online_offline
  • Label: charging_trigger_type
    Label Description: Trigger for usage report
    Example: QUOTA_THRESHOLD, QHT, FINAL, QUOTA_EXHAUSTED, VALIDITY_TIME, OTHER_QUOTA_TYPE, FORCED_REAUTHORISATION, UNIT_COUNT_INACTIVITY _TIMER, ABNORMAL_RELEASE, QOS_CHANGE, VOLUME_LIMIT, TIME_LIMIT, EVENT_LIMIT, PLMN,CHANGE, USER_LOCATION_CHANGE, RAT_CHANGE, UE_TIMEZONE_CHANGE, TARIFF_TIME_CHANGE, MAX_NUMBER_OF_CHANGES_IN_CHARGING_CONDITIONS, MANAGEMENT_INTERVENTION, CHANGE_OF_UE_PRESENCE_IN_PRESENCE_REPORTING_AREA, CHANGE_OF_3GPP_PS_DATA_OFF_STATUS, SERVING_NODE_CHANGE, REMOVAL_OF_UPF, ADDITION_OF_UPF, START_OF_SERVICE_DATA_FLOW, AMBR_CHANGE
SMF Charging Zero Usage Report Stats Category
chf_zero_usage_report_stats
Description: The current count for usage reports dropped due to zero usage
Sample Query: 'chf_zero_usage_report_stats{measurement_type="volume"}'
Labels:
  • Label: measurement_type
    Label Description: Measurement type
    Example: volume, duration, duration-volume
SMF DB Marshal Category
smf_db_marshal_stats
Description: SMF DB marshal stats
Sample Query: sum(smf_db_marshal_stats) by (module)
Labels:
  • Label: module
    Label Description: module type counter
    Example: policy, charging, upserv, access, generic
SMF Data Consistency Check Category
smf_datacheck_stats
Description: Total number of sessions checked for consistency
Sample Query: 'smf_datacheck_stats{rat_type="NR", status="failed"}'
Labels:
  • Label: rat_type
  • Label: pdu_type
    Label Description: Type of PDU session
  • Label: status
    Label Description: Procedure status after data consistency check
  • Label: reason
    Label Description: Failure reason of data inconsistency
    Example: invalid_n4_data_in_txn_start, invalid_n4_data_in_txn_end, invalid_n7_data_in_txn_start, invalid_n7_data_in_txn_end, invalid_n40_data_in_txn_start, invalid_n40_data_in_txn_end
SMF Disconnect stats Category
smf_disconnect_stats
Description: SMF Disconnect stats counters
Sample Query: 'smf_disconnect_stats{reason="disc_pdurel_amf_init_detach"}'
Labels:
  • Label: rat_type
    Label Description: RAT Type of the Session
  • Label: reason
    Label Description: The reason associated with an call disconnect
    Example: disc_pdusetup_create_over_create, disc_pdusetup_release_over_create, disc_pdusetup_admin_clear, disc_pdusetup_n1_decode_failure, disc_pdusetup_n1_content_not_found, disc_pdusetup_sess_abs_timeout, disc_pdusetup_sess_idle_timeout, disc_pdusetup_sess_cp_idle_timeout, disc_pdusetup_sess_default_flow_only_timeout, disc_pdusetup_ssc_mode_not_supported, disc_pdusetup_ssc_mode_denied, disc_pdusetup_identity_conflict, disc_pdusetup_pdutype_unsupported, disc_pdusetup_pdutype_denied, disc_pdusetup_snssai_denied, disc_pdusetup_dnn_denied, disc_pdusetup_iwf_denied, disc_pdusetup_subscription_denied, disc_pdusetup_dnn_not_supported, disc_pdusetup_dnn_not_supported_in_slice, disc_pdusetup_network_failure, disc_pdusetup_pdu_sess_does_not_exist, disc_init_chg_data_err, disc_pdusetup_ip_alloc_failed, disc_pdusetup_static_ip_alloc_failed, disc_pdusetup_pdu_fetch_failure, disc_pdusetup_udm_reg_failed, disc_pdusetup_udm_sub_fetch_failure, disc_pdusetup_udm_sub_fetch_resp_failed, disc_pdusetup_udm_sub_notify_failed, disc_pdusetup_upf_setup_cause_not_accepted, disc_pdusetup_secondary_auth_failed, disc_pdusetup_secondary_auth_resp_failed, disc_pdusetup_sm_cxt_invalid, disc_pdusetup_sm_cxt_invalid_ie, disc_pdusetup_sm_cxt_sess_id_err, disc_pdusetup_sm_cxt_invalid_json, disc_pdusetup_sm_cxt_n1_process_failed, disc_pdusetup_sm_cxt_man_param_missing, disc_pdusetup_pcf_create_exchg_failure, disc_pdusetup_pcf_create_rsp_failure, disc_pdusetup_rm_exchg_failure, disc_pdusetup_rm_rsp_failure, disc_pdusetup_pcf_update_exchg_failure, disc_pdusetup_pcf_update_rsp_failure, disc_chf_data_exchg_failure, disc_chf_data_rsp_failure, disc_pdusetup_upf_setup_exchg_failure, disc_pdusetup_upf_setup_rsp_failure, disc_pdusetup_n1n2_transfer_exchg_failure, disc_pdusetup_n1n2_transfer_rsp_failure, disc_pdusetup_n2_setup_failed, disc_pdusetup_ue_init_release, disc_pdusetup_amf_assign_ebi_failure, disc_pdusetup_upf_modify_exchg_failure, disc_pdusetup_upf_modify_rsp_failure, disc_pdusetup_upf_modify_failed, disc_pdusetup_upf_serv_data_nill, disc_pdusetup_upf_dl_tunnel_info_not_found, disc_pdusetup_upf_tunnel_id_not_found, disc_pdusetup_upf_mod_gnb_tun_params_failed, disc_pdusetup_upf_mod_rsra_tun_params_failed, disc_pdusetup_upf_mod_tun_param_tos-failed, disc_pdusetup_smf_mop_offline, disc_pdusetup_sm_context_nssai_not_supported, disc_pdusetup_sm_context_network_failure, disc_pdusetup_lbo_rejected, disc_pdusetup_home_route_not_supported, disc_pdusetup_internal_error, disc_pdusetup_plmn_not_supported, disc_pdurel_amf_sends_ue_not_found, disc_pdusetup_dnn_missing, disc_pdusetup_udm_dnn_missing, disc_pdusetup_resource_mgr_rsp_failed, disc_pdusetup_apply_wps_failed, disc_pdurel_ue_init_release, disc_pdurel_amf_init_release, disc_pdurel_amf_init_release_404, disc_pdurel_amf_init_release_mod_req, disc_pdurel_pcf_reconciliation, disc_rel_chf_err, disc_pdurel_pcf_init_release, disc_pdurel_udm_init_release, disc_pdurel_gnb_init_release, disc_pdurel_smf_init_release, disc_pdurel_upf_init_association_release, disc_pdurel_radius_init_release, disc_pdurel_upf_init_path_failure, disc_pdurel_upf_recovered, disc_pdurel_config_change, disc_db_conflict_release, disc_pdurel_pcf_reconciliation, disc_n2ho_n4_modify_failed, disc_n2ho_failure, disc_n2ho_guard_timer_expiry, disc_n2ho_idft_timer_expiry, disc_n26_4g_5g_ho_n4_modify_failed, disc_n26_4g_5g_im_mobility_n4_modify_failed, disc_pdumodify_context_not_found, disc_pdumodify_invalid_pdu_sess_identity, disc_pdurelease_invalid_pdu_sess_identity, disc_pduim_context_not_found, disc_n26_4g_5g_ho, disc_n26_5g_4g_ho, disc_n26_5g_4g_ho_timer_expired_post_exec, disc_n26_4g_5g_ho_udm_reg_failed, disc_n26_5g_4g_ho_mbr_failed, disc_pdusetup_upf_rule_creation_mod_failure, disc_non3gpp_utn_5g_ho, disc_5gtonon3gpp_utn_ho, disc_4g_non3gpp_utn_ho, disc_non3gpp_utn_4g_ho, disc_enb_wifi_ho_failed, disc_utn3gpp_5g_ho_failed, disc_sess_report_srsr_pdu_sess_rel, disc_pdn_ue_init_release, disc_pdn_mme_init_release, disc_pdn_chf_reconciliation, disc_pdn_pcf_reconciliation, disc_pdn_pcf_init_release, disc_pdn_pcf_fallback, disc_pdn_udm_init_release, disc_pdn_chf_init_release, disc_pdn_upf_init_release, disc_admin_init_release, disc_sess_time_exp_release, disc_sess_cp_idle_time_exp_release, disc_session_recreate, disc_gtpc_peer_pathfail, disc_gtpc_peer_restart, disc_upf_init_path_failure, disc_transaction_timedout, disc_upf_recovered, disc_sgw_ctx_failure, disc_pdn_internal_release, disc_reason_unknown,, disc_pdnsetup_iwk_5gs_flag_false, disc_pdnsetup_pduid_init_failed, disc_pdnsetup_csr_invalid, disc_pdnsetup_udm_reg_failed, disc_pdnsetup_udm_reg_req_create_failed, disc_pdnsetup_udm_rpc_failed, disc_pdnsetup_udm_dnn_missing, disc_pdnsetup_udm_reg_resp_failed, disc_pdnsetup_udm_sub_fetch_failed, disc_pdnsetup_udm_sub_fetch_resp_failed, disc_pdnsetup_udm_sub_notify_failed, disc_pdnsetup_udm_sub_notify_resp_failed, disc_pdnsetup_udm_sgw_u_teid_missing, disc_pdnsetup_secondary_auth_failed, disc_pdnsetup_secondary_auth_resp_failed, disc_pdnsetup_secondary_auth_ip_addr_conflict, disc_pdnsetup_pcf_create_failed, disc_pdnsetup_pcf_create_resp_failed, disc_pdnsetup_pcf_update_req_create_failed, disc_pdnsetup_pcf_update_exchg_failed, disc_pdnsetup_pcf_update_resp_failed, disc_pdnsetup_resource_mgr_exchg_failed, disc_pdnsetup_resource_mgr_resp_failed, disc_pdnsetup_upf_sess_setup_exchg_failed, disc_pdnsetup_upf_sess_setup_resp_failed, disc_pdnsetup_upf_sgw_tunnelid_error, disc_pdnsetup_upf_local_fteid_error, disc_pdnsetup_ssc_mode_denied, disc_pdnsetup_pdu_type_denied, disc_pdnsetup_pdu_type_not_supported, disc_pdnsetup_ssc_mode_not_supported, disc_pdnsetup_subscription_denied, disc_pdnsetup_smf_mop_offline, disc_pdnsetup_plmn_not_supported, disc_pdnsetup_non5gcapableue_not_allowed, disc_pdnsetup_default_flow_only_timeout, disc_affinity_add_error, disc_pdnsetup_sgwctx_brr_data_invalid, disc_ue_int_n1_5g_sm_status, disc_pdu_ctx_not_found, disc_internal_affinity_add_error, upf_sess_report_gter_pdn_sess_rel, upf_sess_report_srir_pdn_sess_rel, upf_sess_report_spter_pdn_sess_rel, upf_sess_report_srsr_pdn_sess_rel, upf_sess_report_erir_pdn_sess_rel, upf_sess_report_upir_pdn_sess_rel, disc_sess_report_srsr_pdn_sess_rel, disc_originatingEntity_request_timed_out, disc_new_pdn_type_due_to_single_addr_bearer_only, disc_new_pdn_type_due_to_network_preference, disc_pdnsetup_dnn_missing_or_unknown, disc_request_timeout_at_originating_entry, disc_pdusetup_integrity_protected_mdr_not_acceptable, disc_pdnsetup_upip_status_req_denied_in_rat, disc_pdn_pcrf_init_release, disc_pdnsetup_pcrf_create_resp_failed, disc_pdnsetup_charging_create_resp_failed, disc_vsmf_insert_dtssa_acscr_not_configured, disc_vsmf_insert_interplmn_ho_not_configured, disc_vsm_insert_hsmf_retrieve_failure, disc_ro2ho_n2ho_interplmn_ho_not_configured, disc_ro2ho_n4_modify_failed, disc_ho2ro_n4_modify_failed, disc_ho2ro_failure disc_ro2ho_failure, disc_ro2ho_guard_timer_expiry, disc_ho2ro_guard_timer_expiry
SMF EBI stats Category
smf_ebi_stats
Description: Stats for the EBI Assignement
Sample Query: 'smf_ebi_stats{status="success"}'
Labels:
    Example: pdusetup_ebi_assignment
  • Label: status
    Label Description: status of EBI Assignment
SMF IPAM Address Events Current Counter Category
IPAM_address_allocations_current
Description: Current state of SMF IPAM Address allocations
Sample Query: 'IPAM_address_allocations_current{dnn="dnn1",servingArea="area1",nssai="slice1",pool="p1",allocationType="dynamic",addressType="IPv4",upf="dp1",grInstId="1"}'
Labels:
  • Label: dnn
    Example: Any string
  • Label: servingArea
    Label Description: name of the serving area associated with the request
    Example: Any string
  • Label: nssai
    Label Description: name of the nssai associated with the request
    Example: Any string
  • Label: pool
    Label Description: name of the pool associated with the request
    Example: Any string
  • Label: allocationType
    Label Description: type of allocation associated with the request
    Example: static/dynamic
  • Label: addressType
    Label Description: address type associated with the request
    Example: IPv4/IPv6PD
  • Label: upf
    Label Description: upf identifier associated with the request
    Example: Any string
  • Label: grInstId
    Label Description: GR Instance ID
    Example: 1 or 2
SMF IPAM Address Events Total Counter Category
IPAM_address_events_total
Description: Total number of SMF IPAM Address events
Sample Query: 'IPAM_address_events_total{dnn="dnn1",servingArea="area1",nssai="slice1",pool="p1",eventType="Allocation",allocationType="dynamic",addressType="IPv4",upf="dp1",grInstId="1"}'
Labels:
  • Label: dnn
    Example: Any string
    Example: Any string
  • Label: nssai
    Example: Any string
  • Label: pool
    Example: Any string
  • Label: eventType
    Label Description: type of event associated with the request
    Example: Allocation/Release
  • Label: upf
    Example: Any string
  • Label: grInstId
    Example: 1 or 2
SMF IPAM Chunk Events Current Counter Category
IPAM_chunk_allocations_current
Description: Current state of SMF IPAM Address Chunk allocations
Sample Query: 'IPAM_chunk_allocations_current{dnn="dnn1",servingArea="area1",nssai="slice1",pool="p1",addressType="IPv4",upf="dp1",grInstId="1",forRemoteSmf="true"}'
Labels:
  • Label: dnn
    Example: Any string
    Label Description: name of the serving Area associated with the request
    Example: Any string
  • Label: nssai
    Example: Any string
  • Label: pool
    Example: Any string
  • Label: upf
    Example: Any string
  • Label: grInstId
    Example: 1 or 2
  • Label: forRemoteSmf
    Label Description: Indicates if chunk is reserved for Remote SMF
    Example: true/false
SMF IPAM Chunk Events Total Counter Category
IPAM_chunk_events_total
Description: Total number of SMF IPAM Address Chunk events
Sample Query: 'IPAM_chunk_events_total{dnn="dnn1",servingArea="area1",nssai="slice1",pool="p1",eventType="Allocation",addressType="IPv4",upf="dp1",grInstId="1",forRemoteSmf="true"}'
Labels:
  • Label: dnn
    Example: Any string
    Example: Any string
  • Label: nssai
    Example: Any string
  • Label: pool
    Example: Any string
  • Label: eventType
  • Label: upf
    Example: Any string
  • Label: grInstId
    Example: 1 or 2
    Example: true/false
SMF N1 Message stats Category
smf_n1_message_stats
Description: Stats for N1 Messages
Sample Query: 'smf_n1_message_stats{procedure_type="pcf_req_pdu_sess_mod"}'
Labels:
    Example: pdu_sess_create, ue_req_pdu_sess_mod, smf_req_pdu_sess_mod, pcf_req_pdu_sess_mod, udm_req_pdu_sess_mod, gnb_req_pdu_sess_mod, ue_req_pdu_sess_rel, smf_req_pdu_sess_rel, pcf_req_pdu_sess_rel, amf_req_pdu_sess_rel, udm_req_pdu_sess_rel, gnb_req_pdu_sess_rel, chf_req_pdu_sess_rel, admin_req_pdu_sess_rel, ue_req_active_to_idle, ue_req_idle_to_active, nw_req_service_active, upf_notify_downlink_data, xn_path_switch,pdn_sess_create,pdn_5g_4g_handover,pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, n2_handover, xn_handover, n26_4g_to_5g_handover, n26_4g_to_5g_im_mobility, pdu_im, pdn_sess_create, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, pcf_initiated_pdn_detach, smf_initiated_pdn_detach, upf_initiated_pdn_detach, smf_eps_fb
  • Label: direction
    Label Description: Direction of N1 message
    Example: outbound, inbound
    Label Description: The N1 message type
    Example: pdu_session_establishment_reject, pdu_session_release_request, pdu_session_modification_command_reject, pdu_session_modification_reject, pdu_session_release_reject, 5g_sm_status_msg_release, 5g_sm_status_msg_no_action, 5g_sm_status_msg_invalid_pti
  • Label: n1_cause
    Label Description: N1 cause assosiated with the message
    Example: OPERATOR_DETERMINED_BARRING, INSUFFICIENT_RESOURCES, MISSING_OR_UNKNOWN_DNN, UNKNOWN_PDU_SESSION_TYPE, USER_AUTHENTICATION_OR_AUTHORIZATION_FAILED, REQUEST_REJECTED_UNSPECIFIED, SERVICE_OPTION_NOT_SUPPORTED, REQUESTED_SERVICE_OPTION_NOT_SUBSCRIBED, SERVICE_OPTION_TEMPORARILY_OUT_OF_ORDER, PTI_ALREADY_IN_USE, REGULAR_DEACTIVATION, NETWORK_FAILURE, REACTIVATION_REQUESTED, SEMANTIC_ERROR_IN_THE_TFT_OPERATION, SYNTACTICAL_ERROR_IN_THE_TFT_OPERATION, INVALID_PDU_SESSION_IDENTITY, SEMANTIC_ERRORS_IN_PACKET_FILTER, SYNTACTICAL_ERROR_IN_PACKET_FILTER, OUT_OF_LADN_SERVICE_AREA, PTI_MISMATCH, PDU_SESSION_TYPE_IPV4_ONLY_ALLOWED, PDU_SESSION_TYPE_IPV6_ONLY_ALLOWED, PDU_SESSION_DOES_NOT_EXIST, INSUFFICIENT_RESOURCES_FOR_SPECIFIC_SLICE_AND_DNN, NOT_SUPPORTED_SSC_MODE, INSUFFICIENT_RESOURCES_FOR_SPECIFIC_SLICE, MISSING_OR_UNKNOWN_DNN_IN_A_SLICE, INVALID_PTI_VALUE, MAXIMUM_DATA_RATE_PER_UE_FOR_USER_PLANE_INTEGRITY_PROTECTION_IS_TOO_LOW, SEMANTIC_ERROR_IN_THE_QOS_OPERATION, SYNTACTICAL_ERROR_IN_THE_QOS_OPERATION, INVALID_MAPPED_EPS_BEARER_IDENTITY, SEMANTICALLY_INCORRECT_MESSAGE, INVALID_MANDATORY_INFORMATION, MESSAGE_TYPE_NON_EXISTENT_OR_NOT_IMPLEMENTED, MESSAGE_TYPE_NOT_COMPATIBLE_WITH_THE_PROTOCOL_STATE, INFORMATION_ELEMENT_NON_EXISTENT_OR_NOT_IMPLEMENTED, CONDITIONAL_IE_ERROR, MESSAGE_NOT_COMPATIBLE_WITH_THE_PROTOCOL_STATE, PROTOCOL_ERROR_UNSPECIFIED
SMF N2 Message stats Category
smf_n2_message_stats
Description: Stats for N2 Messages
Sample Query: 'smf_n2_message_stats{procedure_type="pcf_req_pdu_sess_mod"}'
Labels:
  • Label: direction
    Label Description: Direction of N2 message
  • Label: n2_Ngap_ie_type
    Label Description: The N2 Ngap IE type
    Example: N2_PDU_SESSION_RESOURCE_RELEASE_COMMAND_TRANSFER, N2_PDU_SESSION_PATH_SWITCH_REQUEST_TRANSFER, N2_INVALID_OR_UNSUPPORTED_NGAP_IE_TYPE, N2_PDU_SESSION_PATH_SWITCH_REQUEST_SETUP_FAILED_TRANSFER, N2_PDU_SESSION_RESOURCE_SETUP_UNSUCCESS_TRANSFER, N2_PDU_SESSION_RESOURCE_NOTIFY_RELEASED_TRANSFER, N2_PDU_SESSION_RESOURCE_MODIFY_UNSUCCESS_TRANSFER, N2_PDU_SESSION_HANDOVER_REQUEST_ACK_TRANSFER, N2_PDU_SESSION_HANDOVER_RESOURCE_ALLOC_UNSUCCESS_TRANSFER, N2_INVALID_OR_UNSUPPORTED_NGAP_TYPE, N2_PDU_SESSION_RESOURCE_SETUP_RESPONSE_TRANSFER
  • Label: n2_cause_group
    Label Description: The N2 Cause Group
    Example: NgapCauseGroupEnum_RadioNetworkCause, NgapCauseGroupEnum_TransportLayerCause, NgapCauseGroupEnum_NASCause, NgapCauseGroupEnum_ProtocolCause, NgapCauseGroupEnum_MiscCause, NgapCauseGroupEnum_NgapCauseGroupDummy
  • Label: n2_cause
    Label Description: N2 cause assosiated with the message
    Example: NgapCauseEnum_RadioNetwork_DummyEnum, NgapCauseEnum_RadioNetwork_Unspecified, NgapCauseEnum_RadioNetwork_TXnRELOCOverall_expiry, NgapCauseEnum_RadioNetwork_Successful_handover, NgapCauseEnum_RadioNetwork_Release_due_to_NG_RAN_generated_reason, NgapCauseEnum_RadioNetwork_Release_due_to_5GC_generated_reason, NgapCauseEnum_RadioNetwork_Handover_cancelled, NgapCauseEnum_RadioNetwork_Partial_handover, NgapCauseEnum_RadioNetwork_Handover_failure_in_target_5GC_NG_RAN_node_or_target_system, NgapCauseEnum_RadioNetwork_Handover_target_not_allowed, NgapCauseEnum_RadioNetwork_TNGRELOCoverall_expiry, NgapCauseEnum_RadioNetwork_TNGRELOCprep_expiry, NgapCauseEnum_RadioNetwork_Cell_not_available, NgapCauseEnum_RadioNetwork_Unknown_target_ID, NgapCauseEnum_RadioNetwork_No_radio_resources_available_in_target_cell, NgapCauseEnum_RadioNetwork_Unknown_local_UE_NGAP_ID, NgapCauseEnum_RadioNetwork_Inconsistent_remote_UE_NGAP_ID, NgapCauseEnum_RadioNetwork_Handover_desirable_for_radio_reasons, NgapCauseEnum_RadioNetwork_Time_critical_handover, NgapCauseEnum_RadioNetwork_Resource_optimisation_handover, NgapCauseEnum_RadioNetwork_Reduce_load_in_serving_cell, NgapCauseEnum_RadioNetwork_User_inactivity, NgapCauseEnum_RadioNetwork_Radio_connection_with_UE_lost, NgapCauseEnum_RadioNetwork_Radio_resources_not_available, NgapCauseEnum_RadioNetwork_Invalid_QoS_combination, NgapCauseEnum_RadioNetwork_Failure_in_the_radio_interface_procedure, NgapCauseEnum_RadioNetwork_Interaction_with_other_procedure, NgapCauseEnum_RadioNetwork_Unknown_PDU_Session_ID, NgapCauseEnum_RadioNetwork_Unknown_QoS_Flow_ID, NgapCauseEnum_RadioNetwork_Multiple_PDU_Session_ID_Instances, NgapCauseEnum_RadioNetwork_Multiple_QoS_Flow_ID_Instances, NgapCauseEnum_RadioNetwork_Encryption_and_or_integrity_protection_algorithms_not_supported, NgapCauseEnum_RadioNetwork_NG_intra_system_handover_triggered, NgapCauseEnum_RadioNetwork_NG_inter_system_handover_triggered, NgapCauseEnum_RadioNetwork_Xn_handover_triggered, NgapCauseEnum_RadioNetwork_Not_supported_5QI_value, NgapCauseEnum_RadioNetwork_UE_context_transfer, NgapCauseEnum_RadioNetwork_IMS_voice_EPS_fallback_or_RAT_fallback_triggered, NgapCauseEnum_RadioNetwork_UP_integrity_protection_not_possible, NgapCauseEnum_RadioNetwork_UP_confidentiality_protection_not_possible, NgapCauseEnum_RadioNetwork_Slice_not_supported, NgapCauseEnum_RadioNetwork_UE_in_RRC_INACTIVE_state_not_reachable, NgapCauseEnum_RadioNetwork_Redirection, NgapCauseEnum_RadioNetwork_Resources_not_available_for_the_slice, NgapCauseEnum_RadioNetwork_UE_maximum_integrity_protected_data_rate_reason, NgapCauseEnum_RadioNetwork_Release_due_to_CN_detected_mobility, NgapCauseEnum_RadioNetwork_N26_Interface_Not_Available, NgapCauseEnum_RadioNetwork_Release_Due_To_Pre_Emption, NgapCauseEnum_Transport_resource_unavailable, NgapCauseEnum_Transport_Unspecified, NgapCauseEnum_Nas_Normal_release, NgapCauseEnum_Nas_Authentication_failure, NgapCauseEnum_Nas_Deregister, NgapCauseEnum_Nas_Nas_Unspecified, NgapCauseEnum_Protocol_Transfer_syntax_error, NgapCauseEnum_Protocol_Abstract_syntax_error_reject, NgapCauseEnum_Protocol_Abstract_syntax_error_ignore_and_notify, NgapCauseEnum_Protocol_Message_not_compatible_with_receiver_state, NgapCauseEnum_Protocol_Semantic_error, NgapCauseEnum_Protocol_Abstract_syntax_error_falsely_constructed_message, NgapCauseEnum_Protocol_Proto_Unspecified, NgapCauseEnum_Misc_Control_processing_overload, NgapCauseEnum_Misc_Not_enough_user_plane_processing_resources, NgapCauseEnum_Misc_Hardware_failure, NgapCauseEnum_Misc_O_M_intervention, NgapCauseEnum_Misc_Unknown_PLMN, NgapCauseEnum_Misc_Unspecified, NgapCauseEnum_UP_integrity_protection_not_possible, NgapCauseEnum_Encryption_and_or_integrity_protection_algorithms_not_supported
  • Label: n2_fail_reason
    Label Description: N2 failure reason
    Example: None, N2 Decode Failed, Invalid N2 Container, upfServData is Nil, DL TunnelInfo is Not Found, UPF Tunnel ID lookup Failed, UPF MOD GNB Tunnel Params Failed, UPF MOD RSRA Tunnel Params Failed, UPF MOD Apply WPS Failed, MOD Tunnel LI Params Failed, Qos Mod Info Failed, Missing N2 SM Info, PDU Context Not Found, Default QFI (1) present in failed QosFlowList, RSRA Tunnel Recreation Failed For HO, Update QER Rule Map Failed, Rollback N2 Failed, Invalid Cause N2 SM Info, Mandatory IE incorrect in N2 SM Info, Xn HO Tobe Switch Flag Is Not Set in SmContextUpdateData, Invalid QFI List in PathSwitchRequest, QoS Flow Accepted List not found in XnHO, at least one Qfi to be accepted, PDU Session is Not Established, Missing T-gNB DL UP TunnelInfo, Missing S-gNB DL UP TunnelInfo, Default QFI is present in the Failed QFI List, N4 Session Modification failed, SLA Timeout
SMF Node Manager stats Category
smf_service_node_mgr_stats
Description: Stats for SMF Node Manager
Sample Query: 'smf_service_node_mgr_stats{ip_req_type="ip-alloc"}'
Labels:
  • Label: upf_ep_key
    Label Description: UPF Endpoint Key
    Example: IP String Value
  • Label: first_nodemgr_inst
    Label Description: First Nodemgr instance ID
    Example: unsigned integer
  • Label: second_nodemgr_inst
    Label Description: Second Nodemgr instance ID
  • Label: error
    Label Description: Error in case of Node Mgr failure
    Example: None, Both associated nodemgr instances are down, Second nodeMgr down and First NodeMgr responded with SmfRspFailure, Second nodeMgr down and First NodeMgr failed with IpcError, First NodeMgr responded with SmfRspFailure, First NodeMgr failed with IpcError, Second NodeMgr failed with IpcError, Second NodeMgr responded with SmfRspFailure
  • Label: retransmit
    Label Description: Is retransmit message
    Example: true, false
  • Label: ip_req_type
    Label Description: Type of IP request
    Example: ip-alloc, ip-dealloc, ip-static, ip-static-subscription, ip-static-radius
  • Label: pdu_type
SMF PCSCF Server Stats Category
smf_pcscf_server_stats
Description: Stats for SMF PCSCF Server
Sample Query: 'smf_pcscf_server_stats{PrimaryIPv4="1.2.3.4"}'
Labels:
  • Label: PrimaryIPv4
    Label Description: Primary PCSCF IPV4 address
    Example: 1.2.3.4
  • Label: SecondaryIPv4
    Label Description: Secondary PCSCF IPV4 address
    Example: 1.2.3.4
  • Label: TertiaryIPv4
    Label Description: Tertiary PCSCF IPV4 address
    Example: 1.2.3.4
  • Label: PrimaryIPv6
    Label Description: Primary PCSCF IPV6 address
    Example: IPv6 IP
  • Label: SecondaryIPv6
    Label Description: Secondary PCSCF IPV6 address
    Example: IPv6 IP
  • Label: TertiaryIPv6
    Label Description: Tertiary PCSCF IPV6 address
    Example: IPv6 IP
  • Label: ResolvedFrom
    Label Description: Info used to resolve PCSCF Address
    Example: DNS, LocalConfig
SMF PDU Status Category
smf_service_counters
Description: The current count of SMF pdu sessions
Sample Query: 'smf_service_counters{pdu_state="all_pdu"}'
Labels:
  • Label: pdu_state
    Label Description: PDU session status indicated by N3 UPF tunnel status
    Example: all_pdu, idle, connected
  • Label: rat_type
  • Label: dnn
    Label Description: Dnn configured in dnn-policy, also can have virtual_dnn if configured, separated by #
    Example: intershat, intershat#cisco.com
  • Label: roaming_status
    Label Description: Roaming status of the subscriber session
    Example: visitor-lbo, visitor-hr, roamer, homer, none
  • Label: ssc_mode
    Label Description: SSC Mode of the session
  • Label: flow_type
    Label Description: Indicates whether it's total bearer or dedicated bearer
    Example: dedicated_bearer, total_bearer
SMF Procedure Category
smf_service_stats
Description: SMF call flow procedure counters
Sample Query: 'smf_service_stats{procedure_type="pdu_sess_create"}'
Labels:
    Example: pdu_sess_create, ue_req_pdu_sess_mod, smf_req_pdu_sess_mod, pcf_req_pdu_sess_mod, udm_req_pdu_sess_mod, gnb_req_pdu_sess_mod, ue_req_pdu_sess_rel, smf_req_pdu_sess_rel, pcf_req_pdu_sess_rel, amf_req_pdu_sess_rel, udm_req_pdu_sess_rel, gnb_req_pdu_sess_rel, chf_req_pdu_sess_rel, admin_req_pdu_sess_rel, ue_req_active_to_idle, ue_req_idle_to_active, nw_req_service_active, upf_notify_downlink_data, xn_path_switch,pdn_sess_create,pdn_5g_4g_handover,pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, n2_handover, xn_handover, n26_4g_to_5g_handover, n26_4g_to_5g_im_mobility, pdu_im, pdn_sess_create, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, pcf_initiated_pdn_detach, smf_initiated_pdn_detach, upf_initiated_pdn_detach, smf_eps_fb, misc_pdu_sess_rel, pcrf_req_ded_brr_mod, pcrf_req_ded_brr_create, pcrf_req_ded_brr_delete, suspend_notification, resume_notification, change_notification, gx_validation_failure_pdn_sess_rel, smf_inter_plmn_ro2ho_n2ho, smf_inter_plmn_ho2ro_n2ho, smf_idft_inter_plmn_ro2ho_n2ho, smf_dft_inter_plmn_ro2ho_n2ho, smf_idft_inter_plmn_ho2ro_n2ho smf_dft_inter_plmn_ho2ro_n2ho
  • Label: status
    Label Description: call flow procedure counter
    Example: attempted, success, failures, pcrf_failure
  • Label: pdu_type
  • Label: dnn
  • Label: reason
    Label Description: Reason for failure status. For sucessess and attempted it will be Empty
    Example: proc_pdu_not_established, proc_pdu_ctx_not_found, n2ho_ie_validation_failed, n2ho_n4_ho_preparing_failed, n2ho_n4_ho_prepared_failed, n2ho_n4_ho_completed_failed, n2ho_ho_cancelled, n2ho_resource_alloc_unsuccess_transfer, n2ho_invalid_state, n2ho_preparation_unsuccess_transfer, n2ho_n1n2_transfer_failure, n2ho_dft_intra_amf, n2ho_dft_inter_amf, n2ho_idft_intra_amf, n2ho_idft_inter_amf, n2ho_default_flow_failed, n2ho_n2_decode_failiure, n2ho_chf_update_failure, n2ho_invalid_response, xnho_tobe_switched_flag_not_set, xnho_dl_tunnel_info_not_found, xnho_invalid_accepted_qfi_list, xnho_n4_modification_failed, xnho_n1n2_transfer_failure//NotUsedtoberemoved, xnho_n2_decode_failiure, xnho_pdu_state_error, n26ho_4g_5g_n1n2_transfer_failure, n26ho_4g_5g_invalid_state, n26ho_4g_5g_n4_failed_prepared_state, n26ho_4g_5g_resource_alloc_unsuccess_transfer, n26ho_4g_5g_timedout_in_post_exec_state, n26ho_4g_5g_n4_failed_completed_state, n26ho_4g_5g_handover_cancelled, n26ho_4g_5g_send_n4mod_failed_preparing_state, n26ho_4g_5g_n4mod_rsp_failed_preparing_state, n26ho_4g_5g_n4mod_rsp_timeout_preparing_state, n26ho_4g_5g_im_mobility_send_n4mod_failed, n26ho_4g_5g_im_mobility_n4mod_rsp_failed, n26ho_4g_5g_im_mobility_n4mod_rsp_timeout, n26ho_4g_5g_invalid_eps_pdn_connlist, n26ho_4g_5g_udm_reg_failed, n26ho_4g_5g_dft, n26ho_4g_5g_idft, n26ho_5g_4g_dft, n26ho_5g_4g_idft, n26ho_5g_4g_ctxrtrive_rec_for_4g_session, n26ho_5g_4g_handover_cancel, n26ho_4g_5g_no_eps_5gs_continuity, n26ho_default_flow_failed, n26ho_n2_decode_failiure, n26ho_chf_update_failure, n26im_mobility_4g_5g_no_eps_5gs_continuity, n26im_mobility_4g_5g_default_eps_bearer_inactive, pduim_n1n2_transfer_failure, pduim_n2_setup_response_failure, pduim_n1n2_txfr_failure_notification, pduim_n4_modification_failed, pduim_misc_error, pduim_n1n2ack_decode_error, pduim_n1n2ack_unhndl_cause, pduim_n1n2ack_unhndl_rsp_code, pduim_n1n2ack_unhndl_prb_cause, pduim_suspended_procedure, pduim_amf_ctx_not_found, pduim_internal_error, pduim_upstate_not_in_deactivated_state, pduim_pdu_access_type_mismatch, pduim_pdu_gnb_tunnel_not_available, pduim_pdu_n4_deactivated_state, pduim_sla_timer_expired, pduim_temp_reject_max_retry, upf_failure, pcf_failure, idft_release_failure, access_4g_already, idft_setup_failure, mbr_setup_failure, sgw_failure, udm_registration_failure, udm_subscription_fetch_failure, udm_subscribe_notify_failure, udm_update_notify_failure, aaa_subscribe_auth_failure, aaa_framed_ip_addr_conflict, pcf_create_failure, pcf_update_failure, charging_data_failure, no_rule_matched, invalid_protocol, invalid_dst_mask, invalid_src_mask, invalid_5qi, invalid_arp, invalid_other, internal_error, invalid_ebi, invalid_framed_ipv6_pfx_length, invalid_acct_sess_id_radius_dm, reason_unknown, invalid_rat_type, session_associated_to_online_chf, session_not_in_state, unknown, n4_release_failed, gtpu_peer_path_failed, rel_received_for_non_5g_session, qfi_failed_to_setup, utn3gppto5gho_n4_failed_completed_state, utn3gppto5gho_n4_failed_prepared_state, utn3gppto5gho_resource_alloc_unsuccess_transfer, utn3gppto5gho_invalid_state, utn3gppto5gho_policy_update_failure, utn3gppto5gho_charging_update_failure, utn3gppto5gho_n1n2_transfer_failure, utn3gppto5gho_pcf_update_failed_post_ho, utn3gppto5gho_chf_update_failed_post_ho, utn3gppto5gho_n4_failed_post_ho, utn3gppto5gho_del_bearer_failed, utn3gppto5gho_partial_flow_failure, utn3gppto5gho_default_flow_failed, utn3gppto5gho_eps_fallback, utn3gppto5gho_setup_unsuccess_transfer, utn3gppto5gho_fail_due_n2msg_rsp_not_rcvd, utn3gppto5gho_ctxt_create_res_failure, utn3gppto5gho_invalid_ctxt_create_req, utn3gpp_epsfallback_failed_during_5g_4g_ho, utn3gpp_epsfallback_failed_guard_timer_expiry, nr_to_untrusted_wifi_invalid_sess_state, nr_to_untrusted_wifi_invalid_json, nr_to_untrusted_wifi_invalid_paa, nr_to_untrusted_wifi_invalid_msg, nr_to_untrusted_wifi_pcf_failed, nr_to_untrusted_wifi_n40_failed, nr_to_untrusted_wifi_n4_failed, nr_to_untrusted_wifi_pcf_failed_post_cb, nr_to_untrusted_wifi_n40_failed_post_cb, nr_to_untrusted_wifi_n4_failed_post_cb, nr_to_untrusted_wifi_cbr_failed, nr_to_untrusted_wifi_ubr_failed, nr_to_untrusted_wifi_cb_res_failed, nr_to_untrusted_wifi_n1n2_release_failed, nr_to_untrusted_wifi_n4_failed_post_ho, nr_to_untrusted_wifi_pcf_update_failed_post_ho, nr_to_untrusted_wifi_chf_update_failed_post_ho, nr_to_untrusted_wifi_sla_timer_expired, nr_to_untrusted_wifi_dbr_failed, enb_to_untrusted_wifi_to_enb_ho_reject, enb_to_untrusted_wifi_to_enb_invalid_sess_state, enb_to_untrusted_wifi_to_enb_invalid_json, enb_to_untrusted_wifi_to_enb_invalid_paa, enb_to_untrusted_wifi_to_enb_invalid_msg, enb_to_untrusted_wifi_to_enb_udm_failed, enb_to_untrusted_wifi_to_enb_pcf_failed, enb_to_untrusted_wifi_to_enb_n40_failed, enb_to_untrusted_wifi_to_enb_n4_failed, enb_to_untrusted_wifi_to_enb_pcf_failed_post_cb, enb_to_untrusted_wifi_to_enb_mbr_failed, enb_to_untrusted_wifi_to_enb_n4_failed_post_mbr, enb_to_untrusted_wifi_to_enb_n40_failed_post_cb, enb_to_untrusted_wifi_to_enb_n4_failed_post_cb, enb_to_untrusted_wifi_to_enb_n40_failed_post_db, enb_to_untrusted_wifi_to_enb_pcf_failed_post_db, enb_to_untrusted_wifi_to_enb_cbr_failed, enb_to_untrusted_wifi_to_enb_dbr_failed, enb_to_untrusted_wifi_to_enb_ubr_failed, dsr_target_rat_rejected, upip_req_denied_in_rat, nr_to_untrusted_wifi_upip_status_req_denied_in_rat, pcrf_create_failure, cbr_fail_upstate_inactive, ubr_fail_upstate_inactive, pdnrel_conditional_ie_missing, pdn_create_over_created_pdn, interplmn_ho_not_configured, dtssa_acscr_not_supported, ho2ro_invalid_state, ro2ho_invalid_state, mbc_retransmit_msg, change_notification_retransmit_msg
  • Label: emergency_call
    Label Description: Flag indicating if it is an emergency call
  • Label: rat_type
    Example: EUTRA, NR, WLAN, rat_type_unknown
  • Label: up_state
    Label Description: Userplane connection status of the session
    Example: UpState_None, UpState_Establishing, UpState_Activating, UpState_Activated, UpState_Deactivating, UpState_Deactivated, UpState_Modifying, UpState_Deleting, UpState_Deleted
  • Label: qos_5qi
    Label Description: 5Qi applicable for the QoS flow
    Example: 1, 2, 5
  • Label: always_on
    Example: enable, disable
  • Label: dcnr
    Label Description: UE DCNR status
  • Label: smf_current_procedure
    Label Description: Current Procedure Name for Message Level Stats
    Example: DedBearerProc, eps_fb_ded_brr, ue_req_ded_brr_mod, udm_req_ded_brr_mod, smf_req_ded_brr_del, upf_req_ded_brr_del, mme_req_ded_brr_del, mme_req_ded_brr_mod, pcf_req_ded_brr_mod, pcf_req_ded_brr_create, pcf_req_ded_brr_delete
  • Label: fourg_only_ue
    Label Description: Only 4g capable UE flag
  • Label: pra
    Label Description: Presence Reporting Area Information
    Example: enable, none
  • Label: upip_active
    Label Description: UPIP activated for the session or not
  • Label: local_policy
    Label Description: Flows or Bearers created based on local policy config
SMF Procedure Collision Category
smf_procedure_collision
Description: Total number of procedures collided
Sample Query: sum(smf_procedure_collision) by (smf_current_procedure, smf_current_state, smf_new_procedure, smf_current_procedure_action)
Labels:
  • Label: smf_current_state
    Label Description: Current Procedure State
    Example: DEDICATED BEARER: Await N7 Policy Update, PDN5G4GHO: Await UPF Modify Response, 4G RELEASE: Idle, MODIFY: Await N2 Update, RELEASE: Await PCF Delete, SETUP: Post UPF Modify
  • Label: smf_new_procedure
    Label Description: New Procedure Name
  • Label: smf_current_procedure_action
    Label Description: Current Procedure Action on Collision
    Example: Ignore, Suspend, Resume, Abort, Cleanup, Continue, Ready, INVALID ACTION
SMF Procedure Total Time Statistics Category
smf_procedure_seconds
Description: Total number of seconds taken to complete the procedure
Sample Query: 'smf_procedure_seconds{smf_proc_status="Aborted"}'
Labels:
  • Label: smf_proc_status
    Label Description: Procedure Status
    Example: Queued, Running, Aborted, Suspended, Invalid, Cleanedup, RequireSuspend, RequireCleanup, RequireAbort, ProcStatusComplete, Unknown
SMF Protocol message counters Category
smf_proto_udp_msg_total
Description: SMF Protocol message statistics
Sample Query: 'smf_proto_udp_msg_total{message_direction="inbound",nf_type="amf"}'
Labels:
  • Label: message_name
    Label Description: name of N4 interface message
    Example: n4_session_establishment_req, n4_session_establishment_res, n4_session_modification_req, n4_session_modification_res, n4_session_report_req, n4_session_report_res, n4_session_deletion_req, n4_session_deletion_res, n4_association_setup_req, n4_association_setup_res, n4_association_update_req, n4_association_update_res, n4_association_release_req, n4_association_release_res, n4_prime_pfd_management_req, n4_prime_pfd_management_res, n4_heartbeat_req, n4_heartbeat_res, n4_node_report_req, n4_node_report_res
  • Label: message_direction
    Label Description: direction of message from SMF perspective
  • Label: status
    Label Description: status of message processing
    Example: accepted, denied, discarded
SMF RAN failed stats Category
smf_ran_failed_flows
Description: Stats for the failed QFIs sent in UE Sync
Sample Query: 'smf_ran_failed_flows{procedure_type="pdu_ue_sync_proc"}'
Labels:
  • Label: procedure_type
    Example: pdu_ue_sync_proc
  • Label: reason
    Label Description: The reason associated with failure
    Example: qfi_failed_to_setup
SMF RSRA stats Category
smf_service_rsra_stats
Description: Stats for SMF Service RSRA
Sample Query: 'smf_service_rsra_stats{rat_type="NR"}'
Labels:
    Label Description: The RSRA procedure type
    Example: router_advt_solicit_request, router_advt_unsolicit_request, router_solicit_request
  • Label: status
    Label Description: status of RSRA
    Example: failed, sent, retransmit, received
  • Label: rat_type
    Label Description: Type of the radio access associated with the request
  • Label: upf_ep_key
  • Label: reason
    Label Description: reason for the failed status
    Example: userplane_error, ho_in_progress, ipc_failed, userplane_error, encode_failed, decode_failed
SMF Secondary RAT Usage Report Stats Category
smf_secondary_rat_usage_report_stats
Description: Stats for SMF Secondary RAT Usage Report
Sample Query: 'smf_secondary_rat_usage_report_stats{rat_type="NR"}'
Labels:
  • Label: status
    Label Description: Status of Sec RAT Usage Report
    Example: ReceivedFromSgw
  • Label: reason
    Label Description: The reason associated with status
    Example: success
  • Label: rat_type
    Example: NR
  • Label: ebi
    Label Description: ebi number as string
    Example: unsigned int as string or NA
  • Label: qfi
    Label Description: qfi number as string
SMF Service Node Report Stats Category
smf_service_node_report_stats
Description: Stats for SMF Service Node Report
Sample Query: 'smf_service_node_report_stats{procedure_type="upf_node_report_pdu_sess_rel"}'
Labels:
    Label Description: The SMF procedure type
    Example: upf_node_report_pdu_sess_rel, upf_node_report_pdn_sess_rel
  • Label: status
    Label Description: Status of SMF Service Node Report
    Example: attempted, failures, success
  • Label: pdu_type
  • Label: rat_type
  • Label: up_state
  • Label: peer_gtpu_ep_key
    Label Description: GTP Peer
    Example: IP String
  • Label: upf_endpoint
SMF Service Resource Management Stats Category
smf_service_resource_mgmt_stats
Description: SMF Service Resource Management Stats
Sample Query: 'smf_service_resource_mgmt_stats{ip_req_type="ip-alloc",pdu_type="ipv4",dnn="dnn1"}'
Labels:
    Example: pdu_sess_create, ue_req_pdu_sess_mod, smf_req_pdu_sess_mod, pcf_req_pdu_sess_mod, udm_req_pdu_sess_mod, gnb_req_pdu_sess_mod, ue_req_pdu_sess_rel, smf_req_pdu_sess_rel, pcf_req_pdu_sess_rel, amf_req_pdu_sess_rel, udm_req_pdu_sess_rel, gnb_req_pdu_sess_rel, chf_req_pdu_sess_rel, admin_req_pdu_sess_rel, ue_req_active_to_idle, ue_req_idle_to_active, nw_req_service_active, upf_notify_downlink_data, xn_path_switch,pdn_sess_create,pdn_5g_4g_handover,pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, n2_handover, xn_handover, n26_4g_to_5g_handover, n26_4g_to_5g_im_mobility, pdu_im, pdn_sess_create, pcf_req_ded_brr_create, pcf_req_ded_brr_delete, pcf_req_ded_brr_mod, pcf_initiated_pdn_detach, smf_initiated_pdn_detach, upf_initiated_pdn_detach, smf_eps_fb, Cleanuplocal
  • Label: status
    Label Description: status of resource management request
  • Label: pdu_type
  • Label: dnn
    Example: Any string
  • Label: rat_type
SMF Service gtpc cache statistics Category
smf_service_gtpc_cache_stats
Description: SMF Service gtpc cache counters
Sample Query: 'smf_service_gtpc_cache_stats{gr_instance_id="1"}'
Labels:
    Example: eps_fb_ded_brr, ue_req_ded_brr_mod, udm_req_ded_brr_mod, smf_req_ded_brr_del, mme_req_ded_brr_del, mme_req_ded_brr_mod, mme_req_ded_brr_del, pcrf_req_ded_brr_create, pcf_req_ded_brr_create, pcrf_req_ded_brr_delete, pcf_req_ded_brr_delete, pcrf_req_ded_brr_mod, pcf_req_ded_brr_mod, ProcessNoStateMBR, suspend_acknowledgement
  • Label: message_type
    Label Description: GTPC Message Type
    Example: CreateBearerReq, UpdateBearerReq, DeleteBearerReq, ModifyBearerResp, DeleteSessionResp, ModifyBearerResp, CreateSessionResp, SuspendAck,
  • Label: gtpc_cache_operation
    Label Description: GTPC cache operation
    Example: add, delete
    Example: Any string
SMF Session counters Category
smf_session_counters
Description: SMF current active Session counters
Sample Query: 'smf_session_counters{rat_type="NR",pdu_type="ipv4",dnn="dnn1",ssc_mode="ssc_mode_1"}'
Labels:
  • Label: rat_type
  • Label: pdu_type
  • Label: dnn
  • Label: ssc_mode
  • Label: always_on
  • Label: dcnr
  • Label: unauthenticated_supi
    Label Description: indicates if SUPI is unauthenticated
  • Label: pra
  • Label: policy_type
    Label Description: Policy type of the subscriber session
    Example: pcf, pcrf, none
SMF Session stats Category
smf_session_stats
Description: SMF Session stats counters
Sample Query: 'smf_session_stats{rat_type="NR",pdu_type="ipv4",dnn="dnn1",ssc_mode="ssc_mode_1",status="attempted"}'
Labels:
  • Label: rat_type
  • Label: pdu_type
  • Label: dnn
  • Label: ssc_mode
  • Label: status
    Label Description: PDU session status indicated at SMF
    Example: attempted, success, setup
SMF Start Procedure Statistics Category
smf_procedure_start
Description: Total number of procedures started
Sample Query: 'smf_procedure_start{smf_proc_type="PDN Connect"}'
Labels:
SMF Stop Procedure Statistics Category
smf_procedure_stop
Description: Total number of procedures stopped
Sample Query: 'smf_procedure_stop{smf_proc_type="PDU Session Establishment"}'
Labels:
SMF Timeout stats Category
smf_timeout_stats
Description: SMF Timeout stats
Sample Query: 'smf_timeout_stats{timeout_type="SessionSetupTimeout"}'
Labels:
  • Label: timeout_type
    Label Description: SMF Timeout type
    Example: SessionSetupTimeout, SessionCallflowTimeout, SessionEpsFbTimeout, SessionPolicyRevalTimeout, SessionRsRaAdvTime, SessionModifyTimeout, SessionReleaseTimeout, SessionN2HoTimeout, SessionImTimeout, SessionDedBearerTimeout, SessionPdnSetupTimeout, SessionPdnDisconnectTimeout, SessionPdnModifyTimeout, SessionPduIdftTimeout, SessionPdu5G4GHandover, SessionNrToUnTrustWifiHOTimeout, Session4GWifi4GHOTimeout, SessionWifiTo4GHoMBReqTimeout, SessionRouterSolicitTimeout, SessionUsageReportTimeout, SessionPathSwitchTimeout, SessionN1N2RetryAfter, SessionPDUIMN1N2RetryAfter, SessionN2HoIdftTimeout, SessionN26HoIdftTimeout, SessionAbsoluteTimeout, SessionIwfN26IdftTimeout, SessionDedBrrReEstTimer, SessionDedBrrDelayTimer, Session4G5GN26Timeout, SessionN1N2RetryTimeout, SessionN1N2RetransTimeout, SessionPDUIMResumeTimeout, SessionUrrOutOfOrderWaitTimeout, SessionPduRelCmdRetryTimeout, SessionUnTrustWiFiToNrHOTimeout, SessionUbrRetryTimer, SessionDbrRetryTimer, SessionPduUeSyncTimeout, SessionAmfChangeGuardTimeout, SessionPduSetupProcSLA, SessionPduImProcSLA, ProcedureSlaTimeout, SessionN2HOProcSLA, SessionCatchAllTimeout, SessionIdleTimeout, SessionCpIdleTimeout, SessionTempRejectHoTimeout, SessionDefaultFlowOnlyTimeout, SessionErirDelayTimeout
SMF Total Procedure Count Category
smf_procedure_total
Description: Total number of procedures executed
Sample Query: 'smf_procedure_total{smf_proc_status="Running"}'
Labels:
SMF Total Timedout Procedure Count Category
smf_procedure_timeout
Description: Total number of procedures executed more than 10sec
Sample Query: 'smf_procedure_timeout{smf_proc_status="Running"}'
Labels:
SMF Total Timedout Procedure Time Category
smf_procedure_timeout_seconds
Description: Total number of seconds taken by procedures executed more than 10sec
Sample Query: 'smf_procedure_timeout_seconds{smf_proc_status="Running"}'
Labels:
SMF Total Unhandled Event Statistics Category
smf_procedure_unhndl_event
Description: Total number of unhandled events per procedure type
Sample Query: 'smf_procedure_unhndl_event{smf_proc_type="PDU Session Release - SMF initiated"}'
Labels:
    Label Description: Type of Request/Response Message associated with Unhandled Event
    Example: N11SmContextUpdateSuccess, N11EbiAssignmentReq, N4HeartBeatFailure, S5CreateSessRsp, NLiSubscriberQueryReq, RadiusCoaDisconnectReq, N7SmPolicyUpdateSuccess
  • Label: guard_timer
    Label Description: This is a check for Guard Timeout. TRUE if Guard Timer has expired, else FALSE
    Example: TRUE, FALSE
SMF Total Unhandled Transaction Statistics Category
smf_procedure_unhndl_trans
Description: Total number of unhandled transactions per procedure type
Sample Query: 'smf_procedure_unhndl_trans{message_type="RadiusCoaDisconnectReq"}'
Labels:
    Label Description: Type of Request/Response Message associated with Unhandled Transaction
SMF User Plane Session counters Category
smf_up_session_counters
Description: SMF current active User Plane Sessions
Sample Query: 'smf_up_session_counters{pdu_type="ipv4",dnn="dnn1",ssc_mode="ssc_mode_1"}'
Labels:
  • Label: rat_type
  • Label: pdu_type
  • Label: dnn
    Example: Any string
  • Label: ssc_mode
UDM Message Failure Action Stats Category
smf_udm_msg_fail_action
Description: Stats for UDM Message Failure Action
Sample Query: 'smf_udm_msg_fail_action{udm_msg="UdmRegistration"}'
Labels:
  • Label: udm_msg
    Label Description: Type of UDM Message
    Example: UdmRegistration, UdmDeregistration, UdmSmSubscription, UdmSubscribeToNotify, UdmUnSubscribeToNotify
  • Label: udm_failure_action
    Label Description: Action taken on UDM Message failure
    Example: ignore, continue, terminate
  • Label: udm_end_point
    Label Description: UDM Endpoint
    Example: IP String
UDP RPC message statistics Category
udp_rpc_msg_stats
Description: Statistics for UDP RPC
Sample Query: 'sum (udp_rpc_msg_stats{gr_instance_id="1"})'
Labels:
  • Label: msgtype
    Label Description: message Type
    Example: MessageNone, PfcpUdpProxyMsg, UdpProxyMsg, UnknownMsg
  • Label: direction
    Label Description: Direction of UDP RPC message
  • Label: status
    Example: success, failures
  • Label: transport_type
    Label Description: Transport type of message
    Example: original, asyncmessage, retransmited,
    Example: Any string
    Label Description: Type of Interface communicate with PGW
    Example: pcf, pcrf
UDP Request Total Message Stats Category
smf_service_udp_req_msg_total
Description: Stats for Total UDP Request Messages
Sample Query: 'smf_service_udp_req_msg_total{status="attempted"}'
Labels:
    Label Description: Type of UDP Message
    Example: N4SessionEstablishmentReq
  • Label: status
    Label Description: Status of UDP Message
  • Label: trans_type
    Label Description: Transmission type of UDP Message
    Example: trans_type_origin, trans_type_reselected
  • Label: cause_code
    Label Description: Causecode of UDP Message
    Example: Reserved, Request_Accepted, Request_Rejected_Unspecified, Session_Ctx_Not_Found, Mandatory_IE_Missing, Cond_IE_Missing, Invalid_Length, Mandatory_IE_Incorrect, Invalid_FW_Policy, Invalid_FTEID_Alloc_Opt, No_Established_PFCP_Assc, Rule_Creation_Mod_Failure, PFCP_Entity_In_Congestion, No_Resource_Available, Service_Not_Supported, System_failure, No_Response, Duplicate_Userplane_Id, OutOfRange_Userplane_Id
UPF selection stats Category
upf_selection_stats
Description: Stats for the UPF Selection
Sample Query: 'upf_selection_stats{upf_selection_type="preferred"}'
Labels:
  • Label: upf_selection_type
    Label Description: Type of UPF Selection
    Example: preferred
  • Label: upf_fqdn
    Label Description: FQDN of the UPF selected
    Example: string
  • Label: status
    Label Description: Status the UPF selected
    Example: attempted, failed
  • Label: reason
    Label Description: Reason for status of the UPF selected
    Example: upf_not_associated, upf_profile_not_found, upf_not_active
  • Label: dnn
    Example: Any string
  • Label: rat_type
  • Label: pdu_session_type
    Label Description: PDU Session type
  • Label: pdu_subscription_type
    Label Description: PDU Subscription type
  • Label: snssai
    Label Description: SNSSAI of the session having sd and sst
    Example: sd:<string> sst:<uint>
udp-proxy Metrics Reference
UDP-Proxy BGP Routes Count Category
upd_proxy_bgp_routes_count
Description: UDP Proxy BGP routes added count
Sample Query: 'upd_proxy_bgp_routes_count{service_name="udp-proxy", status="success"}'
Labels:
  • Label: status
    Label Description: Status of message while sending or receiving
    Example: success, failed
UDP-Proxy messages Category
udp_proxy_msg_total
Description: UDP Proxy message counters being recieved or sent
Sample Query: 'udp_proxy_msg_total{message_name="radius_request", message_direction="inbound", status="success"}'
Labels:
    Label Description: UDP messages coming via udp-proxy service
    Example: radius_request, radius_response, heartbeat_request, heartbeat_response
    Label Description: Message being sent or being received
  • Label: status
